  4. neue Visualisierung "webui" (alternative zu vis & vis-2)
1.2k Beiträge 23 Kommentatoren 461.4k Aufrufe 22 Beobachtet
  • Smilie108S Offline
    Smilie108S Offline
    Smilie108
    #1149
    ;) ========== Start marking the full check here ===========
    Script v.2026-01-31
    *** BASE SYSTEM ***
    Operating System: Ubuntu 24.04.4 LTS
     Static hostname: iobroker-kramsach-live
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.8.0-111-generic
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
       Firmware Date: Tue 2014-04-01
        Firmware Age: 12y 1month 3d
    OS is similar to: debian
    model name      : QEMU Virtual CPU version 2.5+
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     19:41:01 up 12 min,  2 users,  load average: 1.53, 1.36, 0.89
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System codenamed 'noble' is an aging Ubuntu release! Please upgrade to the latest LTS release 'resolute' in due time!
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2026-05-04 19:41:01 CEST
               Universal time: Mon 2026-05-04 17:41:01 UTC
                     RTC time: Mon 2026-05-04 17:41:01
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    smilie108
    HOME=/home/smilie108
    GROUPS=smilie108 adm cdrom sudo dip plugdev lxd iobroker
    js-controller is not running
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:             20G        953M         18G        3.8M        1.6G         19G
    Swap:           8.6G          0B        8.6G
    Total:           29G        953M         27G
    Active iob-Instances:   1
            19779 M total memory
              911 M used memory
              831 M active memory
              813 M inactive memory
            17697 M free memory
              171 M buffer memory
             1368 M swap cache
             8191 M total swap
                0 M used swap
             8191 M free swap
    top - 19:41:02 up 12 min,  2 users,  load average: 1.53, 1.36, 0.89
    Tasks: 157 total,   2 running, 155 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 28.6 us,  4.8 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  19779.1 total,  17690.4 free,    918.6 used,   1539.6 buff/cache
    MiB Swap:   8192.0 total,   8192.0 free,      0.0 used.  18860.5 avail Mem
    *** FAILED SERVICES ***
      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
    * iobroker.service loaded failed failed ioBroker Server
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
            SUB    -> The low-level unit activation state, values depend on unit type.
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                        Type   Size  Used Avail Use% Mounted on
    tmpfs                             tmpfs  2.0G  1.1M  2.0G   1% /run
    /dev/mapper/ubuntu--vg-ubuntu--lv ext4    98G   58G   36G  62% /
    tmpfs                             tmpfs  9.7G     0  9.7G   0% /dev/shm
    tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
    /dev/sda2                         ext4   2.0G  200M  1.6G  11% /boot
    tmpfs                             tmpfs  2.0G   12K  2.0G   1% /run/user/1000
    [Mon May  4 19:28:18 2026] EXT4-fs (dm-0): mounted filesystem 8d603055-1d71-4ec7-84ad-951b1082fd39 ro with ordered data mode. Quota mode: none.
    [Mon May  4 19:28:18 2026] EXT4-fs (dm-0): re-mounted 8d603055-1d71-4ec7-84ad-951b1082fd39 r/w.
    [Mon May  4 19:28:19 2026] EXT4-fs (sda2): mounted filesystem 965f4498-2280-470d-b312-91df09b7b1f5 r/w with ordered data mode. Quota mode: none.
    Show mounted filesystems:
    TARGET  SOURCE                            FSTYPE OPTIONS
    /       /dev/mapper/ubuntu--vg-ubuntu--lv ext4   rw,relatime
    `-/boot /dev/sda2                         ext4   rw,relatime
    /var:
    2.5G    /var/
    1.4G    /var/lib
    970M    /var/lib/mysql
    942M    /var/log
    903M    /var/log/journal/18c66e219588459ea2005bc764231802
    Archived and active journals take up 902.9M in the file system.
    /opt/iobroker/backups:
    91M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    765M    /opt/iobroker/iobroker-data/
    271M    /opt/iobroker/iobroker-data/files
    195M    /opt/iobroker/iobroker-data/history
    134M    /opt/iobroker/iobroker-data/cloudless-homeconnect.0
    128M    /opt/iobroker/iobroker-data/backup-objects
    133M    /opt/iobroker/iobroker-data/cloudless-homeconnect.0/homeconnect-profile-downloader-win32-x64-1.0.1.zip
    29M     /opt/iobroker/iobroker-data/objects.jsonl
    13M     /opt/iobroker/iobroker-data/files/webui/node_modules/monaco-editor/esm/vs/editor/ts.worker.js
    8.2M    /opt/iobroker/iobroker-data/files/modbus.admin/assets/index-Blv_5nFZ.js
    7.8M    /opt/iobroker/iobroker-data/states.jsonl
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_cefeaafbdc82ee11b712469ec33d7414-if00-port0
    *** ZigBee Settings ***
    ⚠ HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'.
    Please check your setting:
    /dev/ttyUSB0
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.2
    /usr/bin/node           v22.22.2
    /usr/bin/npm            10.9.7
    /usr/bin/npx            10.9.7
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.2-1nodesource1
      Candidate: 22.22.2-1nodesource1
      Version table:
     *** 22.22.2-1nodesource1 1001
         22.22.1-1nodesource1 1001
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         18.19.1+dfsg-6ubuntu5 500
            500 http://at.archive.ubuntu.com/ubuntu noble/universe amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
      Smilie108S Offline
      Smilie108
      #1150
      ioBroker Status
      iobroker is not running on this host.
      Objects type: jsonl
      States type: jsonl
      Hosts:
      iobroker-kramsach-live iobroker-kramsach-live (version: 7.1.1, hostname: iobroker-kramsach-live, alive, uptime: 49)
      Core adapters versions
      js-controller: 7.1.1
      admin: 7.8.23
      javascript: 9.2.1
      nodejs modules from github: 1
      +-- iobroker.euhome@0.1.5 (git+ssh://git@github.com/TA2k/ioBroker.euhome.git#da498b16858260123ddad3633f344e0ef05c99de)
      Adapter State
      system.adapter.accuweather.0 : accuweather : iobroker-kramsach-live - disabled
      system.adapter.admin.0 : admin : iobroker-kramsach-live - enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0 : alias-manager : iobroker-kramsach-live - disabled
      system.adapter.apg-info.0 : apg-info : iobroker-kramsach-live - enabled
      system.adapter.backitup.0 : backitup : iobroker-kramsach-live - enabled
      system.adapter.bosch-ebike.0 : bosch-ebike : iobroker-kramsach-live - enabled
      system.adapter.cloudless-homeconnect.0 : cloudless-homeconnect : iobroker-kramsach-live - disabled
      system.adapter.discovery.0 : discovery : iobroker-kramsach-live - enabled
      system.adapter.echarts.0 : echarts : iobroker-kramsach-live - enabled
      system.adapter.email.0 : email : iobroker-kramsach-live - disabled
      system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-kramsach-live - enabled
      system.adapter.euhome.0 : euhome : iobroker-kramsach-live - enabled
      system.adapter.feiertage.0 : feiertage : iobroker-kramsach-live - enabled
      system.adapter.flexcharts.0 : flexcharts : iobroker-kramsach-live - disabled
      system.adapter.flexcharts.1 : flexcharts : iobroker-kramsach-live - disabled
      system.adapter.flot.0 : flot : iobroker-kramsach-live - disabled
      system.adapter.hass.0 : hass : iobroker-kramsach-live - enabled, port: 8123
      system.adapter.heatingcontrol.0 : heatingcontrol : iobroker-kramsach-live - enabled
      system.adapter.history.0 : history : iobroker-kramsach-live - enabled
      system.adapter.history.1 : history : iobroker-kramsach-live - enabled
      system.adapter.homeconnect.0 : homeconnect : iobroker-kramsach-live - enabled
      system.adapter.javascript.0 : javascript : iobroker-kramsach-live - enabled
      system.adapter.javascript.1 : javascript : iobroker-kramsach-live - enabled
      system.adapter.kecontact.0 : kecontact : iobroker-kramsach-live - enabled
      system.adapter.modbus.0 : modbus : iobroker-kramsach-live - enabled
      system.adapter.modbus.1 : modbus : iobroker-kramsach-live - disabled
      system.adapter.modbus.2 : modbus : iobroker-kramsach-live - disabled
      system.adapter.mqtt.0 : mqtt : iobroker-kramsach-live - enabled, port: 1883, bind: 0.0.0.0
      system.adapter.nissan.0 : nissan : iobroker-kramsach-live - disabled
      system.adapter.openweathermap.0 : openweathermap : iobroker-kramsach-live - enabled
      system.adapter.pegelalarm.0 : pegelalarm : iobroker-kramsach-live - enabled
      system.adapter.pi-hole2.0 : pi-hole2 : iobroker-kramsach-live - enabled, port: 80
      system.adapter.proxmox.0 : proxmox : iobroker-kramsach-live - enabled, port: 8006
      system.adapter.pvforecast.0 : pvforecast : iobroker-kramsach-live - enabled
      system.adapter.s7.0 : s7 : iobroker-kramsach-live - enabled
      system.adapter.samsung_tizen.0 : samsung_tizen : iobroker-kramsach-live - disabled, port: 8002
      system.adapter.scenes.0 : scenes : iobroker-kramsach-live - enabled
      system.adapter.scheduler.0 : scheduler : iobroker-kramsach-live - enabled
      system.adapter.shelly.0 : shelly : iobroker-kramsach-live - enabled, port: 1882, bind: 0.0.0.0
      system.adapter.signal-cmb.0 : signal-cmb : iobroker-kramsach-live - disabled
      system.adapter.simple-api.0 : simple-api : iobroker-kramsach-live - enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.solax.0 : solax : iobroker-kramsach-live - enabled
      system.adapter.sourceanalytix.0 : sourceanalytix : iobroker-kramsach-live - enabled
      system.adapter.sql.0 : sql : iobroker-kramsach-live - enabled, port: 3306
      system.adapter.sql.1 : sql : iobroker-kramsach-live - enabled, port: 3306
      system.adapter.sql.2 : sql : iobroker-kramsach-live - enabled, port: 3306
      system.adapter.sql.3 : sql : iobroker-kramsach-live - enabled
      system.adapter.sql.4 : sql : iobroker-kramsach-live - enabled
      system.adapter.sql.5 : sql : iobroker-kramsach-live - enabled, port: 3306
      system.adapter.sql.6 : sql : iobroker-kramsach-live - enabled, port: 3306
      system.adapter.sql.7 : sql : iobroker-kramsach-live - enabled, port: 3306
      system.adapter.sql.8 : sql : iobroker-kramsach-live - enabled, port: 3306
      system.adapter.sql.9 : sql : iobroker-kramsach-live - enabled, port: 3306
      system.adapter.tuya.0 : tuya : iobroker-kramsach-live - enabled
      system.adapter.viessmannapi.0 : viessmannapi : iobroker-kramsach-live - enabled
      system.adapter.web.0 : web : iobroker-kramsach-live - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.webui.0 : webui : iobroker-kramsach-live - disabled
      system.adapter.whatsapp-cmb.0 : whatsapp-cmb : iobroker-kramsach-live - enabled
      system.adapter.zigbee.0 : zigbee : iobroker-kramsach-live - enabled, port: /dev/ttyUSB0
      • instance is alive
      ioBroker-Repositories
      │ (index) │ name │ url │ auto upgrade │
      │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │
      │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │
      Active repo(s): beta
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: beta
      Adapter "accuweather" : 2.2.0 , installed 2.2.0
      Adapter "admin" : 7.8.23 , installed 7.8.23
      Adapter "alias-manager": 2.1.0 , installed 2.1.0
      Adapter "apg-info" : 0.1.32 , installed 0.1.32
      Adapter "backitup" : 3.3.17 , installed 3.3.17
      Adapter "bosch-ebike" : 0.1.12 , installed 0.1.12
      Adapter "cloudless-homeconnect": 1.6.4, installed 1.6.4
      Adapter "discovery" : 5.0.0 , installed 5.0.0
      Adapter "echarts" : 3.1.0 , installed 3.1.0
      Adapter "email" : 2.0.4 , installed 2.0.4
      Adapter "energiefluss-erweitert": 0.8.2, installed 0.8.2
      Adapter "feiertage" : 1.3.0 , installed 1.3.0
      Adapter "flexcharts" : 0.7.0 , installed 0.7.0
      Adapter "flot" : 1.12.0 , installed 1.12.0
      Adapter "hass" : 2.0.3 , installed 2.0.3
      Adapter "heatingcontrol": 3.1.4 , installed 3.1.4
      Adapter "history" : 4.0.0 , installed 4.0.0
      Adapter "homeconnect" : 1.5.2 , installed 1.5.2
      Adapter "javascript" : 9.2.1 , installed 9.2.1
      Controller "js-controller": 7.1.1 , installed 7.1.1
      Adapter "kecontact" : 3.6.0 , installed 3.6.0
      Adapter "modbus" : 8.1.3 , installed 8.1.3
      Adapter "mqtt" : 6.1.4 , installed 6.1.4
      Adapter "nissan" : 0.1.18 , installed 0.1.18
      Adapter "openweathermap": 1.4.0 , installed 1.4.0
      Adapter "pegelalarm" : 1.4.0 , installed 1.4.0
      Adapter "pi-hole2" : 1.1.1 , installed 1.1.1
      Adapter "proxmox" : 2.5.3 , installed 2.5.3
      Adapter "pvforecast" : 6.1.0 , installed 6.1.0
      Adapter "s7" : 1.5.0 , installed 1.5.0
      Adapter "samsung_tizen": 1.1.0 , installed 1.1.0
      Adapter "scenes" : 4.0.4 , installed 4.0.4
      Adapter "scheduler" : 1.5.0 , installed 1.5.0
      Adapter "shelly" : 10.6.1 , installed 10.6.1
      Adapter "signal-cmb" : 0.3.0 , installed 0.3.0
      Adapter "simple-api" : 3.0.7 , installed 3.0.7
      Adapter "socketio" : 7.1.3 , installed 7.1.3
      Adapter "solax" : 0.9.23 , installed 0.9.23
      Adapter "sourceanalytix": 0.4.14 , installed 0.4.14
      Adapter "sql" : 3.0.1 , installed 3.0.1
      Adapter "tuya" : 3.17.0 , installed 3.17.0
      Adapter "viessmannapi" : 2.4.5 , installed 2.4.5
      Adapter "web" : 8.1.0 , installed 8.1.0
      Adapter "webui" : 1.44.0 , installed 1.44.0
      Adapter "whatsapp-cmb" : 0.3.0 , installed 0.3.0
      Adapter "ws" : 4.1.0 , installed 4.1.0
      Adapter "zigbee" : 3.4.1 , installed 3.4.1
      • Smilie108S Smilie108
        ioBroker Status
        Objects type: jsonl
        States type: jsonl
        Hosts:
        admin: 7.8.23
        javascript: 9.2.1
        Adapter State
        • instance is alive
        #1151
        @Smilie108
        Poste die Ausgabe bitte 'in einem Rutsch' vollständig in ein Posting.
          Smilie108S Offline
          Smilie108
          #1152
          ok
          er war noch nicht fertig ;) gleich
            Smilie108S Offline
            Smilie108
            #1153
            Script v.2026-01-31
            *** BASE SYSTEM ***
                     Chassis: vm 🖴
              Virtualization: kvm
            Docker          : false
            Kernel          : x86_64
            Userland        : 64 bit
             19:43:23 up 15 min,  2 users,  load average: 1.30, 1.34, 0.95
            CPU threads: 4
                           Local time: Mon 2026-05-04 19:43:23 CEST
                       Universal time: Mon 2026-05-04 17:43:23 UTC
                             RTC time: Mon 2026-05-04 17:43:23
                          NTP service: active
                      RTC in local TZ: no
            smilie108
            Display-Manager:
            Desktop:
            Session:                tty
            *** MEMORY ***
            Mem:             20G        957M         18G        3.8M        1.6G         19G
            Swap:           8.6G          0B        8.6G
            Total:           29G        957M         27G
                      913 M used memory
                      855 M active memory
                      829 M inactive memory
                    17670 M free memory
                      174 M buffer memory
                     1389 M swap cache
                     8191 M total swap
                        0 M used swap
                     8191 M free swap
            top - 19:43:23 up 15 min,  2 users,  load average: 1.30, 1.34, 0.95
            Tasks: 159 total,   2 running, 157 sleeping,   0 stopped,   0 zombie
            %Cpu(s): 26.2 us,  4.8 sy,  0.0 ni, 69.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :  19779.1 total,  17690.5 free,    893.8 used,   1564.3 buff/cache
            MiB Swap:   8192.0 total,   8192.0 free,      0.0 used.  18885.3 avail Mem
            *** FILESYSTEM ***
            /var:
            2.5G    /var/
            1.4G    /var/lib
            970M    /var/lib/mysql
            942M    /var/log
            776M    /opt/iobroker/iobroker-data/
            40M     /opt/iobroker/iobroker-data/objects.jsonl
            USB-Devices by-id:
            ⚠ HINT:
            /dev/ttyUSB0
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            /usr/bin/npm            10.9.7
            /usr/bin/npx            10.9.7
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            admin:          7.8.23
            javascript:     9.2.1
            Adapter State
            + instance is alive
            Objects and States
            Objects:        31895
            States:         26449
            Hit:1 http://at.archive.ubuntu.com/ubuntu noble InRelease
            Hit:2 http://at.archive.ubuntu.com/ubuntu noble-updates InRelease
            Hit:3 http://at.archive.ubuntu.com/ubuntu noble-backports InRelease
            Hit:4 https://apt.grafana.com stable InRelease
            Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
            Hit:6 http://security.ubuntu.com/ubuntu noble-security InRelease
            Reading package lists...
            Pending systemupdates: 4
            *** Listening Ports ***
            tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      992        5876       652/systemd-resolve
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6881       1/init
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4317       1/init
            tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      992        5878       652/systemd-resolve
            tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      111        9236       973/mariadbd
            tcp6       0      0 :::22                   :::*                    LISTEN      0          6883       1/init
            tcp6       0      0 :::111                  :::*                    LISTEN      0          2875       1/init
            tcp6       0      0 :::80                   :::*                    LISTEN      0          10440      1139/apache2
            tcp6       0      0 :::3000                 :::*                    LISTEN      114        11519      1109/grafana
            udp        0      0 127.0.0.54:53           0.0.0.0:*                           992        5877       652/systemd-resolve
            udp        0      0 127.0.0.53:53           0.0.0.0:*                           992        5875       652/systemd-resolve
            udp        0      0 192.168.2.30:68         0.0.0.0:*                           998        8716       787/systemd-network
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          4318       1/init
            udp6       0      0 :::111                  :::*                                0          3864       1/init
            udp6       0      0 fe80::be24:11ff:fec:546 :::*                                998        9399       787/systemd-network
            2026-05-04 19:30:00.860  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-05-04 19:30:05.857  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-05-04 19:30:05.863  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-05-04 19:30:10.858  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-05-04 19:30:10.866  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-05-04 19:30:15.861  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-05-04 19:30:15.869  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-05-04 19:30:20.862  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-05-04 19:30:20.871  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-05-04 19:30:25.864  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-05-04 19:30:25.874  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-05-04 19:30:30.865  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-05-04 19:30:30.876  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-05-04 19:30:35.866  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-05-04 19:30:35.878  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-05-04 19:30:40.867  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-05-04 19:30:40.881  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-05-04 19:30:45.869  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2026-05-04 19:30:45.883  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
            2026-05-04 19:30:50.871  - info: sql.3 (2908) Objects database successfully reconnected
            2026-05-04 19:30:50.886  - info: sql.3 (2908) Objects database successfully reconnected
            2026-05-04 19:30:51.712  - info: sql.3 (2908) terminating
            2026-05-04 19:30:51.712  - info: sql.3 (2908) Terminated (NO_ERROR): Without reason
            2026-05-04 19:30:51.752  - info: sql.3 (2908) terminating
            iob diag has finished.
              Smilie108S Offline
              Smilie108
              #1154
              grad gesehen das ich mal upgraden sollte ubuntu
                #1155
                @Smilie108 sagte:
                26.04 ist aber auch gerade erst vor einer Woche veröffentlicht worden. Ein Upgrade würde ich für Herbst anpeilen. Dann sind die Kinderkrankheiten raus.
                • iobroker.service loaded failed failed ioBroker Server
                Starten den ioBroker. Dann sieht man mehr...
                  Smilie108S Offline
                  Smilie108
                  #1156
                  was soll mir dann *** LIFE CYCLE STATUS ***
                  Operating System codenamed 'noble' is an aging Ubuntu release! Please upgrade to the latest LTS release 'resolute' in due time! das sagen ?
                    #1157
                    @Smilie108
                    Das sagt dir, dass du zu gegebener Zeit ein Upgrade auf die aktuelle LTS-Version vornehmen solltest.
                    Ubuntu schaltet das aber ohnehin für die breite Masse erst nach dem ersten Pointrelease frei. Wird irgendwann im August der Fall sein.
                    Also ist Herbst 2026 ein guter Zeitpunkt dafür.
                      Smilie108S Offline
                      Smilie108
                      #1158
                      ;) ok bin grad am starten vom iob dann mach ich nochmal ein diag
                        Smilie108S Offline
                        Smilie108
                        #1159
                        Script v.2026-01-31
                        *** BASE SYSTEM ***
                                 Chassis: vm 🖴
                          Virtualization: kvm
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : 64 bit
                         20:04:22 up 36 min,  2 users,  load average: 2.96, 3.23, 2.14
                        CPU threads: 4
                                       Local time: Mon 2026-05-04 20:04:22 CEST
                                   Universal time: Mon 2026-05-04 18:04:22 UTC
                                         RTC time: Mon 2026-05-04 18:04:22
                                      NTP service: active
                                  RTC in local TZ: no
                        smilie108
                        iobroker
                        HOME=/home/iobroker
                        GROUPS=iobroker tty dialout audio video plugdev
                        Display-Manager:
                        Desktop:
                        Session:                tty
                        *** MEMORY ***
                        Mem:             20G        5.4G         13G        3.8M        1.8G         15G
                        Swap:           8.6G          0B        8.6G
                        Total:           29G        5.4G         22G
                        Active iob-Instances:   44
                                 5172 M used memory
                                 4996 M active memory
                                  941 M inactive memory
                                13272 M free memory
                                  178 M buffer memory
                                 1525 M swap cache
                                 8191 M total swap
                                    0 M used swap
                                 8191 M free swap
                        top - 20:04:22 up 36 min,  2 users,  load average: 2.96, 3.23, 2.14
                        Tasks: 207 total,   2 running, 205 sleeping,   0 stopped,   0 zombie
                        %Cpu(s): 34.9 us, 11.6 sy,  0.0 ni, 51.2 id,  0.0 wa,  0.0 hi,  2.3 si,  0.0 st
                        MiB Mem :  19779.1 total,  13275.8 free,   5169.0 used,   1703.8 buff/cache
                        MiB Swap:   8192.0 total,   8192.0 free,      0.0 used.  14610.1 avail Mem
                        0 loaded units listed.
                        *** FILESYSTEM ***
                        /var:
                        2.5G    /var/
                        1.4G    /var/lib
                        970M    /var/lib/mysql
                        942M    /var/log
                        787M    /opt/iobroker/iobroker-data/
                        44M     /opt/iobroker/iobroker-data/objects.jsonl
                        15M     /opt/iobroker/iobroker-data/states.jsonl
                        USB-Devices by-id:
                        ⚠ HINT:
                        /dev/ttyUSB0
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        /usr/bin/npm            10.9.7
                        /usr/bin/npx            10.9.7
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        iobroker-kramsach-live iobroker-kramsach-live (version: 7.1.1, hostname: iobroker-kramsach-live, alive, uptime: 363)
                        admin:          7.8.23
                        javascript:     9.2.1
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : iobroker-kramsach-live                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        + system.adapter.backitup.0               : backitup              : iobroker-kramsach-live                   -  enabled
                        + system.adapter.bosch-ebike.0            : bosch-ebike           : iobroker-kramsach-live                   -  enabled
                        + system.adapter.discovery.0              : discovery             : iobroker-kramsach-live                   -  enabled
                        + system.adapter.echarts.0                : echarts               : iobroker-kramsach-live                   -  enabled
                        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-kramsach-live                   -  enabled
                        + system.adapter.euhome.0                 : euhome                : iobroker-kramsach-live                   -  enabled
                        + system.adapter.hass.0                   : hass                  : iobroker-kramsach-live                   -  enabled, port: 8123
                        + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker-kramsach-live                   -  enabled
                        + system.adapter.history.0                : history               : iobroker-kramsach-live                   -  enabled
                        + system.adapter.history.1                : history               : iobroker-kramsach-live                   -  enabled
                        + system.adapter.homeconnect.0            : homeconnect           : iobroker-kramsach-live                   -  enabled
                        + system.adapter.javascript.0             : javascript            : iobroker-kramsach-live                   -  enabled
                        + system.adapter.javascript.1             : javascript            : iobroker-kramsach-live                   -  enabled
                        + system.adapter.kecontact.0              : kecontact             : iobroker-kramsach-live                   -  enabled
                        + system.adapter.modbus.0                 : modbus                : iobroker-kramsach-live                   -  enabled
                        + system.adapter.mqtt.0                   : mqtt                  : iobroker-kramsach-live                   -  enabled, port: 1883, bind: 0.0.0.0
                        + system.adapter.pi-hole2.0               : pi-hole2              : iobroker-kramsach-live                   -  enabled, port: 80
                        + system.adapter.proxmox.0                : proxmox               : iobroker-kramsach-live                   -  enabled, port: 8006
                        + system.adapter.pvforecast.0             : pvforecast            : iobroker-kramsach-live                   -  enabled
                        + system.adapter.s7.0                     : s7                    : iobroker-kramsach-live                   -  enabled
                        + system.adapter.scenes.0                 : scenes                : iobroker-kramsach-live                   -  enabled
                        + system.adapter.scheduler.0              : scheduler             : iobroker-kramsach-live                   -  enabled
                        + system.adapter.shelly.0                 : shelly                : iobroker-kramsach-live                   -  enabled, port: 1882, bind: 0.0.0.0
                        + system.adapter.simple-api.0             : simple-api            : iobroker-kramsach-live                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                        + system.adapter.solax.0                  : solax                 : iobroker-kramsach-live                   -  enabled
                        + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker-kramsach-live                   -  enabled
                        + system.adapter.sql.0                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                        + system.adapter.sql.1                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                        + system.adapter.sql.2                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                        + system.adapter.sql.3                    : sql                   : iobroker-kramsach-live                   -  enabled
                        + system.adapter.sql.4                    : sql                   : iobroker-kramsach-live                   -  enabled
                        + system.adapter.sql.5                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                        + system.adapter.sql.6                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                        + system.adapter.sql.7                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                        + system.adapter.sql.8                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                        + system.adapter.sql.9                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                        + system.adapter.tuya.0                   : tuya                  : iobroker-kramsach-live                   -  enabled
                        + system.adapter.viessmannapi.0           : viessmannapi          : iobroker-kramsach-live                   -  enabled
                        + system.adapter.web.0                    : web                   : iobroker-kramsach-live                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        + system.adapter.webui.0                  : webui                 : iobroker-kramsach-live                   -  enabled
                        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker-kramsach-live                   -  enabled
                        + system.adapter.zigbee.0                 : zigbee                : iobroker-kramsach-live                   -  enabled, port: /dev/ttyUSB0
                        + instance is alive
                        Objects and States
                        Objects:        32009
                        States:         26991
                        Ign:6 http://security.ubuntu.com/ubuntu noble-security InRelease
                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       240773     67908/io.mqtt.0
                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       241563     68467/io.shelly.0
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       225677     64683/iobroker.js-c
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       226354     64683/iobroker.js-c
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       249631     69865/io.web.0
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       226581     64811/io.admin.0
                        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       248213     69643/io.simple-api
                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       245806     68717/io.tuya.0
                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       245807     68717/io.tuya.0
                        udp        0      0 0.0.0.0:7090            0.0.0.0:*                           1001       236456     67747/io.kecontact.
                        udp        0      0 0.0.0.0:7092            0.0.0.0:*                           1001       236457     67747/io.kecontact.
                        udp        0      0 0.0.0.0:46834           0.0.0.0:*                           1001       235441     67747/io.kecontact.
                        2026-05-04 20:05:58.425  - warn: modbus.0 (67832) Error: undefined
                        2026-05-04 20:05:58.425  - error: modbus.0 (67832) Request timed out.
                        2026-05-04 20:05:58.425  - error: modbus.0 (67832) Client in error state.
                        2026-05-04 20:05:58.425  - warn: modbus.0 (67832) [DevID_1/holdingRegs] Block 1047-1073: {}
                        2026-05-04 20:05:59.426  - info: modbus.0 (67832) Disconnected from slave 192.168.2.43
                        2026-05-04 20:06:07.390  - info: web.0 (69865) ==> Connected system.user.admin from ::ffff:192.168.2.186
                        2026-05-04 20:06:08.026  - error: web.0 (69865) [getState] ERROR: Error: The id is empty! Please provide a valid id.
                        2026-05-04 20:06:08.029  - error: web.0 (69865) [getState] ERROR: Error: The id is empty! Please provide a valid id.
                        2026-05-04 20:06:08.040  - error: web.0 (69865) [getState] ERROR: Error: The id is empty! Please provide a valid id.
                        2026-05-04 20:06:08.062  - info: webui.0 (69983) runCommand: uiConnected, parameter:
                        2026-05-04 20:06:08.100  - error: web.0 (69865) [getState] ERROR: Error: The id is empty! Please provide a valid id.
                        2026-05-04 20:06:08.130  - info: webui.0 (69983) runCommand: uiChangedView, parameter: start
                        2026-05-04 20:06:08.156  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/anchored-region: EISDIR: illegal operation on a directory, read
                        2026-05-04 20:06:08.203  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/breadcrumb: EISDIR: illegal operation on a directory, read
                        2026-05-04 20:06:08.206  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/breadcrumb-item: EISDIR: illegal operation on a directory, read
                        2026-05-04 20:06:08.219  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/data-grid: EISDIR: illegal operation on a directory, read
                        2026-05-04 20:06:08.230  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/listbox: EISDIR: illegal operation on a directory, read
                        2026-05-04 20:06:08.234  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/listbox-option: EISDIR: illegal operation on a directory, read
                        2026-05-04 20:06:08.249  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/select: EISDIR: illegal operation on a directory, read
                        2026-05-04 20:06:08.263  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/toolbar: EISDIR: illegal operation on a directory, read
                        2026-05-04 20:06:08.264  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/tooltip: EISDIR: illegal operation on a directory, read
                        2026-05-04 20:06:08.271  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/styles: EISDIR: illegal operation on a directory, read
                        2026-05-04 20:06:08.452  - info: web.0 (69865) ==> Connected system.user.admin from ::ffff:192.168.2.186
                        2026-05-04 20:06:09.429  - info: modbus.0 (67832) Connected to slave 192.168.2.43
                        2026-05-04 20:06:28.960  - info: solax.0 (68592) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
                          Smilie108S Offline
                          Smilie108
                          #1160
                          das ist jetzt wärend dem laufenden betrieb
                            Script v.2026-01-31
                            *** BASE SYSTEM ***
                                     Chassis: vm 🖴
                              Virtualization: kvm
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                            CPU threads: 4
                                          NTP service: active
                                      RTC in local TZ: no
                            smilie108
                            iobroker
                            HOME=/home/iobroker
                            Display-Manager:
                            Desktop:
                            Session:                tty
                            *** MEMORY ***
                            Swap:           8.6G          0B        8.6G
                            Total:           29G        5.4G         22G
                                     5172 M used memory
                                    13272 M free memory
                                      178 M buffer memory
                                     1525 M swap cache
                                     8191 M total swap
                                        0 M used swap
                                     8191 M free swap
                            *** FILESYSTEM ***
                            /var:
                            2.5G    /var/
                            1.4G    /var/lib
                            970M    /var/lib/mysql
                            942M    /var/log
                            USB-Devices by-id:
                            ⚠ HINT:
                            /dev/ttyUSB0
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            /usr/bin/npm            10.9.7
                            /usr/bin/npx            10.9.7
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            admin:          7.8.23
                            javascript:     9.2.1
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        32009
                            States:         26991
                            #1161
                            @Smilie108 sagte:
                            ⚠ HINT:
                            /dev/ttyUSB0
                            Hat mit deinem Problem zwar nichts zu tun, aber trag in zigbee.0 statt /dev/ttyUSB0 besser:
                            ein.
                            ZEHN sql-Instanzen? Was treibst du da?
                            Spiel die ein.
                            Zu
                            fällt mir aber auch nix ein. Nur das ich auf meinem Testsystem mit
                            Adapter "webui" : 1.39.0 , installed 1.39.0
                            gar nichts mit @fluentui installiert habe.
                              Smilie108S Offline
                              Smilie108
                              #1162
                              ;) naja ich habe gerne gewerke getrennt und das einfachste und übersichtlichste ist es auf instanzbasis wenn sich die hw mal wieder ändert und du eine neue heizung hast aber die daten der alten für vergleichswecke zb noch etwas behalten wilst dann mach ich eine neue db und schreib das neu darein kann aber die alte zum vergleichen beutzen und bei bedarf auch einfach mal elleminieren
                                Smilie108S Offline
                                Smilie108
                                #1163
                                @thomas-braun aber danke fürs nachschauen ich hab das mal deinstalliert und werde sehen was nicht mher geht ;)
                                • jogibear9988J Offline
                                  jogibear9988
                                  #1164
                                  du kannst in webui ja auch pakete installieren:
                                  Check my ioBroker webui - a vis alternative
                                  see: https://github.com/iobroker-community-adapters/ioBroker.webui
                                    Smilie108S Offline
                                    Smilie108
                                    #1165
                                    @jogibear9988 ja da hab ich das flue ja schon mal neu instalierne probiert und hatte trotzdem die verzeichniss fehler nur so als hinweis ;)
                                      jogibear9988
                                      #1166
                                      ja, das liegt eben an den npm paketen....
                                      da ist nicht alles standardisiert, manche gehen, manche nicht, manche gingen mal....
                                      bsp fluent ui, hat ne fehlerhafte webcomponent mainifest json...
                                        Kamikaze
                                        schrieb zuletzt editiert von
                                        #1167
                                        Hallo jogibear,
                                        ich weiss nicht, wo du als erstes nachschaust, abewr ich habe auf Github einen Issue eröffnet, da ich meine Controls nicht exportiert bekomme.
                                        Wäre schön, wenn du dir das einmal ansehen könntest.
