  4. iobroker zeschossen
    6.8k
iobroker zeschossen
175 Beiträge 9 Kommentatoren 48.7k Aufrufe 7 Beobachtet
  • KrisiunK Krisiun
    @thomas-braun sagte in iobroker zeschossen:
    sudo apt full-upgrade
    Nr 1
    krisiun@Marek2:~$ sudo apt full-upgrade
    Reading package lists... Done
    Calculating upgrade... Done
    The following packages were automatically installed and are no longer required:
      javascript-common libc-ares2 libffi7 libjs-highlight.js libllvm13 libnode72 libpython2-dev libpython2-stdlib
      libpython2.7 libpython2.7-dev libpython2.7-minimal libpython2.7-stdlib python2 python2-dev python2-minimal python2.7
      python2.7-dev python2.7-minimal
    Use 'sudo apt autoremove' to remove them.
    The following packages will be upgraded:
      nodejs
    1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Need to get 0 B/29.5 MB of archives.
    After this operation, 188 MB of additional disk space will be used.
    Do you want to continue? [Y/n] y
    (Reading database ... 48341 files and directories currently installed.)
    Preparing to unpack .../nodejs_18.18.0-1nodesource1_amd64.deb ...
    Unpacking nodejs (18.18.0-1nodesource1) over (12.22.9~dfsg-1ubuntu3) ...
    dpkg: error processing archive /var/cache/apt/archives/nodejs_18.18.0-1nodesource1_amd64.deb (--unpack):
     trying to overwrite '/usr/share/systemtap/tapset/node.stp', which is also in package libnode72:amd64 12.22.9~dfsg-1ubuntu3
    Errors were encountered while processing:
    needrestart is being skipped since dpkg has failed
    E: Sub-process /usr/bin/dpkg returned an error code (1)
    KrisiunK Offline
    KrisiunK Offline
    Krisiun
    #118
    @krisiun
    Nr 2
    krisiun@Marek2:~$ sudo apt autoremove
    The following packages will be REMOVED:
      javascript-common libffi7 libjs-highlight.js libllvm13 libpython2-dev libpython2-stdlib libpython2.7
    0 upgraded, 0 newly installed, 16 to remove and 1 not upgraded.
    After this operation, 135 MB disk space will be freed.
    Removing javascript-common (11+nmu1) ...
    Removing libffi7:amd64 (3.3-5ubuntu1) ...
    Removing libjs-highlight.js (9.18.5+dfsg1-1) ...
    Removing libllvm13:amd64 (1:13.0.1-2ubuntu2.2) ...
    Removing python2-dev (2.7.18-3) ...
    Removing libpython2-dev:amd64 (2.7.18-3) ...
    Removing python2 (2.7.18-3) ...
    Removing libpython2-stdlib:amd64 (2.7.18-3) ...
    Removing python2.7-dev (2.7.18-13ubuntu1.1) ...
    Removing libpython2.7-dev:amd64 (2.7.18-13ubuntu1.1) ...
    Removing libpython2.7:amd64 (2.7.18-13ubuntu1.1) ...
    Removing python2.7 (2.7.18-13ubuntu1.1) ...
    Removing libpython2.7-stdlib:amd64 (2.7.18-13ubuntu1.1) ...
    Removing python2-minimal (2.7.18-3) ...
    Removing python2.7-minimal (2.7.18-13ubuntu1.1) ...
    Unlinking and removing bytecode for runtime python2.7
    Removing libpython2.7-minimal:amd64 (2.7.18-13ubuntu1.1) ...
    Processing triggers for libc-bin (2.35-0ubuntu3.4) ...
    Processing triggers for man-db (2.10.2-1) ...
    Processing triggers for mailcap (3.70+nmu1ubuntu1) ...
    Processing triggers for desktop-file-utils (0.26-1ubuntu3) ...
    Scanning processes...
    Scanning candidates...
    Scanning processor microcode...
    Scanning linux images...
    Failed to retrieve available kernel versions.
    Failed to check for processor microcode upgrades.
    No services need to be restarted.
    No containers need to be restarted.
    User sessions running outdated binaries:
     krisiun @ /dev/tty1: bash[5843]
     root @ /dev/pts/0: apt[6559,6667], sh[6672]
     root @ /dev/tty1: bash[5801], init[5800], su[5842]
    No VM guests are running outdated hypervisor (qemu) binaries on this host.
    • KrisiunK Krisiun
      Nr 1
        nodejs
      #119
      @krisiun sagte in iobroker zeschossen:
      libnode72
      sudo apt purge libnode72 node-*
      KrisiunK 1 Antwort Letzte Antwort
        libnode72
        KrisiunK Offline
        KrisiunK Offline
        Krisiun
        #120
        Die ausgabe ist zu groß kann ich nicht schicken aber ich schicke Die die letzte Zeile da ist denke ich ein fehler
        • KrisiunK Krisiun
          #121
          @krisiun
          Nee, kann ich nicht.
            @krisiun
            KrisiunK Offline
            KrisiunK Offline
            Krisiun
            #122
            Leider
            • KrisiunK Krisiun
              Nr 1
                nodejs
              OliverIOO Offline
              OliverIOO Offline
              OliverIO
              #123
              @krisiun
              zu wsl unter windows würde gern auf die faq von microsoft hinweisen.
              du kannst da gern experimentieren, allerdings ist wsl eigentlich nur zu linux-entwicklung unter windows gedacht und nicht um da einen server dauerhaft laufen zu lassen.
              https://learn.microsoft.com/en-us/windows/wsl/faq#can-i-use-wsl-for-production-scenarios--
              Meine Adapter und Widgets
              Links im Profil
              • OliverIOO OliverIO
                @krisiun
                KrisiunK Offline
                KrisiunK Offline
                Krisiun
                #124
                @oliverio
                OK also es wird nix?
                • KrisiunK Krisiun
                  Leider
                  #125
                  Leider
                  ...nicht vollständig.
                    Leider
                    KrisiunK Offline
                    KrisiunK Offline
                    Krisiun
                    #126
                    krisiun@Marek2:~$ sudo apt purge libnode72
                    The following package was automatically installed and is no longer required:
                      libc-ares2
                    Use 'sudo apt autoremove' to remove it.
                    The following additional packages will be installed:
                      nodejs
                      libnode72*
                      nodejs
                    1 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                    After this operation, 147 MB of additional disk space will be used.
                    (Reading database ... 47321 files and directories currently installed.)
                    • KrisiunK Krisiun
                        libc-ares2
                        nodejs
                        libnode72*
                        nodejs
                      #127
                      libnode72
                      sudo apt remove libnode72
                      • KrisiunK Krisiun
                        @oliverio
                        OliverIOO Offline
                        OliverIOO Offline
                        OliverIO
                        #128
                        @krisiun
                        zum probieren schon,
                        aber wenn ich sehe, das der thread hier schon 124 beiträge lang ist, dann hapert es ein wenig an den skills und dann ist es nochmal schwerer das in so einem szenario zum laufen zu bringen.
                        daher, kauf dir lieber eine raspi.
                        die sind nicht so teuer.
                        denk dran, die anzahl der adapter gehen direkt auf den hauptspeicher.
                        wenn du dir einen mit 1MB ram holst, dann ist das nur für ein paar Adapter sinnvoll. wenn du vor hast, mehrere Sorten von Geräte anzubinden, dann hol dir einen mit 4MB, da bist du erst einmal save
                        und kannst dich langsam in das thema linux einlesen.
                        ein rapsi schluckt auch nicht soviel strom (<10W) wie ein ganzer PC der dauerhalft läuft (womöglich noch mit einer eigenen Grafikkarte)
                        da kommen dann eher 100W und höher auf.
                        10w24h=240W, bei 30 cent/1Kw, dann ca 7cent pro Tag
                        100w
                        24=2400W, bei 30 cent/1Kw, dann ca 70cent pro Tag und höher.
                        Fürs Jahr kannst dir das ja selber ausrechnen.
                        Links im Profil
                        KrisiunK Great SUNG 2 Antworten Letzte Antwort
                          libnode72
                          KrisiunK Offline
                          KrisiunK Offline
                          Krisiun
                          #129
                          krisiun@Marek2:~$ sudo apt remove libnode72
                            libc-ares2
                            nodejs
                            libnode72
                            nodejs
                            @krisiun
                            100w
                            KrisiunK Offline
                            KrisiunK Offline
                            Krisiun
                            #130
                            @oliverio sagte in iobroker zeschossen:
                            @krisiun
                            100w
                            Danke für den Tipp aber ich habe schon einen
                            KrisiunK bahnuhrB 2 Antworten Letzte Antwort
                            • KrisiunK Krisiun
                              @krisiun
                              100w
                              KrisiunK Offline
                              KrisiunK Offline
                              Krisiun
                              #131
                              @krisiun
                              100w
                              Das hier läuft nur sporadisch nicht ständig
                              • KrisiunK Krisiun
                                @krisiun
                                100w
                                bahnuhrB Online
                                bahnuhrB Online
                                bahnuhr
                                #132
                                habe schon einen
                                hoffentlich was ordentliches mit viel Speicher
                                Danke.
                                • KrisiunK Krisiun
                                    libc-ares2
                                    nodejs
                                    libnode72
                                    nodejs
                                  #133
                                  @krisiun
                                  apt policy nodejs
                                  • bahnuhrB bahnuhr
                                    habe schon einen
                                    KrisiunK Offline
                                    KrisiunK Offline
                                    Krisiun
                                    #134
                                    @bahnuhr
                                    Ja das passt schon. Danke
                                    bahnuhrB Thomas BraunT 2 Antworten Letzte Antwort
                                    • KrisiunK Krisiun
                                      @bahnuhr
                                      bahnuhrB Online
                                      bahnuhrB Online
                                      bahnuhr
                                      #135
                                      @bahnuhr
                                      Und wat für einen ?
                                      Danke.
                                        @krisiun
                                        apt policy nodejs
                                        KrisiunK Offline
                                        KrisiunK Offline
                                        Krisiun
                                        #136
                                        krisiun@Marek2:~$ apt policy nodejs
                                        nodejs:
                                          Installed: 12.22.9~dfsg-1ubuntu3
                                          Candidate: 18.18.0-1nodesource1
                                          Version table:
                                             18.18.0-1nodesource1 500
                                                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                             18.17.1-1nodesource1 500
                                             18.17.0-1nodesource1 500
                                             18.16.1-1nodesource1 500
                                             18.16.0-1nodesource1 500
                                             18.15.0-1nodesource1 500
                                             18.14.2-1nodesource1 500
                                             18.14.1-1nodesource1 500
                                             18.14.0-1nodesource1 500
                                             18.13.0-1nodesource1 500
                                             18.12.0-1nodesource1 500
                                             18.11.0-1nodesource1 500
                                             18.10.0-1nodesource1 500
                                             18.9.1-1nodesource1 500
                                             18.9.0-1nodesource1 500
                                             18.8.0-1nodesource1 500
                                             18.7.0-1nodesource1 500
                                             18.6.0-1nodesource1 500
                                             18.5.0-1nodesource1 500
                                             18.4.0-1nodesource1 500
                                             18.3.0-1nodesource1 500
                                             18.2.0-1nodesource1 500
                                             18.1.0-1nodesource1 500
                                             18.0.0-1nodesource1 500
                                         *** 12.22.9~dfsg-1ubuntu3 500
                                                500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                                        • KrisiunK Krisiun
                                          @bahnuhr
                                          #137
                                          @krisiun
                                          sudo apt remove nodejs libnode72
