  4. [Gelöst] Update js-controller geht nicht
45 Beiträge 3 Kommentatoren 6.3k Aufrufe 3 Beobachtet
  • S Stephan1966
    ioBroker vorher anhalten?
    @stephan1966
    Sollte egal sein. Vielleicht den deconz-Adapter danach mal neustarten.
      @stephan1966
      Stephan1966
      Hier das Ergebnis, sieht soweit ich das beurteilen kann noch genauso aus!
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: raspberrypismarthome
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.2
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : armhf
      Systemuptime and Load:
       14:56:47 up 2 min,  1 user,  load average: 1.21, 0.66, 0.26
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Tue 2023-12-19 14:56:47 CET
                 Universal time: Tue 2023-12-19 13:56:47 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            3.8G        651M        2.8G        1.0M        302M        3.1G
      Swap:            99M          0B         99M
      Total:          3.9G        651M        2.9G
               3794 M total memory
                651 M used memory
                725 M active memory
                118 M inactive memory
               2840 M free memory
                 41 M buffer memory
                260 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
        UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
      * deconz-init.service   loaded failed failed deCONZ: ZigBee gateway -- Initialisation
      * deconz-update.service loaded failed failed deCONZ: ZigBee gateway -- Update Service
      * deconz-wifi.service   loaded failed failed deCONZ: ZigBee gateway -- WIFI Service
      3 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       29G  6.2G   22G  22% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     759M  1.8M  758M   1% /run
      /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Tue Dec 19 14:54:28 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Tue Dec 19 14:54:29 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Tue Dec 19 14:54:29 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Tue Dec 19 14:54:32 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      1.9G    /var/
      1.1G    /var/log/journal/2db8461036a4455ab0afd36ad1c9f367
      1.1G    /var/log
      658M    /var/cache
      Archived and active journals take up 1.0G in the file system.
      /opt/iobroker/backups:
      396M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      310M    /opt/iobroker/iobroker-data/
      180M    /opt/iobroker/iobroker-data/files
      105M    /opt/iobroker/iobroker-data/backup-objects
      67M     /opt/iobroker/iobroker-data/files/javascript.admin
      48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      8.6M    /opt/iobroker/iobroker-data/objects.jsonl
      8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
      8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
      USB-Devices by-id:
      find: '/dev/serial/by-id/': No such file or directory
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.12.0
      javascript:     7.1.6
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypismarthome                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : raspberrypismarthome                     -  enabled
      + system.adapter.backitup.0               : backitup              : raspberrypismarthome                     -  enabled
      + system.adapter.deconz.1                 : deconz                : raspberrypismarthome                     -  enabled, port: 80
      + system.adapter.discovery.0              : discovery             : raspberrypismarthome                     -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypismarthome                     -  enabled
      + system.adapter.info.0                   : info                  : raspberrypismarthome                     -  enabled
      + system.adapter.iot.0                    : iot                   : raspberrypismarthome                     -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypismarthome                     -  enabled
      + system.adapter.net-tools.0              : net-tools             : raspberrypismarthome                     -  enabled
      + system.adapter.ping.0                   : ping                  : raspberrypismarthome                     -  enabled
      + system.adapter.pushover.0               : pushover              : raspberrypismarthome                     -  enabled
      + system.adapter.tr-064.0                 : tr-064                : raspberrypismarthome                     -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypismarthome                     -  enabled
      + system.adapter.web.0                    : web                   : raspberrypismarthome                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
      Adapter    "backitup"     : 2.8.7    , installed 2.8.7
      Adapter    "deconz"       : 1.3.23   , installed 1.3.23
      Adapter    "discovery"    : 4.2.0    , installed 4.2.0
      Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
      Adapter    "info"         : 2.0.0    , installed 2.0.0
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
      Adapter    "pushover"     : 3.0.3    , installed 3.0.3
      Adapter    "socketio"     : 6.6.0    , installed 6.6.0
      Adapter    "vis"          : 1.5.4    , installed 1.5.4
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
      Objects and States
      Objects:        2065
      States:         1769
      Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          14205      816/smbd
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       13015      400/deCONZ
      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          14206      816/smbd
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       12989      400/deCONZ
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15042      537/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13070      501/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12123      501/iobroker.js-con
      tcp6       0      0 :::445                  :::*                    LISTEN      0          14203      816/smbd
      tcp6       0      0 :::139                  :::*                    LISTEN      0          14204      816/smbd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15044      537/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13211      662/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17527      1040/io.web.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       16822      1070/io.deconz.1
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15097      400/deCONZ
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12103      749/dhcpcd
      udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          14181      750/nmbd
      udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          14180      750/nmbd
      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          14164      750/nmbd
      udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          14183      750/nmbd
      udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          14182      750/nmbd
      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          14165      750/nmbd
      udp        0      0 0.0.0.0:41316           0.0.0.0:*                           108        14958      394/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14956      394/avahi-daemon: r
      udp6       0      0 :::1900                 :::*                                1001       16824      1070/io.deconz.1
      udp6       0      0 :::1900                 :::*                                1001       16823      1070/io.deconz.1
      udp6       0      0 :::45045                :::*                                108        14959      394/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          13027      749/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        14957      394/avahi-daemon: r
      2023-12-19 14:55:23.658  - error: fritzdect.0 (1025) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
      2023-12-19 14:55:23.658  - error: fritzdect.0 (1025) login not possible, check user and permissions
      2023-12-19 14:55:24.974  - info: host.raspberrypismarthome instance system.adapter.web.0 started with pid 1040
      2023-12-19 14:55:28.042  - info: web.0 (1040) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
      2023-12-19 14:55:28.584  - info: web.0 (1040) socket.io server listening on port 8082
      2023-12-19 14:55:28.603  - info: web.0 (1040) http server listening on port 8082
      2023-12-19 14:55:31.435  - info: vis.0 (1055) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
      2023-12-19 14:55:32.211  - info: vis.0 (1055) Terminated (NO_ERROR): Without reason
      2023-12-19 14:55:32.794  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
      2023-12-19 14:55:32.972  - info: host.raspberrypismarthome instance system.adapter.deconz.1 started with pid 1070
      2023-12-19 14:55:35.726  - info: deconz.1 (1070) starting. Version 1.3.23 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.19.0, js-controller: 5.0.17
      2023-12-19 14:55:35.883  - info: deconz.1 (1070) deConz Version: 2.24.2; API version: 1.16.0
      2023-12-19 14:55:36.496  - info: admin.0 (662) ==> Connected system.user.admin from ::ffff:192.168.178.59
      2023-12-19 14:55:38.641  - info: host.raspberrypismarthome instance system.adapter.info.0 started with pid 1086
      2023-12-19 14:55:41.025  - info: host.raspberrypismarthome instance system.adapter.iot.0 started with pid 1101
      2023-12-19 14:55:45.888  - info: info.0 (1086) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.17
      2023-12-19 14:55:46.253  - info: info.0 (1086) Reading/updating systemdata.
      2023-12-19 14:55:46.468  - info: iot.0 (1101) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
      2023-12-19 14:55:46.638  - info: iot.0 (1101) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      2023-12-19 14:55:47.531  - info: iot.0 (1101) Connection changed: connect "s_glebe66_googlemail_com"
      2023-12-19 14:55:47.731  - info: info.0 (1086) cpu Temp res = {"main":46.251,"cores":[],"max":46.251,"socket":[],"chipset":null}
      2023-12-19 14:55:49.207  - info: alexa2.0 (987) Subscribing to states...
      2023-12-19 14:55:49.216  - info: alexa2.0 (987) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
      2023-12-19 14:55:51.087  - info: alexa2.0 (987) Alexa-Push-Connection (macDms = true) established. Disable Polling
      2023-12-19 14:55:55.552  - info: alexa2.0 (987) Initialization Done ...
      iob diag has finished.
      Beste Grüße,
      Stephan
      Iobroker Nutzer seit 2022
      • S Stephan1966
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : armhf
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M          0B         99M
                 3794 M total memory
                  651 M used memory
                  725 M active memory
                 2840 M free memory
                   41 M buffer memory
                  260 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        1.9G    /var/
        1.1G    /var/log
        658M    /var/cache
        USB-Devices by-id:
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.12.0
        javascript:     7.1.6
        Adapter State
        + instance is alive
        Objects and States
        Objects:        2065
        States:         1769
        Pending Updates: 0
        @stephan1966 sagte in Update js-controller geht nicht:
        deconz-init.service
        Dann musst du mal schauen, was da klemmen könnte.
        systemctl status deconz*
          deconz-init.service
          Stephan1966
          @thomas-braun sagte in Update js-controller geht nicht:
          Ergebnis meiner Eingabe!
          pi@raspberrypismarthome:~ $ systemctl status deconz*
          Unit deconz-latest-beta.deb.service could not be found.
          Beste Grüße,
          Stephan
          • S Stephan1966
            @stephan1966
            Mal mit beta-Zeuch herumgespielt?
            apt policy deconz*
            sagt?
              @stephan1966
              apt policy deconz*
              sagt?
              Stephan1966
              Kann mich nicht erinnern, hier das Ergebnis:
              pi@raspberrypismarthome:~ $ apt policy deconz*
              N: Paket deconz-latest-beta.deb kann nicht gefunden werden.
              N: Mittels des Musters »deconz-latest-beta.deb« konnte kein Paket gefunden werden.
              Beste Grüße,
              Stephan
              • S Stephan1966
                @stephan1966
                ls -lAh
                  @stephan1966
                  ls -lAh
                  Stephan1966
                  ls -lAh
                  Ergebnis:
                  pi@raspberrypismarthome:~ $ ls -lAh
                  insgesamt 6,6M
                  drwxr-xr-x 2 root root 4,0K 10. Jan 2023 backup
                  -rw------- 1 pi pi 3,9K 19. Dez 14:54 .bash_history
                  -rw-r--r-- 1 pi pi 220 30. Okt 2021 .bash_logout
                  -rw-r--r-- 1 pi pi 3,7K 18. Dez 12:12 .bashrc
                  drwxr-xr-x 4 pi pi 4,0K 2. Dez 2021 .cache
                  drwx------ 3 pi pi 4,0K 2. Dez 2021 .config
                  -rw-r--r-- 1 pi pi 161K 20. Aug 2021 deCONZ_ConBeeII_0x26720700.bin.GCF
                  -rw-r--r-- 1 pi pi 6,4M 30. Apr 2022 deconz-latest-beta.deb
                  drwxr-xr-x 2 pi pi 4,0K 2. Dez 2021 .iobroker
                  drwxr-xr-x 3 pi pi 4,0K 21. Dez 2021 .local
                  drwxr-xr-x 5 pi pi 4,0K 2. Dez 2021 .npm
                  -rw------- 1 pi pi 36 2. Dez 2021 .npmrc
                  -rw-r--r-- 1 pi pi 807 30. Okt 2021 .profile
                  Beste Grüße,
                  Stephan
                  • S Stephan1966
                    ls -lAh
                    Ergebnis:
                    insgesamt 6,6M
                    @stephan1966
                    Das muss da weg:
                    rm deconz-latest-beta.deb
                    Und bitte Auszüge aus der Konsole immer in Code Tags setzen. Liest sich besser.
                      @stephan1966
                      Das muss da weg:
                      Stephan1966
                      Hier das Ergebnis nachdem ich rm deconz-latest-beta.deb ausgeführt habe: ```
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : armhf
                       09:35:28 up 2 days, 18:41,  1 user,  load average: 0.07, 0.19, 0.22
                      CPU threads: 4
                      Current issues:
                                     Local time: Fri 2023-12-22 09:35:28 CET
                                 Universal time: Fri 2023-12-22 08:35:28 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      /home/pi
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            3.8G        803M        2.4G        1.0M        625M        2.9G
                      Swap:            99M          0B         99M
                      Total:          3.9G        803M        2.5G
                               3794 M total memory
                                803 M used memory
                                883 M active memory
                                401 M inactive memory
                               2364 M free memory
                                 90 M buffer memory
                                535 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /dev/root      ext4       29G  6.2G   22G  23% /
                      /var:
                      1.9G    /var/
                      1.1G    /var/log
                      658M    /var/cache
                      403M    /opt/iobroker/backups/
                      333M    /opt/iobroker/iobroker-data/
                      106M    /opt/iobroker/iobroker-data/backup-objects
                      28M     /opt/iobroker/iobroker-data/objects.jsonl
                      USB-Devices by-id:
                      /usr/bin/npm            10.2.3
                      /usr/bin/npx            10.2.3
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.12.0
                      javascript:     7.1.6
                      Adapter State
                      + instance is alive
                      Adapter    "pushover"     : 3.0.6    , installed 3.0.6
                      Objects and States
                      Objects:        2065
                      States:         1761
                      Pending Updates: 0
                      2023-12-22 09:15:38.510  - info: host.raspberrypismarthome stopInstance system.adapter.pushover.0 send kill signal
                      2023-12-22 09:15:38.738  - info: host.raspberrypismarthome iobroker upload [14] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/blockly.js blockly.js application/javascript
                      2023-12-22 09:15:38.760  - info: host.raspberrypismarthome iobroker upload [13] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/de/translations.json i18n/de/translations.json application/json
                      2023-12-22 09:15:38.771  - info: host.raspberrypismarthome iobroker upload [12] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/en/translations.json i18n/en/translations.json application/json
                      2023-12-22 09:15:38.781  - info: host.raspberrypismarthome iobroker upload [11] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/es/translations.json i18n/es/translations.json application/json
                      2023-12-22 09:15:38.792  - info: host.raspberrypismarthome iobroker upload [10] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                      2023-12-22 09:15:38.803  - info: host.raspberrypismarthome iobroker upload [9] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/it/translations.json i18n/it/translations.json application/json
                      2023-12-22 09:15:38.815  - info: host.raspberrypismarthome iobroker upload [8] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                      2023-12-22 09:15:38.825  - info: host.raspberrypismarthome iobroker upload [7] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                      2023-12-22 09:15:38.839  - info: host.raspberrypismarthome iobroker upload [6] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                      2023-12-22 09:15:38.852  - info: host.raspberrypismarthome iobroker upload [5] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                      2023-12-22 09:15:38.864  - info: host.raspberrypismarthome iobroker upload [4] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                      2023-12-22 09:15:38.874  - info: host.raspberrypismarthome iobroker upload [3] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/index_m.html index_m.html text/html
                      2023-12-22 09:15:38.884  - info: host.raspberrypismarthome iobroker upload [2] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/jsonConfig.json jsonConfig.json application/json
                      2023-12-22 09:15:38.895  - info: host.raspberrypismarthome iobroker upload [1] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/pushover.png pushover.png image/png
                      2023-12-22 09:15:38.905  - info: host.raspberrypismarthome iobroker upload [0] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/words.js words.js application/javascript
                      2023-12-22 09:15:38.976  - info: pushover.0 (829) terminating
                      2023-12-22 09:15:38.978  - info: pushover.0 (829) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2023-12-22 09:15:39.514  - info: host.raspberrypismarthome stopInstance system.adapter.pushover.0 killing pid 829
                      2023-12-22 09:15:39.611  - info: host.raspberrypismarthome instance system.adapter.pushover.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2023-12-22 09:15:39.947  - info: host.raspberrypismarthome iobroker exit 0
                      2023-12-22 09:15:41.597  - info: host.raspberrypismarthome instance system.adapter.pushover.0 started with pid 17654
                      2023-12-22 09:15:44.251  - info: pushover.0 (17654) starting. Version 3.0.6 in /opt/iobroker/node_modules/iobroker.pushover, node: v18.19.0, js-controller: 5.0.17
                      2023-12-22 09:18:40.465  - info: admin.0 (662) ==> Connected system.user.admin from ::ffff:192.168.178.59
                      2023-12-22 09:18:43.110  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                      Beste Grüße,
                      Stephan
                      • S Stephan1966
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : armhf
                        CPU threads: 4
                        Current issues:
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        /home/pi
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:            99M          0B         99M
                                 3794 M total memory
                                  803 M used memory
                                  883 M active memory
                                 2364 M free memory
                                   90 M buffer memory
                                  535 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /var:
                        1.9G    /var/
                        1.1G    /var/log
                        658M    /var/cache
                        USB-Devices by-id:
                        /usr/bin/npm            10.2.3
                        /usr/bin/npx            10.2.3
                        nodejs:
                          Version table:
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.12.0
                        javascript:     7.1.6
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        2065
                        States:         1761
                        Pending Updates: 0
                        @stephan1966
                        wirft jetzt was raus?
                        S 2 Antworten Letzte Antwort
                          @stephan1966
                          Stephan1966
                          @thomas-braun ```
                          Copy text starting here:
                                                  v.2023-10-10
                                   Icon name: computer
                                Architecture: arm64
                          Kernel:                 aarch64
                          Userland:               armhf
                          Timezone:               Europe/Berlin (CET, +0100)
                          User-ID:                1000
                          X-Server:               false
                          Pending OS-Updates:     0
                          Pending iob updates:    0
                          Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                                  /usr/bin/npm            10.2.3
                                                  /usr/bin/npx            10.2.3
                          Recommended versions are nodejs 18.19.0 and npm 10.2.3
                          MEMORY:
                          Mem:            3.8G        848M        2.3G        1.0M        626M        2.9G
                          Swap:            99M          0B         99M
                          Total:          3.9G        848M        2.4G
                          Active iob-Instances:   15
                          ioBroker Core:          js-controller           5.0.17
                                                  admin                   6.12.0
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                2065
                          States:                 1761
                          Size of iob-Database:
                          6.3M    /opt/iobroker/iobroker-data/objects.json.migrated
                          6.3M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                          6.8M    /opt/iobroker/iobroker-data/states.jsonl
                          488K    /opt/iobroker/iobroker-data/states.json.migrated
                          488K    /opt/iobroker/iobroker-data/states.json.bak.migrated
                          0       /opt/iobroker/iobroker-data/states.json.broken
                          Beste Grüße,
                          Stephan
                            @stephan1966
                            Stephan1966
                            @thomas-braun ```
                            === Mark text until here for copying ===
                            ● deconz-update.service - deCONZ: ZigBee gateway -- Update Service
                                 Loaded: loaded (/lib/systemd/system/deconz-update.service; disabled; vendor preset: enabled)
                                 Active: failed (Result: exit-code) since Tue 2023-12-19 14:54:22 CET; 2 days ago
                                Process: 542 ExecStart=/usr/bin/deCONZ-update2.sh (code=exited, status=203/EXEC)
                               Main PID: 542 (code=exited, status=203/EXEC)
                                    CPU: 3ms
                            Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-update.service: Scheduled restart job, restart counter is at 5.
                            Dez 19 14:54:22 raspberrypismarthome systemd[1]: Stopped deCONZ: ZigBee gateway -- Update Service.
                            Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-update.service: Start request repeated too quickly.
                            Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-update.service: Failed with result 'exit-code'.
                            Dez 19 14:54:22 raspberrypismarthome systemd[1]: Failed to start deCONZ: ZigBee gateway -- Update Service.
                            ● deconz-init.service - deCONZ: ZigBee gateway -- Initialisation
                                 Loaded: loaded (/lib/systemd/system/deconz-init.service; disabled; vendor preset: enabled)
                                 Active: failed (Result: exit-code) since Tue 2023-12-19 14:54:21 CET; 2 days ago
                                Process: 397 ExecStart=/usr/bin/deCONZ-init.sh (code=exited, status=203/EXEC)
                               Main PID: 397 (code=exited, status=203/EXEC)
                                    CPU: 4ms
                            Dez 19 14:54:21 raspberrypismarthome systemd[1]: Starting deCONZ: ZigBee gateway -- Initialisation...
                            Dez 19 14:54:21 raspberrypismarthome systemd[397]: deconz-init.service: Failed to locate executable /usr/bin/deCONZ-init.sh: No such file or directory
                            Dez 19 14:54:21 raspberrypismarthome systemd[397]: deconz-init.service: Failed at step EXEC spawning /usr/bin/deCONZ-init.sh: No such file or directory
                            Dez 19 14:54:21 raspberrypismarthome systemd[1]: deconz-init.service: Main process exited, code=exited, status=203/EXEC
                            Dez 19 14:54:21 raspberrypismarthome systemd[1]: deconz-init.service: Failed with result 'exit-code'.
                            Dez 19 14:54:21 raspberrypismarthome systemd[1]: Failed to start deCONZ: ZigBee gateway -- Initialisation.
                            ● deconz-wifi.service - deCONZ: ZigBee gateway -- WIFI Service
                                 Loaded: loaded (/lib/systemd/system/deconz-wifi.service; enabled; vendor preset: enabled)
                                Process: 547 ExecStart=/usr/bin/deCONZ-WIFI2.sh (code=exited, status=203/EXEC)
                               Main PID: 547 (code=exited, status=203/EXEC)
                                    CPU: 2ms
                            Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-wifi.service: Scheduled restart job, restart counter is at 5.
                            Dez 19 14:54:22 raspberrypismarthome systemd[1]: Stopped deCONZ: ZigBee gateway -- WIFI Service.
                            Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-wifi.service: Start request repeated too quickly.
                            Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-wifi.service: Failed with result 'exit-code'.
                            Dez 19 14:54:22 raspberrypismarthome systemd[1]: Failed to start deCONZ: ZigBee gateway -- WIFI Service.
                            ● deconz.service - deCONZ: ZigBee gateway -- REST API
                                 Loaded: loaded (/lib/systemd/system/deconz.service; enabled; vendor preset: enabled)
                                 Active: active (running) since Tue 2023-12-19 14:54:21 CET; 2 days ago
                               Main PID: 400 (deCONZ)
                                  Tasks: 6 (limit: 3933)
                                    CPU: 55min 35.525s
                                 CGroup: /system.slice/deconz.service
                                         └─400 /usr/bin/deCONZ -platform minimal --http-port=80
                            Dez 19 14:54:21 raspberrypismarthome systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
                            Dez 19 14:54:22 raspberrypismarthome deCONZ[400]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-pi'
                            Dez 19 14:54:23 raspberrypismarthome deCONZ[400]: libpng warning: iCCP: known incorrect sRGB profile
                            Dez 19 14:54:25 raspberrypismarthome deCONZ[400]: This plugin does not support propagateSizeHints()
                            Dez 19 14:54:28 raspberrypismarthome deCONZ[400]: This plugin does not support propagateSizeHints()
                            Beste Grüße,
                            Stephan
                            • S Stephan1966
                              @thomas-braun ```
                                      CPU: 3ms
                                      CPU: 4ms
                                      CPU: 2ms
                                      CPU: 55min 35.525s
                              ls -lAh /usr/bin/deCONZ-WIFI2.sh
                              ls -lAh /usr/bin/deCONZ-update2.sh
                                Stephan1966
                                pi@raspberrypismarthome:~ $ ls -lAh /usr/bin/deCONZ-WIFI2.sh
                                ls: Zugriff auf '/usr/bin/deCONZ-WIFI2.sh' nicht möglich: Datei oder Verzeichnis nicht gefunden
                                pi@raspberrypismarthome:~ $ ls -lAh /usr/bin/deCONZ-update2.sh
                                ls: Zugriff auf '/usr/bin/deCONZ-update2.sh' nicht möglich: Datei oder Verzeichnis nicht gefunden
                                Beste Grüße,
                                Stephan
                                • S Stephan1966
                                  @stephan1966
                                  Das ist dann auch der Grund, warum der Service failed.
                                  Ich hab aber kein deconz laufen, keine Ahnung wo der Eintrag für die Services überhaupt herkommt.
                                    @stephan1966
                                    Stephan1966
                                    Es scheint ja bis auf eine Lampe bei mir alles zu funktionieren, ob die Lampe damit zusammenhängt bekomme ich ja vielleicht noch heraus!
                                    Danke für den Super-Support 👍
                                    Beste Grüße,
                                    Stephan
