  4. iobroker zeschossen
    6.8k
iobroker zeschossen
175 Beiträge 9 Kommentatoren 48.7k Aufrufe 7 Beobachtet
  • KrisiunK Krisiun
    @thomas-braun sagte in iobroker zeschossen:
    sudo apt purge libnode72
    Leider
    Errors were encountered while processing:
     /var/cache/apt/archives/nodejs_18.18.0-1nodesource1_amd64.deb
    needrestart is being skipped since dpkg has failed
    E: Sub-process /usr/bin/dpkg returned an error code (1)
    #125
    @krisiun sagte in iobroker zeschossen:
    Leider
    ...nicht vollständig.
    KrisiunK 1 Antwort Letzte Antwort
      Leider
      KrisiunK Offline
      KrisiunK Offline
      Krisiun
      #126
      krisiun@Marek2:~$ sudo apt purge libnode72
      Reading package lists... Done
      The following package was automatically installed and is no longer required:
        libc-ares2
      Use 'sudo apt autoremove' to remove it.
      The following additional packages will be installed:
        nodejs
      The following packages will be REMOVED:
        libnode72*
      The following packages will be upgraded:
        nodejs
      1 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
      Need to get 0 B/29.5 MB of archives.
      After this operation, 147 MB of additional disk space will be used.
      Do you want to continue? [Y/n] y
      (Reading database ... 47321 files and directories currently installed.)
      Preparing to unpack .../nodejs_18.18.0-1nodesource1_amd64.deb ...
      Unpacking nodejs (18.18.0-1nodesource1) over (12.22.9~dfsg-1ubuntu3) ...
      dpkg: error processing archive /var/cache/apt/archives/nodejs_18.18.0-1nodesource1_amd64.deb (--unpack):
       trying to overwrite '/usr/share/systemtap/tapset/node.stp', which is also in package libnode72:amd64 12.22.9~dfsg-1ubuntu3
      • KrisiunK Krisiun
          libc-ares2
          nodejs
          libnode72*
          nodejs
        #127
        libnode72
        sudo apt remove libnode72
        • KrisiunK Krisiun
          @oliverio
          OK also es wird nix?
          OliverIOO Offline
          OliverIOO Offline
          OliverIO
          #128
          @krisiun
          zum probieren schon,
          aber wenn ich sehe, das der thread hier schon 124 beiträge lang ist, dann hapert es ein wenig an den skills und dann ist es nochmal schwerer das in so einem szenario zum laufen zu bringen.
          daher, kauf dir lieber eine raspi.
          die sind nicht so teuer.
          denk dran, die anzahl der adapter gehen direkt auf den hauptspeicher.
          wenn du dir einen mit 1MB ram holst, dann ist das nur für ein paar Adapter sinnvoll. wenn du vor hast, mehrere Sorten von Geräte anzubinden, dann hol dir einen mit 4MB, da bist du erst einmal save
          und kannst dich langsam in das thema linux einlesen.
          ein rapsi schluckt auch nicht soviel strom (<10W) wie ein ganzer PC der dauerhalft läuft (womöglich noch mit einer eigenen Grafikkarte)
          da kommen dann eher 100W und höher auf.
          10w24h=240W, bei 30 cent/1Kw, dann ca 7cent pro Tag
          100w
          24=2400W, bei 30 cent/1Kw, dann ca 70cent pro Tag und höher.
          Fürs Jahr kannst dir das ja selber ausrechnen.
          Meine Adapter und Widgets
          Links im Profil
          KrisiunK Great SUNG 2 Antworten Letzte Antwort
            libnode72
            KrisiunK Offline
            KrisiunK Offline
            Krisiun
            #129
            krisiun@Marek2:~$ sudo apt remove libnode72
              libc-ares2
              nodejs
              libnode72
              nodejs
            • OliverIOO OliverIO
              @krisiun
              100w
              KrisiunK Offline
              KrisiunK Offline
              Krisiun
              #130
              @oliverio sagte in iobroker zeschossen:
              @krisiun
              100w
              Danke für den Tipp aber ich habe schon einen
              KrisiunK bahnuhrB 2 Antworten Letzte Antwort
              • KrisiunK Krisiun
                @krisiun
                100w
                KrisiunK Offline
                KrisiunK Offline
                Krisiun
                #131
                @krisiun
                100w
                Das hier läuft nur sporadisch nicht ständig
                • KrisiunK Krisiun
                  @krisiun
                  100w
                  bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  #132
                  habe schon einen
                  hoffentlich was ordentliches mit viel Speicher
                  Danke.
                  • KrisiunK Krisiun
                      libc-ares2
                      nodejs
                      libnode72
                      nodejs
                    #133
                    @krisiun
                    apt policy nodejs
                    • bahnuhrB bahnuhr
                      habe schon einen
                      KrisiunK Offline
                      KrisiunK Offline
                      Krisiun
                      #134
                      @bahnuhr
                      Ja das passt schon. Danke
                      bahnuhrB Thomas BraunT 2 Antworten Letzte Antwort
                      • KrisiunK Krisiun
                        @bahnuhr
                        bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        #135
                        @bahnuhr
                        Und wat für einen ?
                        Danke.
                          @krisiun
                          apt policy nodejs
                          KrisiunK Offline
                          KrisiunK Offline
                          Krisiun
                          #136
                          krisiun@Marek2:~$ apt policy nodejs
                          nodejs:
                            Installed: 12.22.9~dfsg-1ubuntu3
                            Candidate: 18.18.0-1nodesource1
                            Version table:
                               18.18.0-1nodesource1 500
                                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                               18.17.1-1nodesource1 500
                               18.17.0-1nodesource1 500
                               18.16.1-1nodesource1 500
                               18.16.0-1nodesource1 500
                               18.15.0-1nodesource1 500
                               18.14.2-1nodesource1 500
                               18.14.1-1nodesource1 500
                               18.14.0-1nodesource1 500
                               18.13.0-1nodesource1 500
                               18.12.0-1nodesource1 500
                               18.11.0-1nodesource1 500
                               18.10.0-1nodesource1 500
                               18.9.1-1nodesource1 500
                               18.9.0-1nodesource1 500
                               18.8.0-1nodesource1 500
                               18.7.0-1nodesource1 500
                               18.6.0-1nodesource1 500
                               18.5.0-1nodesource1 500
                               18.4.0-1nodesource1 500
                               18.3.0-1nodesource1 500
                               18.2.0-1nodesource1 500
                               18.1.0-1nodesource1 500
                               18.0.0-1nodesource1 500
                           *** 12.22.9~dfsg-1ubuntu3 500
                                  500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                          • KrisiunK Krisiun
                            @bahnuhr
                            #137
                            @krisiun
                            sudo apt remove nodejs libnode72
                            • bahnuhrB bahnuhr
                              @bahnuhr
                              Und wat für einen ?
                              KrisiunK Offline
                              KrisiunK Offline
                              Krisiun
                              #138
                              @bahnuhr sagte in iobroker zeschossen:
                              @bahnuhr
                              Und wat für einen ?
                              Es geht da nicht um den raspi der geht doch einwandfrei. Keine probleme.
                                @krisiun
                                KrisiunK Offline
                                KrisiunK Offline
                                Krisiun
                                #139
                                nodejs:
                                  Version table:
                                Removing nodejs (12.22.9~dfsg-1ubuntu3) ...
                                Removing libnode72:amd64 (12.22.9~dfsg-1ubuntu3) ...
                                Processing triggers for man-db (2.10.2-1) ...
                                Processing triggers for libc-bin (2.35-0ubuntu3.4) ...
                                Scanning processes...
                                Scanning candidates...
                                Scanning processor microcode...
                                Scanning linux images...
                                Failed to retrieve available kernel versions.
                                Failed to check for processor microcode upgrades.
                                No services need to be restarted.MOVED:
                                  libnode72 nodejs
                                No containers need to be restarted. remove and 0 not upgraded.
                                After this operation, 42.1 MB disk space will be freed.
                                User sessions running outdated binaries:
                                 krisiun @ /dev/tty1: bash[5843]
                                 root @ /dev/pts/0: apt[7094,7146], sh[7151]
                                 root @ /dev/tty1: bash[5801], init[5800], su[5842]
                                No VM guests are running outdated hypervisor (qemu) binaries on this host.
                                • KrisiunK Krisiun
                                  @bahnuhr
                                  Und wat für einen ?
                                  bahnuhrB Online
                                  bahnuhrB Online
                                  bahnuhr
                                  #140
                                  @bahnuhr
                                  Und wat für einen ?
                                  Musst es ja nicht verraten.
                                  War nur neugierig.
                                  Danke.
                                  • bahnuhrB bahnuhr
                                    @bahnuhr
                                    Und wat für einen ?
                                    War nur neugierig.
                                    KrisiunK Offline
                                    KrisiunK Offline
                                    Krisiun
                                    #141
                                    @bahnuhr
                                    Und wat für einen ?
                                    War nur neugierig.
                                    Nein du hast mich falsch verstanden das ist doch kein Geheimnis aber ich bin jetzt wo anders beschäftigt und die daten habe ich doch nicht im kopf
                                    • KrisiunK Krisiun
                                      nodejs:
                                        Version table:
                                        libnode72 nodejs
                                      #142
                                      @krisiun
                                      sudo apt update
                                      sudo apt full-upgrade
                                        @krisiun
                                        sudo apt update
                                        KrisiunK Offline
                                        KrisiunK Offline
                                        Krisiun
                                        #143
                                        krisiun@Marek2:~$ sudo apt update
                                        Get:1 http://security.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
                                        Hit:2 https://deb.nodesource.com/node_18.x nodistro InRelease
                                        Hit:3 http://archive.ubuntu.com/ubuntu jammy InRelease
                                        Get:4 http://archive.ubuntu.com/ubuntu jammy-updates InRelease [119 kB]
                                        Get:5 http://archive.ubuntu.com/ubuntu jammy-backports InRelease [109 kB]
                                        Fetched 338 kB in 3s (98.9 kB/s)
                                        All packages are up to date.
                                        krisiun@Marek2:~$ sudo apt full-upgrade
                                        Calculating upgrade... Done
                                          libc-ares2
                                        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                          @krisiun
                                          100w
                                          Great SUNG Offline
                                          Great SUNG Offline
                                          Great SUN
                                          #144
                                          @oliverio Ich kann auch noch einen HP Mini-PC empfehlen 8GB Ram, 256GB SSD, 2,9Ghz CPU. Der maximale gemessene Verbrauch unter Last lag bei dem bei 25W. Durchschnitt eher bei 5W ;-)
                                          KrisiunK DJMarc75D 2 Antworten Letzte Antwort
