  4. Neuer Adapter für Roborock-Staubsauger
    6.7k
1.1k Beiträge 155 Kommentatoren 482.8k Aufrufe 138 Beobachtet
  • N nu_81
    Hallo, habe das Update durchgeführt.
    Der Fehler bleibt jedoch leider.
    Script v.2025-08-09
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.12.34+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     11:31:58 up 11:00,  2 users,  load average: 1.93, 0.82, 0.49
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    ~ Throttling has occurred
    ~ Soft temperature limit has occurred
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2025-08-25 11:31:58 CEST
               Universal time: Mon 2025-08-25 09:31:58 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pihome
    HOME=/home/pihome
    GROUPS=pihome adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker uosserver
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            4.0G        3.4G         59M         25M        599M        542M
    Swap:           2.1G        452M        1.7G
    Total:          6.1G        3.9G        1.8G
    Active iob-Instances:   24
             3796 M total memory
             3280 M used memory
             2278 M active memory
             1257 M inactive memory
               55 M free memory
               35 M buffer memory
              535 M swap cache
             2047 M total swap
              432 M used swap
             1615 M free swap
    top - 11:31:58 up 11:00,  2 users,  load average: 1.93, 0.82, 0.49
    Tasks: 237 total,   1 running, 236 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 14.3 us, 14.3 sy,  0.0 ni, 71.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3796.9 total,     52.2 free,   3283.9 used,    571.4 buff/cache
    MiB Swap:   2048.0 total,   1616.0 free,    432.0 used.    513.0 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     760M  1.2M  759M   1% /run
    /dev/mmcblk0p2 ext4       29G   19G  8.9G  68% /
    tmpfs          tmpfs     1.9G  6.3M  1.9G   1% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   66M  445M  13% /boot/firmware
    tmpfs          tmpfs     380M   84K  380M   1% /run/user/1002
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Mon Aug 25 00:31:18 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:5A:13:07 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=b69ad78b-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Mon Aug 25 00:31:21 2025] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
    [Mon Aug 25 00:31:23 2025] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.8G    /var/
    476M    /var/log
    412M    /var/log/journal/0350b7d3c8bd4b9ca7427777c909465d
    172M    /var/lib
    Archived and active journals take up 411.5M in the file system.
    /opt/iobroker/backups:
    15M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    358M    /opt/iobroker/iobroker-data/
    269M    /opt/iobroker/iobroker-data/files
    68M     /opt/iobroker/iobroker-data/backup-objects
    48M     /opt/iobroker/iobroker-data/files/iot.admin
    47M     /opt/iobroker/iobroker-data/files/iot.admin/static/js
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
    16M     /opt/iobroker/iobroker-data/objects.jsonl
    8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
    8.6M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
    *** ZigBee Settings ***
    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.18.0
    /usr/bin/node           v22.18.0
    /usr/bin/npm            10.9.3
    /usr/bin/npx            10.9.3
    /usr/bin/corepack       0.33.0
    nodejs:
      Installed: 22.18.0-1nodesource1
      Candidate: 22.18.0-1nodesource1
      Version table:
     *** 22.18.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
         18.19.0+dfsg-6~deb12u1 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 39639)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.6.17
    javascript:     8.9.2
    nodejs modules from github:     1
    +-- iobroker.tapo@0.4.8 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#615315d4bae5c77b153ac5067bdca8ba3ad3996f)
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.alarm.0                  : alarm                 : raspberrypi                              -  enabled
    + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
    + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
      system.adapter.denon.0                  : denon                 : raspberrypi                              - disabled
      system.adapter.deyeidc.0                : deyeidc               : raspberrypi                              - disabled, port: 8899
    + system.adapter.fahrplan.0               : fahrplan              : raspberrypi                              -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              -  enabled
      system.adapter.mihome-vacuum.2          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
    + system.adapter.nuki-extended.0          : nuki-extended         : raspberrypi                              -  enabled
    + system.adapter.ph803w.0                 : ph803w                : raspberrypi                              -  enabled
      system.adapter.roborock.0               : roborock              : raspberrypi                              -  enabled
      system.adapter.scenes.0                 : scenes                : raspberrypi                              - disabled
      system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
    + system.adapter.tapo.0                   : tapo                  : raspberrypi                              -  enabled
    + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
      system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
    + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.6.17   , installed 7.6.17
    Adapter    "alarm"        : 3.7.0    , installed 3.7.0
    Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
    Adapter    "cloud"        : 5.0.1    , installed 5.0.1
    Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
    Adapter    "denon"        : 1.15.12  , installed 1.15.12
    Adapter    "deyeidc"      : 0.2.0    , installed 0.2.0
    Adapter    "fahrplan"     : 1.4.1    , installed 1.4.1
    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
    Adapter    "ical"         : 1.16.2   , installed 1.16.2
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
    Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
    Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
    Adapter    "ph803w"       : 1.2.0    , installed 1.2.0
    Adapter    "roborock"     : 0.6.18   , installed 0.6.18
    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
    Adapter    "schoolfree"   : 1.1.10   , installed 1.1.10
    Adapter    "shelly"       : 10.1.0   , installed 10.1.0
    Adapter    "shuttercontrol": 2.0.3   , installed 2.0.3
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
    Objects and States
    Objects:        8782
    States:         6752
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:6789            0.0.0.0:*               LISTEN      1002       6662       920/slirp4netns
    tcp        0      0 0.0.0.0:8882            0.0.0.0:*               LISTEN      1002       6672       920/slirp4netns
    tcp        0      0 0.0.0.0:8881            0.0.0.0:*               LISTEN      1002       6670       920/slirp4netns
    tcp        0      0 0.0.0.0:8880            0.0.0.0:*               LISTEN      1002       6668       920/slirp4netns
    tcp        0      0 0.0.0.0:8444            0.0.0.0:*               LISTEN      1002       6666       920/slirp4netns
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      999        9512       863/pihole-FTL
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6540       739/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        924        863/pihole-FTL
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      999        9513       863/pihole-FTL
    tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1002       6664       920/slirp4netns
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       15151      2682/io.shelly.1
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       930        716/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5702       716/iobroker.js-con
    tcp        0      0 0.0.0.0:11443           0.0.0.0:*               LISTEN      1002       6674       920/slirp4netns
    tcp        0      0 127.0.0.1:11002         0.0.0.0:*               LISTEN      1002       5094       737/discovery
    tcp6       0      0 :::3000                 :::*                    LISTEN      1001       14447      2186/io.fullybrowse
    tcp6       0      0 :::51989                :::*                    LISTEN      1001       11994      2364/io.nuki-extend
    tcp6       0      0 :::80                   :::*                    LISTEN      999        9514       863/pihole-FTL
    tcp6       0      0 :::22                   :::*                    LISTEN      0          6542       739/sshd: /usr/sbin
    tcp6       0      0 :::53                   :::*                    LISTEN      999        926        863/pihole-FTL
    tcp6       0      0 :::443                  :::*                    LISTEN      999        9515       863/pihole-FTL
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       15445      2584/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7048       907/io.admin.0
    udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        923        863/pihole-FTL
    udp        0      0 0.0.0.0:123             0.0.0.0:*                           999        24743      863/pihole-FTL
    udp        0      0 0.0.0.0:60493           0.0.0.0:*                           1001       11997      2376/io.ph803w.0
    udp        0      0 0.0.0.0:58631           0.0.0.0:*                           1002       675873     920/slirp4netns
    udp        0      0 0.0.0.0:5514            0.0.0.0:*                           1002       6678       920/slirp4netns
    udp        0      0 0.0.0.0:3478            0.0.0.0:*                           1002       6676       920/slirp4netns
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       14856      2439/io.shelly.0
    udp        0      0 255.255.255.255:10001   0.0.0.0:*                           1002       868410     737/discovery
    udp        0      0 0.0.0.0:10003           0.0.0.0:*                           1002       6680       920/slirp4netns
    udp        0      0 192.168.2.109:38760     0.0.0.0:*                           1002       868411     737/discovery
    udp6       0      0 :::53                   :::*                                999        925        863/pihole-FTL
    udp6       0      0 :::123                  :::*                                999        23343      863/pihole-FTL
    udp6       0      0 :::59687                :::*                                1002       675872     920/slirp4netns
    udp6       0      0 fe80::9e7d:2a5f:b7c:546 :::*                                0          849        644/NetworkManager
    udp6       0      0 :::54266                :::*                                1002       675860     920/slirp4netns
        at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25)
        at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33)
        at Socket.emit (node:events:518:28)
        at Socket.emit (node:domain:489:12)
        at UDP.onMessage (node:dgram:988:8)
    2025-08-25 11:33:11.924  - error: roborock.0 (49238) Exception-Code: ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH: error:1C80006B:Provider routines::wrong final block length
    2025-08-25 11:33:11.957  - info: roborock.0 (49238) terminating
    2025-08-25 11:33:11.959  - warn: roborock.0 (49238) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2025-08-25 11:33:12.555  - error: host.raspberrypi Caught by controller[0]: Error: error:1C80006B:Provider routines::wrong final block length
    2025-08-25 11:33:12.556  - error: host.raspberrypi Caught by controller[0]:     at Decipheriv.final (node:internal/crypto/cipher:184:29)
    2025-08-25 11:33:12.556  - error: host.raspberrypi Caught by controller[0]:     at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25)
    2025-08-25 11:33:12.556  - error: host.raspberrypi Caught by controller[0]:     at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33)
    2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:     at Socket.emit (node:events:518:28)
    2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:     at Socket.emit (node:domain:489:12)
    2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:     at UDP.onMessage (node:dgram:988:8) {
    2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:   library: 'Provider routines',
    2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:   reason: 'wrong final block length',
    2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:   code: 'ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH'
    2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]: }
    2025-08-25 11:33:12.557  - error: host.raspberrypi instance system.adapter.roborock.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2025-08-25 11:33:12.558  - info: host.raspberrypi Restart adapter system.adapter.roborock.0 because enabled
    2025-08-25 11:33:18.253  - info: tapo.0 (2625) Get camera Status failed
    2025-08-25 11:33:18.254  - info: tapo.0 (2625) No stok found for: 80211AE049E6EC914F17A219E950F4E9242DB387 this means the device is offline or connection lost. No update or commands possible
    2025-08-25 11:33:28.273  - info: tapo.0 (2625) Get camera Status failed
    2025-08-25 11:33:28.274  - info: tapo.0 (2625) No stok found for: 80211AE049E6EC914F17A219E950F4E9242DB387 this means the device is offline or connection lost. No update or commands possible
    N Offline
    N Offline
    nu_81
    #881
    @nu_81 Hallo, hat jemand hierzu noch eine Idee?
    Danke euch schonmal
    • N nu_81
      Script v.2025-08-09
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pihome
      HOME=/home/pihome
      iobroker
      HOME=/home/iobroker
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
               3796 M total memory
               3280 M used memory
                 55 M free memory
                 35 M buffer memory
                535 M swap cache
               2047 M total swap
                432 M used swap
               1615 M free swap
      *** FILESYSTEM ***
      /var:
      2.8G    /var/
      476M    /var/log
      172M    /var/lib
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.9.3
      /usr/bin/npx            10.9.3
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.6.17
      javascript:     8.9.2
      Adapter State
      + instance is alive
      Objects and States
      Objects:        8782
      States:         6752
      Pending Updates: 0
      Ro75R Offline
      Ro75R Offline
      Ro75
      #882
      @nu_81 sagte in Neuer Adapter für Roborock-Staubsauger:
      Previously detected issues: ~ Under-voltage has occurred ~ Arm frequency capping has occurred ~ Throttling has occurred ~ Soft temperature limit has occurred
      Originalnetzteil verwenden - kein Ladegerät! Sorge für gute Kühlung.
      Ro75.
      N 1 Antwort Letzte Antwort
      • D3ltoroxpD Offline
        D3ltoroxpD Offline
        D3ltoroxp
        #883
        ich kann leider vom Adapter keine DP abgreifen, der mit den Status der Station anzeigt. Tank voll, leer usw. Hab den roborock Qrevo Edge S5A + Station.
        • Ro75R Ro75
          Ro75.
          N Offline
          N Offline
          nu_81
          #884
          @ro75
          Danke, ich benutze das Originalnetzteil.
          Das mit der Kühlung hatte ich schon gesehen und kümmere mich nun um ein anderes Gehäuse, bzw. um einen Lüfter.
          Das Problem mit der Kühlung verursacht aber doch nicht das Problem am Adapter, oder?!
            D3ltoroxpD Offline
            D3ltoroxp
            #885
            Ich sehe auch grad, er connected gar nicht mehr mit dem Sauger. Das ist neu, es ging mal.
            roborock.0
            2025-09-01 18:08:41.980	info	terminating
            roborock.0
            2025-09-01 18:08:41.657	info	MQTT connection established {"cmd":"connack","retain":false,"qos":0,"dup":false,"length":2,"topic":null,"payload":null,"sessionPresent":false,"returnCode":0}.
            roborock.0
            2025-09-01 18:08:41.478	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
            roborock.0
            2025-09-01 18:08:41.477	info	terminating
            roborock.0
            2025-09-01 18:08:41.468	error	this.homeData is not initialized. Initialize via updateHomeData() first
            roborock.0
            2025-09-01 18:08:41.467	error	Error: this.homeData is not initialized. Initialize via updateHomeData() first at http_api.getDevices (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:192:10) at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:112:39)
            roborock.0
            2025-09-01 18:08:41.464	error	unhandled promise rejection: this.homeData is not initialized. Initialize via updateHomeData() first
            roborock.0
            2025-09-01 18:08:41.463	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            roborock.0
            2025-09-01 18:08:41.462	info	MQTT initialized
            roborock.0
            2025-09-01 18:08:41.418	error	No homeId found
            roborock.0
            2025-09-01 18:08:41.417	error	failed to get getHomeDetail: invalid token
            • D3ltoroxpD D3ltoroxp
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              N Offline
              N Offline
              nu_81
              #886
              Habe den Adapter komplett entfernt und neu installiert.
              Der Fehler bleibt leider.
              Jemand noch eine Idee?
              host.raspberrypi
              2025-09-01 20:11:10.015	info	Restart adapter system.adapter.roborock.0 because enabled
              host.raspberrypi
              2025-09-01 20:11:10.015	error	instance system.adapter.roborock.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.raspberrypi
              2025-09-01 20:11:10.015	error	Caught by controller[0]: }
              host.raspberrypi
              2025-09-01 20:11:10.015	error	Caught by controller[0]: code: 'ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH'
              host.raspberrypi
              2025-09-01 20:11:10.015	error	Caught by controller[0]: reason: 'wrong final block length',
              host.raspberrypi
              2025-09-01 20:11:10.015	error	Caught by controller[0]: library: 'Provider routines',
              host.raspberrypi
              2025-09-01 20:11:10.015	error	Caught by controller[0]: at UDP.onMessage (node:dgram:988:8) {
              host.raspberrypi
              2025-09-01 20:11:10.014	error	Caught by controller[0]: at Socket.emit (node:domain:489:12)
              host.raspberrypi
              2025-09-01 20:11:10.014	error	Caught by controller[0]: at Socket.emit (node:events:518:28)
              host.raspberrypi
              2025-09-01 20:11:10.014	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33)
              host.raspberrypi
              2025-09-01 20:11:10.014	error	Caught by controller[0]: at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25)
              host.raspberrypi
              2025-09-01 20:11:10.014	error	Caught by controller[0]: at Decipheriv.final (node:internal/crypto/cipher:184:29)
              host.raspberrypi
              2025-09-01 20:11:10.014	error	Caught by controller[0]: Error: error:1C80006B:Provider routines::wrong final block length
              roborock.0
              2025-09-01 20:11:09.673	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
              roborock.0
              2025-09-01 20:11:09.671	info	terminating
              roborock.0
              2025-09-01 20:11:09.641	error	Exception-Code: ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH: error:1C80006B:Provider routines::wrong final block length
              roborock.0
              2025-09-01 20:11:09.641	error	Error: error:1C80006B:Provider routines::wrong final block length at Decipheriv.final (node:internal/crypto/cipher:184:29) at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33) at Socket.emit (node:events:518:28) at Socket.emit (node:domain:489:12) at UDP.onMessage (node:dgram:988:8)
              roborock.0
              2025-09-01 20:11:09.640	error	uncaught exception: error:1C80006B:Provider routines::wrong final block length
              roborock.0
              2025-09-01 20:11:07.212	info	MQTT initialized
              roborock.0
              2025-09-01 20:11:05.656	info	Starting adapter. This might take a few minutes depending on your setup. Please wait.
              roborock.0
              2025-09-01 20:11:05.626	info	starting. Version 0.6.18 in /opt/iobroker/node_modules/iobroker.roborock, node: v22.18.0, js-controller: 7.0.7
              • N nu_81
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                roborock.0
                roborock.0
                roborock.0
                roborock.0
                roborock.0
                roborock.0
                roborock.0
                roborock.0
                N Offline
                N Offline
                nu_81
                #887
                @nu_81 said in Neuer Adapter für Roborock-Staubsauger:
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                roborock.0
                roborock.0
                roborock.0
                roborock.0
                roborock.0
                roborock.0
                roborock.0
                roborock.0
                Hab es durch iÍnstallation des dev_ts gelöst.
                • N nu_81
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  N Offline
                  N Offline
                  nu_81
                  #888
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  Hab es durch Installation des dev_ts gelöst.
                  • N Offline
                    N Offline
                    Nachtfuchs
                    #889
                    Hallo Gemeinde,
                    wir sind seit gestern Besitzer des QRevo Slim und nun soll dieser natürlich auch mit dem ioBroker sprechen. Adapter aus Adapterliste ausgewählt, aber er wirft diese Fehlermeldungen aus - kennt das jemand?
                    Dank euch
                    Thomas BraunT B 2 Antworten Letzte Antwort
                    • N Nachtfuchs
                      Hallo Gemeinde,
                      Dank euch
                      #890
                      @nachtfuchs
                      iob stop
                      iob fix
                      iob start
                      Und bring deine nodejs-Installation in Ordnung. Keine aktuelle Version verwendet npm 10.7.0.
                      • N Offline
                        N Offline
                        Nachtfuchs
                        #891
                        @Thomas-Braun
                        Mal wieder unglaublicher support, DANKE!
                        Und danke für den Hinweis, werde mich mal am Wochenende an Dein nodejs Fixer Skript machen.
                        • N Offline
                          N Offline
                          Nachtfuchs
                          schrieb am zuletzt editiert von Nachtfuchs
                          #892
                          Hallo Gemeinde,
                          ich tauche tiefer in den Adapter ein und habe eine Frage:
                          Setting
                          Wir haben im Anbau ein Badezimmer und Wohn-/Schlafzimmer. Ersteres mit Fliesen, letztere mit Parkett.
                          Ich habe dem QRevo Slim in der App zwei Programme geschrieben:
                          1. im Badezimmer wischen, den Rest saugen
                          2. die gesamte Fläche mit wenig Wasser wischen, also Fliesen und Parkett
                          Im Badezimmer haben wir den HMIP WRC 6, ein Schalter ist "Staubsauger" - dieser führt dazu, dass
                          a) das Sonos ausgeht (Pause button = wahr)
                          b) der Staubsauger angeht mit Programm 1) und
                          c) nach einer Verzögerung das Licht ausgeht
                          1. soll nur sehr selektiv ausgeführt werden; diesen würde ich dann über einen anderen Taster auf dem WRC 6 steuern.
                          Die Idee war nun, in den Datenpunkt "StartProgram" das Programm mit dem Namen "Saug+Wi Anbau" (Programm 1) zu schreiben, damit er genau das tut.
                          Dieses möchte ich über das angefügte Script erreichen, aber wenn ich auslöse, beginnt er mit der Voll-Reinigung, sprich Wischen überall.
                          Ziel wäre wie gesagt, mittels des anderen Tasters auch "Wi Anbau" (2) zu steuern.
                          Wenn ich hingegen das Programm auf der IOBroker Oberfläche setze, so reinigt er richtig.
                          Ich hatte in einer anderen script-Version auch erst das Programm geschrieben und dann den Datenpunkt "app_start" auf TRUE gesetzt, im Sinne erst Programm mitteilen, dann starten - hat leider auch nicht funktioniert.
                          Wo habe ich den Denkfehler?
                          Dank euch
                          • N Nachtfuchs
                            Hallo Gemeinde,
                            Dank euch
                            bjappler
                            schrieb am zuletzt editiert von bjappler
                            #893
                            @nachtfuchs
                            ich bekomme auch eine ähnliche Fehlermeldung.
                            $ iobroker add roborock --host 43f86e6ffd35
                            NPM version: 10.8.2Installing iobroker.roborock@0.6.18... (System call)
                            npm error code EBADENGINEnpm error engine Unsupported enginenpm error engine Not compatible with your version of node/npm: iobroker.roborock@0.6.18npm error notsup Not compatible with your version of node/npm: iobroker.roborock@0.6.18npm error notsup Required: {"node":">= 20"}npm error notsup Actual: {"npm":"10.8.2","node":"v18.20.4"}npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2025-09-11T13_59_37_295Z-debug-0.loghost.43f86e6ffd35 Cannot install iobroker.roborock@0.6.18: 1
                            ERROR: Process exited with code 25
                            Das System ist ein Dockerimage der Version v9.1.2. Doch auch mit Version V10 und der aktuellsten V11 wird die gleiche Fehlermeldung angezeigt (https://github.com/buanet/ioBroker.docker/releases).
                            Leider kann ich die Kommandos
                            @thomas-braun said in Neuer Adapter für Roborock-Staubsauger:
                            @nachtfuchs
                            iob stop
                            iob fix
                            iob start
                            nicht im Container nicht ausführen, dann kommt die Meldung "The execution of this command is blocked as your ioBroker is running inside a Docker container!"
                            Kennt sich jemand hiermit aus?
                            • B bjappler
                              @nachtfuchs
                              @nachtfuchs
                              iob stop
                              iob fix
                              iob start
                              #894
                              @bjappler sagte in Neuer Adapter für Roborock-Staubsauger:
                              Du hast da noch
                              "node":"v18.20.4"
                              installiert, der Adapter verlangt aber
                              Also nodejs sauber installieren/updaten.
                              Bzw. das akutelle Docker-Imager ausrollen.
                                D3ltoroxpD Offline
                                D3ltoroxp
                                #895
                                Habt ihr bei euch den Status euerer Station drin ?
                                • N Nachtfuchs
                                  Hallo Gemeinde,
                                  Setting
                                  Dank euch
                                  N Offline
                                  N Offline
                                  Nachtfuchs
                                  #896
                                  Verzeiht die Nachfrage,
                                  hat keiner eine Idee?
                                  Dank euch
                                  @nachtfuchs said in Neuer Adapter für Roborock-Staubsauger:
                                  Hallo Gemeinde,
                                  Setting
                                  Dank euch
                                  wolfi913W 1 Antwort Letzte Antwort
                                  • N Nachtfuchs
                                    Dank euch
                                    Hallo Gemeinde,
                                    Setting
                                    Dank euch
                                    wolfi913W Online
                                    wolfi913W Online
                                    wolfi913
                                    #897
                                    @nachtfuchs sagte in Neuer Adapter für Roborock-Staubsauger:
                                    Schau Dir mal mein Blockly hier an
                                    Das erstellt Dir für die in der App gespeicherten Programme jeweils einen Datenpunkt mit dem Du das jeweilige Programm starten kannst.
                                      samsungfreak
                                      #898
                                      ich habe seid ein paar Tage das Problem, dass der Roborock Adapter "rot" wird und die DPs nicht aktualisiert werden.
                                      Wenn ich den Adapter starte ist er für 5 Minuten "grün" ohne die DPs zu aktualsieren. Folgendes steht im Debug LOG:
                                      Hat jemand eine Idee, woran es liegt?
                                      M S 2 Antworten Letzte Antwort
                                      • S samsungfreak
                                        mx-driver
                                        #899
                                        @samsungfreak said in Neuer Adapter für Roborock-Staubsauger:
                                        Seit mein S8 ein Firmware update bekommen hat geht bei mir auch nix mehr.
                                        • Frederik BussF Offline
                                          Frederik Buss
                                          #900
                                          Ich habe mittlerweile eine HomeAssistant VM auf meinem Proxmox neben iobroker installiert und dort funktioniert der Saros10 vom Start weg. Dank HASS Adapter lässt der sich aus iobroker heraus wirklich gut steuern, mit Bildchen, Programme starten und allem drum und dran. Ich bin kein Freund davon die beiden Systeme parallel laufen zu haben, aber es kommen immer mehr Restriktionen (Roborock, Samsung, BMW, OttoWilde und keine Ahnung wer noch künftig dazu kommt). Immerhin es geht mit etwas einlesen, YouTube Tutorials schauen, Backups ziehen usw.
