  4. [Gelöst] Update js-controller geht nicht
45 Beiträge 3 Kommentatoren 6.3k Aufrufe 3 Beobachtet
    @stephan1966
    Den ganzen langen Text...
    Stephan1966
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypismarthome
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : armhf
    Systemuptime and Load:
     13:39:16 up  2:19,  1 user,  load average: 0.18, 0.07, 0.09
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Mon 2023-12-18 13:39:16 CET
               Universal time: Mon 2023-12-18 12:39:16 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            3.8G        728M        1.5G        1.0M        1.6G        3.0G
    Swap:            99M          0B         99M
    Total:          3.9G        728M        1.6G
             3794 M total memory
              728 M used memory
              801 M active memory
             1225 M inactive memory
             1495 M free memory
              202 M buffer memory
             1367 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
      UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
    * deconz-init.service   loaded failed failed deCONZ: ZigBee gateway -- Initialisation
    * deconz-update.service loaded failed failed deCONZ: ZigBee gateway -- Update Service
    * deconz-wifi.service   loaded failed failed deCONZ: ZigBee gateway -- WIFI Service
    3 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       29G  6.1G   22G  22% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  1.8M  758M   1% /run
    /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Mon Dec 18 11:19:29 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Mon Dec 18 11:19:30 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Dec 18 11:19:30 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Mon Dec 18 11:19:32 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    1.9G    /var/
    1.1G    /var/log/journal/2db8461036a4455ab0afd36ad1c9f367
    1.1G    /var/log
    658M    /var/cache
    Archived and active journals take up 1.0G in the file system.
    /opt/iobroker/backups:
    393M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    295M    /opt/iobroker/iobroker-data/
    164M    /opt/iobroker/iobroker-data/files
    105M    /opt/iobroker/iobroker-data/backup-objects
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    43M     /opt/iobroker/iobroker-data/files/iot.admin
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    9.1M    /opt/iobroker/iobroker-data/objects.jsonl
    8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! invalid: @types/node@14.18.36 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-18T12_39_24_312Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.12.0
    javascript:     6.1.4
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypismarthome                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : raspberrypismarthome                     -  enabled
    + system.adapter.backitup.0               : backitup              : raspberrypismarthome                     -  enabled
    + system.adapter.deconz.1                 : deconz                : raspberrypismarthome                     -  enabled, port: 80
    + system.adapter.discovery.0              : discovery             : raspberrypismarthome                     -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : raspberrypismarthome                     -  enabled
    + system.adapter.info.0                   : info                  : raspberrypismarthome                     -  enabled
    + system.adapter.iot.0                    : iot                   : raspberrypismarthome                     -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypismarthome                     -  enabled
    + system.adapter.net-tools.0              : net-tools             : raspberrypismarthome                     -  enabled
    + system.adapter.ping.0                   : ping                  : raspberrypismarthome                     -  enabled
    + system.adapter.pushover.0               : pushover              : raspberrypismarthome                     -  enabled
    + system.adapter.tr-064.0                 : tr-064                : raspberrypismarthome                     -  enabled
      system.adapter.vis.0                    : vis                   : raspberrypismarthome                     -  enabled
    + system.adapter.web.0                    : web                   : raspberrypismarthome                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alexa2"       : 3.26.3   , installed 3.23.2 [Updatable]
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "deconz"       : 1.3.23   , installed 1.3.23
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "fritzdect"    : 2.5.9    , installed 2.2.6  [Updatable]
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.1.6    , installed 6.1.4  [Updatable]
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "zigbee"       : 1.8.24   , installed 1.8.10 [Updatable]
    Objects and States
    Objects:        2017
    States:         1715
    Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       48602      8219/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       50489      8219/iobroker.js-co
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          15069      831/smbd
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       11194      400/deCONZ
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          15070      831/smbd
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       12931      400/deCONZ
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14170      535/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       54627      9795/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       64933      12757/io.web.0
    tcp6       0      0 :::445                  :::*                    LISTEN      0          15067      831/smbd
    tcp6       0      0 :::139                  :::*                    LISTEN      0          15068      831/smbd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14172      535/sshd: /usr/sbin
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14033      392/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       58563      10450/io.deconz.1
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       14805      400/deCONZ
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14249      747/dhcpcd
    udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          16432      751/nmbd
    udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          16431      751/nmbd
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          16415      751/nmbd
    udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          16434      751/nmbd
    udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          16433      751/nmbd
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          16416      751/nmbd
    udp        0      0 0.0.0.0:45598           0.0.0.0:*                           108        14035      392/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        14034      392/avahi-daemon: r
    udp6       0      0 :::1900                 :::*                                1001       58565      10450/io.deconz.1
    udp6       0      0 :::1900                 :::*                                1001       58564      10450/io.deconz.1
    udp6       0      0 :::34833                :::*                                108        14036      392/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          14262      747/dhcpcd
    2023-12-18 12:32:44.197  - info: host.raspberrypismarthome iobroker upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/noSwipe.jpg widgets/swipe/img/noSwipe.jpg image/jpeg
    2023-12-18 12:32:44.210  - info: host.raspberrypismarthome iobroker upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout-shapes.js widgets/swipe/js/jquery.roundabout-shapes.js application/javascript
    2023-12-18 12:32:44.222  - info: host.raspberrypismarthome iobroker upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout.min.js widgets/swipe/js/jquery.roundabout.min.js application/javascript
    2023-12-18 12:32:44.236  - info: host.raspberrypismarthome iobroker upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.touchSwipe.min.js widgets/swipe/js/jquery.touchSwipe.min.js application/javascript
    2023-12-18 12:32:44.248  - info: host.raspberrypismarthome iobroker upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe.html widgets/swipe.html text/html
    2023-12-18 12:32:44.260  - info: host.raspberrypismarthome iobroker upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/jquery.sliderTabs.js widgets/tabs/jquery.sliderTabs.js application/javascript
    2023-12-18 12:32:44.277  - info: host.raspberrypismarthome iobroker upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicator.png widgets/tabs/styles/images/indicator.png image/png
    2023-12-18 12:32:44.289  - info: host.raspberrypismarthome iobroker upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicatorActive.png widgets/tabs/styles/images/indicatorActive.png image/png
    2023-12-18 12:32:44.301  - info: host.raspberrypismarthome iobroker upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftArrow.png widgets/tabs/styles/images/leftArrow.png image/png
    2023-12-18 12:32:44.313  - info: host.raspberrypismarthome iobroker upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftPanelArrow.png widgets/tabs/styles/images/leftPanelArrow.png image/png
    2023-12-18 12:32:44.325  - info: host.raspberrypismarthome iobroker upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightArrow.png widgets/tabs/styles/images/rightArrow.png image/png
    2023-12-18 12:32:44.340  - info: host.raspberrypismarthome iobroker upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightPanelArrow.png widgets/tabs/styles/images/rightPanelArrow.png image/png
    2023-12-18 12:32:44.353  - info: host.raspberrypismarthome iobroker upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.css widgets/tabs/styles/jquery.sliderTabs.css text/css
    2023-12-18 12:32:44.365  - info: host.raspberrypismarthome iobroker upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.min.css widgets/tabs/styles/jquery.sliderTabs.min.css text/css
    2023-12-18 12:32:44.378  - info: host.raspberrypismarthome iobroker upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs.html widgets/tabs.html text/html
    2023-12-18 12:32:44.390  - info: host.raspberrypismarthome iobroker upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/dev.html widgets/todo/dev.html text/html
    2023-12-18 12:32:44.403  - info: host.raspberrypismarthome iobroker upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/homematic.html widgets/todo/homematic.html text/html
    2023-12-18 12:32:44.415  - info: host.raspberrypismarthome iobroker upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/special.html widgets/todo/special.html text/html
    2023-12-18 12:32:44.430  - info: host.raspberrypismarthome iobroker upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/weather.html widgets/todo/weather.html text/html
    2023-12-18 12:32:44.484  - info: host.raspberrypismarthome iobroker Update "system.adapter.vis.0"
    2023-12-18 12:32:44.541  - info: host.raspberrypismarthome iobroker upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
    2023-12-18 12:32:45.614  - info: host.raspberrypismarthome iobroker exit 0
    2023-12-18 12:32:46.690  - info: vis.0 (12885) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
    2023-12-18 12:32:47.358  - info: vis.0 (12885) Terminated (NO_ERROR): Without reason
    2023-12-18 12:32:47.928  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
    iob diag has finished.
    Beste Grüße,
    Stephan
    Iobroker Nutzer seit 2022
    • S Stephan1966
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : armhf
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               3794 M total memory
                728 M used memory
                801 M active memory
               1495 M free memory
                202 M buffer memory
               1367 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      1.9G    /var/
      1.1G    /var/log
      658M    /var/cache
      USB-Devices by-id:
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.12.0
      javascript:     6.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        2017
      States:         1715
      Pending Updates: 0
      @stephan1966
      sudo systemctl set-default multi-user.target
      Was ist denn mit dem 'deconz' los?
      würde mir auch zu denken geben. Renkt sich aber ggf. nach einem Neustart ein.
      Schmeiß die Adapter-Updates drauf.
      iob upgrade all
        @stephan1966
        iob upgrade all
        Stephan1966
        === Mark text until here for copying ===
        pi@raspberrypismarthome:~ $ iob stop
        pi@raspberrypismarthome:~ $ iob ugrade all
        iobroker [command]
        Commands:
        iobroker setup Setup ioBroker
        iobroker start [all|<adapter>.<instance>|<adapter>] Starts the js-controller or a specified adapter instance or all instances of an adapter
        iobroker stop [<adapter>.<instance>|<adapter>] stops the js-controller or a specified adapter instance or all instances of an adapter
        iobroker restart [<adapter>.<instance>|<adapter>] Restarts js-controller or a specified adapter instance or all instances of an adapter [aliases: r]
        iobroker debug <adapter>[.<instance>] Starts a Node.js debugging session for the adapter instance
        iobroker info Shows the host info
        iobroker logs [<adapter>] Monitor log
        iobroker add <adapter> [desiredNumber] Add instance of adapter [aliases: a]
        iobroker install <adapter> Installs a specified adapter [aliases: i]
        iobroker rebuild [<module>] Rebuild all native modules or path
        iobroker url <url> [<name>] Install adapter from specified url, e.g. GitHub
        iobroker del <adapter> Remove adapter and all instances from this host [aliases: delete]
        iobroker del <adapter>.<instance> Remove adapter instance [aliases: delete]
        iobroker update [<repositoryUrl>] Update repository and list adapters
        iobroker upgrade Upgrade management
        iobroker upload [all|<adapter>] Upload management [aliases: u]
        iobroker object Object management [aliases: o]
        iobroker state State management [aliases: s]
        iobroker message <adapter>[.instance] <command> [<message>] Send message to adapter instance/s
        iobroker list <type> [<filter>] List all entries, like objects
        iobroker chmod <mode> <file> Change file rights
        iobroker chown <user> <group> <file> Change file ownership
        iobroker touch <file> Touch file
        iobroker rm <file> Remove file
        iobroker file File management
        iobroker user User commands
        iobroker group group management
        iobroker host <hostname> Set host to given hostname
        iobroker set <adapter>.<instance> Change settings of adapter config
        iobroker license <license.file or license.text> Update license by given file
        iobroker cert Certificate management
        iobroker clean <yes> Clears all objects and states
        iobroker backup Create backup
        iobroker restore <backup name or path> Restore a specified backup
        iobroker validate <backup name or path> Validate a specified backup
        iobroker status [all|<adapter>.<instance>] Status of ioBroker or adapter instance [aliases: isrun]
        iobroker repo [<name>] Show repo information
        iobroker uuid Show uuid of the installation [aliases: id]
        iobroker unsetup Reset license, installation secret and language
        iobroker fix Execute the installation fixer script, this updates your ioBroker installation
        iobroker nodejs-update [<major-version>] Upgrade the Node.JS installation to the current LTS
        iobroker multihost Multihost management
        iobroker compact compact group management
        iobroker plugin Plugin management
        iobroker vendor <passphrase> [<vendor.json>] Update the vendor information using given passphrase
        iobroker version [<adapter>] Show version of js-controller or specified adapter [aliases: v]
        Options:
        --help Show help [boolean]
        Beste Grüße,
        Stephan
        • S Stephan1966
          iobroker [command]
          Commands:
          Options:
          @stephan1966
          Das muss ja auch
          iob upgrade all
          heißen.
            @stephan1966
            Das muss ja auch
            iob upgrade all
            heißen.
            Stephan1966
            Habe ich doch vor 3 Minuten gemacht!
            Beste Grüße,
            Stephan
            • S Stephan1966
              @stephan1966
              Du hast das falsch geschrieben und eine entsprechende Rückmeldung erhalten, aber kein upgrade durchgeführt.
                @stephan1966
                Stephan1966
                Wer lesen kann ist klar im Vorteil 👍
                Beste Grüße,
                Stephan
                  @stephan1966
                  Stephan1966
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : armhf
                   14:07:31 up  2:48,  1 user,  load average: 1.44, 0.89, 0.48
                  CPU threads: 4
                  Current issues:
                                 Local time: Mon 2023-12-18 14:07:32 CET
                             Universal time: Mon 2023-12-18 13:07:32 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  /home/pi
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            3.8G        606M        1.3G        1.0M        1.9G        3.1G
                  Swap:            99M          0B         99M
                  Total:          3.9G        606M        1.4G
                           3794 M total memory
                            606 M used memory
                            688 M active memory
                           1517 M inactive memory
                           1321 M free memory
                            207 M buffer memory
                           1658 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /var:
                  1.9G    /var/
                  1.1G    /var/log
                  658M    /var/cache
                  313M    /opt/iobroker/iobroker-data/
                  180M    /opt/iobroker/iobroker-data/files
                  67M     /opt/iobroker/iobroker-data/files/javascript.admin
                  48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                  9.7M    /opt/iobroker/iobroker-data/objects.jsonl
                  USB-Devices by-id:
                  /usr/bin/npm            10.2.3
                  /usr/bin/npx            10.2.3
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.12.0
                  javascript:     7.1.6
                  Adapter State
                  + system.adapter.alexa2.0                 : alexa2                : raspberrypismarthome                     -  enabled
                  + instance is alive
                  Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
                  Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
                  Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                  Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
                  Objects and States
                  Objects:        2050
                  States:         1756
                  Pending Updates: 0
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       87946      15594/iobroker.js-c
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       87939      15594/iobroker.js-c
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       90447      15612/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       90049      15972/io.web.0
                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       91665      16022/io.deconz.1
                  udp6       0      0 :::1900                 :::*                                1001       91667      16022/io.deconz.1
                  udp6       0      0 :::1900                 :::*                                1001       91666      16022/io.deconz.1
                  2023-12-18 14:07:42.363  - error: fritzdect.0 (15942) no response part in returned error message
                  2023-12-18 14:07:42.363  - error: fritzdect.0 (15942) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
                  2023-12-18 14:07:42.364  - error: fritzdect.0 (15942) login not possible, check user and permissions
                  2023-12-18 14:07:43.505  - info: host.raspberrypismarthome instance system.adapter.web.0 started with pid 15972
                  2023-12-18 14:07:47.252  - info: web.0 (15972) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
                  2023-12-18 14:07:47.570  - info: web.0 (15972) socket.io server listening on port 8082
                  2023-12-18 14:07:47.582  - info: web.0 (15972) http server listening on port 8082
                  2023-12-18 14:07:50.378  - info: vis.0 (15997) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
                  2023-12-18 14:07:51.083  - info: vis.0 (15997) Terminated (NO_ERROR): Without reason
                  2023-12-18 14:07:51.489  - info: host.raspberrypismarthome instance system.adapter.deconz.1 started with pid 16022
                  2023-12-18 14:07:51.682  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
                  2023-12-18 14:07:54.669  - info: deconz.1 (16022) starting. Version 1.3.23 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.19.0, js-controller: 5.0.17
                  2023-12-18 14:07:54.881  - info: deconz.1 (16022) deConz Version: 2.24.2; API version: 1.16.0
                  2023-12-18 14:07:55.488  - info: host.raspberrypismarthome instance system.adapter.info.0 started with pid 16046
                  2023-12-18 14:07:59.511  - info: host.raspberrypismarthome instance system.adapter.iot.0 started with pid 16090
                  2023-12-18 14:08:01.351  - info: info.0 (16046) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.17
                  2023-12-18 14:08:01.666  - info: info.0 (16046) Reading/updating systemdata.
                  2023-12-18 14:08:04.164  - info: info.0 (16046) cpu Temp res = {"main":47.225,"cores":[],"max":47.225,"socket":[],"chipset":null}
                  2023-12-18 14:08:05.265  - info: iot.0 (16090) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
                  2023-12-18 14:08:05.531  - info: iot.0 (16090) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                  2023-12-18 14:08:06.392  - info: iot.0 (16090) Connection changed: connect "s_glebe66_googlemail_com"
                  2023-12-18 14:08:06.642  - info: alexa2.0 (15845) Subscribing to states...
                  2023-12-18 14:08:06.650  - info: alexa2.0 (15845) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
                  2023-12-18 14:08:08.370  - info: alexa2.0 (15845) Alexa-Push-Connection (macDms = true) established. Disable Polling
                  2023-12-18 14:08:15.917  - info: alexa2.0 (15845) Initialization Done ...
                  Beste Grüße,
                  Stephan
                  • S Stephan1966
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : armhf
                    CPU threads: 4
                    Current issues:
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:            99M          0B         99M
                             3794 M total memory
                              606 M used memory
                              688 M active memory
                             1321 M free memory
                              207 M buffer memory
                             1658 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /var:
                    1.9G    /var/
                    1.1G    /var/log
                    658M    /var/cache
                    USB-Devices by-id:
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.12.0
                    javascript:     7.1.6
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        2050
                    States:         1756
                    Pending Updates: 0
                    @stephan1966
                    Hast du das boot target gesetzt?
                    sudo reboot
                    Was ist denn nun mit deconz los?
                      @stephan1966
                      sudo reboot
                      Stephan1966
                      @thomas-braun sagte in Update js-controller geht nicht:
                      sudo reboot
                      Muss ich diese beiden Befehle eingeben?
                      ioBroker vorher anhalten?
                      Beste Grüße,
                      Stephan
                      • S Stephan1966
                        sudo reboot
                        @stephan1966 sagte in Update js-controller geht nicht:
                        Ja / Nein.
                          @stephan1966
                          Gib mal die Langfassung von
                          iob diag
                          bekannt.
                          Stephan1966
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : armhf
                           14:25:37 up 1 min,  1 user,  load average: 1.42, 0.45, 0.16
                          CPU threads: 4
                          Current issues:
                                         Local time: Mon 2023-12-18 14:25:37 CET
                                     Universal time: Mon 2023-12-18 13:25:37 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          /home/pi
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          Boot Target:    multi-user.target
                          *** MEMORY ***
                          Mem:            3.8G        698M        2.8G        1.0M        293M        3.0G
                          Swap:            99M          0B         99M
                          Total:          3.9G        698M        2.9G
                                   3794 M total memory
                                    698 M used memory
                                    767 M active memory
                                    119 M inactive memory
                                   2802 M free memory
                                     40 M buffer memory
                                    252 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          [Mon Dec 18 14:24:23 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
                          [Mon Dec 18 14:24:24 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                          [Mon Dec 18 14:24:24 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                          [Mon Dec 18 14:24:27 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                          /var:
                          1.9G    /var/
                          1.1G    /var/log
                          658M    /var/cache
                          315M    /opt/iobroker/iobroker-data/
                          11M     /opt/iobroker/iobroker-data/objects.jsonl
                          USB-Devices by-id:
                          /usr/bin/npm            10.2.3
                          /usr/bin/npx            10.2.3
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.12.0
                          javascript:     7.1.6
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        2065
                          States:         1769
                          Pending Updates: 0
                          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       13818      399/deCONZ
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13783      523/sshd: /usr/sbin
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12213      504/iobroker.js-con
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14838      504/iobroker.js-con
                          tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          14054      753/smbd
                          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       12175      399/deCONZ
                          tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          14053      753/smbd
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15694      676/io.admin.0
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17553      1023/io.web.0
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          13785      523/sshd: /usr/sbin
                          tcp6       0      0 :::139                  :::*                    LISTEN      0          14052      753/smbd
                          tcp6       0      0 :::445                  :::*                    LISTEN      0          14051      753/smbd
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        2041       393/avahi-daemon: r
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       17621      1083/io.deconz.1
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15442      399/deCONZ
                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13837      747/dhcpcd
                          udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          13983      748/nmbd
                          udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          13982      748/nmbd
                          udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          13966      748/nmbd
                          udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          13985      748/nmbd
                          udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          13984      748/nmbd
                          udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          13967      748/nmbd
                          udp        0      0 0.0.0.0:51768           0.0.0.0:*                           108        2043       393/avahi-daemon: r
                          udp6       0      0 :::5353                 :::*                                108        2042       393/avahi-daemon: r
                          udp6       0      0 :::48542                :::*                                108        2044       393/avahi-daemon: r
                          udp6       0      0 :::1900                 :::*                                1001       17623      1083/io.deconz.1
                          udp6       0      0 :::1900                 :::*                                1001       17622      1083/io.deconz.1
                          udp6       0      0 :::546                  :::*                                0          13850      747/dhcpcd
                          2023-12-18 14:25:19.593  - error: fritzdect.0 (1008) no response part in returned error message
                          2023-12-18 14:25:19.593  - error: fritzdect.0 (1008) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
                          2023-12-18 14:25:19.594  - error: fritzdect.0 (1008) login not possible, check user and permissions
                          2023-12-18 14:25:20.809  - info: host.raspberrypismarthome instance system.adapter.web.0 started with pid 1023
                          2023-12-18 14:25:24.559  - info: web.0 (1023) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
                          2023-12-18 14:25:25.051  - info: web.0 (1023) socket.io server listening on port 8082
                          2023-12-18 14:25:25.059  - info: web.0 (1023) http server listening on port 8082
                          2023-12-18 14:25:27.639  - info: vis.0 (1059) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
                          2023-12-18 14:25:28.699  - info: vis.0 (1059) Terminated (NO_ERROR): Without reason
                          2023-12-18 14:25:28.750  - info: host.raspberrypismarthome instance system.adapter.deconz.1 started with pid 1083
                          2023-12-18 14:25:29.290  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
                          2023-12-18 14:25:31.643  - info: alexa2.0 (939) Subscribing to states...
                          2023-12-18 14:25:31.653  - info: alexa2.0 (939) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
                          2023-12-18 14:25:31.867  - info: deconz.1 (1083) starting. Version 1.3.23 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.19.0, js-controller: 5.0.17
                          2023-12-18 14:25:32.013  - info: deconz.1 (1083) deConz Version: 2.24.2; API version: 1.16.0
                          2023-12-18 14:25:32.791  - info: host.raspberrypismarthome instance system.adapter.info.0 started with pid 1107
                          2023-12-18 14:25:33.549  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                          2023-12-18 14:25:36.750  - info: host.raspberrypismarthome instance system.adapter.iot.0 started with pid 1133
                          2023-12-18 14:25:38.276  - info: info.0 (1107) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.17
                          2023-12-18 14:25:38.565  - info: info.0 (1107) Reading/updating systemdata.
                          2023-12-18 14:25:40.091  - info: info.0 (1107) cpu Temp res = {"main":46.738,"cores":[],"max":46.738,"socket":[],"chipset":null}
                          2023-12-18 14:25:40.203  - info: alexa2.0 (939) Initialization Done ...
                          2023-12-18 14:25:41.632  - info: iot.0 (1133) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
                          2023-12-18 14:25:41.783  - info: iot.0 (1133) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                          2023-12-18 14:25:42.623  - info: iot.0 (1133) Connection changed: connect "s_glebe66_googlemail_com"
                          Beste Grüße,
                          Stephan
                            Ja / Nein.
                            Stephan1966
                            Ja / Nein.
                            ist erledigt
                            Beste Grüße,
                            Stephan
                              Stephan1966
                              Nachfolgend der aktuelle Stand, ich glaube es ist noch nicht OK oder?
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : armhf
                               12:52:33 up 22:28,  1 user,  load average: 0.15, 0.03, 0.01
                              CPU threads: 4
                              Current issues:
                                             Local time: Tue 2023-12-19 12:52:33 CET
                                         Universal time: Tue 2023-12-19 11:52:33 UTC
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              /home/pi
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            3.8G        816M        2.4G        1.0M        588M        2.9G
                              Swap:            99M          0B         99M
                              Total:          3.9G        816M        2.5G
                                       3794 M total memory
                                        816 M used memory
                                        895 M active memory
                                        367 M inactive memory
                                       2389 M free memory
                                         89 M buffer memory
                                        499 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              /dev/root      ext4       29G  6.2G   22G  23% /
                              /var:
                              1.9G    /var/
                              1.1G    /var/log
                              658M    /var/cache
                              396M    /opt/iobroker/backups/
                              329M    /opt/iobroker/iobroker-data/
                              24M     /opt/iobroker/iobroker-data/objects.jsonl
                              USB-Devices by-id:
                              /usr/bin/npm            10.2.3
                              /usr/bin/npx            10.2.3
                              nodejs:
                                Version table:
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.12.0
                              javascript:     7.1.6
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        2065
                              States:         1761
                              Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                              Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                              Pending Updates: 0
                              2023-12-19 00:22:45.291  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                              2023-12-19 02:00:19.204  - error: backitup.0 (974) [iobroker/ftp] Error: Access to home directory not allowed.
                              2023-12-19 02:00:19.217  - error: backitup.0 (974) [iobroker] Error: Access to home directory not allowed.
                              2023-12-19 02:24:51.981  - info: admin.0 (676) Request actual repository...
                              2023-12-19 02:24:52.654  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                              2023-12-19 02:24:58.132  - info: admin.0 (676) Repository received successfully.
                              2023-12-19 02:25:47.031  - info: info.0 (1107) Reading/updating systemdata.
                              2023-12-19 02:25:47.675  - info: info.0 (1107) cpu Temp res = {"main":41.868,"cores":[],"max":41.868,"socket":[],"chipset":null}
                              2023-12-19 03:18:22.246  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                              2023-12-19 03:18:23.687  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                              2023-12-19 05:56:01.651  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                              2023-12-19 05:56:03.105  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                              2023-12-19 08:44:32.929  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
                              2023-12-19 08:44:56.919  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
                              2023-12-19 08:44:59.590  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                              2023-12-19 08:46:40.957  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
                              2023-12-19 08:59:55.063  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                              2023-12-19 08:59:56.533  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                              2023-12-19 10:14:57.017  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
                              2023-12-19 10:14:59.037  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                              2023-12-19 10:15:37.424  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
                              2023-12-19 10:21:47.849  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
                              2023-12-19 10:22:19.303  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
                              2023-12-19 12:41:01.489  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                              2023-12-19 12:41:02.953  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                              Beste Grüße,
                              Stephan
                              • S Stephan1966
                                Skript v.2023-10-10
                                *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : armhf
                                CPU threads: 4
                                Current issues:
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                pi
                                /home/pi
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Swap:            99M          0B         99M
                                         3794 M total memory
                                          816 M used memory
                                          895 M active memory
                                         2389 M free memory
                                           89 M buffer memory
                                          499 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                Raspberry only:
                                oom events: 0
                                *** FILESYSTEM ***
                                /var:
                                1.9G    /var/
                                1.1G    /var/log
                                658M    /var/cache
                                USB-Devices by-id:
                                /usr/bin/npm            10.2.3
                                /usr/bin/npx            10.2.3
                                nodejs:
                                  Version table:
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.12.0
                                javascript:     7.1.6
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        2065
                                States:         1761
                                Pending Updates: 0
                                Versuch mal, den deconz neuzuinstallieren.
                                sudo apt install --reinstall deconz
                                  Stephan1966
                                  Beste Grüße,
                                  Stephan
                                  • S Stephan1966
                                    @stephan1966
                                    Sollte egal sein. Vielleicht den deconz-Adapter danach mal neustarten.
                                      @stephan1966
                                      Stephan1966
                                      Hier das Ergebnis, sieht soweit ich das beurteilen kann noch genauso aus!
                                      Skript v.2023-10-10
                                      *** BASE SYSTEM ***
                                               Icon name: computer
                                            Architecture: arm64
                                      Docker          : false
                                      Kernel          : aarch64
                                      Userland        : armhf
                                       14:56:47 up 2 min,  1 user,  load average: 1.21, 0.66, 0.26
                                      CPU threads: 4
                                      Current issues:
                                                     Local time: Tue 2023-12-19 14:56:47 CET
                                                 Universal time: Tue 2023-12-19 13:56:47 UTC
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      pi
                                      /home/pi
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Mem:            3.8G        651M        2.8G        1.0M        302M        3.1G
                                      Swap:            99M          0B         99M
                                      Total:          3.9G        651M        2.9G
                                               3794 M total memory
                                                651 M used memory
                                                725 M active memory
                                                118 M inactive memory
                                               2840 M free memory
                                                 41 M buffer memory
                                                260 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      *** FILESYSTEM ***
                                      /dev/root      ext4       29G  6.2G   22G  22% /
                                      [Tue Dec 19 14:54:28 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
                                      [Tue Dec 19 14:54:29 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                      [Tue Dec 19 14:54:29 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                      [Tue Dec 19 14:54:32 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                      /var:
                                      1.9G    /var/
                                      1.1G    /var/log
                                      658M    /var/cache
                                      310M    /opt/iobroker/iobroker-data/
                                      8.6M    /opt/iobroker/iobroker-data/objects.jsonl
                                      USB-Devices by-id:
                                      /usr/bin/npm            10.2.3
                                      /usr/bin/npx            10.2.3
                                      nodejs:
                                        Version table:
                                      Errors in npm tree:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          6.12.0
                                      javascript:     7.1.6
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        2065
                                      States:         1769
                                      Pending Updates: 0
                                      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          14205      816/smbd
                                      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       13015      400/deCONZ
                                      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          14206      816/smbd
                                      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       12989      400/deCONZ
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15042      537/sshd: /usr/sbin
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13070      501/iobroker.js-con
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12123      501/iobroker.js-con
                                      tcp6       0      0 :::445                  :::*                    LISTEN      0          14203      816/smbd
                                      tcp6       0      0 :::139                  :::*                    LISTEN      0          14204      816/smbd
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          15044      537/sshd: /usr/sbin
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13211      662/io.admin.0
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17527      1040/io.web.0
                                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       16822      1070/io.deconz.1
                                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15097      400/deCONZ
                                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12103      749/dhcpcd
                                      udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          14181      750/nmbd
                                      udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          14180      750/nmbd
                                      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          14164      750/nmbd
                                      udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          14183      750/nmbd
                                      udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          14182      750/nmbd
                                      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          14165      750/nmbd
                                      udp        0      0 0.0.0.0:41316           0.0.0.0:*                           108        14958      394/avahi-daemon: r
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14956      394/avahi-daemon: r
                                      udp6       0      0 :::1900                 :::*                                1001       16824      1070/io.deconz.1
                                      udp6       0      0 :::1900                 :::*                                1001       16823      1070/io.deconz.1
                                      udp6       0      0 :::45045                :::*                                108        14959      394/avahi-daemon: r
                                      udp6       0      0 :::546                  :::*                                0          13027      749/dhcpcd
                                      udp6       0      0 :::5353                 :::*                                108        14957      394/avahi-daemon: r
                                      2023-12-19 14:55:23.658  - error: fritzdect.0 (1025) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
                                      2023-12-19 14:55:23.658  - error: fritzdect.0 (1025) login not possible, check user and permissions
                                      2023-12-19 14:55:24.974  - info: host.raspberrypismarthome instance system.adapter.web.0 started with pid 1040
                                      2023-12-19 14:55:28.042  - info: web.0 (1040) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
                                      2023-12-19 14:55:28.584  - info: web.0 (1040) socket.io server listening on port 8082
                                      2023-12-19 14:55:28.603  - info: web.0 (1040) http server listening on port 8082
                                      2023-12-19 14:55:31.435  - info: vis.0 (1055) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
                                      2023-12-19 14:55:32.211  - info: vis.0 (1055) Terminated (NO_ERROR): Without reason
                                      2023-12-19 14:55:32.794  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
                                      2023-12-19 14:55:32.972  - info: host.raspberrypismarthome instance system.adapter.deconz.1 started with pid 1070
                                      2023-12-19 14:55:35.726  - info: deconz.1 (1070) starting. Version 1.3.23 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.19.0, js-controller: 5.0.17
                                      2023-12-19 14:55:35.883  - info: deconz.1 (1070) deConz Version: 2.24.2; API version: 1.16.0
                                      2023-12-19 14:55:36.496  - info: admin.0 (662) ==> Connected system.user.admin from ::ffff:192.168.178.59
                                      2023-12-19 14:55:38.641  - info: host.raspberrypismarthome instance system.adapter.info.0 started with pid 1086
                                      2023-12-19 14:55:41.025  - info: host.raspberrypismarthome instance system.adapter.iot.0 started with pid 1101
                                      2023-12-19 14:55:45.888  - info: info.0 (1086) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.17
                                      2023-12-19 14:55:46.253  - info: info.0 (1086) Reading/updating systemdata.
                                      2023-12-19 14:55:46.468  - info: iot.0 (1101) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
                                      2023-12-19 14:55:46.638  - info: iot.0 (1101) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                                      2023-12-19 14:55:47.531  - info: iot.0 (1101) Connection changed: connect "s_glebe66_googlemail_com"
                                      2023-12-19 14:55:47.731  - info: info.0 (1086) cpu Temp res = {"main":46.251,"cores":[],"max":46.251,"socket":[],"chipset":null}
                                      2023-12-19 14:55:49.207  - info: alexa2.0 (987) Subscribing to states...
                                      2023-12-19 14:55:49.216  - info: alexa2.0 (987) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
                                      2023-12-19 14:55:51.087  - info: alexa2.0 (987) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                      2023-12-19 14:55:55.552  - info: alexa2.0 (987) Initialization Done ...
                                      Beste Grüße,
                                      Stephan
                                      • S Stephan1966
                                        Skript v.2023-10-10
                                        *** BASE SYSTEM ***
                                                 Icon name: computer
                                              Architecture: arm64
                                        Docker          : false
                                        Kernel          : aarch64
                                        Userland        : armhf
                                        CPU threads: 4
                                        Current issues:
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        pi
                                        /home/pi
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Swap:            99M          0B         99M
                                                 3794 M total memory
                                                  651 M used memory
                                                  725 M active memory
                                                 2840 M free memory
                                                   41 M buffer memory
                                                  260 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        Raspberry only:
                                        oom events: 0
                                        *** FILESYSTEM ***
                                        /var:
                                        1.9G    /var/
                                        1.1G    /var/log
                                        658M    /var/cache
                                        USB-Devices by-id:
                                        /usr/bin/npm            10.2.3
                                        /usr/bin/npx            10.2.3
                                        nodejs:
                                          Version table:
                                        Errors in npm tree:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin:          6.12.0
                                        javascript:     7.1.6
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        2065
                                        States:         1769
                                        Pending Updates: 0
                                        deconz-init.service
                                        Dann musst du mal schauen, was da klemmen könnte.
                                        systemctl status deconz*
                                          deconz-init.service
                                          Stephan1966
                                          Ergebnis meiner Eingabe!
                                          pi@raspberrypismarthome:~ $ systemctl status deconz*
                                          Unit deconz-latest-beta.deb.service could not be found.
                                          Beste Grüße,
                                          Stephan
