  4. iobroker zeschossen
    6.8k
iobroker zeschossen
175 Beiträge 9 Kommentatoren 48.7k Aufrufe 7 Beobachtet
    @krisiun
    MIT DEM BEFEHL:
    sudo rm /etc/apt/sources.list.d/yar*
    Klickst du da mit einem Filebrowser wild durch die Gegend? Lass das!
    KrisiunK Offline
    KrisiunK Offline
    Krisiun
    #92
    krisiun@Marek2:/root$ sudo rm /etc/apt/sources.list.d/yar*
    rm: cannot remove '/etc/apt/sources.list.d/yar*': No such file or directory
      @krisiun
      MIT DEM BEFEHL:
      KrisiunK Offline
      KrisiunK Offline
      Krisiun
      #93
      Ist wohl wieder falsch?
      • KrisiunK Krisiun
        #94
        @krisiun
        cd
        ls -lAh /etc/apt/sources.list.d/
        KrisiunK 1 Antwort Letzte Antwort
          @krisiun
          cd
          KrisiunK Offline
          KrisiunK Offline
          Krisiun
          #95
          krisiun@Marek2:/root$ ls -lAh /etc/apt/sources.list.d/
          total 0
          -rw-r--r-- 1 root root 100 Oct  8 21:12 nodesource.list
          -rw-r--r-- 1 root root 202 Nov 22  2022 nodesource.list.distUpgrade
          -rw-r--r-- 1 root root 109 Oct  8 21:11 nodesource.list.save
          • KrisiunK Krisiun
            total 0
            #96
            @krisiun
            cd
            sudo rm /etc/apt/sources.list.d/nodesource.list.*
            sudo apt update
            • KrisiunK Krisiun
              Hab alles gemacht
              #97
              @krisiun sagte in iobroker zeschossen:
              Hab alles gemacht
              zeigen!
              incl. Eingabe
                @krisiun
                cd
                sudo apt update
                KrisiunK Offline
                KrisiunK Offline
                Krisiun
                #98
                krisiun@Marek2:/root$ cd
                krisiun@Marek2:~$ sudo rm /etc/apt/sources.list.d/nodesource.list.*
                krisiun@Marek2:~$ sudo apt update
                Hit:1 https://deb.nodesource.com/node_18.x nodistro InRelease
                Hit:2 http://security.ubuntu.com/ubuntu jammy-security InRelease
                Hit:3 http://archive.ubuntu.com/ubuntu jammy InRelease
                Hit:4 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
                Hit:5 http://archive.ubuntu.com/ubuntu jammy-backports InRelease
                Err:1 https://deb.nodesource.com/node_18.x nodistro InRelease
                  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 2F59B5F99B1BE0B4
                Reading package lists... Done
                1 package can be upgraded. Run 'apt list --upgradable' to see it.
                W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://deb.nodesource.com/node_18.x nodistro InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 2F59B5F99B1BE0B4
                W: Failed to fetch https://deb.nodesource.com/node_18.x/dists/nodistro/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 2F59B5F99B1BE0B4
                W: Some index files failed to download. They have been ignored, or old ones used instead.
                • KrisiunK Krisiun
                  #99
                  @krisiun
                  Wir nähern uns langsam an...
                  sudo rm `sudo find / -name nodesource.gpg`
                  sudo rm `sudo find / -name nodesource.key`
                  sudo apt install -y ca-certificates curl gnupg
                  sudo mkdir -p /etc/apt/keyrings
                  curl -fsSL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo gpg --dearmor -o /etc/apt/keyrings/nodesource.gpg
                  sudo apt update
                    @krisiun
                    sudo apt update
                    KrisiunK Offline
                    KrisiunK Offline
                    Krisiun
                    #100
                    @thomas-braun sagte in iobroker zeschossen:
                    @krisiun
                    sudo apt update
                    Heißt das jetzt ich soll die Befehle einzeln eingeben?
                    • KrisiunK Krisiun
                      @krisiun
                      sudo apt update
                      #101
                      Zeilenweise am besten.
                      bahnuhrB KrisiunK 7 Antworten Letzte Antwort
                        bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        #102
                        oder
                        markieren mit der Maus (natürlich zeilenweise)
                        Strg+c
                        und in putty rechte Maustaste
                        -> dann steht er drin.
                        Danke.
                        Thomas BraunT KrisiunK 2 Antworten Letzte Antwort
                        • bahnuhrB bahnuhr
                          oder
                          Strg+c
                          #103
                          @bahnuhr
                          Hatte ich bewusst nicht genannt, sonst spuken da wieder Steuerzeichen von seiner Maus durch das Terminal.
                          • bahnuhrB bahnuhr
                            oder
                            Strg+c
                            KrisiunK Offline
                            KrisiunK Offline
                            Krisiun
                            #104
                            @bahnuhr sagte in iobroker zeschossen:
                            oder
                            Strg+c
                            Danke das weiß ich
                              @bahnuhr
                              bahnuhrB Online
                              bahnuhrB Online
                              bahnuhr
                              #105
                              @bahnuhr
                              Tschuldigung
                              Aber es ist gerade so spannend zwischen euch zwei.
                              Besser als jeder Sonntags Krimi ;-)
                              Danke.
                                KrisiunK Offline
                                KrisiunK Offline
                                Krisiun
                                #106
                                Das erste Befehl
                                krisiun@Marek2:~$ sudo rm `sudo find / -name nodesource.gpg`
                                find: ‘/mnt/c/$Recycle.Bin/S-1-5-18’: Permission denied
                                find: ‘/mnt/c/$Recycle.Bin/S-1-5-21-788002034-1723751684-3648524827-500’: Permission denied
                                find: ‘/mnt/c/Config.Msi’: Permission denied
                                find: ‘/mnt/c/Documents and Settings’: Permission denied
                                find: ‘/mnt/c/Dokumente und Einstellungen’: Permission denied
                                find: ‘/mnt/c/PerfLogs’: Permission denied
                                find: ‘/mnt/c/Program Files/Bitdefender/Bitdefender Security/Antiphishing_20759_007’: Permission denied
                                find: ‘/mnt/c/Program Files/Bitdefender/Bitdefender Security/asengines_06558_003’: Permission denied
                                find: ‘/mnt/c/Program Files/Bitdefender/Bitdefender Security/asengines_06559_004’: Permission denied
                                find: ‘/mnt/c/Program Files/Bitdefender/Bitdefender Security/atc/ATC_05108_076’: Permission denied
                                find: ‘/mnt/c/Program Files/Bitdefender/Bitdefender Security/atc/ATC_05109_077’: Permission denied
                                find: ‘/mnt/c/Program Files/Bitdefender/Bitdefender Security/ctc2/ctc2_00084_002’: Permission denied
                                find: ‘/mnt/c/Program Files/Bitdefender/Bitdefender Security/guster/guster_00219_005’: Permission denied
                                find: ‘/mnt/c/Program Files/Common Files/Bitdefender/Bitdefender Threat Scanner/Antivirus_71693_081’: Permission denied
                                find: ‘/mnt/c/Program Files/Common Files/Bitdefender/Bitdefender Threat Scanner/Antivirus_71694_082’: Permission denied
                                find: ‘/mnt/c/Program Files/Gemeinsame Dateien’: Permission denied
                                find: ‘/mnt/c/Program Files/Windows Defender Advanced Threat Protection/Classification/Configuration’: Permission denied
                                find: ‘/mnt/c/Program Files/WindowsApps’: Permission denied
                                find: ‘/mnt/c/Program Files (x86)/Google/CrashReports’: Permission denied
                                find: ‘/mnt/c/ProgramData/Ashampoo Backup/control/plans’: Permission denied
                                find: ‘/mnt/c/ProgramData/Ashampoo Backup PB/control/plans’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Crypto/PCPKSP/WindowsAIK’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Diagnosis’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Network/Downloader’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Provisioning/AssetCache’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Search/Data’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/SmsRouter’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Spectrum’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/AppRepository’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/LfSvc’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/Models’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/PackagedEventProviders’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/Power Efficiency Diagnostics’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/SystemData’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/AppCrash_ABService.exe_a6e99a4b0f55d3311682c67cee6817dec2ee5c_4cc5d8b8_791f6666-5ca8-4aed-8bdf-df1d054c3380’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/AppCrash_bad_module_info_1eba89dbf420a62f833a4ce282376bda3656d4_85207d7d_cc173f9e-1a13-436c-8eac-a5f89533a608’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/AppCrash_bad_module_info_26851ced9dceca7ff813c34112d2afbecefcef_85207d7d_479dd9a9-5c5b-47eb-a696-d63e159d21ca’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/AppCrash_ParameterService_2966e6b2ec77d0d13ca7f84231d73477da1b3ca2_83365c01_1a752bf0-56dd-4159-84e4-5a1eeb3c2a7b’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/AppHang_Power_58f93056b11115583a30254ff7c47d85736e6f_00000000_8b1bedf3-6037-4c12-8de5-8f5304bfb58a’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3025__2013ccf7dd2c6a38017706ea8bcb9e9b5a68d_00000000_9592d1a6-e983-4afd-a02b-8282b2caeff8’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_1fa6896623bee99db5439d1856d6a665dafa764_00000000_14f9904e-a128-457c-b9f7-3138cc1a7cb6’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_1fa6896623bee99db5439d1856d6a665dafa764_00000000_37e7f2f6-93a8-4697-bf6f-2de97f1207d2’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_1fa6896623bee99db5439d1856d6a665dafa764_00000000_874bde03-cfad-4f88-9f49-656e5ed05588’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_1fa6896623bee99db5439d1856d6a665dafa764_00000000_a237e08f-c42d-4dba-aa81-76e3a7ce0ef9’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_1fa6896623bee99db5439d1856d6a665dafa764_00000000_b61e0910-ff31-4442-8532-4cadb49536dd’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_1fa6896623bee99db5439d1856d6a665dafa764_00000000_ddbd0615-dd98-4470-9159-68fed10dbf25’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_2626ccbb36305544119092c1b32bb995ab51af9c_00000000_2e88686f-15e9-4632-bd2b-4be0faebc0bb’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_b4558307420184bedaceb16561f78f95ddfdeab_00000000_0cd3eb45-d373-4308-9349-fcf66b4d20f7’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_b4558307420184bedaceb16561f78f95ddfdeab_00000000_6df7ff92-5560-4237-9260-cbfcc9d7be34’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_b4558307420184bedaceb16561f78f95ddfdeab_00000000_82268fc1-6a1a-442b-a6a4-06ae48424016’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_b4558307420184bedaceb16561f78f95ddfdeab_00000000_f5db7678-b8a5-466b-a338-837401009ffc’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_bb135ba94395484d9d9de7e3869de2717cb1a_00000000_19f4d8dd-2d46-41d1-b404-ef56ea1bd084’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_bb135ba94395484d9d9de7e3869de2717cb1a_00000000_393f130b-6dd7-41d1-a57d-261c3e5ee0cf’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_bb135ba94395484d9d9de7e3869de2717cb1a_00000000_5c444dab-125d-43d5-ace1-0174d5538939’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_bb135ba94395484d9d9de7e3869de2717cb1a_00000000_8326e675-0e7c-4808-b732-d42ef4fa9818’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_bb135ba94395484d9d9de7e3869de2717cb1a_00000000_a9a4dfe4-1e88-46ff-a32b-1a628b4c4626’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_bb135ba94395484d9d9de7e3869de2717cb1a_00000000_cd79d4bd-16b1-4677-8e95-b60a7ce29eff’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_d9fbae6febf87e5988378f95c9721aead7c6f58b_00000000_40cb612b-74d9-444d-b52c-3959f0bee3fa’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_d9fbae6febf87e5988378f95c9721aead7c6f58b_00000000_69cd1897-7f4b-4b6e-bb76-499bf2e2f73d’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_d9fbae6febf87e5988378f95c9721aead7c6f58b_00000000_868d6bd2-d22b-40c5-8ca5-8cc59ed305ed’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_d9fbae6febf87e5988378f95c9721aead7c6f58b_00000000_caacc5b9-27a2-4141-8196-98fec2b9b4cb’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_d9fbae6febf87e5988378f95c9721aead7c6f58b_00000000_d756fa5f-c1c0-4f82-bff2-cb2e7dd8ca00’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_e15b8ce8e18dbc4c3bd576b24c3efe7887a8871_00000000_0bf8e3c7-f37a-4666-be88-9e6ed7a37988’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_e15b8ce8e18dbc4c3bd576b24c3efe7887a8871_00000000_20d10a72-e8c5-4287-847a-9e0b14c27218’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_e15b8ce8e18dbc4c3bd576b24c3efe7887a8871_00000000_30fd5b84-77b2-48c0-a0c9-0d3b4d605df4’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_e15b8ce8e18dbc4c3bd576b24c3efe7887a8871_00000000_3c5c0ec7-0a73-45f8-93df-bb51a08ed873’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_e15b8ce8e18dbc4c3bd576b24c3efe7887a8871_00000000_452db7e2-bd67-4f1d-bf96-b6d853aff563’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_e15b8ce8e18dbc4c3bd576b24c3efe7887a8871_00000000_66d8c94a-27d3-4862-b60f-014a5f29ec0d’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_e15b8ce8e18dbc4c3bd576b24c3efe7887a8871_00000000_66faefef-44d8-4f05-abd2-66a5b5f0c6e3’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_e15b8ce8e18dbc4c3bd576b24c3efe7887a8871_00000000_6ed1c4bb-0bf7-4c43-8911-1a2c2c60f221’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_e15b8ce8e18dbc4c3bd576b24c3efe7887a8871_00000000_74db3675-e0a2-47f5-a05d-eaf5d2f2d733’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_e15b8ce8e18dbc4c3bd576b24c3efe7887a8871_00000000_7a227fc1-7298-4e11-8441-5bded7a4e4f9’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_e15b8ce8e18dbc4c3bd576b24c3efe7887a8871_00000000_948db4c6-9068-4c65-9fa0-cb0cbd896797’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_e15b8ce8e18dbc4c3bd576b24c3efe7887a8871_00000000_b059df9b-ff5a-46d6-b926-86418b2b6d61’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_e15b8ce8e18dbc4c3bd576b24c3efe7887a8871_00000000_b14f646e-ce87-4e3b-9029-e97daecbece3’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_e15b8ce8e18dbc4c3bd576b24c3efe7887a8871_00000000_b19bd3ac-a023-4bd4-9125-d79240594992’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_e15b8ce8e18dbc4c3bd576b24c3efe7887a8871_00000000_b9604065-1070-4202-86d5-a2bbee118f9d’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_e15b8ce8e18dbc4c3bd576b24c3efe7887a8871_00000000_dcf17046-5add-4a72-bd42-66393b0e140a’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_e15b8ce8e18dbc4c3bd576b24c3efe7887a8871_00000000_ec885644-bc8c-43f5-9a28-1d0ade9a8414’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_e15b8ce8e18dbc4c3bd576b24c3efe7887a8871_00000000_ee31aaba-eab6-4141-a3cf-c3e2c3be977d’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_e15b8ce8e18dbc4c3bd576b24c3efe7887a8871_00000000_ff62cd26-e544-4bf6-87a7-9d3de6891082’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_e8ef6fd0b76b81b72b3c93d2d1697a162fdf283c_00000000_11828b94-e93d-4b97-872f-46eabcb48a2c’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_e8ef6fd0b76b81b72b3c93d2d1697a162fdf283c_00000000_14e461c3-8265-45e1-a6df-6a3033e944f7’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_e8ef6fd0b76b81b72b3c93d2d1697a162fdf283c_00000000_3dc18f9c-0f3c-4c5e-8420-a7aefcb1d769’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_e8ef6fd0b76b81b72b3c93d2d1697a162fdf283c_00000000_a605d129-30d9-44a9-bf5a-213852cd0ced’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_e8ef6fd0b76b81b72b3c93d2d1697a162fdf283c_00000000_aa2bed10-b178-4d83-aaf5-1576864c0c1e’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205_e8ef6fd0b76b81b72b3c93d2d1697a162fdf283c_00000000_adfb2c3a-fa0d-4dec-9b52-4a360362047a’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205__774444131b43596279a9bec84157e98956a3231e_00000000_3b3882f2-68cb-4a87-8736-53082e0ee6c0’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205__774444131b43596279a9bec84157e98956a3231e_00000000_c119d682-f737-4b21-b064-c6ecd8e998aa’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3205__774444131b43596279a9bec84157e98956a3231e_00000000_fc240b0a-d2b1-4546-a964-f77fafd5c4fd’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3266_535d3dfc5268afb59e5ddd6898e9eb9afef4f370_00000000_1753502c-29bd-4bd8-9d9d-5b7b80945aad’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3266_535d3dfc5268afb59e5ddd6898e9eb9afef4f370_00000000_413dd79a-5ef0-4814-b995-7c4bf3fe19a9’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3266_54c091fd2d3a1c16416ff021d2ce675e32eba_00000000_048acd45-4162-4913-9124-e3eb3a8572d3’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3266_54c091fd2d3a1c16416ff021d2ce675e32eba_00000000_0ba32cd9-1206-478a-a10d-42250e62cd68’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3266_54c091fd2d3a1c16416ff021d2ce675e32eba_00000000_2f8fe712-131a-40ff-a3a9-898d94ccc61e’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3266_54c091fd2d3a1c16416ff021d2ce675e32eba_00000000_7c6478a7-39b8-4927-966d-c4b1f804ece0’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3266_54c091fd2d3a1c16416ff021d2ce675e32eba_00000000_92bb4de5-42dc-47f6-9f03-2a80251fb628’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3266_54c091fd2d3a1c16416ff021d2ce675e32eba_00000000_9ae5678f-399f-4fa4-a462-38e8ddb4db6d’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3266_54c091fd2d3a1c16416ff021d2ce675e32eba_00000000_df2132d7-6169-440b-a3cd-de060d7bb7f8’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3266_54c091fd2d3a1c16416ff021d2ce675e32eba_00000000_f7737ee5-c313-4f4f-a902-722854cf8fbe’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3266_702fd01c21e3402939e5de31d38b533217ea84c9_00000000_08c38cc6-d658-47ec-a51e-3026985a0029’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3266_702fd01c21e3402939e5de31d38b533217ea84c9_00000000_5735cd16-7802-4305-85fb-6f85437fb2d5’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3266_702fd01c21e3402939e5de31d38b533217ea84c9_00000000_814c8284-7f6f-42a9-a956-0aa4de462455’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3266_702fd01c21e3402939e5de31d38b533217ea84c9_00000000_850a397e-f397-4665-bddb-a104d7564207’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3266_702fd01c21e3402939e5de31d38b533217ea84c9_00000000_89e03c14-d12f-4d8d-a09a-2188e801012a’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3266_702fd01c21e3402939e5de31d38b533217ea84c9_00000000_8c8a3599-3a04-4e81-9ba9-a9b90e8ff197’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3266_702fd01c21e3402939e5de31d38b533217ea84c9_00000000_b6f90071-d73c-4bcb-bdab-3ba932975f2a’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3266_702fd01c21e3402939e5de31d38b533217ea84c9_00000000_b82b0173-eb64-4146-850b-208bdacc17fc’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3266_702fd01c21e3402939e5de31d38b533217ea84c9_00000000_da9bb2a8-ecf9-4572-bb0f-5ce7004387af’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3266_702fd01c21e3402939e5de31d38b533217ea84c9_00000000_de4f72ad-65b6-44cc-9828-6ebd3e134c1a’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3266_702fd01c21e3402939e5de31d38b533217ea84c9_00000000_e63b7afe-10bd-4a31-8872-8d8fb9bd2043’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3266_995447fd1df45a6b2668eedd8c82219337b3b8dd_00000000_34348b7b-49b9-413e-bd8f-6aa7e52c467c’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3266_995447fd1df45a6b2668eedd8c82219337b3b8dd_00000000_f04d5af1-f989-4604-ad9d-1b85483197eb’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3266_b443f3285d57af3212064c6311cf3231fad0ff_00000000_91a5f4a0-4959-4049-adaf-dcd91f724ce7’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3266_eaf89f418f9f7ca901e8f7964a69b22fa567bf5_00000000_e77891d0-320a-43e1-8aa3-6f2151220b13’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3266__7fa23a45d4de580b3e6a7c89a5e3aef9ac82082_00000000_8ee5d074-2c77-4e1a-9df9-33c94be2e934’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3266__e99e255b2540e03ad063fc352c921d4209921c_00000000_59e6f36d-f0d1-47d8-aedb-799129bca101’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3385_3d4084361d84c5e91a6fb4e54581654eb444f4b3_00000000_2832893f-b282-4d4b-8f23-da02402de35c’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3385_3d4084361d84c5e91a6fb4e54581654eb444f4b3_00000000_38a77458-16b3-4889-af94-e74f113036d7’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3385_3d4084361d84c5e91a6fb4e54581654eb444f4b3_00000000_7d37e2db-05c5-469e-86cd-82d79d90f35e’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3385_66e91ac88f838d57d6526c6ea87728789172a31c_00000000_0f754e86-e18f-4a56-80bc-e08bd93d90cd’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3385_67a820722333a1aca48f4e53a506970d93faeae_00000000_98e5dbe1-e109-4aea-8e4f-0cd18e61070b’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3385_828b88eaedcbbc2fc5bc2cdcb28562a78fc389d_00000000_056da37e-003d-4dd6-aa20-89bfa89b93bf’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3385_828b88eaedcbbc2fc5bc2cdcb28562a78fc389d_00000000_911373a9-4d89-42a3-a7f5-05f9ba576aff’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3385_828b88eaedcbbc2fc5bc2cdcb28562a78fc389d_00000000_d665a658-ed22-4c3e-b66b-fb8cdc2762a0’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3385_a8cacc5929d1533dc8cd3f4d6496af4739e39_00000000_2614057b-9a2c-4643-8dd9-64e86c33fab9’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3385_a8cacc5929d1533dc8cd3f4d6496af4739e39_00000000_57b3a02e-d39d-42b6-9582-1e2dc355ec8d’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3385_a8cacc5929d1533dc8cd3f4d6496af4739e39_00000000_6378347c-612c-465d-bf28-fcc0082a8a75’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3385_a8cacc5929d1533dc8cd3f4d6496af4739e39_00000000_63d995f8-4abd-44f7-94e7-35ed3b150e1b’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3385_a8cacc5929d1533dc8cd3f4d6496af4739e39_00000000_cb07bcf6-94e2-417a-ae59-f14cd9bb9587’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3385_a8cacc5929d1533dc8cd3f4d6496af4739e39_00000000_e8669ec1-6898-4c1a-93d0-cc23a1016869’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3385_cca243ff617ce9eb4cd216be5f08691ca6ef3b_00000000_7ba3a8c4-da30-46c7-a222-92df2a879c7e’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3385_deebce902793d1dd858981df4710273fd2da185d_00000000_b5bdbce9-d1a9-438a-a338-095508571b54’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3385_deebce902793d1dd858981df4710273fd2da185d_00000000_d164be6d-13dc-417b-8865-35f989b310f7’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3385_deebce902793d1dd858981df4710273fd2da185d_00000000_d520153e-f856-4d60-8aa8-975d1a53a083’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3385_ebf29ada5155caef3c3b76b525d977f993528a_00000000_087f80d7-8ad9-4515-a4dc-6e6f5186c5ee’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3385_ebf29ada5155caef3c3b76b525d977f993528a_00000000_1c4d6b22-3a12-4b59-8725-0fb4de216fb4’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3385_ebf29ada5155caef3c3b76b525d977f993528a_00000000_64fbf1a1-5b5f-4113-8b0a-d195e5d79acf’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3385_ebf29ada5155caef3c3b76b525d977f993528a_00000000_aff2e447-c723-4ea7-a68e-540386923412’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3385_ebf29ada5155caef3c3b76b525d977f993528a_00000000_b247216e-9897-4c07-a462-b9ed437e6584’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3385__241ac4ca7aa9ed1bab6e243abf9b53c34c42eb71_00000000_0db6391a-32b2-42c2-89e4-98be0dd1ad85’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3385__94787da9668f8583f56db2d6a65f75a7987b7_00000000_3e73de38-4673-4a90-bcd0-3dba114ce388’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3385__94787da9668f8583f56db2d6a65f75a7987b7_00000000_b5b357c2-fca2-4185-9c93-274d99405778’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_10.0.19041.3385__b535d7a3f5c050b69b7c3c194a4c4da9cb6efbe_00000000_7fcb96db-b84f-431c-a3e3-c87330e625ce’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_{1ADA5981-C818-4_7993977a8f366b1b535ecd7bbbed6e78ba84c_00000000_cab_e62ad9ba-94d3-427c-b982-f3c8723cb8f8’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_{782B4301-80B0-4_4542365c80a5382acfd1b16889677252dff34f_00000000_cab_a4131850-b067-43a3-85a9-aab910af9983’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_{856FE327-2E32-4_2929e0879d572b1577e1e25068e8df9a5fe378d9_00000000_cab_44df3d28-82c1-4605-88bf-2f1171cae49d’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_{95AB5EF8-D951-4_5b1f1692a44183c8ce35fcf8a78aed1f7526e_00000000_cab_1bfbafdf-e687-4d4d-8788-90eadb4220e9’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_{A4196900-9928-4_88edd868da3d18f75c2db75e0223efe78c7417_00000000_cab_76fdadb3-cd94-4f24-8d45-a0bcade547f5’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_{CD2F8DF1-C67E-4_f136b7511665e192f8d4ec3ad1e77d46182efa24_00000000_cab_f8c491ee-18bd-46fd-a66b-3e69dcf74263’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_{E48FD0EA-3C21-4_beacce19061ae6b4f5c6dc7fbe1960a940ab_00000000_cab_852dbb44-5151-45a4-a9ee-6c4f7ab4279a’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_{E9925E88-29AC-4_71497c65a85eae9fd3aa3e7689ad3b2c45706fdc_00000000_cab_9c434831-d499-4ad4-b983-2f87149959c8’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Critical_{FB09BA66-4CF2-4_14f882f18919ad42ceb76c9fc5f412b516f22_00000000_cab_08f1ff07-fa85-42e1-a388-09af2ca7703a’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/Kernel_50_64a0eaa45afa4783a2fa15ab0323dce56bbee61_00000000_cab_7b524272-8504-4ea9-bde4-8fadde858f7c’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/NonCritical_0x80509004_dee4d09a5de6b89a4de25887bd4db6bdaa7afc5_00000000_0f917efe-3c43-4a15-b0c6-78eabf49a4e6’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/NonCritical_10.0.19041_12bc5c44749e1d9a745b9edc8aed6793455cd522_00000000_e66242ba-ba14-4bd4-ad7e-e0070f9b1e36’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/NonCritical_Microsoft Corpor_41bd3d2fa18feb9f71aeedce9e9c879f5a6422e_00000000_b6edbb2a-8d1e-4978-80a1-46d7fba5e5a0’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/NonCritical_Microsoft Corpor_92b5549fbabc4a49b6caeb6eba77bec84b871fd_00000000_0141818f-deff-4919-b59d-b264b3f8213e’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/NonCritical_Microsoft Corpor_92b5549fbabc4a49b6caeb6eba77bec84b871fd_00000000_1d180f3e-57eb-4fef-a485-52ccfe157cec’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/NonCritical_Microsoft Corpor_92b5549fbabc4a49b6caeb6eba77bec84b871fd_00000000_7dbf8179-d7fe-44e9-9239-71980cdb651f’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/NonCritical_Microsoft Corpor_92b5549fbabc4a49b6caeb6eba77bec84b871fd_00000000_a7d97c92-8ce8-4411-88a7-093c03606210’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/NonCritical_Microsoft Corpor_ab5202e333134d851971d5e36a5fea98375a24_00000000_7b9d1bc2-bda1-4a87-adc8-707841e0e846’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/NonCritical_Microsoft Corpor_bf5cd2d3331faa4af8a74c614eb43ebc69d577e_00000000_737d18a4-6343-4cd1-8082-261e655abdc3’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/NonCritical_Microsoft Corpor_bf5cd2d3331faa4af8a74c614eb43ebc69d577e_00000000_88f037f7-d653-4ba0-956b-de6bec27228b’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/NonCritical_Microsoft Corpor_bf5cd2d3331faa4af8a74c614eb43ebc69d577e_00000000_8e5301cb-2214-4d5a-adcd-e2fd9fa46b87’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/NonCritical_Microsoft Corpor_bf5cd2d3331faa4af8a74c614eb43ebc69d577e_00000000_b74e3c1f-1c9a-4cc9-9b0d-0103d5c7da9f’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/NonCritical_Microsoft Corpor_bf5cd2d3331faa4af8a74c614eb43ebc69d577e_00000000_e9e15120-03da-4979-a68b-0bfeff4c5aa4’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/NonCritical_Microsoft Window_628641234d2843dd131e729ce0bc50168948a9da_00000000_cba4bfab-46bd-4076-8262-ea1c4600aa0d’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/NonCritical_MicrosoftEdgeUpd_4df8dce2697bd23aa5ebc0def77646d714659a7c_00000000_b87a1ad9-7f6a-4260-911b-ec08a866e5ff’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/NonCritical_MicrosoftEdgeUpd_7b16be7bdf552bdc43e24804272db49eab32bbd_00000000_cafb517b-8a94-4607-9f68-b2002444f50b’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/NonCritical_MicrosoftEdgeUpd_c824b5ca322fa012bba46b25d7c1c7ceeab439e6_00000000_8849dbc3-ab5a-4175-9531-846cdeb88db0’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/NonCritical_Update;ScanForUp_485624251d7110b291b6abacd1896830892d48b0_00000000_ed7b31e2-4149-45c5-b040-366c7f7c72ab’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/WER/ReportArchive/NonCritical_Update;_a64d8c7849ebf2d92718b8e57a453b36258b9_00000000_9ea13549-dce1-4e29-ac0c-8905f09c5427’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows/wfp’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows Defender/Clean Store’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows Defender/DLPCache’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows Defender/Features’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows Defender/LocalCopy’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows Defender/Network Inspection System’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows Defender/Quarantine’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows Defender/Scans’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows Defender/Support’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows Defender Advanced Threat Protection/Cache’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows Defender Advanced Threat Protection/Cyber’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows Defender Advanced Threat Protection/DataCollection’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows Defender Advanced Threat Protection/DLP’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows Defender Advanced Threat Protection/Downloads’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows Defender Advanced Threat Protection/Platform’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows Defender Advanced Threat Protection/SenseCM’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows Defender Advanced Threat Protection/SenseNDR’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows Defender Advanced Threat Protection/Temp/PSScriptOutputs’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows Defender Advanced Threat Protection/Trace’: Permission denied
                                find: ‘/mnt/c/ProgramData/Microsoft/Windows NT/MSFax’: Permission denied
                                find: ‘/mnt/c/ProgramData/Packages’: Permission denied
                                find: ‘/mnt/c/ProgramData/RealVNC-Service’: Permission denied
                                find: ‘/mnt/c/ProgramData/WindowsHolographicDevices’: Permission denied
                                find: ‘/mnt/c/Recovery’: Permission denied
                                find: ‘/mnt/c/System Volume Information’: Permission denied
                                find: ‘/mnt/c/Users/Administrator’: Permission denied
                                find: ‘/mnt/c/Users/defaultuser0’: Permission denied
                                find: ‘/mnt/c/Users/Marek 2/AppData/Local/Bitdefender/Bdch/installer_admin’: Permission denied
                                find: ‘/mnt/c/Users/Marek 2/AppData/Local/Bitdefender/Bdch/mitm_install_tool_dci_admin’: Permission denied
                                find: ‘/mnt/c/Users/Marek 2/AppData/Local/Bitdefender/Bdch/productcfg_admin’: Permission denied
                                find: ‘/mnt/c/Users/Marek 2/AppData/Local/Packages/CanonicalGroupLimited.Ubuntu20.04onWindows_79rhkp1fndgsc/LocalState/rootfs’: Permission denied
                                find: ‘/mnt/c/Users/Marek 2/AppData/Local/Packages/CanonicalGroupLimited.Ubuntu20.04onWindows_79rhkp1fndgsc/LocalState/temp/{530d585c-d044-4563-861a-f470ca79a97f}’: Permission denied
                                find: ‘/mnt/c/Windows/appcompat/Programs’: Permission denied
                                find: ‘/mnt/c/Windows/CSC’: Permission denied
                                find: ‘/mnt/c/Windows/InfusedApps’: Permission denied
                                find: ‘/mnt/c/Windows/LiveKernelReports’: Permission denied
                                find: ‘/mnt/c/Windows/Logs/HomeGroup’: Permission denied
                                find: ‘/mnt/c/Windows/Logs/SystemRestore’: Permission denied
                                find: ‘/mnt/c/Windows/Logs/Telephony’: Permission denied
                                find: ‘/mnt/c/Windows/Logs/WindowsBackup’: Permission denied
                                find: ‘/mnt/c/Windows/Minidump’: Permission denied
                                find: ‘/mnt/c/Windows/ModemLogs’: Permission denied
                                find: ‘/mnt/c/Windows/PLA/Reports’: Permission denied
                                find: ‘/mnt/c/Windows/PLA/Rules’: Permission denied
                                find: ‘/mnt/c/Windows/PLA/Templates’: Permission denied
                                find: ‘/mnt/c/Windows/Prefetch’: Permission denied
                                find: ‘/mnt/c/Windows/Provisioning/Autopilot’: Permission denied
                                find: ‘/mnt/c/Windows/Resources/Themes/aero/VSCache’: Permission denied
                                find: ‘/mnt/c/Windows/security/audit’: Permission denied
                                find: ‘/mnt/c/Windows/security/cap’: Permission denied
                                find: ‘/mnt/c/Windows/ServiceProfiles/iobroker(SmartHome)’: Permission denied
                                find: ‘/mnt/c/Windows/ServiceProfiles/iobroker(SmartHome1)’: Permission denied
                                find: ‘/mnt/c/Windows/ServiceProfiles/LocalService’: Permission denied
                                find: ‘/mnt/c/Windows/ServiceProfiles/NetworkService’: Permission denied
                                find: ‘/mnt/c/Windows/ServiceState’: Permission denied
                                find: ‘/mnt/c/Windows/System32/appmgmt/MACHINE’: Permission denied
                                find: ‘/mnt/c/Windows/System32/appmgmt/S-1-5-18’: Permission denied
                                find: ‘/mnt/c/Windows/System32/Com/dmp’: Permission denied
                                find: ‘/mnt/c/Windows/System32/config’: Permission denied
                                find: ‘/mnt/c/Windows/System32/Configuration’: Permission denied
                                find: ‘/mnt/c/Windows/System32/drivers/DriverData’: Permission denied
                                find: ‘/mnt/c/Windows/System32/DriverState’: Permission denied
                                find: ‘/mnt/c/Windows/System32/FxsTmp’: Permission denied
                                find: ‘/mnt/c/Windows/System32/ias’: Permission denied
                                find: ‘/mnt/c/Windows/System32/LogFiles/HTTPERR’: Permission denied
                                find: ‘/mnt/c/Windows/System32/LogFiles/WMI’: Permission denied
                                find: ‘/mnt/c/Windows/System32/MsDtc’: Permission denied
                                find: ‘/mnt/c/Windows/System32/networklist’: Permission denied
                                find: ‘/mnt/c/Windows/System32/SleepStudy’: Permission denied
                                find: ‘/mnt/c/Windows/System32/spool/PRINTERS’: Permission denied
                                find: ‘/mnt/c/Windows/System32/spool/SERVERS’: Permission denied
                                find: ‘/mnt/c/Windows/System32/sru’: Permission denied
                                find: ‘/mnt/c/Windows/System32/Tasks’: Permission denied
                                find: ‘/mnt/c/Windows/System32/Tasks_Migrated’: Permission denied
                                find: ‘/mnt/c/Windows/System32/wbem/MOF’: Permission denied
                                find: ‘/mnt/c/Windows/System32/WDI’: Permission denied
                                find: ‘/mnt/c/Windows/SystemTemp’: Permission denied
                                find: ‘/mnt/c/Windows/SysWOW64/Com/dmp’: Permission denied
                                find: ‘/mnt/c/Windows/SysWOW64/config’: Permission denied
                                find: ‘/mnt/c/Windows/SysWOW64/Configuration’: Permission denied
                                find: ‘/mnt/c/Windows/SysWOW64/FxsTmp’: Permission denied
                                find: ‘/mnt/c/Windows/SysWOW64/Msdtc’: Permission denied
                                find: ‘/mnt/c/Windows/SysWOW64/networklist’: Permission denied
                                find: ‘/mnt/c/Windows/SysWOW64/sru’: Permission denied
                                find: ‘/mnt/c/Windows/SysWOW64/Tasks’: Permission denied
                                find: ‘/mnt/c/Windows/Temp/724D114C-1B02-4206-B99D-17A9DE2ED185’: Permission denied
                                find: ‘/mnt/d/$RECYCLE.BIN/S-1-5-18’: Permission denied
                                find: ‘/mnt/d/$RECYCLE.BIN/S-1-5-21-1515861603-1305653247-2782837703-1001’: Permission denied
                                find: ‘/mnt/d/$RECYCLE.BIN/S-1-5-21-788002034-1723751684-3648524827-500’: Permission denied
                                find: ‘/mnt/d/System Volume Information’: Permission denied
                                find: ‘/mnt/d/WindowsApps’: Permission denied
                                rm: missing operand
                                Try 'rm --help' for more information.
                                  KrisiunK Offline
                                  KrisiunK Offline
                                  Krisiun
                                  #107
                                  Nächste Befehl
                                  krisiun@Marek2:~$ sudo rm `sudo find / -name nodesource.key`
                                  rm: missing operand
                                  • KrisiunK Krisiun
                                    Nächste Befehl
                                    rm: missing operand
                                    KrisiunK Offline
                                    KrisiunK Offline
                                    Krisiun
                                    #108
                                    @krisiun
                                    Überall Zugriff Verweigert
                                      KrisiunK Offline
                                      KrisiunK Offline
                                      Krisiun
                                      #109
                                      Dann
                                      krisiun@Marek2:~$ sudo apt install -y ca-certificates curl gnupg
                                      ca-certificates is already the newest version (20230311ubuntu0.22.04.1).
                                      curl is already the newest version (7.81.0-1ubuntu1.13).
                                      gnupg is already the newest version (2.2.27-3ubuntu2.1).
                                      The following packages were automatically installed and are no longer required:
                                        javascript-common libffi7 libjs-highlight.js libllvm13 libpython2-dev libpython2-stdlib libpython2.7
                                        libpython2.7-dev libpython2.7-minimal libpython2.7-stdlib python2 python2-dev python2-minimal python2.7
                                        python2.7-dev python2.7-minimal
                                      Use 'sudo apt autoremove' to remove them.
                                      0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
                                        KrisiunK Offline
                                        KrisiunK Offline
                                        Krisiun
                                        #110
                                        Nr 4
                                          KrisiunK Offline
                                          KrisiunK Offline
                                          Krisiun
                                          #111
                                          Nr 5 Passiert nicht
