  4. Neuer Adapter für Roborock-Staubsauger
    6.7k
1.1k Beiträge 155 Kommentatoren 482.9k Aufrufe 138 Beobachtet
    AXMLM
    schrieb am zuletzt editiert von AXMLM
    #901
    habe Qrevo Master. Adapter wird für 1 Sekunde grün und wird mit einigen Fehlermeldungen geschlossen.
    host.smarthome
    2025-10-04 19:08:53.259	info	Restart adapter system.adapter.roborock.0 because enabled
    host.smarthome
    2025-10-04 19:08:53.259	error	instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    roborock.0
    2025-10-04 19:08:52.606	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    roborock.0
    2025-10-04 19:08:52.604	info	terminating
    roborock.0
    2025-10-04 19:08:52.595	error	Cannot read properties of undefined (reading 'captureException')
    roborock.0
    2025-10-04 19:08:52.594	error	TypeError: Cannot read properties of undefined (reading 'captureException') at Roborock.catchError (/opt/iobroker/node_modules/iobroker.roborock/main.js:881:44) at Socket.handleMessage (/opt/iobroker/node_modules/iobroker.roborock/lib/local_api.js:211:19) at Socket.emit (node:events:524:28) at UDP.onMessage [as onmessage] (node:dgram:951:8)
    roborock.0
    2025-10-04 19:08:52.593	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
    roborock.0
    2025-10-04 19:08:52.592	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    roborock.0
    2025-10-04 19:08:52.589	error	Failed to process undefined on robot undefined (unknown device model): Failed to process message: Error: error:1C80006B:Provider routines::wrong final block length at Decipheriv.final (node:internal/crypto/cipher:193:29) at local_api.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/local_api.js:248:25) at Socket.handleMessage (/opt/iobroker/node_modules/iobroker.roborock/lib/local_api.js:199:34) at Socket.emit (node:events:524:28) at UDP.onMessage [as onmessage] (node:dgram:951:8)
    roborock.0
    2025-10-04 19:08:52.363	info	MQTT connection established {"cmd":"connack","retain":false,"qos":0,"dup":false,"length":2,"topic":null,"payload":null,"sessionPresent":false,"returnCode":0}.
    roborock.0
    2025-10-04 19:08:52.287	info	MQTT initialized
    roborock.0
    2025-10-04 19:08:51.821	info	Loaded existing clientID: 031db179-0b1b-4eb0-8104-83d8f1eae377
    roborock.0
    2025-10-04 19:08:51.798	info	Starting adapter. This might take a few minutes depending on your setup. Please wait.
    roborock.0
    2025-10-04 19:08:51.779	info	starting. Version 0.6.19 in /opt/iobroker/node_modules/iobroker.roborock, node: v20.19.5, js-controller: 7.0.7
    host.smarthome
    2025-10-04 19:08:48.709	info	instance system.adapter.roborock.0 in version "0.6.19" started with pid 484173
    host.smarthome
    2025-10-04 19:08:18.230	info	Restart adapter system.adapter.roborock.0 because enabled
    host.smarthome
    2025-10-04 19:08:18.229	error	instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    roborock.0
    2025-10-04 19:08:18.109	info	terminating
    roborock.0
    2025-10-04 19:08:17.604	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    roborock.0
    2025-10-04 19:08:17.602	info	terminating
    roborock.0
    2025-10-04 19:08:17.593	error	Cannot read properties of undefined (reading 'captureException')
    roborock.0
    2025-10-04 19:08:17.592	error	TypeError: Cannot read properties of undefined (reading 'captureException') at Roborock.catchError (/opt/iobroker/node_modules/iobroker.roborock/main.js:881:44) at Socket.handleMessage (/opt/iobroker/node_modules/iobroker.roborock/lib/local_api.js:211:19) at Socket.emit (node:events:524:28) at UDP.onMessage [as onmessage] (node:dgram:951:8)
    roborock.0
    2025-10-04 19:08:17.591	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
    roborock.0
    2025-10-04 19:08:17.590	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    roborock.0
    2025-10-04 19:08:17.587	error	Failed to process undefined on robot undefined (unknown device model): Failed to process message: Error: error:1C80006B:Provider routines::wrong final block length at Decipheriv.final (node:internal/crypto/cipher:193:29) at local_api.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/local_api.js:248:25) at Socket.handleMessage (/opt/iobroker/node_modules/iobroker.roborock/lib/local_api.js:199:34) at Socket.emit (node:events:524:28) at UDP.onMessage [as onmessage] (node:dgram:951:8)
    roborock.0
    2025-10-04 19:08:14.483	info	MQTT connection established {"cmd":"connack","retain":false,"qos":0,"dup":false,"length":2,"topic":null,"payload":null,"sessionPresent":false,"returnCode":0}.
    roborock.0
    2025-10-04 19:08:14.383	info	MQTT initialized
    roborock.0
    2025-10-04 19:08:13.808	info	Loaded existing clientID: 031db179-0b1b-4eb0-8104-83d8f1eae377
    roborock.0
    2025-10-04 19:08:13.787	info	Starting adapter. This might take a few minutes depending on your setup. Please wait.
    roborock.0
    2025-10-04 19:08:13.768	info	starting. Version 0.6.19 in /opt/iobroker/node_modules/iobroker.roborock, node: v20.19.5, js-controller: 7.0.7
    ich vermute dass es daran liegt, dass der Roboter nocj nicht unterstützt wird. Oder gibt es noch andere Gründe?
    • A AXMLM
      host.smarthome
      host.smarthome
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      host.smarthome
      host.smarthome
      host.smarthome
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      roborock.0
      #902
      @axmlm sagte in Neuer Adapter für Roborock-Staubsauger:
      Mag zwar kein Grund sein, aber bring das Ding auf nodejs@22. Per
      iob nodejs-update
      ist das in 2 Minuten passiert.
      A 2 Antworten Letzte Antwort
        iob nodejs-update
        AXMLM
        #903
        @thomas-braun said in Neuer Adapter für Roborock-Staubsauger:
        iob nodejs-update
        habe kein putty auf dieem Rechner. Gibt es einen weg über IObroker selbst?
        • A AXMLM
          iob nodejs-update
          #904
          @axmlm
          Da läuft doch ein Linux. Also hast du da auch ein Teminal.
          A 1 Antwort Letzte Antwort
          -1
            @axmlm
            AXMLM
            #905
            stehe auf dem Schlauch. habe Ubuntu Server mit IObroker und kann nur über Putty zugreifen. weder monitor noch Tastatur ist angeschlossen.
            • A AXMLM
              #906
              @axmlm
              Was denn jetzt? SSH-Zugriff (von mir aus per puTTY) oder nicht?
              Die PowerShell kann das aber auch.
                @axmlm
                AXMLM
                #907
                auch so, jetzt verstehe ich dich. Habe kein Zugriff auf power Shell. Bin gerade an administrierten Rechner. Dann muss ich doch an anderen Rechner gehen.
                  iob nodejs-update
                  AXMLM
                  #908
                  erledigt, hat nichts gebracht
                  • A AXMLM
                    #909
                    hat nichts gebracht
                    Hat ja auch niemand behauptet, das es dein Problem mit einem unbekannten Gerät lösen würde.
                      hat nichts gebracht
                      AXMLM
                      #910
                      habe auch nur eine sehr kleine Hoffnung gehabt.
                      Der Adapter sieht den Robi und schreibt die Objekte teilweise aus. Geht aber wie gesagt sofort auf rot.
                      Gibt es einen anderen Adapter, bzw. wie sind die Chancen, dass der Qrevo Master bald unterstützt wird?
                      wolfi913W 1 Antwort Letzte Antwort
                      • A AXMLM
                        wolfi913W Online
                        wolfi913W Online
                        wolfi913
                        #911
                        @axmlm
                        Schau mal hier:
                        https://github.com/copystring/ioBroker.roborock/issues/752
                        Du müsstest die dev-Version über Git installieren. Mit der soll's scheinbar funktionieren
                        • wolfi913W wolfi913
                          @axmlm
                          Schau mal hier:
                          samsungfreak
                          schrieb am zuletzt editiert von samsungfreak
                          #912
                          @wolfi913 Ich habe die Version (0.6.19) bereits am Laufen. Damit lief mein oborock Qrevo Master auch eine Zeit lang ganz gut (der Adapter ist ab und an abgestürtzt). Nach einem Firmware Update von meinem Master geht der Adapter kurz "grün" wie bei @mx-driver und danach bricht die Verbindung ab.
                          @copystring : Welche Daten brauchst du um das Problem fixen zu können?
                          • WebrangerW Offline
                            WebrangerW Offline
                            Webranger
                            #913
                            gibt es schon irgendwelche infos ob der Roborock Q10 S5 demnächst mit dem Adapter abgefragt werden kann?
                            Intel NUC Celeron, Xiaomi Gateway, Fritzbox 7590, XS1
                              AXMLM
                              #914
                              @wolfi913
                              adapter wird jetzt grün (Qrevo Master). Fange an zu testen
                              • A AXMLM
                                @wolfi913
                                AXMLM
                                #915
                                @axmlm
                                Bekomme folgende Fehler. Aktuell keine Verbindung zum Robi. Robi hat gerade den Trocknungsvorgang beendet und schläft. Soll ich ihn evtl. manuell wecken?
                                roborock.0
                                2025-10-05 18:20:25.330	error	this.cached_get_status_value for hoZrvn1fr2gj57IuzAQrv is not initialized. Request get_status first. this.cached_get_status_value: []
                                roborock.0
                                2025-10-05 18:20:25.329	warn	Failed to process "get_prop" on robot hoZrvn1fr2gj57IuzAQrv (roborock.vacuum.a117): Error: Local request with id 466 and method get_prop timed out after 30 seconds. Local connection state: true at /opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:785:14 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:1452:7) at listOnTimeout (node:internal/timers:588:17) at process.processTimers (node:internal/timers:523:7)
                                • Frederik BussF Frederik Buss
                                  Ich habe mittlerweile eine HomeAssistant VM auf meinem Proxmox neben iobroker installiert und dort funktioniert der Saros10 vom Start weg. Dank HASS Adapter lässt der sich aus iobroker heraus wirklich gut steuern, mit Bildchen, Programme starten und allem drum und dran. Ich bin kein Freund davon die beiden Systeme parallel laufen zu haben, aber es kommen immer mehr Restriktionen (Roborock, Samsung, BMW, OttoWilde und keine Ahnung wer noch künftig dazu kommt). Immerhin es geht mit etwas einlesen, YouTube Tutorials schauen, Backups ziehen usw.
                                  mx-driver
                                  #916
                                  @frederik-buss
                                  so mache ich es jetzt auch.
                                  Läuft prima und ich bin nicht mehr so abhängig von den Adaptern.
                                    michael 1975
                                    #917
                                    Mein Sauger hat heute ein update bekommen seit dem läst es ich nicht mehr über den IObroker steuern.
                                    im Log Steht
                                    2025-10-31 15:55:56.614	error	Failed to process mainUpdateInterval on robot w2SMrldXELMYjyzxZy4Mw (roborock.vacuum.a97): Error: this.get_status is not initialized. Request get_status first. at requests_handler.isCleaning (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:611:10) at /opt/iobroker/node_modules/iobroker.roborock/main.js:117:48 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:2751:38) at listOnTimeout (node:internal/timers:581:17) at processTimers (node:internal/timers:519:7)
                                    P 1 Antwort Letzte Antwort
                                    • M michael 1975
                                      im Log Steht
                                      PixelPirat
                                      #918
                                      @michael-1975 sagte in Neuer Adapter für Roborock-Staubsauger:
                                      im Log Steht
                                      Selbes leider bei mir - seit dem Update auf Version 02.17.42. Zudem werden auch bei mir alle Objekte im Unterordner „deviceStatus“ nur noch mit „null“ befüllt.
                                      Fujitsu Esprimo Q920 i5 32GB & 1TB SSD
                                      Proxmox Virtualisierung
                                      > ioBroker, HomeMatic IP, Zabbix, Portainer, Grafana, Docker, HomeAssistant, PiHole, Paperless-ngx, n8n
                                      Synology NAS
                                        Sepp
                                        #919
                                        so wie es aussieht ist es bei mir auch so
                                        • S Sepp
                                          PixelPirat
                                          #920
                                          @sepp @michael-1975
                                          Das Problem ist auf Github schon bekannt und copystring arbeitet bereits an einer Lösung.
                                          Quelle: https://github.com/copystring/ioBroker.roborock/issues/869
                                          Synology NAS
                                          K 1 Antwort Letzte Antwort
