  4. Test Adapter Awtrix-Light (Awtrix 3)
2.2k Beiträge 167 Kommentatoren 1.5m Aufrufe 141 Beobachtet
  • darkbluD darkblu
    @djmarc75 ,
    danke für die Belehrung, kommt nicht mehr vor, vielleicht
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    #1163
    @darkblu sagte in Test Adapter Awtrix-Light:
    Das ist keine Belehrung sondern sollte eigentlich klar sein ... und spar Dir die Ironie bitte.
    Lehrling seit 1975 !!!
    • Palm_ManiacP Offline
      Palm_Maniac
      #1164
      Eben ist es doch wieder passiert, ohne das ich was geschraubt habe.
      awtrix-light.0
      2023-08-17 10:24:10.976	error	Unable to perform action for apps.pv.visible - API is not connected (device not reachable?)
      awtrix-light.0
      2023-08-17 10:24:06.162	error	Unable to perform action for apps.pv.visible - API is not connected (device not reachable?)
      awtrix-light.0
      2023-08-17 10:23:57.768	error	Unable to perform action for apps.pv.visible - API is not connected (device not reachable?)
      awtrix-light.0
      2023-08-17 10:23:54.207	error	Unable to perform action for apps.pv.visible - API is not connected (device not reachable?)
      awtrix-light.0
      2023-08-17 10:23:53.024	error	Unable to perform action for apps.pv.visible - API is not connected (device not reachable?)
      awtrix-light.0
      2023-08-17 10:23:51.771	error	Unable to perform action for apps.pv.visible - API is not connected (device not reachable?)
      awtrix-light.0
      2023-08-17 10:23:42.396	error	Unable to perform action for apps.pv.visible - API is not connected (device not reachable?)
      awtrix-light.0
      2023-08-17 10:23:39.876	error	Unable to perform action for apps.pv.visible - API is not connected (device not reachable?)
      awtrix-light.0
      2023-08-17 10:23:33.913	error	Unable to perform action for apps.pv.visible - API is not connected (device not reachable?)
      awtrix-light.0
      2023-08-17 10:23:27.982	error	Unable to perform action for apps.pv.visible - API is not connected (device not reachable?)
      awtrix-light.0
      2023-08-17 10:23:25.548	error	Unable to perform action for apps.pv.visible - API is not connected (device not reachable?)
      awtrix-light.0
      2023-08-17 10:23:20.789	error	Unable to perform action for apps.pv.visible - API is not connected (device not reachable?)
      Das Interface der Ulanzi ist erreichbar. Es ist natürlich möglich, dass sich das Problem von selbst wieder gelöst hat, da seit 10:24Uhr keine neue Meldung mehr aufgelaufen ist. Leider hab ich es vorhin erst entdeckt und bis dahin schien es wohl wieder zu laufen.
      Ich hätte da noch etwas. Ich lasse unter anderem auch den Diesel-Preis unserer Lieblingstankstelle durchlaufen und wollte dazu noch den Preisverlauf anzeigen lassen. Leider wird mir da nur eine Flatline angezeigt, weil wahrscheinlich der abgebildete Zeitraum zu kurz ist. Was ich da bräuchte, wäre eine Darstellung von 6-12 Stunden. Läßt sich da was machen? Ich habe leider nichts gefunden, wo ich den Zeitraum für die Darstellung verändern könnte.
      arteckA haus-automatisierungH 2 Antworten Letzte Antwort
      • Palm_ManiacP Palm_Maniac
        awtrix-light.0
        awtrix-light.0
        awtrix-light.0
        awtrix-light.0
        awtrix-light.0
        awtrix-light.0
        awtrix-light.0
        awtrix-light.0
        awtrix-light.0
        awtrix-light.0
        awtrix-light.0
        awtrix-light.0
        arteckA Offline
        arteckA Offline
        arteck
        #1165
        @palm_maniac wie oft werden die daten von der PV app geändert ???
        bestimmt in sekunden takt..
        Palm_ManiacP 1 Antwort Letzte Antwort
        • arteckA arteck
          Palm_Maniac
          #1166
          @arteck Ja, aber ich habe im Adapter 3 Sekunden eingestellt. So genau muß es da nicht sein.
            arteckA Offline
            arteckA Offline
            arteck
            #1167
            @palm_maniac das klappt nicht... du musst immer die antwortzeit der Dose berücksichtigen...
            ich bin dazu übergegangen die Daten alle 1 min zu senden..
            es scheint als ob de Dose das nicht so schnell verarbeiten kann
            • arteckA arteck
              Palm_Maniac
              #1168
              @arteck Es lief aber alles durch, seit gestern bis heute morgen und vor dem Firmware-Update sogar über mehrere Tage mit dieser Konfig.
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                haus-automatisierungH Offline
                #1169
                @palm_maniac sagte in Test Adapter Awtrix-Light:
                Die Frage ist ja auch, warum Du alle paar Sekunden die Sichtbarkeit einer App ändern möchtest.
                📚 Meine Dokumentation
                  Palm_Maniac
                  #1170
                  @haus-automatisierung Die Apps schalten im 7-10 Sekunden Abstand durch, also doch wie das System selbst. Oder was meinst du?
                    #1171
                    @palm_maniac Laut Log wird der Datenpunkt apps.pv.visible ständig neu geschrieben.
                      Palm_Maniac
                      #1172
                      @haus-automatisierung Ah, das ist mein erster Versuch die PV-Anzeige bei 0W abzuschalten. Da muß ich nochmal optimierend ran.
                        #1173
                        Das kannst Du direkt auf der Custom App festlegen in den Instanzeinstellungen.
                        EDIT: Sorry, das geht in der Produktivversion ja noch gar nicht - habe das mit meinem Entwicklungsstand verwechselt
                        Palm_ManiacP K 2 Antworten Letzte Antwort
                          Palm_Maniac
                          #1174
                          @haus-automatisierung Deshalb hab ich nix gefunden und schon gedacht, ich bin blöd und blind. ;)
                          • C Offline
                            calliou1234
                            #1175
                            Gtuen Abend Zusammen,
                            sehr toller Adapter, vielen Dank dafür.
                            Versuche gerande ein paar Daten meiner PV Anlage anzuzeigen.
                            Leider zeigt die Ulanzi nix an.
                            Im log steht:
                            [initCustomApps] State value of custom app "pvleistung" (javascript.0.PV.PVLeistung) is not acknowledged (ack: false) - waiting for new value
                            Jemand ne Idee?
                            Thomas
                            :mrgreen:
                            • C calliou1234
                              Im log steht:
                              Jemand ne Idee?
                              Thomas
                              #1176
                              @calliou1234 sagte in Test Adapter Awtrix-Light:
                              Jemand ne Idee?
                              Es werden nur bestätigte Werte übermittelt.
                              • H Offline
                                Heinz2100
                                #1177
                                Hallo, erst einmal vielen Dank für den tollen Adapter. Gibt es die Möglichkeit die Icons einer App per Skript zu ändern? Ich denke da an Mondphasen, Wettericons oder auch Speicher-/Ladezustände des PV-Speichers. Tausend Dank
                                • FreunderNachtF Offline
                                  FreunderNacht
                                  #1178
                                  Hallo Mathias,
                                  es geht um folgende Einstellmöglichkeit im Adapter:
                                  Nach der Beschreibung unter dem Eingabefeld vermute ich mal, daß ich hier eine Zeit definieren kann, nach der der Adapter die Werte für die Apps abfragt.
                                  Ich habe diesen auf 10 Sekunden gestellt, trotzdem habe ich den Eindruck, daß die Werte in kürzeren Intervallen an die Ulanzia geschickt werden.
                                  Ich bekomme von meinem Senec Speicher in kürzeren Intervallen neue Werte und ich vermute stark, daß diese auch direkt weiter gegeben werden.
                                  Ich schaue mir das ganze aber nochmal im Debug Log an.
                                  Habe ich aber die Funktionen dieser Einstellung richtig interpretiert?
                                  Intel NUC mit Proxmox
                                  IO Broker (Homematic IP / CCU3 / Shelly / Tasmota / Zigbee)
                                  Influx DB
                                  Grafana
                                  PiHole
                                  PiVPN
                                  • H Heinz2100
                                    Kelzith
                                    #1179
                                    @heinz2100 Ich würde für jeden Zustand eine eigene App mit Icon erstellen und mit einem Script steuern welche angezeigt wird.
                                    H 1 Antwort Letzte Antwort
                                      FreunderNacht
                                      #1180
                                      mal eine Frage in die Runde.
                                      Ich habe aktuell bei mir 6 Apps mit einer Anzeigedauer von je 2 Sekunden am laufen.
                                      Wie sieht es bei euch aus?
                                      Influx DB
                                      Grafana
                                      PiHole
                                      PiVPN
                                      • K Kelzith
                                        Heinz2100
                                        #1181
                                        @kelzith So habe ich das auch verwirklicht, aber es wird sehr schnell sehr komplex (Stichwort Mondphasen). Es wäre eigentlich auch relativ leicht umsetzbar, wenn die Symbolzahl auch ein Datenpunkt statt Zahl sein könnte/dürfte.
                                        • darkbluD Offline
                                          darkbluD Offline
                                          darkblu
                                          #1182
                                          @haus-automatisierung ,
                                          könntest du mir bitte erklären, was es mit dieser Warnmeldung auf sich hat ?
                                          Ich lasse nun alle Datenpunkte per Blockly in eigene Datenpunkte schreiben, alle 45 Sekunden.
                                          Ich dachte die sekündliche live Abfrage wäre zu viel, scheinbar nicht.
                                          Das log ist trotzdem ruck zuck wieder voll mit dieser Meldung (für alle 8 Apps).
                                          Oder liegt es doch an der Signalstärke der Ulanzi ?
                                          Der RSSI schwankt so zwischen -62 und -72
                                          Vielen Dank
                                          Raspi 4, 4GB für Influxdb 1.8 und Grafana
                                          Raspi 5, 8 GB für ioBroker
                                          Threadnetzwerk per Apple
