Betatest NSPanel-lovelace-ui v0.7.x
Tasmotakonsole nach Anschalten Panel:
00:00:00.003 HDW: ESP32-D0WD-V3 v3.1 (PSRAM) 00:00:00.039 UFS: FlashFS mounted with 308 kB free 00:00:00.054 CFG: Loaded from File, Count 32 00:00:00.062 QPC: Count 1 00:00:00.122 BRY: Berry initialized, RAM used 3766 bytes 00:00:00.143 Project tasmota - Tasmota Version 15.2.0.2(5680069-nspanel)-3.3.5(2026-01-07T13:56:55) 00:00:01.149 WIF: Connecting to AP1 Sorocaba Channel 1 BSSId F0:9F:C2:F7:9B:60 in mode HT20 as NSPanelOG... 00:00:03.840 WIF: Connected 00:00:04.986 HTP: Web server active on NSPanelOG with IP address 192.168.1.164 00:00:08.132 QPC: Reset 00:00:09.178 MQT: Attempting connection... 00:00:10.348 MQT: TLS connected in 1168 ms, stack low mark 2280 00:00:10.349 MQT: Connected 00:00:10.355 MQT: NSPanel/OG/tele/LWT = Online (retained) 00:00:10.359 MQT: NSPanel/OG/cmnd/POWER = 00:00:10.367 MQT: NSPanel/OG/tele/INFO1 = {"Info1":{"Module":"NSPanelOG","Version":"15.2.0.2(5680069-nspanel)","FallbackTopic":"cmnd/NSPanelOG-1D3968_fb/","GroupTopic":"NSPanel/OG/cmnd/"}} 00:00:10.385 MQT: NSPanel/OG/tele/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"NSPanelOG","IPAddress":"192.168.1.164","IP6Global":"fd5a:8fd2:ee86:44c:e665:b8ff:fe1d:3968","IP6Local":"fe80::e665:b8ff:fe1d:3968%st2"}} 00:00:10.410 MQT: NSPanel/OG/tele/INFO3 = {"Info3":{"RestartReason":"Vbat power on reset","BootCount":10}} 00:00:10.416 MQT: NSPanel/OG/stat/RESULT = {"POWER1":"OFF"} 00:00:10.419 MQT: NSPanel/OG/stat/POWER1 = OFF 00:00:10.422 MQT: NSPanel/OG/stat/RESULT = {"POWER2":"OFF"} 00:00:10.435 MQT: NSPanel/OG/stat/POWER2 = OFF 00:00:12.665 MQT: NSPanel/OG/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND pageType~pageStartup"} 00:00:15.376 MQT: NSPanel/OG/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND pageType~pageStartup"} 00:00:16.426 MQT: NSPanel/OG/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND pageType~pageStartup"} 00:00:16.461 MQT: NSPanel/OG/tele/STATE = {"Time":"1970-01-01T00:00:16","Uptime":"0T00:00:13","UptimeSec":13,"Heap":121,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":1104,"MqttCount":1,"Berry":{"HeapUsed":4,"Objects":46},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"Sorocaba","BSSId":"F0:9F:C2:F7:9B:60","Channel":1,"Mode":"HT20","RSSI":100,"Signal":-50,"LinkCount":1,"Downtime":"0T00:00:03"},"Hostname":"NSPanelOG","IPAddress":"192.168.1.164"} 00:00:16.511 MQT: NSPanel/OG/tele/SENSOR = {"Time":"1970-01-01T00:00:16","ANALOG":{"Temperature1":-6.3},"TempUnit":"C"} 00:00:17.555 MQT: NSPanel/OG/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND pageType~pageStartup"} 00:00:19.827 MQT: NSPanel/OG/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND pageType~pageStartup"} 00:00:27.546 MQT: NSPanel/OG/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND pageType~pageStartup"} 00:00:29.684 MQT: NSPanel/OG/stat/STATUS0 = {"Status":{"Module":0,"DeviceName":"Tasmota","FriendlyName":["NSPanelOG","Tasmota2"],"Topic":"tasmota_1D3968","ButtonTopic":"0","Power":"00","PowerLock":"00","PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0,"StatusRetain":0},"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://ota.tasmota.com/tasmota32/release/tasmota32-nspanel.bin","RestartReason":"Vbat power on reset","Uptime":"0T00:00:24","StartupUTC":"","Sleep":50,"CfgHolder":4617,"BootCount":10,"BCResetTime":"1970-01-01T00:00:00","SaveCount":33},"StatusFWR":{"Version":"15.2.0.2(5680069-nspanel)","BuildDateTime":"2026-01-07T13:56:55","Core":"3.3.5","SDK":"5.3.4.251223","CpuFrequency":160,"Hardware":"ESP32-D0WD-V3 v3.1","CR":"517/699"},"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"FileLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["Sorocaba",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","2805C80001000600003C5A0A192800000000","00000080","20206000","00044000","00000000"]},"StatusMEM":{"ProgramSize":2068,"Free":811,"Heap":118,"StackLowMark":2,"PsrMax":2048,"PsrFree":2037,"ProgramFlashSize":4096,"FlashSize":4096,"FlashChipId":"1640C8","FlashFrequency":40,"FlashMode":"DIO","Features":["0809","9F9AD7DF","0015A001","B7F7BFCF","05DA9BC4","E0360DC7","480840D2","20200000","D4BC482D","810A80F1","00000814"],"Drivers":"1,2,!3,!4,!5,7,!8,9,10,11,12,!14,!16,!17,!20,!21,24,26,!27,29,!34,!35,38,50,52,!59,!60,62,!63,!66,!67,!68,!73,!75,82,!86,!87,!88,!91,!121","Sensors":"1,2,3,5,6,7,8,9,10,11,12,13,14,15,17,18,19,20,21,22,26,31,34,37,39,40,42,43,45,51,52,55,56,58,59,64,66,67,74,85,92,95,98,103,105,109,127","I2CDriver":"7,8,9,10,11,12,13,14,15,17,18,20,24,29,31,36,41,42,44,46,48,58,62,65,69,76,77,82,89"},"StatusNET":{"Hostname":"NSPanelOG","IPAddress":"192.168.1.164","Gateway":"192.168.1.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.1.1","DNSServer2":"8.8.8.8","Mac":"E4:65:B8:1D:39:68","IP6Global":"fd5a:8fd2:ee86:44c:e665:b8ff:fe1d:3968","IP6Local":"fe80::e665:b8ff:fe1d:3968%st2","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"192.168.1.1","DNSServer2":"8.8.8.8","Mac":"00:00:00:00:00:00","IP6Global":"","IP6Local":""},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":16.0},"StatusMQT":{"MqttHost":"192.168.1.19","MqttPort":8883,"MqttClientMask":"NSPanelOG-1D3968","MqttClient":"NSPanelOG-1D3968","MqttUser":"ceASHxzZGaPOqiX","MqttCount":1,"MqttTLS":1,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4},"StatusTIM":{"UTC":"1970-01-01T00:00:29Z","Local":"1970-01-01T00:00:29","StartDST":"1970-01-01T00:00:00","EndDST":"1970-01-01T00:00:00","Timezone":"+00:00","Sunrise":"20:13","Sunset":"05:47"},"StatusSNS":{"Time":"1970-01-01T00:00:29","ANALOG":{"Temperature1":-6.3},"TempUnit":"C"},"StatusSTS":{"Time":"1970-01-01T00:00:29","Uptime":"0T00:00:24","UptimeSec":24,"Heap":117,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":1602,"MqttCount":1,"Berry":{"HeapUsed":4,"Objects":46},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"Sorocaba","BSSId":"F0:9F:C2:F7:9B:60","Channel":1,"Mode":"HT20","RSSI":100,"Signal":-50,"LinkCount":1,"Downtime":"0T00:00:03"},"Hostname":"NSPanelOG","IPAddress":"192.168.1.164"}} 00:00:35.673 MQT: NSPanel/OG/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND pageType~pageStartup"} 00:00:46.605 MQT: NSPanel/OG/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND pageType~pageStartup"} 00:00:59.619 MQT: NSPanel/OG/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND pageType~pageStartup"}Adapter-log:
nspanel-lovelace-ui.0 2026-01-08 18:57:43.714 info [NSPanelOG] Setting panel to offline until first message! nspanel-lovelace-ui.0 2026-01-08 18:57:42.295 info [mqttServer] MQTT server started and listening on port 8883 nspanel-lovelace-ui.0 2026-01-08 18:57:42.121 info Detailed configuration checks are suppressed here. Full validation output is only shown when the configuration script is sent to the adapter. nspanel-lovelace-ui.0 2026-01-08 18:57:42.121 info Found 1 script configs for topics: NSPanel/OG nspanel-lovelace-ui.0 2026-01-08 18:57:42.120 info Configured panels: name#topic -> [NSPanelOG#NSPanel/OG] nspanel-lovelace-ui.0 2026-01-08 18:57:42.078 info starting. Version 0.9.1 in /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui, node: v22.21.0, js-controller: 7.0.7 nspanel-lovelace-ui.0 2026-01-08 18:57:37.043 info terminating nspanel-lovelace-ui.0 2026-01-08 18:57:36.786 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason nspanel-lovelace-ui.0 2026-01-08 18:57:36.786 info terminating nspanel-lovelace-ui.0 2026-01-08 18:57:36.781 info [mqttClient] MQTT connection closed. nspanel-lovelace-ui.0 2026-01-08 18:57:36.684 info [NSPanelOG] Goint offline because delete panel! nspanel-lovelace-ui.0 2026-01-08 18:57:36.539 info Got terminate signal TERMINATE_YOURSELF -
@ticaki @tt-tom Sorry! Eben habe ich mich an den Vorfall vor ca. 6 Monaten erinnert. Ich habe im unifi den NSpanels den Zugang zum Internet verweigert. Trotz des Flashs war das Gerät gesperrt. Nun hat es sofort funktioniert. Panel zeigt sofort die Uhrzeit an. Toller Adapter! Echt einfach die erste Einrichtung. Nun geht es ans Script :-)
@armilar Ist es möglich, die Hue Lichtszenen einzubinden, ähnlich wie beim Skript:
https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-ALIAS-Definitionen#hue-licht-channel-hueHabe im Wiki nichts dazu gefunden. Danke dir
Ich selber habe keine Lampensteuerung jedoch sollte lt. code.
modelist:wie im SkriptinSel_Alias:muß auf einem Datenpunkt zeigen der beschreibbar ist und vom TypstringDas hab ich aus dem Code, ist viel zulange her das ich das Programmiert habe und nutze es selbst nicht. Vielleicht kann @tt-tom das mal testen.
ich hätte hier 2 Beispiele:
{ id: 'alias.0.Haus.Obergeschoss.Schlafzimmer_2.Licht.Tradfri_GU10_3', name: 'RGB Hex (CT=Mired)', // RGBsingle Channel - IKEA Tradfri GU10 über zigbee.0 - Color-Temperature in Mired icon: 'lightbulb-on', icon2: 'lightbulb-outline', offColor: Off, minValueColorTemp: 500, // Mired = Warmweiß = 1.000.000 / 2000 K = 500 Mired maxValueColorTemp: 153, // Mired = Kaltweiß = 1.000.000 / 6536 K = 153 Mired interpolateColor: true, inSel_Alias: 'alias.0.Haus.Obergeschoss.Schlafzimmer_2.Licht.Tradfri_GU10_3.VALUE', inSel_ChoiceState: true }, { id: 'alias.0.Haus.Erdgeschoss.Wohnzimmer.Licht.E14_Fenster_Mitte_RGB', name: 'RGB (CT=Mired)', // RGB Channel - E14 Livarno Home Color über zigbee.0 - Color-Temperature in Mired icon: 'lightbulb-on', icon2: 'lightbulb-outline', offColor: Off, minValueColorTemp: 500, // Mired = Warmweiß = 1.000.000 / 2000 K = 500 Mired maxValueColorTemp: 153, // Mired = Kaltweiß = 1.000.000 / 6536 K = 153 Mired interpolateColor: true, modeList: ["blink","breathe","okay","channel_change","finish_effect","stop_effect","colorloop","stop_colorloop"], inSel_ChoiceState: true },Der erste mit
inSel_Aliasund der zweite mitmodeList -
@Armilar
Für die modeList braucht man ein MODE Datenpunkt im Alias oder wo schreibt er die Rückgabe hin. Sollte eine Zahl sein die zurückkommt, wenn ich mich richtig erinnere. -
Ich sehe im Code nicht das ein Datenpunkt MODE benutzt wird
inSel_ChoiceStatewird im Adapter nicht verwendet - ist nur als kompatibilität in den typesEDIT: hab das mal im Code vermerkt:
inSel_ChoiceState?: boolean; //deprecated -
Hi, ich bin gerade dabei das zweite Panel auf den Adapter umzustellen. Da habe ich mich mal am global Skript versucht, da auf allen 5 Panel bei mir die gleichen Seiten sind und nur die Main Page eine andere ist. Das funktioniert auch bis ich den Adapter neu starte da erhalte ich folgende Fehlermeldungen:
nspanel-lovelace-ui.0 2026-01-13 16:59:05.257 error Error: Error: PanelTopic: Wohnzimmer_NSPanel uniqueID WZ_Status is double! Ignore this panel! nspanel-lovelace-ui.0 2026-01-13 16:59:05.256 error Error: Error: PanelTopic: NSPanel_weis uniqueID WZ_Lampen is double! Ignore this panel!Die Seiten gibt es aber gar nicht mehr die habe ich umbenannt und im Global Skript haben alle Seiten den Zusatz _glob damit man sofort sieht wo sie herkommen.
Dann gibt es eine Möglichkeit die Navigation die man im Adapter macht auf ein anderes Panel zu kopieren?
Und ich habe gesehen das es einen Seiten typ Scheduel gibt. Was macht der und wie wird der parametriert?
Vielen lieben Dank schon mal!
Zu der Frage 1. der Doppel-ID-Check fürs Skript hat in der aktuellen Version Fehler die nicht jede Dopplung finden. Der Test beim Adapterstart jedoch findet jede doppelte Seite und steigt dann aus.
Du könntest ein Backup machen und die aktuelle (19:50 - 13.01.2026) Github version testen, die sollte beim Skript senden alle doppelten Namen finden und anmeckern. Ist aber noch nicht für den produktiven Einsatz getestet.
Zu der Frage 2. Nicht ohne sich durch das config json zu wühlen.
Zu der Frage 3. cardSchedule ist ein cardEntities mit 6 Zeilen und AFAIK ohne Druckflächen - gedacht um Termine anzuzeigen - Fahrplanadapter/Mülladapter usw.
Ok ich habe es hinbekommen, ich hatte nur die Seitennamen angepasst und vergessen die Unique_IDs mit anzupassen.
Ich komme auch gerade nicht mit der Navigation über den Adapter weiter, ich habe da schon einige Seiten angelegt, aber ich kann bei prev und next nicht alle auswählen (auch die die schon angelegt sind). Woran kann das liegen?
Kann ich zur Not die Navigation auch wie in der Skriptversion direkt im Skript machen (muss dazu wahrscheinlich den Haken useNavigation im Adapter raus nehmen)? Und liest der Adapter sich die Navigation dann vom Skript aus ein?
Gibt es für cardSchedule ein Beispiel?
Gibt es schon eine Timer / Wecker Seite?
@danny_v1 sagte in Betatest NSPanel-lovelace-ui v0.7.x:
kannst du das bitte genauer beschreiben. Welche Seiten hast du angelegt im Adapter? Welche Seite siehst du nicht bei next/prev?
Die Seiten die du im Tab PageConfig erstellst werden in die Navigation vom Script dazwischen geschoben. Die Navigation vom Script gibt das Grundgerüst. Beispiel: Du hast drei Seiten Main, Licht, Rollo unter pages[] deklariert. Diese würden auf dem Panel hinter einander angezeigt. Jetzt erstellst du im Adapter eine Seite z.B. QR und wählst da bei Navigation das Panel aus und bei next Licht. Dann würde im Panel jetzt Main, Licht, QR, Rollo angezeigt werden. Die letzte Seite ist immer die Servicepage.
In deinem global Script musst du die Navigation komplett erstellen, weil alles Seiten von dort gleich behandelt werden und der Panel Navigation hinten angesetzt werden.Gibt es für cardSchedule ein Beispiel?
Wie schon geschrieben, wie eine cardEntities nur ohne Navigation und die beiden Textfelder haben andere Größen.
ja, hast aber noch nicht alle Funktionen vom Script. soviel ich weiss.
ich hab ne entität
{ type: 'script', ScreensaverEntity: 'zigbee2mqtt.0.0xa4c138e6f081dd85.temperature', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 1, ScreensaverEntityIconOn: 'thermometer', ScreensaverEntityIconOff: null, ScreensaverEntityText: 'Terrasse', ScreensaverEntityUnitText: '°C', ScreensaverEntityIconColor: {'val_min': -20, 'val_max': 40, 'val_best': 20}, ScreensaverEntityIconSelect: [ {icon: 'sun-thermometer', value: 40}, {icon: 'sun-thermometer-outline', value: 35}, {icon: 'thermometer-high', value: 30}, {icon: 'thermometer', value: 25}, {icon: 'thermometer-low', value: 15}, {icon: 'snowflake-alert', value: 1}, {icon: 'snowflake-thermometer', value: -2}, {icon: 'snowflake', value: -10}, ] },im screenasver. dasProblem ist die Farbgebung.. von thermometer erwarte ich von blau nach gelb..und nicht von gelb nach rot wie es gerade angezeigt wird.
So sieht das bei mir aus gibt einen verlauf von blau - grün - gelb - rot
ScreensaverEntityIconColor: { val_min: 40, val_max: -10, val_best: 20, mode: 'quadriGradAnchor' },Das Anchor binden val_best an die Farbe: muß nachgucken
Ja, weil der Code rot-gelb-grün (triGrad) oder rot-gelb-grün-blau (quadriGrad) macht.
Bei
quadriGradAnchorgibt val_best die position von grün an.case 0: // Rot → Gelb case 1: // Gelb → Grün case 2: // Grün → Cyan case 3: // Cyan → BlauEDIT:
min = rot
max = grün/blau -
Hi Jungs, ich wollte einfach mal Danke sagen. Für euren Adapter und euren Support. Vorallem an @tt-tom . Läuft nun alles hervorragend!
Noch eine Frage: Der Screensaver schaltet sich ja im Nachtmodus ab. Ist es eigentlich möglich, das ganze per Bewegung zu koppeln? Also Display an wenn Bewegung erkannt? Und wie ist eure Meinung zum internen Temp. Sensor? Lohnt sich da Energie reinzustecken, oder ist dieser sowieso Schrott?
