neue Visualisierung "webui" (alternative zu vis & vis-2)
Script v.2026-01-31 *** BASE SYSTEM *** Operating System: Ubuntu 24.04.4 LTS Static hostname: iobroker-kramsach-live Icon name: computer-vm Chassis: vm 🖴 Virtualization: kvm Kernel: Linux 6.8.0-111-generic Architecture: x86-64 Hardware Vendor: QEMU Hardware Model: Standard PC _i440FX + PIIX, 1996_ Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org Firmware Date: Tue 2014-04-01 Firmware Age: 12y 1month 3d OS is similar to: debian model name : QEMU Virtual CPU version 2.5+ Docker : false Virtualization : kvm Kernel : x86_64 Userland : 64 bit Systemuptime and Load: 20:04:22 up 36 min, 2 users, load average: 2.96, 3.23, 2.14 CPU threads: 4 *** LIFE CYCLE STATUS *** Operating System codenamed 'noble' is an aging Ubuntu release! Please upgrade to the latest LTS release 'resolute' in due time! *** TIME AND TIMEZONES *** Local time: Mon 2026-05-04 20:04:22 CEST Universal time: Mon 2026-05-04 18:04:22 UTC RTC time: Mon 2026-05-04 18:04:22 Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': smilie108 HOME=/home/smilie108 GROUPS=smilie108 adm cdrom sudo dip plugdev lxd iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev *** DISPLAY-SERVER SETUP *** Display-Server: false Unit display-manager.service could not be found. Display-Manager: Desktop: Session: tty *** MEMORY *** total used free shared buff/cache available Mem: 20G 5.4G 13G 3.8M 1.8G 15G Swap: 8.6G 0B 8.6G Total: 29G 5.4G 22G Active iob-Instances: 44 19779 M total memory 5172 M used memory 4996 M active memory 941 M inactive memory 13272 M free memory 178 M buffer memory 1525 M swap cache 8191 M total swap 0 M used swap 8191 M free swap *** top - Table Of Processes *** top - 20:04:22 up 36 min, 2 users, load average: 2.96, 3.23, 2.14 Tasks: 207 total, 2 running, 205 sleeping, 0 stopped, 0 zombie %Cpu(s): 34.9 us, 11.6 sy, 0.0 ni, 51.2 id, 0.0 wa, 0.0 hi, 2.3 si, 0.0 st MiB Mem : 19779.1 total, 13275.8 free, 5169.0 used, 1703.8 buff/cache MiB Swap: 8192.0 total, 8192.0 free, 0.0 used. 14610.1 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on tmpfs tmpfs 2.0G 1.1M 2.0G 1% /run /dev/mapper/ubuntu--vg-ubuntu--lv ext4 98G 58G 36G 62% / tmpfs tmpfs 9.7G 0 9.7G 0% /dev/shm tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock /dev/sda2 ext4 2.0G 200M 1.6G 11% /boot tmpfs tmpfs 2.0G 12K 2.0G 1% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Mon May 4 19:28:18 2026] EXT4-fs (dm-0): mounted filesystem 8d603055-1d71-4ec7-84ad-951b1082fd39 ro with ordered data mode. Quota mode: none. [Mon May 4 19:28:18 2026] EXT4-fs (dm-0): re-mounted 8d603055-1d71-4ec7-84ad-951b1082fd39 r/w. [Mon May 4 19:28:19 2026] EXT4-fs (sda2): mounted filesystem 965f4498-2280-470d-b312-91df09b7b1f5 r/w with ordered data mode. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mapper/ubuntu--vg-ubuntu--lv ext4 rw,relatime `-/boot /dev/sda2 ext4 rw,relatime Files in neuralgic directories: /var: 2.5G /var/ 1.4G /var/lib 970M /var/lib/mysql 942M /var/log 903M /var/log/journal/18c66e219588459ea2005bc764231802 Archived and active journals take up 902.9M in the file system. /opt/iobroker/backups: 91M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 787M /opt/iobroker/iobroker-data/ 271M /opt/iobroker/iobroker-data/files 195M /opt/iobroker/iobroker-data/history 134M /opt/iobroker/iobroker-data/cloudless-homeconnect.0 128M /opt/iobroker/iobroker-data/backup-objects The five largest files in iobroker-data are: 133M /opt/iobroker/iobroker-data/cloudless-homeconnect.0/homeconnect-profile-downloader-win32-x64-1.0.1.zip 44M /opt/iobroker/iobroker-data/objects.jsonl 15M /opt/iobroker/iobroker-data/states.jsonl 13M /opt/iobroker/iobroker-data/files/webui/node_modules/monaco-editor/esm/vs/editor/ts.worker.js 8.2M /opt/iobroker/iobroker-data/files/modbus.admin/assets/index-Blv_5nFZ.js USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_cefeaafbdc82ee11b712469ec33d7414-if00-port0 *** ZigBee Settings *** ⚠ HINT: Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting: /dev/ttyUSB0 Zigbee Network Settings on your coordinator/in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' *** NodeJS-Installation *** /usr/bin/nodejs v22.22.2 /usr/bin/node v22.22.2 /usr/bin/npm 10.9.7 /usr/bin/npx 10.9.7 ✓ Node.js installation is correct nodejs: Installed: 22.22.2-1nodesource1 Candidate: 22.22.2-1nodesource1 Version table: *** 22.22.2-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 22.22.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.22.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.21.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.15.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.5.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.4.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 18.19.1+dfsg-6ubuntu5 500 500 http://at.archive.ubuntu.com/ubuntu noble/universe amd64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: █████ ██ ██ ██████ ██████ ██████ ██████ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ███████ ██ ██ ██ ███ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ███████ ███████ ██████ ██████ ██████ ██████ ██ *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: iobroker-kramsach-live iobroker-kramsach-live (version: 7.1.1, hostname: iobroker-kramsach-live, alive, uptime: 363) Core adapters versions js-controller: 7.1.1 admin: 7.8.23 javascript: 9.2.1 nodejs modules from github: 1 +-- iobroker.euhome@0.1.5 (git+ssh://git@github.com/TA2k/ioBroker.euhome.git#da498b16858260123ddad3633f344e0ef05c99de) Adapter State system.adapter.accuweather.0 : accuweather : iobroker-kramsach-live - disabled + system.adapter.admin.0 : admin : iobroker-kramsach-live - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.alias-manager.0 : alias-manager : iobroker-kramsach-live - disabled system.adapter.apg-info.0 : apg-info : iobroker-kramsach-live - enabled + system.adapter.backitup.0 : backitup : iobroker-kramsach-live - enabled + system.adapter.bosch-ebike.0 : bosch-ebike : iobroker-kramsach-live - enabled system.adapter.cloudless-homeconnect.0 : cloudless-homeconnect : iobroker-kramsach-live - disabled + system.adapter.discovery.0 : discovery : iobroker-kramsach-live - enabled + system.adapter.echarts.0 : echarts : iobroker-kramsach-live - enabled system.adapter.email.0 : email : iobroker-kramsach-live - disabled + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-kramsach-live - enabled + system.adapter.euhome.0 : euhome : iobroker-kramsach-live - enabled system.adapter.feiertage.0 : feiertage : iobroker-kramsach-live - enabled system.adapter.flexcharts.0 : flexcharts : iobroker-kramsach-live - disabled system.adapter.flexcharts.1 : flexcharts : iobroker-kramsach-live - disabled system.adapter.flot.0 : flot : iobroker-kramsach-live - disabled + system.adapter.hass.0 : hass : iobroker-kramsach-live - enabled, port: 8123 + system.adapter.heatingcontrol.0 : heatingcontrol : iobroker-kramsach-live - enabled + system.adapter.history.0 : history : iobroker-kramsach-live - enabled + system.adapter.history.1 : history : iobroker-kramsach-live - enabled + system.adapter.homeconnect.0 : homeconnect : iobroker-kramsach-live - enabled + system.adapter.javascript.0 : javascript : iobroker-kramsach-live - enabled + system.adapter.javascript.1 : javascript : iobroker-kramsach-live - enabled + system.adapter.kecontact.0 : kecontact : iobroker-kramsach-live - enabled + system.adapter.modbus.0 : modbus : iobroker-kramsach-live - enabled system.adapter.modbus.1 : modbus : iobroker-kramsach-live - disabled system.adapter.modbus.2 : modbus : iobroker-kramsach-live - disabled + system.adapter.mqtt.0 : mqtt : iobroker-kramsach-live - enabled, port: 1883, bind: 0.0.0.0 system.adapter.nissan.0 : nissan : iobroker-kramsach-live - disabled system.adapter.openweathermap.0 : openweathermap : iobroker-kramsach-live - enabled system.adapter.pegelalarm.0 : pegelalarm : iobroker-kramsach-live - enabled + system.adapter.pi-hole2.0 : pi-hole2 : iobroker-kramsach-live - enabled, port: 80 + system.adapter.proxmox.0 : proxmox : iobroker-kramsach-live - enabled, port: 8006 + system.adapter.pvforecast.0 : pvforecast : iobroker-kramsach-live - enabled + system.adapter.s7.0 : s7 : iobroker-kramsach-live - enabled system.adapter.samsung_tizen.0 : samsung_tizen : iobroker-kramsach-live - disabled, port: 8002 + system.adapter.scenes.0 : scenes : iobroker-kramsach-live - enabled + system.adapter.scheduler.0 : scheduler : iobroker-kramsach-live - enabled + system.adapter.shelly.0 : shelly : iobroker-kramsach-live - enabled, port: 1882, bind: 0.0.0.0 system.adapter.signal-cmb.0 : signal-cmb : iobroker-kramsach-live - disabled + system.adapter.simple-api.0 : simple-api : iobroker-kramsach-live - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.solax.0 : solax : iobroker-kramsach-live - enabled + system.adapter.sourceanalytix.0 : sourceanalytix : iobroker-kramsach-live - enabled + system.adapter.sql.0 : sql : iobroker-kramsach-live - enabled, port: 3306 + system.adapter.sql.1 : sql : iobroker-kramsach-live - enabled, port: 3306 + system.adapter.sql.2 : sql : iobroker-kramsach-live - enabled, port: 3306 + system.adapter.sql.3 : sql : iobroker-kramsach-live - enabled + system.adapter.sql.4 : sql : iobroker-kramsach-live - enabled + system.adapter.sql.5 : sql : iobroker-kramsach-live - enabled, port: 3306 + system.adapter.sql.6 : sql : iobroker-kramsach-live - enabled, port: 3306 + system.adapter.sql.7 : sql : iobroker-kramsach-live - enabled, port: 3306 + system.adapter.sql.8 : sql : iobroker-kramsach-live - enabled, port: 3306 + system.adapter.sql.9 : sql : iobroker-kramsach-live - enabled, port: 3306 + system.adapter.tuya.0 : tuya : iobroker-kramsach-live - enabled + system.adapter.viessmannapi.0 : viessmannapi : iobroker-kramsach-live - enabled + system.adapter.web.0 : web : iobroker-kramsach-live - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.webui.0 : webui : iobroker-kramsach-live - enabled + system.adapter.whatsapp-cmb.0 : whatsapp-cmb : iobroker-kramsach-live - enabled + system.adapter.zigbee.0 : zigbee : iobroker-kramsach-live - enabled, port: /dev/ttyUSB0 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobroker-kramsach-live - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.hass.0 : hass : iobroker-kramsach-live - enabled, port: 8123 + system.adapter.mqtt.0 : mqtt : iobroker-kramsach-live - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.pi-hole2.0 : pi-hole2 : iobroker-kramsach-live - enabled, port: 80 + system.adapter.proxmox.0 : proxmox : iobroker-kramsach-live - enabled, port: 8006 + system.adapter.shelly.0 : shelly : iobroker-kramsach-live - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : iobroker-kramsach-live - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.sql.0 : sql : iobroker-kramsach-live - enabled, port: 3306 + system.adapter.sql.1 : sql : iobroker-kramsach-live - enabled, port: 3306 + system.adapter.sql.2 : sql : iobroker-kramsach-live - enabled, port: 3306 + system.adapter.sql.5 : sql : iobroker-kramsach-live - enabled, port: 3306 + system.adapter.sql.6 : sql : iobroker-kramsach-live - enabled, port: 3306 + system.adapter.sql.7 : sql : iobroker-kramsach-live - enabled, port: 3306 + system.adapter.sql.8 : sql : iobroker-kramsach-live - enabled, port: 3306 + system.adapter.sql.9 : sql : iobroker-kramsach-live - enabled, port: 3306 + system.adapter.web.0 : web : iobroker-kramsach-live - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : iobroker-kramsach-live - enabled, port: /dev/ttyUSB0 ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): beta Upgrade policy: none Installed ioBroker-Adapters Used repository: beta Adapter "accuweather" : 2.2.0 , installed 2.2.0 Adapter "admin" : 7.8.23 , installed 7.8.23 Adapter "alias-manager": 2.1.0 , installed 2.1.0 Adapter "apg-info" : 0.1.32 , installed 0.1.32 Adapter "backitup" : 3.3.17 , installed 3.3.17 Adapter "bosch-ebike" : 0.1.12 , installed 0.1.12 Adapter "cloudless-homeconnect": 1.6.4, installed 1.6.4 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "echarts" : 3.1.0 , installed 3.1.0 Adapter "email" : 2.0.4 , installed 2.0.4 Adapter "energiefluss-erweitert": 0.8.2, installed 0.8.2 Adapter "feiertage" : 1.3.0 , installed 1.3.0 Adapter "flexcharts" : 0.7.0 , installed 0.7.0 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "hass" : 2.0.3 , installed 2.0.3 Adapter "heatingcontrol": 3.1.4 , installed 3.1.4 Adapter "history" : 4.0.0 , installed 4.0.0 Adapter "homeconnect" : 1.5.2 , installed 1.5.2 Adapter "javascript" : 9.2.1 , installed 9.2.1 Controller "js-controller": 7.1.1 , installed 7.1.1 Adapter "kecontact" : 3.6.0 , installed 3.6.0 Adapter "modbus" : 8.1.3 , installed 8.1.3 Adapter "mqtt" : 6.1.4 , installed 6.1.4 Adapter "nissan" : 0.1.18 , installed 0.1.18 Adapter "openweathermap": 1.4.0 , installed 1.4.0 Adapter "pegelalarm" : 1.4.0 , installed 1.4.0 Adapter "pi-hole2" : 1.1.1 , installed 1.1.1 Adapter "proxmox" : 2.5.3 , installed 2.5.3 Adapter "pvforecast" : 6.1.0 , installed 6.1.0 Adapter "s7" : 1.5.0 , installed 1.5.0 Adapter "samsung_tizen": 1.1.0 , installed 1.1.0 Adapter "scenes" : 4.0.4 , installed 4.0.4 Adapter "scheduler" : 1.5.0 , installed 1.5.0 Adapter "shelly" : 10.6.1 , installed 10.6.1 Adapter "signal-cmb" : 0.3.0 , installed 0.3.0 Adapter "simple-api" : 3.0.7 , installed 3.0.7 Adapter "socketio" : 7.1.3 , installed 7.1.3 Adapter "solax" : 0.9.23 , installed 0.9.23 Adapter "sourceanalytix": 0.4.14 , installed 0.4.14 Adapter "sql" : 3.0.1 , installed 3.0.1 Adapter "tuya" : 3.17.0 , installed 3.17.0 Adapter "viessmannapi" : 2.4.5 , installed 2.4.5 Adapter "web" : 8.1.0 , installed 8.1.0 Adapter "webui" : 1.44.0 , installed 1.44.0 Adapter "whatsapp-cmb" : 0.3.0 , installed 0.3.0 Adapter "ws" : 4.1.0 , installed 4.1.0 Adapter "zigbee" : 3.4.1 , installed 3.4.1 Objects and States Please stand by - This may take a while Objects: 32009 States: 26991 *** OS-Repositories and Updates *** Hit:1 http://at.archive.ubuntu.com/ubuntu noble InRelease Hit:2 http://at.archive.ubuntu.com/ubuntu noble-updates InRelease Hit:3 http://at.archive.ubuntu.com/ubuntu noble-backports InRelease Hit:4 https://apt.grafana.com stable InRelease Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease Ign:6 http://security.ubuntu.com/ubuntu noble-security InRelease Hit:6 http://security.ubuntu.com/ubuntu noble-security InRelease Reading package lists... Pending systemupdates: 4 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN 992 5876 652/systemd-resolve tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 6881 1/init tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 4317 1/init tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 240773 67908/io.mqtt.0 tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1001 241563 68467/io.shelly.0 tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 225677 64683/iobroker.js-c tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 226354 64683/iobroker.js-c tcp 0 0 127.0.0.54:53 0.0.0.0:* LISTEN 992 5878 652/systemd-resolve tcp 0 0 127.0.0.1:3306 0.0.0.0:* LISTEN 111 9236 973/mariadbd tcp6 0 0 :::8082 :::* LISTEN 1001 249631 69865/io.web.0 tcp6 0 0 :::8081 :::* LISTEN 1001 226581 64811/io.admin.0 tcp6 0 0 :::8087 :::* LISTEN 1001 248213 69643/io.simple-api tcp6 0 0 :::22 :::* LISTEN 0 6883 1/init tcp6 0 0 :::111 :::* LISTEN 0 2875 1/init tcp6 0 0 :::80 :::* LISTEN 0 10440 1139/apache2 tcp6 0 0 :::3000 :::* LISTEN 114 11519 1109/grafana udp 0 0 0.0.0.0:6666 0.0.0.0:* 1001 245806 68717/io.tuya.0 udp 0 0 0.0.0.0:6667 0.0.0.0:* 1001 245807 68717/io.tuya.0 udp 0 0 0.0.0.0:7090 0.0.0.0:* 1001 236456 67747/io.kecontact. udp 0 0 0.0.0.0:7092 0.0.0.0:* 1001 236457 67747/io.kecontact. udp 0 0 0.0.0.0:46834 0.0.0.0:* 1001 235441 67747/io.kecontact. udp 0 0 127.0.0.54:53 0.0.0.0:* 992 5877 652/systemd-resolve udp 0 0 127.0.0.53:53 0.0.0.0:* 992 5875 652/systemd-resolve udp 0 0 192.168.2.30:68 0.0.0.0:* 998 8716 787/systemd-network udp 0 0 0.0.0.0:111 0.0.0.0:* 0 4318 1/init udp6 0 0 :::111 :::* 0 3864 1/init udp6 0 0 fe80::be24:11ff:fec:546 :::* 998 9399 787/systemd-network *** Log File - Last 25 Lines *** 2026-05-04 20:05:58.425 - warn: modbus.0 (67832) Error: undefined 2026-05-04 20:05:58.425 - error: modbus.0 (67832) Request timed out. 2026-05-04 20:05:58.425 - error: modbus.0 (67832) Client in error state. 2026-05-04 20:05:58.425 - warn: modbus.0 (67832) [DevID_1/holdingRegs] Block 1047-1073: {} 2026-05-04 20:05:59.426 - info: modbus.0 (67832) Disconnected from slave 192.168.2.43 2026-05-04 20:06:07.390 - info: web.0 (69865) ==> Connected system.user.admin from ::ffff:192.168.2.186 2026-05-04 20:06:08.026 - error: web.0 (69865) [getState] ERROR: Error: The id is empty! Please provide a valid id. 2026-05-04 20:06:08.029 - error: web.0 (69865) [getState] ERROR: Error: The id is empty! Please provide a valid id. 2026-05-04 20:06:08.040 - error: web.0 (69865) [getState] ERROR: Error: The id is empty! Please provide a valid id. 2026-05-04 20:06:08.062 - info: webui.0 (69983) runCommand: uiConnected, parameter: 2026-05-04 20:06:08.100 - error: web.0 (69865) [getState] ERROR: Error: The id is empty! Please provide a valid id. 2026-05-04 20:06:08.130 - info: webui.0 (69983) runCommand: uiChangedView, parameter: start 2026-05-04 20:06:08.156 - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/anchored-region: EISDIR: illegal operation on a directory, read 2026-05-04 20:06:08.203 - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/breadcrumb: EISDIR: illegal operation on a directory, read 2026-05-04 20:06:08.206 - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/breadcrumb-item: EISDIR: illegal operation on a directory, read 2026-05-04 20:06:08.219 - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/data-grid: EISDIR: illegal operation on a directory, read 2026-05-04 20:06:08.230 - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/listbox: EISDIR: illegal operation on a directory, read 2026-05-04 20:06:08.234 - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/listbox-option: EISDIR: illegal operation on a directory, read 2026-05-04 20:06:08.249 - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/select: EISDIR: illegal operation on a directory, read 2026-05-04 20:06:08.263 - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/toolbar: EISDIR: illegal operation on a directory, read 2026-05-04 20:06:08.264 - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/tooltip: EISDIR: illegal operation on a directory, read 2026-05-04 20:06:08.271 - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/styles: EISDIR: illegal operation on a directory, read 2026-05-04 20:06:08.452 - info: web.0 (69865) ==> Connected system.user.admin from ::ffff:192.168.2.186 2026-05-04 20:06:09.429 - info: modbus.0 (67832) Connected to slave 192.168.2.43 2026-05-04 20:06:28.960 - info: solax.0 (68592) State value to set for "solax.0.data.json" has to be type "string" but received type "number"============ Mark until here for C&P =============
iob diag has finished.
⚠ HINT:
/dev/ttyUSB0Hat mit deinem Problem zwar nichts zu tun, aber trag in zigbee.0 statt /dev/ttyUSB0 besser:
/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_cefeaafbdc82ee11b712469ec33d7414-if00-port0ein.
ZEHN sql-Instanzen? Was treibst du da?
Spiel die ein.
Zu
2026-05-04 20:06:08.156 - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/anchored-region: EISDIR: illegal operation on a directory, read 2026-05-04 20:06:08.203 - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/breadcrumb: EISDIR: illegal operation on a directory, read 2026-05-04 20:06:08.206 - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/breadcrumb-item: EISDIR: illegal operation on a directory, read 2026-05-04 20:06:08.219 - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/data-grid: EISDIR: illegal operation on a directory, read 2026-05-04 20:06:08.230 - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/listbox: EISDIR: illegal operation on a directory, read 2026-05-04 20:06:08.234 - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/listbox-option: EISDIR: illegal operation on a directory, read 2026-05-04 20:06:08.249 - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/select: EISDIR: illegal operation on a directory, read 2026-05-04 20:06:08.263 - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/toolbar: EISDIR: illegal operation on a directory, read 2026-05-04 20:06:08.264 - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/tooltip: EISDIR: illegal operation on a directory, read 2026-05-04 20:06:08.271 - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/styles: EISDIR: illegal operation on a directory, readfällt mir aber auch nix ein. Nur das ich auf meinem Testsystem mit
Adapter "webui" : 1.39.0 , installed 1.39.0
gar nichts mit @fluentui installiert habe. -
;) naja ich habe gerne gewerke getrennt und das einfachste und übersichtlichste ist es auf instanzbasis wenn sich die hw mal wieder ändert und du eine neue heizung hast aber die daten der alten für vergleichswecke zb noch etwas behalten wilst dann mach ich eine neue db und schreib das neu darein kann aber die alte zum vergleichen beutzen und bei bedarf auch einfach mal elleminieren
@thomas-braun aber danke fürs nachschauen ich hab das mal deinstalliert und werde sehen was nicht mher geht ;)
du kannst in webui ja auch pakete installieren:
@jogibear9988 ja da hab ich das flue ja schon mal neu instalierne probiert und hatte trotzdem die verzeichniss fehler nur so als hinweis ;)
ja, das liegt eben an den npm paketen....
da ist nicht alles standardisiert, manche gehen, manche nicht, manche gingen mal....
bsp fluent ui, hat ne fehlerhafte webcomponent mainifest json...
