  4. neue Visualisierung "webui" (alternative zu vis & vis-2)
1.2k Beiträge 23 Kommentatoren 460.9k Aufrufe 22 Beobachtet
  • Smilie108S Offline
    Smilie108S Offline
    Smilie108
    #1140
    @jogibear9988 Ja jetzt gehts ;) Vielen dank einstweilen
      Smilie108S Offline
      Smilie108
      #1141
      @jogibear9988 woher kommt eigentlich das host.iobroker-kramsach-live
      2026-05-03 22:06:24.216 warn host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/styles: EISDIR: illegal operation on a directory, read
      2026-05-03 22:06:24.167 warn host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/tooltip: EISDIR: illegal operation on a directory, read
      2026-05-03 22:06:24.167 warn host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/toolbar: EISDIR: illegal operation on a directory, read
      2026-05-03 22:06:23.975 warn host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/listbox-option: EISDIR: illegal operation on a directory, read
      2026-05-03 22:06:23.974 warn host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/listbox: EISDIR: illegal operation on a directory, read
      2026-05-03 22:06:23.930 warn host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/data-grid: EISDIR: illegal operation on a directory, read
      2026-05-03 22:06:23.880 warn host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/select: EISDIR: illegal operation on a directory, read
      2026-05-03 22:06:23.876 warn host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/breadcrumb-item: EISDIR: illegal operation on a directory, read
      2026-05-03 22:06:23.831 warn host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/breadcrumb: EISDIR: illegal operation on a directory, read
      2026-05-03 22:06:23.824 warn host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/anchored-region: EISDIR: illegal operation on a directory, read
      • Smilie108S Smilie108
        #1142
        @Smilie108 sagte:
        Da sollte eigentlich der hostname deines hosts auftauchen.
        Falls der bei dir anders heißt, versuch ein
        iob host this
        Smilie108S 1 Antwort Letzte Antwort
          @Smilie108 sagte:
          iob host this
          Smilie108S Offline
          Smilie108S Offline
          Smilie108
          #1143
          @Thomas-Braun mhm der host heist iobroker-kramsach-live ;) es gibt auch einen entwiklungs oder spiel host aber nicht in der gleichen vm
            #1144
            @Smilie108
            Dann hast du ja deine Antwort auf
            Oder geht es dir um die Meldung
              Smilie108S Offline
              Smilie108
              #1145
              eigentlich um die eisdir weil auch wenn ich in webui das paket neu installiere bleibt die meldung
                #1146
                @Smilie108
                Da soll eine Datei gelesen werden, die aber ein Verzeichnis ist.
                Wohl ein Pack-Fehler im npm-Paket.
                Oder falsche Rechte. Oder falsches nodejs-Setup.
                Jag den
                iob fix
                mal über das System.
                  Smilie108S Offline
                  Smilie108
                  #1147
                  @thomas-braun hab ich gemacht hat auch so gesagt das er fehler behoben hat aber das mit dem oben habe ich immer noch // weis auch leider nicht seit wann bin nur jetzt mal am iob logfile aufarbeiten da ist es mir aufgefallen ;)
                    #1148
                    @Smilie108
                    iob diag
                    sagt?
                      Smilie108S Offline
                      Smilie108
                      #1149
                      ;) ========== Start marking the full check here ===========
                      Script v.2026-01-31
                      *** BASE SYSTEM ***
                      Operating System: Ubuntu 24.04.4 LTS
                       Static hostname: iobroker-kramsach-live
                             Icon name: computer-vm
                               Chassis: vm 🖴
                        Virtualization: kvm
                                Kernel: Linux 6.8.0-111-generic
                          Architecture: x86-64
                       Hardware Vendor: QEMU
                        Hardware Model: Standard PC _i440FX + PIIX, 1996_
                      Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
                         Firmware Date: Tue 2014-04-01
                          Firmware Age: 12y 1month 3d
                      OS is similar to: debian
                      model name      : QEMU Virtual CPU version 2.5+
                      Docker          : false
                      Virtualization  : kvm
                      Kernel          : x86_64
                      Userland        : 64 bit
                      Systemuptime and Load:
                       19:41:01 up 12 min,  2 users,  load average: 1.53, 1.36, 0.89
                      CPU threads: 4
                      *** LIFE CYCLE STATUS ***
                      Operating System codenamed 'noble' is an aging Ubuntu release! Please upgrade to the latest LTS release 'resolute' in due time!
                      *** TIME AND TIMEZONES ***
                                     Local time: Mon 2026-05-04 19:41:01 CEST
                                 Universal time: Mon 2026-05-04 17:41:01 UTC
                                       RTC time: Mon 2026-05-04 17:41:01
                                    NTP service: active
                                RTC in local TZ: no
                      *** Users and Groups ***
                      User that called 'iob diag':
                      smilie108
                      HOME=/home/smilie108
                      GROUPS=smilie108 adm cdrom sudo dip plugdev lxd iobroker
                      js-controller is not running
                      *** DISPLAY-SERVER SETUP ***
                      Display-Server:         false
                      Unit display-manager.service could not be found.
                      Display-Manager:
                      Desktop:
                      Session:                tty
                      *** MEMORY ***
                      Mem:             20G        953M         18G        3.8M        1.6G         19G
                      Swap:           8.6G          0B        8.6G
                      Total:           29G        953M         27G
                      Active iob-Instances:   1
                              19779 M total memory
                                911 M used memory
                                831 M active memory
                                813 M inactive memory
                              17697 M free memory
                                171 M buffer memory
                               1368 M swap cache
                               8191 M total swap
                                  0 M used swap
                               8191 M free swap
                      top - 19:41:02 up 12 min,  2 users,  load average: 1.53, 1.36, 0.89
                      Tasks: 157 total,   2 running, 155 sleeping,   0 stopped,   0 zombie
                      %Cpu(s): 28.6 us,  4.8 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :  19779.1 total,  17690.4 free,    918.6 used,   1539.6 buff/cache
                      MiB Swap:   8192.0 total,   8192.0 free,      0.0 used.  18860.5 avail Mem
                      *** FAILED SERVICES ***
                        UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                      * iobroker.service loaded failed failed ioBroker Server
                      Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                              ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                              SUB    -> The low-level unit activation state, values depend on unit type.
                      1 loaded units listed.
                      *** DMESG CRITICAL ERRORS ***
                      No critical errors detected
                      *** FILESYSTEM ***
                      Filesystem                        Type   Size  Used Avail Use% Mounted on
                      tmpfs                             tmpfs  2.0G  1.1M  2.0G   1% /run
                      /dev/mapper/ubuntu--vg-ubuntu--lv ext4    98G   58G   36G  62% /
                      tmpfs                             tmpfs  9.7G     0  9.7G   0% /dev/shm
                      tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
                      /dev/sda2                         ext4   2.0G  200M  1.6G  11% /boot
                      tmpfs                             tmpfs  2.0G   12K  2.0G   1% /run/user/1000
                      [Mon May  4 19:28:18 2026] EXT4-fs (dm-0): mounted filesystem 8d603055-1d71-4ec7-84ad-951b1082fd39 ro with ordered data mode. Quota mode: none.
                      [Mon May  4 19:28:18 2026] EXT4-fs (dm-0): re-mounted 8d603055-1d71-4ec7-84ad-951b1082fd39 r/w.
                      [Mon May  4 19:28:19 2026] EXT4-fs (sda2): mounted filesystem 965f4498-2280-470d-b312-91df09b7b1f5 r/w with ordered data mode. Quota mode: none.
                      Show mounted filesystems:
                      TARGET  SOURCE                            FSTYPE OPTIONS
                      /       /dev/mapper/ubuntu--vg-ubuntu--lv ext4   rw,relatime
                      `-/boot /dev/sda2                         ext4   rw,relatime
                      /var:
                      2.5G    /var/
                      1.4G    /var/lib
                      970M    /var/lib/mysql
                      942M    /var/log
                      903M    /var/log/journal/18c66e219588459ea2005bc764231802
                      Archived and active journals take up 902.9M in the file system.
                      /opt/iobroker/backups:
                      91M     /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      765M    /opt/iobroker/iobroker-data/
                      271M    /opt/iobroker/iobroker-data/files
                      195M    /opt/iobroker/iobroker-data/history
                      134M    /opt/iobroker/iobroker-data/cloudless-homeconnect.0
                      128M    /opt/iobroker/iobroker-data/backup-objects
                      133M    /opt/iobroker/iobroker-data/cloudless-homeconnect.0/homeconnect-profile-downloader-win32-x64-1.0.1.zip
                      29M     /opt/iobroker/iobroker-data/objects.jsonl
                      13M     /opt/iobroker/iobroker-data/files/webui/node_modules/monaco-editor/esm/vs/editor/ts.worker.js
                      8.2M    /opt/iobroker/iobroker-data/files/modbus.admin/assets/index-Blv_5nFZ.js
                      7.8M    /opt/iobroker/iobroker-data/states.jsonl
                      USB-Devices by-id:
                      USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
                      please always prefer the links 'by-id':
                      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_cefeaafbdc82ee11b712469ec33d7414-if00-port0
                      *** ZigBee Settings ***
                      ⚠ HINT:
                      Your zigbee.0 COM-Port is NOT matching 'by-id'.
                      Please check your setting:
                      /dev/ttyUSB0
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v22.22.2
                      /usr/bin/node           v22.22.2
                      /usr/bin/npm            10.9.7
                      /usr/bin/npx            10.9.7
                      ✓ Node.js installation is correct
                      nodejs:
                        Installed: 22.22.2-1nodesource1
                        Candidate: 22.22.2-1nodesource1
                        Version table:
                       *** 22.22.2-1nodesource1 1001
                           22.22.1-1nodesource1 1001
                           22.22.0-1nodesource1 1001
                           22.21.0-1nodesource1 1001
                           22.20.0-1nodesource1 1001
                           22.19.0-1nodesource1 1001
                           22.18.0-1nodesource1 1001
                           22.17.1-1nodesource1 1001
                           22.17.0-1nodesource1 1001
                           22.16.0-1nodesource1 1001
                           22.15.1-1nodesource1 1001
                           22.15.0-1nodesource1 1001
                           22.14.0-1nodesource1 1001
                           22.13.1-1nodesource1 1001
                           22.13.0-1nodesource1 1001
                           22.12.0-1nodesource1 1001
                           22.11.0-1nodesource1 1001
                           22.10.0-1nodesource1 1001
                           22.9.0-1nodesource1 1001
                           22.8.0-1nodesource1 1001
                           22.7.0-1nodesource1 1001
                           22.6.0-1nodesource1 1001
                           22.5.1-1nodesource1 1001
                           22.5.0-1nodesource1 1001
                           22.4.1-1nodesource1 1001
                           22.4.0-1nodesource1 1001
                           22.3.0-1nodesource1 1001
                           22.2.0-1nodesource1 1001
                           22.1.0-1nodesource1 1001
                           22.0.0-1nodesource1 1001
                           18.19.1+dfsg-6ubuntu5 500
                              500 http://at.archive.ubuntu.com/ubuntu noble/universe amd64 Packages
                      No problems detected
                      Errors in npm tree: 0
                      *** ioBroker-Installation ***
                      ioBroker Status
                        Smilie108S Offline
                        Smilie108
                        #1150
                        ioBroker Status
                        iobroker is not running on this host.
                        Objects type: jsonl
                        States type: jsonl
                        Hosts:
                        iobroker-kramsach-live iobroker-kramsach-live (version: 7.1.1, hostname: iobroker-kramsach-live, alive, uptime: 49)
                        Core adapters versions
                        js-controller: 7.1.1
                        admin: 7.8.23
                        javascript: 9.2.1
                        nodejs modules from github: 1
                        +-- iobroker.euhome@0.1.5 (git+ssh://git@github.com/TA2k/ioBroker.euhome.git#da498b16858260123ddad3633f344e0ef05c99de)
                        Adapter State
                        system.adapter.accuweather.0 : accuweather : iobroker-kramsach-live - disabled
                        system.adapter.admin.0 : admin : iobroker-kramsach-live - enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        system.adapter.alias-manager.0 : alias-manager : iobroker-kramsach-live - disabled
                        system.adapter.apg-info.0 : apg-info : iobroker-kramsach-live - enabled
                        system.adapter.backitup.0 : backitup : iobroker-kramsach-live - enabled
                        system.adapter.bosch-ebike.0 : bosch-ebike : iobroker-kramsach-live - enabled
                        system.adapter.cloudless-homeconnect.0 : cloudless-homeconnect : iobroker-kramsach-live - disabled
                        system.adapter.discovery.0 : discovery : iobroker-kramsach-live - enabled
                        system.adapter.echarts.0 : echarts : iobroker-kramsach-live - enabled
                        system.adapter.email.0 : email : iobroker-kramsach-live - disabled
                        system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-kramsach-live - enabled
                        system.adapter.euhome.0 : euhome : iobroker-kramsach-live - enabled
                        system.adapter.feiertage.0 : feiertage : iobroker-kramsach-live - enabled
                        system.adapter.flexcharts.0 : flexcharts : iobroker-kramsach-live - disabled
                        system.adapter.flexcharts.1 : flexcharts : iobroker-kramsach-live - disabled
                        system.adapter.flot.0 : flot : iobroker-kramsach-live - disabled
                        system.adapter.hass.0 : hass : iobroker-kramsach-live - enabled, port: 8123
                        system.adapter.heatingcontrol.0 : heatingcontrol : iobroker-kramsach-live - enabled
                        system.adapter.history.0 : history : iobroker-kramsach-live - enabled
                        system.adapter.history.1 : history : iobroker-kramsach-live - enabled
                        system.adapter.homeconnect.0 : homeconnect : iobroker-kramsach-live - enabled
                        system.adapter.javascript.0 : javascript : iobroker-kramsach-live - enabled
                        system.adapter.javascript.1 : javascript : iobroker-kramsach-live - enabled
                        system.adapter.kecontact.0 : kecontact : iobroker-kramsach-live - enabled
                        system.adapter.modbus.0 : modbus : iobroker-kramsach-live - enabled
                        system.adapter.modbus.1 : modbus : iobroker-kramsach-live - disabled
                        system.adapter.modbus.2 : modbus : iobroker-kramsach-live - disabled
                        system.adapter.mqtt.0 : mqtt : iobroker-kramsach-live - enabled, port: 1883, bind: 0.0.0.0
                        system.adapter.nissan.0 : nissan : iobroker-kramsach-live - disabled
                        system.adapter.openweathermap.0 : openweathermap : iobroker-kramsach-live - enabled
                        system.adapter.pegelalarm.0 : pegelalarm : iobroker-kramsach-live - enabled
                        system.adapter.pi-hole2.0 : pi-hole2 : iobroker-kramsach-live - enabled, port: 80
                        system.adapter.proxmox.0 : proxmox : iobroker-kramsach-live - enabled, port: 8006
                        system.adapter.pvforecast.0 : pvforecast : iobroker-kramsach-live - enabled
                        system.adapter.s7.0 : s7 : iobroker-kramsach-live - enabled
                        system.adapter.samsung_tizen.0 : samsung_tizen : iobroker-kramsach-live - disabled, port: 8002
                        system.adapter.scenes.0 : scenes : iobroker-kramsach-live - enabled
                        system.adapter.scheduler.0 : scheduler : iobroker-kramsach-live - enabled
                        system.adapter.shelly.0 : shelly : iobroker-kramsach-live - enabled, port: 1882, bind: 0.0.0.0
                        system.adapter.signal-cmb.0 : signal-cmb : iobroker-kramsach-live - disabled
                        system.adapter.simple-api.0 : simple-api : iobroker-kramsach-live - enabled, port: 8087, bind: 0.0.0.0, run as: admin
                        system.adapter.solax.0 : solax : iobroker-kramsach-live - enabled
                        system.adapter.sourceanalytix.0 : sourceanalytix : iobroker-kramsach-live - enabled
                        system.adapter.sql.0 : sql : iobroker-kramsach-live - enabled, port: 3306
                        system.adapter.sql.1 : sql : iobroker-kramsach-live - enabled, port: 3306
                        system.adapter.sql.2 : sql : iobroker-kramsach-live - enabled, port: 3306
                        system.adapter.sql.3 : sql : iobroker-kramsach-live - enabled
                        system.adapter.sql.4 : sql : iobroker-kramsach-live - enabled
                        system.adapter.sql.5 : sql : iobroker-kramsach-live - enabled, port: 3306
                        system.adapter.sql.6 : sql : iobroker-kramsach-live - enabled, port: 3306
                        system.adapter.sql.7 : sql : iobroker-kramsach-live - enabled, port: 3306
                        system.adapter.sql.8 : sql : iobroker-kramsach-live - enabled, port: 3306
                        system.adapter.sql.9 : sql : iobroker-kramsach-live - enabled, port: 3306
                        system.adapter.tuya.0 : tuya : iobroker-kramsach-live - enabled
                        system.adapter.viessmannapi.0 : viessmannapi : iobroker-kramsach-live - enabled
                        system.adapter.web.0 : web : iobroker-kramsach-live - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                        system.adapter.webui.0 : webui : iobroker-kramsach-live - disabled
                        system.adapter.whatsapp-cmb.0 : whatsapp-cmb : iobroker-kramsach-live - enabled
                        system.adapter.zigbee.0 : zigbee : iobroker-kramsach-live - enabled, port: /dev/ttyUSB0
                        • instance is alive
                        ioBroker-Repositories
                        │ (index) │ name │ url │ auto upgrade │
                        │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │
                        │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │
                        Active repo(s): beta
                        Upgrade policy: none
                        Installed ioBroker-Adapters
                        Used repository: beta
                        Adapter "accuweather" : 2.2.0 , installed 2.2.0
                        Adapter "admin" : 7.8.23 , installed 7.8.23
                        Adapter "alias-manager": 2.1.0 , installed 2.1.0
                        Adapter "apg-info" : 0.1.32 , installed 0.1.32
                        Adapter "backitup" : 3.3.17 , installed 3.3.17
                        Adapter "bosch-ebike" : 0.1.12 , installed 0.1.12
                        Adapter "cloudless-homeconnect": 1.6.4, installed 1.6.4
                        Adapter "discovery" : 5.0.0 , installed 5.0.0
                        Adapter "echarts" : 3.1.0 , installed 3.1.0
                        Adapter "email" : 2.0.4 , installed 2.0.4
                        Adapter "energiefluss-erweitert": 0.8.2, installed 0.8.2
                        Adapter "feiertage" : 1.3.0 , installed 1.3.0
                        Adapter "flexcharts" : 0.7.0 , installed 0.7.0
                        Adapter "flot" : 1.12.0 , installed 1.12.0
                        Adapter "hass" : 2.0.3 , installed 2.0.3
                        Adapter "heatingcontrol": 3.1.4 , installed 3.1.4
                        Adapter "history" : 4.0.0 , installed 4.0.0
                        Adapter "homeconnect" : 1.5.2 , installed 1.5.2
                        Adapter "javascript" : 9.2.1 , installed 9.2.1
                        Controller "js-controller": 7.1.1 , installed 7.1.1
                        Adapter "kecontact" : 3.6.0 , installed 3.6.0
                        Adapter "modbus" : 8.1.3 , installed 8.1.3
                        Adapter "mqtt" : 6.1.4 , installed 6.1.4
                        Adapter "nissan" : 0.1.18 , installed 0.1.18
                        Adapter "openweathermap": 1.4.0 , installed 1.4.0
                        Adapter "pegelalarm" : 1.4.0 , installed 1.4.0
                        Adapter "pi-hole2" : 1.1.1 , installed 1.1.1
                        Adapter "proxmox" : 2.5.3 , installed 2.5.3
                        Adapter "pvforecast" : 6.1.0 , installed 6.1.0
                        Adapter "s7" : 1.5.0 , installed 1.5.0
                        Adapter "samsung_tizen": 1.1.0 , installed 1.1.0
                        Adapter "scenes" : 4.0.4 , installed 4.0.4
                        Adapter "scheduler" : 1.5.0 , installed 1.5.0
                        Adapter "shelly" : 10.6.1 , installed 10.6.1
                        Adapter "signal-cmb" : 0.3.0 , installed 0.3.0
                        Adapter "simple-api" : 3.0.7 , installed 3.0.7
                        Adapter "socketio" : 7.1.3 , installed 7.1.3
                        Adapter "solax" : 0.9.23 , installed 0.9.23
                        Adapter "sourceanalytix": 0.4.14 , installed 0.4.14
                        Adapter "sql" : 3.0.1 , installed 3.0.1
                        Adapter "tuya" : 3.17.0 , installed 3.17.0
                        Adapter "viessmannapi" : 2.4.5 , installed 2.4.5
                        Adapter "web" : 8.1.0 , installed 8.1.0
                        Adapter "webui" : 1.44.0 , installed 1.44.0
                        Adapter "whatsapp-cmb" : 0.3.0 , installed 0.3.0
                        Adapter "ws" : 4.1.0 , installed 4.1.0
                        Adapter "zigbee" : 3.4.1 , installed 3.4.1
                          ioBroker Status
                          Objects type: jsonl
                          States type: jsonl
                          Hosts:
                          admin: 7.8.23
                          javascript: 9.2.1
                          Adapter State
                          • instance is alive
                          #1151
                          @Smilie108
                          Poste die Ausgabe bitte 'in einem Rutsch' vollständig in ein Posting.
                            Smilie108S Offline
                            Smilie108
                            #1152
                            ok
                            er war noch nicht fertig ;) gleich
                              Smilie108S Offline
                              Smilie108
                              #1153
                              Script v.2026-01-31
                              *** BASE SYSTEM ***
                                       Chassis: vm 🖴
                                Virtualization: kvm
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : 64 bit
                               19:43:23 up 15 min,  2 users,  load average: 1.30, 1.34, 0.95
                              CPU threads: 4
                                             Local time: Mon 2026-05-04 19:43:23 CEST
                                         Universal time: Mon 2026-05-04 17:43:23 UTC
                                               RTC time: Mon 2026-05-04 17:43:23
                                            NTP service: active
                                        RTC in local TZ: no
                              smilie108
                              Display-Manager:
                              Desktop:
                              Session:                tty
                              *** MEMORY ***
                              Mem:             20G        957M         18G        3.8M        1.6G         19G
                              Swap:           8.6G          0B        8.6G
                              Total:           29G        957M         27G
                                        913 M used memory
                                        855 M active memory
                                        829 M inactive memory
                                      17670 M free memory
                                        174 M buffer memory
                                       1389 M swap cache
                                       8191 M total swap
                                          0 M used swap
                                       8191 M free swap
                              top - 19:43:23 up 15 min,  2 users,  load average: 1.30, 1.34, 0.95
                              Tasks: 159 total,   2 running, 157 sleeping,   0 stopped,   0 zombie
                              %Cpu(s): 26.2 us,  4.8 sy,  0.0 ni, 69.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                              MiB Mem :  19779.1 total,  17690.5 free,    893.8 used,   1564.3 buff/cache
                              MiB Swap:   8192.0 total,   8192.0 free,      0.0 used.  18885.3 avail Mem
                              *** FILESYSTEM ***
                              /var:
                              2.5G    /var/
                              1.4G    /var/lib
                              970M    /var/lib/mysql
                              942M    /var/log
                              776M    /opt/iobroker/iobroker-data/
                              40M     /opt/iobroker/iobroker-data/objects.jsonl
                              USB-Devices by-id:
                              ⚠ HINT:
                              /dev/ttyUSB0
                              zigbee.X
                              Extended Pan ID:
                              *** MASKED ***
                              Pan ID:
                              *** MASKED ***
                              Channel:
                              *** MASKED ***
                              Network Key:
                              *** MASKED ***
                              /usr/bin/npm            10.9.7
                              /usr/bin/npx            10.9.7
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              admin:          7.8.23
                              javascript:     9.2.1
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        31895
                              States:         26449
                              Hit:1 http://at.archive.ubuntu.com/ubuntu noble InRelease
                              Hit:2 http://at.archive.ubuntu.com/ubuntu noble-updates InRelease
                              Hit:3 http://at.archive.ubuntu.com/ubuntu noble-backports InRelease
                              Hit:4 https://apt.grafana.com stable InRelease
                              Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                              Hit:6 http://security.ubuntu.com/ubuntu noble-security InRelease
                              Reading package lists...
                              Pending systemupdates: 4
                              *** Listening Ports ***
                              tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      992        5876       652/systemd-resolve
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6881       1/init
                              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4317       1/init
                              tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      992        5878       652/systemd-resolve
                              tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      111        9236       973/mariadbd
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          6883       1/init
                              tcp6       0      0 :::111                  :::*                    LISTEN      0          2875       1/init
                              tcp6       0      0 :::80                   :::*                    LISTEN      0          10440      1139/apache2
                              tcp6       0      0 :::3000                 :::*                    LISTEN      114        11519      1109/grafana
                              udp        0      0 127.0.0.54:53           0.0.0.0:*                           992        5877       652/systemd-resolve
                              udp        0      0 127.0.0.53:53           0.0.0.0:*                           992        5875       652/systemd-resolve
                              udp        0      0 192.168.2.30:68         0.0.0.0:*                           998        8716       787/systemd-network
                              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          4318       1/init
                              udp6       0      0 :::111                  :::*                                0          3864       1/init
                              udp6       0      0 fe80::be24:11ff:fec:546 :::*                                998        9399       787/systemd-network
                              2026-05-04 19:30:00.860  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
                              2026-05-04 19:30:05.857  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                              2026-05-04 19:30:05.863  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
                              2026-05-04 19:30:10.858  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                              2026-05-04 19:30:10.866  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
                              2026-05-04 19:30:15.861  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                              2026-05-04 19:30:15.869  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
                              2026-05-04 19:30:20.862  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                              2026-05-04 19:30:20.871  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
                              2026-05-04 19:30:25.864  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                              2026-05-04 19:30:25.874  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
                              2026-05-04 19:30:30.865  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                              2026-05-04 19:30:30.876  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
                              2026-05-04 19:30:35.866  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                              2026-05-04 19:30:35.878  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
                              2026-05-04 19:30:40.867  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                              2026-05-04 19:30:40.881  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
                              2026-05-04 19:30:45.869  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                              2026-05-04 19:30:45.883  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
                              2026-05-04 19:30:50.871  - info: sql.3 (2908) Objects database successfully reconnected
                              2026-05-04 19:30:50.886  - info: sql.3 (2908) Objects database successfully reconnected
                              2026-05-04 19:30:51.712  - info: sql.3 (2908) terminating
                              2026-05-04 19:30:51.712  - info: sql.3 (2908) Terminated (NO_ERROR): Without reason
                              2026-05-04 19:30:51.752  - info: sql.3 (2908) terminating
                              iob diag has finished.
                                Smilie108S Offline
                                Smilie108
                                #1154
                                grad gesehen das ich mal upgraden sollte ubuntu
                                  #1155
                                  @Smilie108 sagte:
                                  26.04 ist aber auch gerade erst vor einer Woche veröffentlicht worden. Ein Upgrade würde ich für Herbst anpeilen. Dann sind die Kinderkrankheiten raus.
                                  • iobroker.service loaded failed failed ioBroker Server
                                  Starten den ioBroker. Dann sieht man mehr...
                                    Smilie108S Offline
                                    Smilie108
                                    #1156
                                    was soll mir dann *** LIFE CYCLE STATUS ***
                                    Operating System codenamed 'noble' is an aging Ubuntu release! Please upgrade to the latest LTS release 'resolute' in due time! das sagen ?
                                      #1157
                                      @Smilie108
                                      Das sagt dir, dass du zu gegebener Zeit ein Upgrade auf die aktuelle LTS-Version vornehmen solltest.
                                      Ubuntu schaltet das aber ohnehin für die breite Masse erst nach dem ersten Pointrelease frei. Wird irgendwann im August der Fall sein.
                                      Also ist Herbst 2026 ein guter Zeitpunkt dafür.
                                        Smilie108S Offline
                                        Smilie108
                                        #1158
                                        ;) ok bin grad am starten vom iob dann mach ich nochmal ein diag
                                          Smilie108S Offline
                                          Smilie108
                                          #1159
                                          Script v.2026-01-31
                                          *** BASE SYSTEM ***
                                                   Chassis: vm 🖴
                                            Virtualization: kvm
                                          Docker          : false
                                          Kernel          : x86_64
                                          Userland        : 64 bit
                                           20:04:22 up 36 min,  2 users,  load average: 2.96, 3.23, 2.14
                                          CPU threads: 4
                                                         Local time: Mon 2026-05-04 20:04:22 CEST
                                                     Universal time: Mon 2026-05-04 18:04:22 UTC
                                                           RTC time: Mon 2026-05-04 18:04:22
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          smilie108
                                          iobroker
                                          HOME=/home/iobroker
                                          GROUPS=iobroker tty dialout audio video plugdev
                                          Display-Manager:
                                          Desktop:
                                          Session:                tty
                                          *** MEMORY ***
                                          Mem:             20G        5.4G         13G        3.8M        1.8G         15G
                                          Swap:           8.6G          0B        8.6G
                                          Total:           29G        5.4G         22G
                                          Active iob-Instances:   44
                                                   5172 M used memory
                                                   4996 M active memory
                                                    941 M inactive memory
                                                  13272 M free memory
                                                    178 M buffer memory
                                                   1525 M swap cache
                                                   8191 M total swap
                                                      0 M used swap
                                                   8191 M free swap
                                          top - 20:04:22 up 36 min,  2 users,  load average: 2.96, 3.23, 2.14
                                          Tasks: 207 total,   2 running, 205 sleeping,   0 stopped,   0 zombie
                                          %Cpu(s): 34.9 us, 11.6 sy,  0.0 ni, 51.2 id,  0.0 wa,  0.0 hi,  2.3 si,  0.0 st
                                          MiB Mem :  19779.1 total,  13275.8 free,   5169.0 used,   1703.8 buff/cache
                                          MiB Swap:   8192.0 total,   8192.0 free,      0.0 used.  14610.1 avail Mem
                                          0 loaded units listed.
                                          *** FILESYSTEM ***
                                          /var:
                                          2.5G    /var/
                                          1.4G    /var/lib
                                          970M    /var/lib/mysql
                                          942M    /var/log
                                          787M    /opt/iobroker/iobroker-data/
                                          44M     /opt/iobroker/iobroker-data/objects.jsonl
                                          15M     /opt/iobroker/iobroker-data/states.jsonl
                                          USB-Devices by-id:
                                          ⚠ HINT:
                                          /dev/ttyUSB0
                                          zigbee.X
                                          Extended Pan ID:
                                          *** MASKED ***
                                          Pan ID:
                                          *** MASKED ***
                                          Channel:
                                          *** MASKED ***
                                          Network Key:
                                          *** MASKED ***
                                          /usr/bin/npm            10.9.7
                                          /usr/bin/npx            10.9.7
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Hosts:
                                          iobroker-kramsach-live iobroker-kramsach-live (version: 7.1.1, hostname: iobroker-kramsach-live, alive, uptime: 363)
                                          admin:          7.8.23
                                          javascript:     9.2.1
                                          Adapter State
                                          + system.adapter.admin.0                  : admin                 : iobroker-kramsach-live                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                          + system.adapter.backitup.0               : backitup              : iobroker-kramsach-live                   -  enabled
                                          + system.adapter.bosch-ebike.0            : bosch-ebike           : iobroker-kramsach-live                   -  enabled
                                          + system.adapter.discovery.0              : discovery             : iobroker-kramsach-live                   -  enabled
                                          + system.adapter.echarts.0                : echarts               : iobroker-kramsach-live                   -  enabled
                                          + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-kramsach-live                   -  enabled
                                          + system.adapter.euhome.0                 : euhome                : iobroker-kramsach-live                   -  enabled
                                          + system.adapter.hass.0                   : hass                  : iobroker-kramsach-live                   -  enabled, port: 8123
                                          + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker-kramsach-live                   -  enabled
                                          + system.adapter.history.0                : history               : iobroker-kramsach-live                   -  enabled
                                          + system.adapter.history.1                : history               : iobroker-kramsach-live                   -  enabled
                                          + system.adapter.homeconnect.0            : homeconnect           : iobroker-kramsach-live                   -  enabled
                                          + system.adapter.javascript.0             : javascript            : iobroker-kramsach-live                   -  enabled
                                          + system.adapter.javascript.1             : javascript            : iobroker-kramsach-live                   -  enabled
                                          + system.adapter.kecontact.0              : kecontact             : iobroker-kramsach-live                   -  enabled
                                          + system.adapter.modbus.0                 : modbus                : iobroker-kramsach-live                   -  enabled
                                          + system.adapter.mqtt.0                   : mqtt                  : iobroker-kramsach-live                   -  enabled, port: 1883, bind: 0.0.0.0
                                          + system.adapter.pi-hole2.0               : pi-hole2              : iobroker-kramsach-live                   -  enabled, port: 80
                                          + system.adapter.proxmox.0                : proxmox               : iobroker-kramsach-live                   -  enabled, port: 8006
                                          + system.adapter.pvforecast.0             : pvforecast            : iobroker-kramsach-live                   -  enabled
                                          + system.adapter.s7.0                     : s7                    : iobroker-kramsach-live                   -  enabled
                                          + system.adapter.scenes.0                 : scenes                : iobroker-kramsach-live                   -  enabled
                                          + system.adapter.scheduler.0              : scheduler             : iobroker-kramsach-live                   -  enabled
                                          + system.adapter.shelly.0                 : shelly                : iobroker-kramsach-live                   -  enabled, port: 1882, bind: 0.0.0.0
                                          + system.adapter.simple-api.0             : simple-api            : iobroker-kramsach-live                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                          + system.adapter.solax.0                  : solax                 : iobroker-kramsach-live                   -  enabled
                                          + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker-kramsach-live                   -  enabled
                                          + system.adapter.sql.0                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                                          + system.adapter.sql.1                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                                          + system.adapter.sql.2                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                                          + system.adapter.sql.3                    : sql                   : iobroker-kramsach-live                   -  enabled
                                          + system.adapter.sql.4                    : sql                   : iobroker-kramsach-live                   -  enabled
                                          + system.adapter.sql.5                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                                          + system.adapter.sql.6                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                                          + system.adapter.sql.7                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                                          + system.adapter.sql.8                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                                          + system.adapter.sql.9                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                                          + system.adapter.tuya.0                   : tuya                  : iobroker-kramsach-live                   -  enabled
                                          + system.adapter.viessmannapi.0           : viessmannapi          : iobroker-kramsach-live                   -  enabled
                                          + system.adapter.web.0                    : web                   : iobroker-kramsach-live                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                          + system.adapter.webui.0                  : webui                 : iobroker-kramsach-live                   -  enabled
                                          + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker-kramsach-live                   -  enabled
                                          + system.adapter.zigbee.0                 : zigbee                : iobroker-kramsach-live                   -  enabled, port: /dev/ttyUSB0
                                          + instance is alive
                                          Objects and States
                                          Objects:        32009
                                          States:         26991
                                          Ign:6 http://security.ubuntu.com/ubuntu noble-security InRelease
                                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       240773     67908/io.mqtt.0
                                          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       241563     68467/io.shelly.0
                                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       225677     64683/iobroker.js-c
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       226354     64683/iobroker.js-c
                                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       249631     69865/io.web.0
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       226581     64811/io.admin.0
                                          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       248213     69643/io.simple-api
                                          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       245806     68717/io.tuya.0
                                          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       245807     68717/io.tuya.0
                                          udp        0      0 0.0.0.0:7090            0.0.0.0:*                           1001       236456     67747/io.kecontact.
                                          udp        0      0 0.0.0.0:7092            0.0.0.0:*                           1001       236457     67747/io.kecontact.
                                          udp        0      0 0.0.0.0:46834           0.0.0.0:*                           1001       235441     67747/io.kecontact.
                                          2026-05-04 20:05:58.425  - warn: modbus.0 (67832) Error: undefined
                                          2026-05-04 20:05:58.425  - error: modbus.0 (67832) Request timed out.
                                          2026-05-04 20:05:58.425  - error: modbus.0 (67832) Client in error state.
                                          2026-05-04 20:05:58.425  - warn: modbus.0 (67832) [DevID_1/holdingRegs] Block 1047-1073: {}
                                          2026-05-04 20:05:59.426  - info: modbus.0 (67832) Disconnected from slave 192.168.2.43
                                          2026-05-04 20:06:07.390  - info: web.0 (69865) ==> Connected system.user.admin from ::ffff:192.168.2.186
                                          2026-05-04 20:06:08.026  - error: web.0 (69865) [getState] ERROR: Error: The id is empty! Please provide a valid id.
                                          2026-05-04 20:06:08.029  - error: web.0 (69865) [getState] ERROR: Error: The id is empty! Please provide a valid id.
                                          2026-05-04 20:06:08.040  - error: web.0 (69865) [getState] ERROR: Error: The id is empty! Please provide a valid id.
                                          2026-05-04 20:06:08.062  - info: webui.0 (69983) runCommand: uiConnected, parameter:
                                          2026-05-04 20:06:08.100  - error: web.0 (69865) [getState] ERROR: Error: The id is empty! Please provide a valid id.
                                          2026-05-04 20:06:08.130  - info: webui.0 (69983) runCommand: uiChangedView, parameter: start
                                          2026-05-04 20:06:08.156  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/anchored-region: EISDIR: illegal operation on a directory, read
                                          2026-05-04 20:06:08.203  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/breadcrumb: EISDIR: illegal operation on a directory, read
                                          2026-05-04 20:06:08.206  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/breadcrumb-item: EISDIR: illegal operation on a directory, read
                                          2026-05-04 20:06:08.219  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/data-grid: EISDIR: illegal operation on a directory, read
                                          2026-05-04 20:06:08.230  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/listbox: EISDIR: illegal operation on a directory, read
                                          2026-05-04 20:06:08.234  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/listbox-option: EISDIR: illegal operation on a directory, read
                                          2026-05-04 20:06:08.249  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/select: EISDIR: illegal operation on a directory, read
                                          2026-05-04 20:06:08.263  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/toolbar: EISDIR: illegal operation on a directory, read
                                          2026-05-04 20:06:08.264  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/tooltip: EISDIR: illegal operation on a directory, read
                                          2026-05-04 20:06:08.271  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/styles: EISDIR: illegal operation on a directory, read
                                          2026-05-04 20:06:08.452  - info: web.0 (69865) ==> Connected system.user.admin from ::ffff:192.168.2.186
                                          2026-05-04 20:06:09.429  - info: modbus.0 (67832) Connected to slave 192.168.2.43
                                          2026-05-04 20:06:28.960  - info: solax.0 (68592) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
