  4. Nach Update auf Admin 5.8 Startet Biobroker nicht mehr
    5.2k
120 Beiträge 7 Kommentatoren 13.3k Aufrufe 5 Beobachtet
  • M michaelxhoffmann
    @crunchip
    Jo gemacht:
    pi@raspberrypi:/opt/iobroker/node_modules/iobroker.web $ npm install --omit=dev
    up to date, audited 139 packages in 5s
    10 packages are looking for funding
      run `npm fund` for details
    3 moderate severity vulnerabilities
    To address all issues (including breaking changes), run:
      npm audit fix --force
    Run `npm audit` for details.
    pi@raspberrypi:/opt/iobroker/node_modules/iobroker.socketio $ npm install --omit=dev
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    added 62 packages, and audited 64 packages in 28s
    3 packages are looking for funding
    1 moderate severity vulnerability
    Socketio immer noch rot :(
    crunchipC Abwesend
    crunchipC Abwesend
    #74
    @michaelxhoffmann ok, sollten dann jetzt wieder laufen
    eventuell auch mal
    sudo reboot
      eventuell auch mal
      sudo reboot
      michaelxhoffmann
      schrieb am zuletzt editiert von michaelxhoffmann
      #75
      @crunchip nope :( Instanz bleibt rot
      Homematic CCU2 - Raspberry Pi 4 - IOS (siri) - Amazon Echo 3rd Gen.
        #76
        @michaelxhoffmann sagte in Nach Update auf Admin 5.8 Startet Biobroker nicht mehr:
        @crunchip nope :( Adapter bleibt rot
        und was steht im log?????
          michaelxhoffmann
          #77
          @homoran ```
          host.raspberrypi
          2023-08-31 14:10:03.959	info	object deleted system.adapter.socketio.0
          host.raspberrypi
          2023-08-31 14:10:00.888	info	iobroker host.raspberrypi Counted 3 states (system.adapter.socketio.0.*) from states
          host.raspberrypi
          2023-08-31 14:10:00.751	info	iobroker host.raspberrypi Counted 2 states (io.socketio.0.*) from states
          host.raspberrypi
          2023-08-31 14:10:00.711	info	iobroker host.raspberrypi Counted 14 states of system.adapter.socketio.0
          host.raspberrypi
          2023-08-31 14:10:00.641	info	iobroker host.raspberrypi Counted 2 states of socketio.0
          host.raspberrypi
          2023-08-31 14:10:00.571	info	iobroker host.raspberrypi Counted 1 channels of socketio.0
          host.raspberrypi
          2023-08-31 14:10:00.442	info	iobroker host.raspberrypi Counted 1 instances of socketio.0
          host.raspberrypi
          2023-08-31 14:10:00.003	info	iobroker Delete instance "socketio.0"
          host.raspberrypi
          2023-08-31 14:09:54.509	info	iobroker del socketio.0
          host.raspberrypi
          2023-08-31 14:09:08.373	info	system.adapter.socketio.0 will be rebuilt
          host.raspberrypi
          2023-08-31 14:09:08.373	info	Adapter system.adapter.socketio.0 needs rebuild and will be restarted afterwards.
          host.raspberrypi
          2023-08-31 14:09:08.373	error	instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.raspberrypi
          2023-08-31 14:09:08.372	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
          host.raspberrypi
          2023-08-31 14:09:08.371	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
          host.raspberrypi
          2023-08-31 14:09:08.370	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
          host.raspberrypi
          2023-08-31 14:09:04.753	info	instance system.adapter.socketio.0 started with pid 1994
          jarvis.0
          2023-08-31 14:09:02.390	info	Connection: WebSocket opened on port 8400 using http...
          crunchipC HomoranH 3 Antworten Letzte Antwort
            @homoran ```
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            host.raspberrypi
            jarvis.0
            crunchipC Abwesend
            crunchipC Abwesend
            #78
            @michaelxhoffmann nur socketio und web funktioniert jetzt?
              @homoran ```
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              host.raspberrypi
              jarvis.0
              #79
              ok!
              warten.
              @crunchip
              aber wieso noch ein rebuild?
              von anderer Node-Version steht jetzt ichts mehr drin
              EDIT:
              Das ist doch das log vor dem löschen (??) des Adapters
                michaelxhoffmann
                #80
                @crunchip Nein web funktioniert auch nicht
                  @homoran ```
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  jarvis.0
                  crunchipC Abwesend
                  crunchipC Abwesend
                  #81
                  ist dass das log nach dem reboot?
                  edit
                  @Homoran hab dein edit gesehen
                    edit
                    michaelxhoffmann
                    #82
                    @crunchip Ich habe in der letzten halben stunde diverse male neu gebootet. Sicherheitshalber boote ich jetzt noch mal neu und logge neu
                      crunchipC Abwesend
                      crunchipC Abwesend
                      #83
                      @michaelxhoffmann warte mal mit dem reboot
                      mach noch zuvor ein
                      sudo -u iobroker npm cache clean --force
                      und dann reboot
                      anschliessend log von web und socketio
                        mach noch zuvor ein
                        und dann reboot
                        michaelxhoffmann
                        #84
                        @crunchip :) zu spät ich mache einfach noch mal ein reboot. das übt
                          crunchipC Abwesend
                          crunchipC Abwesend
                          #85
                          dann zeig die Logausgabe
                            michaelxhoffmann
                            #86
                            spberrypi
                            2023-08-31 14:32:54.203	info	system.adapter.web.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules","module":"iobroker.js-controller","version":"5.0.12"})
                            host.raspberrypi
                            2023-08-31 14:32:54.202	info	Adapter system.adapter.web.0 needs rebuild of iobroker.js-controller and will be restarted afterwards.
                            host.raspberrypi
                            2023-08-31 14:32:54.202	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            host.raspberrypi
                            2023-08-31 14:32:54.202	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
                            host.raspberrypi
                            2023-08-31 14:32:54.201	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
                            host.raspberrypi
                            2023-08-31 14:32:54.200	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
                            host.raspberrypi
                            2023-08-31 14:32:51.934	info	instance system.adapter.web.0 started with pid 3561
                            jarvis.0
                            2023-08-31 14:31:13.899	info	Connection: WebSocket opened on port 8400 using http...
                            lovelace.0
                            2023-08-31 14:30:38.444	warn	Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
                            host.raspberrypi
                            2023-08-31 14:30:07.863	warn	adapter "web" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                            host.raspberrypi
                            2023-08-31 14:30:07.861	info	system.adapter.web.0 will be rebuilt
                            host.raspberrypi
                            2023-08-31 14:30:07.861	info	Adapter system.adapter.web.0 needs rebuild and will be restarted afterwards.
                            host.raspberrypi
                            2023-08-31 14:30:07.861	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            host.raspberrypi
                            2023-08-31 14:30:07.860	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
                            host.raspberrypi
                            2023-08-31 14:30:07.859	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
                            host.raspberrypi
                            2023-08-31 14:30:07.859	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
                            jarvis.0
                            host.raspberrypi
                            2023-08-31 14:30:28.465	info	system.adapter.socketio.0 will be rebuilt
                            host.raspberrypi
                            2023-08-31 14:30:28.464	error	instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            host.raspberrypi
                            2023-08-31 14:30:28.463	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
                            host.raspberrypi
                            2023-08-31 14:30:28.464	info	Adapter system.adapter.socketio.0 needs rebuild and will be restarted afterwards.
                            host.raspberrypi
                            2023-08-31 14:30:28.462	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
                            host.raspberrypi
                            2023-08-31 14:30:28.461	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
                            host.raspberrypi
                            2023-08-31 14:32:53.816	warn	adapter "socketio" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                            host.raspberrypi
                            2023-08-31 14:32:53.815	info	system.adapter.socketio.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules","module":"iobroker.js-controller","version":"5.0.12"})
                            host.raspberrypi
                            2023-08-31 14:32:53.815	info	Adapter system.adapter.socketio.0 needs rebuild of iobroker.js-controller and will be restarted afterwards.
                            host.raspberrypi
                            2023-08-31 14:32:53.815	error	instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            host.raspberrypi
                            2023-08-31 14:32:53.814	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
                            host.raspberrypi
                            2023-08-31 14:32:53.813	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
                            host.raspberrypi
                            2023-08-31 14:32:53.813	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
                            host.raspberrypi
                            2023-08-31 14:32:51.985	info	instance system.adapter.socketio.0 started with pid 3567
                            jarvis.0
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            host.raspberrypi
                            2023-08-31 14:30:24.252	info	instance system.adapter.socketio.0 started with pid 1643
                              spberrypi
                              host.raspberrypi
                              host.raspberrypi
                              host.raspberrypi
                              host.raspberrypi
                              host.raspberrypi
                              host.raspberrypi
                              jarvis.0
                              lovelace.0
                              host.raspberrypi
                              host.raspberrypi
                              host.raspberrypi
                              host.raspberrypi
                              host.raspberrypi
                              host.raspberrypi
                              host.raspberrypi
                              jarvis.0
                              host.raspberrypi
                              host.raspberrypi
                              host.raspberrypi
                              host.raspberrypi
                              host.raspberrypi
                              host.raspberrypi
                              host.raspberrypi
                              host.raspberrypi
                              host.raspberrypi
                              host.raspberrypi
                              host.raspberrypi
                              host.raspberrypi
                              host.raspberrypi
                              host.raspberrypi
                              jarvis.0
                              host.raspberrypi
                              host.raspberrypi
                              host.raspberrypi
                              host.raspberrypi
                              host.raspberrypi
                              host.raspberrypi
                              host.raspberrypi
                              #87
                              @michaelxhoffmann wieso springt die Zeit im 2. log? (zeile 16 -> 14)
                              Ansonsten scheinen beide Adapter gerade neu gebaut zu werden.
                              Also etwas warten
                                Also etwas warten
                                crunchipC Abwesend
                                crunchipC Abwesend
                                #88
                                @homoran glaub da springt nix, das hat er zusammenkopiert, daher auch ne leerzeile(31)
                                  #89
                                  @crunchip oder der ntp schlägt nach dem reboot verzögert zu
                                    michaelxhoffmann
                                    #90
                                    Nun denn das Ergebnis bleibt das gleiche. Weder Socketio noch web.0 laufen.
                                    Ich will noch nicht mal ausschließen dass in der ganzen Rettungsaktion was schief gegangen ist durch falsche Eingaben meinerseits. Die Frage ist jetzt lässt sich das irgendwie retten oder muss ich doch alles neu installieren?
                                    crunchipC HomoranH 2 Antworten Letzte Antwort
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      #91
                                      @michaelxhoffmann
                                      dann wie vorhin geschrieben
                                      und nochmal manuell
                                      cd /opt/iobroker/node_modules/iobroker.socketio
                                      cd /opt/iobroker/node_modules/iobroker.web
                                        #92
                                        klar, weil die neu gebaut werden/wurden
                                        @homoran sagte in Nach Update auf Admin 5.8 Startet Biobroker nicht mehr:
                                        ansonsten scheinen beide Adapter gerade neu gebaut zu werden.
                                        Also etwas warten
                                        das ist jetzt allerfi gs schon länger her.
                                        hast du nach ausreichendem Warten nochmal versucht die Instanzen zu starten?
                                          Also etwas warten
                                          michaelxhoffmann
                                          #93
                                          Ja, ich habe ja den Broker neu gestartet...
                                          Aber OK Jetzt noch mal so gemacht wie im Vorposten geschrieben.
                                          pi@raspberrypi:/ $ sudo -u iobroker npm cache clean --force
                                          npm WARN using --force Recommended protections disabled.
                                          pi@raspberrypi:/ $ cd /opt/iobroker/node_modules/iobroker.socketio
                                          up to date, audited 64 packages in 4s
                                          pi@raspberrypi:/opt/iobroker/node_modules/iobroker.socketio $ cd /opt/iobroker/node_modules/iobroker.web
