  4. Support Adapter Energiefluss-erweitert
vis
4.6k Beiträge 206 Kommentatoren 6.5m Aufrufe 178 Beobachtet
  • A andi2055
    Toller Adapter!
    Spiele gerade etwas damit rum. Irgendwann kann ich keine Elemente mehr einfügen wie Kreis oder Rechteck.
    Bestehendes Duplizieren funktioniert.
    Im Log sind die aber anscheinend mit drin.
    Ein Bug?
    Gibt es die Möglichkeit die Konfig zu exporieren und importieren?
        "basic": {
            "enable_grid": true,
            "enable_animation": false,
            "enable_area_catch": true,
            "enable_config_icon": true,
            "enable_last_id": false,
            "height": 540,
            "width": 530,
            "styles": "",
            "font": {
                "family": "\"Arial\", sans-serif",
                "size": "20",
                "color": "",
                "fill": "",
                "align": "middle"
            "rect": {
                "height": 100,
                "width": 100,
                "corners": 10
            "circle": {
                "radius": 50
            "elm": {
                "stroke_width": 5,
                "color": "",
                "fill": "",
                "pos_x": "50",
                "pos_y": "50"
            "icon": {
                "height": 24,
                "width": 24,
                "color": ""
        "calculation": {
            "battery": {
                "dod": 0,
                "capacity": 0,
                "percent": null,
                "charge": null,
                "charge_prop": false,
                "charge_kw": false,
                "discharge": null,
                "discharge_prop": false,
                "discharge_kw": false
        "animation": {
            "stroke": "#ffce4a",
            "stroke_dasharray": "10 17 10 17 10  72",
            "stroke_width": "6",
            "animation_duration": "2000",
            "stroke_linecap": "round",
            "animation_timing_function": "linear"
        "animation_configuration": {
            "dots": "3",
            "distance": "17",
            "length": "10"
        "line": {
            "stroke_width": "8",
            "stroke": "#000000"
        "elements": {
            "2": {
                "type": "text",
                "subType": "datasource",
                "id": 2,
                "pos_x": 84,
                "pos_y": 59,
                "color": "none",
                "fill": "rgb(255, 206, 74)",
                "font_family": "Arial, sans-serif",
                "font_size": 18,
                "degree": 0,
                "align": "middle",
                "text": "ID 2",
                "unit": "W",
                "append": "",
                "prepend": "",
                "source": "0",
                "source_option": "-1",
                "source_display": "value",
                "shadow": "",
                "threshold": 0,
                "calculate_kw": false,
                "convert": false,
                "decimal_places": 0,
                "subtract": [
                    -1
                "css_general": "",
                "css_active_positive": "",
                "css_inactive_positive": "",
                "css_active_negative": "",
                "css_inactive_negative": ""
            "5": {
                "type": "rect",
                "id": 5,
                "rx": 10,
                "height": 100,
                "width": 100,
                "pos_x": 35,
                "pos_y": 18,
                "fill": "none",
                "color": "rgb(255, 206, 74)",
                "stroke": 2,
                "shadow": "rgba(0,0,0,0.7)",
                "frame": "_overlay",
                "url": "",
                "fill_value": null,
                "fill_type": "percent",
                "fill_direction": "90",
                "fill_max": null,
                "source": -1,
                "threshold": 0,
                "css_general": "",
            "6": {
                "type": "icon",
                "id": "6",
                "icon": "material-symbols:solar-power",
                "width": 24,
                "height": 24,
                "color": "rgba(0, 0, 0, 0.7)",
                "pos_x": "73",
                "pos_y": "22",
                "shadow": "",
                "css_general": "",
                "css_inactive_negative": "",
                "source": -1,
                "threshold": 0
            "7": {
                "type": "rect",
                "id": 7,
                "rx": 10,
                "height": 100,
                "width": 100,
                "pos_x": 171,
                "pos_y": 176,
                "fill": "none",
                "color": "rgb(0, 181, 221)",
                "stroke": 2,
                "url": "",
                "fill_value": null,
                "fill_direction": 90,
                "fill_max": null,
                "source": -1,
                "threshold": 0,
                "css_general": "",
            "9": {
                "type": "text",
                "id": 9,
                "pos_x": 221,
                "pos_y": 218,
                "color": "none",
                "fill": "rgb(0, 181, 221)",
                "font_size": 18,
                "degree": 0,
                "align": "middle",
                "text": "ID 9",
                "unit": "kW",
                "append": "",
                "prepend": "",
                "source": -1,
                "source_option": -1,
                "shadow": "",
                "threshold": 0,
                "calculate_kw": true,
                "convert": false,
                "decimal_places": 2,
                "subtract": [
                    -1
                "css_general": "",
            "10": {
                "type": "text",
                "id": 10,
                "pos_x": 87,
                "pos_y": 90,
                "color": "none",
                "fill": "rgba(0, 0, 0, 0.7)",
                "font_size": 14,
                "degree": 0,
                "align": "middle",
                "text": "Produktion",
                "shadow": "",
                "css_general": ""
            "11": {
                "type": "text",
                "id": 11,
                "pos_x": 221,
                "pos_y": 252,
                "color": "none",
                "font_size": 14,
                "degree": 0,
                "align": "middle",
                "text": "Verbrauch",
                "shadow": "",
                "css_general": ""
            "12": {
                "type": "icon",
                "id": "12",
                "icon": "mdi:house-city",
                "width": 24,
                "height": 24,
                "pos_x": "209",
                "pos_y": "182",
                "shadow": "",
                "css_general": "",
                "source": 1,
                "threshold": 0
            "14": {
                "type": "rect",
                "id": 14,
                "rx": 10,
                "height": 100,
                "width": 100,
                "pos_x": 35,
                "pos_y": 342,
                "fill": "none",
                "color": "rgba(97, 104, 122, 0.7)",
                "stroke": 2,
                "url": "",
                "fill_value": null,
                "fill_max": null,
                "source": -1,
                "threshold": 0,
                "css_general": "",
            "19": {
                "type": "text",
                "id": 19,
                "pos_x": 85,
                "pos_y": 384,
                "color": "none",
                "fill": "rgb(97, 104, 122)",
                "font_size": 18,
                "degree": 0,
                "align": "middle",
                "text": "ID 19",
                "unit": "kW",
                "append": "",
                "prepend": "",
                "source": "1",
                "shadow": "",
                "threshold": 0,
                "convert": false,
                "subtract": [
                    -1
                "css_general": "",
            "20": {
                "type": "icon",
                "id": "20",
                "icon": "mdi:electricity-from-grid",
                "width": 24,
                "height": 24,
                "pos_x": "73",
                "pos_y": "348",
                "shadow": "",
                "css_general": "",
                "source": -1,
                "threshold": 0
            "21": {
                "type": "text",
                "id": 21,
                "pos_x": 85,
                "pos_y": 418,
                "color": "none",
                "font_size": 14,
                "degree": 0,
                "align": "middle",
                "text": "Netz",
                "shadow": "",
                "css_general": ""
            "22": {
                "type": "rect",
                "id": 22,
                "rx": 10,
                "height": 100,
                "width": 100,
                "pos_x": 354,
                "pos_y": 255,
                "fill": "url(\"#gradient_22\")",
                "color": "rgb(197, 144, 46)",
                "stroke": 2,
                "url": "",
                "fill_value": null,
                "fill_max": null,
                "source": 2,
                "threshold": 0,
                "css_general": "",
            "23": {
                "type": "icon",
                "id": "23",
                "icon": "material-symbols:heat-pump-outline",
                "width": 24,
                "height": 24,
                "pos_x": "392",
                "pos_y": "261",
                "shadow": "",
                "css_general": "",
                "source": -1,
                "threshold": 0
            "24": {
                "type": "text",
                "id": 24,
                "pos_x": 404,
                "pos_y": 331,
                "color": "none",
                "font_size": 14,
                "degree": 0,
                "align": "middle",
                "text": "LWP",
                "shadow": "",
                "css_general": ""
            "26": {
                "type": "text",
                "id": 26,
                "pos_x": 405,
                "pos_y": 297,
                "color": "none",
                "fill": "rgb(197, 144, 46)",
                "font_size": 18,
                "degree": 0,
                "align": "middle",
                "text": "ID 26",
                "unit": "kW",
                "append": "",
                "prepend": "",
                "source": 2,
                "shadow": "",
                "threshold": 0,
                "convert": false,
                "subtract": [
                    -1
                "css_general": "",
            "28": {
                "type": "rect",
                "id": 28,
                "rx": 10,
                "height": 100,
                "width": 100,
                "pos_x": 351,
                "pos_y": 98,
                "fill": "none",
                "color": "rgb(37, 214, 254)",
                "stroke": 5,
                "shadow": "",
                "url": "",
                "fill_value": null,
                "fill_type": -1,
                "fill_max": null,
                "source": 1,
                "threshold": 0,
                "css_general": "",
            "29": {
                "type": "icon",
                "id": "29",
                "icon": "mdi:house",
                "width": 24,
                "height": 24,
                "color": "rgb(0, 0, 0)",
                "pos_x": "387",
                "pos_y": "100",
                "shadow": "",
                "css_general": "",
                "source": -1,
                "threshold": 0
            "30": {
                "type": "text",
                "id": 30,
                "pos_x": 374,
                "pos_y": 178,
                "color": "none",
                "fill": "rgb(142, 224, 227)",
                "font_size": 20,
                "degree": 0,
                "align": "start",
                "text": "Haus",
                "shadow": "",
                "css_general": ""
            "31": {
                "type": "text",
                "id": 31,
                "pos_x": 5031,
                "pos_y": 5021,
                "color": "none",
                "fill": "rgb(78, 130, 215)",
                "font_size": 20,
                "degree": 0,
                "align": "start",
                "text": "ID 31",
                "unit": "kW",
                "append": "",
                "prepend": "",
                "source": -1,
                "shadow": "",
                "threshold": 0,
                "convert": false,
                "subtract": [
                    -1
                "css_general": "",
            "32": {
                "type": "text",
                "id": 32,
                "pos_x": 503,
                "pos_y": 5045,
                "color": "none",
                "fill": "rgb(119, 111, 110)",
                "font_size": 20,
                "degree": 0,
                "align": "start",
                "text": "Text",
                "shadow": "",
                "css_general": ""
            "33": {
                "type": "text",
                "id": 33,
                "pos_x": 400,
                "pos_y": 147,
                "color": "none",
                "font_size": 18,
                "degree": 0,
                "align": "middle",
                "text": "ID 33",
                "unit": "W",
                "append": "",
                "prepend": "",
                "source": "1",
                "shadow": "",
                "threshold": 0,
                "convert": false,
                "subtract": [
                    -1
                "css_general": "",
            "34": {
                "type": "circle",
                "id": 34,
                "radius": 50,
                "pos_x": 5024,
                "pos_y": 500,
                "fill": "none",
                "color": "rgb(68, 172, 252)",
                "stroke": 5,
                "shadow": "",
                "url": "",
                "fill_value": null,
                "fill_type": -1,
                "fill_max": null,
                "source": -1,
                "threshold": 0,
                "css_general": "",
            "35": {
                "type": "rect",
                "id": 35,
                "rx": 10,
                "height": 100,
                "width": 100,
                "pos_x": 5023,
                "pos_y": 5012,
                "fill": "none",
                "color": "rgb(40, 176, 44)",
                "stroke": 5,
                "shadow": "",
                "url": "",
                "fill_value": null,
                "fill_type": -1,
                "fill_max": null,
                "source": -1,
                "threshold": 0,
                "css_general": "",
            "36": {
                "type": "rect",
                "id": 36,
                "rx": 10,
                "height": 100,
                "width": 100,
                "pos_x": 509,
                "pos_y": 5027,
                "fill": "none",
                "color": "rgb(186, 78, 128)",
                "stroke": 5,
                "shadow": "",
                "url": "",
                "fill_value": null,
                "fill_type": -1,
                "fill_max": null,
                "source": -1,
                "threshold": 0,
                "css_general": "",
        "defs": {
            "path_5_7": {
                "type": "def",
                "id": "path_5_7",
                "d": "M105 119  V 130.2 A 15 15 0 0 0 120 145.2  H 186 A 15 15 0 0 1 201 160.2  V 175",
                "startSlot": "bottom_right",
                "endSlot": "top_left"
            "path_14_7": {
                "type": "def",
                "id": "path_14_7",
                "d": "M105 341  V 328.2 A 15 15 0 0 1 120 313.2  H 186 A 15 15 0 0 0 201 298.2  V 277",
                "startSlot": "top_right",
                "endSlot": "bottom_left"
            "path_5_14": {
                "type": "def",
                "id": "path_5_14",
                "d": "M85 119  V 341",
                "startSlot": "bottom",
                "endSlot": "top"
            "path_7_28": {
                "type": "def",
                "id": "path_7_28",
                "d": "M272 206  H 287.2 A 15 15 0 0 0 302.2 191  V 163 A 15 15 0 0 1 317.2 148  H 348.5",
                "startSlot": "right_top",
                "endSlot": "left"
            "path_7_22": {
                "type": "def",
                "id": "path_7_22",
                "d": "M272 246  H 288.2 A 15 15 0 0 1 303.2 261  V 290 A 15 15 0 0 0 318.2 305  H 353",
                "startSlot": "right_bottom",
                "endSlot": "left"
        "lines": {
            "line_path_5_7": {
                "type": "line",
                "id": "line_path_5_7",
                "href": "#path_5_7",
                "shadow": ""
            "line_path_14_7": {
                "type": "line",
                "id": "line_path_14_7",
                "href": "#path_14_7",
                "shadow": ""
            "line_path_5_14": {
                "type": "line",
                "id": "line_path_5_14",
                "href": "#path_5_14",
                "shadow": ""
            "line_path_7_28": {
                "type": "line",
                "id": "line_path_7_28",
                "href": "#path_7_28",
                "shadow": ""
            "line_path_7_22": {
                "type": "line",
                "id": "line_path_7_22",
                "href": "#path_7_22",
                "shadow": ""
        "animations": {
            "anim_path_5_7": {
                "type": "animation",
                "id": "anim_path_5_7",
                "source": -1,
                "threshold": 0,
                "animation_properties": "positive",
                "animation_option": false,
                "dots": 0,
                "duration": 0,
                "power": 0,
                "animation_type": -1,
                "css_general": "",
            "anim_path_14_7": {
                "id": "anim_path_14_7",
                "source": -1,
                "threshold": 10,
                "animation_properties": "negative",
                "dots": 0,
                "duration": 0,
                "power": 0,
                "css_general": "",
            "anim_path_5_14": {
                "id": "anim_path_5_14",
                "source": -1,
                "threshold": 0,
                "dots": 0,
                "duration": 0,
                "power": 0,
                "css_general": "",
            "anim_path_7_28": {
                "id": "anim_path_7_28",
                "source": -1,
                "threshold": 0,
                "dots": 0,
                "duration": 0,
                "power": 0,
                "css_general": "",
            "anim_path_7_22": {
                "id": "anim_path_7_22",
                "source": -1,
                "threshold": 0,
                "dots": 0,
                "duration": 0,
                "power": 0,
                "css_general": "",
        "datasources": {
            "0": {
                "source": "alias.0.PV.30775_Measurement_GridMs_TotW",
                "alias": "PV_Power"
            "1": {
                "source": "linkeddevices.0.KG.Stromzähler.Haus_Power_curr",
                "alias": "Haus_Power"
            "2": {
                "source": "linkeddevices.0.KG.Stromzähler.LWP_Power_curr",
                "alias": "LWP_Power"
    #778
    @andi2055 sagte in Test Adapter Energiefluss-erweitert v0.0.x GitHub/Latest:
    ja!
    unter objekten in den Datenpunkten
    • A andi2055
      Toller Adapter!
      Ein Bug?
          "basic": {
              "height": 540,
              "width": 530,
              "styles": "",
              "font": {
                  "size": "20",
                  "color": "",
                  "fill": "",
                  "align": "middle"
              "rect": {
                  "height": 100,
                  "width": 100,
                  "corners": 10
              "circle": {
                  "radius": 50
              "elm": {
                  "stroke_width": 5,
                  "color": "",
                  "fill": "",
                  "pos_x": "50",
                  "pos_y": "50"
              "icon": {
                  "height": 24,
                  "width": 24,
                  "color": ""
          "calculation": {
              "battery": {
                  "dod": 0,
                  "capacity": 0,
                  "percent": null,
                  "charge": null,
                  "charge_kw": false,
                  "discharge": null,
          "animation": {
              "dots": "3",
              "distance": "17",
              "length": "10"
          "line": {
              "stroke": "#000000"
          "elements": {
              "2": {
                  "type": "text",
                  "id": 2,
                  "pos_x": 84,
                  "pos_y": 59,
                  "color": "none",
                  "font_size": 18,
                  "degree": 0,
                  "align": "middle",
                  "text": "ID 2",
                  "unit": "W",
                  "append": "",
                  "prepend": "",
                  "source": "0",
                  "shadow": "",
                  "threshold": 0,
                  "convert": false,
                  "subtract": [
                      -1
                  "css_general": "",
              "5": {
                  "type": "rect",
                  "id": 5,
                  "rx": 10,
                  "height": 100,
                  "width": 100,
                  "pos_x": 35,
                  "pos_y": 18,
                  "fill": "none",
                  "stroke": 2,
                  "url": "",
                  "fill_value": null,
                  "fill_max": null,
                  "source": -1,
                  "threshold": 0,
                  "css_general": "",
              "6": {
                  "type": "icon",
                  "id": "6",
                  "width": 24,
                  "height": 24,
                  "pos_x": "73",
                  "pos_y": "22",
                  "shadow": "",
                  "css_general": "",
                  "source": -1,
                  "threshold": 0
              "7": {
                  "type": "rect",
                  "id": 7,
                  "rx": 10,
                  "height": 100,
                  "width": 100,
                  "pos_x": 171,
                  "pos_y": 176,
                  "fill": "none",
                  "stroke": 2,
                  "url": "",
                  "fill_value": null,
                  "fill_max": null,
                  "source": -1,
                  "threshold": 0,
                  "css_general": "",
              "9": {
                  "type": "text",
                  "id": 9,
                  "pos_x": 221,
                  "pos_y": 218,
                  "color": "none",
                  "font_size": 18,
                  "degree": 0,
                  "align": "middle",
                  "text": "ID 9",
                  "unit": "kW",
                  "append": "",
                  "prepend": "",
                  "source": -1,
                  "shadow": "",
                  "threshold": 0,
                  "convert": false,
                  "subtract": [
                      -1
                  "css_general": "",
              "10": {
                  "type": "text",
                  "id": 10,
                  "pos_x": 87,
                  "pos_y": 90,
                  "color": "none",
                  "font_size": 14,
                  "degree": 0,
                  "align": "middle",
                  "shadow": "",
                  "css_general": ""
              "11": {
                  "type": "text",
                  "id": 11,
                  "pos_x": 221,
                  "pos_y": 252,
                  "color": "none",
                  "font_size": 14,
                  "degree": 0,
                  "align": "middle",
                  "shadow": "",
                  "css_general": ""
              "12": {
                  "type": "icon",
                  "id": "12",
                  "width": 24,
                  "height": 24,
                  "pos_x": "209",
                  "pos_y": "182",
                  "shadow": "",
                  "css_general": "",
                  "source": 1,
                  "threshold": 0
              "14": {
                  "type": "rect",
                  "id": 14,
                  "rx": 10,
                  "height": 100,
                  "width": 100,
                  "pos_x": 35,
                  "pos_y": 342,
                  "fill": "none",
                  "stroke": 2,
                  "url": "",
                  "fill_value": null,
                  "fill_max": null,
                  "source": -1,
                  "threshold": 0,
                  "css_general": "",
              "19": {
                  "type": "text",
                  "id": 19,
                  "pos_x": 85,
                  "pos_y": 384,
                  "color": "none",
                  "font_size": 18,
                  "degree": 0,
                  "align": "middle",
                  "text": "ID 19",
                  "unit": "kW",
                  "append": "",
                  "prepend": "",
                  "source": "1",
                  "shadow": "",
                  "threshold": 0,
                  "convert": false,
                  "subtract": [
                      -1
                  "css_general": "",
              "20": {
                  "type": "icon",
                  "id": "20",
                  "width": 24,
                  "height": 24,
                  "pos_x": "73",
                  "pos_y": "348",
                  "shadow": "",
                  "css_general": "",
                  "source": -1,
                  "threshold": 0
              "21": {
                  "type": "text",
                  "id": 21,
                  "pos_x": 85,
                  "pos_y": 418,
                  "color": "none",
                  "font_size": 14,
                  "degree": 0,
                  "align": "middle",
                  "text": "Netz",
                  "shadow": "",
                  "css_general": ""
              "22": {
                  "type": "rect",
                  "id": 22,
                  "rx": 10,
                  "height": 100,
                  "width": 100,
                  "pos_x": 354,
                  "pos_y": 255,
                  "stroke": 2,
                  "url": "",
                  "fill_value": null,
                  "fill_max": null,
                  "source": 2,
                  "threshold": 0,
                  "css_general": "",
              "23": {
                  "type": "icon",
                  "id": "23",
                  "width": 24,
                  "height": 24,
                  "pos_x": "392",
                  "pos_y": "261",
                  "shadow": "",
                  "css_general": "",
                  "source": -1,
                  "threshold": 0
              "24": {
                  "type": "text",
                  "id": 24,
                  "pos_x": 404,
                  "pos_y": 331,
                  "color": "none",
                  "font_size": 14,
                  "degree": 0,
                  "align": "middle",
                  "text": "LWP",
                  "shadow": "",
                  "css_general": ""
              "26": {
                  "type": "text",
                  "id": 26,
                  "pos_x": 405,
                  "pos_y": 297,
                  "color": "none",
                  "font_size": 18,
                  "degree": 0,
                  "align": "middle",
                  "text": "ID 26",
                  "unit": "kW",
                  "append": "",
                  "prepend": "",
                  "source": 2,
                  "shadow": "",
                  "threshold": 0,
                  "convert": false,
                  "subtract": [
                      -1
                  "css_general": "",
              "28": {
                  "type": "rect",
                  "id": 28,
                  "rx": 10,
                  "height": 100,
                  "width": 100,
                  "pos_x": 351,
                  "pos_y": 98,
                  "fill": "none",
                  "stroke": 5,
                  "shadow": "",
                  "url": "",
                  "fill_value": null,
                  "fill_type": -1,
                  "fill_max": null,
                  "source": 1,
                  "threshold": 0,
                  "css_general": "",
              "29": {
                  "type": "icon",
                  "id": "29",
                  "width": 24,
                  "height": 24,
                  "pos_x": "387",
                  "pos_y": "100",
                  "shadow": "",
                  "css_general": "",
                  "source": -1,
                  "threshold": 0
              "30": {
                  "type": "text",
                  "id": 30,
                  "pos_x": 374,
                  "pos_y": 178,
                  "color": "none",
                  "font_size": 20,
                  "degree": 0,
                  "align": "start",
                  "text": "Haus",
                  "shadow": "",
                  "css_general": ""
              "31": {
                  "type": "text",
                  "id": 31,
                  "pos_x": 5031,
                  "pos_y": 5021,
                  "color": "none",
                  "font_size": 20,
                  "degree": 0,
                  "align": "start",
                  "text": "ID 31",
                  "unit": "kW",
                  "append": "",
                  "prepend": "",
                  "source": -1,
                  "shadow": "",
                  "threshold": 0,
                  "convert": false,
                  "subtract": [
                      -1
                  "css_general": "",
              "32": {
                  "type": "text",
                  "id": 32,
                  "pos_x": 503,
                  "pos_y": 5045,
                  "color": "none",
                  "font_size": 20,
                  "degree": 0,
                  "align": "start",
                  "text": "Text",
                  "shadow": "",
                  "css_general": ""
              "33": {
                  "type": "text",
                  "id": 33,
                  "pos_x": 400,
                  "pos_y": 147,
                  "color": "none",
                  "font_size": 18,
                  "degree": 0,
                  "align": "middle",
                  "text": "ID 33",
                  "unit": "W",
                  "append": "",
                  "prepend": "",
                  "source": "1",
                  "shadow": "",
                  "threshold": 0,
                  "convert": false,
                  "subtract": [
                      -1
                  "css_general": "",
              "34": {
                  "type": "circle",
                  "id": 34,
                  "radius": 50,
                  "pos_x": 5024,
                  "pos_y": 500,
                  "fill": "none",
                  "stroke": 5,
                  "shadow": "",
                  "url": "",
                  "fill_value": null,
                  "fill_type": -1,
                  "fill_max": null,
                  "source": -1,
                  "threshold": 0,
                  "css_general": "",
              "35": {
                  "type": "rect",
                  "id": 35,
                  "rx": 10,
                  "height": 100,
                  "width": 100,
                  "pos_x": 5023,
                  "pos_y": 5012,
                  "fill": "none",
                  "stroke": 5,
                  "shadow": "",
                  "url": "",
                  "fill_value": null,
                  "fill_type": -1,
                  "fill_max": null,
                  "source": -1,
                  "threshold": 0,
                  "css_general": "",
              "36": {
                  "type": "rect",
                  "id": 36,
                  "rx": 10,
                  "height": 100,
                  "width": 100,
                  "pos_x": 509,
                  "pos_y": 5027,
                  "fill": "none",
                  "stroke": 5,
                  "shadow": "",
                  "url": "",
                  "fill_value": null,
                  "fill_type": -1,
                  "fill_max": null,
                  "source": -1,
                  "threshold": 0,
                  "css_general": "",
          "defs": {
              "path_5_7": {
                  "type": "def",
                  "id": "path_5_7",
              "path_14_7": {
                  "type": "def",
                  "id": "path_14_7",
              "path_5_14": {
                  "type": "def",
                  "id": "path_5_14",
                  "endSlot": "top"
              "path_7_28": {
                  "type": "def",
                  "id": "path_7_28",
                  "endSlot": "left"
              "path_7_22": {
                  "type": "def",
                  "id": "path_7_22",
                  "endSlot": "left"
          "lines": {
              "line_path_5_7": {
                  "type": "line",
                  "shadow": ""
              "line_path_14_7": {
                  "type": "line",
                  "shadow": ""
              "line_path_5_14": {
                  "type": "line",
                  "shadow": ""
              "line_path_7_28": {
                  "type": "line",
                  "shadow": ""
              "line_path_7_22": {
                  "type": "line",
                  "shadow": ""
          "animations": {
              "anim_path_5_7": {
                  "source": -1,
                  "threshold": 0,
                  "dots": 0,
                  "duration": 0,
                  "power": 0,
                  "css_general": "",
              "anim_path_14_7": {
                  "source": -1,
                  "threshold": 10,
                  "dots": 0,
                  "duration": 0,
                  "power": 0,
                  "css_general": "",
              "anim_path_5_14": {
                  "source": -1,
                  "threshold": 0,
                  "dots": 0,
                  "duration": 0,
                  "power": 0,
                  "css_general": "",
              "anim_path_7_28": {
                  "source": -1,
                  "threshold": 0,
                  "dots": 0,
                  "duration": 0,
                  "power": 0,
                  "css_general": "",
              "anim_path_7_22": {
                  "source": -1,
                  "threshold": 0,
                  "dots": 0,
                  "duration": 0,
                  "power": 0,
                  "css_general": "",
          "datasources": {
              "0": {
                  "alias": "PV_Power"
              "1": {
              "2": {
      SKBS Offline
      SKBS Offline
      SKB
      #779
      @andi2055 Du hast in den Basis Einstellungen die Farbe entweder entfernt oder nicht gespeichert.
      Daher sind die Elemente ohne Farbe.
      • SKBS SKB
        @happyuser20 Das ist eine prima Idee :) Danke für den Tipp.
        Ich habe hier einmal ein Beispiel. Man könnte dann die Hintergrundfarbe des Kreises angeben und die der Umrandung.
        Ich denke, man sollte auch Startpunkte angeben können. Dauert nur etwas, bis ich das fertig habe.
        H Online
        H Online
        Happyuser20
        #780
        @skb Wenn das noch kommt, ist der Adapter für Perfekt 👍 😀
        SKBS 2 Antworten Letzte Antwort
        • H Happyuser20
          SKBS Offline
          SKBS Offline
          SKB
          #781
          @happyuser20 freut mich, wenn du dies so siehst ;)
          Es kommen doch immer neue Ideen dazu.
          • SKBS SKB
            andi2055
            #782
            @skb sagte in Test Adapter Energiefluss-erweitert v0.0.x GitHub/Latest:
            Bewusst habe ich da unter Settings nichts manuell geändert. Die Farbe muss da irgendwann durch eine andere Aktion entfernt worden sein... Ich habe auch neue Instanzen erzeugt, um von Anfang an zu starten und das ist mir mehrfach passiert.
            Nun habe ich eine Farbe manuell eingefügt, gespeichert und neu aufgerufen.
            Trotzdem erscheinen keine neuen Elemente...?
            Muss ich noch etwas tun? Danke dir!
            SKBS 1 Antwort Letzte Antwort
            • A andi2055
              SKBS Offline
              SKBS Offline
              SKB
              #783
              @andi2055 Gespeichert hast Du die Dinge aber, ja?
              Erscheinen bei F12 Fehler im Browser?
              • SKBS SKB
                andi2055
                #784
                @skb
                Fehler gerade entdeckt. Die Position ist außerhalb des Bereiches...
                Muss ich was tun oder ein Bug?
                • A andi2055
                  @skb
                  SKBS Offline
                  SKBS Offline
                  SKB
                  #785
                  @andi2055 Was mich hier wundert, warum es bei den Anderen geht und bei dir nicht - bei mir geht es ja auch.
                  Edit: Kommando zurück - ich konnte den Fehler nachstellen. Gib' mir ein paar Minuten, dann habe ich es behoben.
                  • A andi2055
                    @skb
                    SKBS Offline
                    SKBS Offline
                    SKB
                    #786
                    @andi2055 Fehler ist behoben. Kannst einfach nochmal von Github drüber installieren.
                    Am Besten lädst Du dann die Daten aus dem Datenpunkt
                    energiefluss-erweiter.<Instance>.configuration
                    einmal in einen Editor und suchst nach "pos_x" und "pos_y" und passt dort in etwa die Koordinaten an, das sie passen und legst es dann wieder in den Datenpunkt zurück.
                    Sorry für den blöden Fehler.
                    • SKBS SKB
                      andi2055
                      #787
                      super, Danke dir. Funktioniert nun!
                      • H Happyuser20
                        SKBS Offline
                        SKBS Offline
                        SKB
                        #788
                        @happyuser20 wäre dies etwas, was dich zufrieden stellen würde?
                        Konfigurieren kann man dies dann so:
                        HomoranH H 2 Antworten Letzte Antwort
                        • SKBS SKB
                          #789
                          du denkst an alles!
                          ich habs mal abgewartet 😀
                          den Maximalwert braucht's ja.
                            du denkst an alles!
                            SKBS Offline
                            SKBS Offline
                            SKB
                            #790
                            @homoran also könnte man dies so einpflegen?
                            • SKBS SKB
                              #791
                              @skb ich denke, das ist eine gute, sinnvolle Variante. Zumindest bei Kreisen, die ich bisher nicht verwende.
                                SKBS Offline
                                SKBS Offline
                                SKB
                                #792
                                @homoran geht ja bei den Rechtecken auch ;)
                                • Issr4kI Offline
                                  Issr4kI Offline
                                  Issr4k
                                  schrieb am zuletzt editiert von Issr4k
                                  #793
                                  Toller Adapter!
                                  Löst meine ekelhafte verbastelte Eigenbaulösung ab… die ähnlich aussieht, aber die Hölle ist wenn was geändert werden muss…
                                  Hätte drei Anmerkungen / Fragen und hoffe, dass ich das beim überfliegen des Threads nicht übersehen habe…
                                  • Können auch Bilder oder speziell svg‘s statt der Icons eingebunden werden? Falls ja, zufällig ein Beispiel parat?
                                  • Gleiches für nicht Standard Schriftarten…
                                  • Sind die Verbindungslinien per Gradient färbbar?
                                  • SKBS SKB
                                    H Online
                                    H Online
                                    Happyuser20
                                    #794
                                    @skb Spitze 👍 👍 👍
                                    • Issr4kI Issr4k
                                      Toller Adapter!
                                      SKBS Offline
                                      SKBS Offline
                                      SKB
                                      #795
                                      @issr4k Bilder habe ich nicht vorgesehen, da ich keinen Upload zur Verfügung stellen kann.
                                      Jedoch könnte man ein Rechteck oder Kreis auf dem Workspace platzieren und dort dann per CSS ein Hintergrundbild einbinden (soweit die Theorie).
                                      Mit den Schriftarten verhält sich ähnlich. Diese können per CSS eingebunden werden.
                                      Mit Linie und Gradient müsstest Du noch ein wenig erläutern, was du da möchtest? Einen Farbverlauf?
                                      Issr4kI 1 Antwort Letzte Antwort
                                      • H Happyuser20
                                        @skb Spitze 👍 👍 👍
                                        SKBS Offline
                                        SKBS Offline
                                        SKB
                                        #796
                                        @happyuser20 das klingt nach einem Happy User :D
                                        Melde mich, sobald es eingepflegt ist.
                                        • SKBS SKB
                                          Issr4kI Offline
                                          Issr4kI Offline
                                          Issr4k
                                          #797
                                          @skb ja genau Farbverläufe :)
                                          Als Bildslternative ist ein svg codr ja sowieso die bessere Wahl.
                                          Werde es mal versuchen in so einen Platzhalter zu packen.
                                          Dankeschön!
