  4. iobroker zeschossen
    6.8k
iobroker zeschossen
175 Beiträge 9 Kommentatoren 48.7k Aufrufe 7 Beobachtet
  • KrisiunK Krisiun
    @thomas-braun sagte in iobroker zeschossen:
    sudo apt full-upgrade
    Nr 1
    krisiun@Marek2:~$ sudo apt full-upgrade
    Reading package lists... Done
    Calculating upgrade... Done
    The following packages were automatically installed and are no longer required:
      javascript-common libc-ares2 libffi7 libjs-highlight.js libllvm13 libnode72 libpython2-dev libpython2-stdlib
      libpython2.7 libpython2.7-dev libpython2.7-minimal libpython2.7-stdlib python2 python2-dev python2-minimal python2.7
      python2.7-dev python2.7-minimal
    Use 'sudo apt autoremove' to remove them.
    The following packages will be upgraded:
      nodejs
    1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Need to get 0 B/29.5 MB of archives.
    After this operation, 188 MB of additional disk space will be used.
    Do you want to continue? [Y/n] y
    (Reading database ... 48341 files and directories currently installed.)
    Preparing to unpack .../nodejs_18.18.0-1nodesource1_amd64.deb ...
    Unpacking nodejs (18.18.0-1nodesource1) over (12.22.9~dfsg-1ubuntu3) ...
    dpkg: error processing archive /var/cache/apt/archives/nodejs_18.18.0-1nodesource1_amd64.deb (--unpack):
     trying to overwrite '/usr/share/systemtap/tapset/node.stp', which is also in package libnode72:amd64 12.22.9~dfsg-1ubuntu3
    Errors were encountered while processing:
    needrestart is being skipped since dpkg has failed
    E: Sub-process /usr/bin/dpkg returned an error code (1)
    OliverIOO Offline
    OliverIOO Offline
    OliverIO
    #123
    @krisiun
    zu wsl unter windows würde gern auf die faq von microsoft hinweisen.
    du kannst da gern experimentieren, allerdings ist wsl eigentlich nur zu linux-entwicklung unter windows gedacht und nicht um da einen server dauerhaft laufen zu lassen.
    https://learn.microsoft.com/en-us/windows/wsl/faq#can-i-use-wsl-for-production-scenarios--
    Meine Adapter und Widgets
    Links im Profil
    KrisiunK 1 Antwort Letzte Antwort
    • OliverIOO OliverIO
      @krisiun
      KrisiunK Offline
      KrisiunK Offline
      Krisiun
      #124
      @oliverio
      OK also es wird nix?
      • KrisiunK Krisiun
        sudo apt purge libnode72
        Leider
        #125
        @krisiun sagte in iobroker zeschossen:
        Leider
        ...nicht vollständig.
          Leider
          KrisiunK Offline
          KrisiunK Offline
          Krisiun
          #126
          krisiun@Marek2:~$ sudo apt purge libnode72
          The following package was automatically installed and is no longer required:
            libc-ares2
          Use 'sudo apt autoremove' to remove it.
          The following additional packages will be installed:
            nodejs
          The following packages will be REMOVED:
            libnode72*
            nodejs
          1 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
          After this operation, 147 MB of additional disk space will be used.
          (Reading database ... 47321 files and directories currently installed.)
          • KrisiunK Krisiun
              libc-ares2
              nodejs
              libnode72*
              nodejs
            #127
            libnode72
            sudo apt remove libnode72
            • KrisiunK Krisiun
              @oliverio
              OliverIOO Offline
              OliverIOO Offline
              OliverIO
              #128
              @krisiun
              zum probieren schon,
              aber wenn ich sehe, das der thread hier schon 124 beiträge lang ist, dann hapert es ein wenig an den skills und dann ist es nochmal schwerer das in so einem szenario zum laufen zu bringen.
              daher, kauf dir lieber eine raspi.
              die sind nicht so teuer.
              denk dran, die anzahl der adapter gehen direkt auf den hauptspeicher.
              wenn du dir einen mit 1MB ram holst, dann ist das nur für ein paar Adapter sinnvoll. wenn du vor hast, mehrere Sorten von Geräte anzubinden, dann hol dir einen mit 4MB, da bist du erst einmal save
              und kannst dich langsam in das thema linux einlesen.
              ein rapsi schluckt auch nicht soviel strom (<10W) wie ein ganzer PC der dauerhalft läuft (womöglich noch mit einer eigenen Grafikkarte)
              da kommen dann eher 100W und höher auf.
              10w24h=240W, bei 30 cent/1Kw, dann ca 7cent pro Tag
              100w
              24=2400W, bei 30 cent/1Kw, dann ca 70cent pro Tag und höher.
              Fürs Jahr kannst dir das ja selber ausrechnen.
              Links im Profil
              KrisiunK Great SUNG 2 Antworten Letzte Antwort
                libnode72
                KrisiunK Offline
                KrisiunK Offline
                Krisiun
                #129
                krisiun@Marek2:~$ sudo apt remove libnode72
                  libc-ares2
                  nodejs
                  libnode72
                  nodejs
                  @krisiun
                  100w
                  KrisiunK Offline
                  KrisiunK Offline
                  Krisiun
                  #130
                  @oliverio sagte in iobroker zeschossen:
                  @krisiun
                  100w
                  Danke für den Tipp aber ich habe schon einen
                  KrisiunK bahnuhrB 2 Antworten Letzte Antwort
                  • KrisiunK Krisiun
                    @krisiun
                    100w
                    KrisiunK Offline
                    KrisiunK Offline
                    Krisiun
                    #131
                    @krisiun
                    100w
                    Das hier läuft nur sporadisch nicht ständig
                    • KrisiunK Krisiun
                      @krisiun
                      100w
                      bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      #132
                      habe schon einen
                      hoffentlich was ordentliches mit viel Speicher
                      Danke.
                      • KrisiunK Krisiun
                          libc-ares2
                          nodejs
                          libnode72
                          nodejs
                        #133
                        @krisiun
                        apt policy nodejs
                        • bahnuhrB bahnuhr
                          habe schon einen
                          KrisiunK Offline
                          KrisiunK Offline
                          Krisiun
                          #134
                          @bahnuhr
                          Ja das passt schon. Danke
                          bahnuhrB Thomas BraunT 2 Antworten Letzte Antwort
                          • KrisiunK Krisiun
                            @bahnuhr
                            bahnuhrB Online
                            bahnuhrB Online
                            bahnuhr
                            #135
                            @bahnuhr
                            Und wat für einen ?
                            Danke.
                              @krisiun
                              apt policy nodejs
                              KrisiunK Offline
                              KrisiunK Offline
                              Krisiun
                              #136
                              krisiun@Marek2:~$ apt policy nodejs
                              nodejs:
                                Installed: 12.22.9~dfsg-1ubuntu3
                                Candidate: 18.18.0-1nodesource1
                                Version table:
                                   18.18.0-1nodesource1 500
                                      500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                   18.17.1-1nodesource1 500
                                   18.17.0-1nodesource1 500
                                   18.16.1-1nodesource1 500
                                   18.16.0-1nodesource1 500
                                   18.15.0-1nodesource1 500
                                   18.14.2-1nodesource1 500
                                   18.14.1-1nodesource1 500
                                   18.14.0-1nodesource1 500
                                   18.13.0-1nodesource1 500
                                   18.12.0-1nodesource1 500
                                   18.11.0-1nodesource1 500
                                   18.10.0-1nodesource1 500
                                   18.9.1-1nodesource1 500
                                   18.9.0-1nodesource1 500
                                   18.8.0-1nodesource1 500
                                   18.7.0-1nodesource1 500
                                   18.6.0-1nodesource1 500
                                   18.5.0-1nodesource1 500
                                   18.4.0-1nodesource1 500
                                   18.3.0-1nodesource1 500
                                   18.2.0-1nodesource1 500
                                   18.1.0-1nodesource1 500
                                   18.0.0-1nodesource1 500
                               *** 12.22.9~dfsg-1ubuntu3 500
                                      500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                              • KrisiunK Krisiun
                                @bahnuhr
                                #137
                                @krisiun
                                sudo apt remove nodejs libnode72
                                • bahnuhrB bahnuhr
                                  @bahnuhr
                                  Und wat für einen ?
                                  KrisiunK Offline
                                  KrisiunK Offline
                                  Krisiun
                                  #138
                                  @bahnuhr sagte in iobroker zeschossen:
                                  @bahnuhr
                                  Und wat für einen ?
                                  Es geht da nicht um den raspi der geht doch einwandfrei. Keine probleme.
                                    @krisiun
                                    KrisiunK Offline
                                    KrisiunK Offline
                                    Krisiun
                                    #139
                                    nodejs:
                                      Version table:
                                    Removing nodejs (12.22.9~dfsg-1ubuntu3) ...
                                    Removing libnode72:amd64 (12.22.9~dfsg-1ubuntu3) ...
                                    Processing triggers for man-db (2.10.2-1) ...
                                    Processing triggers for libc-bin (2.35-0ubuntu3.4) ...
                                    Scanning processes...
                                    Scanning candidates...
                                    Scanning processor microcode...
                                    Scanning linux images...
                                    Failed to retrieve available kernel versions.
                                    Failed to check for processor microcode upgrades.
                                    No services need to be restarted.MOVED:
                                      libnode72 nodejs
                                    No containers need to be restarted. remove and 0 not upgraded.
                                    After this operation, 42.1 MB disk space will be freed.
                                    User sessions running outdated binaries:
                                     krisiun @ /dev/tty1: bash[5843]
                                     root @ /dev/pts/0: apt[7094,7146], sh[7151]
                                     root @ /dev/tty1: bash[5801], init[5800], su[5842]
                                    No VM guests are running outdated hypervisor (qemu) binaries on this host.
                                    • KrisiunK Krisiun
                                      @bahnuhr
                                      Und wat für einen ?
                                      bahnuhrB Online
                                      bahnuhrB Online
                                      bahnuhr
                                      #140
                                      @bahnuhr
                                      Und wat für einen ?
                                      Musst es ja nicht verraten.
                                      War nur neugierig.
                                      Danke.
                                      • bahnuhrB bahnuhr
                                        @bahnuhr
                                        Und wat für einen ?
                                        War nur neugierig.
                                        KrisiunK Offline
                                        KrisiunK Offline
                                        Krisiun
                                        #141
                                        @bahnuhr
                                        Und wat für einen ?
                                        War nur neugierig.
                                        Nein du hast mich falsch verstanden das ist doch kein Geheimnis aber ich bin jetzt wo anders beschäftigt und die daten habe ich doch nicht im kopf
                                        • KrisiunK Krisiun
                                          nodejs:
                                            Version table:
                                            libnode72 nodejs
                                          #142
                                          @krisiun
                                          sudo apt update
