  4. iobroker zeschossen
    6.8k
iobroker zeschossen
175 Beiträge 9 Kommentatoren 48.7k Aufrufe 7 Beobachtet
  • KrisiunK Krisiun
    Die ausgabe ist zu groß kann ich nicht schicken aber ich schicke Die die letzte Zeile da ist denke ich ein fehler
    Errors were encountered while processing:
     /var/cache/apt/archives/nodejs_18.18.0-1nodesource1_amd64.deb
    needrestart is being skipped since dpkg has failed
    E: Sub-process /usr/bin/dpkg returned an error code (1)
    #121
    @krisiun
    Nee, kann ich nicht.
    sudo apt purge libnode72
    KrisiunK 1 Antwort Letzte Antwort
      @krisiun
      KrisiunK Offline
      KrisiunK Offline
      Krisiun
      #122
      @thomas-braun sagte in iobroker zeschossen:
      Leider
      • KrisiunK Krisiun
        sudo apt full-upgrade
        Nr 1
        krisiun@Marek2:~$ sudo apt full-upgrade
        Reading package lists... Done
        Building dependency tree... Done
        Calculating upgrade... Done
        The following packages were automatically installed and are no longer required:
          javascript-common libc-ares2 libffi7 libjs-highlight.js libllvm13 libnode72 libpython2-dev libpython2-stdlib
          libpython2.7 libpython2.7-dev libpython2.7-minimal libpython2.7-stdlib python2 python2-dev python2-minimal python2.7
          python2.7-dev python2.7-minimal
        Use 'sudo apt autoremove' to remove them.
        The following packages will be upgraded:
          nodejs
        1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        Need to get 0 B/29.5 MB of archives.
        After this operation, 188 MB of additional disk space will be used.
        Do you want to continue? [Y/n] y
        (Reading database ... 48341 files and directories currently installed.)
        Preparing to unpack .../nodejs_18.18.0-1nodesource1_amd64.deb ...
        Unpacking nodejs (18.18.0-1nodesource1) over (12.22.9~dfsg-1ubuntu3) ...
        dpkg: error processing archive /var/cache/apt/archives/nodejs_18.18.0-1nodesource1_amd64.deb (--unpack):
         trying to overwrite '/usr/share/systemtap/tapset/node.stp', which is also in package libnode72:amd64 12.22.9~dfsg-1ubuntu3
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        #123
        @krisiun
        zu wsl unter windows würde gern auf die faq von microsoft hinweisen.
        du kannst da gern experimentieren, allerdings ist wsl eigentlich nur zu linux-entwicklung unter windows gedacht und nicht um da einen server dauerhaft laufen zu lassen.
        https://learn.microsoft.com/en-us/windows/wsl/faq#can-i-use-wsl-for-production-scenarios--
        Meine Adapter und Widgets
        Links im Profil
        • OliverIOO OliverIO
          @krisiun
          KrisiunK Offline
          KrisiunK Offline
          Krisiun
          #124
          @oliverio
          OK also es wird nix?
          • KrisiunK Krisiun
            Leider
            #125
            @krisiun sagte in iobroker zeschossen:
            Leider
            ...nicht vollständig.
              Leider
              KrisiunK Offline
              KrisiunK Offline
              Krisiun
              #126
              krisiun@Marek2:~$ sudo apt purge libnode72
              The following package was automatically installed and is no longer required:
                libc-ares2
              Use 'sudo apt autoremove' to remove it.
              The following additional packages will be installed:
                nodejs
              The following packages will be REMOVED:
                libnode72*
                nodejs
              1 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
              After this operation, 147 MB of additional disk space will be used.
              (Reading database ... 47321 files and directories currently installed.)
              • KrisiunK Krisiun
                  libc-ares2
                  nodejs
                  libnode72*
                  nodejs
                #127
                libnode72
                sudo apt remove libnode72
                • KrisiunK Krisiun
                  @oliverio
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  #128
                  @krisiun
                  zum probieren schon,
                  aber wenn ich sehe, das der thread hier schon 124 beiträge lang ist, dann hapert es ein wenig an den skills und dann ist es nochmal schwerer das in so einem szenario zum laufen zu bringen.
                  daher, kauf dir lieber eine raspi.
                  die sind nicht so teuer.
                  denk dran, die anzahl der adapter gehen direkt auf den hauptspeicher.
                  wenn du dir einen mit 1MB ram holst, dann ist das nur für ein paar Adapter sinnvoll. wenn du vor hast, mehrere Sorten von Geräte anzubinden, dann hol dir einen mit 4MB, da bist du erst einmal save
                  und kannst dich langsam in das thema linux einlesen.
                  ein rapsi schluckt auch nicht soviel strom (<10W) wie ein ganzer PC der dauerhalft läuft (womöglich noch mit einer eigenen Grafikkarte)
                  da kommen dann eher 100W und höher auf.
                  10w24h=240W, bei 30 cent/1Kw, dann ca 7cent pro Tag
                  100w
                  24=2400W, bei 30 cent/1Kw, dann ca 70cent pro Tag und höher.
                  Fürs Jahr kannst dir das ja selber ausrechnen.
                  Links im Profil
                  KrisiunK Great SUNG 2 Antworten Letzte Antwort
                    libnode72
                    KrisiunK Offline
                    KrisiunK Offline
                    Krisiun
                    #129
                    krisiun@Marek2:~$ sudo apt remove libnode72
                      libc-ares2
                      nodejs
                      libnode72
                      nodejs
                      @krisiun
                      100w
                      KrisiunK Offline
                      KrisiunK Offline
                      Krisiun
                      #130
                      @oliverio sagte in iobroker zeschossen:
                      @krisiun
                      100w
                      Danke für den Tipp aber ich habe schon einen
                      KrisiunK bahnuhrB 2 Antworten Letzte Antwort
                      • KrisiunK Krisiun
                        @krisiun
                        100w
                        KrisiunK Offline
                        KrisiunK Offline
                        Krisiun
                        #131
                        @krisiun
                        100w
                        Das hier läuft nur sporadisch nicht ständig
                        • KrisiunK Krisiun
                          @krisiun
                          100w
                          bahnuhrB Online
                          bahnuhrB Online
                          bahnuhr
                          #132
                          habe schon einen
                          hoffentlich was ordentliches mit viel Speicher
                          Danke.
                          • KrisiunK Krisiun
                              libc-ares2
                              nodejs
                              libnode72
                              nodejs
                            #133
                            @krisiun
                            apt policy nodejs
                            • bahnuhrB bahnuhr
                              habe schon einen
                              KrisiunK Offline
                              KrisiunK Offline
                              Krisiun
                              #134
                              @bahnuhr
                              Ja das passt schon. Danke
                              bahnuhrB Thomas BraunT 2 Antworten Letzte Antwort
                              • KrisiunK Krisiun
                                @bahnuhr
                                bahnuhrB Online
                                bahnuhrB Online
                                bahnuhr
                                #135
                                @bahnuhr
                                Und wat für einen ?
                                Danke.
                                  @krisiun
                                  apt policy nodejs
                                  KrisiunK Offline
                                  KrisiunK Offline
                                  Krisiun
                                  #136
                                  krisiun@Marek2:~$ apt policy nodejs
                                  nodejs:
                                    Installed: 12.22.9~dfsg-1ubuntu3
                                    Candidate: 18.18.0-1nodesource1
                                    Version table:
                                       18.18.0-1nodesource1 500
                                          500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                       18.17.1-1nodesource1 500
                                       18.17.0-1nodesource1 500
                                       18.16.1-1nodesource1 500
                                       18.16.0-1nodesource1 500
                                       18.15.0-1nodesource1 500
                                       18.14.2-1nodesource1 500
                                       18.14.1-1nodesource1 500
                                       18.14.0-1nodesource1 500
                                       18.13.0-1nodesource1 500
                                       18.12.0-1nodesource1 500
                                       18.11.0-1nodesource1 500
                                       18.10.0-1nodesource1 500
                                       18.9.1-1nodesource1 500
                                       18.9.0-1nodesource1 500
                                       18.8.0-1nodesource1 500
                                       18.7.0-1nodesource1 500
                                       18.6.0-1nodesource1 500
                                       18.5.0-1nodesource1 500
                                       18.4.0-1nodesource1 500
                                       18.3.0-1nodesource1 500
                                       18.2.0-1nodesource1 500
                                       18.1.0-1nodesource1 500
                                       18.0.0-1nodesource1 500
                                   *** 12.22.9~dfsg-1ubuntu3 500
                                          500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                                          100 /var/lib/dpkg/status
                                  • KrisiunK Krisiun
                                    @bahnuhr
                                    #137
                                    @krisiun
                                    sudo apt remove nodejs libnode72
                                    • bahnuhrB bahnuhr
                                      @bahnuhr
                                      Und wat für einen ?
                                      KrisiunK Offline
                                      KrisiunK Offline
                                      Krisiun
                                      #138
                                      @bahnuhr sagte in iobroker zeschossen:
                                      @bahnuhr
                                      Und wat für einen ?
                                      Es geht da nicht um den raspi der geht doch einwandfrei. Keine probleme.
                                        @krisiun
                                        KrisiunK Offline
                                        KrisiunK Offline
                                        Krisiun
                                        #139
                                        nodejs:
                                          Version table:
                                        Removing nodejs (12.22.9~dfsg-1ubuntu3) ...
                                        Removing libnode72:amd64 (12.22.9~dfsg-1ubuntu3) ...
                                        Processing triggers for man-db (2.10.2-1) ...
                                        Processing triggers for libc-bin (2.35-0ubuntu3.4) ...
                                        Scanning processes...
                                        Scanning candidates...
                                        Scanning processor microcode...
                                        Scanning linux images...
                                        Failed to retrieve available kernel versions.
                                        Failed to check for processor microcode upgrades.
                                        No services need to be restarted.MOVED:
                                          libnode72 nodejs
                                        No containers need to be restarted. remove and 0 not upgraded.
                                        After this operation, 42.1 MB disk space will be freed.
                                        User sessions running outdated binaries:
                                         krisiun @ /dev/tty1: bash[5843]
                                         root @ /dev/pts/0: apt[7094,7146], sh[7151]
                                         root @ /dev/tty1: bash[5801], init[5800], su[5842]
                                        No VM guests are running outdated hypervisor (qemu) binaries on this host.
                                        • KrisiunK Krisiun
                                          @bahnuhr
                                          Und wat für einen ?
                                          bahnuhrB Online
                                          bahnuhrB Online
                                          bahnuhr
                                          #140
                                          @bahnuhr
                                          Und wat für einen ?
                                          Musst es ja nicht verraten.
                                          War nur neugierig.
                                          Danke.
