  4. iobroker zeschossen
    6.8k
iobroker zeschossen
175 Beiträge 9 Kommentatoren 48.7k Aufrufe 7 Beobachtet
    @krisiun sagte in iobroker zeschossen:
    libnode72
    sudo apt purge libnode72 node-*
    KrisiunK Offline
    KrisiunK Offline
    Krisiun
    #120
    Die ausgabe ist zu groß kann ich nicht schicken aber ich schicke Die die letzte Zeile da ist denke ich ein fehler
    Errors were encountered while processing:
     /var/cache/apt/archives/nodejs_18.18.0-1nodesource1_amd64.deb
    needrestart is being skipped since dpkg has failed
    E: Sub-process /usr/bin/dpkg returned an error code (1)
    • KrisiunK Krisiun
      #121
      @krisiun
      Nee, kann ich nicht.
      KrisiunK 1 Antwort Letzte Antwort
        @krisiun
        KrisiunK Offline
        KrisiunK Offline
        Krisiun
        #122
        @thomas-braun sagte in iobroker zeschossen:
        Leider
        • KrisiunK Krisiun
          sudo apt full-upgrade
          Nr 1
          krisiun@Marek2:~$ sudo apt full-upgrade
          Reading package lists... Done
          Calculating upgrade... Done
          The following packages were automatically installed and are no longer required:
            javascript-common libc-ares2 libffi7 libjs-highlight.js libllvm13 libnode72 libpython2-dev libpython2-stdlib
            libpython2.7 libpython2.7-dev libpython2.7-minimal libpython2.7-stdlib python2 python2-dev python2-minimal python2.7
            python2.7-dev python2.7-minimal
          Use 'sudo apt autoremove' to remove them.
          The following packages will be upgraded:
            nodejs
          1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
          Need to get 0 B/29.5 MB of archives.
          After this operation, 188 MB of additional disk space will be used.
          Do you want to continue? [Y/n] y
          (Reading database ... 48341 files and directories currently installed.)
          Preparing to unpack .../nodejs_18.18.0-1nodesource1_amd64.deb ...
          Unpacking nodejs (18.18.0-1nodesource1) over (12.22.9~dfsg-1ubuntu3) ...
          dpkg: error processing archive /var/cache/apt/archives/nodejs_18.18.0-1nodesource1_amd64.deb (--unpack):
           trying to overwrite '/usr/share/systemtap/tapset/node.stp', which is also in package libnode72:amd64 12.22.9~dfsg-1ubuntu3
          OliverIOO Offline
          OliverIOO Offline
          OliverIO
          #123
          @krisiun
          zu wsl unter windows würde gern auf die faq von microsoft hinweisen.
          du kannst da gern experimentieren, allerdings ist wsl eigentlich nur zu linux-entwicklung unter windows gedacht und nicht um da einen server dauerhaft laufen zu lassen.
          https://learn.microsoft.com/en-us/windows/wsl/faq#can-i-use-wsl-for-production-scenarios--
          Meine Adapter und Widgets
          Links im Profil
          • OliverIOO OliverIO
            @krisiun
            KrisiunK Offline
            KrisiunK Offline
            Krisiun
            #124
            @oliverio
            OK also es wird nix?
            • KrisiunK Krisiun
              Leider
              #125
              Leider
              ...nicht vollständig.
                Leider
                KrisiunK Offline
                KrisiunK Offline
                Krisiun
                #126
                krisiun@Marek2:~$ sudo apt purge libnode72
                The following package was automatically installed and is no longer required:
                  libc-ares2
                Use 'sudo apt autoremove' to remove it.
                The following additional packages will be installed:
                  nodejs
                The following packages will be REMOVED:
                  libnode72*
                  nodejs
                1 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                After this operation, 147 MB of additional disk space will be used.
                (Reading database ... 47321 files and directories currently installed.)
                • KrisiunK Krisiun
                    libc-ares2
                    nodejs
                    libnode72*
                    nodejs
                  #127
                  libnode72
                  sudo apt remove libnode72
                  • KrisiunK Krisiun
                    @oliverio
                    OliverIOO Offline
                    OliverIOO Offline
                    OliverIO
                    #128
                    @krisiun
                    zum probieren schon,
                    aber wenn ich sehe, das der thread hier schon 124 beiträge lang ist, dann hapert es ein wenig an den skills und dann ist es nochmal schwerer das in so einem szenario zum laufen zu bringen.
                    daher, kauf dir lieber eine raspi.
                    die sind nicht so teuer.
                    denk dran, die anzahl der adapter gehen direkt auf den hauptspeicher.
                    wenn du dir einen mit 1MB ram holst, dann ist das nur für ein paar Adapter sinnvoll. wenn du vor hast, mehrere Sorten von Geräte anzubinden, dann hol dir einen mit 4MB, da bist du erst einmal save
                    und kannst dich langsam in das thema linux einlesen.
                    ein rapsi schluckt auch nicht soviel strom (<10W) wie ein ganzer PC der dauerhalft läuft (womöglich noch mit einer eigenen Grafikkarte)
                    da kommen dann eher 100W und höher auf.
                    10w24h=240W, bei 30 cent/1Kw, dann ca 7cent pro Tag
                    100w
                    24=2400W, bei 30 cent/1Kw, dann ca 70cent pro Tag und höher.
                    Fürs Jahr kannst dir das ja selber ausrechnen.
                    Links im Profil
                    KrisiunK Great SUNG 2 Antworten Letzte Antwort
                      libnode72
                      KrisiunK Offline
                      KrisiunK Offline
                      Krisiun
                      #129
                      krisiun@Marek2:~$ sudo apt remove libnode72
                        libc-ares2
                        nodejs
                        libnode72
                        nodejs
                        @krisiun
                        100w
                        KrisiunK Offline
                        KrisiunK Offline
                        Krisiun
                        #130
                        @oliverio sagte in iobroker zeschossen:
                        @krisiun
                        100w
                        Danke für den Tipp aber ich habe schon einen
                        KrisiunK bahnuhrB 2 Antworten Letzte Antwort
                        • KrisiunK Krisiun
                          @krisiun
                          100w
                          KrisiunK Offline
                          KrisiunK Offline
                          Krisiun
                          #131
                          @krisiun
                          100w
                          Das hier läuft nur sporadisch nicht ständig
                          • KrisiunK Krisiun
                            @krisiun
                            100w
                            bahnuhrB Online
                            bahnuhrB Online
                            bahnuhr
                            #132
                            habe schon einen
                            hoffentlich was ordentliches mit viel Speicher
                            Danke.
                            • KrisiunK Krisiun
                                libc-ares2
                                nodejs
                                libnode72
                                nodejs
                              #133
                              @krisiun
                              apt policy nodejs
                              • bahnuhrB bahnuhr
                                habe schon einen
                                KrisiunK Offline
                                KrisiunK Offline
                                Krisiun
                                #134
                                @bahnuhr
                                Ja das passt schon. Danke
                                bahnuhrB Thomas BraunT 2 Antworten Letzte Antwort
                                • KrisiunK Krisiun
                                  @bahnuhr
                                  bahnuhrB Online
                                  bahnuhrB Online
                                  bahnuhr
                                  #135
                                  @bahnuhr
                                  Und wat für einen ?
                                  Danke.
                                    @krisiun
                                    apt policy nodejs
                                    KrisiunK Offline
                                    KrisiunK Offline
                                    Krisiun
                                    #136
                                    krisiun@Marek2:~$ apt policy nodejs
                                    nodejs:
                                      Installed: 12.22.9~dfsg-1ubuntu3
                                      Candidate: 18.18.0-1nodesource1
                                      Version table:
                                         18.18.0-1nodesource1 500
                                            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                         18.17.1-1nodesource1 500
                                         18.17.0-1nodesource1 500
                                         18.16.1-1nodesource1 500
                                         18.16.0-1nodesource1 500
                                         18.15.0-1nodesource1 500
                                         18.14.2-1nodesource1 500
                                         18.14.1-1nodesource1 500
                                         18.14.0-1nodesource1 500
                                         18.13.0-1nodesource1 500
                                         18.12.0-1nodesource1 500
                                         18.11.0-1nodesource1 500
                                         18.10.0-1nodesource1 500
                                         18.9.1-1nodesource1 500
                                         18.9.0-1nodesource1 500
                                         18.8.0-1nodesource1 500
                                         18.7.0-1nodesource1 500
                                         18.6.0-1nodesource1 500
                                         18.5.0-1nodesource1 500
                                         18.4.0-1nodesource1 500
                                         18.3.0-1nodesource1 500
                                         18.2.0-1nodesource1 500
                                         18.1.0-1nodesource1 500
                                         18.0.0-1nodesource1 500
                                     *** 12.22.9~dfsg-1ubuntu3 500
                                            500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                                    • KrisiunK Krisiun
                                      @bahnuhr
                                      #137
                                      @krisiun
                                      sudo apt remove nodejs libnode72
                                      • bahnuhrB bahnuhr
                                        @bahnuhr
                                        Und wat für einen ?
                                        KrisiunK Offline
                                        KrisiunK Offline
                                        Krisiun
                                        #138
                                        @bahnuhr sagte in iobroker zeschossen:
                                        @bahnuhr
                                        Und wat für einen ?
                                        Es geht da nicht um den raspi der geht doch einwandfrei. Keine probleme.
                                          @krisiun
                                          KrisiunK Offline
                                          KrisiunK Offline
                                          Krisiun
                                          #139
                                          nodejs:
                                            Version table:
                                          Removing nodejs (12.22.9~dfsg-1ubuntu3) ...
                                          Removing libnode72:amd64 (12.22.9~dfsg-1ubuntu3) ...
                                          Processing triggers for man-db (2.10.2-1) ...
                                          Processing triggers for libc-bin (2.35-0ubuntu3.4) ...
                                          Scanning processes...
                                          Scanning candidates...
                                          Scanning processor microcode...
                                          Scanning linux images...
                                          Failed to retrieve available kernel versions.
                                          Failed to check for processor microcode upgrades.
                                          No services need to be restarted.MOVED:
                                            libnode72 nodejs
                                          No containers need to be restarted. remove and 0 not upgraded.
                                          After this operation, 42.1 MB disk space will be freed.
                                          User sessions running outdated binaries:
                                           krisiun @ /dev/tty1: bash[5843]
                                           root @ /dev/pts/0: apt[7094,7146], sh[7151]
                                           root @ /dev/tty1: bash[5801], init[5800], su[5842]
                                          No VM guests are running outdated hypervisor (qemu) binaries on this host.
