  4. iobroker zeschossen
    6.8k
iobroker zeschossen
175 Beiträge 9 Kommentatoren 48.7k Aufrufe 7 Beobachtet
  • KrisiunK Offline
    KrisiunK Offline
    Krisiun
    Hallo allerseits, ich habe gestern versucht Nodje auf die neueste Version zu aktualisieren und hab bestimmt was falsch gemacht. Jetzt startet iob überhaupt nicht mehr.
    Bei " iobroker start" über Konsole kommt:
    root@Marek2:~# iobroker start
    /usr/bin/node: 1: cannot create : Permission denied
    /usr/bin/node: 2: : not found
    /usr/bin/node: 4: Syntax error: Unterminated quoted string
    Wenn ich " iob diag " mache kommt das:
    Skript v.2023-06-20
    *** BASE SYSTEM ***
    Failed to connect to bus: Host is down
    model name      : Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz
    Docker          : false
    Virtualization  : wsl
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     18:46:07 up 27 min,  0 users,  load average: 0.52, 0.58, 0.59
    CPU threads: 8
    *** Time and Time Zones ***
    System has not been booted with systemd as init system (PID 1). Can't operate.
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:             16G        5.9G         10G         17M        223M         10G
    Swap:            30G          0B         30G
    Total:           46G        5.9G         40G
    Error: /proc must be mounted
      To mount /proc at boot you need an /etc/fstab line like:
          proc   /proc   proc    defaults
      In the meantime, run "mount proc /proc -t proc"
    *** FILESYSTEM ***
    Filesystem     Type   Size  Used Avail Use% Mounted on
    rootfs         lxfs   238G  195G   43G  83% /
    none           tmpfs  238G  195G   43G  83% /dev
    none           tmpfs  238G  195G   43G  83% /run
    none           tmpfs  238G  195G   43G  83% /run/lock
    none           tmpfs  238G  195G   43G  83% /run/shm
    none           tmpfs  238G  195G   43G  83% /run/user
    tmpfs          tmpfs  238G  195G   43G  83% /sys/fs/cgroup
    C:\            drvfs  238G  195G   43G  83% /mnt/c
    D:\            drvfs  932G  541G  391G  59% /mnt/d
    Show mounted filesystems (real ones only):
    TARGET   SOURCE FSTYPE OPTIONS
    /        rootfs lxfs   rw,noatime
    |-/mnt/c C:\    drvfs  rw,noatime,uid=0,gid=0,case=off
    `-/mnt/d D:\    drvfs  rw,noatime,uid=0,gid=0,case=off
    /var:
    428M    /var/
    330M    /var/lib
    157M    /var/lib/snapd/seed/snaps
    157M    /var/lib/snapd
    No journal files were found.
    Archived and active journals take up 0B in the file system.
    /opt/iobroker/backups:
    103M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    431M    /opt/iobroker/iobroker-data/
    285M    /opt/iobroker/iobroker-data/files
    107M    /opt/iobroker/iobroker-data/backup-objects
    72M     /opt/iobroker/iobroker-data/files/telegram.admin
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    15M     /opt/iobroker/iobroker-data/objects.jsonl
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
    *** NodeJS-Installation ***
    /home/iobroker/.diag.sh: line 177: /usr/bin/nodejs: cannot execute binary file: Exec format error
    /usr/bin/nodejs
    /home/iobroker/.diag.sh: line 178: /usr/bin/node: cannot execute binary file: Exec format error
    /usr/bin/node
    /mnt/c/Windows/system32/npm
    : not foundram Files/nodejs/npx: 2:
    : not foundram Files/nodejs/npx: 5:
    : not foundram Files/nodejs/npx: 7:
    : not foundram Files/nodejs/npx: 9:
    /mnt/c/Program Files/nodejs/npx: 10: Syntax error: word unexpected (expecting "in")
    /home/iobroker/.diag.sh: line 186: /usr/bin/nodejs: cannot execute binary file: Exec format error
    /home/iobroker/.diag.sh: line 187: /usr/bin/node: cannot execute binary file: Exec format error
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 12.22.9~dfsg-1ubuntu3
      Candidate: 12.22.9~dfsg-1ubuntu3
      Version table:
     *** 12.22.9~dfsg-1ubuntu3 500
            500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
            100 /var/lib/dpkg/status
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Core adapters versions
    js-controller:
    admin:
    javascript:
    Adapters from github:   0
    Adapter State
    ioBroker-Repositories
    Installed ioBroker-Instances
    Objects and States
    Objects:        0
    States:         0
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://dl.yarnpkg.com/debian stable InRelease: The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
    W: Failed to fetch https://dl.yarnpkg.com/debian/dists/stable/InRelease  The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Get:1 https://dl.yarnpkg.com/debian stable InRelease [17.1 kB]
    Hit:2 http://security.ubuntu.com/ubuntu jammy-security InRelease
    Hit:3 http://archive.ubuntu.com/ubuntu jammy InRelease
    Hit:4 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:5 http://archive.ubuntu.com/ubuntu jammy-backports InRelease
    Err:1 https://dl.yarnpkg.com/debian stable InRelease
    Fetched 17.1 kB in 3s (5230 B/s)
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    2023-10-07 21:49:27.501  - info: host.Marek2 instance system.adapter.kodi.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.502  - info: host.Marek2 instance system.adapter.tr-064.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.502  - info: host.Marek2 instance system.adapter.shelly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.502  - info: host.Marek2 stopInstance system.adapter.pushover.0 killing pid 9396
    2023-10-07 21:49:27.537  - info: host.Marek2 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.538  - info: host.Marek2 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.539  - info: host.Marek2 instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.634  - info: host.Marek2 stopInstance system.adapter.web.0 killing pid 10344
    2023-10-07 21:49:27.635  - info: host.Marek2 stopInstance system.adapter.philips-tv.0 killing pid 10481
    2023-10-07 21:49:27.647  - info: host.Marek2 instance system.adapter.sonoff.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.668  - info: host.Marek2 instance system.adapter.iot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.668  - info: host.Marek2 instance system.adapter.broadlink2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.730  - info: host.Marek2 instance system.adapter.info.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.730  - info: host.Marek2 instance system.adapter.yahka.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.730  - info: host.Marek2 instance system.adapter.tankerkoenig.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.765  - info: host.Marek2 instance system.adapter.firetv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.765  - info: host.Marek2 instance system.adapter.parcel.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.839  - info: host.Marek2 instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.840  - info: host.Marek2 instance system.adapter.philips-tv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:27.901  - info: host.Marek2 instance system.adapter.pushover.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:29.473  - info: tuya.0 (9456) terminating
    2023-10-07 21:49:29.475  - info: tuya.0 (9456) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-10-07 21:49:30.080  - info: host.Marek2 instance system.adapter.tuya.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-07 21:49:30.081  - info: host.Marek2 All instances are stopped.
    2023-10-07 21:49:30.150  - info: host.Marek2 terminated
    Kann mir da jemand helfen oder ist das schon ein hofnungsose Fahl?
    Thomas BraunT GlasfaserG 3 Antworten Letzte Antwort
    • KrisiunK Krisiun
      Skript v.2023-06-20
      *** BASE SYSTEM ***
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 8
      root
      /root
      root
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:            30G          0B         30G
      Total:           46G        5.9G         40G
      *** FILESYSTEM ***
      /var:
      428M    /var/
      330M    /var/lib
      157M    /var/lib/snapd
      /usr/bin/nodejs
      /usr/bin/node
      nodejs:
        Version table:
      ioBroker Status
      js-controller:
      admin:
      javascript:
      Adapter State
      Objects and States
      Objects:        0
      States:         0
      Pending Updates: 0
      @krisiun sagte in iobroker zeschossen:
      Was hast du denn genau gemacht?
      • KrisiunK Offline
        KrisiunK Offline
        Krisiun
        Das weiß ich jetzt nicht so genau aber ich denke ich habe falsche angaben gemacht
        KrisiunK Thomas BraunT 2 Antworten Letzte Antwort
        • KrisiunK Krisiun
          KrisiunK Offline
          KrisiunK Offline
          Krisiun
          Das habe ich eingegeben
          iobroker stop
          curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash -
          sudo apt install -y nodejs
          KrisiunK 1 Antwort Letzte Antwort
          • KrisiunK Krisiun
            iobroker stop
            KrisiunK Offline
            KrisiunK Offline
            Krisiun
            iobroker stop
            Aber es hat nicht geklappt dann habe ich weiter probiert und wahrscheinlich das war mein Fehler
            • KrisiunK Krisiun
              Das ist in Kombination mit einer root-shell eine denkbar ungünstige Situation...
              Da sollte man schon genau wissen, was man wie und warum macht.
              Leg dir einen user an, gibt dem sudo-Rechte und dann installierst du das nodesource-Repo danach:
              • KrisiunK Krisiun
                Skript v.2023-06-20
                *** BASE SYSTEM ***
                Docker          : false
                Kernel          : x86_64
                Userland        : amd64
                CPU threads: 8
                root
                /root
                root
                X-Server:       false
                Desktop:
                Terminal:
                *** MEMORY ***
                Swap:            30G          0B         30G
                Total:           46G        5.9G         40G
                *** FILESYSTEM ***
                /var:
                428M    /var/
                330M    /var/lib
                157M    /var/lib/snapd
                /usr/bin/nodejs
                /usr/bin/node
                nodejs:
                  Version table:
                ioBroker Status
                js-controller:
                admin:
                javascript:
                Adapter State
                Objects and States
                Objects:        0
                States:         0
                Pending Updates: 0
                GlasfaserG Offline
                GlasfaserG Offline
                Glasfaser
                root@Marek2:
                Das Thema dazu hatte wir schonmal und auch dich mehrmals dazu gewarnt !!
                https://forum.iobroker.net/post/897161
                • KrisiunK Offline
                  KrisiunK Offline
                  Krisiun
                  OK Sorry das kommt davon wenn man nicht auf Euch hört
                  GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                  • KrisiunK Krisiun
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Glasfaser
                    @krisiun
                    Auch hier ... ein Kommentar dazu ... zu WSL
                    https://forum.iobroker.net/post/897255
                    • KrisiunK Krisiun
                      Wird ja nicht ohne Grund immer wieder darauf hingewiesen.
                      Wer nicht hören will, muss ein Backup haben.
                      Oder seinen Umgang mit dem System ändern.
                      • KrisiunK Offline
                        KrisiunK Offline
                        Krisiun
                        Ich habe schon verstanden. Macht mich nicht noch mehr fertig als ich schon bin.
                        Die istallation auf Windows rechner war für mich für Testzwecke. Ich wollte nicht riskieren aufm rassby zu experimentieren.
                        Eins möchte ich von Euch wissen? Kann man die installation noch retten oder nicht?
                        Thomas BraunT bahnuhrB 2 Antworten Letzte Antwort
                        • KrisiunK Krisiun
                          Skript v.2023-06-20
                          *** BASE SYSTEM ***
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : amd64
                          CPU threads: 8
                          root
                          /root
                          root
                          X-Server:       false
                          Desktop:
                          Terminal:
                          *** MEMORY ***
                          Swap:            30G          0B         30G
                          Total:           46G        5.9G         40G
                          *** FILESYSTEM ***
                          /var:
                          428M    /var/
                          330M    /var/lib
                          157M    /var/lib/snapd
                          /usr/bin/nodejs
                          /usr/bin/node
                          nodejs:
                            Version table:
                          ioBroker Status
                          js-controller:
                          admin:
                          javascript:
                          Adapter State
                          Objects and States
                          Objects:        0
                          States:         0
                          Pending Updates: 0
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Glasfaser
                          eine Normal Abfrage funktioniert ja noch nicht mal.
                          Ich denke mal da ist Linux zerschossen
                          • KrisiunK Krisiun
                            Keine Ahnung. Du kannst ja nicht sagen, was du da wo mit root-Rechten herumgefummelt hast.
                            Ich würde zuerstmal ordentliche user anlegen, den root dann in Ruh' lassen und ordentlich das nodesource-Repo anlegen.
                            • KrisiunK Krisiun
                              bahnuhrB Online
                              bahnuhrB Online
                              bahnuhr
                              Hab ich alles hinter mir.
                              Kauf dir ein ordentliches System (z.B. nuc) und mach proxmox drauf. Dann kannst du ganz schnell ein backup machen; und dies evtl. wieder zurück spielen.
                              Fazit:
                              nuc kaufen
                              proxmox drauf
                              backup von deinem backitup einspielen.
                              Fertig.
                              P.S.
                              was ist ein rassby ?
                              Danke.
                              • GlasfaserG Glasfaser
                                @glasfaser sagte in iobroker zeschossen:
                                Ich vermute, das wsl bootet nicht per systemd.
                                Edit:
                                Näheres hier
                                https://devblogs.microsoft.com/commandline/systemd-support-is-now-available-in-wsl/
                                  Edit:
                                  Näheres hier
                                  KrisiunK Offline
                                  KrisiunK Offline
                                  Krisiun
                                  @thomas-braun sagte in iobroker zeschossen:
                                  Nein leider nicht
                                  • bahnuhrB bahnuhr
                                    Fazit:
                                    nuc kaufen
                                    proxmox drauf
                                    Fertig.
                                    P.S.
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    Glasfaser
                                    @bahnuhr sagte in iobroker zeschossen:
                                    KrisiunK bahnuhrB 2 Antworten Letzte Antwort
                                      KrisiunK Offline
                                      KrisiunK Offline
                                      Krisiun
                                      Raspberry Pi
                                        bahnuhrB Online
                                        bahnuhrB Online
                                        bahnuhr
                                        @glasfaser
                                        Das ist cool.
                                        Bild bitte per Link ;-)
                                        Danke.
                                        • KrisiunK Offline
                                          KrisiunK Offline
                                          Krisiun
                                          Danke Euch trotzdem. Dann muss ich wohl wieder von vorne anfangen 😧
