  4. [Gelöst] Update js-controller geht nicht
45 Beiträge 3 Kommentatoren 6.3k Aufrufe 3 Beobachtet
    @stephan1966
    Gib mal die Langfassung von
    iob diag
    bekannt.
    Stephan1966
    Den ganzen Text welcher direkt nach der Befehlseingabe erscheint?
    Beste Grüße,
    Stephan
    Iobroker Nutzer seit 2022
    • S Stephan1966
      @stephan1966
      Den ganzen langen Text...
      S 2 Antworten Letzte Antwort
        @stephan1966
        Stephan1966
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: raspberrypismarthome
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : armhf
        Systemuptime and Load:
         13:39:16 up  2:19,  1 user,  load average: 0.18, 0.07, 0.09
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Mon 2023-12-18 13:39:16 CET
                   Universal time: Mon 2023-12-18 12:39:16 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            3.8G        728M        1.5G        1.0M        1.6G        3.0G
        Swap:            99M          0B         99M
        Total:          3.9G        728M        1.6G
                 3794 M total memory
                  728 M used memory
                  801 M active memory
                 1225 M inactive memory
                 1495 M free memory
                  202 M buffer memory
                 1367 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
          UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
        * deconz-init.service   loaded failed failed deCONZ: ZigBee gateway -- Initialisation
        * deconz-update.service loaded failed failed deCONZ: ZigBee gateway -- Update Service
        * deconz-wifi.service   loaded failed failed deCONZ: ZigBee gateway -- WIFI Service
        3 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4       29G  6.1G   22G  22% /
        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
        tmpfs          tmpfs     759M  1.8M  758M   1% /run
        /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
        tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
        [Mon Dec 18 11:19:29 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Mon Dec 18 11:19:30 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Mon Dec 18 11:19:30 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Mon Dec 18 11:19:32 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        TARGET  SOURCE         FSTYPE OPTIONS
        /       /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
        /var:
        1.9G    /var/
        1.1G    /var/log/journal/2db8461036a4455ab0afd36ad1c9f367
        1.1G    /var/log
        658M    /var/cache
        Archived and active journals take up 1.0G in the file system.
        /opt/iobroker/backups:
        393M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        295M    /opt/iobroker/iobroker-data/
        164M    /opt/iobroker/iobroker-data/files
        105M    /opt/iobroker/iobroker-data/backup-objects
        51M     /opt/iobroker/iobroker-data/files/javascript.admin
        43M     /opt/iobroker/iobroker-data/files/iot.admin
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
        9.1M    /opt/iobroker/iobroker-data/objects.jsonl
        8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
        8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
        USB-Devices by-id:
        find: '/dev/serial/by-id/': No such file or directory
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.0-1nodesource1
          Candidate: 18.19.0-1nodesource1
          Version table:
         *** 18.19.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
             12.22.12~dfsg-1~deb11u4 500
        No problems detected
        Errors in npm tree:
        npm ERR! code ELSPROBLEMS
        npm ERR! invalid: @types/node@14.18.36 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-18T12_39_24_312Z-debug-0.log
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.17
        admin:          6.12.0
        javascript:     6.1.4
        Adapters from github:   0
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypismarthome                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.alexa2.0                 : alexa2                : raspberrypismarthome                     -  enabled
        + system.adapter.backitup.0               : backitup              : raspberrypismarthome                     -  enabled
        + system.adapter.deconz.1                 : deconz                : raspberrypismarthome                     -  enabled, port: 80
        + system.adapter.discovery.0              : discovery             : raspberrypismarthome                     -  enabled
        + system.adapter.fritzdect.0              : fritzdect             : raspberrypismarthome                     -  enabled
        + system.adapter.info.0                   : info                  : raspberrypismarthome                     -  enabled
        + system.adapter.iot.0                    : iot                   : raspberrypismarthome                     -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypismarthome                     -  enabled
        + system.adapter.net-tools.0              : net-tools             : raspberrypismarthome                     -  enabled
        + system.adapter.ping.0                   : ping                  : raspberrypismarthome                     -  enabled
        + system.adapter.pushover.0               : pushover              : raspberrypismarthome                     -  enabled
        + system.adapter.tr-064.0                 : tr-064                : raspberrypismarthome                     -  enabled
          system.adapter.vis.0                    : vis                   : raspberrypismarthome                     -  enabled
        + system.adapter.web.0                    : web                   : raspberrypismarthome                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "alexa2"       : 3.26.3   , installed 3.23.2 [Updatable]
        Adapter    "backitup"     : 2.8.7    , installed 2.8.7
        Adapter    "deconz"       : 1.3.23   , installed 1.3.23
        Adapter    "discovery"    : 4.2.0    , installed 4.2.0
        Adapter    "fritzdect"    : 2.5.9    , installed 2.2.6  [Updatable]
        Adapter    "info"         : 2.0.0    , installed 2.0.0
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "javascript"   : 7.1.6    , installed 6.1.4  [Updatable]
        Controller "js-controller": 5.0.17   , installed 5.0.17
        Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
        Adapter    "pushover"     : 3.0.3    , installed 3.0.3
        Adapter    "socketio"     : 6.6.0    , installed 6.6.0
        Adapter    "vis"          : 1.5.4    , installed 1.5.4
        Adapter    "web"          : 6.1.10   , installed 6.1.10
        Adapter    "ws"           : 2.5.8    , installed 2.5.8
        Adapter    "zigbee"       : 1.8.24   , installed 1.8.10 [Updatable]
        Objects and States
        Objects:        2017
        States:         1715
        Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       48602      8219/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       50489      8219/iobroker.js-co
        tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          15069      831/smbd
        tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       11194      400/deCONZ
        tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          15070      831/smbd
        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       12931      400/deCONZ
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14170      535/sshd: /usr/sbin
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       54627      9795/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       64933      12757/io.web.0
        tcp6       0      0 :::445                  :::*                    LISTEN      0          15067      831/smbd
        tcp6       0      0 :::139                  :::*                    LISTEN      0          15068      831/smbd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          14172      535/sshd: /usr/sbin
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14033      392/avahi-daemon: r
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       58563      10450/io.deconz.1
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       14805      400/deCONZ
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14249      747/dhcpcd
        udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          16432      751/nmbd
        udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          16431      751/nmbd
        udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          16415      751/nmbd
        udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          16434      751/nmbd
        udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          16433      751/nmbd
        udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          16416      751/nmbd
        udp        0      0 0.0.0.0:45598           0.0.0.0:*                           108        14035      392/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        14034      392/avahi-daemon: r
        udp6       0      0 :::1900                 :::*                                1001       58565      10450/io.deconz.1
        udp6       0      0 :::1900                 :::*                                1001       58564      10450/io.deconz.1
        udp6       0      0 :::34833                :::*                                108        14036      392/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          14262      747/dhcpcd
        2023-12-18 12:32:44.197  - info: host.raspberrypismarthome iobroker upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/noSwipe.jpg widgets/swipe/img/noSwipe.jpg image/jpeg
        2023-12-18 12:32:44.210  - info: host.raspberrypismarthome iobroker upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout-shapes.js widgets/swipe/js/jquery.roundabout-shapes.js application/javascript
        2023-12-18 12:32:44.222  - info: host.raspberrypismarthome iobroker upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout.min.js widgets/swipe/js/jquery.roundabout.min.js application/javascript
        2023-12-18 12:32:44.236  - info: host.raspberrypismarthome iobroker upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.touchSwipe.min.js widgets/swipe/js/jquery.touchSwipe.min.js application/javascript
        2023-12-18 12:32:44.248  - info: host.raspberrypismarthome iobroker upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe.html widgets/swipe.html text/html
        2023-12-18 12:32:44.260  - info: host.raspberrypismarthome iobroker upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/jquery.sliderTabs.js widgets/tabs/jquery.sliderTabs.js application/javascript
        2023-12-18 12:32:44.277  - info: host.raspberrypismarthome iobroker upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicator.png widgets/tabs/styles/images/indicator.png image/png
        2023-12-18 12:32:44.289  - info: host.raspberrypismarthome iobroker upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicatorActive.png widgets/tabs/styles/images/indicatorActive.png image/png
        2023-12-18 12:32:44.301  - info: host.raspberrypismarthome iobroker upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftArrow.png widgets/tabs/styles/images/leftArrow.png image/png
        2023-12-18 12:32:44.313  - info: host.raspberrypismarthome iobroker upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftPanelArrow.png widgets/tabs/styles/images/leftPanelArrow.png image/png
        2023-12-18 12:32:44.325  - info: host.raspberrypismarthome iobroker upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightArrow.png widgets/tabs/styles/images/rightArrow.png image/png
        2023-12-18 12:32:44.340  - info: host.raspberrypismarthome iobroker upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightPanelArrow.png widgets/tabs/styles/images/rightPanelArrow.png image/png
        2023-12-18 12:32:44.353  - info: host.raspberrypismarthome iobroker upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.css widgets/tabs/styles/jquery.sliderTabs.css text/css
        2023-12-18 12:32:44.365  - info: host.raspberrypismarthome iobroker upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.min.css widgets/tabs/styles/jquery.sliderTabs.min.css text/css
        2023-12-18 12:32:44.378  - info: host.raspberrypismarthome iobroker upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs.html widgets/tabs.html text/html
        2023-12-18 12:32:44.390  - info: host.raspberrypismarthome iobroker upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/dev.html widgets/todo/dev.html text/html
        2023-12-18 12:32:44.403  - info: host.raspberrypismarthome iobroker upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/homematic.html widgets/todo/homematic.html text/html
        2023-12-18 12:32:44.415  - info: host.raspberrypismarthome iobroker upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/special.html widgets/todo/special.html text/html
        2023-12-18 12:32:44.430  - info: host.raspberrypismarthome iobroker upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/weather.html widgets/todo/weather.html text/html
        2023-12-18 12:32:44.484  - info: host.raspberrypismarthome iobroker Update "system.adapter.vis.0"
        2023-12-18 12:32:44.541  - info: host.raspberrypismarthome iobroker upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
        2023-12-18 12:32:45.614  - info: host.raspberrypismarthome iobroker exit 0
        2023-12-18 12:32:46.690  - info: vis.0 (12885) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
        2023-12-18 12:32:47.358  - info: vis.0 (12885) Terminated (NO_ERROR): Without reason
        2023-12-18 12:32:47.928  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
        iob diag has finished.
        Beste Grüße,
        Stephan
        • S Stephan1966
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
          Docker          : false
          Kernel          : aarch64
          Userland        : armhf
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            99M          0B         99M
                   3794 M total memory
                    728 M used memory
                    801 M active memory
                   1495 M free memory
                    202 M buffer memory
                   1367 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          1.9G    /var/
          1.1G    /var/log
          658M    /var/cache
          USB-Devices by-id:
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.12.0
          javascript:     6.1.4
          Adapter State
          + instance is alive
          Objects and States
          Objects:        2017
          States:         1715
          Pending Updates: 0
          @stephan1966
          sudo systemctl set-default multi-user.target
          Was ist denn mit dem 'deconz' los?
          würde mir auch zu denken geben. Renkt sich aber ggf. nach einem Neustart ein.
          Schmeiß die Adapter-Updates drauf.
          iob upgrade all
            @stephan1966
            iob upgrade all
            Stephan1966
            === Mark text until here for copying ===
            pi@raspberrypismarthome:~ $ iob stop
            pi@raspberrypismarthome:~ $ iob ugrade all
            iobroker [command]
            Commands:
            iobroker setup Setup ioBroker
            iobroker start [all|<adapter>.<instance>|<adapter>] Starts the js-controller or a specified adapter instance or all instances of an adapter
            iobroker stop [<adapter>.<instance>|<adapter>] stops the js-controller or a specified adapter instance or all instances of an adapter
            iobroker restart [<adapter>.<instance>|<adapter>] Restarts js-controller or a specified adapter instance or all instances of an adapter [aliases: r]
            iobroker debug <adapter>[.<instance>] Starts a Node.js debugging session for the adapter instance
            iobroker info Shows the host info
            iobroker logs [<adapter>] Monitor log
            iobroker add <adapter> [desiredNumber] Add instance of adapter [aliases: a]
            iobroker install <adapter> Installs a specified adapter [aliases: i]
            iobroker rebuild [<module>] Rebuild all native modules or path
            iobroker url <url> [<name>] Install adapter from specified url, e.g. GitHub
            iobroker del <adapter> Remove adapter and all instances from this host [aliases: delete]
            iobroker del <adapter>.<instance> Remove adapter instance [aliases: delete]
            iobroker update [<repositoryUrl>] Update repository and list adapters
            iobroker upgrade Upgrade management
            iobroker upload [all|<adapter>] Upload management [aliases: u]
            iobroker object Object management [aliases: o]
            iobroker state State management [aliases: s]
            iobroker message <adapter>[.instance] <command> [<message>] Send message to adapter instance/s
            iobroker list <type> [<filter>] List all entries, like objects
            iobroker chmod <mode> <file> Change file rights
            iobroker chown <user> <group> <file> Change file ownership
            iobroker touch <file> Touch file
            iobroker rm <file> Remove file
            iobroker file File management
            iobroker user User commands
            iobroker group group management
            iobroker host <hostname> Set host to given hostname
            iobroker set <adapter>.<instance> Change settings of adapter config
            iobroker license <license.file or license.text> Update license by given file
            iobroker cert Certificate management
            iobroker clean <yes> Clears all objects and states
            iobroker backup Create backup
            iobroker restore <backup name or path> Restore a specified backup
            iobroker validate <backup name or path> Validate a specified backup
            iobroker status [all|<adapter>.<instance>] Status of ioBroker or adapter instance [aliases: isrun]
            iobroker repo [<name>] Show repo information
            iobroker uuid Show uuid of the installation [aliases: id]
            iobroker unsetup Reset license, installation secret and language
            iobroker fix Execute the installation fixer script, this updates your ioBroker installation
            iobroker nodejs-update [<major-version>] Upgrade the Node.JS installation to the current LTS
            iobroker multihost Multihost management
            iobroker compact compact group management
            iobroker plugin Plugin management
            iobroker vendor <passphrase> [<vendor.json>] Update the vendor information using given passphrase
            iobroker version [<adapter>] Show version of js-controller or specified adapter [aliases: v]
            Options:
            --help Show help [boolean]
            Beste Grüße,
            Stephan
            • S Stephan1966
              iobroker [command]
              Commands:
              Options:
              @stephan1966
              Das muss ja auch
              iob upgrade all
              heißen.
                @stephan1966
                Das muss ja auch
                iob upgrade all
                heißen.
                Stephan1966
                Habe ich doch vor 3 Minuten gemacht!
                Beste Grüße,
                Stephan
                • S Stephan1966
                  @stephan1966
                  Du hast das falsch geschrieben und eine entsprechende Rückmeldung erhalten, aber kein upgrade durchgeführt.
                    @stephan1966
                    Stephan1966
                    Wer lesen kann ist klar im Vorteil 👍
                    Beste Grüße,
                    Stephan
                      @stephan1966
                      Stephan1966
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : armhf
                       14:07:31 up  2:48,  1 user,  load average: 1.44, 0.89, 0.48
                      CPU threads: 4
                      Current issues:
                                     Local time: Mon 2023-12-18 14:07:32 CET
                                 Universal time: Mon 2023-12-18 13:07:32 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      /home/pi
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            3.8G        606M        1.3G        1.0M        1.9G        3.1G
                      Swap:            99M          0B         99M
                      Total:          3.9G        606M        1.4G
                               3794 M total memory
                                606 M used memory
                                688 M active memory
                               1517 M inactive memory
                               1321 M free memory
                                207 M buffer memory
                               1658 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /var:
                      1.9G    /var/
                      1.1G    /var/log
                      658M    /var/cache
                      313M    /opt/iobroker/iobroker-data/
                      180M    /opt/iobroker/iobroker-data/files
                      67M     /opt/iobroker/iobroker-data/files/javascript.admin
                      48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                      9.7M    /opt/iobroker/iobroker-data/objects.jsonl
                      USB-Devices by-id:
                      /usr/bin/npm            10.2.3
                      /usr/bin/npx            10.2.3
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.12.0
                      javascript:     7.1.6
                      Adapter State
                      + system.adapter.alexa2.0                 : alexa2                : raspberrypismarthome                     -  enabled
                      + instance is alive
                      Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
                      Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
                      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                      Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
                      Objects and States
                      Objects:        2050
                      States:         1756
                      Pending Updates: 0
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       87946      15594/iobroker.js-c
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       87939      15594/iobroker.js-c
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       90447      15612/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       90049      15972/io.web.0
                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       91665      16022/io.deconz.1
                      udp6       0      0 :::1900                 :::*                                1001       91667      16022/io.deconz.1
                      udp6       0      0 :::1900                 :::*                                1001       91666      16022/io.deconz.1
                      2023-12-18 14:07:42.363  - error: fritzdect.0 (15942) no response part in returned error message
                      2023-12-18 14:07:42.363  - error: fritzdect.0 (15942) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
                      2023-12-18 14:07:42.364  - error: fritzdect.0 (15942) login not possible, check user and permissions
                      2023-12-18 14:07:43.505  - info: host.raspberrypismarthome instance system.adapter.web.0 started with pid 15972
                      2023-12-18 14:07:47.252  - info: web.0 (15972) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
                      2023-12-18 14:07:47.570  - info: web.0 (15972) socket.io server listening on port 8082
                      2023-12-18 14:07:47.582  - info: web.0 (15972) http server listening on port 8082
                      2023-12-18 14:07:50.378  - info: vis.0 (15997) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
                      2023-12-18 14:07:51.083  - info: vis.0 (15997) Terminated (NO_ERROR): Without reason
                      2023-12-18 14:07:51.489  - info: host.raspberrypismarthome instance system.adapter.deconz.1 started with pid 16022
                      2023-12-18 14:07:51.682  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
                      2023-12-18 14:07:54.669  - info: deconz.1 (16022) starting. Version 1.3.23 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.19.0, js-controller: 5.0.17
                      2023-12-18 14:07:54.881  - info: deconz.1 (16022) deConz Version: 2.24.2; API version: 1.16.0
                      2023-12-18 14:07:55.488  - info: host.raspberrypismarthome instance system.adapter.info.0 started with pid 16046
                      2023-12-18 14:07:59.511  - info: host.raspberrypismarthome instance system.adapter.iot.0 started with pid 16090
                      2023-12-18 14:08:01.351  - info: info.0 (16046) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.17
                      2023-12-18 14:08:01.666  - info: info.0 (16046) Reading/updating systemdata.
                      2023-12-18 14:08:04.164  - info: info.0 (16046) cpu Temp res = {"main":47.225,"cores":[],"max":47.225,"socket":[],"chipset":null}
                      2023-12-18 14:08:05.265  - info: iot.0 (16090) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
                      2023-12-18 14:08:05.531  - info: iot.0 (16090) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                      2023-12-18 14:08:06.392  - info: iot.0 (16090) Connection changed: connect "s_glebe66_googlemail_com"
                      2023-12-18 14:08:06.642  - info: alexa2.0 (15845) Subscribing to states...
                      2023-12-18 14:08:06.650  - info: alexa2.0 (15845) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
                      2023-12-18 14:08:08.370  - info: alexa2.0 (15845) Alexa-Push-Connection (macDms = true) established. Disable Polling
                      2023-12-18 14:08:15.917  - info: alexa2.0 (15845) Initialization Done ...
                      Beste Grüße,
                      Stephan
                      • S Stephan1966
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : armhf
                        CPU threads: 4
                        Current issues:
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        /home/pi
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:            99M          0B         99M
                                 3794 M total memory
                                  606 M used memory
                                  688 M active memory
                                 1321 M free memory
                                  207 M buffer memory
                                 1658 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /var:
                        1.9G    /var/
                        1.1G    /var/log
                        658M    /var/cache
                        USB-Devices by-id:
                        /usr/bin/npm            10.2.3
                        /usr/bin/npx            10.2.3
                        nodejs:
                          Version table:
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.12.0
                        javascript:     7.1.6
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        2050
                        States:         1756
                        Pending Updates: 0
                        @stephan1966
                        Hast du das boot target gesetzt?
                        sudo reboot
                        Was ist denn nun mit deconz los?
                          @stephan1966
                          sudo reboot
                          Stephan1966
                          @thomas-braun sagte in Update js-controller geht nicht:
                          sudo reboot
                          Muss ich diese beiden Befehle eingeben?
                          ioBroker vorher anhalten?
                          Beste Grüße,
                          Stephan
                          • S Stephan1966
                            sudo reboot
                            @stephan1966 sagte in Update js-controller geht nicht:
                            Ja / Nein.
                              @stephan1966
                              iob diag
                              bekannt.
                              Stephan1966
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : armhf
                               14:25:37 up 1 min,  1 user,  load average: 1.42, 0.45, 0.16
                              CPU threads: 4
                              Current issues:
                                             Local time: Mon 2023-12-18 14:25:37 CET
                                         Universal time: Mon 2023-12-18 13:25:37 UTC
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              /home/pi
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              Boot Target:    multi-user.target
                              *** MEMORY ***
                              Mem:            3.8G        698M        2.8G        1.0M        293M        3.0G
                              Swap:            99M          0B         99M
                              Total:          3.9G        698M        2.9G
                                       3794 M total memory
                                        698 M used memory
                                        767 M active memory
                                        119 M inactive memory
                                       2802 M free memory
                                         40 M buffer memory
                                        252 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              [Mon Dec 18 14:24:23 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
                              [Mon Dec 18 14:24:24 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                              [Mon Dec 18 14:24:24 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                              [Mon Dec 18 14:24:27 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                              /var:
                              1.9G    /var/
                              1.1G    /var/log
                              658M    /var/cache
                              315M    /opt/iobroker/iobroker-data/
                              11M     /opt/iobroker/iobroker-data/objects.jsonl
                              USB-Devices by-id:
                              /usr/bin/npm            10.2.3
                              /usr/bin/npx            10.2.3
                              nodejs:
                                Version table:
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.12.0
                              javascript:     7.1.6
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        2065
                              States:         1769
                              Pending Updates: 0
                              tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       13818      399/deCONZ
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13783      523/sshd: /usr/sbin
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12213      504/iobroker.js-con
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14838      504/iobroker.js-con
                              tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          14054      753/smbd
                              tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       12175      399/deCONZ
                              tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          14053      753/smbd
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15694      676/io.admin.0
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17553      1023/io.web.0
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          13785      523/sshd: /usr/sbin
                              tcp6       0      0 :::139                  :::*                    LISTEN      0          14052      753/smbd
                              tcp6       0      0 :::445                  :::*                    LISTEN      0          14051      753/smbd
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        2041       393/avahi-daemon: r
                              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       17621      1083/io.deconz.1
                              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15442      399/deCONZ
                              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13837      747/dhcpcd
                              udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          13983      748/nmbd
                              udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          13982      748/nmbd
                              udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          13966      748/nmbd
                              udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          13985      748/nmbd
                              udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          13984      748/nmbd
                              udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          13967      748/nmbd
                              udp        0      0 0.0.0.0:51768           0.0.0.0:*                           108        2043       393/avahi-daemon: r
                              udp6       0      0 :::5353                 :::*                                108        2042       393/avahi-daemon: r
                              udp6       0      0 :::48542                :::*                                108        2044       393/avahi-daemon: r
                              udp6       0      0 :::1900                 :::*                                1001       17623      1083/io.deconz.1
                              udp6       0      0 :::1900                 :::*                                1001       17622      1083/io.deconz.1
                              udp6       0      0 :::546                  :::*                                0          13850      747/dhcpcd
                              2023-12-18 14:25:19.593  - error: fritzdect.0 (1008) no response part in returned error message
                              2023-12-18 14:25:19.593  - error: fritzdect.0 (1008) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
                              2023-12-18 14:25:19.594  - error: fritzdect.0 (1008) login not possible, check user and permissions
                              2023-12-18 14:25:20.809  - info: host.raspberrypismarthome instance system.adapter.web.0 started with pid 1023
                              2023-12-18 14:25:24.559  - info: web.0 (1023) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
                              2023-12-18 14:25:25.051  - info: web.0 (1023) socket.io server listening on port 8082
                              2023-12-18 14:25:25.059  - info: web.0 (1023) http server listening on port 8082
                              2023-12-18 14:25:27.639  - info: vis.0 (1059) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
                              2023-12-18 14:25:28.699  - info: vis.0 (1059) Terminated (NO_ERROR): Without reason
                              2023-12-18 14:25:28.750  - info: host.raspberrypismarthome instance system.adapter.deconz.1 started with pid 1083
                              2023-12-18 14:25:29.290  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
                              2023-12-18 14:25:31.643  - info: alexa2.0 (939) Subscribing to states...
                              2023-12-18 14:25:31.653  - info: alexa2.0 (939) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
                              2023-12-18 14:25:31.867  - info: deconz.1 (1083) starting. Version 1.3.23 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.19.0, js-controller: 5.0.17
                              2023-12-18 14:25:32.013  - info: deconz.1 (1083) deConz Version: 2.24.2; API version: 1.16.0
                              2023-12-18 14:25:32.791  - info: host.raspberrypismarthome instance system.adapter.info.0 started with pid 1107
                              2023-12-18 14:25:33.549  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                              2023-12-18 14:25:36.750  - info: host.raspberrypismarthome instance system.adapter.iot.0 started with pid 1133
                              2023-12-18 14:25:38.276  - info: info.0 (1107) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.17
                              2023-12-18 14:25:38.565  - info: info.0 (1107) Reading/updating systemdata.
                              2023-12-18 14:25:40.091  - info: info.0 (1107) cpu Temp res = {"main":46.738,"cores":[],"max":46.738,"socket":[],"chipset":null}
                              2023-12-18 14:25:40.203  - info: alexa2.0 (939) Initialization Done ...
                              2023-12-18 14:25:41.632  - info: iot.0 (1133) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
                              2023-12-18 14:25:41.783  - info: iot.0 (1133) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                              2023-12-18 14:25:42.623  - info: iot.0 (1133) Connection changed: connect "s_glebe66_googlemail_com"
                              Beste Grüße,
                              Stephan
                                Ja / Nein.
                                Stephan1966
                                Ja / Nein.
                                ist erledigt
                                Beste Grüße,
                                Stephan
                                  Stephan1966
                                  Nachfolgend der aktuelle Stand, ich glaube es ist noch nicht OK oder?
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm64
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : armhf
                                   12:52:33 up 22:28,  1 user,  load average: 0.15, 0.03, 0.01
                                  CPU threads: 4
                                  Current issues:
                                                 Local time: Tue 2023-12-19 12:52:33 CET
                                             Universal time: Tue 2023-12-19 11:52:33 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  pi
                                  /home/pi
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:            3.8G        816M        2.4G        1.0M        588M        2.9G
                                  Swap:            99M          0B         99M
                                  Total:          3.9G        816M        2.5G
                                           3794 M total memory
                                            816 M used memory
                                            895 M active memory
                                            367 M inactive memory
                                           2389 M free memory
                                             89 M buffer memory
                                            499 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  /dev/root      ext4       29G  6.2G   22G  23% /
                                  /var:
                                  1.9G    /var/
                                  1.1G    /var/log
                                  658M    /var/cache
                                  396M    /opt/iobroker/backups/
                                  329M    /opt/iobroker/iobroker-data/
                                  24M     /opt/iobroker/iobroker-data/objects.jsonl
                                  USB-Devices by-id:
                                  /usr/bin/npm            10.2.3
                                  /usr/bin/npx            10.2.3
                                  nodejs:
                                    Version table:
                                  Errors in npm tree:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.12.0
                                  javascript:     7.1.6
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        2065
                                  States:         1761
                                  Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                  Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                  Pending Updates: 0
                                  2023-12-19 00:22:45.291  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                  2023-12-19 02:00:19.204  - error: backitup.0 (974) [iobroker/ftp] Error: Access to home directory not allowed.
                                  2023-12-19 02:00:19.217  - error: backitup.0 (974) [iobroker] Error: Access to home directory not allowed.
                                  2023-12-19 02:24:51.981  - info: admin.0 (676) Request actual repository...
                                  2023-12-19 02:24:52.654  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                  2023-12-19 02:24:58.132  - info: admin.0 (676) Repository received successfully.
                                  2023-12-19 02:25:47.031  - info: info.0 (1107) Reading/updating systemdata.
                                  2023-12-19 02:25:47.675  - info: info.0 (1107) cpu Temp res = {"main":41.868,"cores":[],"max":41.868,"socket":[],"chipset":null}
                                  2023-12-19 03:18:22.246  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                                  2023-12-19 03:18:23.687  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                  2023-12-19 05:56:01.651  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                                  2023-12-19 05:56:03.105  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                  2023-12-19 08:44:32.929  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
                                  2023-12-19 08:44:56.919  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
                                  2023-12-19 08:44:59.590  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                  2023-12-19 08:46:40.957  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
                                  2023-12-19 08:59:55.063  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                                  2023-12-19 08:59:56.533  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                  2023-12-19 10:14:57.017  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
                                  2023-12-19 10:14:59.037  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                  2023-12-19 10:15:37.424  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
                                  2023-12-19 10:21:47.849  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
                                  2023-12-19 10:22:19.303  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
                                  2023-12-19 12:41:01.489  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                                  2023-12-19 12:41:02.953  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                  Beste Grüße,
                                  Stephan
                                  • S Stephan1966
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm64
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : armhf
                                    CPU threads: 4
                                    Current issues:
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    pi
                                    /home/pi
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Swap:            99M          0B         99M
                                             3794 M total memory
                                              816 M used memory
                                              895 M active memory
                                             2389 M free memory
                                               89 M buffer memory
                                              499 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    /var:
                                    1.9G    /var/
                                    1.1G    /var/log
                                    658M    /var/cache
                                    USB-Devices by-id:
                                    /usr/bin/npm            10.2.3
                                    /usr/bin/npx            10.2.3
                                    nodejs:
                                      Version table:
                                    Errors in npm tree:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          6.12.0
                                    javascript:     7.1.6
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        2065
                                    States:         1761
                                    Pending Updates: 0
                                    Versuch mal, den deconz neuzuinstallieren.
                                    sudo apt install --reinstall deconz
                                      Stephan1966
                                      Beste Grüße,
                                      Stephan
                                      • S Stephan1966
                                        @stephan1966
                                        Sollte egal sein. Vielleicht den deconz-Adapter danach mal neustarten.
                                          @stephan1966
                                          Stephan1966
                                          Hier das Ergebnis, sieht soweit ich das beurteilen kann noch genauso aus!
                                          Skript v.2023-10-10
                                          *** BASE SYSTEM ***
                                                   Icon name: computer
                                                Architecture: arm64
                                          Docker          : false
                                          Kernel          : aarch64
                                          Userland        : armhf
                                           14:56:47 up 2 min,  1 user,  load average: 1.21, 0.66, 0.26
                                          CPU threads: 4
                                          Current issues:
                                                         Local time: Tue 2023-12-19 14:56:47 CET
                                                     Universal time: Tue 2023-12-19 13:56:47 UTC
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          pi
                                          /home/pi
                                          X-Server:       false
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Mem:            3.8G        651M        2.8G        1.0M        302M        3.1G
                                          Swap:            99M          0B         99M
                                          Total:          3.9G        651M        2.9G
                                                   3794 M total memory
                                                    651 M used memory
                                                    725 M active memory
                                                    118 M inactive memory
                                                   2840 M free memory
                                                     41 M buffer memory
                                                    260 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          Raspberry only:
                                          oom events: 0
                                          *** FILESYSTEM ***
                                          /dev/root      ext4       29G  6.2G   22G  22% /
                                          [Tue Dec 19 14:54:28 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
                                          [Tue Dec 19 14:54:29 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                          [Tue Dec 19 14:54:29 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                          [Tue Dec 19 14:54:32 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                          /var:
                                          1.9G    /var/
                                          1.1G    /var/log
                                          658M    /var/cache
                                          310M    /opt/iobroker/iobroker-data/
                                          8.6M    /opt/iobroker/iobroker-data/objects.jsonl
                                          USB-Devices by-id:
                                          /usr/bin/npm            10.2.3
                                          /usr/bin/npx            10.2.3
                                          nodejs:
                                            Version table:
                                          Errors in npm tree:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          admin:          6.12.0
                                          javascript:     7.1.6
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        2065
                                          States:         1769
                                          Pending Updates: 0
                                          tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          14205      816/smbd
                                          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       13015      400/deCONZ
                                          tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          14206      816/smbd
                                          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       12989      400/deCONZ
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15042      537/sshd: /usr/sbin
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13070      501/iobroker.js-con
                                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12123      501/iobroker.js-con
                                          tcp6       0      0 :::445                  :::*                    LISTEN      0          14203      816/smbd
                                          tcp6       0      0 :::139                  :::*                    LISTEN      0          14204      816/smbd
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          15044      537/sshd: /usr/sbin
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13211      662/io.admin.0
                                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17527      1040/io.web.0
                                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       16822      1070/io.deconz.1
                                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15097      400/deCONZ
                                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12103      749/dhcpcd
                                          udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          14181      750/nmbd
                                          udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          14180      750/nmbd
                                          udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          14164      750/nmbd
                                          udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          14183      750/nmbd
                                          udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          14182      750/nmbd
                                          udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          14165      750/nmbd
                                          udp        0      0 0.0.0.0:41316           0.0.0.0:*                           108        14958      394/avahi-daemon: r
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14956      394/avahi-daemon: r
                                          udp6       0      0 :::1900                 :::*                                1001       16824      1070/io.deconz.1
                                          udp6       0      0 :::1900                 :::*                                1001       16823      1070/io.deconz.1
                                          udp6       0      0 :::45045                :::*                                108        14959      394/avahi-daemon: r
                                          udp6       0      0 :::546                  :::*                                0          13027      749/dhcpcd
                                          udp6       0      0 :::5353                 :::*                                108        14957      394/avahi-daemon: r
                                          2023-12-19 14:55:23.658  - error: fritzdect.0 (1025) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
                                          2023-12-19 14:55:23.658  - error: fritzdect.0 (1025) login not possible, check user and permissions
                                          2023-12-19 14:55:24.974  - info: host.raspberrypismarthome instance system.adapter.web.0 started with pid 1040
                                          2023-12-19 14:55:28.042  - info: web.0 (1040) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
                                          2023-12-19 14:55:28.584  - info: web.0 (1040) socket.io server listening on port 8082
                                          2023-12-19 14:55:28.603  - info: web.0 (1040) http server listening on port 8082
                                          2023-12-19 14:55:31.435  - info: vis.0 (1055) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
                                          2023-12-19 14:55:32.211  - info: vis.0 (1055) Terminated (NO_ERROR): Without reason
                                          2023-12-19 14:55:32.794  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
                                          2023-12-19 14:55:32.972  - info: host.raspberrypismarthome instance system.adapter.deconz.1 started with pid 1070
                                          2023-12-19 14:55:35.726  - info: deconz.1 (1070) starting. Version 1.3.23 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.19.0, js-controller: 5.0.17
                                          2023-12-19 14:55:35.883  - info: deconz.1 (1070) deConz Version: 2.24.2; API version: 1.16.0
                                          2023-12-19 14:55:36.496  - info: admin.0 (662) ==> Connected system.user.admin from ::ffff:192.168.178.59
                                          2023-12-19 14:55:38.641  - info: host.raspberrypismarthome instance system.adapter.info.0 started with pid 1086
                                          2023-12-19 14:55:41.025  - info: host.raspberrypismarthome instance system.adapter.iot.0 started with pid 1101
                                          2023-12-19 14:55:45.888  - info: info.0 (1086) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.17
                                          2023-12-19 14:55:46.253  - info: info.0 (1086) Reading/updating systemdata.
                                          2023-12-19 14:55:46.468  - info: iot.0 (1101) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
                                          2023-12-19 14:55:46.638  - info: iot.0 (1101) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                                          2023-12-19 14:55:47.531  - info: iot.0 (1101) Connection changed: connect "s_glebe66_googlemail_com"
                                          2023-12-19 14:55:47.731  - info: info.0 (1086) cpu Temp res = {"main":46.251,"cores":[],"max":46.251,"socket":[],"chipset":null}
                                          2023-12-19 14:55:49.207  - info: alexa2.0 (987) Subscribing to states...
                                          2023-12-19 14:55:49.216  - info: alexa2.0 (987) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
                                          2023-12-19 14:55:51.087  - info: alexa2.0 (987) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                          2023-12-19 14:55:55.552  - info: alexa2.0 (987) Initialization Done ...
                                          Beste Grüße,
                                          Stephan
