  4. iobroker zeschossen
    6.8k
iobroker zeschossen
175 Beiträge 9 Kommentatoren 48.7k Aufrufe 7 Beobachtet
  • KrisiunK Krisiun
    Kann aber trotzdem den iob nicht starten. Gleiche Fehler.
    krisiun@Marek2:/root$ iobroker start
    /usr/bin/node: 1: cannot create : Permission denied
    /usr/bin/node: 2: : not found
    /usr/bin/node: 4: Syntax error: Unterminated quoted string
    #81
    @krisiun
    NICHT SO SCHNELL!
    Du bist ja auch noch nicht fertig...
    sudo apt update
    cd
    sagt?
    KrisiunK 1 Antwort Letzte Antwort
      @krisiun
      NICHT SO SCHNELL!
      sudo apt update
      cd
      sagt?
      KrisiunK Offline
      KrisiunK Offline
      Krisiun
      #82
      krisiun@Marek2:/root$ sudo apt update
      Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
      Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
      Hit:3 http://security.ubuntu.com/ubuntu jammy-security InRelease
      Get:4 https://dl.yarnpkg.com/debian stable InRelease [17.1 kB]
      Hit:5 http://archive.ubuntu.com/ubuntu jammy-backports InRelease
      Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
      Err:4 https://dl.yarnpkg.com/debian stable InRelease
        The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
      Err:6 https://deb.nodesource.com/node_18.x nodistro InRelease
        The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 2F59B5F99B1BE0B4
      Fetched 17.1 kB in 4s (4719 B/s)
      Reading package lists... Done
      Building dependency tree... Done
      1 package can be upgraded. Run 'apt list --upgradable' to see it.
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://dl.yarnpkg.com/debian stable InRelease: The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://deb.nodesource.com/node_18.x nodistro InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 2F59B5F99B1BE0B4
      W: Failed to fetch https://deb.nodesource.com/node_18.x/dists/nodistro/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 2F59B5F99B1BE0B4
      W: Failed to fetch https://dl.yarnpkg.com/debian/dists/stable/InRelease  The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      • KrisiunK Krisiun
        #83
        @krisiun
        Du solltest doch yarn löschen...
        sudo rm /etc/apt/sources.list.d/yar*
          @krisiun
          KrisiunK Offline
          KrisiunK Offline
          Krisiun
          #84
          Dann sag mir bitte, bitte wie? Sorry aber das ist mir auch schon unangenehm dass ich das nicht schnalle
          • KrisiunK Krisiun
            #85
            @krisiun
            Dann
            sudo rm `sudo find / -name nodesource.gpg`
            sudo rm `sudo find / -name nodesource.key`
            sudo apt install -y ca-certificates curl gnupg
            sudo mkdir -p /etc/apt/keyrings
            curl -fsSL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo gpg --dearmor -o /etc/apt/keyrings/nodesource.gpg
            sudo apt update
            • KrisiunK Krisiun
              #86
              @krisiun sagte in iobroker zeschossen:
              Steht doch da.
                Steht doch da.
                KrisiunK Offline
                KrisiunK Offline
                Krisiun
                #87
                Ich bin dabei aber ich kanns nicht finden
                Thomas BraunT bahnuhrB 2 Antworten Letzte Antwort
                • KrisiunK Krisiun
                  #88
                  Was? Dein Terminal?
                    Was? Dein Terminal?
                    KrisiunK Offline
                    KrisiunK Offline
                    Krisiun
                    #89
                    wo ich das löschen kann
                    • KrisiunK Krisiun
                      bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      #90
                      Du sollst da nichts finden.
                      Sondern dich per putty (oder was du auch immer nimmst) einloggen.
                      Und dann in der konsole den Befehl eingeben.
                      Mehr nicht.
                      Danke.
                      • KrisiunK Krisiun
                        #91
                        @krisiun
                        MIT DEM BEFEHL:
                        Klickst du da mit einem Filebrowser wild durch die Gegend? Lass das!
                        KrisiunK 2 Antworten Letzte Antwort
                          @krisiun
                          MIT DEM BEFEHL:
                          KrisiunK Offline
                          KrisiunK Offline
                          Krisiun
                          #92
                          krisiun@Marek2:/root$ sudo rm /etc/apt/sources.list.d/yar*
                          rm: cannot remove '/etc/apt/sources.list.d/yar*': No such file or directory
                            @krisiun
                            MIT DEM BEFEHL:
                            KrisiunK Offline
                            KrisiunK Offline
                            Krisiun
                            #93
                            Ist wohl wieder falsch?
                            • KrisiunK Krisiun
                              #94
                              @krisiun
                              cd
                              ls -lAh /etc/apt/sources.list.d/
                                @krisiun
                                cd
                                KrisiunK Offline
                                KrisiunK Offline
                                Krisiun
                                #95
                                krisiun@Marek2:/root$ ls -lAh /etc/apt/sources.list.d/
                                total 0
                                -rw-r--r-- 1 root root 100 Oct  8 21:12 nodesource.list
                                -rw-r--r-- 1 root root 202 Nov 22  2022 nodesource.list.distUpgrade
                                -rw-r--r-- 1 root root 109 Oct  8 21:11 nodesource.list.save
                                • KrisiunK Krisiun
                                  total 0
                                  #96
                                  @krisiun
                                  cd
                                  sudo rm /etc/apt/sources.list.d/nodesource.list.*
                                  sudo apt update
                                  • KrisiunK Krisiun
                                    Hab alles gemacht
                                    #97
                                    Hab alles gemacht
                                    zeigen!
                                    incl. Eingabe
                                      @krisiun
                                      cd
                                      sudo apt update
                                      KrisiunK Offline
                                      KrisiunK Offline
                                      Krisiun
                                      #98
                                      krisiun@Marek2:/root$ cd
                                      krisiun@Marek2:~$ sudo rm /etc/apt/sources.list.d/nodesource.list.*
                                      krisiun@Marek2:~$ sudo apt update
                                      Hit:1 https://deb.nodesource.com/node_18.x nodistro InRelease
                                      Hit:2 http://security.ubuntu.com/ubuntu jammy-security InRelease
                                      Hit:3 http://archive.ubuntu.com/ubuntu jammy InRelease
                                      Hit:4 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
                                      Err:1 https://deb.nodesource.com/node_18.x nodistro InRelease
                                      • KrisiunK Krisiun
                                        #99
                                        @krisiun
                                        Wir nähern uns langsam an...
                                        sudo apt update
                                          @krisiun
                                          sudo apt update
                                          KrisiunK Offline
                                          KrisiunK Offline
                                          Krisiun
                                          #100
                                          @thomas-braun sagte in iobroker zeschossen:
                                          @krisiun
                                          sudo apt update
                                          Heißt das jetzt ich soll die Befehle einzeln eingeben?
