  4. iobroker zeschossen
    6.8k
iobroker zeschossen
175 Beiträge 9 Kommentatoren 48.7k Aufrufe 7 Beobachtet
    @krisiun
    Du solltest doch yarn löschen...
    sudo rm /etc/apt/sources.list.d/yar*
    KrisiunK Offline
    KrisiunK Offline
    Krisiun
    #84
    Dann sag mir bitte, bitte wie? Sorry aber das ist mir auch schon unangenehm dass ich das nicht schnalle
    • KrisiunK Krisiun
      krisiun@Marek2:/root$ sudo apt update
      Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
      Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
      Hit:3 http://security.ubuntu.com/ubuntu jammy-security InRelease
      Get:4 https://dl.yarnpkg.com/debian stable InRelease [17.1 kB]
      Hit:5 http://archive.ubuntu.com/ubuntu jammy-backports InRelease
      Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
      Err:4 https://dl.yarnpkg.com/debian stable InRelease
        The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
      Err:6 https://deb.nodesource.com/node_18.x nodistro InRelease
        The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 2F59B5F99B1BE0B4
      Fetched 17.1 kB in 4s (4719 B/s)
      Reading package lists... Done
      1 package can be upgraded. Run 'apt list --upgradable' to see it.
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://dl.yarnpkg.com/debian stable InRelease: The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://deb.nodesource.com/node_18.x nodistro InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 2F59B5F99B1BE0B4
      W: Failed to fetch https://deb.nodesource.com/node_18.x/dists/nodistro/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 2F59B5F99B1BE0B4
      W: Failed to fetch https://dl.yarnpkg.com/debian/dists/stable/InRelease  The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      #85
      @krisiun
      Dann
      sudo rm `sudo find / -name nodesource.gpg`
      sudo rm `sudo find / -name nodesource.key`
      sudo apt install -y ca-certificates curl gnupg
      sudo mkdir -p /etc/apt/keyrings
      curl -fsSL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo gpg --dearmor -o /etc/apt/keyrings/nodesource.gpg
      sudo apt update
      • KrisiunK Krisiun
        #86
        @krisiun sagte in iobroker zeschossen:
        Steht doch da.
        KrisiunK 1 Antwort Letzte Antwort
          Steht doch da.
          KrisiunK Offline
          KrisiunK Offline
          Krisiun
          #87
          Ich bin dabei aber ich kanns nicht finden
          Thomas BraunT bahnuhrB 2 Antworten Letzte Antwort
          • KrisiunK Krisiun
            #88
            Was? Dein Terminal?
              Was? Dein Terminal?
              KrisiunK Offline
              KrisiunK Offline
              Krisiun
              #89
              wo ich das löschen kann
              • KrisiunK Krisiun
                bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                #90
                Du sollst da nichts finden.
                Sondern dich per putty (oder was du auch immer nimmst) einloggen.
                Und dann in der konsole den Befehl eingeben.
                Mehr nicht.
                Danke.
                • KrisiunK Krisiun
                  #91
                  @krisiun
                  MIT DEM BEFEHL:
                  Klickst du da mit einem Filebrowser wild durch die Gegend? Lass das!
                  KrisiunK 2 Antworten Letzte Antwort
                    @krisiun
                    MIT DEM BEFEHL:
                    KrisiunK Offline
                    KrisiunK Offline
                    Krisiun
                    #92
                    krisiun@Marek2:/root$ sudo rm /etc/apt/sources.list.d/yar*
                    rm: cannot remove '/etc/apt/sources.list.d/yar*': No such file or directory
                      @krisiun
                      MIT DEM BEFEHL:
                      KrisiunK Offline
                      KrisiunK Offline
                      Krisiun
                      #93
                      Ist wohl wieder falsch?
                      • KrisiunK Krisiun
                        #94
                        @krisiun
                        cd
                        ls -lAh /etc/apt/sources.list.d/
                          @krisiun
                          cd
                          KrisiunK Offline
                          KrisiunK Offline
                          Krisiun
                          #95
                          krisiun@Marek2:/root$ ls -lAh /etc/apt/sources.list.d/
                          total 0
                          -rw-r--r-- 1 root root 100 Oct  8 21:12 nodesource.list
                          -rw-r--r-- 1 root root 202 Nov 22  2022 nodesource.list.distUpgrade
                          -rw-r--r-- 1 root root 109 Oct  8 21:11 nodesource.list.save
                          • KrisiunK Krisiun
                            total 0
                            #96
                            @krisiun
                            cd
                            sudo rm /etc/apt/sources.list.d/nodesource.list.*
                            sudo apt update
                            • KrisiunK Krisiun
                              Hab alles gemacht
                              #97
                              Hab alles gemacht
                              zeigen!
                              incl. Eingabe
                                @krisiun
                                cd
                                sudo apt update
                                KrisiunK Offline
                                KrisiunK Offline
                                Krisiun
                                #98
                                krisiun@Marek2:/root$ cd
                                krisiun@Marek2:~$ sudo rm /etc/apt/sources.list.d/nodesource.list.*
                                krisiun@Marek2:~$ sudo apt update
                                Hit:1 https://deb.nodesource.com/node_18.x nodistro InRelease
                                Hit:2 http://security.ubuntu.com/ubuntu jammy-security InRelease
                                Hit:3 http://archive.ubuntu.com/ubuntu jammy InRelease
                                Hit:4 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
                                Err:1 https://deb.nodesource.com/node_18.x nodistro InRelease
                                • KrisiunK Krisiun
                                  #99
                                  @krisiun
                                  Wir nähern uns langsam an...
                                  sudo apt update
                                    @krisiun
                                    sudo apt update
                                    KrisiunK Offline
                                    KrisiunK Offline
                                    Krisiun
                                    #100
                                    @thomas-braun sagte in iobroker zeschossen:
                                    @krisiun
                                    sudo apt update
                                    Heißt das jetzt ich soll die Befehle einzeln eingeben?
                                    • KrisiunK Krisiun
                                      @krisiun
                                      sudo apt update
                                      #101
                                      Zeilenweise am besten.
                                      bahnuhrB KrisiunK 7 Antworten Letzte Antwort
                                        bahnuhrB Online
                                        bahnuhrB Online
                                        bahnuhr
                                        #102
                                        oder
                                        markieren mit der Maus (natürlich zeilenweise)
                                        Strg+c
                                        und in putty rechte Maustaste
                                        -> dann steht er drin.
                                        Danke.
                                        Thomas BraunT KrisiunK 2 Antworten Letzte Antwort
                                        • bahnuhrB bahnuhr
                                          oder
                                          Strg+c
                                          #103
                                          @bahnuhr
                                          Hatte ich bewusst nicht genannt, sonst spuken da wieder Steuerzeichen von seiner Maus durch das Terminal.
