  4. neue Visualisierung "webui" (alternative zu vis & vis-2)
1.2k Beiträge 23 Kommentatoren 470.4k Aufrufe 19 Beobachtet
  • Smilie108S Offline
    Smilie108S Offline
    Smilie108
    #1141
    @jogibear9988 woher kommt eigentlich das host.iobroker-kramsach-live
    2026-05-03 22:06:24.216 warn host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/styles: EISDIR: illegal operation on a directory, read
    2026-05-03 22:06:24.167 warn host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/tooltip: EISDIR: illegal operation on a directory, read
    2026-05-03 22:06:24.167 warn host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/toolbar: EISDIR: illegal operation on a directory, read
    2026-05-03 22:06:23.975 warn host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/listbox-option: EISDIR: illegal operation on a directory, read
    2026-05-03 22:06:23.974 warn host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/listbox: EISDIR: illegal operation on a directory, read
    2026-05-03 22:06:23.930 warn host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/data-grid: EISDIR: illegal operation on a directory, read
    2026-05-03 22:06:23.880 warn host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/select: EISDIR: illegal operation on a directory, read
    2026-05-03 22:06:23.876 warn host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/breadcrumb-item: EISDIR: illegal operation on a directory, read
    2026-05-03 22:06:23.831 warn host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/breadcrumb: EISDIR: illegal operation on a directory, read
    2026-05-03 22:06:23.824 warn host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/anchored-region: EISDIR: illegal operation on a directory, read
    • Smilie108S Smilie108
      #1142
      @Smilie108 sagte:
      Da sollte eigentlich der hostname deines hosts auftauchen.
      Falls der bei dir anders heißt, versuch ein
      iob host this
      Smilie108S 1 Antwort Letzte Antwort
        @Smilie108 sagte:
        iob host this
        Smilie108S Offline
        Smilie108S Offline
        Smilie108
        #1143
        @Thomas-Braun mhm der host heist iobroker-kramsach-live ;) es gibt auch einen entwiklungs oder spiel host aber nicht in der gleichen vm
          #1144
          @Smilie108
          Dann hast du ja deine Antwort auf
          Oder geht es dir um die Meldung
            Smilie108S Offline
            Smilie108
            #1145
            eigentlich um die eisdir weil auch wenn ich in webui das paket neu installiere bleibt die meldung
              #1146
              @Smilie108
              Da soll eine Datei gelesen werden, die aber ein Verzeichnis ist.
              Wohl ein Pack-Fehler im npm-Paket.
              Oder falsche Rechte. Oder falsches nodejs-Setup.
              Jag den
              iob fix
              mal über das System.
                Smilie108S Offline
                Smilie108
                #1147
                @thomas-braun hab ich gemacht hat auch so gesagt das er fehler behoben hat aber das mit dem oben habe ich immer noch // weis auch leider nicht seit wann bin nur jetzt mal am iob logfile aufarbeiten da ist es mir aufgefallen ;)
                  #1148
                  @Smilie108
                  iob diag
                  sagt?
                    Smilie108S Offline
                    Smilie108
                    #1149
                    ;) ========== Start marking the full check here ===========
                    Script v.2026-01-31
                    *** BASE SYSTEM ***
                    Operating System: Ubuntu 24.04.4 LTS
                     Static hostname: iobroker-kramsach-live
                           Icon name: computer-vm
                             Chassis: vm 🖴
                      Virtualization: kvm
                              Kernel: Linux 6.8.0-111-generic
                        Architecture: x86-64
                     Hardware Vendor: QEMU
                      Hardware Model: Standard PC _i440FX + PIIX, 1996_
                    Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
                       Firmware Date: Tue 2014-04-01
                        Firmware Age: 12y 1month 3d
                    OS is similar to: debian
                    model name      : QEMU Virtual CPU version 2.5+
                    Docker          : false
                    Virtualization  : kvm
                    Kernel          : x86_64
                    Userland        : 64 bit
                    Systemuptime and Load:
                     19:41:01 up 12 min,  2 users,  load average: 1.53, 1.36, 0.89
                    CPU threads: 4
                    *** LIFE CYCLE STATUS ***
                    Operating System codenamed 'noble' is an aging Ubuntu release! Please upgrade to the latest LTS release 'resolute' in due time!
                    *** TIME AND TIMEZONES ***
                                   Local time: Mon 2026-05-04 19:41:01 CEST
                               Universal time: Mon 2026-05-04 17:41:01 UTC
                                     RTC time: Mon 2026-05-04 17:41:01
                                  NTP service: active
                              RTC in local TZ: no
                    *** Users and Groups ***
                    User that called 'iob diag':
                    smilie108
                    HOME=/home/smilie108
                    GROUPS=smilie108 adm cdrom sudo dip plugdev lxd iobroker
                    js-controller is not running
                    *** DISPLAY-SERVER SETUP ***
                    Display-Server:         false
                    Unit display-manager.service could not be found.
                    Display-Manager:
                    Desktop:
                    Session:                tty
                    *** MEMORY ***
                    Mem:             20G        953M         18G        3.8M        1.6G         19G
                    Swap:           8.6G          0B        8.6G
                    Total:           29G        953M         27G
                    Active iob-Instances:   1
                            19779 M total memory
                              911 M used memory
                              831 M active memory
                              813 M inactive memory
                            17697 M free memory
                              171 M buffer memory
                             1368 M swap cache
                             8191 M total swap
                                0 M used swap
                             8191 M free swap
                    top - 19:41:02 up 12 min,  2 users,  load average: 1.53, 1.36, 0.89
                    Tasks: 157 total,   2 running, 155 sleeping,   0 stopped,   0 zombie
                    %Cpu(s): 28.6 us,  4.8 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :  19779.1 total,  17690.4 free,    918.6 used,   1539.6 buff/cache
                    MiB Swap:   8192.0 total,   8192.0 free,      0.0 used.  18860.5 avail Mem
                    *** FAILED SERVICES ***
                      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                    * iobroker.service loaded failed failed ioBroker Server
                    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                            SUB    -> The low-level unit activation state, values depend on unit type.
                    1 loaded units listed.
                    *** DMESG CRITICAL ERRORS ***
                    No critical errors detected
                    *** FILESYSTEM ***
                    Filesystem                        Type   Size  Used Avail Use% Mounted on
                    tmpfs                             tmpfs  2.0G  1.1M  2.0G   1% /run
                    /dev/mapper/ubuntu--vg-ubuntu--lv ext4    98G   58G   36G  62% /
                    tmpfs                             tmpfs  9.7G     0  9.7G   0% /dev/shm
                    tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
                    /dev/sda2                         ext4   2.0G  200M  1.6G  11% /boot
                    tmpfs                             tmpfs  2.0G   12K  2.0G   1% /run/user/1000
                    [Mon May  4 19:28:18 2026] EXT4-fs (dm-0): mounted filesystem 8d603055-1d71-4ec7-84ad-951b1082fd39 ro with ordered data mode. Quota mode: none.
                    [Mon May  4 19:28:18 2026] EXT4-fs (dm-0): re-mounted 8d603055-1d71-4ec7-84ad-951b1082fd39 r/w.
                    [Mon May  4 19:28:19 2026] EXT4-fs (sda2): mounted filesystem 965f4498-2280-470d-b312-91df09b7b1f5 r/w with ordered data mode. Quota mode: none.
                    Show mounted filesystems:
                    TARGET  SOURCE                            FSTYPE OPTIONS
                    /       /dev/mapper/ubuntu--vg-ubuntu--lv ext4   rw,relatime
                    `-/boot /dev/sda2                         ext4   rw,relatime
                    /var:
                    2.5G    /var/
                    1.4G    /var/lib
                    970M    /var/lib/mysql
                    942M    /var/log
                    903M    /var/log/journal/18c66e219588459ea2005bc764231802
                    Archived and active journals take up 902.9M in the file system.
                    /opt/iobroker/backups:
                    91M     /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    765M    /opt/iobroker/iobroker-data/
                    271M    /opt/iobroker/iobroker-data/files
                    195M    /opt/iobroker/iobroker-data/history
                    134M    /opt/iobroker/iobroker-data/cloudless-homeconnect.0
                    128M    /opt/iobroker/iobroker-data/backup-objects
                    133M    /opt/iobroker/iobroker-data/cloudless-homeconnect.0/homeconnect-profile-downloader-win32-x64-1.0.1.zip
                    29M     /opt/iobroker/iobroker-data/objects.jsonl
                    13M     /opt/iobroker/iobroker-data/files/webui/node_modules/monaco-editor/esm/vs/editor/ts.worker.js
                    8.2M    /opt/iobroker/iobroker-data/files/modbus.admin/assets/index-Blv_5nFZ.js
                    7.8M    /opt/iobroker/iobroker-data/states.jsonl
                    USB-Devices by-id:
                    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
                    please always prefer the links 'by-id':
                    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_cefeaafbdc82ee11b712469ec33d7414-if00-port0
                    *** ZigBee Settings ***
                    ⚠ HINT:
                    Your zigbee.0 COM-Port is NOT matching 'by-id'.
                    Please check your setting:
                    /dev/ttyUSB0
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs         v22.22.2
                    /usr/bin/node           v22.22.2
                    /usr/bin/npm            10.9.7
                    /usr/bin/npx            10.9.7
                    ✓ Node.js installation is correct
                    nodejs:
                      Installed: 22.22.2-1nodesource1
                      Candidate: 22.22.2-1nodesource1
                      Version table:
                     *** 22.22.2-1nodesource1 1001
                            500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
                            100 /var/lib/dpkg/status
                         22.22.1-1nodesource1 1001
                         22.22.0-1nodesource1 1001
                         22.21.0-1nodesource1 1001
                         22.20.0-1nodesource1 1001
                         22.19.0-1nodesource1 1001
                         22.18.0-1nodesource1 1001
                         22.17.1-1nodesource1 1001
                         22.17.0-1nodesource1 1001
                         22.16.0-1nodesource1 1001
                         22.15.1-1nodesource1 1001
                         22.15.0-1nodesource1 1001
                         22.14.0-1nodesource1 1001
                         22.13.1-1nodesource1 1001
                         22.13.0-1nodesource1 1001
                         22.12.0-1nodesource1 1001
                         22.11.0-1nodesource1 1001
                         22.10.0-1nodesource1 1001
                         22.9.0-1nodesource1 1001
                         22.8.0-1nodesource1 1001
                         22.7.0-1nodesource1 1001
                         22.6.0-1nodesource1 1001
                         22.5.1-1nodesource1 1001
                         22.5.0-1nodesource1 1001
                         22.4.1-1nodesource1 1001
                         22.4.0-1nodesource1 1001
                         22.3.0-1nodesource1 1001
                         22.2.0-1nodesource1 1001
                         22.1.0-1nodesource1 1001
                         22.0.0-1nodesource1 1001
                         18.19.1+dfsg-6ubuntu5 500
                            500 http://at.archive.ubuntu.com/ubuntu noble/universe amd64 Packages
                    No problems detected
                    Errors in npm tree: 0
                    *** ioBroker-Installation ***
                    ioBroker Status
                      Smilie108S Offline
                      Smilie108
                      #1150
                      ioBroker Status
                      iobroker is not running on this host.
                      Objects type: jsonl
                      States type: jsonl
                      Hosts:
                      iobroker-kramsach-live iobroker-kramsach-live (version: 7.1.1, hostname: iobroker-kramsach-live, alive, uptime: 49)
                      Core adapters versions
                      js-controller: 7.1.1
                      admin: 7.8.23
                      javascript: 9.2.1
                      nodejs modules from github: 1
                      +-- iobroker.euhome@0.1.5 (git+ssh://git@github.com/TA2k/ioBroker.euhome.git#da498b16858260123ddad3633f344e0ef05c99de)
                      Adapter State
                      system.adapter.accuweather.0 : accuweather : iobroker-kramsach-live - disabled
                      system.adapter.admin.0 : admin : iobroker-kramsach-live - enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      system.adapter.alias-manager.0 : alias-manager : iobroker-kramsach-live - disabled
                      system.adapter.apg-info.0 : apg-info : iobroker-kramsach-live - enabled
                      system.adapter.backitup.0 : backitup : iobroker-kramsach-live - enabled
                      system.adapter.bosch-ebike.0 : bosch-ebike : iobroker-kramsach-live - enabled
                      system.adapter.cloudless-homeconnect.0 : cloudless-homeconnect : iobroker-kramsach-live - disabled
                      system.adapter.discovery.0 : discovery : iobroker-kramsach-live - enabled
                      system.adapter.echarts.0 : echarts : iobroker-kramsach-live - enabled
                      system.adapter.email.0 : email : iobroker-kramsach-live - disabled
                      system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-kramsach-live - enabled
                      system.adapter.euhome.0 : euhome : iobroker-kramsach-live - enabled
                      system.adapter.feiertage.0 : feiertage : iobroker-kramsach-live - enabled
                      system.adapter.flexcharts.0 : flexcharts : iobroker-kramsach-live - disabled
                      system.adapter.flexcharts.1 : flexcharts : iobroker-kramsach-live - disabled
                      system.adapter.flot.0 : flot : iobroker-kramsach-live - disabled
                      system.adapter.hass.0 : hass : iobroker-kramsach-live - enabled, port: 8123
                      system.adapter.heatingcontrol.0 : heatingcontrol : iobroker-kramsach-live - enabled
                      system.adapter.history.0 : history : iobroker-kramsach-live - enabled
                      system.adapter.history.1 : history : iobroker-kramsach-live - enabled
                      system.adapter.homeconnect.0 : homeconnect : iobroker-kramsach-live - enabled
                      system.adapter.javascript.0 : javascript : iobroker-kramsach-live - enabled
                      system.adapter.javascript.1 : javascript : iobroker-kramsach-live - enabled
                      system.adapter.kecontact.0 : kecontact : iobroker-kramsach-live - enabled
                      system.adapter.modbus.0 : modbus : iobroker-kramsach-live - enabled
                      system.adapter.modbus.1 : modbus : iobroker-kramsach-live - disabled
                      system.adapter.modbus.2 : modbus : iobroker-kramsach-live - disabled
                      system.adapter.mqtt.0 : mqtt : iobroker-kramsach-live - enabled, port: 1883, bind: 0.0.0.0
                      system.adapter.nissan.0 : nissan : iobroker-kramsach-live - disabled
                      system.adapter.openweathermap.0 : openweathermap : iobroker-kramsach-live - enabled
                      system.adapter.pegelalarm.0 : pegelalarm : iobroker-kramsach-live - enabled
                      system.adapter.pi-hole2.0 : pi-hole2 : iobroker-kramsach-live - enabled, port: 80
                      system.adapter.proxmox.0 : proxmox : iobroker-kramsach-live - enabled, port: 8006
                      system.adapter.pvforecast.0 : pvforecast : iobroker-kramsach-live - enabled
                      system.adapter.s7.0 : s7 : iobroker-kramsach-live - enabled
                      system.adapter.samsung_tizen.0 : samsung_tizen : iobroker-kramsach-live - disabled, port: 8002
                      system.adapter.scenes.0 : scenes : iobroker-kramsach-live - enabled
                      system.adapter.scheduler.0 : scheduler : iobroker-kramsach-live - enabled
                      system.adapter.shelly.0 : shelly : iobroker-kramsach-live - enabled, port: 1882, bind: 0.0.0.0
                      system.adapter.signal-cmb.0 : signal-cmb : iobroker-kramsach-live - disabled
                      system.adapter.simple-api.0 : simple-api : iobroker-kramsach-live - enabled, port: 8087, bind: 0.0.0.0, run as: admin
                      system.adapter.solax.0 : solax : iobroker-kramsach-live - enabled
                      system.adapter.sourceanalytix.0 : sourceanalytix : iobroker-kramsach-live - enabled
                      system.adapter.sql.0 : sql : iobroker-kramsach-live - enabled, port: 3306
                      system.adapter.sql.1 : sql : iobroker-kramsach-live - enabled, port: 3306
                      system.adapter.sql.2 : sql : iobroker-kramsach-live - enabled, port: 3306
                      system.adapter.sql.3 : sql : iobroker-kramsach-live - enabled
                      system.adapter.sql.4 : sql : iobroker-kramsach-live - enabled
                      system.adapter.sql.5 : sql : iobroker-kramsach-live - enabled, port: 3306
                      system.adapter.sql.6 : sql : iobroker-kramsach-live - enabled, port: 3306
                      system.adapter.sql.7 : sql : iobroker-kramsach-live - enabled, port: 3306
                      system.adapter.sql.8 : sql : iobroker-kramsach-live - enabled, port: 3306
                      system.adapter.sql.9 : sql : iobroker-kramsach-live - enabled, port: 3306
                      system.adapter.tuya.0 : tuya : iobroker-kramsach-live - enabled
                      system.adapter.viessmannapi.0 : viessmannapi : iobroker-kramsach-live - enabled
                      system.adapter.web.0 : web : iobroker-kramsach-live - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                      system.adapter.webui.0 : webui : iobroker-kramsach-live - disabled
                      system.adapter.whatsapp-cmb.0 : whatsapp-cmb : iobroker-kramsach-live - enabled
                      system.adapter.zigbee.0 : zigbee : iobroker-kramsach-live - enabled, port: /dev/ttyUSB0
                      • instance is alive
                      ioBroker-Repositories
                      │ (index) │ name │ url │ auto upgrade │
                      │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │
                      │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │
                      Active repo(s): beta
                      Upgrade policy: none
                      Installed ioBroker-Adapters
                      Used repository: beta
                      Adapter "accuweather" : 2.2.0 , installed 2.2.0
                      Adapter "admin" : 7.8.23 , installed 7.8.23
                      Adapter "alias-manager": 2.1.0 , installed 2.1.0
                      Adapter "apg-info" : 0.1.32 , installed 0.1.32
                      Adapter "backitup" : 3.3.17 , installed 3.3.17
                      Adapter "bosch-ebike" : 0.1.12 , installed 0.1.12
                      Adapter "cloudless-homeconnect": 1.6.4, installed 1.6.4
                      Adapter "discovery" : 5.0.0 , installed 5.0.0
                      Adapter "echarts" : 3.1.0 , installed 3.1.0
                      Adapter "email" : 2.0.4 , installed 2.0.4
                      Adapter "energiefluss-erweitert": 0.8.2, installed 0.8.2
                      Adapter "feiertage" : 1.3.0 , installed 1.3.0
                      Adapter "flexcharts" : 0.7.0 , installed 0.7.0
                      Adapter "flot" : 1.12.0 , installed 1.12.0
                      Adapter "hass" : 2.0.3 , installed 2.0.3
                      Adapter "heatingcontrol": 3.1.4 , installed 3.1.4
                      Adapter "history" : 4.0.0 , installed 4.0.0
                      Adapter "homeconnect" : 1.5.2 , installed 1.5.2
                      Adapter "javascript" : 9.2.1 , installed 9.2.1
                      Controller "js-controller": 7.1.1 , installed 7.1.1
                      Adapter "kecontact" : 3.6.0 , installed 3.6.0
                      Adapter "modbus" : 8.1.3 , installed 8.1.3
                      Adapter "mqtt" : 6.1.4 , installed 6.1.4
                      Adapter "nissan" : 0.1.18 , installed 0.1.18
                      Adapter "openweathermap": 1.4.0 , installed 1.4.0
                      Adapter "pegelalarm" : 1.4.0 , installed 1.4.0
                      Adapter "pi-hole2" : 1.1.1 , installed 1.1.1
                      Adapter "proxmox" : 2.5.3 , installed 2.5.3
                      Adapter "pvforecast" : 6.1.0 , installed 6.1.0
                      Adapter "s7" : 1.5.0 , installed 1.5.0
                      Adapter "samsung_tizen": 1.1.0 , installed 1.1.0
                      Adapter "scenes" : 4.0.4 , installed 4.0.4
                      Adapter "scheduler" : 1.5.0 , installed 1.5.0
                      Adapter "shelly" : 10.6.1 , installed 10.6.1
                      Adapter "signal-cmb" : 0.3.0 , installed 0.3.0
                      Adapter "simple-api" : 3.0.7 , installed 3.0.7
                      Adapter "socketio" : 7.1.3 , installed 7.1.3
                      Adapter "solax" : 0.9.23 , installed 0.9.23
                      Adapter "sourceanalytix": 0.4.14 , installed 0.4.14
                      Adapter "sql" : 3.0.1 , installed 3.0.1
                      Adapter "tuya" : 3.17.0 , installed 3.17.0
                      Adapter "viessmannapi" : 2.4.5 , installed 2.4.5
                      Adapter "web" : 8.1.0 , installed 8.1.0
                      Adapter "webui" : 1.44.0 , installed 1.44.0
                      Adapter "whatsapp-cmb" : 0.3.0 , installed 0.3.0
                      Adapter "ws" : 4.1.0 , installed 4.1.0
                      Adapter "zigbee" : 3.4.1 , installed 3.4.1
                        ioBroker Status
                        Objects type: jsonl
                        States type: jsonl
                        Hosts:
                        admin: 7.8.23
                        javascript: 9.2.1
                        Adapter State
                        • instance is alive
                        #1151
                        @Smilie108
                        Poste die Ausgabe bitte 'in einem Rutsch' vollständig in ein Posting.
                          Smilie108S Offline
                          Smilie108
                          #1152
                          ok
                          er war noch nicht fertig ;) gleich
                            Smilie108S Offline
                            Smilie108
                            #1153
                            Script v.2026-01-31
                            *** BASE SYSTEM ***
                                     Chassis: vm 🖴
                              Virtualization: kvm
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                             19:43:23 up 15 min,  2 users,  load average: 1.30, 1.34, 0.95
                            CPU threads: 4
                                           Local time: Mon 2026-05-04 19:43:23 CEST
                                       Universal time: Mon 2026-05-04 17:43:23 UTC
                                             RTC time: Mon 2026-05-04 17:43:23
                                          NTP service: active
                                      RTC in local TZ: no
                            smilie108
                            Display-Manager:
                            Desktop:
                            Session:                tty
                            *** MEMORY ***
                            Mem:             20G        957M         18G        3.8M        1.6G         19G
                            Swap:           8.6G          0B        8.6G
                            Total:           29G        957M         27G
                                      913 M used memory
                                      855 M active memory
                                      829 M inactive memory
                                    17670 M free memory
                                      174 M buffer memory
                                     1389 M swap cache
                                     8191 M total swap
                                        0 M used swap
                                     8191 M free swap
                            top - 19:43:23 up 15 min,  2 users,  load average: 1.30, 1.34, 0.95
                            Tasks: 159 total,   2 running, 157 sleeping,   0 stopped,   0 zombie
                            %Cpu(s): 26.2 us,  4.8 sy,  0.0 ni, 69.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :  19779.1 total,  17690.5 free,    893.8 used,   1564.3 buff/cache
                            MiB Swap:   8192.0 total,   8192.0 free,      0.0 used.  18885.3 avail Mem
                            *** FILESYSTEM ***
                            /var:
                            2.5G    /var/
                            1.4G    /var/lib
                            970M    /var/lib/mysql
                            942M    /var/log
                            776M    /opt/iobroker/iobroker-data/
                            40M     /opt/iobroker/iobroker-data/objects.jsonl
                            USB-Devices by-id:
                            ⚠ HINT:
                            /dev/ttyUSB0
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            /usr/bin/npm            10.9.7
                            /usr/bin/npx            10.9.7
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            admin:          7.8.23
                            javascript:     9.2.1
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        31895
                            States:         26449
                            Hit:1 http://at.archive.ubuntu.com/ubuntu noble InRelease
                            Hit:2 http://at.archive.ubuntu.com/ubuntu noble-updates InRelease
                            Hit:3 http://at.archive.ubuntu.com/ubuntu noble-backports InRelease
                            Hit:4 https://apt.grafana.com stable InRelease
                            Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                            Hit:6 http://security.ubuntu.com/ubuntu noble-security InRelease
                            Reading package lists...
                            Pending systemupdates: 4
                            *** Listening Ports ***
                            tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      992        5876       652/systemd-resolve
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6881       1/init
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4317       1/init
                            tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      992        5878       652/systemd-resolve
                            tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      111        9236       973/mariadbd
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          6883       1/init
                            tcp6       0      0 :::111                  :::*                    LISTEN      0          2875       1/init
                            tcp6       0      0 :::80                   :::*                    LISTEN      0          10440      1139/apache2
                            tcp6       0      0 :::3000                 :::*                    LISTEN      114        11519      1109/grafana
                            udp        0      0 127.0.0.54:53           0.0.0.0:*                           992        5877       652/systemd-resolve
                            udp        0      0 127.0.0.53:53           0.0.0.0:*                           992        5875       652/systemd-resolve
                            udp        0      0 192.168.2.30:68         0.0.0.0:*                           998        8716       787/systemd-network
                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          4318       1/init
                            udp6       0      0 :::111                  :::*                                0          3864       1/init
                            udp6       0      0 fe80::be24:11ff:fec:546 :::*                                998        9399       787/systemd-network
                            2026-05-04 19:30:00.860  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
                            2026-05-04 19:30:05.857  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                            2026-05-04 19:30:05.863  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
                            2026-05-04 19:30:10.858  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                            2026-05-04 19:30:10.866  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
                            2026-05-04 19:30:15.861  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                            2026-05-04 19:30:15.869  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
                            2026-05-04 19:30:20.862  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                            2026-05-04 19:30:20.871  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
                            2026-05-04 19:30:25.864  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                            2026-05-04 19:30:25.874  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
                            2026-05-04 19:30:30.865  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                            2026-05-04 19:30:30.876  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
                            2026-05-04 19:30:35.866  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                            2026-05-04 19:30:35.878  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
                            2026-05-04 19:30:40.867  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                            2026-05-04 19:30:40.881  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
                            2026-05-04 19:30:45.869  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                            2026-05-04 19:30:45.883  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
                            2026-05-04 19:30:50.871  - info: sql.3 (2908) Objects database successfully reconnected
                            2026-05-04 19:30:50.886  - info: sql.3 (2908) Objects database successfully reconnected
                            2026-05-04 19:30:51.712  - info: sql.3 (2908) terminating
                            2026-05-04 19:30:51.712  - info: sql.3 (2908) Terminated (NO_ERROR): Without reason
                            2026-05-04 19:30:51.752  - info: sql.3 (2908) terminating
                            iob diag has finished.
                              Smilie108S Offline
                              Smilie108
                              #1154
                              grad gesehen das ich mal upgraden sollte ubuntu
                                #1155
                                @Smilie108 sagte:
                                26.04 ist aber auch gerade erst vor einer Woche veröffentlicht worden. Ein Upgrade würde ich für Herbst anpeilen. Dann sind die Kinderkrankheiten raus.
                                • iobroker.service loaded failed failed ioBroker Server
                                Starten den ioBroker. Dann sieht man mehr...
                                  Smilie108S Offline
                                  Smilie108
                                  #1156
                                  was soll mir dann *** LIFE CYCLE STATUS ***
                                  Operating System codenamed 'noble' is an aging Ubuntu release! Please upgrade to the latest LTS release 'resolute' in due time! das sagen ?
                                    #1157
                                    @Smilie108
                                    Das sagt dir, dass du zu gegebener Zeit ein Upgrade auf die aktuelle LTS-Version vornehmen solltest.
                                    Ubuntu schaltet das aber ohnehin für die breite Masse erst nach dem ersten Pointrelease frei. Wird irgendwann im August der Fall sein.
                                    Also ist Herbst 2026 ein guter Zeitpunkt dafür.
                                      Smilie108S Offline
                                      Smilie108
                                      #1158
                                      ;) ok bin grad am starten vom iob dann mach ich nochmal ein diag
                                        Smilie108S Offline
                                        Smilie108
                                        #1159
                                        Script v.2026-01-31
                                        *** BASE SYSTEM ***
                                                 Chassis: vm 🖴
                                          Virtualization: kvm
                                        Docker          : false
                                        Kernel          : x86_64
                                        Userland        : 64 bit
                                         20:04:22 up 36 min,  2 users,  load average: 2.96, 3.23, 2.14
                                        CPU threads: 4
                                                       Local time: Mon 2026-05-04 20:04:22 CEST
                                                   Universal time: Mon 2026-05-04 18:04:22 UTC
                                                         RTC time: Mon 2026-05-04 18:04:22
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        smilie108
                                        iobroker
                                        HOME=/home/iobroker
                                        GROUPS=iobroker tty dialout audio video plugdev
                                        Display-Manager:
                                        Desktop:
                                        Session:                tty
                                        *** MEMORY ***
                                        Mem:             20G        5.4G         13G        3.8M        1.8G         15G
                                        Swap:           8.6G          0B        8.6G
                                        Total:           29G        5.4G         22G
                                        Active iob-Instances:   44
                                                 5172 M used memory
                                                 4996 M active memory
                                                  941 M inactive memory
                                                13272 M free memory
                                                  178 M buffer memory
                                                 1525 M swap cache
                                                 8191 M total swap
                                                    0 M used swap
                                                 8191 M free swap
                                        top - 20:04:22 up 36 min,  2 users,  load average: 2.96, 3.23, 2.14
                                        Tasks: 207 total,   2 running, 205 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s): 34.9 us, 11.6 sy,  0.0 ni, 51.2 id,  0.0 wa,  0.0 hi,  2.3 si,  0.0 st
                                        MiB Mem :  19779.1 total,  13275.8 free,   5169.0 used,   1703.8 buff/cache
                                        MiB Swap:   8192.0 total,   8192.0 free,      0.0 used.  14610.1 avail Mem
                                        0 loaded units listed.
                                        *** FILESYSTEM ***
                                        /var:
                                        2.5G    /var/
                                        1.4G    /var/lib
                                        970M    /var/lib/mysql
                                        942M    /var/log
                                        787M    /opt/iobroker/iobroker-data/
                                        44M     /opt/iobroker/iobroker-data/objects.jsonl
                                        15M     /opt/iobroker/iobroker-data/states.jsonl
                                        USB-Devices by-id:
                                        ⚠ HINT:
                                        /dev/ttyUSB0
                                        zigbee.X
                                        Extended Pan ID:
                                        *** MASKED ***
                                        Pan ID:
                                        *** MASKED ***
                                        Channel:
                                        *** MASKED ***
                                        Network Key:
                                        *** MASKED ***
                                        /usr/bin/npm            10.9.7
                                        /usr/bin/npx            10.9.7
                                        nodejs:
                                          Version table:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Hosts:
                                        iobroker-kramsach-live iobroker-kramsach-live (version: 7.1.1, hostname: iobroker-kramsach-live, alive, uptime: 363)
                                        admin:          7.8.23
                                        javascript:     9.2.1
                                        Adapter State
                                        + system.adapter.admin.0                  : admin                 : iobroker-kramsach-live                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                        + system.adapter.backitup.0               : backitup              : iobroker-kramsach-live                   -  enabled
                                        + system.adapter.bosch-ebike.0            : bosch-ebike           : iobroker-kramsach-live                   -  enabled
                                        + system.adapter.discovery.0              : discovery             : iobroker-kramsach-live                   -  enabled
                                        + system.adapter.echarts.0                : echarts               : iobroker-kramsach-live                   -  enabled
                                        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-kramsach-live                   -  enabled
                                        + system.adapter.euhome.0                 : euhome                : iobroker-kramsach-live                   -  enabled
                                        + system.adapter.hass.0                   : hass                  : iobroker-kramsach-live                   -  enabled, port: 8123
                                        + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker-kramsach-live                   -  enabled
                                        + system.adapter.history.0                : history               : iobroker-kramsach-live                   -  enabled
                                        + system.adapter.history.1                : history               : iobroker-kramsach-live                   -  enabled
                                        + system.adapter.homeconnect.0            : homeconnect           : iobroker-kramsach-live                   -  enabled
                                        + system.adapter.javascript.0             : javascript            : iobroker-kramsach-live                   -  enabled
                                        + system.adapter.javascript.1             : javascript            : iobroker-kramsach-live                   -  enabled
                                        + system.adapter.kecontact.0              : kecontact             : iobroker-kramsach-live                   -  enabled
                                        + system.adapter.modbus.0                 : modbus                : iobroker-kramsach-live                   -  enabled
                                        + system.adapter.mqtt.0                   : mqtt                  : iobroker-kramsach-live                   -  enabled, port: 1883, bind: 0.0.0.0
                                        + system.adapter.pi-hole2.0               : pi-hole2              : iobroker-kramsach-live                   -  enabled, port: 80
                                        + system.adapter.proxmox.0                : proxmox               : iobroker-kramsach-live                   -  enabled, port: 8006
                                        + system.adapter.pvforecast.0             : pvforecast            : iobroker-kramsach-live                   -  enabled
                                        + system.adapter.s7.0                     : s7                    : iobroker-kramsach-live                   -  enabled
                                        + system.adapter.scenes.0                 : scenes                : iobroker-kramsach-live                   -  enabled
                                        + system.adapter.scheduler.0              : scheduler             : iobroker-kramsach-live                   -  enabled
                                        + system.adapter.shelly.0                 : shelly                : iobroker-kramsach-live                   -  enabled, port: 1882, bind: 0.0.0.0
                                        + system.adapter.simple-api.0             : simple-api            : iobroker-kramsach-live                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                        + system.adapter.solax.0                  : solax                 : iobroker-kramsach-live                   -  enabled
                                        + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker-kramsach-live                   -  enabled
                                        + system.adapter.sql.0                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                                        + system.adapter.sql.1                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                                        + system.adapter.sql.2                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                                        + system.adapter.sql.3                    : sql                   : iobroker-kramsach-live                   -  enabled
                                        + system.adapter.sql.4                    : sql                   : iobroker-kramsach-live                   -  enabled
                                        + system.adapter.sql.5                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                                        + system.adapter.sql.6                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                                        + system.adapter.sql.7                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                                        + system.adapter.sql.8                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                                        + system.adapter.sql.9                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                                        + system.adapter.tuya.0                   : tuya                  : iobroker-kramsach-live                   -  enabled
                                        + system.adapter.viessmannapi.0           : viessmannapi          : iobroker-kramsach-live                   -  enabled
                                        + system.adapter.web.0                    : web                   : iobroker-kramsach-live                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        + system.adapter.webui.0                  : webui                 : iobroker-kramsach-live                   -  enabled
                                        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker-kramsach-live                   -  enabled
                                        + system.adapter.zigbee.0                 : zigbee                : iobroker-kramsach-live                   -  enabled, port: /dev/ttyUSB0
                                        + instance is alive
                                        Objects and States
                                        Objects:        32009
                                        States:         26991
                                        Ign:6 http://security.ubuntu.com/ubuntu noble-security InRelease
                                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       240773     67908/io.mqtt.0
                                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       241563     68467/io.shelly.0
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       225677     64683/iobroker.js-c
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       226354     64683/iobroker.js-c
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       249631     69865/io.web.0
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       226581     64811/io.admin.0
                                        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       248213     69643/io.simple-api
                                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       245806     68717/io.tuya.0
                                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       245807     68717/io.tuya.0
                                        udp        0      0 0.0.0.0:7090            0.0.0.0:*                           1001       236456     67747/io.kecontact.
                                        udp        0      0 0.0.0.0:7092            0.0.0.0:*                           1001       236457     67747/io.kecontact.
                                        udp        0      0 0.0.0.0:46834           0.0.0.0:*                           1001       235441     67747/io.kecontact.
                                        2026-05-04 20:05:58.425  - warn: modbus.0 (67832) Error: undefined
                                        2026-05-04 20:05:58.425  - error: modbus.0 (67832) Request timed out.
                                        2026-05-04 20:05:58.425  - error: modbus.0 (67832) Client in error state.
                                        2026-05-04 20:05:58.425  - warn: modbus.0 (67832) [DevID_1/holdingRegs] Block 1047-1073: {}
                                        2026-05-04 20:05:59.426  - info: modbus.0 (67832) Disconnected from slave 192.168.2.43
                                        2026-05-04 20:06:07.390  - info: web.0 (69865) ==> Connected system.user.admin from ::ffff:192.168.2.186
                                        2026-05-04 20:06:08.026  - error: web.0 (69865) [getState] ERROR: Error: The id is empty! Please provide a valid id.
                                        2026-05-04 20:06:08.029  - error: web.0 (69865) [getState] ERROR: Error: The id is empty! Please provide a valid id.
                                        2026-05-04 20:06:08.040  - error: web.0 (69865) [getState] ERROR: Error: The id is empty! Please provide a valid id.
                                        2026-05-04 20:06:08.062  - info: webui.0 (69983) runCommand: uiConnected, parameter:
                                        2026-05-04 20:06:08.100  - error: web.0 (69865) [getState] ERROR: Error: The id is empty! Please provide a valid id.
                                        2026-05-04 20:06:08.130  - info: webui.0 (69983) runCommand: uiChangedView, parameter: start
                                        2026-05-04 20:06:08.156  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/anchored-region: EISDIR: illegal operation on a directory, read
                                        2026-05-04 20:06:08.203  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/breadcrumb: EISDIR: illegal operation on a directory, read
                                        2026-05-04 20:06:08.206  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/breadcrumb-item: EISDIR: illegal operation on a directory, read
                                        2026-05-04 20:06:08.219  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/data-grid: EISDIR: illegal operation on a directory, read
                                        2026-05-04 20:06:08.230  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/listbox: EISDIR: illegal operation on a directory, read
                                        2026-05-04 20:06:08.234  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/listbox-option: EISDIR: illegal operation on a directory, read
                                        2026-05-04 20:06:08.249  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/select: EISDIR: illegal operation on a directory, read
                                        2026-05-04 20:06:08.263  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/toolbar: EISDIR: illegal operation on a directory, read
                                        2026-05-04 20:06:08.264  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/tooltip: EISDIR: illegal operation on a directory, read
                                        2026-05-04 20:06:08.271  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/styles: EISDIR: illegal operation on a directory, read
                                        2026-05-04 20:06:08.452  - info: web.0 (69865) ==> Connected system.user.admin from ::ffff:192.168.2.186
                                        2026-05-04 20:06:09.429  - info: modbus.0 (67832) Connected to slave 192.168.2.43
                                        2026-05-04 20:06:28.960  - info: solax.0 (68592) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
                                          Smilie108S Offline
                                          Smilie108
                                          #1160
                                          das ist jetzt wärend dem laufenden betrieb
