  4. Nach Update auf Admin 5.8 Startet Biobroker nicht mehr
    5.2k
120 Beiträge 7 Kommentatoren 13.3k Aufrufe 5 Beobachtet
  • M michaelxhoffmann
    @homoran ```
    host.raspberrypi
    2023-08-31 14:10:03.959	info	object deleted system.adapter.socketio.0
    host.raspberrypi
    2023-08-31 14:10:00.888	info	iobroker host.raspberrypi Counted 3 states (system.adapter.socketio.0.*) from states
    host.raspberrypi
    2023-08-31 14:10:00.751	info	iobroker host.raspberrypi Counted 2 states (io.socketio.0.*) from states
    host.raspberrypi
    2023-08-31 14:10:00.711	info	iobroker host.raspberrypi Counted 14 states of system.adapter.socketio.0
    host.raspberrypi
    2023-08-31 14:10:00.641	info	iobroker host.raspberrypi Counted 2 states of socketio.0
    host.raspberrypi
    2023-08-31 14:10:00.571	info	iobroker host.raspberrypi Counted 1 channels of socketio.0
    host.raspberrypi
    2023-08-31 14:10:00.442	info	iobroker host.raspberrypi Counted 1 instances of socketio.0
    host.raspberrypi
    2023-08-31 14:10:00.003	info	iobroker Delete instance "socketio.0"
    host.raspberrypi
    2023-08-31 14:09:54.509	info	iobroker del socketio.0
    host.raspberrypi
    2023-08-31 14:09:08.373	info	system.adapter.socketio.0 will be rebuilt
    host.raspberrypi
    2023-08-31 14:09:08.373	info	Adapter system.adapter.socketio.0 needs rebuild and will be restarted afterwards.
    host.raspberrypi
    2023-08-31 14:09:08.373	error	instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2023-08-31 14:09:08.372	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
    host.raspberrypi
    2023-08-31 14:09:08.371	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
    host.raspberrypi
    2023-08-31 14:09:08.370	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
    host.raspberrypi
    2023-08-31 14:09:04.753	info	instance system.adapter.socketio.0 started with pid 1994
    jarvis.0
    2023-08-31 14:09:02.390	info	Connection: WebSocket opened on port 8400 using http...
    crunchipC Abwesend
    crunchipC Abwesend
    #78
    @michaelxhoffmann nur socketio und web funktioniert jetzt?
      @homoran ```
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      jarvis.0
      #79
      @michaelxhoffmann sagte in Nach Update auf Admin 5.8 Startet Biobroker nicht mehr:
      ok!
      warten.
      @crunchip
      aber wieso noch ein rebuild?
      von anderer Node-Version steht jetzt ichts mehr drin
      EDIT:
      Das ist doch das log vor dem löschen (??) des Adapters
        michaelxhoffmann
        #80
        @crunchip Nein web funktioniert auch nicht
        Homematic CCU2 - Raspberry Pi 4 - IOS (siri) - Amazon Echo 3rd Gen.
          @homoran ```
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          jarvis.0
          crunchipC Abwesend
          crunchipC Abwesend
          #81
          ist dass das log nach dem reboot?
          edit
          @Homoran hab dein edit gesehen
            edit
            michaelxhoffmann
            #82
            @crunchip Ich habe in der letzten halben stunde diverse male neu gebootet. Sicherheitshalber boote ich jetzt noch mal neu und logge neu
              crunchipC Abwesend
              crunchipC Abwesend
              #83
              @michaelxhoffmann warte mal mit dem reboot
              mach noch zuvor ein
              sudo -u iobroker npm cache clean --force
              und dann reboot
              anschliessend log von web und socketio
                mach noch zuvor ein
                und dann reboot
                michaelxhoffmann
                #84
                @crunchip :) zu spät ich mache einfach noch mal ein reboot. das übt
                  crunchipC Abwesend
                  crunchipC Abwesend
                  #85
                  @michaelxhoffmann ok
                  dann zeig die Logausgabe
                    michaelxhoffmann
                    #86
                    spberrypi
                    2023-08-31 14:32:54.203	info	system.adapter.web.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules","module":"iobroker.js-controller","version":"5.0.12"})
                    host.raspberrypi
                    2023-08-31 14:32:54.202	info	Adapter system.adapter.web.0 needs rebuild of iobroker.js-controller and will be restarted afterwards.
                    host.raspberrypi
                    2023-08-31 14:32:54.202	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    host.raspberrypi
                    2023-08-31 14:32:54.202	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
                    host.raspberrypi
                    2023-08-31 14:32:54.201	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
                    host.raspberrypi
                    2023-08-31 14:32:54.200	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
                    host.raspberrypi
                    2023-08-31 14:32:51.934	info	instance system.adapter.web.0 started with pid 3561
                    jarvis.0
                    2023-08-31 14:31:13.899	info	Connection: WebSocket opened on port 8400 using http...
                    lovelace.0
                    2023-08-31 14:30:38.444	warn	Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
                    host.raspberrypi
                    2023-08-31 14:30:07.863	warn	adapter "web" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                    host.raspberrypi
                    2023-08-31 14:30:07.861	info	system.adapter.web.0 will be rebuilt
                    host.raspberrypi
                    2023-08-31 14:30:07.861	info	Adapter system.adapter.web.0 needs rebuild and will be restarted afterwards.
                    host.raspberrypi
                    2023-08-31 14:30:07.861	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    host.raspberrypi
                    2023-08-31 14:30:07.860	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
                    host.raspberrypi
                    2023-08-31 14:30:07.859	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
                    host.raspberrypi
                    2023-08-31 14:30:07.859	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
                    jarvis.0
                    host.raspberrypi
                    2023-08-31 14:30:28.465	info	system.adapter.socketio.0 will be rebuilt
                    host.raspberrypi
                    2023-08-31 14:30:28.464	error	instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    host.raspberrypi
                    2023-08-31 14:30:28.463	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
                    host.raspberrypi
                    2023-08-31 14:30:28.464	info	Adapter system.adapter.socketio.0 needs rebuild and will be restarted afterwards.
                    host.raspberrypi
                    2023-08-31 14:30:28.462	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
                    host.raspberrypi
                    2023-08-31 14:30:28.461	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
                    host.raspberrypi
                    2023-08-31 14:32:53.816	warn	adapter "socketio" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                    host.raspberrypi
                    2023-08-31 14:32:53.815	info	system.adapter.socketio.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules","module":"iobroker.js-controller","version":"5.0.12"})
                    host.raspberrypi
                    2023-08-31 14:32:53.815	info	Adapter system.adapter.socketio.0 needs rebuild of iobroker.js-controller and will be restarted afterwards.
                    host.raspberrypi
                    2023-08-31 14:32:53.815	error	instance system.adapter.socketio.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    host.raspberrypi
                    2023-08-31 14:32:53.814	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.socketio/main.js' ]
                    host.raspberrypi
                    2023-08-31 14:32:53.813	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/main.js:9:21)
                    host.raspberrypi
                    2023-08-31 14:32:53.813	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.socketio/main.js
                    host.raspberrypi
                    2023-08-31 14:32:51.985	info	instance system.adapter.socketio.0 started with pid 3567
                    jarvis.0
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    2023-08-31 14:30:24.252	info	instance system.adapter.socketio.0 started with pid 1643
                      spberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      jarvis.0
                      lovelace.0
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      jarvis.0
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      jarvis.0
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      host.raspberrypi
                      #87
                      @michaelxhoffmann wieso springt die Zeit im 2. log? (zeile 16 -> 14)
                      Ansonsten scheinen beide Adapter gerade neu gebaut zu werden.
                      Also etwas warten
                        Also etwas warten
                        crunchipC Abwesend
                        crunchipC Abwesend
                        #88
                        @homoran glaub da springt nix, das hat er zusammenkopiert, daher auch ne leerzeile(31)
                          #89
                          @crunchip oder der ntp schlägt nach dem reboot verzögert zu
                            michaelxhoffmann
                            #90
                            Nun denn das Ergebnis bleibt das gleiche. Weder Socketio noch web.0 laufen.
                            Ich will noch nicht mal ausschließen dass in der ganzen Rettungsaktion was schief gegangen ist durch falsche Eingaben meinerseits. Die Frage ist jetzt lässt sich das irgendwie retten oder muss ich doch alles neu installieren?
                            crunchipC HomoranH 2 Antworten Letzte Antwort
                              crunchipC Abwesend
                              crunchipC Abwesend
                              #91
                              @michaelxhoffmann
                              dann wie vorhin geschrieben
                              und nochmal manuell
                              cd /opt/iobroker/node_modules/iobroker.socketio
                              npm install --omit=dev
                              cd /opt/iobroker/node_modules/iobroker.web
                                #92
                                klar, weil die neu gebaut werden/wurden
                                @homoran sagte in Nach Update auf Admin 5.8 Startet Biobroker nicht mehr:
                                ansonsten scheinen beide Adapter gerade neu gebaut zu werden.
                                Also etwas warten
                                das ist jetzt allerfi gs schon länger her.
                                hast du nach ausreichendem Warten nochmal versucht die Instanzen zu starten?
                                  Also etwas warten
                                  michaelxhoffmann
                                  schrieb am zuletzt editiert von michaelxhoffmann
                                  #93
                                  Ja, ich habe ja den Broker neu gestartet...
                                  Aber OK Jetzt noch mal so gemacht wie im Vorposten geschrieben.
                                  pi@raspberrypi:/ $ sudo -u iobroker npm cache clean --force
                                  npm WARN using --force Recommended protections disabled.
                                  pi@raspberrypi:/ $ cd /opt/iobroker/node_modules/iobroker.socketio
                                  pi@raspberrypi:/opt/iobroker/node_modules/iobroker.socketio $ npm install --omit=dev
                                  up to date, audited 64 packages in 4s
                                  3 packages are looking for funding
                                    run `npm fund` for details
                                  1 moderate severity vulnerability
                                  To address all issues (including breaking changes), run:
                                    npm audit fix --force
                                  Run `npm audit` for details.
                                  pi@raspberrypi:/opt/iobroker/node_modules/iobroker.socketio $ cd /opt/iobroker/node_modules/iobroker.web
                                  pi@raspberrypi:/opt/iobroker/node_modules/iobroker.web $ npm install --omit=dev
                                  up to date, audited 139 packages in 5s
                                  10 packages are looking for funding
                                  3 moderate severity vulnerabilities
                                    #94
                                    wann?
                                    nach dem letzten log, als der rebuild noch lief?
                                      wann?
                                      michaelxhoffmann
                                      #95
                                      @homoran Ähm Gute Frage. Woran erkenne ich denn dass der Rebuild noch läuft?
                                      HomoranH crunchipC 2 Antworten Letzte Antwort
                                        adapter "socketio" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                                        hast du wirklich den Adapter gelöscht, oder nur die Instanz?
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        #96
                                        weil es mir gerade einfällt bei dieser Frage
                                        ich bekommt den socketio auch nicht mehr los, hatte den Adapter schon per admin als auch über die Konsole gelöscht,
                                        als es letztens ein Update gab wurde er wieder bei mir angezeigt.
                                        erneut gelöscht, was aber auffällt, er bleibt als Adapter ohne Instanz bestehen
                                          #97
                                          Gegenfrage: wie lange nach
                                          Also etwas warten
                                          hast du gewartet?
