  5. [gelöst] Payload Daten in Objekte schreiben
78 Beiträge 4 Kommentatoren 9.7k Aufrufe 2 Beobachtet
  • GregorSG GregorS
    Habe ich korrigiert. Der Teufel steckt im Detail
    19:01:43.238	info	javascript.0 (652027) script.js.LoRAWAN_DEV_1: {"end_device_ids":{"device_id":"eui-a840414601871305","application_ids":{"application_id":"gs-mg-dragino-01"},"dev_eui":"A840414601871305","join_eui":"A840410000000101","dev_addr":"260BE9CF"},"correlation_ids":["as:up:01H5Z8SJDEQ23SXYZE51TC07BD","gs:conn:01H5TF5M58SGAQZTB5B766P6EM","gs:up:host:01H5TF5M5DGPVSKX7RKJ1HPXFF","gs:uplink:01H5Z8SJ70D6PACPHB0R2GHN04","ns:uplink:01H5Z8SJ712X5TEW0CWDE4CXQM","rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01H5Z8SJ715Z75WJ51BS6ZWF31","rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01H5Z8SJDDM0YCG82TXN5P6Q2T"],"received_at":"2023-07-22T17:01:43.213639158Z","uplink_message":{"session_key_id":"AYlu5XV3aMaeiMVAq8yISw==","f_port":2,"f_cnt":4377,"frm_payload":"NiwAAAAAAAA0/0E=","decoded_payload":{"ACI1_mA":"0.000", "ACI2_mA":"0.000", "AVI1_V":"13.868", "AVI2_V":"0.000", "Acount_times":null, "Count1_times":null, "Count2_times":null, "DI1_status":"L", "DI2_status":"H", "DI3_status":null, "DO1_status":"H", "DO2_status":"H", "DO3_status":null, "First_status":null, "Hardware_mode":"LT22222", "RO1_status":"OFF", "RO2_status":"OFF", "Work_mode":"2ACI+2AVI"},"rx_metadata":[{"gateway_ids":{"gateway_id":"eui-7076ff0056080b0f","eui":"7076FF0056080B0F"},"time":"2023-07-22T17:01:42.871Z","timestamp":1199555188,"rssi":-118,"channel_rssi":-118,"snr":-13.8,"uplink_token":"CiIKIAoUZXVpLTcwNzZmZjAwNTYwODBiMGYSCHB2/wBWCAsPEPSE/7sEGgsI95bwpQYQ0Mb0AyCgqr7Y9K0mKgwI9pbwpQYQwM+pnwM=","channel_index":4,"gps_time":"2023-07-22T17:01:42.871Z","received_at":"2023-07-22T17:01:42.714662309Z"}],"settings":{"data_rate":{"lora":{"bandwidth":125000, "spreading_factor":12, "coding_rate":"4/5"}}, "frequency":"867900000", "timestamp":1199555188, "time":"2023-07-22T17:01:42.871Z"},"received_at":"2023-07-22T17:01:43.009292984Z","consumed_airtime":"1.482752s","version_ids":{"brand_id":"dragino", "model_id":"lt22222-l", "hardware_version":"_unknown_hw_version_", "firmware_version":"1.5.6", "band_id":"EU_863_870"},"network_ids":{"net_id":"000013","tenant_id":"ttn","cluster_id":"eu1","cluster_address":"eu1.cloud.thethings.network"}}}
    19:01:43.238	info	javascript.0 (652027) script.js.LoRAWAN_DEV_1: {'ACI1_mA':'0.000','ACI2_mA':'0.000','AVI1_V':'13.868','AVI2_V':'0.000','Acount_times':null,'Count1_times':null,'Count2_times':null,'DI1_status':'L','DI2_status':'H','DI3_status':null,'DO1_status':'H','DO2_status':'H','DO3_status':null,'First_status':null,'Hardware_mode':'LT22222','RO1_status':'OFF','RO2_status':'OFF','Work_mode':'2ACI+2AVI'}
    #68
    @gregors sagte: Der Teufel steckt im Detail
    ... und nun wurde auch der Datenpunkt "AVI1_V" mit dem Wert 13.87 gefüllt?
    • GregorSG GregorS
      GregorSG Offline
      GregorSG Offline
      GregorS
      #69
      @Homoran
      @marc-berg
      Danke für Eure Geduld und die Hilfe.
      Jetzt funktioniert es.
      INTEL NUC i7, Sonoff, hmIP, AVM, Jeelink, T-Link, Alexa, Saia-Burgess, uvm.
      GregorSG 1 Antwort Letzte Antwort
      • GregorSG GregorS
        @Homoran
        @marc-berg
        GregorSG Offline
        GregorSG Offline
        GregorS
        #70
        Wie kann ich denn
        "rssi" und "time"
        extrahieren?
        Alle anderen Infos haben funktioniert.
        • GregorSG GregorS
          Wie kann ich denn
          "rssi" und "time"
          extrahieren?
          #71
          @gregors sagte: "rssi" und "time"
              const msg = JSON.parse(dp.state.val).uplink_message;
              const payload = msg.decoded_payload;
              const rx0 = msg.rx_metadata[0];
              log(rx0.time);
              log(rx0.rssi);
          • GregorSG Offline
            GregorSG Offline
            GregorS
            #72
            Nachdem ich jetzt die Daten in ioBroker habe, ist mir die Nacht eine
            zusätzliche Anwendung durch den Kopf gegangen.
            Dazu muss ich allerdings RO1 schalten.
            Über das Gateway habe ich bereits Erfolg gehabt, und die Rückmeldung im ioBroker aufgenommen.
            Messaging / Downlink --> 03 00 11 Relais öffnen
            --> 03 01 11 Relais schliessen
            Wie kann ich das RO1 aus ioBroker schalten?
            • GregorSG GregorS
              Marc BergM Online
              Marc BergM Online
              Marc Berg
              #73
              @gregors sagte in [gelöst] Payload Daten in Objekte schreiben:
              Ich habe das über Node Red umgesetzt, aber den entscheidenden Teil kannst du vielleicht adaptieren.
              So sieht ein einfacher Beispiel-Flow aus:
              Der Payload (hier "0501100200") wird in einem Function-Node verarbeitet (Base64 Kodierung + Erzeugung des Downlinks) und dann per MQTT an TTN gesendet.
              Der Code im Function-Node sieht so aus (in 'msg.hex' steckt "0501100200"):
              var s=msg.hex;
              var b=Buffer.from(s, 'hex');            //Buffer erzeugen
              s=b.toString("base64");                 //to base64
              msg.payload=
                  "downlinks": [{
                    "f_port": 2,
                    "frm_payload": s,
                    "priority": "NORMAL"
              return msg;
              Dieser so aufbereitete Payload wird dann per MQTT an folgendes Topic gesendet:
              v3/<APPLICATION-ID>@ttn/devices/<DEVICE_ID>/down/replace
              • Marc BergM Marc Berg
                var s=msg.hex;
                msg.payload=
                    "downlinks": [{
                      "f_port": 2,
                      "frm_payload": s,
                return msg;
                GregorSG Offline
                GregorSG Offline
                GregorS
                #74
                @marc-berg
                Danke für den Denkanstoss.
                Habe aber bisher noch keinen Erfolg gehabt.
                Bekomme das Payload nicht gesendet.
                Bleibe dran
                • GregorSG GregorS
                  @marc-berg
                  Bleibe dran
                  Marc BergM Online
                  Marc BergM Online
                  Marc Berg
                  #75
                  Bleibe dran
                  Das müsste ja dann bei dir zum Einschalten so aussehen:
                      "downlinks": [{
                        "f_port": 2,
                        "frm_payload": "AwER",
                  und zum Ausschalten so:
                      "downlinks": [{
                        "f_port": 2,
                        "frm_payload": "AwAR",
                  Auf welche Weise sendest du den Downlink?
                    Bleibe dran
                        "downlinks": [{
                          "f_port": 2,
                        "downlinks": [{
                          "f_port": 2,
                    GregorSG Offline
                    GregorSG Offline
                    GregorS
                    schrieb am zuletzt editiert von GregorS
                    #76
                    @marc-berg said in [gelöst] Payload Daten in Objekte schreiben:
                    Was meinst du damit?
                    Ich habe mehrer Versionen probiert, aber es hakt immer am "Doppelpunkt" hinter downlinks.
                    Ich galube, da fehlt was entscheidendes.
                    //'mqtt.2.v3.gs-mg-dragino-01@ttn.devices.eui-a840414601871305.down.sent'/*v3/gs-mg-dragino-01@ttn/devices/eui-a840414601871305/down/sent*/
                    on('mqtt.2.v3.gs-mg-dragino-01@ttn.devices.eui-a840414601871305.down', function (dp)
                      "downlinks": [{
                        "f_port": 2,
                        "frm_payload": "130011=",
                    18:26:04.002	error	javascript.0 (681137) script.js.LoRAWAN_DEV_1_senden compile failed: at script.js.LoRAWAN_DEV_1_senden:4
                    paul53P Marc BergM 2 Antworten Letzte Antwort
                    • GregorSG GregorS
                        "downlinks": [{
                          "f_port": 2,
                      #77
                      @gregors
                      Du willst doch keine Daten erhalten (triggern), sondern Daten senden. Das macht man mit sendTo() oder mit setState() auf den Datenpunkt, der an das Topic "v3/gs-mg-dragino-01@ttn/devices/eui-a840414601871305/down/replace" sendet.
                      • GregorSG GregorS
                          "downlinks": [{
                            "f_port": 2,
                        Marc BergM Online
                        Marc BergM Online
                        Marc Berg
                        #78
                        Nun ja, man kann ja die Daten per MQTT oder per API senden. Wie ich jetzt gesehen habe, versuchst du es per MQTT. Das heißt, du hast eine MQTT Instanz erstellt und dich damit an TTN angemeldet? Funktioniert denn die Anmeldung?
                        Zum Scripting kann ich nicht viel sagen, dazu hat sich ja @paul53 schon geäußert.
                        Aber das hier:
                        ist auf jeden Fall falsch Base64 kodiert. Ein guter Konverter ist z.B. der hier https://base64.guru/converter/encode/hex
                        Wenn Du deinen Hexadezimal-Payload "03 01 11" durch den Konverter schickst, kommt "AwER" raus.
