  4. [Gelöst] Update js-controller geht nicht
45 Beiträge 3 Kommentatoren 6.3k Aufrufe 3 Beobachtet
  • S Stephan1966
    @thomas-braun sagte in Update js-controller geht nicht:
    Was ist denn mit dem 'deconz' los?
    Nachfolgend der aktuelle Stand, ich glaube es ist noch nicht OK oder?
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypismarthome
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : armhf
    Systemuptime and Load:
     12:52:33 up 22:28,  1 user,  load average: 0.15, 0.03, 0.01
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Tue 2023-12-19 12:52:33 CET
               Universal time: Tue 2023-12-19 11:52:33 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            3.8G        816M        2.4G        1.0M        588M        2.9G
    Swap:            99M          0B         99M
    Total:          3.9G        816M        2.5G
             3794 M total memory
              816 M used memory
              895 M active memory
              367 M inactive memory
             2389 M free memory
               89 M buffer memory
              499 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
      UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
    * deconz-init.service   loaded failed failed deCONZ: ZigBee gateway -- Initialisation
    * deconz-update.service loaded failed failed deCONZ: ZigBee gateway -- Update Service
    * deconz-wifi.service   loaded failed failed deCONZ: ZigBee gateway -- WIFI Service
    3 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       29G  6.2G   22G  23% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  1.8M  758M   1% /run
    /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Mon Dec 18 14:24:23 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Mon Dec 18 14:24:24 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Dec 18 14:24:24 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Mon Dec 18 14:24:27 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    1.9G    /var/
    1.1G    /var/log/journal/2db8461036a4455ab0afd36ad1c9f367
    1.1G    /var/log
    658M    /var/cache
    Archived and active journals take up 1.0G in the file system.
    /opt/iobroker/backups:
    396M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    329M    /opt/iobroker/iobroker-data/
    180M    /opt/iobroker/iobroker-data/files
    105M    /opt/iobroker/iobroker-data/backup-objects
    67M     /opt/iobroker/iobroker-data/files/javascript.admin
    48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    24M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.12.0
    javascript:     7.1.6
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypismarthome                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : raspberrypismarthome                     -  enabled
    + system.adapter.backitup.0               : backitup              : raspberrypismarthome                     -  enabled
    + system.adapter.deconz.1                 : deconz                : raspberrypismarthome                     -  enabled, port: 80
    + system.adapter.discovery.0              : discovery             : raspberrypismarthome                     -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : raspberrypismarthome                     -  enabled
    + system.adapter.info.0                   : info                  : raspberrypismarthome                     -  enabled
    + system.adapter.iot.0                    : iot                   : raspberrypismarthome                     -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypismarthome                     -  enabled
    + system.adapter.net-tools.0              : net-tools             : raspberrypismarthome                     -  enabled
    + system.adapter.ping.0                   : ping                  : raspberrypismarthome                     -  enabled
    + system.adapter.pushover.0               : pushover              : raspberrypismarthome                     -  enabled
    + system.adapter.tr-064.0                 : tr-064                : raspberrypismarthome                     -  enabled
      system.adapter.vis.0                    : vis                   : raspberrypismarthome                     -  enabled
    + system.adapter.web.0                    : web                   : raspberrypismarthome                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "deconz"       : 1.3.23   , installed 1.3.23
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
    Objects and States
    Objects:        2065
    States:         1761
    Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       13818      399/deCONZ
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13783      523/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12213      504/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14838      504/iobroker.js-con
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          14054      753/smbd
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       12175      399/deCONZ
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          14053      753/smbd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15694      676/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17553      1023/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13785      523/sshd: /usr/sbin
    tcp6       0      0 :::139                  :::*                    LISTEN      0          14052      753/smbd
    tcp6       0      0 :::445                  :::*                    LISTEN      0          14051      753/smbd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        2041       393/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       17621      1083/io.deconz.1
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15442      399/deCONZ
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13837      747/dhcpcd
    udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          13983      748/nmbd
    udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          13982      748/nmbd
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          13966      748/nmbd
    udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          13985      748/nmbd
    udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          13984      748/nmbd
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          13967      748/nmbd
    udp        0      0 0.0.0.0:51768           0.0.0.0:*                           108        2043       393/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        2042       393/avahi-daemon: r
    udp6       0      0 :::48542                :::*                                108        2044       393/avahi-daemon: r
    udp6       0      0 :::1900                 :::*                                1001       17623      1083/io.deconz.1
    udp6       0      0 :::1900                 :::*                                1001       17622      1083/io.deconz.1
    udp6       0      0 :::546                  :::*                                0          13850      747/dhcpcd
    2023-12-19 00:22:45.291  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
    2023-12-19 02:00:19.204  - error: backitup.0 (974) [iobroker/ftp] Error: Access to home directory not allowed.
    2023-12-19 02:00:19.217  - error: backitup.0 (974) [iobroker] Error: Access to home directory not allowed.
    2023-12-19 02:24:51.981  - info: admin.0 (676) Request actual repository...
    2023-12-19 02:24:52.654  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2023-12-19 02:24:58.132  - info: admin.0 (676) Repository received successfully.
    2023-12-19 02:25:47.031  - info: info.0 (1107) Reading/updating systemdata.
    2023-12-19 02:25:47.675  - info: info.0 (1107) cpu Temp res = {"main":41.868,"cores":[],"max":41.868,"socket":[],"chipset":null}
    2023-12-19 03:18:22.246  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
    2023-12-19 03:18:23.687  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
    2023-12-19 05:56:01.651  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
    2023-12-19 05:56:03.105  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
    2023-12-19 08:44:32.929  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
    2023-12-19 08:44:56.919  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
    2023-12-19 08:44:59.590  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2023-12-19 08:46:40.957  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
    2023-12-19 08:59:55.063  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
    2023-12-19 08:59:56.533  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
    2023-12-19 10:14:57.017  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
    2023-12-19 10:14:59.037  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2023-12-19 10:15:37.424  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
    2023-12-19 10:21:47.849  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
    2023-12-19 10:22:19.303  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
    2023-12-19 12:41:01.489  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
    2023-12-19 12:41:02.953  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
    iob diag has finished.
    @stephan1966 sagte in Update js-controller geht nicht:
    Versuch mal, den deconz neuzuinstallieren.
    sudo apt install --reinstall deconz
      Stephan1966
      ioBroker vorher anhalten?
      Beste Grüße,
      Stephan
      Iobroker Nutzer seit 2022
      • S Stephan1966
        @stephan1966
        Sollte egal sein. Vielleicht den deconz-Adapter danach mal neustarten.
          @stephan1966
          Stephan1966
          Hier das Ergebnis, sieht soweit ich das beurteilen kann noch genauso aus!
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
          Docker          : false
          Kernel          : aarch64
          Userland        : armhf
           14:56:47 up 2 min,  1 user,  load average: 1.21, 0.66, 0.26
          CPU threads: 4
          Current issues:
                         Local time: Tue 2023-12-19 14:56:47 CET
                     Universal time: Tue 2023-12-19 13:56:47 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            3.8G        651M        2.8G        1.0M        302M        3.1G
          Swap:            99M          0B         99M
          Total:          3.9G        651M        2.9G
                   3794 M total memory
                    651 M used memory
                    725 M active memory
                    118 M inactive memory
                   2840 M free memory
                     41 M buffer memory
                    260 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /dev/root      ext4       29G  6.2G   22G  22% /
          [Tue Dec 19 14:54:28 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Tue Dec 19 14:54:29 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Tue Dec 19 14:54:29 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Tue Dec 19 14:54:32 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          /var:
          1.9G    /var/
          1.1G    /var/log
          658M    /var/cache
          310M    /opt/iobroker/iobroker-data/
          8.6M    /opt/iobroker/iobroker-data/objects.jsonl
          USB-Devices by-id:
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.12.0
          javascript:     7.1.6
          Adapter State
          + instance is alive
          Objects and States
          Objects:        2065
          States:         1769
          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
          Pending Updates: 0
          tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          14205      816/smbd
          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       13015      400/deCONZ
          tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          14206      816/smbd
          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       12989      400/deCONZ
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15042      537/sshd: /usr/sbin
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13070      501/iobroker.js-con
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12123      501/iobroker.js-con
          tcp6       0      0 :::445                  :::*                    LISTEN      0          14203      816/smbd
          tcp6       0      0 :::139                  :::*                    LISTEN      0          14204      816/smbd
          tcp6       0      0 :::22                   :::*                    LISTEN      0          15044      537/sshd: /usr/sbin
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13211      662/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17527      1040/io.web.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       16822      1070/io.deconz.1
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15097      400/deCONZ
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12103      749/dhcpcd
          udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          14181      750/nmbd
          udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          14180      750/nmbd
          udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          14164      750/nmbd
          udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          14183      750/nmbd
          udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          14182      750/nmbd
          udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          14165      750/nmbd
          udp        0      0 0.0.0.0:41316           0.0.0.0:*                           108        14958      394/avahi-daemon: r
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14956      394/avahi-daemon: r
          udp6       0      0 :::1900                 :::*                                1001       16824      1070/io.deconz.1
          udp6       0      0 :::1900                 :::*                                1001       16823      1070/io.deconz.1
          udp6       0      0 :::45045                :::*                                108        14959      394/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          13027      749/dhcpcd
          udp6       0      0 :::5353                 :::*                                108        14957      394/avahi-daemon: r
          2023-12-19 14:55:23.658  - error: fritzdect.0 (1025) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
          2023-12-19 14:55:23.658  - error: fritzdect.0 (1025) login not possible, check user and permissions
          2023-12-19 14:55:24.974  - info: host.raspberrypismarthome instance system.adapter.web.0 started with pid 1040
          2023-12-19 14:55:28.042  - info: web.0 (1040) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
          2023-12-19 14:55:28.584  - info: web.0 (1040) socket.io server listening on port 8082
          2023-12-19 14:55:28.603  - info: web.0 (1040) http server listening on port 8082
          2023-12-19 14:55:31.435  - info: vis.0 (1055) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
          2023-12-19 14:55:32.211  - info: vis.0 (1055) Terminated (NO_ERROR): Without reason
          2023-12-19 14:55:32.794  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
          2023-12-19 14:55:32.972  - info: host.raspberrypismarthome instance system.adapter.deconz.1 started with pid 1070
          2023-12-19 14:55:35.726  - info: deconz.1 (1070) starting. Version 1.3.23 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.19.0, js-controller: 5.0.17
          2023-12-19 14:55:35.883  - info: deconz.1 (1070) deConz Version: 2.24.2; API version: 1.16.0
          2023-12-19 14:55:36.496  - info: admin.0 (662) ==> Connected system.user.admin from ::ffff:192.168.178.59
          2023-12-19 14:55:38.641  - info: host.raspberrypismarthome instance system.adapter.info.0 started with pid 1086
          2023-12-19 14:55:41.025  - info: host.raspberrypismarthome instance system.adapter.iot.0 started with pid 1101
          2023-12-19 14:55:45.888  - info: info.0 (1086) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.17
          2023-12-19 14:55:46.253  - info: info.0 (1086) Reading/updating systemdata.
          2023-12-19 14:55:46.468  - info: iot.0 (1101) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
          2023-12-19 14:55:46.638  - info: iot.0 (1101) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
          2023-12-19 14:55:47.531  - info: iot.0 (1101) Connection changed: connect "s_glebe66_googlemail_com"
          2023-12-19 14:55:47.731  - info: info.0 (1086) cpu Temp res = {"main":46.251,"cores":[],"max":46.251,"socket":[],"chipset":null}
          2023-12-19 14:55:49.207  - info: alexa2.0 (987) Subscribing to states...
          2023-12-19 14:55:49.216  - info: alexa2.0 (987) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
          2023-12-19 14:55:51.087  - info: alexa2.0 (987) Alexa-Push-Connection (macDms = true) established. Disable Polling
          2023-12-19 14:55:55.552  - info: alexa2.0 (987) Initialization Done ...
          Beste Grüße,
          Stephan
          • S Stephan1966
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
            Docker          : false
            Kernel          : aarch64
            Userland        : armhf
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:            99M          0B         99M
                     3794 M total memory
                      651 M used memory
                      725 M active memory
                     2840 M free memory
                       41 M buffer memory
                      260 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            1.9G    /var/
            1.1G    /var/log
            658M    /var/cache
            USB-Devices by-id:
            /usr/bin/npm            10.2.3
            /usr/bin/npx            10.2.3
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.12.0
            javascript:     7.1.6
            Adapter State
            + instance is alive
            Objects and States
            Objects:        2065
            States:         1769
            Pending Updates: 0
            deconz-init.service
            Dann musst du mal schauen, was da klemmen könnte.
            systemctl status deconz*
              deconz-init.service
              Stephan1966
              Ergebnis meiner Eingabe!
              pi@raspberrypismarthome:~ $ systemctl status deconz*
              Unit deconz-latest-beta.deb.service could not be found.
              Beste Grüße,
              Stephan
              • S Stephan1966
                @stephan1966
                Mal mit beta-Zeuch herumgespielt?
                apt policy deconz*
                sagt?
                  @stephan1966
                  apt policy deconz*
                  sagt?
                  Stephan1966
                  Kann mich nicht erinnern, hier das Ergebnis:
                  pi@raspberrypismarthome:~ $ apt policy deconz*
                  N: Paket deconz-latest-beta.deb kann nicht gefunden werden.
                  N: Mittels des Musters »deconz-latest-beta.deb« konnte kein Paket gefunden werden.
                  Beste Grüße,
                  Stephan
                  • S Stephan1966
                    @stephan1966
                    ls -lAh
                      @stephan1966
                      ls -lAh
                      Stephan1966
                      ls -lAh
                      Ergebnis:
                      pi@raspberrypismarthome:~ $ ls -lAh
                      insgesamt 6,6M
                      drwxr-xr-x 2 root root 4,0K 10. Jan 2023 backup
                      -rw------- 1 pi pi 3,9K 19. Dez 14:54 .bash_history
                      -rw-r--r-- 1 pi pi 220 30. Okt 2021 .bash_logout
                      -rw-r--r-- 1 pi pi 3,7K 18. Dez 12:12 .bashrc
                      drwxr-xr-x 4 pi pi 4,0K 2. Dez 2021 .cache
                      drwx------ 3 pi pi 4,0K 2. Dez 2021 .config
                      -rw-r--r-- 1 pi pi 161K 20. Aug 2021 deCONZ_ConBeeII_0x26720700.bin.GCF
                      -rw-r--r-- 1 pi pi 6,4M 30. Apr 2022 deconz-latest-beta.deb
                      drwxr-xr-x 2 pi pi 4,0K 2. Dez 2021 .iobroker
                      drwxr-xr-x 3 pi pi 4,0K 21. Dez 2021 .local
                      drwxr-xr-x 5 pi pi 4,0K 2. Dez 2021 .npm
                      -rw------- 1 pi pi 36 2. Dez 2021 .npmrc
                      -rw-r--r-- 1 pi pi 807 30. Okt 2021 .profile
                      Beste Grüße,
                      Stephan
                      • S Stephan1966
                        ls -lAh
                        Ergebnis:
                        insgesamt 6,6M
                        @stephan1966
                        Das muss da weg:
                        rm deconz-latest-beta.deb
                        Und bitte Auszüge aus der Konsole immer in Code Tags setzen. Liest sich besser.
                          @stephan1966
                          Das muss da weg:
                          Stephan1966
                          Hier das Ergebnis nachdem ich rm deconz-latest-beta.deb ausgeführt habe: ```
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : armhf
                           09:35:28 up 2 days, 18:41,  1 user,  load average: 0.07, 0.19, 0.22
                          CPU threads: 4
                          Current issues:
                                         Local time: Fri 2023-12-22 09:35:28 CET
                                     Universal time: Fri 2023-12-22 08:35:28 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          /home/pi
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            3.8G        803M        2.4G        1.0M        625M        2.9G
                          Swap:            99M          0B         99M
                          Total:          3.9G        803M        2.5G
                                   3794 M total memory
                                    803 M used memory
                                    883 M active memory
                                    401 M inactive memory
                                   2364 M free memory
                                     90 M buffer memory
                                    535 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /var:
                          1.9G    /var/
                          1.1G    /var/log
                          658M    /var/cache
                          403M    /opt/iobroker/backups/
                          333M    /opt/iobroker/iobroker-data/
                          106M    /opt/iobroker/iobroker-data/backup-objects
                          28M     /opt/iobroker/iobroker-data/objects.jsonl
                          USB-Devices by-id:
                          /usr/bin/npm            10.2.3
                          /usr/bin/npx            10.2.3
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.12.0
                          javascript:     7.1.6
                          Adapter State
                          + instance is alive
                          Adapter    "pushover"     : 3.0.6    , installed 3.0.6
                          Objects and States
                          Objects:        2065
                          States:         1761
                          Pending Updates: 0
                          2023-12-22 09:15:38.510  - info: host.raspberrypismarthome stopInstance system.adapter.pushover.0 send kill signal
                          2023-12-22 09:15:38.738  - info: host.raspberrypismarthome iobroker upload [14] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/blockly.js blockly.js application/javascript
                          2023-12-22 09:15:38.760  - info: host.raspberrypismarthome iobroker upload [13] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/de/translations.json i18n/de/translations.json application/json
                          2023-12-22 09:15:38.771  - info: host.raspberrypismarthome iobroker upload [12] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/en/translations.json i18n/en/translations.json application/json
                          2023-12-22 09:15:38.781  - info: host.raspberrypismarthome iobroker upload [11] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/es/translations.json i18n/es/translations.json application/json
                          2023-12-22 09:15:38.792  - info: host.raspberrypismarthome iobroker upload [10] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                          2023-12-22 09:15:38.803  - info: host.raspberrypismarthome iobroker upload [9] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/it/translations.json i18n/it/translations.json application/json
                          2023-12-22 09:15:38.815  - info: host.raspberrypismarthome iobroker upload [8] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                          2023-12-22 09:15:38.825  - info: host.raspberrypismarthome iobroker upload [7] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                          2023-12-22 09:15:38.839  - info: host.raspberrypismarthome iobroker upload [6] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                          2023-12-22 09:15:38.852  - info: host.raspberrypismarthome iobroker upload [5] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                          2023-12-22 09:15:38.864  - info: host.raspberrypismarthome iobroker upload [4] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                          2023-12-22 09:15:38.874  - info: host.raspberrypismarthome iobroker upload [3] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/index_m.html index_m.html text/html
                          2023-12-22 09:15:38.884  - info: host.raspberrypismarthome iobroker upload [2] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/jsonConfig.json jsonConfig.json application/json
                          2023-12-22 09:15:38.895  - info: host.raspberrypismarthome iobroker upload [1] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/pushover.png pushover.png image/png
                          2023-12-22 09:15:38.905  - info: host.raspberrypismarthome iobroker upload [0] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/words.js words.js application/javascript
                          2023-12-22 09:15:38.976  - info: pushover.0 (829) terminating
                          2023-12-22 09:15:38.978  - info: pushover.0 (829) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2023-12-22 09:15:39.514  - info: host.raspberrypismarthome stopInstance system.adapter.pushover.0 killing pid 829
                          2023-12-22 09:15:39.611  - info: host.raspberrypismarthome instance system.adapter.pushover.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2023-12-22 09:15:39.947  - info: host.raspberrypismarthome iobroker exit 0
                          2023-12-22 09:15:41.597  - info: host.raspberrypismarthome instance system.adapter.pushover.0 started with pid 17654
                          2023-12-22 09:15:44.251  - info: pushover.0 (17654) starting. Version 3.0.6 in /opt/iobroker/node_modules/iobroker.pushover, node: v18.19.0, js-controller: 5.0.17
                          2023-12-22 09:18:40.465  - info: admin.0 (662) ==> Connected system.user.admin from ::ffff:192.168.178.59
                          2023-12-22 09:18:43.110  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                          Beste Grüße,
                          Stephan
                          • S Stephan1966
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : armhf
                            CPU threads: 4
                            Current issues:
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            /home/pi
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Swap:            99M          0B         99M
                                     3794 M total memory
                                      803 M used memory
                                      883 M active memory
                                     2364 M free memory
                                       90 M buffer memory
                                      535 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            /var:
                            1.9G    /var/
                            1.1G    /var/log
                            658M    /var/cache
                            USB-Devices by-id:
                            /usr/bin/npm            10.2.3
                            /usr/bin/npx            10.2.3
                            nodejs:
                              Version table:
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.12.0
                            javascript:     7.1.6
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        2065
                            States:         1761
                            Pending Updates: 0
                            @stephan1966
                            wirft jetzt was raus?
                            S 2 Antworten Letzte Antwort
                              @stephan1966
                              Stephan1966
                              @thomas-braun ```
                              Copy text starting here:
                                                      v.2023-10-10
                                       Icon name: computer
                                    Architecture: arm64
                              Kernel:                 aarch64
                              Userland:               armhf
                              Timezone:               Europe/Berlin (CET, +0100)
                              User-ID:                1000
                              X-Server:               false
                              Pending OS-Updates:     0
                              Pending iob updates:    0
                              Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                                      /usr/bin/npm            10.2.3
                                                      /usr/bin/npx            10.2.3
                              Recommended versions are nodejs 18.19.0 and npm 10.2.3
                              MEMORY:
                              Mem:            3.8G        848M        2.3G        1.0M        626M        2.9G
                              Swap:            99M          0B         99M
                              Total:          3.9G        848M        2.4G
                              Active iob-Instances:   15
                              ioBroker Core:          js-controller           5.0.17
                                                      admin                   6.12.0
                              Objects type: jsonl
                              States  type: jsonl
                              Objects:                2065
                              States:                 1761
                              Size of iob-Database:
                              6.3M    /opt/iobroker/iobroker-data/objects.json.migrated
                              6.3M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                              6.8M    /opt/iobroker/iobroker-data/states.jsonl
                              488K    /opt/iobroker/iobroker-data/states.json.migrated
                              488K    /opt/iobroker/iobroker-data/states.json.bak.migrated
                              0       /opt/iobroker/iobroker-data/states.json.broken
                              Beste Grüße,
                              Stephan
                                @stephan1966
                                Stephan1966
                                @thomas-braun ```
                                === Mark text until here for copying ===
                                ● deconz-update.service - deCONZ: ZigBee gateway -- Update Service
                                     Loaded: loaded (/lib/systemd/system/deconz-update.service; disabled; vendor preset: enabled)
                                     Active: failed (Result: exit-code) since Tue 2023-12-19 14:54:22 CET; 2 days ago
                                    Process: 542 ExecStart=/usr/bin/deCONZ-update2.sh (code=exited, status=203/EXEC)
                                   Main PID: 542 (code=exited, status=203/EXEC)
                                        CPU: 3ms
                                Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-update.service: Scheduled restart job, restart counter is at 5.
                                Dez 19 14:54:22 raspberrypismarthome systemd[1]: Stopped deCONZ: ZigBee gateway -- Update Service.
                                Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-update.service: Start request repeated too quickly.
                                Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-update.service: Failed with result 'exit-code'.
                                Dez 19 14:54:22 raspberrypismarthome systemd[1]: Failed to start deCONZ: ZigBee gateway -- Update Service.
                                ● deconz-init.service - deCONZ: ZigBee gateway -- Initialisation
                                     Loaded: loaded (/lib/systemd/system/deconz-init.service; disabled; vendor preset: enabled)
                                     Active: failed (Result: exit-code) since Tue 2023-12-19 14:54:21 CET; 2 days ago
                                    Process: 397 ExecStart=/usr/bin/deCONZ-init.sh (code=exited, status=203/EXEC)
                                   Main PID: 397 (code=exited, status=203/EXEC)
                                        CPU: 4ms
                                Dez 19 14:54:21 raspberrypismarthome systemd[1]: Starting deCONZ: ZigBee gateway -- Initialisation...
                                Dez 19 14:54:21 raspberrypismarthome systemd[397]: deconz-init.service: Failed to locate executable /usr/bin/deCONZ-init.sh: No such file or directory
                                Dez 19 14:54:21 raspberrypismarthome systemd[397]: deconz-init.service: Failed at step EXEC spawning /usr/bin/deCONZ-init.sh: No such file or directory
                                Dez 19 14:54:21 raspberrypismarthome systemd[1]: deconz-init.service: Main process exited, code=exited, status=203/EXEC
                                Dez 19 14:54:21 raspberrypismarthome systemd[1]: deconz-init.service: Failed with result 'exit-code'.
                                Dez 19 14:54:21 raspberrypismarthome systemd[1]: Failed to start deCONZ: ZigBee gateway -- Initialisation.
                                ● deconz-wifi.service - deCONZ: ZigBee gateway -- WIFI Service
                                     Loaded: loaded (/lib/systemd/system/deconz-wifi.service; enabled; vendor preset: enabled)
                                    Process: 547 ExecStart=/usr/bin/deCONZ-WIFI2.sh (code=exited, status=203/EXEC)
                                   Main PID: 547 (code=exited, status=203/EXEC)
                                        CPU: 2ms
                                Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-wifi.service: Scheduled restart job, restart counter is at 5.
                                Dez 19 14:54:22 raspberrypismarthome systemd[1]: Stopped deCONZ: ZigBee gateway -- WIFI Service.
                                Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-wifi.service: Start request repeated too quickly.
                                Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-wifi.service: Failed with result 'exit-code'.
                                Dez 19 14:54:22 raspberrypismarthome systemd[1]: Failed to start deCONZ: ZigBee gateway -- WIFI Service.
                                ● deconz.service - deCONZ: ZigBee gateway -- REST API
                                     Loaded: loaded (/lib/systemd/system/deconz.service; enabled; vendor preset: enabled)
                                     Active: active (running) since Tue 2023-12-19 14:54:21 CET; 2 days ago
                                   Main PID: 400 (deCONZ)
                                      Tasks: 6 (limit: 3933)
                                        CPU: 55min 35.525s
                                     CGroup: /system.slice/deconz.service
                                             └─400 /usr/bin/deCONZ -platform minimal --http-port=80
                                Dez 19 14:54:21 raspberrypismarthome systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
                                Dez 19 14:54:22 raspberrypismarthome deCONZ[400]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-pi'
                                Dez 19 14:54:23 raspberrypismarthome deCONZ[400]: libpng warning: iCCP: known incorrect sRGB profile
                                Dez 19 14:54:25 raspberrypismarthome deCONZ[400]: This plugin does not support propagateSizeHints()
                                Dez 19 14:54:28 raspberrypismarthome deCONZ[400]: This plugin does not support propagateSizeHints()
                                Beste Grüße,
                                Stephan
                                • S Stephan1966
                                  @thomas-braun ```
                                          CPU: 3ms
                                          CPU: 4ms
                                          CPU: 2ms
                                          CPU: 55min 35.525s
                                  ls -lAh /usr/bin/deCONZ-WIFI2.sh
                                  ls -lAh /usr/bin/deCONZ-update2.sh
                                    Stephan1966
                                    pi@raspberrypismarthome:~ $ ls -lAh /usr/bin/deCONZ-WIFI2.sh
                                    ls: Zugriff auf '/usr/bin/deCONZ-WIFI2.sh' nicht möglich: Datei oder Verzeichnis nicht gefunden
                                    pi@raspberrypismarthome:~ $ ls -lAh /usr/bin/deCONZ-update2.sh
                                    ls: Zugriff auf '/usr/bin/deCONZ-update2.sh' nicht möglich: Datei oder Verzeichnis nicht gefunden
                                    Beste Grüße,
                                    Stephan
                                    • S Stephan1966
                                      @stephan1966
                                      Das ist dann auch der Grund, warum der Service failed.
                                      Ich hab aber kein deconz laufen, keine Ahnung wo der Eintrag für die Services überhaupt herkommt.
                                        @stephan1966
                                        Stephan1966
                                        Es scheint ja bis auf eine Lampe bei mir alles zu funktionieren, ob die Lampe damit zusammenhängt bekomme ich ja vielleicht noch heraus!
                                        Danke für den Super-Support 👍
                                        Beste Grüße,
                                        Stephan
