  4. [Gelöst] Update js-controller geht nicht
45 Beiträge 3 Kommentatoren 6.3k Aufrufe 3 Beobachtet
  • S Stephan1966
    ======== Start marking the full check here =========
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypismarthome
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : armhf
    Systemuptime and Load:
     14:07:31 up  2:48,  1 user,  load average: 1.44, 0.89, 0.48
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Mon 2023-12-18 14:07:32 CET
               Universal time: Mon 2023-12-18 13:07:32 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            3.8G        606M        1.3G        1.0M        1.9G        3.1G
    Swap:            99M          0B         99M
    Total:          3.9G        606M        1.4G
             3794 M total memory
              606 M used memory
              688 M active memory
             1517 M inactive memory
             1321 M free memory
              207 M buffer memory
             1658 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FAILED SERVICES ***
      UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
    * deconz-init.service   loaded failed failed deCONZ: ZigBee gateway -- Initialisation
    * deconz-update.service loaded failed failed deCONZ: ZigBee gateway -- Update Service
    * deconz-wifi.service   loaded failed failed deCONZ: ZigBee gateway -- WIFI Service
    3 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       29G  6.1G   22G  22% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs          tmpfs     759M  1.8M  758M   1% /run
    /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Mon Dec 18 11:19:29 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Mon Dec 18 11:19:30 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Dec 18 11:19:30 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Mon Dec 18 11:19:32 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    Show mounted filesystems \(real ones only\):
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    1.9G    /var/
    1.1G    /var/log/journal/2db8461036a4455ab0afd36ad1c9f367
    1.1G    /var/log
    658M    /var/cache
    Archived and active journals take up 1.0G in the file system.
    /opt/iobroker/backups:
    393M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    313M    /opt/iobroker/iobroker-data/
    180M    /opt/iobroker/iobroker-data/files
    105M    /opt/iobroker/iobroker-data/backup-objects
    67M     /opt/iobroker/iobroker-data/files/javascript.admin
    48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    9.7M    /opt/iobroker/iobroker-data/objects.jsonl
    8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
            100 /var/lib/dpkg/status
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.12.0
    javascript:     7.1.6
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypismarthome                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : raspberrypismarthome                     -  enabled
    + system.adapter.backitup.0               : backitup              : raspberrypismarthome                     -  enabled
    + system.adapter.deconz.1                 : deconz                : raspberrypismarthome                     -  enabled, port: 80
    + system.adapter.discovery.0              : discovery             : raspberrypismarthome                     -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : raspberrypismarthome                     -  enabled
    + system.adapter.info.0                   : info                  : raspberrypismarthome                     -  enabled
    + system.adapter.iot.0                    : iot                   : raspberrypismarthome                     -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypismarthome                     -  enabled
    + system.adapter.net-tools.0              : net-tools             : raspberrypismarthome                     -  enabled
    + system.adapter.ping.0                   : ping                  : raspberrypismarthome                     -  enabled
    + system.adapter.pushover.0               : pushover              : raspberrypismarthome                     -  enabled
    + system.adapter.tr-064.0                 : tr-064                : raspberrypismarthome                     -  enabled
      system.adapter.vis.0                    : vis                   : raspberrypismarthome                     -  enabled
    + system.adapter.web.0                    : web                   : raspberrypismarthome                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "deconz"       : 1.3.23   , installed 1.3.23
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
    Objects and States
    Objects:        2050
    States:         1756
    Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       87946      15594/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       87939      15594/iobroker.js-c
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          15069      831/smbd
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       11194      400/deCONZ
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          15070      831/smbd
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       12931      400/deCONZ
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14170      535/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       90447      15612/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       90049      15972/io.web.0
    tcp6       0      0 :::445                  :::*                    LISTEN      0          15067      831/smbd
    tcp6       0      0 :::139                  :::*                    LISTEN      0          15068      831/smbd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14172      535/sshd: /usr/sbin
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14033      392/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       91665      16022/io.deconz.1
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       14805      400/deCONZ
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14249      747/dhcpcd
    udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          16432      751/nmbd
    udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          16431      751/nmbd
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          16415      751/nmbd
    udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          16434      751/nmbd
    udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          16433      751/nmbd
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          16416      751/nmbd
    udp        0      0 0.0.0.0:45598           0.0.0.0:*                           108        14035      392/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        14034      392/avahi-daemon: r
    udp6       0      0 :::1900                 :::*                                1001       91667      16022/io.deconz.1
    udp6       0      0 :::1900                 :::*                                1001       91666      16022/io.deconz.1
    udp6       0      0 :::34833                :::*                                108        14036      392/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          14262      747/dhcpcd
    2023-12-18 14:07:42.363  - error: fritzdect.0 (15942) no response part in returned error message
    2023-12-18 14:07:42.363  - error: fritzdect.0 (15942) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
    2023-12-18 14:07:42.364  - error: fritzdect.0 (15942) login not possible, check user and permissions
    2023-12-18 14:07:43.505  - info: host.raspberrypismarthome instance system.adapter.web.0 started with pid 15972
    2023-12-18 14:07:47.252  - info: web.0 (15972) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
    2023-12-18 14:07:47.570  - info: web.0 (15972) socket.io server listening on port 8082
    2023-12-18 14:07:47.582  - info: web.0 (15972) http server listening on port 8082
    2023-12-18 14:07:50.378  - info: vis.0 (15997) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
    2023-12-18 14:07:51.083  - info: vis.0 (15997) Terminated (NO_ERROR): Without reason
    2023-12-18 14:07:51.489  - info: host.raspberrypismarthome instance system.adapter.deconz.1 started with pid 16022
    2023-12-18 14:07:51.682  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
    2023-12-18 14:07:54.669  - info: deconz.1 (16022) starting. Version 1.3.23 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.19.0, js-controller: 5.0.17
    2023-12-18 14:07:54.881  - info: deconz.1 (16022) deConz Version: 2.24.2; API version: 1.16.0
    2023-12-18 14:07:55.488  - info: host.raspberrypismarthome instance system.adapter.info.0 started with pid 16046
    2023-12-18 14:07:59.511  - info: host.raspberrypismarthome instance system.adapter.iot.0 started with pid 16090
    2023-12-18 14:08:01.351  - info: info.0 (16046) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.17
    2023-12-18 14:08:01.666  - info: info.0 (16046) Reading/updating systemdata.
    2023-12-18 14:08:04.164  - info: info.0 (16046) cpu Temp res = {"main":47.225,"cores":[],"max":47.225,"socket":[],"chipset":null}
    2023-12-18 14:08:05.265  - info: iot.0 (16090) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
    2023-12-18 14:08:05.531  - info: iot.0 (16090) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
    2023-12-18 14:08:06.392  - info: iot.0 (16090) Connection changed: connect "s_glebe66_googlemail_com"
    2023-12-18 14:08:06.642  - info: alexa2.0 (15845) Subscribing to states...
    2023-12-18 14:08:06.650  - info: alexa2.0 (15845) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
    2023-12-18 14:08:08.370  - info: alexa2.0 (15845) Alexa-Push-Connection (macDms = true) established. Disable Polling
    2023-12-18 14:08:15.917  - info: alexa2.0 (15845) Initialization Done ...
    iob diag has finished.
    @stephan1966
    Hast du das boot target gesetzt?
    sudo systemctl set-default multi-user.target
    sudo reboot
    Was ist denn nun mit deconz los?
      @stephan1966
      sudo reboot
      Stephan1966
      @thomas-braun sagte in Update js-controller geht nicht:
      sudo reboot
      Muss ich diese beiden Befehle eingeben?
      ioBroker vorher anhalten?
      Beste Grüße,
      Stephan
      Iobroker Nutzer seit 2022
      • S Stephan1966
        sudo reboot
        @stephan1966 sagte in Update js-controller geht nicht:
        Ja / Nein.
          @stephan1966
          Gib mal die Langfassung von
          iob diag
          bekannt.
          Stephan1966
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
          Docker          : false
          Kernel          : aarch64
          Userland        : armhf
           14:25:37 up 1 min,  1 user,  load average: 1.42, 0.45, 0.16
          CPU threads: 4
          Current issues:
                         Local time: Mon 2023-12-18 14:25:37 CET
                     Universal time: Mon 2023-12-18 13:25:37 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:            3.8G        698M        2.8G        1.0M        293M        3.0G
          Swap:            99M          0B         99M
          Total:          3.9G        698M        2.9G
                   3794 M total memory
                    698 M used memory
                    767 M active memory
                    119 M inactive memory
                   2802 M free memory
                     40 M buffer memory
                    252 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          [Mon Dec 18 14:24:23 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Mon Dec 18 14:24:24 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Mon Dec 18 14:24:24 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Mon Dec 18 14:24:27 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          /var:
          1.9G    /var/
          1.1G    /var/log
          658M    /var/cache
          315M    /opt/iobroker/iobroker-data/
          11M     /opt/iobroker/iobroker-data/objects.jsonl
          USB-Devices by-id:
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.12.0
          javascript:     7.1.6
          Adapter State
          + instance is alive
          Objects and States
          Objects:        2065
          States:         1769
          Pending Updates: 0
          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       13818      399/deCONZ
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13783      523/sshd: /usr/sbin
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12213      504/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14838      504/iobroker.js-con
          tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          14054      753/smbd
          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       12175      399/deCONZ
          tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          14053      753/smbd
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15694      676/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17553      1023/io.web.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          13785      523/sshd: /usr/sbin
          tcp6       0      0 :::139                  :::*                    LISTEN      0          14052      753/smbd
          tcp6       0      0 :::445                  :::*                    LISTEN      0          14051      753/smbd
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        2041       393/avahi-daemon: r
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       17621      1083/io.deconz.1
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15442      399/deCONZ
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13837      747/dhcpcd
          udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          13983      748/nmbd
          udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          13982      748/nmbd
          udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          13966      748/nmbd
          udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          13985      748/nmbd
          udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          13984      748/nmbd
          udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          13967      748/nmbd
          udp        0      0 0.0.0.0:51768           0.0.0.0:*                           108        2043       393/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                108        2042       393/avahi-daemon: r
          udp6       0      0 :::48542                :::*                                108        2044       393/avahi-daemon: r
          udp6       0      0 :::1900                 :::*                                1001       17623      1083/io.deconz.1
          udp6       0      0 :::1900                 :::*                                1001       17622      1083/io.deconz.1
          udp6       0      0 :::546                  :::*                                0          13850      747/dhcpcd
          2023-12-18 14:25:19.593  - error: fritzdect.0 (1008) no response part in returned error message
          2023-12-18 14:25:19.593  - error: fritzdect.0 (1008) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
          2023-12-18 14:25:19.594  - error: fritzdect.0 (1008) login not possible, check user and permissions
          2023-12-18 14:25:20.809  - info: host.raspberrypismarthome instance system.adapter.web.0 started with pid 1023
          2023-12-18 14:25:24.559  - info: web.0 (1023) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
          2023-12-18 14:25:25.051  - info: web.0 (1023) socket.io server listening on port 8082
          2023-12-18 14:25:25.059  - info: web.0 (1023) http server listening on port 8082
          2023-12-18 14:25:27.639  - info: vis.0 (1059) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
          2023-12-18 14:25:28.699  - info: vis.0 (1059) Terminated (NO_ERROR): Without reason
          2023-12-18 14:25:28.750  - info: host.raspberrypismarthome instance system.adapter.deconz.1 started with pid 1083
          2023-12-18 14:25:29.290  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
          2023-12-18 14:25:31.643  - info: alexa2.0 (939) Subscribing to states...
          2023-12-18 14:25:31.653  - info: alexa2.0 (939) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
          2023-12-18 14:25:31.867  - info: deconz.1 (1083) starting. Version 1.3.23 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.19.0, js-controller: 5.0.17
          2023-12-18 14:25:32.013  - info: deconz.1 (1083) deConz Version: 2.24.2; API version: 1.16.0
          2023-12-18 14:25:32.791  - info: host.raspberrypismarthome instance system.adapter.info.0 started with pid 1107
          2023-12-18 14:25:33.549  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
          2023-12-18 14:25:36.750  - info: host.raspberrypismarthome instance system.adapter.iot.0 started with pid 1133
          2023-12-18 14:25:38.276  - info: info.0 (1107) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.17
          2023-12-18 14:25:38.565  - info: info.0 (1107) Reading/updating systemdata.
          2023-12-18 14:25:40.091  - info: info.0 (1107) cpu Temp res = {"main":46.738,"cores":[],"max":46.738,"socket":[],"chipset":null}
          2023-12-18 14:25:40.203  - info: alexa2.0 (939) Initialization Done ...
          2023-12-18 14:25:41.632  - info: iot.0 (1133) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
          2023-12-18 14:25:41.783  - info: iot.0 (1133) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
          2023-12-18 14:25:42.623  - info: iot.0 (1133) Connection changed: connect "s_glebe66_googlemail_com"
          Beste Grüße,
          Stephan
            Ja / Nein.
            Stephan1966
            Ja / Nein.
            ist erledigt
            Beste Grüße,
            Stephan
              Stephan1966
              Was ist denn mit dem 'deconz' los?
              Nachfolgend der aktuelle Stand, ich glaube es ist noch nicht OK oder?
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : armhf
               12:52:33 up 22:28,  1 user,  load average: 0.15, 0.03, 0.01
              CPU threads: 4
              Current issues:
                             Local time: Tue 2023-12-19 12:52:33 CET
                         Universal time: Tue 2023-12-19 11:52:33 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              /home/pi
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            3.8G        816M        2.4G        1.0M        588M        2.9G
              Swap:            99M          0B         99M
              Total:          3.9G        816M        2.5G
                       3794 M total memory
                        816 M used memory
                        895 M active memory
                        367 M inactive memory
                       2389 M free memory
                         89 M buffer memory
                        499 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /dev/root      ext4       29G  6.2G   22G  23% /
              /var:
              1.9G    /var/
              1.1G    /var/log
              658M    /var/cache
              396M    /opt/iobroker/backups/
              329M    /opt/iobroker/iobroker-data/
              24M     /opt/iobroker/iobroker-data/objects.jsonl
              USB-Devices by-id:
              /usr/bin/npm            10.2.3
              /usr/bin/npx            10.2.3
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.12.0
              javascript:     7.1.6
              Adapter State
              + instance is alive
              Objects and States
              Objects:        2065
              States:         1761
              Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
              Pending Updates: 0
              2023-12-19 00:22:45.291  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
              2023-12-19 02:00:19.204  - error: backitup.0 (974) [iobroker/ftp] Error: Access to home directory not allowed.
              2023-12-19 02:00:19.217  - error: backitup.0 (974) [iobroker] Error: Access to home directory not allowed.
              2023-12-19 02:24:51.981  - info: admin.0 (676) Request actual repository...
              2023-12-19 02:24:52.654  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
              2023-12-19 02:24:58.132  - info: admin.0 (676) Repository received successfully.
              2023-12-19 02:25:47.031  - info: info.0 (1107) Reading/updating systemdata.
              2023-12-19 02:25:47.675  - info: info.0 (1107) cpu Temp res = {"main":41.868,"cores":[],"max":41.868,"socket":[],"chipset":null}
              2023-12-19 03:18:22.246  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
              2023-12-19 03:18:23.687  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
              2023-12-19 05:56:01.651  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
              2023-12-19 05:56:03.105  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
              2023-12-19 08:44:32.929  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
              2023-12-19 08:44:56.919  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
              2023-12-19 08:44:59.590  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
              2023-12-19 08:46:40.957  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
              2023-12-19 08:59:55.063  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
              2023-12-19 08:59:56.533  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
              2023-12-19 10:14:57.017  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
              2023-12-19 10:14:59.037  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
              2023-12-19 10:15:37.424  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
              2023-12-19 10:21:47.849  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
              2023-12-19 10:22:19.303  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
              2023-12-19 12:41:01.489  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
              2023-12-19 12:41:02.953  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
              Beste Grüße,
              Stephan
              • S Stephan1966
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : armhf
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:            99M          0B         99M
                         3794 M total memory
                          816 M used memory
                          895 M active memory
                         2389 M free memory
                           89 M buffer memory
                          499 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                1.9G    /var/
                1.1G    /var/log
                658M    /var/cache
                USB-Devices by-id:
                /usr/bin/npm            10.2.3
                /usr/bin/npx            10.2.3
                nodejs:
                  Version table:
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.12.0
                javascript:     7.1.6
                Adapter State
                + instance is alive
                Objects and States
                Objects:        2065
                States:         1761
                Pending Updates: 0
                Versuch mal, den deconz neuzuinstallieren.
                sudo apt install --reinstall deconz
                  Stephan1966
                  Beste Grüße,
                  Stephan
                  • S Stephan1966
                    @stephan1966
                    Sollte egal sein. Vielleicht den deconz-Adapter danach mal neustarten.
                      @stephan1966
                      Stephan1966
                      Hier das Ergebnis, sieht soweit ich das beurteilen kann noch genauso aus!
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : armhf
                       14:56:47 up 2 min,  1 user,  load average: 1.21, 0.66, 0.26
                      CPU threads: 4
                      Current issues:
                                     Local time: Tue 2023-12-19 14:56:47 CET
                                 Universal time: Tue 2023-12-19 13:56:47 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      /home/pi
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            3.8G        651M        2.8G        1.0M        302M        3.1G
                      Swap:            99M          0B         99M
                      Total:          3.9G        651M        2.9G
                               3794 M total memory
                                651 M used memory
                                725 M active memory
                                118 M inactive memory
                               2840 M free memory
                                 41 M buffer memory
                                260 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /dev/root      ext4       29G  6.2G   22G  22% /
                      [Tue Dec 19 14:54:28 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
                      [Tue Dec 19 14:54:29 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                      [Tue Dec 19 14:54:29 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                      [Tue Dec 19 14:54:32 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                      /var:
                      1.9G    /var/
                      1.1G    /var/log
                      658M    /var/cache
                      310M    /opt/iobroker/iobroker-data/
                      8.6M    /opt/iobroker/iobroker-data/objects.jsonl
                      USB-Devices by-id:
                      /usr/bin/npm            10.2.3
                      /usr/bin/npx            10.2.3
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.12.0
                      javascript:     7.1.6
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        2065
                      States:         1769
                      Pending Updates: 0
                      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          14205      816/smbd
                      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       13015      400/deCONZ
                      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          14206      816/smbd
                      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       12989      400/deCONZ
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15042      537/sshd: /usr/sbin
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13070      501/iobroker.js-con
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12123      501/iobroker.js-con
                      tcp6       0      0 :::445                  :::*                    LISTEN      0          14203      816/smbd
                      tcp6       0      0 :::139                  :::*                    LISTEN      0          14204      816/smbd
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          15044      537/sshd: /usr/sbin
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13211      662/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17527      1040/io.web.0
                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       16822      1070/io.deconz.1
                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15097      400/deCONZ
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12103      749/dhcpcd
                      udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          14181      750/nmbd
                      udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          14180      750/nmbd
                      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          14164      750/nmbd
                      udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          14183      750/nmbd
                      udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          14182      750/nmbd
                      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          14165      750/nmbd
                      udp        0      0 0.0.0.0:41316           0.0.0.0:*                           108        14958      394/avahi-daemon: r
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14956      394/avahi-daemon: r
                      udp6       0      0 :::1900                 :::*                                1001       16824      1070/io.deconz.1
                      udp6       0      0 :::1900                 :::*                                1001       16823      1070/io.deconz.1
                      udp6       0      0 :::45045                :::*                                108        14959      394/avahi-daemon: r
                      udp6       0      0 :::546                  :::*                                0          13027      749/dhcpcd
                      udp6       0      0 :::5353                 :::*                                108        14957      394/avahi-daemon: r
                      2023-12-19 14:55:23.658  - error: fritzdect.0 (1025) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
                      2023-12-19 14:55:23.658  - error: fritzdect.0 (1025) login not possible, check user and permissions
                      2023-12-19 14:55:24.974  - info: host.raspberrypismarthome instance system.adapter.web.0 started with pid 1040
                      2023-12-19 14:55:28.042  - info: web.0 (1040) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
                      2023-12-19 14:55:28.584  - info: web.0 (1040) socket.io server listening on port 8082
                      2023-12-19 14:55:28.603  - info: web.0 (1040) http server listening on port 8082
                      2023-12-19 14:55:31.435  - info: vis.0 (1055) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
                      2023-12-19 14:55:32.211  - info: vis.0 (1055) Terminated (NO_ERROR): Without reason
                      2023-12-19 14:55:32.794  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
                      2023-12-19 14:55:32.972  - info: host.raspberrypismarthome instance system.adapter.deconz.1 started with pid 1070
                      2023-12-19 14:55:35.726  - info: deconz.1 (1070) starting. Version 1.3.23 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.19.0, js-controller: 5.0.17
                      2023-12-19 14:55:35.883  - info: deconz.1 (1070) deConz Version: 2.24.2; API version: 1.16.0
                      2023-12-19 14:55:36.496  - info: admin.0 (662) ==> Connected system.user.admin from ::ffff:192.168.178.59
                      2023-12-19 14:55:38.641  - info: host.raspberrypismarthome instance system.adapter.info.0 started with pid 1086
                      2023-12-19 14:55:41.025  - info: host.raspberrypismarthome instance system.adapter.iot.0 started with pid 1101
                      2023-12-19 14:55:45.888  - info: info.0 (1086) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.17
                      2023-12-19 14:55:46.253  - info: info.0 (1086) Reading/updating systemdata.
                      2023-12-19 14:55:46.468  - info: iot.0 (1101) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
                      2023-12-19 14:55:46.638  - info: iot.0 (1101) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                      2023-12-19 14:55:47.531  - info: iot.0 (1101) Connection changed: connect "s_glebe66_googlemail_com"
                      2023-12-19 14:55:47.731  - info: info.0 (1086) cpu Temp res = {"main":46.251,"cores":[],"max":46.251,"socket":[],"chipset":null}
                      2023-12-19 14:55:49.207  - info: alexa2.0 (987) Subscribing to states...
                      2023-12-19 14:55:49.216  - info: alexa2.0 (987) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
                      2023-12-19 14:55:51.087  - info: alexa2.0 (987) Alexa-Push-Connection (macDms = true) established. Disable Polling
                      2023-12-19 14:55:55.552  - info: alexa2.0 (987) Initialization Done ...
                      Beste Grüße,
                      Stephan
                      • S Stephan1966
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : armhf
                        CPU threads: 4
                        Current issues:
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        /home/pi
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:            99M          0B         99M
                                 3794 M total memory
                                  651 M used memory
                                  725 M active memory
                                 2840 M free memory
                                   41 M buffer memory
                                  260 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /var:
                        1.9G    /var/
                        1.1G    /var/log
                        658M    /var/cache
                        USB-Devices by-id:
                        /usr/bin/npm            10.2.3
                        /usr/bin/npx            10.2.3
                        nodejs:
                          Version table:
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.12.0
                        javascript:     7.1.6
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        2065
                        States:         1769
                        Pending Updates: 0
                        deconz-init.service
                        Dann musst du mal schauen, was da klemmen könnte.
                        systemctl status deconz*
                          deconz-init.service
                          Stephan1966
                          Ergebnis meiner Eingabe!
                          pi@raspberrypismarthome:~ $ systemctl status deconz*
                          Unit deconz-latest-beta.deb.service could not be found.
                          Beste Grüße,
                          Stephan
                          • S Stephan1966
                            @stephan1966
                            Mal mit beta-Zeuch herumgespielt?
                            apt policy deconz*
                            sagt?
                              @stephan1966
                              apt policy deconz*
                              sagt?
                              Stephan1966
                              Kann mich nicht erinnern, hier das Ergebnis:
                              pi@raspberrypismarthome:~ $ apt policy deconz*
                              N: Paket deconz-latest-beta.deb kann nicht gefunden werden.
                              N: Mittels des Musters »deconz-latest-beta.deb« konnte kein Paket gefunden werden.
                              Beste Grüße,
                              Stephan
                              • S Stephan1966
                                @stephan1966
                                ls -lAh
                                  @stephan1966
                                  ls -lAh
                                  Stephan1966
                                  ls -lAh
                                  Ergebnis:
                                  pi@raspberrypismarthome:~ $ ls -lAh
                                  insgesamt 6,6M
                                  drwxr-xr-x 2 root root 4,0K 10. Jan 2023 backup
                                  -rw------- 1 pi pi 3,9K 19. Dez 14:54 .bash_history
                                  -rw-r--r-- 1 pi pi 220 30. Okt 2021 .bash_logout
                                  -rw-r--r-- 1 pi pi 3,7K 18. Dez 12:12 .bashrc
                                  drwxr-xr-x 4 pi pi 4,0K 2. Dez 2021 .cache
                                  drwx------ 3 pi pi 4,0K 2. Dez 2021 .config
                                  -rw-r--r-- 1 pi pi 161K 20. Aug 2021 deCONZ_ConBeeII_0x26720700.bin.GCF
                                  -rw-r--r-- 1 pi pi 6,4M 30. Apr 2022 deconz-latest-beta.deb
                                  drwxr-xr-x 2 pi pi 4,0K 2. Dez 2021 .iobroker
                                  drwxr-xr-x 3 pi pi 4,0K 21. Dez 2021 .local
                                  drwxr-xr-x 5 pi pi 4,0K 2. Dez 2021 .npm
                                  -rw------- 1 pi pi 36 2. Dez 2021 .npmrc
                                  -rw-r--r-- 1 pi pi 807 30. Okt 2021 .profile
                                  Beste Grüße,
                                  Stephan
                                  • S Stephan1966
                                    ls -lAh
                                    Ergebnis:
                                    insgesamt 6,6M
                                    @stephan1966
                                    Das muss da weg:
                                    rm deconz-latest-beta.deb
                                    Und bitte Auszüge aus der Konsole immer in Code Tags setzen. Liest sich besser.
                                      @stephan1966
                                      Das muss da weg:
                                      Stephan1966
                                      Hier das Ergebnis nachdem ich rm deconz-latest-beta.deb ausgeführt habe: ```
                                      Skript v.2023-10-10
                                      *** BASE SYSTEM ***
                                               Icon name: computer
                                            Architecture: arm64
                                      Docker          : false
                                      Kernel          : aarch64
                                      Userland        : armhf
                                       09:35:28 up 2 days, 18:41,  1 user,  load average: 0.07, 0.19, 0.22
                                      CPU threads: 4
                                      Current issues:
                                                     Local time: Fri 2023-12-22 09:35:28 CET
                                                 Universal time: Fri 2023-12-22 08:35:28 UTC
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      pi
                                      /home/pi
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Mem:            3.8G        803M        2.4G        1.0M        625M        2.9G
                                      Swap:            99M          0B         99M
                                      Total:          3.9G        803M        2.5G
                                               3794 M total memory
                                                803 M used memory
                                                883 M active memory
                                                401 M inactive memory
                                               2364 M free memory
                                                 90 M buffer memory
                                                535 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      *** FILESYSTEM ***
                                      /var:
                                      1.9G    /var/
                                      1.1G    /var/log
                                      658M    /var/cache
                                      403M    /opt/iobroker/backups/
                                      333M    /opt/iobroker/iobroker-data/
                                      106M    /opt/iobroker/iobroker-data/backup-objects
                                      28M     /opt/iobroker/iobroker-data/objects.jsonl
                                      USB-Devices by-id:
                                      /usr/bin/npm            10.2.3
                                      /usr/bin/npx            10.2.3
                                      nodejs:
                                        Version table:
                                      Errors in npm tree:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          6.12.0
                                      javascript:     7.1.6
                                      Adapter State
                                      + instance is alive
                                      Adapter    "pushover"     : 3.0.6    , installed 3.0.6
                                      Objects and States
                                      Objects:        2065
                                      States:         1761
                                      Pending Updates: 0
                                      2023-12-22 09:15:38.510  - info: host.raspberrypismarthome stopInstance system.adapter.pushover.0 send kill signal
                                      2023-12-22 09:15:38.738  - info: host.raspberrypismarthome iobroker upload [14] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/blockly.js blockly.js application/javascript
                                      2023-12-22 09:15:38.760  - info: host.raspberrypismarthome iobroker upload [13] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                      2023-12-22 09:15:38.771  - info: host.raspberrypismarthome iobroker upload [12] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                      2023-12-22 09:15:38.781  - info: host.raspberrypismarthome iobroker upload [11] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                      2023-12-22 09:15:38.792  - info: host.raspberrypismarthome iobroker upload [10] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                      2023-12-22 09:15:38.803  - info: host.raspberrypismarthome iobroker upload [9] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                      2023-12-22 09:15:38.815  - info: host.raspberrypismarthome iobroker upload [8] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                      2023-12-22 09:15:38.825  - info: host.raspberrypismarthome iobroker upload [7] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                      2023-12-22 09:15:38.839  - info: host.raspberrypismarthome iobroker upload [6] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                      2023-12-22 09:15:38.852  - info: host.raspberrypismarthome iobroker upload [5] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                      2023-12-22 09:15:38.864  - info: host.raspberrypismarthome iobroker upload [4] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                      2023-12-22 09:15:38.874  - info: host.raspberrypismarthome iobroker upload [3] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/index_m.html index_m.html text/html
                                      2023-12-22 09:15:38.884  - info: host.raspberrypismarthome iobroker upload [2] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/jsonConfig.json jsonConfig.json application/json
                                      2023-12-22 09:15:38.895  - info: host.raspberrypismarthome iobroker upload [1] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/pushover.png pushover.png image/png
                                      2023-12-22 09:15:38.905  - info: host.raspberrypismarthome iobroker upload [0] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/words.js words.js application/javascript
                                      2023-12-22 09:15:38.976  - info: pushover.0 (829) terminating
                                      2023-12-22 09:15:38.978  - info: pushover.0 (829) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      2023-12-22 09:15:39.514  - info: host.raspberrypismarthome stopInstance system.adapter.pushover.0 killing pid 829
                                      2023-12-22 09:15:39.611  - info: host.raspberrypismarthome instance system.adapter.pushover.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2023-12-22 09:15:39.947  - info: host.raspberrypismarthome iobroker exit 0
                                      2023-12-22 09:15:41.597  - info: host.raspberrypismarthome instance system.adapter.pushover.0 started with pid 17654
                                      2023-12-22 09:15:44.251  - info: pushover.0 (17654) starting. Version 3.0.6 in /opt/iobroker/node_modules/iobroker.pushover, node: v18.19.0, js-controller: 5.0.17
                                      2023-12-22 09:18:40.465  - info: admin.0 (662) ==> Connected system.user.admin from ::ffff:192.168.178.59
                                      2023-12-22 09:18:43.110  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                      Beste Grüße,
                                      Stephan
                                      • S Stephan1966
                                        Skript v.2023-10-10
                                        *** BASE SYSTEM ***
                                                 Icon name: computer
                                              Architecture: arm64
                                        Docker          : false
                                        Kernel          : aarch64
                                        Userland        : armhf
                                        CPU threads: 4
                                        Current issues:
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        pi
                                        /home/pi
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Swap:            99M          0B         99M
                                                 3794 M total memory
                                                  803 M used memory
                                                  883 M active memory
                                                 2364 M free memory
                                                   90 M buffer memory
                                                  535 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        Raspberry only:
                                        oom events: 0
                                        *** FILESYSTEM ***
                                        /var:
                                        1.9G    /var/
                                        1.1G    /var/log
                                        658M    /var/cache
                                        USB-Devices by-id:
                                        /usr/bin/npm            10.2.3
                                        /usr/bin/npx            10.2.3
                                        nodejs:
                                          Version table:
                                        Errors in npm tree:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin:          6.12.0
                                        javascript:     7.1.6
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        2065
                                        States:         1761
                                        Pending Updates: 0
                                        @stephan1966
                                        wirft jetzt was raus?
                                        S 2 Antworten Letzte Antwort
                                          @stephan1966
                                          Stephan1966
                                          @thomas-braun ```
                                          Copy text starting here:
        v.2023-10-10
                                                   Icon name: computer
                                                Architecture: arm64
                                          Installation:           native
                                          Kernel:                 aarch64
                                          Userland:               armhf
                                          Timezone:               Europe/Berlin (CET, +0100)
                                          User-ID:                1000
                                          X-Server:               false
                                          Pending OS-Updates:     0
                                          Pending iob updates:    0
                                          Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
                                          Recommended versions are nodejs 18.19.0 and npm 10.2.3
                                          MEMORY:
                                          Mem:            3.8G        848M        2.3G        1.0M        626M        2.9G
                                          Swap:            99M          0B         99M
                                          Total:          3.9G        848M        2.4G
                                          Active iob-Instances:   15
                                          ioBroker Core:          js-controller           5.0.17
        admin                   6.12.0
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Objects:                2065
                                          States:                 1761
                                          Size of iob-Database:
                                          6.3M    /opt/iobroker/iobroker-data/objects.json.migrated
                                          6.3M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                          6.8M    /opt/iobroker/iobroker-data/states.jsonl
                                          488K    /opt/iobroker/iobroker-data/states.json.migrated
                                          488K    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                          0       /opt/iobroker/iobroker-data/states.json.broken
                                          Beste Grüße,
                                          Stephan
