  4. Nach Update auf Admin 5.8 Startet Biobroker nicht mehr
    5.2k
120 Beiträge 7 Kommentatoren 13.3k Aufrufe 5 Beobachtet
  • M michaelxhoffmann
    @homoran ```
    host.raspberrypi
    2023-08-31 14:10:03.959	info	object deleted system.adapter.socketio.0
    host.raspberrypi
    2023-08-31 14:10:00.888	info	iobroker host.raspberrypi Counted 3 states (system.adapter.socketio.0.*) from states
    host.raspberrypi
    2023-08-31 14:10:00.751	info	iobroker host.raspberrypi Counted 2 states (io.socketio.0.*) from states
    host.raspberrypi
    2023-08-31 14:10:00.711	info	iobroker host.raspberrypi Counted 14 states of system.adapter.socketio.0
    host.raspberrypi
    2023-08-31 14:10:00.641	info	iobroker host.raspberrypi Counted 2 states of socketio.0
    host.raspberrypi
    2023-08-31 14:10:00.571	info	iobroker host.raspberrypi Counted 1 channels of socketio.0
    host.raspberrypi
    2023-08-31 14:10:00.442	info	iobroker host.raspberrypi Counted 1 instances of socketio.0
    host.raspberrypi
    2023-08-31 14:10:00.003	info	iobroker Delete instance "socketio.0"
    host.raspberrypi
    2023-08-31 14:09:54.509	info	iobroker del socketio.0
    host.raspberrypi
    2023-08-31 14:09:08.373	info	system.adapter.socketio.0 will be rebuilt
    host.raspberrypi
    2023-08-31 14:09:08.373	info	Adapter system.adapter.socketio.0 needs rebuild and will be restarted afterwards.
    host.raspberrypi
    2023-08-31 14:09:08.373	error	instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2023-08-31 14:09:08.372	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
    host.raspberrypi
    2023-08-31 14:09:08.371	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
    host.raspberrypi
    2023-08-31 14:09:08.370	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
    host.raspberrypi
    2023-08-31 14:09:04.753	info	instance system.adapter.socketio.0 started with pid 1994
    jarvis.0
    2023-08-31 14:09:02.390	info	Connection: WebSocket opened on port 8400 using http...
    crunchipC Abwesend
    crunchipC Abwesend
    #81
    @michaelxhoffmann sagte in Nach Update auf Admin 5.8 Startet Biobroker nicht mehr:
    ist dass das log nach dem reboot?
    edit
    @Homoran hab dein edit gesehen
      edit
      michaelxhoffmann
      #82
      @crunchip Ich habe in der letzten halben stunde diverse male neu gebootet. Sicherheitshalber boote ich jetzt noch mal neu und logge neu
      Homematic CCU2 - Raspberry Pi 4 - IOS (siri) - Amazon Echo 3rd Gen.
        crunchipC Abwesend
        crunchipC Abwesend
        #83
        @michaelxhoffmann warte mal mit dem reboot
        mach noch zuvor ein
        sudo -u iobroker npm cache clean --force
        und dann reboot
        anschliessend log von web und socketio
          mach noch zuvor ein
          und dann reboot
          michaelxhoffmann
          #84
          @crunchip :) zu spät ich mache einfach noch mal ein reboot. das übt
            crunchipC Abwesend
            crunchipC Abwesend
            #85
            @michaelxhoffmann ok
            dann zeig die Logausgabe
              michaelxhoffmann
              #86
              spberrypi
              2023-08-31 14:32:54.203	info	system.adapter.web.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules","module":"iobroker.js-controller","version":"5.0.12"})
              host.raspberrypi
              2023-08-31 14:32:54.202	info	Adapter system.adapter.web.0 needs rebuild of iobroker.js-controller and will be restarted afterwards.
              host.raspberrypi
              2023-08-31 14:32:54.202	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.raspberrypi
              2023-08-31 14:32:54.202	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
              host.raspberrypi
              2023-08-31 14:32:54.201	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
              host.raspberrypi
              2023-08-31 14:32:54.200	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
              host.raspberrypi
              2023-08-31 14:32:51.934	info	instance system.adapter.web.0 started with pid 3561
              jarvis.0
              2023-08-31 14:31:13.899	info	Connection: WebSocket opened on port 8400 using http...
              lovelace.0
              2023-08-31 14:30:38.444	warn	Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
              host.raspberrypi
              2023-08-31 14:30:07.863	warn	adapter "web" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
              host.raspberrypi
              2023-08-31 14:30:07.861	info	system.adapter.web.0 will be rebuilt
              host.raspberrypi
              2023-08-31 14:30:07.861	info	Adapter system.adapter.web.0 needs rebuild and will be restarted afterwards.
              host.raspberrypi
              2023-08-31 14:30:07.861	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.raspberrypi
              2023-08-31 14:30:07.860	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
              host.raspberrypi
              2023-08-31 14:30:07.859	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
              host.raspberrypi
              2023-08-31 14:30:07.859	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
              jarvis.0
              host.raspberrypi
              2023-08-31 14:30:28.465	info	system.adapter.socketio.0 will be rebuilt
              host.raspberrypi
              2023-08-31 14:30:28.464	error	instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.raspberrypi
              2023-08-31 14:30:28.463	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
              host.raspberrypi
              2023-08-31 14:30:28.464	info	Adapter system.adapter.socketio.0 needs rebuild and will be restarted afterwards.
              host.raspberrypi
              2023-08-31 14:30:28.462	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
              host.raspberrypi
              2023-08-31 14:30:28.461	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
              host.raspberrypi
              2023-08-31 14:32:53.816	warn	adapter "socketio" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
              host.raspberrypi
              2023-08-31 14:32:53.815	info	system.adapter.socketio.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules","module":"iobroker.js-controller","version":"5.0.12"})
              host.raspberrypi
              2023-08-31 14:32:53.815	info	Adapter system.adapter.socketio.0 needs rebuild of iobroker.js-controller and will be restarted afterwards.
              host.raspberrypi
              2023-08-31 14:32:53.815	error	instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.raspberrypi
              2023-08-31 14:32:53.814	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
              host.raspberrypi
              2023-08-31 14:32:53.813	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
              host.raspberrypi
              2023-08-31 14:32:53.813	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
              host.raspberrypi
              2023-08-31 14:32:51.985	info	instance system.adapter.socketio.0 started with pid 3567
              jarvis.0
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              2023-08-31 14:30:24.252	info	instance system.adapter.socketio.0 started with pid 1643
                spberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                jarvis.0
                lovelace.0
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                jarvis.0
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                jarvis.0
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                #87
                @michaelxhoffmann wieso springt die Zeit im 2. log? (zeile 16 -> 14)
                Ansonsten scheinen beide Adapter gerade neu gebaut zu werden.
                Also etwas warten
                  Also etwas warten
                  crunchipC Abwesend
                  crunchipC Abwesend
                  #88
                  @homoran glaub da springt nix, das hat er zusammenkopiert, daher auch ne leerzeile(31)
                    #89
                    @crunchip oder der ntp schlägt nach dem reboot verzögert zu
                      michaelxhoffmann
                      #90
                      Nun denn das Ergebnis bleibt das gleiche. Weder Socketio noch web.0 laufen.
                      Ich will noch nicht mal ausschließen dass in der ganzen Rettungsaktion was schief gegangen ist durch falsche Eingaben meinerseits. Die Frage ist jetzt lässt sich das irgendwie retten oder muss ich doch alles neu installieren?
                      crunchipC HomoranH 2 Antworten Letzte Antwort
                        crunchipC Abwesend
                        crunchipC Abwesend
                        #91
                        @michaelxhoffmann
                        dann wie vorhin geschrieben
                        und nochmal manuell
                        cd /opt/iobroker/node_modules/iobroker.socketio
                        npm install --omit=dev
                        cd /opt/iobroker/node_modules/iobroker.web
                          #92
                          klar, weil die neu gebaut werden/wurden
                          @homoran sagte in Nach Update auf Admin 5.8 Startet Biobroker nicht mehr:
                          ansonsten scheinen beide Adapter gerade neu gebaut zu werden.
                          Also etwas warten
                          das ist jetzt allerfi gs schon länger her.
                          hast du nach ausreichendem Warten nochmal versucht die Instanzen zu starten?
                            Also etwas warten
                            michaelxhoffmann
                            schrieb am zuletzt editiert von michaelxhoffmann
                            #93
                            Ja, ich habe ja den Broker neu gestartet...
                            Aber OK Jetzt noch mal so gemacht wie im Vorposten geschrieben.
                            pi@raspberrypi:/ $ sudo -u iobroker npm cache clean --force
                            npm WARN using --force Recommended protections disabled.
                            pi@raspberrypi:/ $ cd /opt/iobroker/node_modules/iobroker.socketio
                            pi@raspberrypi:/opt/iobroker/node_modules/iobroker.socketio $ npm install --omit=dev
                            up to date, audited 64 packages in 4s
                            3 packages are looking for funding
                              run `npm fund` for details
                            1 moderate severity vulnerability
                            To address all issues (including breaking changes), run:
                              npm audit fix --force
                            Run `npm audit` for details.
                            pi@raspberrypi:/opt/iobroker/node_modules/iobroker.socketio $ cd /opt/iobroker/node_modules/iobroker.web
                            pi@raspberrypi:/opt/iobroker/node_modules/iobroker.web $ npm install --omit=dev
                            up to date, audited 139 packages in 5s
                            10 packages are looking for funding
                            3 moderate severity vulnerabilities
                              #94
                              wann?
                              nach dem letzten log, als der rebuild noch lief?
                                wann?
                                michaelxhoffmann
                                #95
                                @homoran Ähm Gute Frage. Woran erkenne ich denn dass der Rebuild noch läuft?
                                HomoranH crunchipC 2 Antworten Letzte Antwort
                                  adapter "socketio" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                                  hast du wirklich den Adapter gelöscht, oder nur die Instanz?
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  #96
                                  weil es mir gerade einfällt bei dieser Frage
                                  ich bekommt den socketio auch nicht mehr los, hatte den Adapter schon per admin als auch über die Konsole gelöscht,
                                  als es letztens ein Update gab wurde er wieder bei mir angezeigt.
                                  erneut gelöscht, was aber auffällt, er bleibt als Adapter ohne Instanz bestehen
                                    #97
                                    Gegenfrage: wie lange nach
                                    Also etwas warten
                                    hast du gewartet?
                                      Also etwas warten
                                      hast du gewartet?
                                      michaelxhoffmann
                                      #98
                                      @homoran schätzungsweise 30 Minuten
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        #99
                                        Trying to rebuild it... 2 attempt host.raspberrypi
                                        wenn er es ein drittes mal versucht hat
                                          #100
                                          @michaelxhoffmann das muss reichen.
                                          jetzt 3ntweder weitermachen wie @crunchip mit npm cache clean geschrieben hatte oder mal die neue Spur von @crunchip verfolgen.
                                          Ich würde da mal mit iob del socketio --debug versuchen, hab aber keine Ahnung ob das was bringt
