  4. Neuer Adapter für Roborock-Staubsauger
    6.7k
1.1k Beiträge 155 Kommentatoren 482.6k Aufrufe 138 Beobachtet
  • copystringC Offline
    copystringC Offline
    copystring
    #861
    Immer erstmal auf GitHub nach schauen, ob jemand das gleiche Problem hat. Falls nicht, einfach ein GitHub Issue aufmachen. Ich schaue es mir dann an.
    Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
    https://paypal.me/copystring
    • copystringC copystring
      TimoWald
      #862
      Hallo ich habe aktuell diesen Fehler. Kann mir einer verraten woran es liegt?
      2025-07-26 17:58:52.423 - info: host.iobroker instance system.adapter.roborock.0 in version "0.6.19" (non-npm: copystring/ioBroker.roborock#769dee8a000aa78ecdcb826185abcafc1aada5d5) started with pid 2115372
      2025-07-26 17:58:56.781 - info: roborock.0 (2115372) starting. Version 0.6.19 (non-npm: copystring/ioBroker.roborock#769dee8a000aa78ecdcb826185abcafc1aada5d5) in /opt/iobroker/node_modules/iobroker.roborock, node: v20.18.0, js-controller: 7.0.6
      2025-07-26 17:58:56.799 - info: roborock.0 (2115372) Starting adapter. This might take a few minutes depending on your setup. Please wait.
      2025-07-26 17:58:56.821 - info: roborock.0 (2115372) Loaded existing clientID: ee6783f4-5d0a-4d48-b00e-7cafd23b31d9
      2025-07-26 17:58:57.104 - error: roborock.0 (2115372) Failed to process undefined on robot undefined (unknown device model): TypeError: Cannot read properties of null (reading 'rrHomeId')
      at http_api.getHomeID (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:111:31)
      at processTicksAndRejections (node:internal/process/task_queues:95:5)
      at http_api.updateHomeData (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:123:19)
      at http_api.init (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:33:3)
      at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:55:3)
      2025-07-26 17:58:57.328 - info: roborock.0 (2115372) MQTT initialized
      2025-07-26 17:58:57.329 - error: roborock.0 (2115372) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2025-07-26 17:58:57.330 - error: roborock.0 (2115372) unhandled promise rejection: this.homeData is not initialized. Initialize via getHomeData() first
      2025-07-26 17:58:57.330 - error: roborock.0 (2115372) Error: this.homeData is not initialized. Initialize via getHomeData() first
      at http_api.getDevices (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:179:10)
      at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:62:39)
      2025-07-26 17:58:57.330 - error: roborock.0 (2115372) this.homeData is not initialized. Initialize via getHomeData() first
      2025-07-26 17:58:57.343 - info: roborock.0 (2115372) terminating
      2025-07-26 17:58:57.344 - warn: roborock.0 (2115372) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2025-07-26 17:58:57.402 - info: roborock.0 (2115372) MQTT connection established {"cmd":"connack","retain":false,"qos":0,"dup":false,"length":2,"topic":null,"payload":null,"sessionPresent":false,"returnCode":0}.
      2025-07-26 17:58:57.845 - info: roborock.0 (2115372) terminating
      2025-07-26 17:58:57.994 - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2025-07-26 17:58:57.994 - error: host.iobroker Caught by controller[1]: Error: this.homeData is not initialized. Initialize via getHomeData() first
      2025-07-26 17:58:57.994 - error: host.iobroker Caught by controller[1]: at http_api.getDevices (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:179:10)
      2025-07-26 17:58:57.994 - error: host.iobroker Caught by controller[1]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:62:39)
      2025-07-26 17:58:57.994 - error: host.iobroker instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2025-07-26 17:58:57.994 - info: host.iobroker Restart adapter system.adapter.roborock.0 because enabled
      2025-07-26 17:58:59.558 - warn: openknx.0 (1699916) Ignoring GroupValue_Write of unknown GA 9/0/4
      2025-07-26 17:59:00.842 - info: host.iobroker "system.adapter.roborock.0" disabled
      • C Offline
        Creekhail
        #863
        Ich möchte mich für die Arbeit an diesem Adapter bedanken.
        Seit einigen Tagen sind wir auf den Saros 10R umgestiegen, vorher war der S7 MaxV im Einsatz. Dort hatte ich noch den Xiaomi-Adapter verwendet.
        Mit dem Umstieg auf das neue Modell habe ich auch bei der App den Wechsel zur Roborock-Original-App vollzogen. Somit musste auch im iobroker auf den neuen Adapter gewechselt werden.
        Nach leichten Anfangsschwierigkeiten (keine lokale Verbindung), läuft die Geschichte jetzt mit der Version 0.6.19
        Daher konnte ich heute auch im VIS die Anpassungen vornehmen, da die Steuerung doch in einigen Punkten vom bisherigen Xiaomi-Adapter abweicht.
        Die wesentlichen Dinge lassen sich jetzt wieder steuern bzw. ablesen, so dass auch ohne Handy der Roboter seinen Dienst verrichten kann.
        Anbei noch ein Screenshot von der VIS dazu.
        T W 2 Antworten Letzte Antwort
        • C Creekhail
          TimoWald
          #864
          @creekhail hallo könnte ich einen Export deiner Seite haben?
          C 1 Antwort Letzte Antwort
          • T TimoWald
            Creekhail
            #865
            @timowald Was genau hast du denn vor bzw. was meinst du mit "Export deiner Seite"?
            • C Creekhail
              TimoWald
              #866
              @creekhail Export deiner Seite vom Robby. Finde diese super und würde es bei mir genauso machen wollen.
              • W Offline
                W Offline
                Würfel
                schrieb am zuletzt editiert von Würfel
                #867
                ich hab die neuste Adapter Version installiert.
                Nun bleibt der Adapter dauerhaft grün.
                Wenn ich auf den Instanzlink klicke und dann 8083 nehme zeigt er mit eine schwarze Seite mit einem Reckeck oben links an und mehreren Buttons.
                In der Zeit geht der Adapter auf Rot und in Logs kommen zig Fehlermeldungen...
                Hab ich etwas falsch eingestellt im Adapter?
                host.PI250GBUSBC
                2025-07-31 23:54:32.537	warn	Do not restart adapter system.adapter.roborock.0 because restart loop detected
                host.PI250GBUSBC
                2025-07-31 23:54:32.537	info	Restart adapter system.adapter.roborock.0 because enabled
                host.PI250GBUSBC
                2025-07-31 23:54:32.536	error	instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                host.PI250GBUSBC
                2025-07-31 23:54:32.536	error	Caught by controller[3]: at requests_handler.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:601:18)
                host.PI250GBUSBC
                2025-07-31 23:54:32.536	error	Caught by controller[3]: at Roborock.catchError (/opt/iobroker/node_modules/iobroker.roborock/main.js:871:43)
                host.PI250GBUSBC
                2025-07-31 23:54:32.536	error	Caught by controller[3]: at http_api.getRobotModel (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:227:66)
                host.PI250GBUSBC
                2025-07-31 23:54:32.536	error	Caught by controller[3]: TypeError: Cannot read properties of undefined (reading 'productId')
                host.PI250GBUSBC
                2025-07-31 23:54:32.536	error	Caught by controller[3]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                host.PI250GBUSBC
                2025-07-31 23:54:32.536	error	Caught by controller[2]: at requests_handler.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:562:26)
                host.PI250GBUSBC
                2025-07-31 23:54:32.536	error	Caught by controller[2]: at requests_handler.sendRequest (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:712:17)
                host.PI250GBUSBC
                2025-07-31 23:54:32.536	error	Caught by controller[2]: at Roborock.catchError (/opt/iobroker/node_modules/iobroker.roborock/main.js:871:43)
                host.PI250GBUSBC
                2025-07-31 23:54:32.535	error	Caught by controller[2]: at http_api.getRobotModel (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:227:66)
                host.PI250GBUSBC
                2025-07-31 23:54:32.535	error	Caught by controller[2]: TypeError: Cannot read properties of undefined (reading 'productId')
                host.PI250GBUSBC
                2025-07-31 23:54:32.535	error	Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                host.PI250GBUSBC
                2025-07-31 23:54:32.535	error	Caught by controller[0]: at requests_handler.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:559:17)
                host.PI250GBUSBC
                2025-07-31 23:54:32.535	error	Caught by controller[0]: at requests_handler.sendRequest (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:712:17)
                host.PI250GBUSBC
                2025-07-31 23:54:32.535	error	Caught by controller[0]: at Roborock.catchError (/opt/iobroker/node_modules/iobroker.roborock/main.js:871:43)
                host.PI250GBUSBC
                2025-07-31 23:54:32.535	error	Caught by controller[0]: at http_api.getRobotModel (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:227:66)
                host.PI250GBUSBC
                2025-07-31 23:54:32.534	error	Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'productId')
                host.PI250GBUSBC
                2025-07-31 23:54:32.534	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                roborock.0
                2025-07-31 23:54:32.330	info	terminating
                roborock.0
                2025-07-31 23:54:31.856	error	Cannot read properties of undefined (reading 'productId')
                roborock.0
                2025-07-31 23:54:31.856	error	TypeError: Cannot read properties of undefined (reading 'productId') at http_api.getRobotModel (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:227:66) at Roborock.catchError (/opt/iobroker/node_modules/iobroker.roborock/main.js:871:43) at requests_handler.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:601:18)
                roborock.0
                2025-07-31 23:54:31.854	error	unhandled promise rejection: Cannot read properties of undefined (reading 'productId')
                roborock.0
                2025-07-31 23:54:31.854	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                roborock.0
                2025-07-31 23:54:31.850	error	Cannot read properties of undefined (reading 'productId')
                roborock.0
                2025-07-31 23:54:31.849	error	TypeError: Cannot read properties of undefined (reading 'productId') at http_api.getRobotModel (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:227:66) at Roborock.catchError (/opt/iobroker/node_modules/iobroker.roborock/main.js:871:43) at requests_handler.sendRequest (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:712:17) at requests_handler.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:562:26)
                roborock.0
                2025-07-31 23:54:31.848	error	unhandled promise rejection: Cannot read properties of undefined (reading 'productId')
                roborock.0
                2025-07-31 23:54:31.848	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                roborock.0
                2025-07-31 23:54:31.828	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                roborock.0
                2025-07-31 23:54:31.826	info	terminating
                roborock.0
                2025-07-31 23:54:31.815	error	Cannot read properties of undefined (reading 'productId')
                roborock.0
                2025-07-31 23:54:31.815	error	TypeError: Cannot read properties of undefined (reading 'productId') at http_api.getRobotModel (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:227:66) at Roborock.catchError (/opt/iobroker/node_modules/iobroker.roborock/main.js:871:43) at requests_handler.sendRequest (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:712:17) at requests_handler.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:559:17)
                roborock.0
                2025-07-31 23:54:31.813	error	unhandled promise rejection: Cannot read properties of undefined (reading 'productId')
                roborock.0
                2025-07-31 23:54:31.812	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                roborock.0
                2025-07-31 23:54:31.500	error	Failed to process mainUpdateInterval on robot bMnYxoB2iqR9CnAlTK9fy (roborock.vacuum.a144): Error: this.get_status is not initialized. Request get_status first. at requests_handler.isCleaning (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:611:10) at /opt/iobroker/node_modules/iobroker.roborock/main.js:117:48 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:2751:38) at listOnTimeout (node:internal/timers:581:17) at processTimers (node:internal/timers:519:7)
                roborock.0
                2025-07-31 23:54:30.411	error	Failed to process mainUpdateInterval on robot bMnYxoB2iqR9CnAlTK9fy (roborock.vacuum.a144): Error: this.get_status is not initialized. Request get_status first. at requests_handler.isCleaning (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:611:10) at /opt/iobroker/node_modules/iobroker.roborock/main.js:117:48
                roborock.0
                2025-07-31 23:54:29.403	info	Starting adapter finished. Let's go!!!!!!!
                roborock.0
                2025-07-31 23:54:22.571	error	Failed to process undefined on robot undefined (unknown device model): This robot is not fully supported just yet. Contact the dev to get this robot fully supported!
                roborock.0
                2025-07-31 23:54:21.279	error	Failed to process undefined on robot undefined (unknown device model): Failed to process message: Error: error:1C80006B:Provider routines::wrong final block length at Decipheriv.final (node:internal/crypto/cipher:193:29) at local_api.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/local_api.js:248:25) at Socket.handleMessage (/opt/iobroker/node_modules/iobroker.roborock/lib/local_api.js:199:34) at Socket.emit (node:events:524:28) at Socket.emit (node:domain:489:12) at UDP.onMessage (node:dgram:951:8)
                roborock.0
                2025-07-31 23:54:17.464	info	MQTT connection established {"cmd":"connack","retain":false,"qos":0,"dup":false,"length":2,"topic":null,"payload":null,"sessionPresent":false,"returnCode":0}.
                roborock.0
                2025-07-31 23:54:17.341	info	MQTT initialized
                roborock.0
                2025-07-31 23:54:16.632	info	Loaded existing clientID: 61f945a6-3735-4f3e-bcaa-dabc268a04bc
                roborock.0
                2025-07-31 23:54:16.569	info	Starting adapter. This might take a few minutes depending on your setup. Please wait.
                roborock.0
                2025-08-01 00:00:14.402	error	Failed to process mainUpdateInterval on robot bMnYxoB2iqR9CnAlTxxxxx (roborock.vacuum.a144): Error: this.get_status is not initialized. Request get_status first. at requests_handler.isCleaning (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:611:10) at /opt/iobroker/node_modules/iobroker.roborock/main.js:117:48 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:2751:38) at listOnTimeout (node:internal/timers:581:17) at processTimers (node:internal/timers:519:7)
                • F fritzkalle
                  ich habe den Adapter jetzt eine Weile mit dem Saros 10R laufen und er funktioniert zwar, stürzt aber häufig ab und ist dann bis zum Neustart nicht ansprechbar :-(
                  Das hier sind die Fehlermeldungen:
                  setTimeout called, but adapter is shutting down
                  Failed to process "get_clean_summary" on robot vArM2m3ap0E3f7dsbZWNX (roborock.vacuum.a144): Error: Could not check object existence of roborock.0.Devices.vArM2m3ap0E3f7dsbZWNX.cleaningInfo.records.10.dust_collection_status: Cannot check object existence of "roborock.0.Devices.vArM2m3ap0E3f7dsbZWNX.cleaningInfo.records.10.dust_collection_status": Connection is closed. at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/maybeCallback.ts:129:17) at Roborock._setObjectNotExists (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:5017:26) at /opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2336:17
                  Could not check object existence of roborock.0.Devices.vArM2m3ap0E3f7dsbZWNX.cleaningInfo.records.10: Cannot check object existence of "roborock.0.Devices.vArM2m3ap0E3f7dsbZWNX.cleaningInfo.records.10": Connection is closed.
                  Could not check object existence of roborock.0.Devices.vArM2m3ap0E3f7dsbZWNX.cleaningInfo.records.10: Cannot check object existence of "roborock.0.Devices.vArM2m3ap0E3f7dsbZWNX.cleaningInfo.records.10": Connection is closed. at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/maybeCallback.ts:129:17) at Roborock._setObjectNotExists (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:5017:26) at runNextTicks (node:internal/process/task_queues:60:5) at processImmediate (node:internal/timers:454:9) at /opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2336:17
                  unhandled promise rejection: Could not check object existence of roborock.0.Devices.vArM2m3ap0E3f7dsbZWNX.cleaningInfo.records.10: Cannot check object existence of "roborock.0.Devices.vArM2m3ap0E3f7dsbZWNX.cleaningInfo.records.10": Connection is closed.
                  get state error: Connection is closed.
                  redis get roborock.0.Devices.vArM2m3ap0E3f7dsbZWNX.cleaningInfo.records.10.clean_type, error - Connection is closed.
                  Ich weiß nicht, ob ich das mit dem Einfügen der Fehlermeldungen richtig gemacht habe. Ich bitte um Nachsicht. Auch weiß ich leider nicht ob und wie ich ein Issue auf Github aufmachen sollte.
                  Viele Grüße!
                  fritzkalle
                  #868
                  Github Issue geschlossen, da Problem nach Neuinstallation des Adapters nicht mehr reproduzierbar.
                  • C Creekhail
                    W Offline
                    W Offline
                    Würfel
                    #869
                    @creekhail
                    Was musstest Du denn anpassen das es bei Dir funktioniert?
                    bei mir wird der Adapter zwar grün, ruft man die Seite von dem Adapter auf springt der Adapter auf Rot und wirft zig Fehler im Log.
                    Tobias
                    • T Nicht stören
                      T Nicht stören
                      ticaki
                      #870
                      Hallo, weil ich meinen neuen Roborock Qrevo Curv S5X, nicht bei miHome gefunden habe, bin auf diesen Adapter (dev-branch) umgestiegen.
                      Der Saugroboter wird noch nicht "unterstützt", aber ich sehe die Daten und kann Programme starten, daher meine Frage:
                      Nach einer gewissen Zeit (ein paar Stunden) wird das Gerät als offline angezeigt und bleibt auch dabei. Ich kann dann zwar noch immer Programme über den Adapter starten, aber die Datenpunkte aktualisieren sich nicht mehr. Um das vollständig zu automatisieren müsste sich roborock.0.Devices.***.deviceStatus.state aktualisieren. Ist das ein Issuewert oder wird sich das ändern falls die Daten eingepflegt werden? Oder sollte ich per Skript den Adapter neustarten, wenn das Gerät länger als X Minuten offline ist.
                      Zusätzlich würde mich auch interessieren, ob es einen state gibt der "Programm läuft/Programm ist fertig" abbildet?
                      Spenden
                      System 9S 1 Antwort Letzte Antwort
                      • T ticaki
                        System 9S Offline
                        System 9S Offline
                        System 9
                        #871
                        guten morgen.
                        ich bekomme fehler, da einige Datenpunkte nicht angelegt werden.
                        State "roborock.0.Devices.6vZ1zawxmrZgMTxgOPtwJn.deviceStatus.carpet_clean_mode" has no existing object, this might lead to an error in future versions
                        State "roborock.0.Devices.6vZ1zawxmrZgMTxgOPtwJn.deviceStatus.carpet_mode" has no existing object, this might lead to an error in future versions
                        was kann ich hier machen ?
                        • System 9S System 9
                          guten morgen.
                          TimoWald
                          #872
                          Hallo, wieso bekomme ich meinen Adapter nicht mehr auf grün?
                          Dieser Feher kommt nach dem starten.
                          Was kann ich tun?
                          2025-08-20 06:57:36.146 - info: host.iobroker instance system.adapter.roborock.0 in version "0.6.19" (non-npm: copystring/ioBroker.roborock#769dee8a000aa78ecdcb826185abcafc1aada5d5) started with pid 2735931
                          2025-08-20 06:57:40.150 - info: roborock.0 (2735931) starting. Version 0.6.19 (non-npm: copystring/ioBroker.roborock#769dee8a000aa78ecdcb826185abcafc1aada5d5) in /opt/iobroker/node_modules/iobroker.roborock, node: v20.18.0, js-controller: 7.0.7
                          2025-08-20 06:57:40.171 - info: roborock.0 (2735931) Starting adapter. This might take a few minutes depending on your setup. Please wait.
                          2025-08-20 06:57:40.187 - info: roborock.0 (2735931) Loaded existing clientID: ee6783f4-5d0a-4d48-b00e-7cafd23b31d9
                          2025-08-20 06:57:40.472 - error: roborock.0 (2735931) Failed to process undefined on robot undefined (unknown device model): TypeError: Cannot read properties of null (reading 'rrHomeId')
                          2025-08-20 06:57:40.762 - info: roborock.0 (2735931) MQTT initialized
                          2025-08-20 06:57:40.763 - error: roborock.0 (2735931) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          2025-08-20 06:57:40.764 - error: roborock.0 (2735931) unhandled promise rejection: this.homeData is not initialized. Initialize via getHomeData() first
                          2025-08-20 06:57:40.764 - error: roborock.0 (2735931) Error: this.homeData is not initialized. Initialize via getHomeData() first
                          2025-08-20 06:57:40.765 - error: roborock.0 (2735931) this.homeData is not initialized. Initialize via getHomeData() first
                          2025-08-20 06:57:40.779 - info: roborock.0 (2735931) terminating
                          2025-08-20 06:57:40.781 - warn: roborock.0 (2735931) Terminated (UNCAUGHT_EXCEPTION): Without reason
                          2025-08-20 06:57:40.843 - info: roborock.0 (2735931) MQTT connection established {"cmd":"connack","retain":false,"qos":0,"dup":false,"length":2,"topic":null,"payload":null,"sessionPresent":false,"returnCode":0}.
                          2025-08-20 06:57:41.282 - info: roborock.0 (2735931) terminating
                          2025-08-20 06:57:41.437 - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                          2025-08-20 06:57:41.437 - error: host.iobroker Caught by controller[1]: Error: this.homeData is not initialized. Initialize via getHomeData() first
                          2025-08-20 06:57:41.437 - error: host.iobroker Caught by controller[1]: at http_api.getDevices (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:179:10)
                          2025-08-20 06:57:41.438 - error: host.iobroker Caught by controller[1]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:62:39)
                          2025-08-20 06:57:41.438 - error: host.iobroker instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                          2025-08-20 06:57:41.438 - info: host.iobroker Restart adapter system.adapter.roborock.0 because enabled
                          2025-08-20 06:57:52.160 - info: host.iobroker "system.adapter.roborock.0" disabled
                          2025-08-20 06:58:14.994 - error: roborock.0 (2735952) adapter disabled
                          2025-08-20 06:58:15.040 - warn: roborock.0 (2735952) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                          2025-08-20 06:58:15.723 - error: host.iobroker instance system.adapter.roborock.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                          2025-08-20 06:58:15.723 - info: host.iobroker Do not restart adapter system.adapter.roborock.0 because disabled or deleted
                          • A Anderl 0
                            Moin!
                            Kann mir bitte jemand mit dem Fehler weiterhelfen? Lief bis gestern alles tadellos, und seit dem bekomm ich diese Fehler ins Log:
                            host.raspberrypi
                            2025-06-30 09:25:58.061	error	instance system.adapter.roborock.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            host.raspberrypi
                            2025-06-30 09:25:58.061	error	Caught by controller[0]: }
                            host.raspberrypi
                            2025-06-30 09:25:58.061	error	Caught by controller[0]: code: 'ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH'
                            host.raspberrypi
                            2025-06-30 09:25:58.061	error	Caught by controller[0]: reason: 'wrong final block length',
                            host.raspberrypi
                            2025-06-30 09:25:58.061	error	Caught by controller[0]: library: 'Provider routines',
                            host.raspberrypi
                            2025-06-30 09:25:58.060	error	Caught by controller[0]: at UDP.onMessage (node:dgram:944:8) {
                            host.raspberrypi
                            2025-06-30 09:25:58.060	error	Caught by controller[0]: at Socket.emit (node:domain:489:12)
                            host.raspberrypi
                            2025-06-30 09:25:58.060	error	Caught by controller[0]: at Socket.emit (node:events:518:28)
                            host.raspberrypi
                            2025-06-30 09:25:58.060	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33)
                            host.raspberrypi
                            2025-06-30 09:25:58.060	error	Caught by controller[0]: at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25)
                            host.raspberrypi
                            2025-06-30 09:25:58.059	error	Caught by controller[0]: at Decipheriv.final (node:internal/crypto/cipher:193:29)
                            host.raspberrypi
                            2025-06-30 09:25:58.055	error	Caught by controller[0]: Error: error:1C80006B:Provider routines::wrong final block length
                            roborock.0
                            2025-06-30 09:25:57.628	error	Exception-Code: ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH: error:1C80006B:Provider routines::wrong final block length
                            roborock.0
                            2025-06-30 09:25:57.627	error	Error: error:1C80006B:Provider routines::wrong final block length at Decipheriv.final (node:internal/crypto/cipher:193:29) at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33) at Socket.emit (node:events:518:28) at Socket.emit (node:domain:489:12) at UDP.onMessage (node:dgram:944:8)
                            roborock.0
                            2025-06-30 09:25:57.623	error	uncaught exception: error:1C80006B:Provider routines::wrong final block length
                            N Offline
                            N Offline
                            nu_81
                            schrieb am zuletzt editiert von nu_81
                            #873
                            @anderl-0
                            hab nun auf einmal die selben Fehler.
                            Hast du das Problem schon gelöst?
                            • N nu_81
                              @anderl-0
                              #874
                              @nu_81
                              Versionsnummern der üblichen Verdächtigen? Alternativ die Ausgabe von
                              iob diag
                              posten.
                              N 1 Antwort Letzte Antwort
                                @nu_81
                                iob diag
                                posten.
                                N Offline
                                N Offline
                                nu_81
                                #875
                                @thomas-braun said in Fehler Roborock - Adapter:
                                @nu_81
                                Welche Verdächtigen meinst du? Kann dir leider nicht folgen.
                                • N nu_81
                                  @nu_81
                                  #876
                                  @nu_81
                                  Versionen von nodejs, js-controller usw.
                                  Poste einfach die Ausgabe von
                                  iob diag
                                  da steht erstmal alles drin.
                                    @nu_81
                                    iob diag
                                    N Offline
                                    N Offline
                                    nu_81
                                    #877
                                    Hier der Log.
                                    Danke schonmal!
                                    Script v.2025-08-09
                                    *** BASE SYSTEM ***
                                     Static hostname: raspberrypi
                                           Icon name: computer
                                              Kernel: Linux 6.12.34+rpt-rpi-v8
                                        Architecture: arm64
                                    OS is similar to:
                                    Model           : Raspberry Pi 4 Model B Rev 1.1
                                    Docker          : false
                                    Virtualization  : none
                                    Kernel          : aarch64
                                    Userland        : 64 bit
                                    Systemuptime and Load:
                                     18:42:51 up  5:25,  3 users,  load average: 1.54, 0.91, 0.58
                                    CPU threads: 4
                                    *** LIFE CYCLE STATUS ***
                                    Operating System is the current Debian stable version codenamed 'bookworm'!
                                    *** RASPBERRY THROTTLING ***
                                    Current issues:
                                    Previously detected issues:
                                    ~ Under-voltage has occurred
                                    ~ Arm frequency capping has occurred
                                    ~ Throttling has occurred
                                    ~ Soft temperature limit has occurred
                                    *** TIME AND TIMEZONES ***
                                                   Local time: Sat 2025-08-23 18:42:51 CEST
                                               Universal time: Sat 2025-08-23 16:42:51 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    *** Users and Groups ***
                                    User that called 'iob diag':
                                    pihome
                                    HOME=/home/pihome
                                    GROUPS=pihome adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker uosserver
                                    iobroker
                                    HOME=/home/iobroker
                                    *** DISPLAY-SERVER SETUP ***
                                    Display-Server:         false
                                    Unit display-manager.service could not be found.
                                    Display-Manager:
                                    Desktop:
                                    Session:                tty
                                    *** MEMORY ***
                                    Mem:            4.0G        3.1G        281M         29M        696M        839M
                                    Swap:           209M        209M        704K
                                    Total:          4.2G        3.4G        282M
                                    Active iob-Instances:   29
                                             3796 M total memory
                                             2995 M used memory
                                             2252 M active memory
                                             1046 M inactive memory
                                              268 M free memory
                                               38 M buffer memory
                                              625 M swap cache
                                              199 M total swap
                                              199 M used swap
                                                0 M free swap
                                    top - 18:42:52 up  5:25,  3 users,  load average: 1.54, 0.91, 0.58
                                    Tasks: 252 total,   1 running, 251 sleeping,   0 stopped,   0 zombie
                                    %Cpu(s): 44.4 us, 22.2 sy,  0.0 ni, 33.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                    MiB Mem :   3796.9 total,    268.2 free,   2996.0 used,    664.5 buff/cache
                                    MiB Swap:    200.0 total,      0.7 free,    199.3 used.    800.9 avail Mem
                                    *** FAILED SERVICES ***
                                    0 loaded units listed.
                                    *** DMESG CRITICAL ERRORS ***
                                    No critical errors detected
                                    *** FILESYSTEM ***
                                    udev           devtmpfs  1.6G     0  1.6G   0% /dev
                                    tmpfs          tmpfs     760M  1.2M  759M   1% /run
                                    /dev/mmcblk0p2 ext4       29G   17G   11G  63% /
                                    tmpfs          tmpfs     1.9G  9.2M  1.9G   1% /dev/shm
                                    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                                    /dev/mmcblk0p1 vfat      510M   66M  445M  13% /boot/firmware
                                    tmpfs          tmpfs     380M   84K  380M   1% /run/user/1002
                                    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                                    [Sat Aug 23 13:17:08 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:5A:13:07 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=b69ad78b-02 rootfstype=ext4 fsck.repair=yes rootwait
                                    [Sat Aug 23 13:17:11 2025] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
                                    [Sat Aug 23 13:17:12 2025] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w.
                                    Show mounted filesystems:
                                    TARGET           SOURCE         FSTYPE OPTIONS
                                    /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                                    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                    /var:
                                    1.2G    /var/
                                    486M    /var/log
                                    380M    /var/log/journal/0350b7d3c8bd4b9ca7427777c909465d
                                    348M    /var/cache
                                    Archived and active journals take up 379.5M in the file system.
                                    /opt/iobroker/backups:
                                    54M     /opt/iobroker/backups/
                                    /opt/iobroker/iobroker-data:
                                    358M    /opt/iobroker/iobroker-data/
                                    269M    /opt/iobroker/iobroker-data/files
                                    68M     /opt/iobroker/iobroker-data/backup-objects
                                    48M     /opt/iobroker/iobroker-data/files/iot.admin
                                    47M     /opt/iobroker/iobroker-data/files/iot.admin/static/js
                                    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                                    24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
                                    15M     /opt/iobroker/iobroker-data/objects.jsonl
                                    8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
                                    8.6M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
                                    USB-Devices by-id:
                                    /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                                    *** ZigBee Settings ***
                                    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                                    zigbee.X
                                    Extended Pan ID:
                                    *** MASKED ***
                                    Pan ID:
                                    *** MASKED ***
                                    Channel:
                                    *** MASKED ***
                                    Network Key:
                                    *** MASKED ***
                                    *** NodeJS-Installation ***
                                    /usr/bin/nodejs         v20.19.4
                                    /usr/bin/node           v20.19.4
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    /usr/bin/corepack       0.32.0
                                    nodejs:
                                      Installed: 20.19.4-1nodesource1
                                      Candidate: 20.19.4-1nodesource1
                                      Version table:
                                     *** 20.19.4-1nodesource1 1001
                                            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                            100 /var/lib/dpkg/status
                                         20.19.3-1nodesource1 1001
                                         20.19.2-1nodesource1 1001
                                         20.19.1-1nodesource1 1001
                                         20.19.0-1nodesource1 1001
                                         20.18.3-1nodesource1 1001
                                         20.18.2-1nodesource1 1001
                                         20.18.1-1nodesource1 1001
                                         20.18.0-1nodesource1 1001
                                         20.17.0-1nodesource1 1001
                                         20.16.0-1nodesource1 1001
                                         20.15.1-1nodesource1 1001
                                         20.15.0-1nodesource1 1001
                                         20.14.0-1nodesource1 1001
                                         20.13.1-1nodesource1 1001
                                         20.13.0-1nodesource1 1001
                                         20.12.2-1nodesource1 1001
                                         20.12.1-1nodesource1 1001
                                         20.12.0-1nodesource1 1001
                                         20.11.1-1nodesource1 1001
                                         20.11.0-1nodesource1 1001
                                         20.10.0-1nodesource1 1001
                                         20.9.0-1nodesource1 1001
                                         20.8.1-1nodesource1 1001
                                         20.8.0-1nodesource1 1001
                                         20.7.0-1nodesource1 1001
                                         20.6.1-1nodesource1 1001
                                         20.6.0-1nodesource1 1001
                                         20.5.1-1nodesource1 1001
                                         20.5.0-1nodesource1 1001
                                         20.4.0-1nodesource1 1001
                                         20.3.1-1nodesource1 1001
                                         20.3.0-1nodesource1 1001
                                         20.2.0-1nodesource1 1001
                                         20.1.0-1nodesource1 1001
                                         20.0.0-1nodesource1 1001
                                         18.19.0+dfsg-6~deb12u2 500
                                         18.19.0+dfsg-6~deb12u1 500
                                    No problems detected
                                    Errors in npm tree: 0
                                    *** ioBroker-Installation ***
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Hosts:
                                    raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 3139)
                                    Core adapters versions
                                    admin:          7.6.17
                                    javascript:     8.9.2
                                    nodejs modules from github:     1
                                    +-- iobroker.tapo@0.4.8 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#615315d4bae5c77b153ac5067bdca8ba3ad3996f)
                                    Adapter State
                                    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                    + system.adapter.alarm.0                  : alarm                 : raspberrypi                              -  enabled
                                    + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                                      system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
                                    + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                                      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                                    + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
                                    + system.adapter.deyeidc.0                : deyeidc               : raspberrypi                              -  enabled, port: 8899
                                    + system.adapter.fahrplan.0               : fahrplan              : raspberrypi                              -  enabled
                                    + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
                                      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                                      system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
                                      system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
                                      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
                                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
                                    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                                    + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                                    + system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              -  enabled
                                    + system.adapter.mihome-vacuum.2          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
                                    + system.adapter.nuki-extended.0          : nuki-extended         : raspberrypi                              -  enabled
                                    + system.adapter.ph803w.0                 : ph803w                : raspberrypi                              -  enabled
                                      system.adapter.roborock.0               : roborock              : raspberrypi                              -  enabled
                                    + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                                      system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              -  enabled
                                    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                                    + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                                    + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
                                    + system.adapter.tapo.0                   : tapo                  : raspberrypi                              -  enabled
                                    + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                                    + system.adapter.telegram.1               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                                    + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                                    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                                      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
                                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                                      system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                                    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
                                    + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : raspberrypi                              -  enabled
                                    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                                    + instance is alive
                                    ioBroker-Repositories
                                    Active repo(s): stable
                                    Upgrade policy: none
                                    Installed ioBroker-Adapters
                                    Used repository: stable
                                    Adapter    "admin"        : 7.6.17   , installed 7.6.17
                                    Adapter    "alarm"        : 3.7.0    , installed 3.7.0
                                    Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
                                    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
                                    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
                                    Adapter    "cloud"        : 5.0.1    , installed 5.0.1
                                    Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
                                    Adapter    "denon"        : 1.15.12  , installed 1.15.12
                                    Adapter    "deyeidc"      : 0.2.0    , installed 0.2.0
                                    Adapter    "fahrplan"     : 1.4.1    , installed 1.4.1
                                    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
                                    Adapter    "ical"         : 1.16.2   , installed 1.16.1 [Updatable]
                                    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                                    Adapter    "iot"          : 3.3.0    , installed 3.3.0
                                    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                                    Controller "js-controller": 7.0.7    , installed 7.0.7
                                    Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
                                    Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
                                    Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
                                    Adapter    "ph803w"       : 1.2.0    , installed 1.2.0
                                    Adapter    "roborock"     : 0.6.18   , installed 0.6.18
                                    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                                    Adapter    "schoolfree"   : 1.1.10   , installed 1.1.9  [Updatable]
                                    Adapter    "shelly"       : 10.1.0   , installed 10.1.0
                                    Adapter    "shuttercontrol": 2.0.3   , installed 2.0.1  [Updatable]
                                    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                                    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                                    Adapter    "web"          : 7.0.8    , installed 7.0.8
                                    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                                    Adapter    "ws"           : 2.6.2    , installed 2.6.2
                                    Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
                                    Objects and States
                                    Objects:        8590
                                    States:         6628
                                    Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
                                    Hit:2 http://deb.debian.org/debian bookworm InRelease
                                    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                                    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                                    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                                    Reading package lists...
                                    Pending Updates: 0
                                    *** Listening Ports ***
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       448519     33748/iobroker.js-c
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       446004     33748/iobroker.js-c
                                    tcp        0      0 0.0.0.0:6789            0.0.0.0:*               LISTEN      1002       6488       914/slirp4netns
                                    tcp        0      0 0.0.0.0:8880            0.0.0.0:*               LISTEN      1002       6494       914/slirp4netns
                                    tcp        0      0 0.0.0.0:8881            0.0.0.0:*               LISTEN      1002       6496       914/slirp4netns
                                    tcp        0      0 0.0.0.0:8882            0.0.0.0:*               LISTEN      1002       6498       914/slirp4netns
                                    tcp        0      0 127.0.0.1:11002         0.0.0.0:*               LISTEN      1002       6361       730/discovery
                                    tcp        0      0 0.0.0.0:8444            0.0.0.0:*               LISTEN      1002       6492       914/slirp4netns
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6107       732/sshd: /usr/sbin
                                    tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        8720       856/pihole-FTL
                                    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      999        8055       856/pihole-FTL
                                    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      999        8056       856/pihole-FTL
                                    tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1002       6490       914/slirp4netns
                                    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       453005     34618/io.shelly.1
                                    tcp        0      0 0.0.0.0:11443           0.0.0.0:*               LISTEN      1002       6500       914/slirp4netns
                                    tcp6       0      0 :::3000                 :::*                    LISTEN      1001       448417     34233/io.fullybrows
                                    tcp6       0      0 :::51989                :::*                    LISTEN      1001       449536     34424/io.nuki-exten
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          6109       732/sshd: /usr/sbin
                                    tcp6       0      0 :::53                   :::*                    LISTEN      999        8722       856/pihole-FTL
                                    tcp6       0      0 :::80                   :::*                    LISTEN      999        8057       856/pihole-FTL
                                    tcp6       0      0 :::443                  :::*                    LISTEN      999        8058       856/pihole-FTL
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       446157     33776/io.admin.0
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       452363     34755/io.web.0
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        484        553/avahi-daemon: r
                                    udp        0      0 0.0.0.0:5514            0.0.0.0:*                           1002       6504       914/slirp4netns
                                    udp        0      0 0.0.0.0:3478            0.0.0.0:*                           1002       6502       914/slirp4netns
                                    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       452785     34516/io.shelly.0
                                    udp        0      0 255.255.255.255:10001   0.0.0.0:*                           1002       555009     730/discovery
                                    udp        0      0 0.0.0.0:10003           0.0.0.0:*                           1002       6506       914/slirp4netns
                                    udp        0      0 0.0.0.0:36782           0.0.0.0:*                           1002       552483     914/slirp4netns
                                    udp        0      0 0.0.0.0:55259           0.0.0.0:*                           1001       451740     34458/io.ph803w.0
                                    udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        8719       856/pihole-FTL
                                    udp        0      0 0.0.0.0:123             0.0.0.0:*                           999        9782       856/pihole-FTL
                                    udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1001       451251     34397/io.mihome-vac
                                    udp        0      0 0.0.0.0:33046           0.0.0.0:*                           104        486        553/avahi-daemon: r
                                    udp        0      0 192.168.2.109:33514     0.0.0.0:*                           1002       552649     730/discovery
                                    udp6       0      0 :::5353                 :::*                                104        485        553/avahi-daemon: r
                                    udp6       0      0 :::53                   :::*                                999        8721       856/pihole-FTL
                                    udp6       0      0 :::123                  :::*                                999        9783       856/pihole-FTL
                                    udp6       0      0 fe80::9e7d:2a5f:b7c:546 :::*                                0          7193       638/NetworkManager
                                    udp6       0      0 :::33351                :::*                                104        487        553/avahi-daemon: r
                                    2025-08-23 18:43:58.144  - error: roborock.0 (42090) Exception-Code: ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH: error:1C80006B:Provider routines::wrong final block length
                                    2025-08-23 18:43:58.191  - info: roborock.0 (42090) terminating
                                    2025-08-23 18:43:58.193  - warn: roborock.0 (42090) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    2025-08-23 18:43:58.851  - info: roborock.0 (42090) terminating
                                    2025-08-23 18:43:59.247  - error: host.raspberrypi Caught by controller[0]: Error: error:1C80006B:Provider routines::wrong final block length
                                    2025-08-23 18:43:59.247  - error: host.raspberrypi Caught by controller[0]:     at Decipheriv.final (node:internal/crypto/cipher:193:29)
                                    2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:     at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25)
                                    2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:     at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33)
                                    2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:     at Socket.emit (node:events:524:28)
                                    2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:     at Socket.emit (node:domain:489:12)
                                    2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:     at UDP.onMessage (node:dgram:951:8) {
                                    2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:   library: 'Provider routines',
                                    2025-08-23 18:43:59.249  - error: host.raspberrypi Caught by controller[0]:   reason: 'wrong final block length',
                                    2025-08-23 18:43:59.249  - error: host.raspberrypi Caught by controller[0]:   code: 'ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH'
                                    2025-08-23 18:43:59.249  - error: host.raspberrypi Caught by controller[0]: }
                                    2025-08-23 18:43:59.249  - error: host.raspberrypi instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                    2025-08-23 18:43:59.249  - info: host.raspberrypi Restart adapter system.adapter.roborock.0 because enabled
                                    2025-08-23 18:44:02.499  - info: tapo.0 (34846) Get camera Status failed
                                    2025-08-23 18:44:02.500  - info: tapo.0 (34846) No stok found for: 80211AE049E6EC914F17A219E950F4E9242DB387 this means the device is offline or connection lost. No update or commands possible
                                    2025-08-23 18:44:06.991  - info: tr-064.0 (34564) forEachConfiguredDevice: in GetSpecificHostEntry 1(Gioia/B8:94:E7:E7:C5:98) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                    2025-08-23 18:44:12.515  - info: tapo.0 (34846) Get camera Status failed
                                    2025-08-23 18:44:12.516  - info: tapo.0 (34846) No stok found for: 80211AE049E6EC914F17A219E950F4E9242DB387 this means the device is offline or connection lost. No update or commands possible
                                    • N nu_81
                                      Hier der Log.
                                      Danke schonmal!
                                      Script v.2025-08-09
                                      *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm64
                                      OS is similar to:
                                      Docker          : false
                                      Kernel          : aarch64
                                      Userland        : 64 bit
                                      CPU threads: 4
                                      Current issues:
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      pihome
                                      HOME=/home/pihome
                                      iobroker
                                      HOME=/home/iobroker
                                      Display-Manager:
                                      Desktop:
                                      Session:                tty
                                      *** MEMORY ***
                                               3796 M total memory
                                               2995 M used memory
                                                268 M free memory
                                                 38 M buffer memory
                                                625 M swap cache
                                                199 M total swap
                                                199 M used swap
                                                  0 M free swap
                                      *** FILESYSTEM ***
                                      /var:
                                      1.2G    /var/
                                      486M    /var/log
                                      348M    /var/cache
                                      USB-Devices by-id:
                                      zigbee.X
                                      Extended Pan ID:
                                      *** MASKED ***
                                      Pan ID:
                                      *** MASKED ***
                                      Channel:
                                      *** MASKED ***
                                      Network Key:
                                      *** MASKED ***
                                      /usr/bin/npm            10.8.2
                                      /usr/bin/npx            10.8.2
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Hosts:
                                      admin:          7.6.17
                                      javascript:     8.9.2
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        8590
                                      States:         6628
                                      Pending Updates: 0
                                      #878
                                      @nu_81 sagte in Neuer Adapter für Roborock-Staubsauger:
                                      Ich habe den Verdacht, das könnte mit nodejs zusammenhängen.
                                      Bring die drei Adapter auf Stand und dann ein
                                      iob nodejs-update
                                      B N 2 Antworten Letzte Antwort
                                        iob nodejs-update
                                        breaksrmine
                                        #879
                                        Beim Adapter 0.6.18 kommt beim Roborock QV 35A folgende Fehler.
                                        Steuern geht aber ohne Probleme
                                        roborock.0
                                        2025-08-23 19:17:02.540 warn Unsupported attribute: seq_type of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                        roborock.0
                                        2025-08-23 19:17:02.539 warn Unsupported attribute: exit_dock of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                        roborock.0
                                        2025-08-23 19:17:02.538 warn Unsupported attribute: cleaning_info of get_status with value [object Object]. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                        roborock.0
                                        2025-08-23 19:17:02.458 warn Unsupported attribute: last_clean_t of get_status with value 1755969220. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                        roborock.0
                                        2025-08-23 19:17:02.457 warn Unsupported attribute: switch_status of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                        roborock.0
                                        2025-08-23 19:17:02.416 warn Unsupported attribute: kct of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                        roborock.0
                                        2025-08-23 19:17:02.336 warn Unsupported attribute: common_status of get_status with value 2. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                        roborock.0
                                        2025-08-23 19:17:02.335 warn Unsupported attribute: dss of get_status with value 169. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                        roborock.0
                                        2025-08-23 19:17:02.335 warn Unsupported attribute: rss of get_status with value 2. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                        roborock.0
                                        2025-08-23 19:17:02.334 warn Unsupported attribute: extra_time of get_status with value 1860. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                        roborock.0
                                        2025-08-23 19:17:02.333 warn Unsupported attribute: clean_percent of get_status with value 45. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                        roborock.0
                                        2025-08-23 19:17:02.172 warn Unsupported attribute: charge_status of get_status with value 1. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                        roborock.0
                                        roborock.0
                                        2025-08-23 19:17:01.851 warn Unsupported attribute: in_warmup of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                        roborock.0
                                        2025-08-23 19:17:01.650 warn Unsupported attribute: water_shortage_status of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                        roborock.0
                                        2025-08-23 19:17:01.530 warn Unsupported attribute: mop_forbidden_enable of get_status with value 1. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                        roborock.0
                                        2025-08-23 19:17:01.529 warn Unsupported attribute: water_box_carriage_status of get_status with value 1. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                        roborock.0
                                        2025-08-23 19:17:01.488 warn Unsupported attribute: water_box_mode of get_status with value 207. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                        roborock.0
                                        2025-08-23 19:17:01.287 warn Unsupported attribute: water_box_status of get_status with value 1. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                                          iob nodejs-update
                                          N Offline
                                          N Offline
                                          nu_81
                                          #880
                                          Hallo, habe das Update durchgeführt.
                                          Der Fehler bleibt jedoch leider.
                                          Script v.2025-08-09
                                          *** BASE SYSTEM ***
                                                 Icon name: computer
                                              Architecture: arm64
                                          OS is similar to:
                                          Docker          : false
                                          Kernel          : aarch64
                                          Userland        : 64 bit
                                           11:31:58 up 11:00,  2 users,  load average: 1.93, 0.82, 0.49
                                          CPU threads: 4
                                          Current issues:
                                                         Local time: Mon 2025-08-25 11:31:58 CEST
                                                     Universal time: Mon 2025-08-25 09:31:58 UTC
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          pihome
                                          HOME=/home/pihome
                                          iobroker
                                          HOME=/home/iobroker
                                          Display-Manager:
                                          Desktop:
                                          Session:                tty
                                          *** MEMORY ***
                                          Mem:            4.0G        3.4G         59M         25M        599M        542M
                                          Swap:           2.1G        452M        1.7G
                                          Total:          6.1G        3.9G        1.8G
                                          Active iob-Instances:   24
                                                   3796 M total memory
                                                   3280 M used memory
                                                   2278 M active memory
                                                   1257 M inactive memory
                                                     55 M free memory
                                                     35 M buffer memory
                                                    535 M swap cache
                                                   2047 M total swap
                                                    432 M used swap
                                                   1615 M free swap
                                          top - 11:31:58 up 11:00,  2 users,  load average: 1.93, 0.82, 0.49
                                          Tasks: 237 total,   1 running, 236 sleeping,   0 stopped,   0 zombie
                                          %Cpu(s): 14.3 us, 14.3 sy,  0.0 ni, 71.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                          MiB Mem :   3796.9 total,     52.2 free,   3283.9 used,    571.4 buff/cache
                                          MiB Swap:   2048.0 total,   1616.0 free,    432.0 used.    513.0 avail Mem
                                          *** FILESYSTEM ***
                                          /dev/mmcblk0p2 ext4       29G   19G  8.9G  68% /
                                          tmpfs          tmpfs     1.9G  6.3M  1.9G   1% /dev/shm
                                          [Mon Aug 25 00:31:18 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:5A:13:07 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=b69ad78b-02 rootfstype=ext4 fsck.repair=yes rootwait
                                          [Mon Aug 25 00:31:21 2025] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
                                          [Mon Aug 25 00:31:23 2025] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w.
                                          /var:
                                          2.8G    /var/
                                          476M    /var/log
                                          412M    /var/log/journal/0350b7d3c8bd4b9ca7427777c909465d
                                          172M    /var/lib
                                          Archived and active journals take up 411.5M in the file system.
                                          15M     /opt/iobroker/backups/
                                          16M     /opt/iobroker/iobroker-data/objects.jsonl
                                          USB-Devices by-id:
                                          zigbee.X
                                          Extended Pan ID:
                                          *** MASKED ***
                                          Pan ID:
                                          *** MASKED ***
                                          Channel:
                                          *** MASKED ***
                                          Network Key:
                                          *** MASKED ***
                                          /usr/bin/nodejs         v22.18.0
                                          /usr/bin/node           v22.18.0
                                          /usr/bin/npm            10.9.3
                                          /usr/bin/npx            10.9.3
                                          /usr/bin/corepack       0.33.0
                                          nodejs:
                                            Installed: 22.18.0-1nodesource1
                                            Candidate: 22.18.0-1nodesource1
                                            Version table:
                                           *** 22.18.0-1nodesource1 1001
                                                  500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                                               22.17.1-1nodesource1 1001
                                               22.17.0-1nodesource1 1001
                                               22.16.0-1nodesource1 1001
                                               22.15.1-1nodesource1 1001
                                               22.15.0-1nodesource1 1001
                                               22.14.0-1nodesource1 1001
                                               22.13.1-1nodesource1 1001
                                               22.13.0-1nodesource1 1001
                                               22.12.0-1nodesource1 1001
                                               22.11.0-1nodesource1 1001
                                               22.10.0-1nodesource1 1001
                                               22.9.0-1nodesource1 1001
                                               22.8.0-1nodesource1 1001
                                               22.7.0-1nodesource1 1001
                                               22.6.0-1nodesource1 1001
                                               22.5.1-1nodesource1 1001
                                               22.5.0-1nodesource1 1001
                                               22.4.1-1nodesource1 1001
                                               22.4.0-1nodesource1 1001
                                               22.3.0-1nodesource1 1001
                                               22.2.0-1nodesource1 1001
                                               22.1.0-1nodesource1 1001
                                               22.0.0-1nodesource1 1001
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Hosts:
                                          raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 39639)
                                          admin:          7.6.17
                                          javascript:     8.9.2
                                          Adapter State
                                            system.adapter.denon.0                  : denon                 : raspberrypi                              - disabled
                                            system.adapter.deyeidc.0                : deyeidc               : raspberrypi                              - disabled, port: 8899
                                            system.adapter.mihome-vacuum.2          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
                                            system.adapter.scenes.0                 : scenes                : raspberrypi                              - disabled
                                            system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
                                          + instance is alive
                                          Adapter    "ical"         : 1.16.2   , installed 1.16.2
                                          Adapter    "schoolfree"   : 1.1.10   , installed 1.1.10
                                          Adapter    "shuttercontrol": 2.0.3   , installed 2.0.3
                                          Objects and States
                                          Objects:        8782
                                          States:         6752
                                          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                                          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                                          Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                                          Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                                          Pending Updates: 0
                                          tcp        0      0 0.0.0.0:6789            0.0.0.0:*               LISTEN      1002       6662       920/slirp4netns
                                          tcp        0      0 0.0.0.0:8882            0.0.0.0:*               LISTEN      1002       6672       920/slirp4netns
                                          tcp        0      0 0.0.0.0:8881            0.0.0.0:*               LISTEN      1002       6670       920/slirp4netns
                                          tcp        0      0 0.0.0.0:8880            0.0.0.0:*               LISTEN      1002       6668       920/slirp4netns
                                          tcp        0      0 0.0.0.0:8444            0.0.0.0:*               LISTEN      1002       6666       920/slirp4netns
                                          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      999        9512       863/pihole-FTL
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6540       739/sshd: /usr/sbin
                                          tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        924        863/pihole-FTL
                                          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      999        9513       863/pihole-FTL
                                          tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1002       6664       920/slirp4netns
                                          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       15151      2682/io.shelly.1
                                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       930        716/iobroker.js-con
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5702       716/iobroker.js-con
                                          tcp        0      0 0.0.0.0:11443           0.0.0.0:*               LISTEN      1002       6674       920/slirp4netns
                                          tcp        0      0 127.0.0.1:11002         0.0.0.0:*               LISTEN      1002       5094       737/discovery
                                          tcp6       0      0 :::3000                 :::*                    LISTEN      1001       14447      2186/io.fullybrowse
                                          tcp6       0      0 :::51989                :::*                    LISTEN      1001       11994      2364/io.nuki-extend
                                          tcp6       0      0 :::80                   :::*                    LISTEN      999        9514       863/pihole-FTL
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          6542       739/sshd: /usr/sbin
                                          tcp6       0      0 :::53                   :::*                    LISTEN      999        926        863/pihole-FTL
                                          tcp6       0      0 :::443                  :::*                    LISTEN      999        9515       863/pihole-FTL
                                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       15445      2584/io.web.0
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7048       907/io.admin.0
                                          udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        923        863/pihole-FTL
                                          udp        0      0 0.0.0.0:123             0.0.0.0:*                           999        24743      863/pihole-FTL
                                          udp        0      0 0.0.0.0:60493           0.0.0.0:*                           1001       11997      2376/io.ph803w.0
                                          udp        0      0 0.0.0.0:58631           0.0.0.0:*                           1002       675873     920/slirp4netns
                                          udp        0      0 0.0.0.0:5514            0.0.0.0:*                           1002       6678       920/slirp4netns
                                          udp        0      0 0.0.0.0:3478            0.0.0.0:*                           1002       6676       920/slirp4netns
                                          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       14856      2439/io.shelly.0
                                          udp        0      0 255.255.255.255:10001   0.0.0.0:*                           1002       868410     737/discovery
                                          udp        0      0 0.0.0.0:10003           0.0.0.0:*                           1002       6680       920/slirp4netns
                                          udp        0      0 192.168.2.109:38760     0.0.0.0:*                           1002       868411     737/discovery
                                          udp6       0      0 :::53                   :::*                                999        925        863/pihole-FTL
                                          udp6       0      0 :::123                  :::*                                999        23343      863/pihole-FTL
                                          udp6       0      0 :::59687                :::*                                1002       675872     920/slirp4netns
                                          udp6       0      0 fe80::9e7d:2a5f:b7c:546 :::*                                0          849        644/NetworkManager
                                          udp6       0      0 :::54266                :::*                                1002       675860     920/slirp4netns
                                              at UDP.onMessage (node:dgram:988:8)
                                          2025-08-25 11:33:11.924  - error: roborock.0 (49238) Exception-Code: ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH: error:1C80006B:Provider routines::wrong final block length
                                          2025-08-25 11:33:11.957  - info: roborock.0 (49238) terminating
                                          2025-08-25 11:33:11.959  - warn: roborock.0 (49238) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                          2025-08-25 11:33:12.555  - error: host.raspberrypi Caught by controller[0]: Error: error:1C80006B:Provider routines::wrong final block length
                                          2025-08-25 11:33:12.556  - error: host.raspberrypi Caught by controller[0]:     at Decipheriv.final (node:internal/crypto/cipher:184:29)
                                          2025-08-25 11:33:12.556  - error: host.raspberrypi Caught by controller[0]:     at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25)
                                          2025-08-25 11:33:12.556  - error: host.raspberrypi Caught by controller[0]:     at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33)
                                          2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:     at Socket.emit (node:events:518:28)
                                          2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:     at Socket.emit (node:domain:489:12)
                                          2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:     at UDP.onMessage (node:dgram:988:8) {
                                          2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:   library: 'Provider routines',
                                          2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:   reason: 'wrong final block length',
                                          2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:   code: 'ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH'
                                          2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]: }
                                          2025-08-25 11:33:12.557  - error: host.raspberrypi instance system.adapter.roborock.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                          2025-08-25 11:33:12.558  - info: host.raspberrypi Restart adapter system.adapter.roborock.0 because enabled
                                          2025-08-25 11:33:18.253  - info: tapo.0 (2625) Get camera Status failed
                                          2025-08-25 11:33:18.254  - info: tapo.0 (2625) No stok found for: 80211AE049E6EC914F17A219E950F4E9242DB387 this means the device is offline or connection lost. No update or commands possible
                                          2025-08-25 11:33:28.273  - info: tapo.0 (2625) Get camera Status failed
                                          2025-08-25 11:33:28.274  - info: tapo.0 (2625) No stok found for: 80211AE049E6EC914F17A219E950F4E9242DB387 this means the device is offline or connection lost. No update or commands possible
                                          N Ro75R 2 Antworten Letzte Antwort
