  5. [gelöst] Payload Daten in Objekte schreiben
78 Beiträge 4 Kommentatoren 9.7k Aufrufe 2 Beobachtet
  • GregorSG GregorS
    Logstufe "Error"
    GregorSG Offline
    GregorSG Offline
    GregorS
    Hab auf Debug umgestellt.
    Jetzt kommt was.
    javascript.0
    	2023-07-22 18:34:43.750	info	script.js.LoRAWAN_DEV_1: undefined
    javascript.0
    	2023-07-22 18:34:43.749	info	script.js.LoRAWAN_DEV_1: {"end_device_ids":{"device_id":"eui-a840414601871305","application_ids":{"application_id":"gs-mg-dragino-01"},"dev_eui":"A840414601871305","join_eui":"A840410000000101","dev_addr":"260BE9CF"},"correlation_ids":["as:up:01H5Z784WHCPR9CKQMD6YA61PJ","gs:conn:01H5TF5M58SGAQZTB5B766P6EM","gs:up:host:01H5TF5M5DGPVSKX7RKJ1HPXFF","gs:uplink:01H5Z784NZ778FHQVN8ATABV4B","ns:uplink:01H5Z784P0FCGCHDWHMB7EZSAR","rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01H5Z784P0MKF1ZWAFJ9K7394H","rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01H5Z784WGE4FZ7ETJHPJJQ9DV"],"received_at":"2023-07-22T16:34:43.728419808Z","uplink_message":{"session_key_id":"AYlu5XV3aMaeiMVAq8yISw==","f_port":2,"f_cnt":4350,"frm_payload":"NgUAAAAAAAA0/0E=","decoded_payload":{"ACI1_mA":"0.000", "ACI2_mA":"0.000", "AVI1_V":"13.829", "AVI2_V":"0.000", "Acount_times":null, "Count1_times":null, "Count2_times":null, "DI1_status":"L", "DI2_status":"H", "DI3_status":null, "DO1_status":"H", "DO2_status":"H", "DO3_status":null, "First_status":null, "Hardware_mode":"LT22222", "RO1_status":"OFF", "RO2_status":"OFF", "Work_mode":"2ACI+2AVI"},"rx_metadata":[{"gateway_ids":{"gateway_id":"eui-7076ff0056080b0f","eui":"7076FF0056080B0F"},"time":"2023-07-22T16:34:42.898Z","timestamp":3874550100,"rssi":-113,"channel_rssi":-113,"snr":-9.5,"uplink_token":"CiIKIAoUZXVpLTcwNzZmZjAwNTYwODBiMGYSCHB2/wBWCAsPENTiw7cOGgwIo4rwpQYQluzr9wEgoOC66eH+JSoMCKKK8KUGEIDJmawD","channel_index":1,"gps_time":"2023-07-22T16:34:42.898Z","received_at":"2023-07-22T16:34:42.235671618Z"}],"settings":{"data_rate":{"lora":{"bandwidth":125000, "spreading_factor":12, "coding_rate":"4/5"}}, "frequency":"867300000", "timestamp":3874550100, "time":"2023-07-22T16:34:42.898Z"},"received_at":"2023-07-22T16:34:43.520848844Z","consumed_airtime":"1.482752s","version_ids":{"brand_id":"dragino", "model_id":"lt22222-l", "hardware_version":"_unknown_hw_version_", "firmware_version":"1.5.6", "band_id":"EU_863_870"},"network_ids":{"net_id":"000013","tenant_id":"ttn","cluster_id":"eu1","cluster_address":"eu1.cloud.thethings.network"}}}
    INTEL NUC i7, Sonoff, hmIP, AVM, Jeelink, T-Link, Alexa, Saia-Burgess, uvm.
    • GregorSG GregorS
      Jetzt kommt was.
      javascript.0
      javascript.0
      @gregors sagte: Hab auf Debug umgestellt.
      Stell auf "info".
      @gregors sagte in Payload Daten in Objekte schreiben:
      Jetzt kommt was.
      Auch alle 2 Minuten aus dem Trigger?
      GregorSG 1 Antwort Letzte Antwort
        Stell auf "info".
        Jetzt kommt was.
        GregorSG Offline
        GregorSG Offline
        GregorS
        18:43:37.493	info	javascript.0 (652027) Start javascript script.js.LoRAWAN_DEV_1
        18:43:37.496	info	javascript.0 (652027) script.js.LoRAWAN_DEV_1: {"end_device_ids":{"device_id":"eui-a840414601871305","application_ids":{"application_id":"gs-mg-dragino-01"},"dev_eui":"A840414601871305","join_eui":"A840410000000101","dev_addr":"260BE9CF"},"correlation_ids":["as:up:01H5Z7MYH48PRXF13SW1RS6HD4","gs:conn:01H5TF5M58SGAQZTB5B766P6EM","gs:up:host:01H5TF5M5DGPVSKX7RKJ1HPXFF","gs:uplink:01H5Z7MYARW1Q74HXA0T7D5T4S","ns:uplink:01H5Z7MYAR2XJWHT5VS9XVHEZZ","rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01H5Z7MYARMWPFGXW00K1X3WSV","rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01H5Z7MYH4FKD5VX7EZXWGJKHZ"],"received_at":"2023-07-22T16:41:43.204341812Z","uplink_message":{"session_key_id":"AYlu5XV3aMaeiMVAq8yISw==","f_port":2,"f_cnt":4357,"frm_payload":"NgMAAAAAAAA0/0E=","decoded_payload":{"ACI1_mA":"0.000", "ACI2_mA":"0.000", "AVI1_V":"13.827", "AVI2_V":"0.000", "Acount_times":null, "Count1_times":null, "Count2_times":null, "DI1_status":"L", "DI2_status":"H", "DI3_status":null, "DO1_status":"H", "DO2_status":"H", "DO3_status":null, "First_status":null, "Hardware_mode":"LT22222", "RO1_status":"OFF", "RO2_status":"OFF", "Work_mode":"2ACI+2AVI"},"rx_metadata":[{"gateway_ids":{"gateway_id":"eui-7076ff0056080b0f","eui":"7076FF0056080B0F"},"time":"2023-07-22T16:41:42.891Z","timestamp":4294543004,"rssi":-118,"channel_rssi":-118,"snr":-12.2,"uplink_token":"CiIKIAoUZXVpLTcwNzZmZjAwNTYwODBiMGYSCHB2/wBWCAsPEJyN5v8PGgwIxo3wpQYQiODg3AMg4KLXtf6KJioMCMaN8KUGEMCp7qgD","channel_index":3,"gps_time":"2023-07-22T16:41:42.891Z","received_at":"2023-07-22T16:41:42.692566999Z"}],"settings":{"data_rate":{"lora":{"bandwidth":125000, "spreading_factor":12, "coding_rate":"4/5"}}, "frequency":"867700000", "timestamp":4294543004, "time":"2023-07-22T16:41:42.891Z"},"received_at":"2023-07-22T16:41:43.000778353Z","consumed_airtime":"1.482752s","version_ids":{"brand_id":"dragino", "model_id":"lt22222-l", "hardware_version":"_unknown_hw_version_", "firmware_version":"1.5.6", "band_id":"EU_863_870"},"network_ids":{"net_id":"000013","tenant_id":"ttn","cluster_id":"eu1","cluster_address":"eu1.cloud.thethings.network"}}}
        18:43:37.496	info	javascript.0 (652027) script.js.LoRAWAN_DEV_1: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
        18:43:43.227	info	javascript.0 (652027) script.js.LoRAWAN_DEV_1: {"end_device_ids":{"device_id":"eui-a840414601871305","application_ids":{"application_id":"gs-mg-dragino-01"},"dev_eui":"A840414601871305","join_eui":"A840410000000101","dev_addr":"260BE9CF"},"correlation_ids":["as:up:01H5Z7RKQ7EM4GPTNH3A4ZZQRM","gs:conn:01H5TF5M58SGAQZTB5B766P6EM","gs:up:host:01H5TF5M5DGPVSKX7RKJ1HPXFF","gs:uplink:01H5Z7RKGRA8VCCA5GDJDAJ32G","ns:uplink:01H5Z7RKGSHDHETYPCFKHZ4WB8","rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01H5Z7RKGSTVXAW22XNQWVCPYS","rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01H5Z7RKQ7Q4ASFM7XB599YRYK"],"received_at":"2023-07-22T16:43:43.207301529Z","uplink_message":{"session_key_id":"AYlu5XV3aMaeiMVAq8yISw==","f_port":2,"f_cnt":4359,"frm_payload":"NicAAAAAAAA0/0E=","decoded_payload":{"ACI1_mA":"0.000", "ACI2_mA":"0.000", "AVI1_V":"13.863", "AVI2_V":"0.000", "Acount_times":null, "Count1_times":null, "Count2_times":null, "DI1_status":"L", "DI2_status":"H", "DI3_status":null, "DO1_status":"H", "DO2_status":"H", "DO3_status":null, "First_status":null, "Hardware_mode":"LT22222", "RO1_status":"OFF", "RO2_status":"OFF", "Work_mode":"2ACI+2AVI"},"rx_metadata":[{"gateway_ids":{"gateway_id":"eui-7076ff0056080b0f","eui":"7076FF0056080B0F"},"time":"2023-07-22T16:43:42.882Z","timestamp":119566764,"rssi":-117,"channel_rssi":-117,"snr":-14.5,"uplink_token":"CiIKIAoUZXVpLTcwNzZmZjAwNTYwODBiMGYSCHB2/wBWCAsPEKzjgTkaCgi/jvClBhCVjhYg4I/wtb2OJioMCL6O8KUGEICByaQD","channel_index":7,"gps_time":"2023-07-22T16:43:42.882Z","received_at":"2023-07-22T16:43:42.693099748Z"}],"settings":{"data_rate":{"lora":{"bandwidth":125000, "spreading_factor":12, "coding_rate":"4/5"}}, "frequency":"868500000", "timestamp":119566764, "time":"2023-07-22T16:43:42.882Z"},"received_at":"2023-07-22T16:43:43.001729646Z","consumed_airtime":"1.482752s","version_ids":{"brand_id":"dragino", "model_id":"lt22222-l", "hardware_version":"_unknown_hw_version_", "firmware_version":"1.5.6", "band_id":"EU_863_870"},"network_ids":{"net_id":"000013","tenant_id":"ttn","cluster_id":"eu1","cluster_address":"eu1.cloud.thethings.network"}}}
        18:43:43.228	info	javascript.0 (652027) script.js.LoRAWAN_DEV_1: undefined
        • GregorSG GregorS
          @gregors
          log(payload);
          zeigt offenbar undefined, da "decoded_payload" falsch geschrieben ist (Zeile 5).
          • GregorSG GregorS
            Logstufe "Error"
            #66
            Logstufe "Error"
            nee, nich?
              @gregors
              log(payload);
              GregorSG Offline
              GregorSG Offline
              GregorS
              #67
              Habe ich korrigiert. Der Teufel steckt im Detail
              19:01:43.238	info	javascript.0 (652027) script.js.LoRAWAN_DEV_1: {"end_device_ids":{"device_id":"eui-a840414601871305","application_ids":{"application_id":"gs-mg-dragino-01"},"dev_eui":"A840414601871305","join_eui":"A840410000000101","dev_addr":"260BE9CF"},"correlation_ids":["as:up:01H5Z8SJDEQ23SXYZE51TC07BD","gs:conn:01H5TF5M58SGAQZTB5B766P6EM","gs:up:host:01H5TF5M5DGPVSKX7RKJ1HPXFF","gs:uplink:01H5Z8SJ70D6PACPHB0R2GHN04","ns:uplink:01H5Z8SJ712X5TEW0CWDE4CXQM","rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01H5Z8SJ715Z75WJ51BS6ZWF31","rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01H5Z8SJDDM0YCG82TXN5P6Q2T"],"received_at":"2023-07-22T17:01:43.213639158Z","uplink_message":{"session_key_id":"AYlu5XV3aMaeiMVAq8yISw==","f_port":2,"f_cnt":4377,"frm_payload":"NiwAAAAAAAA0/0E=","decoded_payload":{"ACI1_mA":"0.000", "ACI2_mA":"0.000", "AVI1_V":"13.868", "AVI2_V":"0.000", "Acount_times":null, "Count1_times":null, "Count2_times":null, "DI1_status":"L", "DI2_status":"H", "DI3_status":null, "DO1_status":"H", "DO2_status":"H", "DO3_status":null, "First_status":null, "Hardware_mode":"LT22222", "RO1_status":"OFF", "RO2_status":"OFF", "Work_mode":"2ACI+2AVI"},"rx_metadata":[{"gateway_ids":{"gateway_id":"eui-7076ff0056080b0f","eui":"7076FF0056080B0F"},"time":"2023-07-22T17:01:42.871Z","timestamp":1199555188,"rssi":-118,"channel_rssi":-118,"snr":-13.8,"uplink_token":"CiIKIAoUZXVpLTcwNzZmZjAwNTYwODBiMGYSCHB2/wBWCAsPEPSE/7sEGgsI95bwpQYQ0Mb0AyCgqr7Y9K0mKgwI9pbwpQYQwM+pnwM=","channel_index":4,"gps_time":"2023-07-22T17:01:42.871Z","received_at":"2023-07-22T17:01:42.714662309Z"}],"settings":{"data_rate":{"lora":{"bandwidth":125000, "spreading_factor":12, "coding_rate":"4/5"}}, "frequency":"867900000", "timestamp":1199555188, "time":"2023-07-22T17:01:42.871Z"},"received_at":"2023-07-22T17:01:43.009292984Z","consumed_airtime":"1.482752s","version_ids":{"brand_id":"dragino", "model_id":"lt22222-l", "hardware_version":"_unknown_hw_version_", "firmware_version":"1.5.6", "band_id":"EU_863_870"},"network_ids":{"net_id":"000013","tenant_id":"ttn","cluster_id":"eu1","cluster_address":"eu1.cloud.thethings.network"}}}
              19:01:43.238	info	javascript.0 (652027) script.js.LoRAWAN_DEV_1: {'ACI1_mA':'0.000','ACI2_mA':'0.000','AVI1_V':'13.868','AVI2_V':'0.000','Acount_times':null,'Count1_times':null,'Count2_times':null,'DI1_status':'L','DI2_status':'H','DI3_status':null,'DO1_status':'H','DO2_status':'H','DO3_status':null,'First_status':null,'Hardware_mode':'LT22222','RO1_status':'OFF','RO2_status':'OFF','Work_mode':'2ACI+2AVI'}
              paul53P GregorSG 2 Antworten Letzte Antwort
              • GregorSG GregorS
                #68
                @gregors sagte: Der Teufel steckt im Detail
                ... und nun wurde auch der Datenpunkt "AVI1_V" mit dem Wert 13.87 gefüllt?
                • GregorSG GregorS
                  GregorSG Offline
                  GregorSG Offline
                  GregorS
                  #69
                  @Homoran
                  @marc-berg
                  Danke für Eure Geduld und die Hilfe.
                  Jetzt funktioniert es.
                  • GregorSG GregorS
                    @Homoran
                    @marc-berg
                    GregorSG Offline
                    GregorSG Offline
                    GregorS
                    #70
                    Wie kann ich denn
                    "rssi" und "time"
                    extrahieren?
                    Alle anderen Infos haben funktioniert.
                    • GregorSG GregorS
                      Wie kann ich denn
                      "rssi" und "time"
                      extrahieren?
                      #71
                      @gregors sagte: "rssi" und "time"
                          const msg = JSON.parse(dp.state.val).uplink_message;
                          const payload = msg.decoded_payload;
                          const rx0 = msg.rx_metadata[0];
                          log(rx0.time);
                          log(rx0.rssi);
                      • GregorSG Offline
                        GregorSG Offline
                        GregorS
                        #72
                        Nachdem ich jetzt die Daten in ioBroker habe, ist mir die Nacht eine
                        zusätzliche Anwendung durch den Kopf gegangen.
                        Dazu muss ich allerdings RO1 schalten.
                        Über das Gateway habe ich bereits Erfolg gehabt, und die Rückmeldung im ioBroker aufgenommen.
                        Messaging / Downlink --> 03 00 11 Relais öffnen
                        --> 03 01 11 Relais schliessen
                        Wie kann ich das RO1 aus ioBroker schalten?
                        • GregorSG GregorS
                          Marc BergM Online
                          Marc BergM Online
                          Marc Berg
                          #73
                          @gregors sagte in [gelöst] Payload Daten in Objekte schreiben:
                          Ich habe das über Node Red umgesetzt, aber den entscheidenden Teil kannst du vielleicht adaptieren.
                          So sieht ein einfacher Beispiel-Flow aus:
                          Der Payload (hier "0501100200") wird in einem Function-Node verarbeitet (Base64 Kodierung + Erzeugung des Downlinks) und dann per MQTT an TTN gesendet.
                          Der Code im Function-Node sieht so aus (in 'msg.hex' steckt "0501100200"):
                          var s=msg.hex;
                          var b=Buffer.from(s, 'hex');            //Buffer erzeugen
                          s=b.toString("base64");                 //to base64
                          msg.payload=
                              "downlinks": [{
                                "f_port": 2,
                                "frm_payload": s,
                                "priority": "NORMAL"
                          return msg;
                          Dieser so aufbereitete Payload wird dann per MQTT an folgendes Topic gesendet:
                          v3/<APPLICATION-ID>@ttn/devices/<DEVICE_ID>/down/replace
                          • Marc BergM Marc Berg
                            var s=msg.hex;
                            msg.payload=
                                "downlinks": [{
                                  "f_port": 2,
                                  "frm_payload": s,
                            return msg;
                            GregorSG Offline
                            GregorSG Offline
                            GregorS
                            #74
                            @marc-berg
                            Danke für den Denkanstoss.
                            Habe aber bisher noch keinen Erfolg gehabt.
                            Bekomme das Payload nicht gesendet.
                            Bleibe dran
                            • GregorSG GregorS
                              @marc-berg
                              Bleibe dran
                              Marc BergM Online
                              Marc BergM Online
                              Marc Berg
                              #75
                              Bleibe dran
                              Das müsste ja dann bei dir zum Einschalten so aussehen:
                                  "downlinks": [{
                                    "f_port": 2,
                                    "frm_payload": "AwER",
                              und zum Ausschalten so:
                                  "downlinks": [{
                                    "f_port": 2,
                                    "frm_payload": "AwAR",
                              Auf welche Weise sendest du den Downlink?
                                Bleibe dran
                                    "downlinks": [{
                                      "f_port": 2,
                                    "downlinks": [{
                                      "f_port": 2,
                                GregorSG Offline
                                GregorSG Offline
                                GregorS
                                schrieb am zuletzt editiert von GregorS
                                #76
                                @marc-berg said in [gelöst] Payload Daten in Objekte schreiben:
                                Was meinst du damit?
                                Ich habe mehrer Versionen probiert, aber es hakt immer am "Doppelpunkt" hinter downlinks.
                                Ich galube, da fehlt was entscheidendes.
                                //'mqtt.2.v3.gs-mg-dragino-01@ttn.devices.eui-a840414601871305.down.sent'/*v3/gs-mg-dragino-01@ttn/devices/eui-a840414601871305/down/sent*/
                                on('mqtt.2.v3.gs-mg-dragino-01@ttn.devices.eui-a840414601871305.down', function (dp)
                                  "downlinks": [{
                                    "f_port": 2,
                                    "frm_payload": "130011=",
                                18:26:04.002	error	javascript.0 (681137) script.js.LoRAWAN_DEV_1_senden compile failed: at script.js.LoRAWAN_DEV_1_senden:4
                                paul53P Marc BergM 2 Antworten Letzte Antwort
                                • GregorSG GregorS
                                    "downlinks": [{
                                      "f_port": 2,
                                  #77
                                  @gregors
                                  Du willst doch keine Daten erhalten (triggern), sondern Daten senden. Das macht man mit sendTo() oder mit setState() auf den Datenpunkt, der an das Topic "v3/gs-mg-dragino-01@ttn/devices/eui-a840414601871305/down/replace" sendet.
                                  • GregorSG GregorS
                                      "downlinks": [{
                                        "f_port": 2,
                                    Marc BergM Online
                                    Marc BergM Online
                                    Marc Berg
                                    #78
                                    Nun ja, man kann ja die Daten per MQTT oder per API senden. Wie ich jetzt gesehen habe, versuchst du es per MQTT. Das heißt, du hast eine MQTT Instanz erstellt und dich damit an TTN angemeldet? Funktioniert denn die Anmeldung?
                                    Zum Scripting kann ich nicht viel sagen, dazu hat sich ja @paul53 schon geäußert.
                                    Aber das hier:
                                    ist auf jeden Fall falsch Base64 kodiert. Ein guter Konverter ist z.B. der hier https://base64.guru/converter/encode/hex
                                    Wenn Du deinen Hexadezimal-Payload "03 01 11" durch den Konverter schickst, kommt "AwER" raus.
