  4. Nach Update auf Admin 5.8 Startet Biobroker nicht mehr
    5.2k
120 Beiträge 7 Kommentatoren 13.3k Aufrufe 5 Beobachtet
    @michaelxhoffmann sagte in Nach Update auf Admin 5.8 Startet Biobroker nicht mehr:
    @crunchip nope :( Adapter bleibt rot
    und was steht im log?????
    michaelxhoffmann
    schrieb am zuletzt editiert von michaelxhoffmann
    #77
    @homoran ```
    host.raspberrypi
    2023-08-31 14:10:03.959	info	object deleted system.adapter.socketio.0
    host.raspberrypi
    2023-08-31 14:10:00.888	info	iobroker host.raspberrypi Counted 3 states (system.adapter.socketio.0.*) from states
    host.raspberrypi
    2023-08-31 14:10:00.751	info	iobroker host.raspberrypi Counted 2 states (io.socketio.0.*) from states
    host.raspberrypi
    2023-08-31 14:10:00.711	info	iobroker host.raspberrypi Counted 14 states of system.adapter.socketio.0
    host.raspberrypi
    2023-08-31 14:10:00.641	info	iobroker host.raspberrypi Counted 2 states of socketio.0
    host.raspberrypi
    2023-08-31 14:10:00.571	info	iobroker host.raspberrypi Counted 1 channels of socketio.0
    host.raspberrypi
    2023-08-31 14:10:00.442	info	iobroker host.raspberrypi Counted 1 instances of socketio.0
    host.raspberrypi
    2023-08-31 14:10:00.003	info	iobroker Delete instance "socketio.0"
    host.raspberrypi
    2023-08-31 14:09:54.509	info	iobroker del socketio.0
    host.raspberrypi
    2023-08-31 14:09:08.373	info	system.adapter.socketio.0 will be rebuilt
    host.raspberrypi
    2023-08-31 14:09:08.373	info	Adapter system.adapter.socketio.0 needs rebuild and will be restarted afterwards.
    host.raspberrypi
    2023-08-31 14:09:08.373	error	instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2023-08-31 14:09:08.372	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
    host.raspberrypi
    2023-08-31 14:09:08.371	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
    host.raspberrypi
    2023-08-31 14:09:08.370	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
    host.raspberrypi
    2023-08-31 14:09:04.753	info	instance system.adapter.socketio.0 started with pid 1994
    jarvis.0
    2023-08-31 14:09:02.390	info	Connection: WebSocket opened on port 8400 using http...
    Homematic CCU2 - Raspberry Pi 4 - IOS (siri) - Amazon Echo 3rd Gen.
    crunchipC HomoranH 3 Antworten Letzte Antwort
    • M michaelxhoffmann
      @homoran ```
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      jarvis.0
      crunchipC Abwesend
      crunchipC Abwesend
      #78
      @michaelxhoffmann nur socketio und web funktioniert jetzt?
        @homoran ```
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        jarvis.0
        #79
        ok!
        warten.
        @crunchip
        aber wieso noch ein rebuild?
        von anderer Node-Version steht jetzt ichts mehr drin
        EDIT:
        Das ist doch das log vor dem löschen (??) des Adapters
          michaelxhoffmann
          #80
          @crunchip Nein web funktioniert auch nicht
            @homoran ```
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            jarvis.0
            crunchipC Abwesend
            crunchipC Abwesend
            #81
            ist dass das log nach dem reboot?
            edit
            @Homoran hab dein edit gesehen
              edit
              michaelxhoffmann
              #82
              @crunchip Ich habe in der letzten halben stunde diverse male neu gebootet. Sicherheitshalber boote ich jetzt noch mal neu und logge neu
                crunchipC Abwesend
                crunchipC Abwesend
                #83
                @michaelxhoffmann warte mal mit dem reboot
                mach noch zuvor ein
                sudo -u iobroker npm cache clean --force
                und dann reboot
                anschliessend log von web und socketio
                  mach noch zuvor ein
                  und dann reboot
                  michaelxhoffmann
                  #84
                  @crunchip :) zu spät ich mache einfach noch mal ein reboot. das übt
                    crunchipC Abwesend
                    crunchipC Abwesend
                    #85
                    @michaelxhoffmann ok
                    dann zeig die Logausgabe
                      michaelxhoffmann
                      #86
                      spberrypi
                      2023-08-31 14:32:54.203	info	system.adapter.web.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules","module":"iobroker.js-controller","version":"5.0.12"})
                      host.raspberrypi
                      2023-08-31 14:32:54.202	info	Adapter system.adapter.web.0 needs rebuild of iobroker.js-controller and will be restarted afterwards.
                      host.raspberrypi
                      2023-08-31 14:32:54.202	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      host.raspberrypi
                      2023-08-31 14:32:54.202	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
                      host.raspberrypi
                      2023-08-31 14:32:54.201	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
                      host.raspberrypi
                      2023-08-31 14:32:54.200	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
                      host.raspberrypi
                      2023-08-31 14:32:51.934	info	instance system.adapter.web.0 started with pid 3561
                      jarvis.0
                      2023-08-31 14:31:13.899	info	Connection: WebSocket opened on port 8400 using http...
                      lovelace.0
                      2023-08-31 14:30:38.444	warn	Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
                      host.raspberrypi
                      2023-08-31 14:30:07.863	warn	adapter "web" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                      host.raspberrypi
                      2023-08-31 14:30:07.861	info	system.adapter.web.0 will be rebuilt
                      host.raspberrypi
                      2023-08-31 14:30:07.861	info	Adapter system.adapter.web.0 needs rebuild and will be restarted afterwards.
                      host.raspberrypi
                      2023-08-31 14:30:07.861	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      host.raspberrypi
                      2023-08-31 14:30:07.860	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
                      host.raspberrypi
                      2023-08-31 14:30:07.859	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
                      host.raspberrypi
                      2023-08-31 14:30:07.859	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
                      jarvis.0
                      host.raspberrypi
                      2023-08-31 14:30:28.465	info	system.adapter.socketio.0 will be rebuilt
                      host.raspberrypi
                      2023-08-31 14:30:28.464	error	instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      host.raspberrypi
                      2023-08-31 14:30:28.463	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
                      host.raspberrypi
                      2023-08-31 14:30:28.464	info	Adapter system.adapter.socketio.0 needs rebuild and will be restarted afterwards.
                      host.raspberrypi
                      2023-08-31 14:30:28.462	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
                      host.raspberrypi
                      2023-08-31 14:30:28.461	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
                      host.raspberrypi
                      2023-08-31 14:32:53.816	warn	adapter "socketio" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                      host.raspberrypi
                      2023-08-31 14:32:53.815	info	system.adapter.socketio.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules","module":"iobroker.js-controller","version":"5.0.12"})
                      host.raspberrypi
                      2023-08-31 14:32:53.815	info	Adapter system.adapter.socketio.0 needs rebuild of iobroker.js-controller and will be restarted afterwards.
                      host.raspberrypi
                      2023-08-31 14:32:53.815	error	instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      host.raspberrypi
                      2023-08-31 14:32:53.814	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
                      host.raspberrypi
                      2023-08-31 14:32:53.813	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
                      host.raspberrypi
                      2023-08-31 14:32:53.813	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
                      host.raspberrypi
                      2023-08-31 14:32:51.985	info	instance system.adapter.socketio.0 started with pid 3567
                      jarvis.0
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      2023-08-31 14:30:24.252	info	instance system.adapter.socketio.0 started with pid 1643
                        spberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        jarvis.0
                        lovelace.0
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        jarvis.0
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        jarvis.0
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        #87
                        @michaelxhoffmann wieso springt die Zeit im 2. log? (zeile 16 -> 14)
                        Ansonsten scheinen beide Adapter gerade neu gebaut zu werden.
                        Also etwas warten
                          Also etwas warten
                          crunchipC Abwesend
                          crunchipC Abwesend
                          #88
                          @homoran glaub da springt nix, das hat er zusammenkopiert, daher auch ne leerzeile(31)
                            #89
                            @crunchip oder der ntp schlägt nach dem reboot verzögert zu
                              michaelxhoffmann
                              #90
                              Nun denn das Ergebnis bleibt das gleiche. Weder Socketio noch web.0 laufen.
                              Ich will noch nicht mal ausschließen dass in der ganzen Rettungsaktion was schief gegangen ist durch falsche Eingaben meinerseits. Die Frage ist jetzt lässt sich das irgendwie retten oder muss ich doch alles neu installieren?
                              crunchipC HomoranH 2 Antworten Letzte Antwort
                                crunchipC Abwesend
                                crunchipC Abwesend
                                #91
                                @michaelxhoffmann
                                dann wie vorhin geschrieben
                                und nochmal manuell
                                cd /opt/iobroker/node_modules/iobroker.socketio
                                npm install --omit=dev
                                cd /opt/iobroker/node_modules/iobroker.web
                                  #92
                                  klar, weil die neu gebaut werden/wurden
                                  @homoran sagte in Nach Update auf Admin 5.8 Startet Biobroker nicht mehr:
                                  ansonsten scheinen beide Adapter gerade neu gebaut zu werden.
                                  Also etwas warten
                                  das ist jetzt allerfi gs schon länger her.
                                  hast du nach ausreichendem Warten nochmal versucht die Instanzen zu starten?
                                    Also etwas warten
                                    michaelxhoffmann
                                    #93
                                    Ja, ich habe ja den Broker neu gestartet...
                                    Aber OK Jetzt noch mal so gemacht wie im Vorposten geschrieben.
                                    pi@raspberrypi:/ $ sudo -u iobroker npm cache clean --force
                                    npm WARN using --force Recommended protections disabled.
                                    pi@raspberrypi:/ $ cd /opt/iobroker/node_modules/iobroker.socketio
                                    pi@raspberrypi:/opt/iobroker/node_modules/iobroker.socketio $ npm install --omit=dev
                                    up to date, audited 64 packages in 4s
                                    3 packages are looking for funding
                                      run `npm fund` for details
                                    1 moderate severity vulnerability
                                    To address all issues (including breaking changes), run:
                                      npm audit fix --force
                                    Run `npm audit` for details.
                                    pi@raspberrypi:/opt/iobroker/node_modules/iobroker.socketio $ cd /opt/iobroker/node_modules/iobroker.web
                                    pi@raspberrypi:/opt/iobroker/node_modules/iobroker.web $ npm install --omit=dev
                                    up to date, audited 139 packages in 5s
                                    10 packages are looking for funding
                                    3 moderate severity vulnerabilities
                                      #94
                                      wann?
                                      nach dem letzten log, als der rebuild noch lief?
                                        wann?
                                        michaelxhoffmann
                                        #95
                                        @homoran Ähm Gute Frage. Woran erkenne ich denn dass der Rebuild noch läuft?
                                        HomoranH crunchipC 2 Antworten Letzte Antwort
                                          adapter "socketio" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                                          hast du wirklich den Adapter gelöscht, oder nur die Instanz?
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          #96
                                          weil es mir gerade einfällt bei dieser Frage
                                          ich bekommt den socketio auch nicht mehr los, hatte den Adapter schon per admin als auch über die Konsole gelöscht,
                                          als es letztens ein Update gab wurde er wieder bei mir angezeigt.
                                          erneut gelöscht, was aber auffällt, er bleibt als Adapter ohne Instanz bestehen
