  5. [gelöst] Payload Daten in Objekte schreiben
78 Beiträge 4 Kommentatoren 9.7k Aufrufe 2 Beobachtet
  • GregorSG GregorS
    Ok.
    Hier das komplette JSON:
    {"end_device_ids":{"device_id":"eui-xxxxxxxxxxxxxxxxxxx","application_ids":{"application_id":"gs-mg-dragino-01"},"dev_eui":"xxxxxxxxxxxxxxxxxxx","join_eui":"yyyyyyyyyyyyyyyyyyy","dev_addr":"zzzzzzzzz"},"correlation_ids":["as:up:01H5KSJPMRECPFW9X31X3RZVV2","gs:conn:01H4KAYPR4MRPH50CJE9DZ7YHC","gs:up:host:01H4KAYPRB2CYT22K4H1T83DQS","gs:uplink:01H5KSJPE94D98RBTM11WVQ1SY","ns:uplink:01H5KSJPEA3KC8FPJJSHNZ1QQX","rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01H5KSJPEAS7598TVH1ZPW5BJ8","rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01H5KSJPMQT2K85MP8BY0FY6SN"],"received_at":"2023-07-18T06:04:10.775410433Z","uplink_message":{"session_key_id":"AYleIPJHcDVYfnq3XreUCg==","f_port":2,"f_cnt":2648,"frm_payload":"NOwAAAAAAAA0/0E=","decoded_payload":{"ACI1_mA":0, "ACI2_mA":0, "AVI1_V":13.548, "AVI2_V":0, "DI1_status":"L", "DI2_status":"H", "DO1_status":"H", "DO2_status":"H", "Hardware_mode":"LT22222", "RO1_status":"OFF", "RO2_status":"OFF", "Work_mode":"2ACI+2AVI"},"rx_metadata":[{"gateway_ids":{"gateway_id":"eui-7076ff0056080b0f","eui":"7076FF0056080B0F"},"time":"2023-07-18T06:04:10.444Z","timestamp":3101631076,"rssi":-116,"channel_rssi":-116,"snr":-9.5,"uplink_token":"CiIKIAoUZXVpLTcwNzZmZjAwNTYwODBiMGYSCHB2/wBWCAsPEOTE/MYLGgwI2tbYpQYQk7fJjwIgoK35vKLj9wEqDAja1tilBhCAztvTAQ==","channel_index":7,"gps_time":"2023-07-18T06:04:10.444Z","received_at":"2023-07-18T06:04:10.277432218Z"}],"settings":{"data_rate":{"lora":{"bandwidth":125000, "spreading_factor":12, "coding_rate":"4/5"}}, "frequency":"868500000", "timestamp":3101631076, "time":"2023-07-18T06:04:10.444Z"},"received_at":"2023-07-18T06:04:10.570656374Z","consumed_airtime":"1.482752s","version_ids":{"brand_id":"dragino", "model_id":"lt22222-l", "hardware_version":"_unknown_hw_version_", "firmware_version":"1.5.6", "band_id":"EU_863_870"},"network_ids":{"net_id":"000013","tenant_id":"ttn","cluster_id":"eu1","cluster_address":"eu1.cloud.thethings.network"}}}
    Bei jeder neuen Meldung kommt ein neues JSON-File mit aktualisierten Daten.
    @gregors sagte in Payload Daten in Objekte schreiben:
    und du willst immer
    die decoded payload in einzelne Datepunkte schreiben?
    es kommen auch immer nur diese Attribute an?
      und du willst immer
      Marc BergM Online
      Marc BergM Online
      Marc Berg
      @homoran @GregorS
      Nur ein kleiner Hinweis, der LT22222 hat die unangenehme Eigenschaft, abhängig vom "work_mode" unterschiedliche Payloads bereitzustellen. Der mögliche Payload ist wesentlich größer, als der im Beispiel dargestellte!
      Im "Exit Mode" ist es beispielweise dieser:
            decode.Work_mode= "Exit mode";
            decode.Mode_status= bytes[9] ? "True":"False";
            decode.AV1L_flag= (bytes[0] &0x80)? "True":"False";
            decode.AV1H_flag= (bytes[0] &0x40)? "True":"False";
            decode.AV2L_flag= (bytes[0] &0x20)? "True":"False";
            decode.AV2H_flag= (bytes[0] &0x10)? "True":"False";
            decode.AC1L_flag= (bytes[0] &0x08)? "True":"False";
            decode.AC1H_flag= (bytes[0] &0x04)? "True":"False";
            decode.AC2L_flag= (bytes[0] &0x02)? "True":"False";
            decode.AC2H_flag= (bytes[0] &0x01)? "True":"False";
            decode.AV1L_status= (bytes[1] &0x80)? "True":"False";
            decode.AV1H_status= (bytes[1] &0x40)? "True":"False";
            decode.AV2L_status= (bytes[1] &0x20)? "True":"False";
            decode.AV2H_status= (bytes[1] &0x10)? "True":"False";
            decode.AC1L_status= (bytes[1] &0x08)? "True":"False";
            decode.AC1H_status= (bytes[1] &0x04)? "True":"False";
            decode.AC2L_status= (bytes[1] &0x02)? "True":"False";
            decode.AC2H_status= (bytes[1] &0x01)? "True":"False";
            decode.DI2_status= (bytes[2] &0x08)? "True":"False";
            decode.DI2_flag= (bytes[2] &0x04)? "True":"False";
            decode.DI1_status= (bytes[2] &0x02)? "True":"False";
            decode.DI1_flag= (bytes[2] &0x01)? "True":"False";
      paul53P HomoranH 2 Antworten Letzte Antwort
        Folgendes Payload bekomme ich vom Gateway:
        ist das vollständig?
        wo kommt das hin? Liegt es in einem Datenpunkt?
        @homoran sagte in Payload Daten in Objekte schreiben:
        wenn ja, triggerst du auf diesen DP bei Änderung.
        Zerlegst den Inhalt des DP mit Attribut von.. und dem "Pfad zum Wert", z.b. uplink_message.decoded_payload.ACI1_mA
        das schreibst du dann in deinen selbst angelegten Datenpunkt.
        ich habe hier das json als Text eingefügt und das Ergebnis als debug ausgegeben.
        du müsstest mit dem Wert des JSON DP arbeiten und unten die ID des DP für di ACI1 einsetzen
        • Marc BergM Marc Berg
          @homoran @GregorS
          @marc-berg sagte: unterschiedliche Payloads
          Dann sollte man prüfen.
            @homoran @GregorS
            @marc-berg sorry, der cache hatte deine Antwort geschluckt. hab sie jetzt nur durch Pauls reponse gefunden.
              Marc BergM Online
              Marc BergM Online
              Marc Berg
              @paul53 sagte in Payload Daten in Objekte schreiben:
              ja, genau. Wenn man zum Beispiel einen Schaltbefehl als Downlink absetzt, bekommt man immer zwei Uplinks zurück. Einen mit Work_mode "Exit mode" und einen mit Work_Mode "2ACI+2AVI". Das ist zunächst etwas verwirrend, aber sicher der vielfältigen Möglichkeiten geschuldet, die man mit diesem Gerät hat.
              GregorSG 1 Antwort Letzte Antwort
                GregorSG Offline
                GregorSG Offline
                GregorS
                Danke.
                Werde es mal die Tage probieren.
                INTEL NUC i7, Sonoff, hmIP, AVM, Jeelink, T-Link, Alexa, Saia-Burgess, uvm.
                • GregorSG GregorS
                  Danke.
                  GregorSG Offline
                  GregorSG Offline
                  GregorS
                  Leider hat es nicht funktioniert.
                  Beim Blockly kommen folgende Fehlermeldungen:
                  avascript.0
                  	2023-07-20 18:55:46.674	error	script.js.LoRaWAN_DEV_1: Cannot get AVI2_V of null
                  javascript.0
                  	2023-07-20 18:55:46.674	error	script.js.LoRaWAN_DEV_1: Cannot get ACI1_mA of undefined
                  javascript.0
                  	2023-07-20 18:53:46.292	error	script.js.LoRaWAN_DEV_1: Cannot get AVI2_V of null
                  javascript.0
                  	2023-07-20 18:53:46.292	error	script.js.LoRaWAN_DEV_1: Cannot get ACI1_mA of null
                  javascript.0
                  	2023-07-20 18:52:46.262	error	script.js.LoRaWAN_DEV_1: Cannot get AVI2_V of null
                  javascript.0
                  	2023-07-20 18:52:46.261	error	script.js.LoRaWAN_DEV_1: Cannot get ACI1_mA of undefined
                  Habe es dann noch mit einem JS versucht (hier aus dem Forum).
                  Alles angepasst, aber dies hat auch nicht funktioniert.
                  javascript.0
                  	2023-07-20 18:57:52.096	error	at Script.runInContext (node:vm:141:12)
                  javascript.0
                  	2023-07-20 18:57:52.096	error	at script.js.LoRAWAN_DEV_1:127:3
                  javascript.0
                  	2023-07-20 18:57:52.096	error	at script.js.LoRAWAN_DEV_1:1:1
                  javascript.0
                  	2023-07-20 18:57:52.095	error	script.js.LoRAWAN_DEV_1: ReferenceError: ttn_decode is not defined
                  Wie deffiniere ich den TTN_decode?
                  ttn_decode
                  //Device
                  createState("0_userdata.0.LoRaWAN.eui-a840414601871305.ACI_1", false, {
                      read: true,
                      write: false,
                      desc: "",
                      def: 0,
                      unit: "mA",
                      role: "",
                      type: "number"
                  createState("0_userdata.0.LoRaWAN.eui-a840414601871305.ACI_2", false, {
                      read: true,
                      write: false,
                      desc: "",
                      def: 0,
                      unit: "mA",
                      role: "",
                      type: "number"
                  createState("0_userdata.0.LoRaWAN.eui-a840414601871305.AVI_1", false, {
                      read: true,
                      write: false,
                      desc: "",
                      def: 0,
                      unit: "V",
                      role: "",
                      type: "number"
                  createState("0_userdata.0.LoRaWAN.eui-a840414601871305.AVI_2", false, {
                      read: true,
                      write: false,
                      desc: "",
                      def: 0,
                      unit: "V",
                      role: "",
                      type: "number"
                  //const fs = require('fs');
                  on({id: 'v3/gs-mg-dragino-01@ttn/devices/eui-a840414601871305/up', change: "ne"}, function (obj) {
                      obj = JSON.parse(getState("v3/gs-mg-dragino-01@ttn/devices/eui-a840414601871305/up").val);
                      setState("0_userdata.0.LoRaWAN.eui-a840414601871305.ACI_1", parseFloat(obj["payload_fields"]["ACI1_mA"].toFixed(2)), true);
                      setState("0_userdata.0.LoRaWAN.eui-a840414601871305.ACI_2", parseFloat(obj["payload_fields"]["ACI2_mA"].toFixed(2)), true);
                      setState("0_userdata.0.LoRaWAN.eui-a840414601871305.AVI_1", parseFloat(obj["payload_fields"]["AVI1_V"].toFixed(2)), true);
                      setState("0_userdata.0.LoRaWAN.eui-a840414601871305.AVI_2", parseFloat(obj["payload_fields"]["AVI2_V"].toFixed(2)), true);
                      var file = "/opt/iobroker/ttn_log.csv";
                      if(!fs.existsSync(file)) {
                          fs.writeFileSync(file, "Time\tData\r\n");
                      fs.appendFileSync(file, (new Date()).toISOString() + "\t" + getState("on({id: 'v3/gs-mg-dragino-01@ttn/devices/eui-a840414601871305/up', change: "ne"}, function (obj) {
                  ").val + "\r\n");
                  Brauche da wohl ein bisschen Nachilfe.
                  • GregorSG GregorS
                    avascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    javascript.0
                    ttn_decode
                    //Device
                        read: true,
                        write: false,
                        desc: "",
                        def: 0,
                        unit: "mA",
                        role: "",
                        type: "number"
                        read: true,
                        write: false,
                        desc: "",
                        def: 0,
                        unit: "mA",
                        role: "",
                        type: "number"
                        read: true,
                        write: false,
                        desc: "",
                        def: 0,
                        unit: "V",
                        role: "",
                        type: "number"
                        read: true,
                        write: false,
                        desc: "",
                        def: 0,
                        unit: "V",
                        role: "",
                        type: "number"
                    ").val + "\r\n");
                    Hast du die Überprüfung, ob der Inhalt existiert nicht umgesetzt?
                    @marc-berg sagte in Payload Daten in Objekte schreiben:
                    und hier die Lösung
                      und hier die Lösung
                      GregorSG Offline
                      GregorSG Offline
                      GregorS
                      schrieb am zuletzt editiert von GregorS
                      Komme mit mit Blockly nicht klar.
                      Muss ich die Variablen "payload","jason" vorher erstellen? Wo?
                      Muss ich im Attribut "uplink_message...." den Pfad zu meinem Objekt reinkopieren?
                      So sieht meine Struktur aus:
                      Ich sende keine Befehle, sondern empfange nur welche von LoRaWan.
                      Muss ich trotzdem die Abfrage machen?
                      Irgendwie bin ich dazu zu blöd.
                      • GregorSG GregorS
                        @gregors sagte: Muss ich die Variablen "payload","jason" vorher erstellen? Wo?
                        Die Variable payload muss unter "Variablen" erstellt werden.
                        Der Datenpunkt "up" dient als Trigger:
                        Wert findet man unter "Trigger".
                        • GregorSG GregorS
                          avascript.0
                          javascript.0
                          javascript.0
                          javascript.0
                          javascript.0
                          javascript.0
                          javascript.0
                          javascript.0
                          javascript.0
                          javascript.0
                          ttn_decode
                          //Device
                              read: true,
                              write: false,
                              desc: "",
                              def: 0,
                              unit: "mA",
                              role: "",
                              type: "number"
                              read: true,
                              write: false,
                              desc: "",
                              def: 0,
                              unit: "mA",
                              role: "",
                              type: "number"
                              read: true,
                              write: false,
                              desc: "",
                              def: 0,
                              unit: "V",
                              role: "",
                              type: "number"
                              read: true,
                              write: false,
                              desc: "",
                              def: 0,
                              unit: "V",
                              role: "",
                              type: "number"
                          ").val + "\r\n");
                          @gregors sagte: Brauche da wohl ein bisschen Nachilfe.
                          const idUp = 'mqtt.2.v3.gs-mg-dragino-01@ttn.devices.eui-a840414601871305.up'/*v3/gs-mg-dragino-01@ttn/devices/eui-a840414601871305/up*/;
                          on(idUp, function (dp) {
                              let payload = JSON.parse(dp.state.val).uplink_message.decoded_paylod;
                              if(payload && payload.AVI1_V != undefined) {
                                  setState("0_userdata.0.LoRaWAN.eui-a840414601871305.ACI_1", Math.round(payload.ACI1_mA * 100) / 100, true);
                                  setState("0_userdata.0.LoRaWAN.eui-a840414601871305.ACI_2", Math.round(payload.ACI2_mA * 100) / 100, true);
                                  setState("0_userdata.0.LoRaWAN.eui-a840414601871305.AVI_1", Math.round(payload.AVI1_V * 100) / 100, true);
                                  setState("0_userdata.0.LoRaWAN.eui-a840414601871305.AVI_2", Math.round(payload.AVI2_V * 100) / 100, true);
                          Zum Triggern muss die DP-ID - nicht der DP-Name - verwendet werden.
                          • GregorSG Offline
                            GregorSG Offline
                            GregorS
                            Habe ich ausprobiert.
                            Keine Fehler mehr, aber es wird nichts in die Objekte geschrieben.
                            • GregorSG GregorS
                              @gregors sagte: es wird nichts in die Objekte geschrieben.
                              Es wird getriggert, d.h. die ID stimmt?
                                GregorSG Offline
                                GregorSG Offline
                                GregorS
                                Kann ich nicht erkennen.
                                Zur Auswahl unter ID bekam ich nur das Objekt UP angeboten.
                                on('mqtt.2.v3.gs-mg-dragino-01@ttn.devices.eui-a840414601871305.up', function (dp) {
                                        setState("0_userdata.0.LoRaWAN.eui-a840414601871305.ACI1_mA", Math.round(payload.ACI1_mA * 100) / 100, true);
                                        setState("0_userdata.0.LoRaWAN.eui-a840414601871305.ACI2_mA", Math.round(payload.ACI2_mA * 100) / 100, true);
                                        setState("0_userdata.0.LoRaWAN.eui-a840414601871305.AVI1_V", Math.round(payload.AVI1_V * 100) / 100, true);
                                        setState("0_userdata.0.LoRaWAN.eui-a840414601871305.AVI2_V", Math.round(payload.AVI2_V * 100) / 100, true);
                                Kann ich auch mit einem Schedule jede Minute triggern?
                                • GregorSG GregorS
                                  @gregors sagte: Objekt UP
                                  Ändert sich der Inhalt? Es wird nur bei Wertänderung getriggert.
                                    GregorSG Offline
                                    GregorSG Offline
                                    GregorS
                                    Der Wert im Payload ändert sich.
                                    Allerdings nur AVI1_V, da es zur Zeit der einzige angeschlossene Wert ist.
                                    Was bedeutet diese Zeile:
                                    Es gibt doch 4 Variablen mit Daten.
                                    Der Wert von 0_userdata.0.LoRaWAN.eui-a840414601871305.AVI1_V bleibt "0"
                                    Habe ihn händisch als Datenpunkt "Number" angelegt.
                                    • GregorSG GregorS
                                      @gregors sagte: Was bedeutet diese Zeile:
                                      Es wird geprüft, ob das payload-Objekt vorhanden ist und ob es "AVI1_V" enthält.
                                      Wenn "AVI1_V" enthalten ist, sind die anderen auch vorhanden.
                                      Die Zeile 1 mit der ID ist hoffentlich als Kommentar gekennzeichnet?
                                        GregorSG Offline
                                        GregorSG Offline
                                        GregorS
                                        Die Zeile 1 war natürlich nicht als Kommentar gekennzeichnet.
                                        Habe ich aber nachgeholt.
                                        Aber die Werte stehen immer noch auf 0
                                        Fehler gibt es keine
                                        //'mqtt.2.v3.gs-mg-dragino-01@ttn.devices.eui-a840414601871305.up'/*v3/gs-mg-dragino-01@ttn/devices/eui-a840414601871305/up*/
                                        • GregorSG GregorS
                                          @gregors bleibt noch die uralte Frage
                                          bzw. nach dem Hinweis von
                                          die Variante:
                                          was kommt da zurück?
                                          u d zwar bei dedem Abruf?
