  4. Test Adapter Philips-TV v0.2.x
philipsphilips tv
550 Beiträge 84 Kommentatoren 188.0k Aufrufe 48 Beobachtet
  • M Michaelnorge
    Hier das gleiche Problem, mein Philips hat sich auf Android 11 upgedated und seitdem funktioniert der Addapter nicht mehr.
    Could not poll API: {"statusCode":401,"body":"<html>\n<head>\n <title>Status page</title>\n</head>\n<body style=\"font-family: sans-serif;\">\n<p style=\"font-size: 1.2em;font-weight: bold;margin: 1em 0px;\">Unauthorized</p>\n<p>The request requires user authentication</p>\n<p>You can get technical details <a href=\"http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html#sec10.4.2\">here</a>.<br>\nPlease continue your visit at our <a href=\"/\">home page</a>.\n</p>\n</body>\n</html>\n","headers":{"date":"Wed, 03 Jul 2024 17:18:57 GMT","accept-ranges":"bytes","server":"Restlet-Framework/2.3.12","www-authenticate":"Digest realm=\"XTV\", domain=\"/\", nonce=\"MTcyMDAyNzEzNzA1Njo2MDVkMzI3ZjM5ZjNhZTdiNTk0OTE5YzE2NWJkNzhhNQ==\", algorithm=MD5, qop=\"auth\"","content-length":"424","content-type":"text/html; charset=UTF-8"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"192.168.178.177:1926","port":"1926","hostname":"192.168.178.177","hash":null,"search":null,"query":null,"pathname":"/6/audio/volume","path":"/6/audio/volume","href":"https://192.168.178.177:1926/6/audio/volume"},"method":"GET","headers":{"authorization":"Digest username=\"thdRK4quOUoh9nGV\", realm=\"XTV\", nonce=\"MTcyMDAyNzEzNzAzNzpiMWU5NjZiMzhmNDFiNjFhN2JiOTE1ZTUwOTE2MTkxMA==\", uri=\"/6/audio/volume\", qop=auth, response=\"79fbee052dd5e76eeb4566b828565e7b\", nc=00000001, cnonce=\"f609e2997c8c4f74a99a45fb2266d454\", algorithm=MD5","referer":"https://192.168.178.177:1926/6/audio/volume"}}}
    Das ist was im Log steht....
    Lucky_ESA
    #521
    @michaelnorge Was hast du denn in der Instanzeinstellung ausgewählt. Ist dieser Logeintrag einmalig?
    Gruß//Lucky
      DaPeace
      #522
      Kann ich mit dem Adapter auch irgendwie die Waipu.TV-App starten wenn die Glotze aus ist? Evt sogar einen direkten Sender? Momentan macht mir Siri die Glotze an/aus, aber das wars eben. Ich würde jetzt gerne für meinen Junior Kika über die Waipu.TV-App starten.
      Grüsse, DaPeace
      • L Lucky_ESA
        @adri525 Das sieht gut aus.
        Wahrscheinlich ist dein Problem eher ein Fall für @Thomas-Braun und iob diag
        Vorab gesagt: Die MAC muss immer Großbuchstaben haben und der PIN darf nur Zahlen beinhalten.
        Welchen Browser nutzt du, welche Admin Version hast du und bist du mit Windows oder Linux unterwegs?
        Du kannst nun mehrere Möglichkeiten ausprobieren:
        Adapter löschen: Bitte links Adapter auswählen, dann den Expertmodus aktivieren, den Adapter suchen und die Mülltonnenzeichen drücken. Danach in deiner Konsole das eingeben
        iob stop
        iob fix
        iob start
        Danach am besten deinen Cache vom Browser leeren und eine neu Instanz von philips-tv unter adpter hinzufügen. Jetzt dann bitte nur deine IP eintragen und den Pairing Button drücken.
        Kommt dann wieder deine Fehlermeldung dann bitte mal das probieren.
        Javascript Adapter installieren und 2 Javascripte anlegen.
        Das erst mit diesem Inhalt füllen..ggf. deine IP anpassen.
        sendTo("philips-tv.0", "pairing", "192.168.1.50"
        , async function (result) {
            console.log(result);
        In das 2te diesen Inhalt kopieren und speichern. Hier musst du später die 0000 mit dem Code auf deinem Fernseher ersetzen.
        sendTo("philips-tv.0", "submitPin", "0000"
        Nun starte das erste Script mit deiner IP und deaktiviere es nach 3 Sekunden. Hier sollte nun der Code in deinem Fernseher erscheinen (hoffentlich)
        Dann die 0000 mit den Code ersetzen und dieses Script starten und den Adapter NICHT neu starten.
        Was kannst du im Log sehen?
        Gruß//Lucky
        PrinzVonBillAir
        schrieb am zuletzt editiert von PrinzVonBillAir
        #523
        @lucky_esa Zur Info, mein Problem aus Post https://forum.iobroker.net/post/1169762 mit dem Pairen mittels des Buttons im Adapter selbst besteht weiterhin, allerdings konnte ich den TV durch die 2 Javaskripte von dir pairen. Eventuell kannst du dies ja irgendwie in den Adapter integrieren. Übrigens mein TV hat Andoid 12, einige hier schreiben ja von Android 11, eventuell ist das 12er OS das Problem? Allerdings hat die Paarung vor ~ 3/4 Jahr ohne Probleme mit dem Button im Adapter funktioniert.IMG_0760.jpg
        paradoxe SituationP L 2 Antworten Letzte Antwort
        • P PrinzVonBillAir
          paradoxe SituationP Offline
          paradoxe Situation
          #524
          @prinzvonbillair Moinsen. Wie und wo füge ich die Skripte ein um meine Fernseher wieder zu pairen. Habe auch eine 65Oled935/12 und seit Ner Woche geht nichts mehr. Ich wäre euch sehr dankbar!
          • L Lucky_ESA
            iob stop
            iob fix
            iob start
            Gruß//Lucky
            paradoxe Situation
            schrieb am zuletzt editiert von paradoxe Situation
            #525
            @lucky_esa sagte in Test Adapter Philips-TV v0.2.x:
            iob stop
            iob fix
            iob start
            Gruß//Lucky
            Moinsen, ich bekomme den Adapter nicht mehr installiert. :-( was mache ich falsch? gibt es tipps und tricks?
            $ iobroker url AlCalzone/ioBroker.philips-tv --host raspberrypi --debug
            install AlCalzone/ioBroker.philips-tv
            NPM version: 9.5.1
            Installing AlCalzone/ioBroker.philips-tv... (System call)
            changed 1 package in 47s184 packages are looking for funding run `npm fund` for details
            upload [1] philips-tv.admin /opt/iobroker/node_modules/iobroker.philips-tv/admin/jsonConfig.json jsonConfig.json application/json
            upload [0] philips-tv.admin /opt/iobroker/node_modules/iobroker.philips-tv/admin/philips-tv.png philips-tv.png image/png
            Process exited with code 0
            • paradoxe SituationP paradoxe Situation
              iob stop
              iob fix
              iob start
              Gruß//Lucky
              NPM version: 9.5.1
              #526
              @paradoxe-situation sagte in Test Adapter Philips-TV v0.2.x:
              klingt doch erst mal gut!
              was sagt die Langfassung von iob diag ?
                iob stop
                iob fix
                iob start
                Gruß//Lucky
                NPM version: 9.5.1
                #527
                NPM version: 9.5.1
                Weist auf eine alte und/oder falsche Installation von nodejs hin. Bring das erstmal auf Stand:
                iob stop
                iob fix
                iob nodejs-update
                • P PrinzVonBillAir
                  Lucky_ESA
                  #528
                  @prinzvonbillair sagte in Test Adapter Philips-TV v0.2.x:
                  @lucky_esa Zur Info, mein Problem aus Post https://forum.iobroker.net/post/1169762 mit dem Pairen mittels des Buttons im Adapter selbst besteht weiterhin, allerdings konnte ich den TV durch die 2 Javaskripte von dir pairen. Eventuell kannst du dies ja irgendwie in den Adapter integrieren. Übrigens mein TV hat Andoid 12, einige hier schreiben ja von Android 11, eventuell ist das 12er OS das Problem? Allerdings hat die Paarung vor ~ 3/4 Jahr ohne Probleme mit dem Button im Adapter funktioniert.!
                  Die 2 Scripte machen das was eigentlich der Adapter machen sollte. In meinen Augen ist das ein issues in der jsonConfig.json. Hier muss der Entwickler wahrscheinlich mal die Datei anpassen.
                  Des Weiteren nutzt dieser Adapter das Package "request" was nicht mehr angewendet werden sollte.
                  Gruß//Lucky
                  • foxriver76F Offline
                    foxriver76F Offline
                    foxriver76
                    #529
                    Das Pairing Problem sollte mit 0.5.4 gefixt sein, anscheinend hat sich was im Verhalten von JSON Config verändert.
                    Videotutorials & mehr
                    FenriswolfF 1 Antwort Letzte Antwort
                    • foxriver76F foxriver76
                      FenriswolfF Offline
                      FenriswolfF Offline
                      Fenriswolf
                      #530
                      @foxriver76 sagte in Test Adapter Philips-TV v0.2.x:
                      Moin,
                      das mit dem Pairing hat mit der 0.5.4 tatsächlich funktioniert, aber dafür bekomme ich im Log jetzt immer folgende Meldung:
                      2024-08-14 20:57:51.828 - info: philips-tv.0 (86167) starting. Version 0.5.4 (non-npm: AlCalzone/ioBroker.philips-tv) in /opt/iobroker/node_modules/iobroker.philips-tv, node: v20.16.0, js-controller: 6.0.9
                      2024-08-14 20:57:51.839 - info: philips-tv.0 (86167) Starting with ip "x.x.x.x" (API v6 - Android)
                      2024-08-14 20:58:05.558 - error: philips-tv.0 (86167) Could not poll API: Unexpected end of JSON input
                      2024-08-14 20:58:11.108 - error: philips-tv.0 (86167) Could not poll API: Unexpected end of JSON input
                      2024-08-14 20:58:16.743 - error: philips-tv.0 (86167) Could not poll API: Unexpected end of JSON input
                      gruß
                      Marc
                      Press any key to continue or any other to quit
                      Domi920D 1 Antwort Letzte Antwort
                      • FenriswolfF Fenriswolf
                        Moin,
                        gruß
                        Marc
                        Domi920D Offline
                        Domi920D Offline
                        Domi920
                        schrieb am zuletzt editiert von Domi920
                        #531
                        Habe genau das gleiche Problem mit meinem 75PUS8108/12 TV.
                        Gibt es schon eine Lösung?
                        Obwohl der Adapter nicht grün ist funktionieren dennoch einige Buttons und manche Datenpunkte werden aktualisiert und das trotz andauernder Fehlermeldung im Log:
                        @fenriswolf sagte in Test Adapter Philips-TV v0.2.x:
                        Moin,
                        gruß
                        Marc
                        L 1 Antwort Letzte Antwort
                        • Domi920D Domi920
                          Moin,
                          gruß
                          Marc
                          Lucky_ESA
                          #532
                          @domi920 sagte in Test Adapter Philips-TV v0.2.x:
                          75PUS8108/12
                          Stop mal den Adapter und restarte den Fernseher unter Einstellung/system. Danach mal den Adapter starten...Kommt dann noch immer diese Fehler?
                          • L Lucky_ESA
                            75PUS8108/12
                            Domi920D Offline
                            Domi920D Offline
                            Domi920
                            #533
                            @lucky_esa Leider gibt es keine Möglichkeit den TV über die Einstellungen neu zu starten:
                            Habe den TV dafür ausgesteckt und 1 Minute gewartet und wieder neu gestartet.
                            Leider kommt die Fehlermeldung wieder.
                            Also erst ist der Adapter grün und nach wenigen Sekunden wieder orange und die Fehlermeldung kommt.
                            L M 2 Antworten Letzte Antwort
                            • Domi920D Domi920
                              Lucky_ESA
                              #534
                              @domi920 Wenn du den Adapter auf debug stellst, sind dann Logeinträge vorhanden?
                              • L Lucky_ESA
                                Domi920D Offline
                                Domi920D Offline
                                Domi920
                                #535
                                @lucky_esa Hier ein Auszug:
                                27
                                12
                                Log-Größe: 1.6 MB
                                philips-tv.0
                                Zeit
                                debug
                                Nachricht
                                philips-tv.0
                                2024-08-25 14:38:28.883	error	Could not poll API: Unexpected end of JSON input
                                philips-tv.0
                                2024-08-25 14:38:23.586	error	Could not poll API: Unexpected end of JSON input
                                philips-tv.0
                                2024-08-25 14:38:18.335	error	Could not poll API: Unexpected end of JSON input
                                philips-tv.0
                                2024-08-25 14:38:13.259	debug	Sending key "VolumeDown"
                                philips-tv.0
                                2024-08-25 14:38:13.259	debug	state change philips-tv.0.keys.volumeDown: false
                                philips-tv.0
                                2024-08-25 14:38:13.102	error	Could not poll API: Unexpected end of JSON input
                                philips-tv.0
                                2024-08-25 14:38:07.852	error	Could not poll API: Unexpected end of JSON input
                                philips-tv.0
                                2024-08-25 14:38:02.613	error	Could not poll API: Unexpected end of JSON input
                                philips-tv.0
                                2024-08-25 14:37:57.282	error	Could not poll API: Unexpected end of JSON input
                                philips-tv.0
                                2024-08-25 14:37:51.992	error	Could not poll API: Unexpected end of JSON input
                                philips-tv.0
                                2024-08-25 14:37:46.696	error	Could not poll API: Unexpected end of JSON input
                                philips-tv.0
                                2024-08-25 14:37:44.350	debug	Sending key "VolumeUp"
                                philips-tv.0
                                2024-08-25 14:37:44.350	debug	state change philips-tv.0.keys.volumeUp: true
                                philips-tv.0
                                2024-08-25 14:37:41.453	error	Could not poll API: Unexpected end of JSON input
                                philips-tv.0
                                2024-08-25 14:37:39.302	debug	Sending key "VolumeUp"
                                philips-tv.0
                                2024-08-25 14:37:39.301	debug	state change philips-tv.0.keys.volumeUp: true
                                philips-tv.0
                                2024-08-25 14:37:36.251	error	Could not poll API: Unexpected end of JSON input
                                philips-tv.0
                                2024-08-25 14:37:30.998	error	Could not poll API: Unexpected end of JSON input
                                philips-tv.0
                                2024-08-25 14:37:25.738	error	Could not poll API: Unexpected end of JSON input
                                philips-tv.0
                                2024-08-25 14:37:20.448	error	Could not poll API: Unexpected end of JSON input
                                philips-tv.0
                                2024-08-25 14:37:14.913	debug	No Ambilight plus Hue support: {"statusCode":404,"body":"<html><head><title>Not Found</title></head><body>Not Found</body></html>","headers":{"date":"Sun, 25 Aug 2024 12:37:14 GMT","connection":"close","content-type":"text/html; charset=utf-8","cache-control":"no-cache","access-control-allow-origin":"*","content-length":"72"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"192.162.1.101:1926","port":"1926","hostname":"192.162.1.101","hash":null,"search":null,"query":null,"pathname":"/6/HueLamp/power","path":"/6/HueLamp/power","href":"https://192.162.1.101:1926/6/HueLamp/power"},"method":"GET","headers":{}}}
                                philips-tv.0
                                2024-08-25 14:37:14.621	debug	No app launch support: {"statusCode":403,"body":"<html><head><title>Forbidden</title></head><body>Forbidden</body></html>","headers":{"date":"Sun, 25 Aug 2024 12:37:14 GMT","connection":"close","content-type":"text/html; charset=utf-8","cache-control":"no-cache","access-control-allow-origin":"*","content-length":"72"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"192.162.1.101:1926","port":"1926","hostname":"192.162.1.101","hash":null,"search":null,"query":null,"pathname":"/6/applications","path":"/6/applications","href":"https://192.162.1.101:1926/6/applications"},"method":"GET","headers":{}}}
                                philips-tv.0
                                2024-08-25 14:37:09.370	info	Starting with ip "192.162.1.101" (API v6 - Android)
                                philips-tv.0
                                2024-08-25 14:37:09.362	info	starting. Version 0.5.4 (non-npm: AlCalzone/ioBroker.philips-tv) in /opt/iobroker/node_modules/iobroker.philips-tv, node: v20.16.0, js-controller: 6.0.9
                                philips-tv.0
                                2024-08-25 14:37:09.173	debug	States connected to redis: 127.0.0.1:9000
                                philips-tv.0
                                2024-08-25 14:37:09.110	debug	States create User PubSub Client
                                philips-tv.0
                                2024-08-25 14:37:09.110	debug	States create System PubSub Client
                                philips-tv.0
                                2024-08-25 14:37:09.097	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                                philips-tv.0
                                2024-08-25 14:37:09.075	debug	Objects connected to redis: 127.0.0.1:9001
                                philips-tv.0
                                2024-08-25 14:37:09.071	debug	Objects client initialize lua scripts
                                philips-tv.0
                                2024-08-25 14:37:09.033	debug	Objects create User PubSub Client
                                philips-tv.0
                                2024-08-25 14:37:09.032	debug	Objects create System PubSub Client
                                philips-tv.0
                                2024-08-25 14:37:08.988	debug	Objects client ready ... initialize now
                                philips-tv.0
                                2024-08-25 14:37:08.965	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                                Die Lautstärkeregelung funktioniert 😄
                                • Domi920D Domi920
                                  27
                                  12
                                  Log-Größe: 1.6 MB
                                  philips-tv.0
                                  Zeit
                                  debug
                                  Nachricht
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  philips-tv.0
                                  Lucky_ESA
                                  #536
                                  6/6/applications
                                  Poste mal den Inhalt von https://192.168.1.101:1926/6/system
                                  Entferne aber bitte die Seriennummer.
                                  • L Lucky_ESA
                                    6/6/applications
                                    Domi920D Offline
                                    Domi920D Offline
                                    Domi920
                                    #537
                                    @Lucky_ESA
                                    Hier bitte:
                                    	"menulanguage": "German",
                                    	"name": "75PUS8108/12",
                                    	"country": "Germany",
                                    	"serialnumber_encrypted": "ENTFERNT",
                                    	"softwareversion_encrypted": "K2kseVsmQFgkd15gKkJ+atJJI6kYBl5fIhF2Isg2DFHegH9Cg/LU4b6H/tjCh/AJ",
                                    	"model_encrypted": "K2kseVsmQFgkd15gKkJ+ahs1fLaY49yyZSxQD2RFgy0=",
                                    	"deviceid_encrypted": "K2kseVsmQFgkd15gKkJ+arzW4E7OQEjAjzaJpAc3qtQ=",
                                    	"nettvversion": "",
                                    	"epgsource": "no_epg",
                                    	"api_version": {
                                    		"Major": 6,
                                    		"Minor": 1,
                                    		"Patch": 0
                                    	"featuring": {
                                    		"jsonfeatures": {
                                    			"recordings": [
                                    				"List",
                                    				"Schedule",
                                    				"Manage"
                                    			"ambilight": [
                                    				"Ambilight"
                                    			"textentry": [
                                    				"context_based",
                                    				"initial_string_available"
                                    			"inputkey": [
                                    				"key",
                                    				"unicode"
                                    			"pointer": [
                                    				"context_based"
                                    			"activities": [
                                    				"browser"
                                    			"alexa": [
                                    				"ssl_available"
                                    		"systemfeatures": {
                                    			"tvtype": "consumer",
                                    			"content": [
                                    				"dmr"
                                    			"pairing_type": "digest_auth_pairing",
                                    			"secured_transport": true,
                                    			"os_type": "Linux"
                                    • Domi920D Domi920
                                      Michaelnorge
                                      #538
                                      @domi920 said in Test Adapter Philips-TV v0.2.x:
                                      Android-Gerät?
                                      In den Einstellungen "Häufige Einstellungen" - "Alle Einstellungen" - "Android-Einstellungen" - "Geräteeinstellungen" - ganz nach unten scrollen :-)
                                      • Smart mit: Rasp 4B / ioBroker / Conbee2 / Trådfri / Xiaomi / HUE / Logitech Harmony / Aqara / Easee Wallbox / Hyundai Ioniq / Alexa / Google Home / Fully Kiosk / VIS
                                      • M Michaelnorge
                                        Android-Gerät?
                                        Domi920D Offline
                                        Domi920D Offline
                                        Domi920
                                        #539
                                        @michaelnorge sagte in Test Adapter Philips-TV v0.2.x:
                                        Android-Gerät?
                                        Nein es ist kein Android System
                                        • Domi920D Domi920
                                          Android-Gerät?
                                          Lucky_ESA
                                          #540
                                          @domi920
                                          Kenne jetzt nicht alle Einstellungen vom Adapter aber musst du dann nicht jointspace statt android auswählen?
                                          Gruß//Lucky
