  4. neue Visualisierung "webui" (alternative zu vis & vis-2)
1.2k Beiträge 23 Kommentatoren 461.2k Aufrufe 22 Beobachtet
  • Smilie108S Offline
    Smilie108S Offline
    Smilie108
    #1152
    ok
    er war noch nicht fertig ;) gleich
      Smilie108S Offline
      Smilie108
      #1153
      Script v.2026-01-31
      *** BASE SYSTEM ***
      Operating System: Ubuntu 24.04.4 LTS
       Static hostname: iobroker-kramsach-live
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: kvm
                Kernel: Linux 6.8.0-111-generic
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
         Firmware Date: Tue 2014-04-01
          Firmware Age: 12y 1month 3d
      OS is similar to: debian
      model name      : QEMU Virtual CPU version 2.5+
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       19:43:23 up 15 min,  2 users,  load average: 1.30, 1.34, 0.95
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System codenamed 'noble' is an aging Ubuntu release! Please upgrade to the latest LTS release 'resolute' in due time!
      *** TIME AND TIMEZONES ***
                     Local time: Mon 2026-05-04 19:43:23 CEST
                 Universal time: Mon 2026-05-04 17:43:23 UTC
                       RTC time: Mon 2026-05-04 17:43:23
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      smilie108
      HOME=/home/smilie108
      GROUPS=smilie108 adm cdrom sudo dip plugdev lxd iobroker
      js-controller is not running
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         false
      Unit display-manager.service could not be found.
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Mem:             20G        957M         18G        3.8M        1.6G         19G
      Swap:           8.6G          0B        8.6G
      Total:           29G        957M         27G
      Active iob-Instances:   1
              19779 M total memory
                913 M used memory
                855 M active memory
                829 M inactive memory
              17670 M free memory
                174 M buffer memory
               1389 M swap cache
               8191 M total swap
                  0 M used swap
               8191 M free swap
      top - 19:43:23 up 15 min,  2 users,  load average: 1.30, 1.34, 0.95
      Tasks: 159 total,   2 running, 157 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 26.2 us,  4.8 sy,  0.0 ni, 69.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  19779.1 total,  17690.5 free,    893.8 used,   1564.3 buff/cache
      MiB Swap:   8192.0 total,   8192.0 free,      0.0 used.  18885.3 avail Mem
      *** FAILED SERVICES ***
        UNIT             LOAD   ACTIVE SUB    DESCRIPTION
      * iobroker.service loaded failed failed ioBroker Server
      Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
              ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
              SUB    -> The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                        Type   Size  Used Avail Use% Mounted on
      tmpfs                             tmpfs  2.0G  1.1M  2.0G   1% /run
      /dev/mapper/ubuntu--vg-ubuntu--lv ext4    98G   58G   36G  62% /
      tmpfs                             tmpfs  9.7G     0  9.7G   0% /dev/shm
      tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
      /dev/sda2                         ext4   2.0G  200M  1.6G  11% /boot
      tmpfs                             tmpfs  2.0G   12K  2.0G   1% /run/user/1000
      [Mon May  4 19:28:18 2026] EXT4-fs (dm-0): mounted filesystem 8d603055-1d71-4ec7-84ad-951b1082fd39 ro with ordered data mode. Quota mode: none.
      [Mon May  4 19:28:18 2026] EXT4-fs (dm-0): re-mounted 8d603055-1d71-4ec7-84ad-951b1082fd39 r/w.
      [Mon May  4 19:28:19 2026] EXT4-fs (sda2): mounted filesystem 965f4498-2280-470d-b312-91df09b7b1f5 r/w with ordered data mode. Quota mode: none.
      Show mounted filesystems:
      TARGET  SOURCE                            FSTYPE OPTIONS
      /       /dev/mapper/ubuntu--vg-ubuntu--lv ext4   rw,relatime
      `-/boot /dev/sda2                         ext4   rw,relatime
      /var:
      2.5G    /var/
      1.4G    /var/lib
      970M    /var/lib/mysql
      942M    /var/log
      903M    /var/log/journal/18c66e219588459ea2005bc764231802
      Archived and active journals take up 902.9M in the file system.
      /opt/iobroker/backups:
      91M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      776M    /opt/iobroker/iobroker-data/
      271M    /opt/iobroker/iobroker-data/files
      195M    /opt/iobroker/iobroker-data/history
      134M    /opt/iobroker/iobroker-data/cloudless-homeconnect.0
      128M    /opt/iobroker/iobroker-data/backup-objects
      133M    /opt/iobroker/iobroker-data/cloudless-homeconnect.0/homeconnect-profile-downloader-win32-x64-1.0.1.zip
      40M     /opt/iobroker/iobroker-data/objects.jsonl
      13M     /opt/iobroker/iobroker-data/files/webui/node_modules/monaco-editor/esm/vs/editor/ts.worker.js
      8.2M    /opt/iobroker/iobroker-data/files/modbus.admin/assets/index-Blv_5nFZ.js
      7.8M    /opt/iobroker/iobroker-data/states.jsonl
      USB-Devices by-id:
      USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
      please always prefer the links 'by-id':
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_cefeaafbdc82ee11b712469ec33d7414-if00-port0
      *** ZigBee Settings ***
      ⚠ HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'.
      Please check your setting:
      /dev/ttyUSB0
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.22.2
      /usr/bin/node           v22.22.2
      /usr/bin/npm            10.9.7
      /usr/bin/npx            10.9.7
      ✓ Node.js installation is correct
      nodejs:
        Installed: 22.22.2-1nodesource1
        Candidate: 22.22.2-1nodesource1
        Version table:
       *** 22.22.2-1nodesource1 1001
           22.22.1-1nodesource1 1001
           22.22.0-1nodesource1 1001
           22.21.0-1nodesource1 1001
           22.20.0-1nodesource1 1001
           22.19.0-1nodesource1 1001
           22.18.0-1nodesource1 1001
           22.17.1-1nodesource1 1001
           22.17.0-1nodesource1 1001
           22.16.0-1nodesource1 1001
           22.15.1-1nodesource1 1001
           22.15.0-1nodesource1 1001
           22.14.0-1nodesource1 1001
           22.13.1-1nodesource1 1001
           22.13.0-1nodesource1 1001
           22.12.0-1nodesource1 1001
           22.11.0-1nodesource1 1001
           22.10.0-1nodesource1 1001
           22.9.0-1nodesource1 1001
           22.8.0-1nodesource1 1001
           22.7.0-1nodesource1 1001
           22.6.0-1nodesource1 1001
           22.5.1-1nodesource1 1001
           22.5.0-1nodesource1 1001
           22.4.1-1nodesource1 1001
           22.4.0-1nodesource1 1001
           22.3.0-1nodesource1 1001
           22.2.0-1nodesource1 1001
           22.1.0-1nodesource1 1001
           22.0.0-1nodesource1 1001
           18.19.1+dfsg-6ubuntu5 500
              500 http://at.archive.ubuntu.com/ubuntu noble/universe amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      iobroker is not running on this host.
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker-kramsach-live iobroker-kramsach-live (version: 7.1.1, hostname: iobroker-kramsach-live, alive, uptime: 49)
      Core adapters versions
      js-controller:  7.1.1
      admin:          7.8.23
      javascript:     9.2.1
      nodejs modules from github:     1
      +-- iobroker.euhome@0.1.5 (git+ssh://git@github.com/TA2k/ioBroker.euhome.git#da498b16858260123ddad3633f344e0ef05c99de)
      Adapter State
        system.adapter.accuweather.0            : accuweather           : iobroker-kramsach-live                   - disabled
        system.adapter.admin.0                  : admin                 : iobroker-kramsach-live                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alias-manager.0          : alias-manager         : iobroker-kramsach-live                   - disabled
        system.adapter.apg-info.0               : apg-info              : iobroker-kramsach-live                   -  enabled
        system.adapter.backitup.0               : backitup              : iobroker-kramsach-live                   -  enabled
        system.adapter.bosch-ebike.0            : bosch-ebike           : iobroker-kramsach-live                   -  enabled
        system.adapter.cloudless-homeconnect.0  : cloudless-homeconnect : iobroker-kramsach-live                   - disabled
        system.adapter.discovery.0              : discovery             : iobroker-kramsach-live                   -  enabled
        system.adapter.echarts.0                : echarts               : iobroker-kramsach-live                   -  enabled
        system.adapter.email.0                  : email                 : iobroker-kramsach-live                   - disabled
        system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-kramsach-live                   -  enabled
        system.adapter.euhome.0                 : euhome                : iobroker-kramsach-live                   -  enabled
        system.adapter.feiertage.0              : feiertage             : iobroker-kramsach-live                   -  enabled
        system.adapter.flexcharts.0             : flexcharts            : iobroker-kramsach-live                   - disabled
        system.adapter.flexcharts.1             : flexcharts            : iobroker-kramsach-live                   - disabled
        system.adapter.flot.0                   : flot                  : iobroker-kramsach-live                   - disabled
        system.adapter.hass.0                   : hass                  : iobroker-kramsach-live                   -  enabled, port: 8123
        system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker-kramsach-live                   -  enabled
        system.adapter.history.0                : history               : iobroker-kramsach-live                   -  enabled
        system.adapter.history.1                : history               : iobroker-kramsach-live                   -  enabled
        system.adapter.homeconnect.0            : homeconnect           : iobroker-kramsach-live                   -  enabled
        system.adapter.javascript.0             : javascript            : iobroker-kramsach-live                   -  enabled
        system.adapter.javascript.1             : javascript            : iobroker-kramsach-live                   -  enabled
        system.adapter.kecontact.0              : kecontact             : iobroker-kramsach-live                   -  enabled
        system.adapter.modbus.0                 : modbus                : iobroker-kramsach-live                   -  enabled
        system.adapter.modbus.1                 : modbus                : iobroker-kramsach-live                   - disabled
        system.adapter.modbus.2                 : modbus                : iobroker-kramsach-live                   - disabled
        system.adapter.mqtt.0                   : mqtt                  : iobroker-kramsach-live                   -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.nissan.0                 : nissan                : iobroker-kramsach-live                   - disabled
        system.adapter.openweathermap.0         : openweathermap        : iobroker-kramsach-live                   -  enabled
        system.adapter.pegelalarm.0             : pegelalarm            : iobroker-kramsach-live                   -  enabled
        system.adapter.pi-hole2.0               : pi-hole2              : iobroker-kramsach-live                   -  enabled, port: 80
        system.adapter.proxmox.0                : proxmox               : iobroker-kramsach-live                   -  enabled, port: 8006
        system.adapter.pvforecast.0             : pvforecast            : iobroker-kramsach-live                   -  enabled
        system.adapter.s7.0                     : s7                    : iobroker-kramsach-live                   -  enabled
        system.adapter.samsung_tizen.0          : samsung_tizen         : iobroker-kramsach-live                   - disabled, port: 8002
        system.adapter.scenes.0                 : scenes                : iobroker-kramsach-live                   -  enabled
        system.adapter.scheduler.0              : scheduler             : iobroker-kramsach-live                   -  enabled
        system.adapter.shelly.0                 : shelly                : iobroker-kramsach-live                   -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.signal-cmb.0             : signal-cmb            : iobroker-kramsach-live                   - disabled
        system.adapter.simple-api.0             : simple-api            : iobroker-kramsach-live                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.solax.0                  : solax                 : iobroker-kramsach-live                   -  enabled
        system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker-kramsach-live                   -  enabled
        system.adapter.sql.0                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
        system.adapter.sql.1                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
        system.adapter.sql.2                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
        system.adapter.sql.3                    : sql                   : iobroker-kramsach-live                   -  enabled
        system.adapter.sql.4                    : sql                   : iobroker-kramsach-live                   -  enabled
        system.adapter.sql.5                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
        system.adapter.sql.6                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
        system.adapter.sql.7                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
        system.adapter.sql.8                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
        system.adapter.sql.9                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
        system.adapter.tuya.0                   : tuya                  : iobroker-kramsach-live                   -  enabled
        system.adapter.viessmannapi.0           : viessmannapi          : iobroker-kramsach-live                   -  enabled
        system.adapter.web.0                    : web                   : iobroker-kramsach-live                   - disabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.webui.0                  : webui                 : iobroker-kramsach-live                   - disabled
        system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker-kramsach-live                   -  enabled
        system.adapter.zigbee.0                 : zigbee                : iobroker-kramsach-live                   -  enabled, port: /dev/ttyUSB0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: beta
      Adapter    "accuweather"  : 2.2.0    , installed 2.2.0
      Adapter    "admin"        : 7.8.23   , installed 7.8.23
      Adapter    "alias-manager": 2.1.0    , installed 2.1.0
      Adapter    "apg-info"     : 0.1.32   , installed 0.1.32
      Adapter    "backitup"     : 3.3.17   , installed 3.3.17
      Adapter    "bosch-ebike"  : 0.1.12   , installed 0.1.12
      Adapter    "cloudless-homeconnect": 1.6.4, installed 1.6.4
      Adapter    "echarts"      : 3.1.0    , installed 3.1.0
      Adapter    "email"        : 2.0.4    , installed 2.0.4
      Adapter    "energiefluss-erweitert": 0.8.2, installed 0.8.2
      Adapter    "feiertage"    : 1.3.0    , installed 1.3.0
      Adapter    "flexcharts"   : 0.7.0    , installed 0.7.0
      Adapter    "hass"         : 2.0.3    , installed 2.0.3
      Adapter    "heatingcontrol": 3.1.4   , installed 3.1.4
      Adapter    "history"      : 4.0.0    , installed 4.0.0
      Adapter    "homeconnect"  : 1.5.2    , installed 1.5.2
      Adapter    "javascript"   : 9.2.1    , installed 9.2.1
      Controller "js-controller": 7.1.1    , installed 7.1.1
      Adapter    "kecontact"    : 3.6.0    , installed 3.6.0
      Adapter    "modbus"       : 8.1.3    , installed 8.1.3
      Adapter    "nissan"       : 0.1.18   , installed 0.1.18
      Adapter    "openweathermap": 1.4.0   , installed 1.4.0
      Adapter    "pegelalarm"   : 1.4.0    , installed 1.4.0
      Adapter    "pi-hole2"     : 1.1.1    , installed 1.1.1
      Adapter    "proxmox"      : 2.5.3    , installed 2.5.3
      Adapter    "pvforecast"   : 6.1.0    , installed 6.1.0
      Adapter    "s7"           : 1.5.0    , installed 1.5.0
      Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
      Adapter    "scenes"       : 4.0.4    , installed 4.0.4
      Adapter    "scheduler"    : 1.5.0    , installed 1.5.0
      Adapter    "shelly"       : 10.6.1   , installed 10.6.1
      Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
      Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
      Adapter    "socketio"     : 7.1.3    , installed 7.1.3
      Adapter    "solax"        : 0.9.23   , installed 0.9.23
      Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
      Adapter    "sql"          : 3.0.1    , installed 3.0.1
      Adapter    "tuya"         : 3.17.0   , installed 3.17.0
      Adapter    "viessmannapi" : 2.4.5    , installed 2.4.5
      Adapter    "web"          : 8.1.0    , installed 8.1.0
      Adapter    "webui"        : 1.44.0   , installed 1.44.0
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Adapter    "ws"           : 4.1.0    , installed 4.1.0
      Adapter    "zigbee"       : 3.4.1    , installed 3.4.1
      Objects and States
      Objects:        31895
      States:         26449
      Hit:1 http://at.archive.ubuntu.com/ubuntu noble InRelease
      Hit:2 http://at.archive.ubuntu.com/ubuntu noble-updates InRelease
      Hit:3 http://at.archive.ubuntu.com/ubuntu noble-backports InRelease
      Hit:4 https://apt.grafana.com stable InRelease
      Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
      Hit:6 http://security.ubuntu.com/ubuntu noble-security InRelease
      Reading package lists...
      Pending systemupdates: 4
      *** Listening Ports ***
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      992        5876       652/systemd-resolve
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6881       1/init
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4317       1/init
      tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      992        5878       652/systemd-resolve
      tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      111        9236       973/mariadbd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          6883       1/init
      tcp6       0      0 :::111                  :::*                    LISTEN      0          2875       1/init
      tcp6       0      0 :::80                   :::*                    LISTEN      0          10440      1139/apache2
      tcp6       0      0 :::3000                 :::*                    LISTEN      114        11519      1109/grafana
      udp        0      0 127.0.0.54:53           0.0.0.0:*                           992        5877       652/systemd-resolve
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           992        5875       652/systemd-resolve
      udp        0      0 192.168.2.30:68         0.0.0.0:*                           998        8716       787/systemd-network
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          4318       1/init
      udp6       0      0 :::111                  :::*                                0          3864       1/init
      udp6       0      0 fe80::be24:11ff:fec:546 :::*                                998        9399       787/systemd-network
      2026-05-04 19:30:00.860  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
      2026-05-04 19:30:05.857  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
      2026-05-04 19:30:05.863  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
      2026-05-04 19:30:10.858  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
      2026-05-04 19:30:10.866  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
      2026-05-04 19:30:15.861  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
      2026-05-04 19:30:15.869  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
      2026-05-04 19:30:20.862  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
      2026-05-04 19:30:20.871  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
      2026-05-04 19:30:25.864  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
      2026-05-04 19:30:25.874  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
      2026-05-04 19:30:30.865  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
      2026-05-04 19:30:30.876  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
      2026-05-04 19:30:35.866  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
      2026-05-04 19:30:35.878  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
      2026-05-04 19:30:40.867  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
      2026-05-04 19:30:40.881  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
      2026-05-04 19:30:45.869  - error: sql.3 (2908) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
      2026-05-04 19:30:45.883  - error: sql.3 (2908) States database error: connect ECONNREFUSED 127.0.0.1:9000
      2026-05-04 19:30:50.871  - info: sql.3 (2908) Objects database successfully reconnected
      2026-05-04 19:30:50.886  - info: sql.3 (2908) Objects database successfully reconnected
      2026-05-04 19:30:51.712  - info: sql.3 (2908) terminating
      2026-05-04 19:30:51.712  - info: sql.3 (2908) Terminated (NO_ERROR): Without reason
      2026-05-04 19:30:51.752  - info: sql.3 (2908) terminating
      iob diag has finished.
        Smilie108S Offline
        Smilie108
        #1154
        grad gesehen das ich mal upgraden sollte ubuntu
        • Smilie108S Smilie108
          #1155
          @Smilie108 sagte:
          26.04 ist aber auch gerade erst vor einer Woche veröffentlicht worden. Ein Upgrade würde ich für Herbst anpeilen. Dann sind die Kinderkrankheiten raus.
          • iobroker.service loaded failed failed ioBroker Server
          Starten den ioBroker. Dann sieht man mehr...
            Smilie108S Offline
            Smilie108
            #1156
            was soll mir dann *** LIFE CYCLE STATUS ***
            Operating System codenamed 'noble' is an aging Ubuntu release! Please upgrade to the latest LTS release 'resolute' in due time! das sagen ?
              #1157
              @Smilie108
              Das sagt dir, dass du zu gegebener Zeit ein Upgrade auf die aktuelle LTS-Version vornehmen solltest.
              Ubuntu schaltet das aber ohnehin für die breite Masse erst nach dem ersten Pointrelease frei. Wird irgendwann im August der Fall sein.
              Also ist Herbst 2026 ein guter Zeitpunkt dafür.
                Smilie108S Offline
                Smilie108
                #1158
                ;) ok bin grad am starten vom iob dann mach ich nochmal ein diag
                  Smilie108S Offline
                  Smilie108
                  #1159
                  Script v.2026-01-31
                  *** BASE SYSTEM ***
                           Chassis: vm 🖴
                    Virtualization: kvm
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : 64 bit
                   20:04:22 up 36 min,  2 users,  load average: 2.96, 3.23, 2.14
                  CPU threads: 4
                                 Local time: Mon 2026-05-04 20:04:22 CEST
                             Universal time: Mon 2026-05-04 18:04:22 UTC
                                   RTC time: Mon 2026-05-04 18:04:22
                                NTP service: active
                            RTC in local TZ: no
                  smilie108
                  iobroker
                  HOME=/home/iobroker
                  GROUPS=iobroker tty dialout audio video plugdev
                  Display-Manager:
                  Desktop:
                  Session:                tty
                  *** MEMORY ***
                  Mem:             20G        5.4G         13G        3.8M        1.8G         15G
                  Swap:           8.6G          0B        8.6G
                  Total:           29G        5.4G         22G
                  Active iob-Instances:   44
                           5172 M used memory
                           4996 M active memory
                            941 M inactive memory
                          13272 M free memory
                            178 M buffer memory
                           1525 M swap cache
                           8191 M total swap
                              0 M used swap
                           8191 M free swap
                  top - 20:04:22 up 36 min,  2 users,  load average: 2.96, 3.23, 2.14
                  Tasks: 207 total,   2 running, 205 sleeping,   0 stopped,   0 zombie
                  %Cpu(s): 34.9 us, 11.6 sy,  0.0 ni, 51.2 id,  0.0 wa,  0.0 hi,  2.3 si,  0.0 st
                  MiB Mem :  19779.1 total,  13275.8 free,   5169.0 used,   1703.8 buff/cache
                  MiB Swap:   8192.0 total,   8192.0 free,      0.0 used.  14610.1 avail Mem
                  0 loaded units listed.
                  *** FILESYSTEM ***
                  /var:
                  2.5G    /var/
                  1.4G    /var/lib
                  970M    /var/lib/mysql
                  942M    /var/log
                  787M    /opt/iobroker/iobroker-data/
                  44M     /opt/iobroker/iobroker-data/objects.jsonl
                  15M     /opt/iobroker/iobroker-data/states.jsonl
                  USB-Devices by-id:
                  ⚠ HINT:
                  /dev/ttyUSB0
                  zigbee.X
                  Extended Pan ID:
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  /usr/bin/npm            10.9.7
                  /usr/bin/npx            10.9.7
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  iobroker-kramsach-live iobroker-kramsach-live (version: 7.1.1, hostname: iobroker-kramsach-live, alive, uptime: 363)
                  admin:          7.8.23
                  javascript:     9.2.1
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : iobroker-kramsach-live                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.backitup.0               : backitup              : iobroker-kramsach-live                   -  enabled
                  + system.adapter.bosch-ebike.0            : bosch-ebike           : iobroker-kramsach-live                   -  enabled
                  + system.adapter.discovery.0              : discovery             : iobroker-kramsach-live                   -  enabled
                  + system.adapter.echarts.0                : echarts               : iobroker-kramsach-live                   -  enabled
                  + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-kramsach-live                   -  enabled
                  + system.adapter.euhome.0                 : euhome                : iobroker-kramsach-live                   -  enabled
                  + system.adapter.hass.0                   : hass                  : iobroker-kramsach-live                   -  enabled, port: 8123
                  + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker-kramsach-live                   -  enabled
                  + system.adapter.history.0                : history               : iobroker-kramsach-live                   -  enabled
                  + system.adapter.history.1                : history               : iobroker-kramsach-live                   -  enabled
                  + system.adapter.homeconnect.0            : homeconnect           : iobroker-kramsach-live                   -  enabled
                  + system.adapter.javascript.0             : javascript            : iobroker-kramsach-live                   -  enabled
                  + system.adapter.javascript.1             : javascript            : iobroker-kramsach-live                   -  enabled
                  + system.adapter.kecontact.0              : kecontact             : iobroker-kramsach-live                   -  enabled
                  + system.adapter.modbus.0                 : modbus                : iobroker-kramsach-live                   -  enabled
                  + system.adapter.mqtt.0                   : mqtt                  : iobroker-kramsach-live                   -  enabled, port: 1883, bind: 0.0.0.0
                  + system.adapter.pi-hole2.0               : pi-hole2              : iobroker-kramsach-live                   -  enabled, port: 80
                  + system.adapter.proxmox.0                : proxmox               : iobroker-kramsach-live                   -  enabled, port: 8006
                  + system.adapter.pvforecast.0             : pvforecast            : iobroker-kramsach-live                   -  enabled
                  + system.adapter.s7.0                     : s7                    : iobroker-kramsach-live                   -  enabled
                  + system.adapter.scenes.0                 : scenes                : iobroker-kramsach-live                   -  enabled
                  + system.adapter.scheduler.0              : scheduler             : iobroker-kramsach-live                   -  enabled
                  + system.adapter.shelly.0                 : shelly                : iobroker-kramsach-live                   -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.simple-api.0             : simple-api            : iobroker-kramsach-live                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                  + system.adapter.solax.0                  : solax                 : iobroker-kramsach-live                   -  enabled
                  + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker-kramsach-live                   -  enabled
                  + system.adapter.sql.0                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                  + system.adapter.sql.1                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                  + system.adapter.sql.2                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                  + system.adapter.sql.3                    : sql                   : iobroker-kramsach-live                   -  enabled
                  + system.adapter.sql.4                    : sql                   : iobroker-kramsach-live                   -  enabled
                  + system.adapter.sql.5                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                  + system.adapter.sql.6                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                  + system.adapter.sql.7                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                  + system.adapter.sql.8                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                  + system.adapter.sql.9                    : sql                   : iobroker-kramsach-live                   -  enabled, port: 3306
                  + system.adapter.tuya.0                   : tuya                  : iobroker-kramsach-live                   -  enabled
                  + system.adapter.viessmannapi.0           : viessmannapi          : iobroker-kramsach-live                   -  enabled
                  + system.adapter.web.0                    : web                   : iobroker-kramsach-live                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + system.adapter.webui.0                  : webui                 : iobroker-kramsach-live                   -  enabled
                  + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker-kramsach-live                   -  enabled
                  + system.adapter.zigbee.0                 : zigbee                : iobroker-kramsach-live                   -  enabled, port: /dev/ttyUSB0
                  + instance is alive
                  Objects and States
                  Objects:        32009
                  States:         26991
                  Ign:6 http://security.ubuntu.com/ubuntu noble-security InRelease
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       240773     67908/io.mqtt.0
                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       241563     68467/io.shelly.0
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       225677     64683/iobroker.js-c
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       226354     64683/iobroker.js-c
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       249631     69865/io.web.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       226581     64811/io.admin.0
                  tcp6       0      0 :::8087                 :::*                    LISTEN      1001       248213     69643/io.simple-api
                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       245806     68717/io.tuya.0
                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       245807     68717/io.tuya.0
                  udp        0      0 0.0.0.0:7090            0.0.0.0:*                           1001       236456     67747/io.kecontact.
                  udp        0      0 0.0.0.0:7092            0.0.0.0:*                           1001       236457     67747/io.kecontact.
                  udp        0      0 0.0.0.0:46834           0.0.0.0:*                           1001       235441     67747/io.kecontact.
                  2026-05-04 20:05:58.425  - warn: modbus.0 (67832) Error: undefined
                  2026-05-04 20:05:58.425  - error: modbus.0 (67832) Request timed out.
                  2026-05-04 20:05:58.425  - error: modbus.0 (67832) Client in error state.
                  2026-05-04 20:05:58.425  - warn: modbus.0 (67832) [DevID_1/holdingRegs] Block 1047-1073: {}
                  2026-05-04 20:05:59.426  - info: modbus.0 (67832) Disconnected from slave 192.168.2.43
                  2026-05-04 20:06:07.390  - info: web.0 (69865) ==> Connected system.user.admin from ::ffff:192.168.2.186
                  2026-05-04 20:06:08.026  - error: web.0 (69865) [getState] ERROR: Error: The id is empty! Please provide a valid id.
                  2026-05-04 20:06:08.029  - error: web.0 (69865) [getState] ERROR: Error: The id is empty! Please provide a valid id.
                  2026-05-04 20:06:08.040  - error: web.0 (69865) [getState] ERROR: Error: The id is empty! Please provide a valid id.
                  2026-05-04 20:06:08.062  - info: webui.0 (69983) runCommand: uiConnected, parameter:
                  2026-05-04 20:06:08.100  - error: web.0 (69865) [getState] ERROR: Error: The id is empty! Please provide a valid id.
                  2026-05-04 20:06:08.130  - info: webui.0 (69983) runCommand: uiChangedView, parameter: start
                  2026-05-04 20:06:08.156  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/anchored-region: EISDIR: illegal operation on a directory, read
                  2026-05-04 20:06:08.203  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/breadcrumb: EISDIR: illegal operation on a directory, read
                  2026-05-04 20:06:08.206  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/breadcrumb-item: EISDIR: illegal operation on a directory, read
                  2026-05-04 20:06:08.219  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/data-grid: EISDIR: illegal operation on a directory, read
                  2026-05-04 20:06:08.230  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/listbox: EISDIR: illegal operation on a directory, read
                  2026-05-04 20:06:08.234  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/listbox-option: EISDIR: illegal operation on a directory, read
                  2026-05-04 20:06:08.249  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/select: EISDIR: illegal operation on a directory, read
                  2026-05-04 20:06:08.263  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/toolbar: EISDIR: illegal operation on a directory, read
                  2026-05-04 20:06:08.264  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/tooltip: EISDIR: illegal operation on a directory, read
                  2026-05-04 20:06:08.271  - warn: host.iobroker-kramsach-live-Server Cannot read file webui.0.widgets / node_modules/@fluentui/web-components/dist/esm/styles: EISDIR: illegal operation on a directory, read
                  2026-05-04 20:06:08.452  - info: web.0 (69865) ==> Connected system.user.admin from ::ffff:192.168.2.186
                  2026-05-04 20:06:09.429  - info: modbus.0 (67832) Connected to slave 192.168.2.43
                  2026-05-04 20:06:28.960  - info: solax.0 (68592) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
                    Smilie108S Offline
                    Smilie108
                    #1160
                    das ist jetzt wärend dem laufenden betrieb
                      Script v.2026-01-31
                      *** BASE SYSTEM ***
                               Chassis: vm 🖴
                        Virtualization: kvm
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : 64 bit
                      CPU threads: 4
                                    NTP service: active
                                RTC in local TZ: no
                      smilie108
                      iobroker
                      HOME=/home/iobroker
                      Display-Manager:
                      Desktop:
                      Session:                tty
                      *** MEMORY ***
                      Swap:           8.6G          0B        8.6G
                      Total:           29G        5.4G         22G
                               5172 M used memory
                              13272 M free memory
                                178 M buffer memory
                               1525 M swap cache
                               8191 M total swap
                                  0 M used swap
                               8191 M free swap
                      *** FILESYSTEM ***
                      /var:
                      2.5G    /var/
                      1.4G    /var/lib
                      970M    /var/lib/mysql
                      942M    /var/log
                      USB-Devices by-id:
                      ⚠ HINT:
                      /dev/ttyUSB0
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      /usr/bin/npm            10.9.7
                      /usr/bin/npx            10.9.7
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      admin:          7.8.23
                      javascript:     9.2.1
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        32009
                      States:         26991
                      #1161
                      @Smilie108 sagte:
                      ⚠ HINT:
                      /dev/ttyUSB0
                      Hat mit deinem Problem zwar nichts zu tun, aber trag in zigbee.0 statt /dev/ttyUSB0 besser:
                      ein.
                      ZEHN sql-Instanzen? Was treibst du da?
                      Spiel die ein.
                      Zu
                      fällt mir aber auch nix ein. Nur das ich auf meinem Testsystem mit
                      Adapter "webui" : 1.39.0 , installed 1.39.0
                      gar nichts mit @fluentui installiert habe.
                        Smilie108S Offline
                        Smilie108
                        #1162
                        ;) naja ich habe gerne gewerke getrennt und das einfachste und übersichtlichste ist es auf instanzbasis wenn sich die hw mal wieder ändert und du eine neue heizung hast aber die daten der alten für vergleichswecke zb noch etwas behalten wilst dann mach ich eine neue db und schreib das neu darein kann aber die alte zum vergleichen beutzen und bei bedarf auch einfach mal elleminieren
                          Smilie108S Offline
                          Smilie108
                          #1163
                          @thomas-braun aber danke fürs nachschauen ich hab das mal deinstalliert und werde sehen was nicht mher geht ;)
                          • jogibear9988J Offline
                            jogibear9988
                            #1164
                            du kannst in webui ja auch pakete installieren:
                            Check my ioBroker webui - a vis alternative
                            see: https://github.com/iobroker-community-adapters/ioBroker.webui
                              Smilie108S Offline
                              Smilie108
                              #1165
                              @jogibear9988 ja da hab ich das flue ja schon mal neu instalierne probiert und hatte trotzdem die verzeichniss fehler nur so als hinweis ;)
                                jogibear9988
                                #1166
                                ja, das liegt eben an den npm paketen....
                                da ist nicht alles standardisiert, manche gehen, manche nicht, manche gingen mal....
                                bsp fluent ui, hat ne fehlerhafte webcomponent mainifest json...
