  4. Nach Update auf Admin 5.8 Startet Biobroker nicht mehr
    5.2k
120 Beiträge 7 Kommentatoren 13.3k Aufrufe 5 Beobachtet
  • M michaelxhoffmann
    spberrypi
    2023-08-31 14:32:54.203	info	system.adapter.web.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules","module":"iobroker.js-controller","version":"5.0.12"})
    host.raspberrypi
    2023-08-31 14:32:54.202	info	Adapter system.adapter.web.0 needs rebuild of iobroker.js-controller and will be restarted afterwards.
    host.raspberrypi
    2023-08-31 14:32:54.202	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2023-08-31 14:32:54.202	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
    host.raspberrypi
    2023-08-31 14:32:54.201	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
    host.raspberrypi
    2023-08-31 14:32:54.200	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
    host.raspberrypi
    2023-08-31 14:32:51.934	info	instance system.adapter.web.0 started with pid 3561
    jarvis.0
    2023-08-31 14:31:13.899	info	Connection: WebSocket opened on port 8400 using http...
    lovelace.0
    2023-08-31 14:30:38.444	warn	Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
    host.raspberrypi
    2023-08-31 14:30:07.863	warn	adapter "web" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
    host.raspberrypi
    2023-08-31 14:30:07.861	info	system.adapter.web.0 will be rebuilt
    host.raspberrypi
    2023-08-31 14:30:07.861	info	Adapter system.adapter.web.0 needs rebuild and will be restarted afterwards.
    host.raspberrypi
    2023-08-31 14:30:07.861	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2023-08-31 14:30:07.860	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
    host.raspberrypi
    2023-08-31 14:30:07.859	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
    host.raspberrypi
    2023-08-31 14:30:07.859	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
    jarvis.0
    host.raspberrypi
    2023-08-31 14:30:28.465	info	system.adapter.socketio.0 will be rebuilt
    host.raspberrypi
    2023-08-31 14:30:28.464	error	instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2023-08-31 14:30:28.463	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
    host.raspberrypi
    2023-08-31 14:30:28.464	info	Adapter system.adapter.socketio.0 needs rebuild and will be restarted afterwards.
    host.raspberrypi
    2023-08-31 14:30:28.462	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
    host.raspberrypi
    2023-08-31 14:30:28.461	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
    host.raspberrypi
    2023-08-31 14:32:53.816	warn	adapter "socketio" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
    host.raspberrypi
    2023-08-31 14:32:53.815	info	system.adapter.socketio.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules","module":"iobroker.js-controller","version":"5.0.12"})
    host.raspberrypi
    2023-08-31 14:32:53.815	info	Adapter system.adapter.socketio.0 needs rebuild of iobroker.js-controller and will be restarted afterwards.
    host.raspberrypi
    2023-08-31 14:32:53.815	error	instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2023-08-31 14:32:53.814	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
    host.raspberrypi
    2023-08-31 14:32:53.813	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
    host.raspberrypi
    2023-08-31 14:32:53.813	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
    host.raspberrypi
    2023-08-31 14:32:51.985	info	instance system.adapter.socketio.0 started with pid 3567
    jarvis.0
    host.raspberrypi
    host.raspberrypi
    host.raspberrypi
    host.raspberrypi
    host.raspberrypi
    host.raspberrypi
    host.raspberrypi
    2023-08-31 14:30:24.252	info	instance system.adapter.socketio.0 started with pid 1643
    #87
    @michaelxhoffmann wieso springt die Zeit im 2. log? (zeile 16 -> 14)
    Ansonsten scheinen beide Adapter gerade neu gebaut zu werden.
    Also etwas warten
      Also etwas warten
      crunchipC Abwesend
      crunchipC Abwesend
      #88
      @homoran glaub da springt nix, das hat er zusammenkopiert, daher auch ne leerzeile(31)
        #89
        @crunchip oder der ntp schlägt nach dem reboot verzögert zu
          michaelxhoffmann
          #90
          Nun denn das Ergebnis bleibt das gleiche. Weder Socketio noch web.0 laufen.
          Ich will noch nicht mal ausschließen dass in der ganzen Rettungsaktion was schief gegangen ist durch falsche Eingaben meinerseits. Die Frage ist jetzt lässt sich das irgendwie retten oder muss ich doch alles neu installieren?
          Homematic CCU2 - Raspberry Pi 4 - IOS (siri) - Amazon Echo 3rd Gen.
          crunchipC HomoranH 2 Antworten Letzte Antwort
            crunchipC Abwesend
            crunchipC Abwesend
            #91
            @michaelxhoffmann
            dann wie vorhin geschrieben
            sudo -u iobroker npm cache clean --force
            und nochmal manuell
            cd /opt/iobroker/node_modules/iobroker.socketio
            npm install --omit=dev
            cd /opt/iobroker/node_modules/iobroker.web
              #92
              @michaelxhoffmann sagte in Nach Update auf Admin 5.8 Startet Biobroker nicht mehr:
              klar, weil die neu gebaut werden/wurden
              @homoran sagte in Nach Update auf Admin 5.8 Startet Biobroker nicht mehr:
              ansonsten scheinen beide Adapter gerade neu gebaut zu werden.
              Also etwas warten
              das ist jetzt allerfi gs schon länger her.
              hast du nach ausreichendem Warten nochmal versucht die Instanzen zu starten?
                Also etwas warten
                michaelxhoffmann
                schrieb am zuletzt editiert von michaelxhoffmann
                #93
                Ja, ich habe ja den Broker neu gestartet...
                Aber OK Jetzt noch mal so gemacht wie im Vorposten geschrieben.
                pi@raspberrypi:/ $ sudo -u iobroker npm cache clean --force
                npm WARN using --force Recommended protections disabled.
                pi@raspberrypi:/ $ cd /opt/iobroker/node_modules/iobroker.socketio
                pi@raspberrypi:/opt/iobroker/node_modules/iobroker.socketio $ npm install --omit=dev
                up to date, audited 64 packages in 4s
                3 packages are looking for funding
                  run `npm fund` for details
                1 moderate severity vulnerability
                To address all issues (including breaking changes), run:
                  npm audit fix --force
                Run `npm audit` for details.
                pi@raspberrypi:/opt/iobroker/node_modules/iobroker.socketio $ cd /opt/iobroker/node_modules/iobroker.web
                pi@raspberrypi:/opt/iobroker/node_modules/iobroker.web $ npm install --omit=dev
                up to date, audited 139 packages in 5s
                10 packages are looking for funding
                3 moderate severity vulnerabilities
                  #94
                  wann?
                  nach dem letzten log, als der rebuild noch lief?
                    wann?
                    michaelxhoffmann
                    #95
                    @homoran Ähm Gute Frage. Woran erkenne ich denn dass der Rebuild noch läuft?
                    HomoranH crunchipC 2 Antworten Letzte Antwort
                      adapter "socketio" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                      hast du wirklich den Adapter gelöscht, oder nur die Instanz?
                      crunchipC Abwesend
                      crunchipC Abwesend
                      #96
                      weil es mir gerade einfällt bei dieser Frage
                      ich bekommt den socketio auch nicht mehr los, hatte den Adapter schon per admin als auch über die Konsole gelöscht,
                      als es letztens ein Update gab wurde er wieder bei mir angezeigt.
                      erneut gelöscht, was aber auffällt, er bleibt als Adapter ohne Instanz bestehen
                        #97
                        Gegenfrage: wie lange nach
                        Also etwas warten
                        hast du gewartet?
                          Also etwas warten
                          hast du gewartet?
                          michaelxhoffmann
                          #98
                          @homoran schätzungsweise 30 Minuten
                            crunchipC Abwesend
                            crunchipC Abwesend
                            #99
                            Trying to rebuild it... 2 attempt host.raspberrypi
                            wenn er es ein drittes mal versucht hat
                              #100
                              @michaelxhoffmann das muss reichen.
                              jetzt 3ntweder weitermachen wie @crunchip mit npm cache clean geschrieben hatte oder mal die neue Spur von @crunchip verfolgen.
                              Ich würde da mal mit iob del socketio --debug versuchen, hab aber keine Ahnung ob das was bringt
                                michaelxhoffmann
                                #101
                                Hmm Ich bin mittlerweile der Ansicht ich versuche ein totes Pferd zu reiten. Ich denke ich installiere alles noch mal auf ein neues. Das bringt irgendwie nichts. Die einzige Frage die ich mir diesbezüglich stelle ist ob ich dann meine Zigbeesachen neu anlernen muss...
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  #102
                                  @michaelxhoffmann naja, tot ist es noch nicht
                                  dann nochmal die Ausgabe in Langfassung
                                  iob diag
                                  in der Regel nicht, wenn man backup hat
                                    iob diag
                                    michaelxhoffmann
                                    #103
                                    @crunchip
                                    Habe mal den
                                    versucht. Im Iobroker Adapterreiter ist der socket.io aber immer noch aufgeführt
                                    Skript v.2023-04-16
                                    *** BASE SYSTEM ***
                                    Model		: Raspberry Pi 4 Model B Rev 1.2
                                    Architecture    : aarch64
                                    Docker          : false
                                    Virtualization  : none
                                    Distributor ID:	Debian
                                    Description:	Debian GNU/Linux 11 (bullseye)
                                    Release:	11
                                    Codename:	bullseye
                                    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                                    NAME="Debian GNU/Linux"
                                    VERSION_ID="11"
                                    VERSION="11 (bullseye)"
                                    VERSION_CODENAME=bullseye
                                    ID=debian
                                    HOME_URL="https://www.debian.org/"
                                    SUPPORT_URL="https://www.debian.org/support"
                                    BUG_REPORT_URL="https://bugs.debian.org/"
                                    Systemuptime and Load:
                                     15:59:02 up  1:13,  1 user,  load average: 0.83, 0.48, 0.32
                                    CPU threads: 4
                                    Raspberry only:
                                    throttled=0x50000
                                    Other values than 0x0 hint to temperature/voltage problems
                                    temp=58.4'C
                                    volt=0.8563V
                                    *** Time and Time Zones ***
                                                   Local time: Thu 2023-08-31 15:59:02 CEST
                                               Universal time: Thu 2023-08-31 13:59:02 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    *** User and Groups ***
                                    pi
                                    /home/pi
                                    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                    *** X-Server-Setup ***
                                    X-Server: 	false
                                    Desktop:
                                    Terminal: 	tty
                                    Boot Target: 	multi-user.target
                                    *** MEMORY ***
                                    Mem:            3.8G        2.2G        1.0G        1.0M        518M        1.5G
                                    Swap:            99M          0B         99M
                                    Total:          3.9G        2.2G        1.1G
                                             3794 M total memory
                                             2243 M used memory
                                             2314 M active memory
                                              309 M inactive memory
                                             1031 M free memory
                                               73 M buffer memory
                                              445 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    /dev/root      ext4       29G  5.4G   22G  20% /
                                    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                    tmpfs          tmpfs     759M  1.1M  758M   1% /run
                                    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                                    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                                    [Thu Aug 31 14:45:29 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5A:BB:67 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c7332932-02 rootfstype=ext4 fsck.repair=yes rootwait
                                    [Thu Aug 31 14:45:30 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                                    [Thu Aug 31 14:45:30 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                                    [Thu Aug 31 14:45:31 2023] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
                                    [Thu Aug 31 14:45:31 2023] EXT4-fs (mmcblk0p2): 1 orphan inode deleted
                                    [Thu Aug 31 14:45:31 2023] EXT4-fs (mmcblk0p2): recovery complete
                                    [Thu Aug 31 14:45:31 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                    [Thu Aug 31 14:45:31 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                    [Thu Aug 31 14:45:33 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                    TARGET  SOURCE         FSTYPE OPTIONS
                                    /       /dev/mmcblk0p2 ext4   rw,noatime
                                    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                    /var:
                                    1.5G	/var/
                                    1.0G	/var/log
                                    977M	/var/log/journal/d25d733f60db4f059662faf3a610222b
                                    178M	/var/cache
                                    Archived and active journals take up 976.2M in the file system.
                                    /opt/iobroker/backups:
                                    209M	/opt/iobroker/backups/
                                    /opt/iobroker/iobroker-data:
                                    534M	/opt/iobroker/iobroker-data/
                                    399M	/opt/iobroker/iobroker-data/files
                                    100M	/opt/iobroker/iobroker-data/backup-objects
                                    88M	/opt/iobroker/iobroker-data/files/echarts.admin
                                    57M	/opt/iobroker/iobroker-data/files/echarts
                                    41M	/opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
                                    23M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
                                    23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
                                    23M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
                                    20M	/opt/iobroker/iobroker-data/objects.jsonl
                                    *** NodeJS-Installation ***
                                    /usr/bin/nodejs 	v18.17.1
                                    /usr/bin/node 		v18.17.1
                                    /usr/bin/npm 		9.6.7
                                    /usr/bin/npx 		9.6.7
                                    nodejs:
                                      Installed: 18.17.1-deb-1nodesource1
                                      Candidate: 18.17.1-deb-1nodesource1
                                      Version table:
                                     *** 18.17.1-deb-1nodesource1 500
                                            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                                         12.22.12~dfsg-1~deb11u4 500
                                            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                         12.22.12~dfsg-1~deb11u3 500
                                            500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                    No problems detected
                                    *** ioBroker-Installation ***
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Core adapters versions
                                    js-controller: 	5.0.12
                                    admin: 		6.8.0
                                    javascript: 	7.0.3
                                    Adapters from github: 	2
                                    Adapter State
                                      system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                                    + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
                                      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                                    + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
                                    + system.adapter.heatingcontrol.0         : heatingcontrol        : raspberrypi                              -  enabled
                                    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                                    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 18701
                                    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
                                    + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 12010
                                      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                                      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
                                    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                                    + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
                                    + system.adapter.logparser.0              : logparser             : raspberrypi                              -  enabled
                                    + system.adapter.lovelace.0               : lovelace              : raspberrypi                              -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
                                      system.adapter.material.0               : material              : raspberrypi                              - disabled
                                    + system.adapter.milight-smart-light.0    : milight-smart-light   : raspberrypi                              -  enabled
                                      system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
                                    + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
                                    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                                    + system.adapter.samsung.0                : samsung               : raspberrypi                              -  enabled
                                    + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                                    + system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled, port: 3307
                                    + system.adapter.sql.1                    : sql                   : raspberrypi                              -  enabled, port: 3306
                                    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                                    + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                                    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                                      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                                      system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                                      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
                                    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                                      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
                                      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
                                      system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
                                      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                                      system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                    + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                                    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB0
                                    + instance is alive
                                    ioBroker-Repositories
                                    Stable (default): http://download.iobroker.net/sources-dist.json
                                    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                                    latest 1      : http://iobroker.live/repo/sources-dist-latest.json
                                    default 1     : http://iobroker.live/repo/sources-dist.json
                                    Installed ioBroker-Instances
                                    Adapter    "admin"        : 6.8.0    , installed 6.8.0
                                    Adapter    "alarm"        : 3.3.12   , installed 3.3.12
                                    Adapter    "alexa2"       : 3.24.1   , installed 3.24.1
                                    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
                                    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                                    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                                    Adapter    "echarts"      : 1.5.1    , installed 1.5.1
                                    Adapter    "fritzbox"     : 0.2.1    , installed 0.5.0
                                    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                                    Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
                                    Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
                                    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                                    Adapter    "ical"         : 1.13.3   , installed 1.13.3
                                    Adapter    "iot"          : 1.14.5   , installed 1.14.5
                                    Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
                                    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
                                    Controller "js-controller": 4.0.24   , installed 5.0.12
                                    Adapter    "logparser"    : 2.2.0    , installed 2.2.0
                                    Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
                                    Adapter    "material"     : 1.3.1    , installed 1.3.1
                                    Adapter    "milight"      : 0.3.6    , installed 0.3.6
                                    Adapter    "milight-smart-light": 1.2.2, installed 1.2.2
                                    Adapter    "openweathermap": 0.3.9   , installed 0.3.9
                                    Adapter    "parcel"       : 0.0.27   , installed 0.0.27
                                    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
                                    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
                                    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                                    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                                    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                                    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
                                    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                                    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                                    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                                    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                                    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
                                    Objects and States
                                    Objects: 	12424
                                    States: 	10577
                                    Hit:1 http://deb.debian.org/debian bullseye InRelease
                                    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                                    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                                    Get:5 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
                                    Fetched 4586 B in 3s (1521 B/s)
                                    Reading package lists...
                                    Pending Updates: 1
                                    *** Listening Ports ***
                                    tcp        0      0 192.168.178.45:12001    0.0.0.0:*               LISTEN      1001       16544      1146/io.hm-rpc.1
                                    tcp        0      0 192.168.178.45:12010    0.0.0.0:*               LISTEN      1001       1915       1164/io.hm-rpc.2
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1547       501/iobroker.js-con
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14212      501/iobroker.js-con
                                    tcp        0      0 192.168.178.45:18701    0.0.0.0:*               LISTEN      1001       16516      1094/io.hm-rpc.0
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3819       534/sshd: /usr/sbin
                                    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       18600      2006/io.jarvis.0
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15505      858/io.admin.0
                                    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       17267      1428/io.terminal.0
                                    tcp6       0      0 :::8091                 :::*                    LISTEN      1001       16757      1333/io.lovelace.0
                                    tcp6       0      0 :::41663                :::*                    LISTEN      1001       18275      1899/io.yahka.0
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          3821       534/sshd: /usr/sbin
                                    udp        0      0 0.0.0.0:54500           0.0.0.0:*                           1001       15268      1449/io.broadlink2.
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14442      399/avahi-daemon: r
                                    udp        0      0 0.0.0.0:36232           0.0.0.0:*                           1001       19064      2597/io.milight-sma
                                    udp        0      0 0.0.0.0:41020           0.0.0.0:*                           108        14444      399/avahi-daemon: r
                                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14509      732/dhcpcd
                                    udp        0      0 0.0.0.0:51308           0.0.0.0:*                           1001       17269      1449/io.broadlink2.
                                    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       15213      1449/io.broadlink2.
                                    udp6       0      0 :::5353                 :::*                                108        14443      399/avahi-daemon: r
                                    udp6       0      0 :::42459                :::*                                108        14445      399/avahi-daemon: r
                                    udp6       0      0 :::546                  :::*                                0          14525      732/dhcpcd
                                    2023-08-31 15:52:31.155  - error: host.raspberrypi Caught by controller[0]: }
                                    2023-08-31 15:52:31.155  - error: host.raspberrypi Caught by controller[0]: Node.js v18.17.1
                                    2023-08-31 15:52:31.155  - error: host.raspberrypi instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    2023-08-31 15:52:31.155  - info: host.raspberrypi Rebuild for adapter system.adapter.socketio.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                    2023-08-31 15:56:33.303  - warn: javascript.0 (892) State "fullybrowser.0.192_168_178_93.Commands.screenOn" not found
                                    2023-08-31 15:56:33.305  - warn: javascript.0 (892)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
                                    2023-08-31 15:56:33.305  - warn: javascript.0 (892)     at script.js.Diele.Bewegung_Diele:5:7
                                    2023-08-31 15:56:33.305  - warn: javascript.0 (892)     at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1924:65)
                                    2023-08-31 15:56:33.306  - warn: javascript.0 (892)     at processImmediate (node:internal/timers:478:21)
                                    2023-08-31 15:57:01.361  - info: host.raspberrypi iobroker del socketio.0
                                    2023-08-31 15:57:04.096  - info: host.raspberrypi iobroker Delete instance "socketio.0"
                                    2023-08-31 15:57:04.345  - info: host.raspberrypi iobroker host.raspberrypi Counted 1 instances of socketio.0
                                    2023-08-31 15:57:04.457  - info: host.raspberrypi iobroker host.raspberrypi Counted 1 channels of socketio.0
                                    2023-08-31 15:57:04.517  - info: host.raspberrypi iobroker host.raspberrypi Counted 2 states of socketio.0
                                    2023-08-31 15:57:04.576  - info: host.raspberrypi iobroker host.raspberrypi Counted 14 states of system.adapter.socketio.0
                                    2023-08-31 15:57:04.610  - info: host.raspberrypi iobroker host.raspberrypi Counted 2 states (io.socketio.0.*) from states
                                    2023-08-31 15:57:04.734  - info: host.raspberrypi iobroker host.raspberrypi Counted 3 states (system.adapter.socketio.0.*) from states
                                    2023-08-31 15:57:07.180  - info: host.raspberrypi iobroker host.raspberrypi Deleting 18 object(s).
                                    2023-08-31 15:57:07.465  - info: host.raspberrypi object deleted system.adapter.socketio.0
                                    2023-08-31 15:57:07.473  - info: host.raspberrypi iobroker host.raspberrypi Deleting 5 state(s).
                                    2023-08-31 15:57:08.749  - info: host.raspberrypi iobroker exit 0
                                    2023-08-31 16:00:01.760  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 17131
                                    2023-08-31 16:00:05.950  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 17153
                                    2023-08-31 16:00:19.121  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                                    2023-08-31 16:00:31.974  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    HomoranH crunchipC 4 Antworten Letzte Antwort
                                      @crunchip
                                      Habe mal den
                                      Skript v.2023-04-16
                                      *** BASE SYSTEM ***
                                      Docker          : false
                                      Release:	11
                                      Codename:	bullseye
                                      VERSION_ID="11"
                                      ID=debian
                                      CPU threads: 4
                                      Raspberry only:
                                      throttled=0x50000
                                      temp=58.4'C
                                      volt=0.8563V
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      pi
                                      /home/pi
                                      X-Server: 	false
                                      Desktop:
                                      Terminal: 	tty
                                      *** MEMORY ***
                                      Swap:            99M          0B         99M
                                               3794 M total memory
                                               2243 M used memory
                                               1031 M free memory
                                                 73 M buffer memory
                                                445 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      *** FILESYSTEM ***
                                      /var:
                                      1.5G	/var/
                                      1.0G	/var/log
                                      178M	/var/cache
                                      /usr/bin/npm 		9.6.7
                                      /usr/bin/npx 		9.6.7
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin: 		6.8.0
                                      javascript: 	7.0.3
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects: 	12424
                                      States: 	10577
                                      Pending Updates: 1
                                      #104
                                      Habe mal den
                                      versucht.
                                      und was kam dabei an debug Ausgaben?
                                        @crunchip
                                        Habe mal den
                                        Skript v.2023-04-16
                                        *** BASE SYSTEM ***
                                        Docker          : false
                                        Release:	11
                                        Codename:	bullseye
                                        VERSION_ID="11"
                                        ID=debian
                                        CPU threads: 4
                                        Raspberry only:
                                        throttled=0x50000
                                        temp=58.4'C
                                        volt=0.8563V
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        pi
                                        /home/pi
                                        X-Server: 	false
                                        Desktop:
                                        Terminal: 	tty
                                        *** MEMORY ***
                                        Swap:            99M          0B         99M
                                                 3794 M total memory
                                                 2243 M used memory
                                                 1031 M free memory
                                                   73 M buffer memory
                                                  445 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        Raspberry only:
                                        oom events: 0
                                        *** FILESYSTEM ***
                                        /var:
                                        1.5G	/var/
                                        1.0G	/var/log
                                        178M	/var/cache
                                        /usr/bin/npm 		9.6.7
                                        /usr/bin/npx 		9.6.7
                                        nodejs:
                                          Version table:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin: 		6.8.0
                                        javascript: 	7.0.3
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects: 	12424
                                        States: 	10577
                                        Pending Updates: 1
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        #105
                                        versucht
                                        gab es auch eine Ausgabe?😜
                                        volt=0.8563V
                                        ist das nicht etwas niedrig?
                                        und dein Filesystem hat nen Treffer
                                          @crunchip
                                          Habe mal den
                                          Skript v.2023-04-16
                                          *** BASE SYSTEM ***
                                          Docker          : false
                                          Release:	11
                                          Codename:	bullseye
                                          VERSION_ID="11"
                                          ID=debian
                                          CPU threads: 4
                                          Raspberry only:
                                          throttled=0x50000
                                          temp=58.4'C
                                          volt=0.8563V
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          pi
                                          /home/pi
                                          X-Server: 	false
                                          Desktop:
                                          Terminal: 	tty
                                          *** MEMORY ***
                                          Swap:            99M          0B         99M
                                                   3794 M total memory
                                                   2243 M used memory
                                                   1031 M free memory
                                                     73 M buffer memory
                                                    445 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          Raspberry only:
                                          oom events: 0
                                          *** FILESYSTEM ***
                                          /var:
                                          1.5G	/var/
                                          1.0G	/var/log
                                          178M	/var/cache
                                          /usr/bin/npm 		9.6.7
                                          /usr/bin/npx 		9.6.7
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          admin: 		6.8.0
                                          javascript: 	7.0.3
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects: 	12424
                                          States: 	10577
                                          Pending Updates: 1
                                          #106
