  5. [gelöst] Payload Daten in Objekte schreiben
78 Beiträge 4 Kommentatoren 9.7k Aufrufe 2 Beobachtet
  • GregorSG GregorS
    18:43:37.493	info	javascript.0 (652027) Start javascript script.js.LoRAWAN_DEV_1
    18:43:37.496	info	javascript.0 (652027) script.js.LoRAWAN_DEV_1: {"end_device_ids":{"device_id":"eui-a840414601871305","application_ids":{"application_id":"gs-mg-dragino-01"},"dev_eui":"A840414601871305","join_eui":"A840410000000101","dev_addr":"260BE9CF"},"correlation_ids":["as:up:01H5Z7MYH48PRXF13SW1RS6HD4","gs:conn:01H5TF5M58SGAQZTB5B766P6EM","gs:up:host:01H5TF5M5DGPVSKX7RKJ1HPXFF","gs:uplink:01H5Z7MYARW1Q74HXA0T7D5T4S","ns:uplink:01H5Z7MYAR2XJWHT5VS9XVHEZZ","rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01H5Z7MYARMWPFGXW00K1X3WSV","rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01H5Z7MYH4FKD5VX7EZXWGJKHZ"],"received_at":"2023-07-22T16:41:43.204341812Z","uplink_message":{"session_key_id":"AYlu5XV3aMaeiMVAq8yISw==","f_port":2,"f_cnt":4357,"frm_payload":"NgMAAAAAAAA0/0E=","decoded_payload":{"ACI1_mA":"0.000", "ACI2_mA":"0.000", "AVI1_V":"13.827", "AVI2_V":"0.000", "Acount_times":null, "Count1_times":null, "Count2_times":null, "DI1_status":"L", "DI2_status":"H", "DI3_status":null, "DO1_status":"H", "DO2_status":"H", "DO3_status":null, "First_status":null, "Hardware_mode":"LT22222", "RO1_status":"OFF", "RO2_status":"OFF", "Work_mode":"2ACI+2AVI"},"rx_metadata":[{"gateway_ids":{"gateway_id":"eui-7076ff0056080b0f","eui":"7076FF0056080B0F"},"time":"2023-07-22T16:41:42.891Z","timestamp":4294543004,"rssi":-118,"channel_rssi":-118,"snr":-12.2,"uplink_token":"CiIKIAoUZXVpLTcwNzZmZjAwNTYwODBiMGYSCHB2/wBWCAsPEJyN5v8PGgwIxo3wpQYQiODg3AMg4KLXtf6KJioMCMaN8KUGEMCp7qgD","channel_index":3,"gps_time":"2023-07-22T16:41:42.891Z","received_at":"2023-07-22T16:41:42.692566999Z"}],"settings":{"data_rate":{"lora":{"bandwidth":125000, "spreading_factor":12, "coding_rate":"4/5"}}, "frequency":"867700000", "timestamp":4294543004, "time":"2023-07-22T16:41:42.891Z"},"received_at":"2023-07-22T16:41:43.000778353Z","consumed_airtime":"1.482752s","version_ids":{"brand_id":"dragino", "model_id":"lt22222-l", "hardware_version":"_unknown_hw_version_", "firmware_version":"1.5.6", "band_id":"EU_863_870"},"network_ids":{"net_id":"000013","tenant_id":"ttn","cluster_id":"eu1","cluster_address":"eu1.cloud.thethings.network"}}}
    18:43:37.496	info	javascript.0 (652027) script.js.LoRAWAN_DEV_1: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    18:43:43.227	info	javascript.0 (652027) script.js.LoRAWAN_DEV_1: {"end_device_ids":{"device_id":"eui-a840414601871305","application_ids":{"application_id":"gs-mg-dragino-01"},"dev_eui":"A840414601871305","join_eui":"A840410000000101","dev_addr":"260BE9CF"},"correlation_ids":["as:up:01H5Z7RKQ7EM4GPTNH3A4ZZQRM","gs:conn:01H5TF5M58SGAQZTB5B766P6EM","gs:up:host:01H5TF5M5DGPVSKX7RKJ1HPXFF","gs:uplink:01H5Z7RKGRA8VCCA5GDJDAJ32G","ns:uplink:01H5Z7RKGSHDHETYPCFKHZ4WB8","rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01H5Z7RKGSTVXAW22XNQWVCPYS","rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01H5Z7RKQ7Q4ASFM7XB599YRYK"],"received_at":"2023-07-22T16:43:43.207301529Z","uplink_message":{"session_key_id":"AYlu5XV3aMaeiMVAq8yISw==","f_port":2,"f_cnt":4359,"frm_payload":"NicAAAAAAAA0/0E=","decoded_payload":{"ACI1_mA":"0.000", "ACI2_mA":"0.000", "AVI1_V":"13.863", "AVI2_V":"0.000", "Acount_times":null, "Count1_times":null, "Count2_times":null, "DI1_status":"L", "DI2_status":"H", "DI3_status":null, "DO1_status":"H", "DO2_status":"H", "DO3_status":null, "First_status":null, "Hardware_mode":"LT22222", "RO1_status":"OFF", "RO2_status":"OFF", "Work_mode":"2ACI+2AVI"},"rx_metadata":[{"gateway_ids":{"gateway_id":"eui-7076ff0056080b0f","eui":"7076FF0056080B0F"},"time":"2023-07-22T16:43:42.882Z","timestamp":119566764,"rssi":-117,"channel_rssi":-117,"snr":-14.5,"uplink_token":"CiIKIAoUZXVpLTcwNzZmZjAwNTYwODBiMGYSCHB2/wBWCAsPEKzjgTkaCgi/jvClBhCVjhYg4I/wtb2OJioMCL6O8KUGEICByaQD","channel_index":7,"gps_time":"2023-07-22T16:43:42.882Z","received_at":"2023-07-22T16:43:42.693099748Z"}],"settings":{"data_rate":{"lora":{"bandwidth":125000, "spreading_factor":12, "coding_rate":"4/5"}}, "frequency":"868500000", "timestamp":119566764, "time":"2023-07-22T16:43:42.882Z"},"received_at":"2023-07-22T16:43:43.001729646Z","consumed_airtime":"1.482752s","version_ids":{"brand_id":"dragino", "model_id":"lt22222-l", "hardware_version":"_unknown_hw_version_", "firmware_version":"1.5.6", "band_id":"EU_863_870"},"network_ids":{"net_id":"000013","tenant_id":"ttn","cluster_id":"eu1","cluster_address":"eu1.cloud.thethings.network"}}}
    18:43:43.228	info	javascript.0 (652027) script.js.LoRAWAN_DEV_1: undefined
    @gregors
    log(payload);
    zeigt offenbar undefined, da "decoded_payload" falsch geschrieben ist (Zeile 5).
    GregorSG 1 Antwort Letzte Antwort
    • GregorSG GregorS
      Logstufe "Error"
      #66
      @gregors sagte in Payload Daten in Objekte schreiben:
      Logstufe "Error"
      nee, nich?
        @gregors
        log(payload);
        GregorSG Offline
        GregorSG Offline
        GregorS
        #67
        Habe ich korrigiert. Der Teufel steckt im Detail
        19:01:43.238	info	javascript.0 (652027) script.js.LoRAWAN_DEV_1: {"end_device_ids":{"device_id":"eui-a840414601871305","application_ids":{"application_id":"gs-mg-dragino-01"},"dev_eui":"A840414601871305","join_eui":"A840410000000101","dev_addr":"260BE9CF"},"correlation_ids":["as:up:01H5Z8SJDEQ23SXYZE51TC07BD","gs:conn:01H5TF5M58SGAQZTB5B766P6EM","gs:up:host:01H5TF5M5DGPVSKX7RKJ1HPXFF","gs:uplink:01H5Z8SJ70D6PACPHB0R2GHN04","ns:uplink:01H5Z8SJ712X5TEW0CWDE4CXQM","rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01H5Z8SJ715Z75WJ51BS6ZWF31","rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01H5Z8SJDDM0YCG82TXN5P6Q2T"],"received_at":"2023-07-22T17:01:43.213639158Z","uplink_message":{"session_key_id":"AYlu5XV3aMaeiMVAq8yISw==","f_port":2,"f_cnt":4377,"frm_payload":"NiwAAAAAAAA0/0E=","decoded_payload":{"ACI1_mA":"0.000", "ACI2_mA":"0.000", "AVI1_V":"13.868", "AVI2_V":"0.000", "Acount_times":null, "Count1_times":null, "Count2_times":null, "DI1_status":"L", "DI2_status":"H", "DI3_status":null, "DO1_status":"H", "DO2_status":"H", "DO3_status":null, "First_status":null, "Hardware_mode":"LT22222", "RO1_status":"OFF", "RO2_status":"OFF", "Work_mode":"2ACI+2AVI"},"rx_metadata":[{"gateway_ids":{"gateway_id":"eui-7076ff0056080b0f","eui":"7076FF0056080B0F"},"time":"2023-07-22T17:01:42.871Z","timestamp":1199555188,"rssi":-118,"channel_rssi":-118,"snr":-13.8,"uplink_token":"CiIKIAoUZXVpLTcwNzZmZjAwNTYwODBiMGYSCHB2/wBWCAsPEPSE/7sEGgsI95bwpQYQ0Mb0AyCgqr7Y9K0mKgwI9pbwpQYQwM+pnwM=","channel_index":4,"gps_time":"2023-07-22T17:01:42.871Z","received_at":"2023-07-22T17:01:42.714662309Z"}],"settings":{"data_rate":{"lora":{"bandwidth":125000, "spreading_factor":12, "coding_rate":"4/5"}}, "frequency":"867900000", "timestamp":1199555188, "time":"2023-07-22T17:01:42.871Z"},"received_at":"2023-07-22T17:01:43.009292984Z","consumed_airtime":"1.482752s","version_ids":{"brand_id":"dragino", "model_id":"lt22222-l", "hardware_version":"_unknown_hw_version_", "firmware_version":"1.5.6", "band_id":"EU_863_870"},"network_ids":{"net_id":"000013","tenant_id":"ttn","cluster_id":"eu1","cluster_address":"eu1.cloud.thethings.network"}}}
        19:01:43.238	info	javascript.0 (652027) script.js.LoRAWAN_DEV_1: {'ACI1_mA':'0.000','ACI2_mA':'0.000','AVI1_V':'13.868','AVI2_V':'0.000','Acount_times':null,'Count1_times':null,'Count2_times':null,'DI1_status':'L','DI2_status':'H','DI3_status':null,'DO1_status':'H','DO2_status':'H','DO3_status':null,'First_status':null,'Hardware_mode':'LT22222','RO1_status':'OFF','RO2_status':'OFF','Work_mode':'2ACI+2AVI'}
        INTEL NUC i7, Sonoff, hmIP, AVM, Jeelink, T-Link, Alexa, Saia-Burgess, uvm.
        paul53P GregorSG 2 Antworten Letzte Antwort
        • GregorSG GregorS
          #68
          @gregors sagte: Der Teufel steckt im Detail
          ... und nun wurde auch der Datenpunkt "AVI1_V" mit dem Wert 13.87 gefüllt?
          • GregorSG GregorS
            GregorSG Offline
            GregorSG Offline
            GregorS
            #69
            @Homoran
            @marc-berg
            Danke für Eure Geduld und die Hilfe.
            Jetzt funktioniert es.
            • GregorSG GregorS
              @Homoran
              @marc-berg
              GregorSG Offline
              GregorSG Offline
              GregorS
              #70
              Wie kann ich denn
              "rssi" und "time"
              extrahieren?
              Alle anderen Infos haben funktioniert.
              • GregorSG GregorS
                Wie kann ich denn
                "rssi" und "time"
                extrahieren?
                #71
                @gregors sagte: "rssi" und "time"
                    const msg = JSON.parse(dp.state.val).uplink_message;
                    const payload = msg.decoded_payload;
                    const rx0 = msg.rx_metadata[0];
                    log(rx0.time);
                    log(rx0.rssi);
                • GregorSG Offline
                  GregorSG Offline
                  GregorS
                  #72
                  Nachdem ich jetzt die Daten in ioBroker habe, ist mir die Nacht eine
                  zusätzliche Anwendung durch den Kopf gegangen.
                  Dazu muss ich allerdings RO1 schalten.
                  Über das Gateway habe ich bereits Erfolg gehabt, und die Rückmeldung im ioBroker aufgenommen.
                  Messaging / Downlink --> 03 00 11 Relais öffnen
                  --> 03 01 11 Relais schliessen
                  Wie kann ich das RO1 aus ioBroker schalten?
                  • GregorSG GregorS
                    Marc BergM Online
                    Marc BergM Online
                    Marc Berg
                    #73
                    @gregors sagte in [gelöst] Payload Daten in Objekte schreiben:
                    Ich habe das über Node Red umgesetzt, aber den entscheidenden Teil kannst du vielleicht adaptieren.
                    So sieht ein einfacher Beispiel-Flow aus:
                    Der Payload (hier "0501100200") wird in einem Function-Node verarbeitet (Base64 Kodierung + Erzeugung des Downlinks) und dann per MQTT an TTN gesendet.
                    Der Code im Function-Node sieht so aus (in 'msg.hex' steckt "0501100200"):
                    var s=msg.hex;
                    var b=Buffer.from(s, 'hex');            //Buffer erzeugen
                    s=b.toString("base64");                 //to base64
                    msg.payload=
                        "downlinks": [{
                          "f_port": 2,
                          "frm_payload": s,
                          "priority": "NORMAL"
                    return msg;
                    Dieser so aufbereitete Payload wird dann per MQTT an folgendes Topic gesendet:
                    v3/<APPLICATION-ID>@ttn/devices/<DEVICE_ID>/down/replace
                    • Marc BergM Marc Berg
                      var s=msg.hex;
                      msg.payload=
                          "downlinks": [{
                            "f_port": 2,
                            "frm_payload": s,
                      return msg;
                      GregorSG Offline
                      GregorSG Offline
                      GregorS
                      #74
                      @marc-berg
                      Danke für den Denkanstoss.
                      Habe aber bisher noch keinen Erfolg gehabt.
                      Bekomme das Payload nicht gesendet.
                      Bleibe dran
                      • GregorSG GregorS
                        @marc-berg
                        Bleibe dran
                        Marc BergM Online
                        Marc BergM Online
                        Marc Berg
                        #75
                        Bleibe dran
                        Das müsste ja dann bei dir zum Einschalten so aussehen:
                            "downlinks": [{
                              "f_port": 2,
                              "frm_payload": "AwER",
                        und zum Ausschalten so:
                            "downlinks": [{
                              "f_port": 2,
                              "frm_payload": "AwAR",
                        Auf welche Weise sendest du den Downlink?
                          Bleibe dran
                              "downlinks": [{
                                "f_port": 2,
                              "downlinks": [{
                                "f_port": 2,
                          GregorSG Offline
                          GregorSG Offline
                          GregorS
                          schrieb am zuletzt editiert von GregorS
                          #76
                          @marc-berg said in [gelöst] Payload Daten in Objekte schreiben:
                          Was meinst du damit?
                          Ich habe mehrer Versionen probiert, aber es hakt immer am "Doppelpunkt" hinter downlinks.
                          Ich galube, da fehlt was entscheidendes.
                          //'mqtt.2.v3.gs-mg-dragino-01@ttn.devices.eui-a840414601871305.down.sent'/*v3/gs-mg-dragino-01@ttn/devices/eui-a840414601871305/down/sent*/
                          on('mqtt.2.v3.gs-mg-dragino-01@ttn.devices.eui-a840414601871305.down', function (dp)
                            "downlinks": [{
                              "f_port": 2,
                              "frm_payload": "130011=",
                          18:26:04.002	error	javascript.0 (681137) script.js.LoRAWAN_DEV_1_senden compile failed: at script.js.LoRAWAN_DEV_1_senden:4
                          paul53P Marc BergM 2 Antworten Letzte Antwort
                          • GregorSG GregorS
                              "downlinks": [{
                                "f_port": 2,
                            #77
                            @gregors
                            Du willst doch keine Daten erhalten (triggern), sondern Daten senden. Das macht man mit sendTo() oder mit setState() auf den Datenpunkt, der an das Topic "v3/gs-mg-dragino-01@ttn/devices/eui-a840414601871305/down/replace" sendet.
                            • GregorSG GregorS
                                "downlinks": [{
                                  "f_port": 2,
                              Marc BergM Online
                              Marc BergM Online
                              Marc Berg
                              #78
                              Nun ja, man kann ja die Daten per MQTT oder per API senden. Wie ich jetzt gesehen habe, versuchst du es per MQTT. Das heißt, du hast eine MQTT Instanz erstellt und dich damit an TTN angemeldet? Funktioniert denn die Anmeldung?
                              Zum Scripting kann ich nicht viel sagen, dazu hat sich ja @paul53 schon geäußert.
                              Aber das hier:
                              ist auf jeden Fall falsch Base64 kodiert. Ein guter Konverter ist z.B. der hier https://base64.guru/converter/encode/hex
                              Wenn Du deinen Hexadezimal-Payload "03 01 11" durch den Konverter schickst, kommt "AwER" raus.
