  4. Tester Zigbee Adapter 3.x gesucht
    6.0k
zigbeezigbee adapter
259 Beiträge 27 Kommentatoren 64.0k Aufrufe 38 Beobachtet
  • M MeisterQ 0
    Jetzt haben fast garkeine Geräte mehr Bilder 😅
    Nach einem Neustart waren die Bilder wieder da.
    179
    Log-Größe: 2.3 MB
    Zeit
    zigbee.0
    	2025-07-18 11:46:25.360	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    zigbee.0
    	2025-07-18 11:46:24.583	info	Closing Zigbee network, 117 seconds remaining
    zigbee.0
    	2025-07-18 11:46:24.359	info	Saved local configuration data
    zigbee.0
    	2025-07-18 11:46:24.359	info	cleaning everything up...
    zigbee.0
    	2025-07-18 11:46:24.358	info	Halting zigbee adapter. Restart delay is at least 30 seconds.
    zigbee.0
    	2025-07-18 11:46:24.356	error	Cannot read properties of undefined (reading 'hasOwnProperty')
    zigbee.0
    	2025-07-18 11:46:24.355	error	TypeError: Cannot read properties of undefined (reading 'hasOwnProperty') at StatesController.AddModelFromHerdsman (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:96:31) at processTicksAndRejections (node:internal/process/task_queues:95:5)
    zigbee.0
    	2025-07-18 11:46:24.355	error	unhandled promise rejection: Cannot read properties of undefined (reading 'hasOwnProperty')
    zigbee.0
    	2025-07-18 11:46:24.355	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    	2025-07-18 11:46:24.350	error	Cannot read properties of undefined (reading 'hasOwnProperty')
    zigbee.0
    	2025-07-18 11:46:24.350	error	TypeError: Cannot read properties of undefined (reading 'hasOwnProperty') at StatesController.AddModelFromHerdsman (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:96:31) at processTicksAndRejections (node:internal/process/task_queues:95:5)
    zigbee.0
    	2025-07-18 11:46:24.350	error	unhandled promise rejection: Cannot read properties of undefined (reading 'hasOwnProperty')
    zigbee.0
    	2025-07-18 11:46:24.350	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    	2025-07-18 11:46:24.349	warn	New device: '0x744dbdfffe61ce69' does not have a known model. please provide an external converter for 'ZigbeeRangeExtender'.
    zigbee.0
    	2025-07-18 11:46:24.348	info	Successfully interviewed '0x744dbdfffe61ce69', device has successfully been paired
    zigbee.0
    	2025-07-18 11:46:23.853	warn	Device 0x744dbdfffe61ce69 "ZigbeeRangeExtender" not found.
    zigbee.0
    	2025-07-18 11:46:23.698	info	Device '0x744dbdfffe61ce69' announced itself
    zigbee.0
    	2025-07-18 11:46:23.636	info	Starting interview of '0x744dbdfffe61ce69'
    zigbee.0
    	2025-07-18 11:46:20.979	info	Opening zigbee Network for 120 seconds
    Leider trotzdem das selbe Spiel
    arteckA Offline
    arteckA Offline
    arteck
    #221
    @meisterq-0 poste mal die shepherd.db.. ich muss mir die Struktur mal laden.
    • haselchenH haselchen
      @asgothian sagte in Tester Zigbee Adapter 3.x gesucht:
      @haselchen sagte in Tester Zigbee Adapter 3.x gesucht:
      @asgothian
      Okay. Die Meldung suggeriert aber , dass etwas nicht geklappt hat. Not Supported ist von der Aussage her ja negativ behaftet.
      Weil , in der Map dann selber alles korrekt angezeigt wird.
      Alle Striche grün und alle Geräte verbunden.
      Da würde ich als User durch die Nachricht einfach nur (unnötig) verunsichert werden.
      Das siehst du falsch. In der Map wird es gerade nicht korrekt dargestellt. Es fehlen die meisten Linien die von den Plug_01 ausgehen - in den meisten fällen scheinen diese nicht einmal mit dem Koordinator verbunden zu sein, wenn du die 'nachbarn' ausblendest.
      Es geht also nicht darum das Linien nicht grün sind. Es geht darum das Linien vollständig fehlen !
      A.
      Nachtrag: Es wird möglicherweise eine Option geben diese Meldung zu unterdrücken, bzw. die Meldung automatisch auszublenden. Das ist aber noch nicht konkret, und wenn es kommt wird es etwas sein was der Nutzer aktiv wird einschalten müssen.
      Ich weiss, dass ihr die Dinger nicht mögt.
      Scheine ich der Einzige zu sein, der damit keine Probleme hat ;)
      In technischer Hinsicht, muss ich Dir vermutlich, mangels Wissen, Recht geben.
      In visueller Hinsicht sieht das aber so aus:
      Alles mit jedem verbunden , ebenso mit dem Coordinator.
      Dementsprechend, würde ich aus meiner Sicht, Deiner Darstellung widersprechen.
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      #222
      Jein. Die Plug 01 werden als Nachbarn von anderen Geräten mit grünen Linien verbunden, aber:
      Den Plug-01 fehlt die blaue Linie. Blende mal in der ansicht der Karte die Nachbarn aus, dann siehst du nur welche 'aktiven' routen exisiteren. Dabei wird auffallen das die Plug 01 eben gerade keine Verbindung gemeldet haben.
      A.
      • AsgothianA Asgothian
        A.
        haselchenH Offline
        haselchenH Offline
        haselchen
        #223
        @asgothian
        Huhu...ich hab zum Test nochmal 2 BWM bei wieder einem anderen Anbieter bestellt.
        Es scheint, dass es überwiegend nur noch die HOBEIAN Geräte gibt.
        Auf der Packung steht auch New Zigbee PIR LUX.
        Er wird zwar als ZG-204ZL erkannt, aber auf der Packung stehen , vermutlich, Updatebezeichnungen des Gerätes.
        ZG-204ZS /ZG-204ZM
        Und da ist vermutlich der Knackpunkt.
        Beim Anlernen (ich habe zum Testen ein Downgrade des Adapters gemacht) wird alles fein säuberlich erkannt und mit ok abgeschlossen.
        Danach ist aber nichts okay. Das Gerät ist zwar in der Kachel und zeigt Verbindung. Aber es wird nichts aktualisiert. Es ist quasi eingefroren.
        Jetzt die Frage, ist es möglich , ohne von Github die Version laden, dieses Gerät einzupflegen?
        Zigbee2Mqttt hat es ja.
        zigbee.0 2025-07-22 11:23:14.095	info	Successfully interviewed '0xa4c13871cd6e84b7', device has successfully been paired
        zigbee.0 2025-07-22 11:23:03.071	info	Device '0xa4c13871cd6e84b7' announced itself
        zigbee.0 2025-07-22 11:23:02.709	info	Starting interview of '0xa4c13871cd6e84b7'
        zigbee.0 2025-07-22 11:22:48.451	info	Zigbee: allowing new devices to join.
        Kein "WLAN" Zeichen vorm Gerät
        AsgothianA S 2 Antworten Letzte Antwort
          @asgothian
          ZG-204ZS /ZG-204ZM
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          #224
          @haselchen ja das geht. Du musst den passenden converter bei z2m identifizieren, den Code in einen externen konverter speichern und diesen in der Konfiguration eintragen.
          Dann bei Adapter Start das log prüfen das er geladen wird und dann ist alles grün.
          Aktuell würde ich einfach die 3.0.3 von GitHub installieren - die soll mittelfristig ( eine Woche oder so ) ins latest.
          A.
            A.
            haselchenH Offline
            haselchenH Offline
            haselchen
            #225
            A.
            Kann ich mir mit der 3.0.3 dann Deine obige Vorgehensweise sparen? :)
              A.
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              #226
              @haselchen Das kann ich dir nicht sagen. Das kannst du aber selber heraus finden:
              • schau auf der Info-Kachel vom Adapter nach der genauen Herstellerbezeichnung / benennung des Gerätes
              • Such im Changelog der ZHC nach dieser Bezeichnung - dann weisst du welche ZHC Version benötigt wird.
              • die 3.0.3 nutzt ZHC 23.72.1
              A.
                A.
                haselchenH Offline
                haselchenH Offline
                haselchen
                #227
                @asgothian
                Oha, ganz schön viel zum Durchgucken :)
                Das Changelog ist bei 24.5.0.
                Ich hab ja keine Ahnung, wie Du das so aufbereitest, bleibst Du Versionstechnisch immer ein wenig zurück zum Testen?
                Ich hab nur hier was gefunden zu dem Gerät. Version 23.51.0
                https://github.com/Koenkk/zigbee-herdsman-converters/pull/9394
                  @locito09 sagte in Tester Zigbee Adapter 3.x gesucht:
                  @dimaiv
                  Muss ich ab github installieren damit der Adapter diese Version zieht oder wie ist das?
                  Der folgende weg führt zum Erfolg:
                  • GitHub Account anlegen
                  • iobroker.zigbee adapter Forken
                  • Package.json Zeile 32 anpassen, von "zigbee-herdsman-converters": "23.35.0" zu "zigbee-herdsman-converters": "23.57.0” ändern
                  • von deinem GitHub installieren
                  • testen ob alles wie gewohnt geht. Wenn ja - PR von deinem GitHub zum iobroker repositiory machen.
                  A.
                  P.s. das Testen ist das wichtige. Da ich das aktuell nicht leisten kann werd ich das hochziehen der ZHC nicht mal eben so machen.
                  GaspodeG Offline
                  GaspodeG Offline
                  Gaspode
                  schrieb am zuletzt editiert von Gaspode
                  #228
                  @haselchen said in Tester Zigbee Adapter 3.x gesucht:
                  @asgothian said in Tester Zigbee Adapter 3.x gesucht:
                  Und zum Testen der neuesten ZHC Version:
                  https://forum.iobroker.net/post/1280579
                  Aber hattest du das nicht schon mal vor ein paar Tagen schon so genutzt?
                  • GaspodeG Gaspode
                    haselchenH Offline
                    haselchenH Offline
                    haselchen
                    #229
                    @Asgothian
                    Du bist mit Geld nicht zu bezahlen 😬
                    Funktioniert auf Anhieb mit der 3.0.3 von Github.
                    Klasse.
                    Dann warte ich auf Stable, dann kanns auch ins Produktivsystem.
                    @Gaspode
                    Ich meine, ich hatte letztens ne URL zum Installieren.
                    Da war der BWM dann drin, aber drumherum gabs Probleme.
                    Ich hab 4 von den Dingern und mich schon grün und blau geärgert, dass sie nicht funktionieren.
                      @Asgothian
                      Klasse.
                      @Gaspode
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      #230
                      @Asgothian
                      Ja, die Version gab es, nachdem die hinreichend oft installiert wurde und die ‘probleme’ die du angesprochen hast Gefixed wurden hab ich die 3.0.3 gebaut. Die nutzt dann die fast aktuellen ZHC
                      A.
                        @Asgothian
                        A.
                        haselchenH Offline
                        haselchenH Offline
                        haselchen
                        #231
                        @asgothian
                        Ist der Adapter schon kompatibel mit NodeJS 22.17.1 ?
                        Ich bekomme aktuelle Update Container nur noch mit dieser Version angeboten.
                          @asgothian
                          #232
                          @haselchen
                          Ja. nodejs@22 dürfte in den nächsten Tagen auch zur offiziellen Empfehlung für den ioBroker werden.
                          Gibt entsprechende PRs dafür. Und der Container muss natürlich auch darauf aufbauen. Ist nur etwas 'vorgeprescht' mit dem Release.
                            @haselchen
                            haselchenH Offline
                            haselchenH Offline
                            haselchen
                            #233
                            Puh. Dann ist ja gut.
                            Durch Zufall die neue Version gesehen.
                            Meistens sinds so kleine "Schönheits"Updates.
                            Hier kam ich ein wenig ins Schwitzen....
                              #234
                              Wegen eines schnöden Updates von nodejs? Warum wird da eigentlich immer so ein Gewese drum gemacht?
                              nodejs@22 ist vor mehr als einem Jahr released worden, da sind also schon diverse Tests gegen gelaufen.
                              Die gängigsten und gepflegten Adapter laufen alle damit. Bei verwaisten Adaptern kann das zugegeben anders aussehen, aber die können auch aus anderen Gründen den Betrieb einstellen.
                              • ste_gleiS ste_glei
                                @mickemup Versuch mal bitte die andere Variante - mit dem Cluster und Attribute via read im send_payload. Es ist denkbar das die SendToZigbee Funktion buggy ist in der 2.x/3.x.
                                A.
                                mit diesem Payload funktioniert es
                                { "read": { "cluster": "genPowerCfg", "attributes": ["batteryPercentageRemaining"] }}
                                Danke für die rege Diskussion und die ganzen Tipps da lerne ich jeden Tag dazu
                                mickemupM Online
                                mickemupM Online
                                mickemup
                                #235
                                @Asgothian
                                Mit dem gleichen Payload wollte ich nun die "Batterie" auch bei den IKEA Styrbar aktualisieren.
                                Es kommt auch eine "Antwort":
                                Batterie Level bleibt aber im Gegensatz zu den Parasolls auf:
                                Irgendwer eine Idee?
                                @ste_glei sagte in Tester Zigbee Adapter 3.x gesucht:
                                A.
                                AsgothianA A 2 Antworten Letzte Antwort
                                • mickemupM mickemup
                                  @Asgothian
                                  A.
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  #236
                                  @mickemup sagte in Tester Zigbee Adapter 3.x gesucht:
                                  Setz das Gerät mal auf Debug (bug icon auf der Kachelrückseite) und schau dir an wie die Antwort verarbeitet wird (und ob sie verarbeitet wird) - geht via debug tab im Adapter oder via ELEVATED log Meldungen
                                  A.
                                  mickemupM 1 Antwort Letzte Antwort
                                    A.
                                    mickemupM Online
                                    mickemupM Online
                                    mickemup
                                    #237
                                    @asgothian
                                    Bei einem Parasoll mit 82% Bat Anzeige kommt folgende Response:
                                    Scheint irgendwie Faktor zwei darin zu stecken....
                                    Beim Styrbar im DEBUG dies:
                                    Kann es sein, dass 255 dafür steht, dass kein Wert vorhanden ist?
                                      @asgothian
                                      AsgothianA Offline
                                      AsgothianA Offline
                                      Asgothian
                                      #238
                                      @asgothian
                                      Diese Briefmarken kann ich nicht entziffern. Bitte die Log-Einträge aus dem ioBroker log als Text posten.
                                      Der vergleich zwischen Styrbar und Parasoll bringt wenig - sie nutzen nicht unbedingt den gleichen Konverter
                                      A.
                                      A.
                                        @Asgothian
                                        A.
                                        AlexHaxe
                                        #239
                                        @mickemup
                                        kann es sein, dass Du Dein Styrbar mal gescheit rekonfigurieren musst, damit es korrekt läuft? Weil meines zeigt einen Batteriestand an, der regelmäßig aktualisiert wird, und laut Historie über die Zeit konstant um jeweils 5% sinkt.
                                        Ein "(null) %" kenne ich nur von Geräten die nicht korrekt konfiguriert sind (es kann sein, dass ein Gerät ein bisschen braucht bis es nach dem (Re-)Konfigurieren Werte für alle Datenfelder zeigt. Das mag dann ein wenig vom Update-Intervall des jeweiligen Gerätetyps und dessen Firmware abhängen) .
                                        Auch reagiert das Gerät auf einen Request mit dem aktuellen Batteriestand (anscheinend immer gedoppelt, ich schätze man wollte "x,5" Werte ermöglichen):
                                        request:
                                            "devId": "zigbee.1.abcdefghijkl",
                                            "ep": "1",
                                            "cid": "genPowerCfg",
                                            "cmd": "read",
                                            "cmdType": "foundation",
                                            "zclData": {
                                                "batteryPercentageRemaining": 0
                                            "cfg": null
                                        response:
                                        SUCCESS {"batteryPercentageRemaining":140}
                                          @asgothian
                                          A.
                                          A.
                                          mickemupM Online
                                          mickemupM Online
                                          mickemup
                                          #240
                                          @asgothian
                                          Sry hier die Response von Styrbar
                                          {"type":"readResponse","data":{"batteryPercentageRemaining":255},"linkquality":232,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":186,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                                          Das hier war beim Parasoll:
                                          {"type":"readResponse","data":{"batteryPercentageRemaining":164},"linkquality":232,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":48,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
