  4. Neuer Adapter für Roborock-Staubsauger
1.1k Beiträge 155 Kommentatoren 513.6k Aufrufe 137 Beobachtet
  • A Anderl 0
    Moin!
    Kann mir bitte jemand mit dem Fehler weiterhelfen? Lief bis gestern alles tadellos, und seit dem bekomm ich diese Fehler ins Log:
    host.raspberrypi
    2025-06-30 09:25:58.061	error	instance system.adapter.roborock.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2025-06-30 09:25:58.061	error	Caught by controller[0]: }
    host.raspberrypi
    2025-06-30 09:25:58.061	error	Caught by controller[0]: code: 'ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH'
    host.raspberrypi
    2025-06-30 09:25:58.061	error	Caught by controller[0]: reason: 'wrong final block length',
    host.raspberrypi
    2025-06-30 09:25:58.061	error	Caught by controller[0]: library: 'Provider routines',
    host.raspberrypi
    2025-06-30 09:25:58.060	error	Caught by controller[0]: at UDP.onMessage (node:dgram:944:8) {
    host.raspberrypi
    2025-06-30 09:25:58.060	error	Caught by controller[0]: at Socket.emit (node:domain:489:12)
    host.raspberrypi
    2025-06-30 09:25:58.060	error	Caught by controller[0]: at Socket.emit (node:events:518:28)
    host.raspberrypi
    2025-06-30 09:25:58.060	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33)
    host.raspberrypi
    2025-06-30 09:25:58.060	error	Caught by controller[0]: at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25)
    host.raspberrypi
    2025-06-30 09:25:58.059	error	Caught by controller[0]: at Decipheriv.final (node:internal/crypto/cipher:193:29)
    host.raspberrypi
    2025-06-30 09:25:58.055	error	Caught by controller[0]: Error: error:1C80006B:Provider routines::wrong final block length
    roborock.0
    2025-06-30 09:25:57.628	error	Exception-Code: ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH: error:1C80006B:Provider routines::wrong final block length
    roborock.0
    2025-06-30 09:25:57.627	error	Error: error:1C80006B:Provider routines::wrong final block length at Decipheriv.final (node:internal/crypto/cipher:193:29) at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33) at Socket.emit (node:events:518:28) at Socket.emit (node:domain:489:12) at UDP.onMessage (node:dgram:944:8)
    roborock.0
    2025-06-30 09:25:57.623	error	uncaught exception: error:1C80006B:Provider routines::wrong final block length
    N
    N
    nu_81
    schrieb am zuletzt editiert von nu_81
    #873
    @anderl-0
    hab nun auf einmal die selben Fehler.
    Hast du das Problem schon gelöst?
    • N nu_81
      @anderl-0
      Thomas BraunT
      Thomas BraunT
      #874
      @nu_81
      Versionsnummern der üblichen Verdächtigen? Alternativ die Ausgabe von
      iob diag
      posten.
      N 1 Antwort Letzte Antwort
        @nu_81
        iob diag
        posten.
        N
        N
        nu_81
        #875
        @thomas-braun said in Fehler Roborock - Adapter:
        @nu_81
        Welche Verdächtigen meinst du? Kann dir leider nicht folgen.
        • N nu_81
          @nu_81
          Thomas BraunT
          Thomas BraunT
          #876
          @nu_81
          Versionen von nodejs, js-controller usw.
          Poste einfach die Ausgabe von
          iob diag
          da steht erstmal alles drin.
            @nu_81
            iob diag
            N
            N
            nu_81
            #877
            Hier der Log.
            Danke schonmal!
            Script v.2025-08-09
            *** BASE SYSTEM ***
             Static hostname: raspberrypi
                   Icon name: computer
                      Kernel: Linux 6.12.34+rpt-rpi-v8
                Architecture: arm64
            OS is similar to:
            Model           : Raspberry Pi 4 Model B Rev 1.1
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : 64 bit
            Systemuptime and Load:
             18:42:51 up  5:25,  3 users,  load average: 1.54, 0.91, 0.58
            CPU threads: 4
            *** LIFE CYCLE STATUS ***
            Operating System is the current Debian stable version codenamed 'bookworm'!
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            ~ Under-voltage has occurred
            ~ Arm frequency capping has occurred
            ~ Throttling has occurred
            ~ Soft temperature limit has occurred
            *** TIME AND TIMEZONES ***
                           Local time: Sat 2025-08-23 18:42:51 CEST
                       Universal time: Sat 2025-08-23 16:42:51 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            pihome
            HOME=/home/pihome
            GROUPS=pihome adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker uosserver
            iobroker
            HOME=/home/iobroker
            *** DISPLAY-SERVER SETUP ***
            Display-Server:         false
            Unit display-manager.service could not be found.
            Display-Manager:
            Desktop:
            Session:                tty
            *** MEMORY ***
            Mem:            4.0G        3.1G        281M         29M        696M        839M
            Swap:           209M        209M        704K
            Total:          4.2G        3.4G        282M
            Active iob-Instances:   29
                     3796 M total memory
                     2995 M used memory
                     2252 M active memory
                     1046 M inactive memory
                      268 M free memory
                       38 M buffer memory
                      625 M swap cache
                      199 M total swap
                      199 M used swap
                        0 M free swap
            top - 18:42:52 up  5:25,  3 users,  load average: 1.54, 0.91, 0.58
            Tasks: 252 total,   1 running, 251 sleeping,   0 stopped,   0 zombie
            %Cpu(s): 44.4 us, 22.2 sy,  0.0 ni, 33.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   3796.9 total,    268.2 free,   2996.0 used,    664.5 buff/cache
            MiB Swap:    200.0 total,      0.7 free,    199.3 used.    800.9 avail Mem
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** DMESG CRITICAL ERRORS ***
            No critical errors detected
            *** FILESYSTEM ***
            udev           devtmpfs  1.6G     0  1.6G   0% /dev
            tmpfs          tmpfs     760M  1.2M  759M   1% /run
            /dev/mmcblk0p2 ext4       29G   17G   11G  63% /
            tmpfs          tmpfs     1.9G  9.2M  1.9G   1% /dev/shm
            tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
            /dev/mmcblk0p1 vfat      510M   66M  445M  13% /boot/firmware
            tmpfs          tmpfs     380M   84K  380M   1% /run/user/1002
            tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
            [Sat Aug 23 13:17:08 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:5A:13:07 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=b69ad78b-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Sat Aug 23 13:17:11 2025] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
            [Sat Aug 23 13:17:12 2025] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w.
            Show mounted filesystems:
            TARGET           SOURCE         FSTYPE OPTIONS
            /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
            `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            1.2G    /var/
            486M    /var/log
            380M    /var/log/journal/0350b7d3c8bd4b9ca7427777c909465d
            348M    /var/cache
            Archived and active journals take up 379.5M in the file system.
            /opt/iobroker/backups:
            54M     /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            358M    /opt/iobroker/iobroker-data/
            269M    /opt/iobroker/iobroker-data/files
            68M     /opt/iobroker/iobroker-data/backup-objects
            48M     /opt/iobroker/iobroker-data/files/iot.admin
            47M     /opt/iobroker/iobroker-data/files/iot.admin/static/js
            38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
            24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
            15M     /opt/iobroker/iobroker-data/objects.jsonl
            8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
            8.6M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
            USB-Devices by-id:
            /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
            *** ZigBee Settings ***
            Your zigbee.0 COM-Port is matching 'by-id'. Very good!
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v20.19.4
            /usr/bin/node           v20.19.4
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            /usr/bin/corepack       0.32.0
            nodejs:
              Installed: 20.19.4-1nodesource1
              Candidate: 20.19.4-1nodesource1
              Version table:
             *** 20.19.4-1nodesource1 1001
                    500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                 20.19.3-1nodesource1 1001
                 20.19.2-1nodesource1 1001
                 20.19.1-1nodesource1 1001
                 20.19.0-1nodesource1 1001
                 20.18.3-1nodesource1 1001
                 20.18.2-1nodesource1 1001
                 20.18.1-1nodesource1 1001
                 20.18.0-1nodesource1 1001
                 20.17.0-1nodesource1 1001
                 20.16.0-1nodesource1 1001
                 20.15.1-1nodesource1 1001
                 20.15.0-1nodesource1 1001
                 20.14.0-1nodesource1 1001
                 20.13.1-1nodesource1 1001
                 20.13.0-1nodesource1 1001
                 20.12.2-1nodesource1 1001
                 20.12.1-1nodesource1 1001
                 20.12.0-1nodesource1 1001
                 20.11.1-1nodesource1 1001
                 20.11.0-1nodesource1 1001
                 20.10.0-1nodesource1 1001
                 20.9.0-1nodesource1 1001
                 20.8.1-1nodesource1 1001
                 20.8.0-1nodesource1 1001
                 20.7.0-1nodesource1 1001
                 20.6.1-1nodesource1 1001
                 20.6.0-1nodesource1 1001
                 20.5.1-1nodesource1 1001
                 20.5.0-1nodesource1 1001
                 20.4.0-1nodesource1 1001
                 20.3.1-1nodesource1 1001
                 20.3.0-1nodesource1 1001
                 20.2.0-1nodesource1 1001
                 20.1.0-1nodesource1 1001
                 20.0.0-1nodesource1 1001
                 18.19.0+dfsg-6~deb12u2 500
                    500 http://deb.debian.org/debian bookworm/main arm64 Packages
                 18.19.0+dfsg-6~deb12u1 500
                    500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
            No problems detected
            Errors in npm tree: 0
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 3139)
            Core adapters versions
            js-controller:  7.0.7
            admin:          7.6.17
            javascript:     8.9.2
            nodejs modules from github:     1
            +-- iobroker.tapo@0.4.8 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#615315d4bae5c77b153ac5067bdca8ba3ad3996f)
            Adapter State
            + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
            + system.adapter.alarm.0                  : alarm                 : raspberrypi                              -  enabled
              system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
            + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
              system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
            + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
            + system.adapter.deyeidc.0                : deyeidc               : raspberrypi                              -  enabled, port: 8899
            + system.adapter.fahrplan.0               : fahrplan              : raspberrypi                              -  enabled
            + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
              system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
              system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
              system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
            + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
            + system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              -  enabled
            + system.adapter.mihome-vacuum.2          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
            + system.adapter.nuki-extended.0          : nuki-extended         : raspberrypi                              -  enabled
            + system.adapter.ph803w.0                 : ph803w                : raspberrypi                              -  enabled
              system.adapter.roborock.0               : roborock              : raspberrypi                              -  enabled
            + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
              system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              -  enabled
            + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
            + system.adapter.tapo.0                   : tapo                  : raspberrypi                              -  enabled
            + system.adapter.telegram.1               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
              system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
            + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
            + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : raspberrypi                              -  enabled
            + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Upgrade policy: none
            Installed ioBroker-Adapters
            Used repository: stable
            Adapter    "admin"        : 7.6.17   , installed 7.6.17
            Adapter    "alarm"        : 3.7.0    , installed 3.7.0
            Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
            Adapter    "alias-manager": 2.0.0    , installed 2.0.0
            Adapter    "backitup"     : 3.3.5    , installed 3.3.5
            Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
            Adapter    "denon"        : 1.15.12  , installed 1.15.12
            Adapter    "deyeidc"      : 0.2.0    , installed 0.2.0
            Adapter    "fahrplan"     : 1.4.1    , installed 1.4.1
            Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
            Adapter    "ical"         : 1.16.2   , installed 1.16.1 [Updatable]
            Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
            Adapter    "iot"          : 3.3.0    , installed 3.3.0
            Adapter    "javascript"   : 8.9.2    , installed 8.9.2
            Controller "js-controller": 7.0.7    , installed 7.0.7
            Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
            Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
            Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
            Adapter    "ph803w"       : 1.2.0    , installed 1.2.0
            Adapter    "roborock"     : 0.6.18   , installed 0.6.18
            Adapter    "scenes"       : 3.2.3    , installed 3.2.3
            Adapter    "schoolfree"   : 1.1.10   , installed 1.1.9  [Updatable]
            Adapter    "shelly"       : 10.1.0   , installed 10.1.0
            Adapter    "shuttercontrol": 2.0.3   , installed 2.0.1  [Updatable]
            Adapter    "trashschedule": 3.3.0    , installed 3.3.0
            Adapter    "web"          : 7.0.8    , installed 7.0.8
            Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
            Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
            Objects and States
            Objects:        8590
            States:         6628
            Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
            Hit:2 http://deb.debian.org/debian bookworm InRelease
            Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
            Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
            Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       448519     33748/iobroker.js-c
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       446004     33748/iobroker.js-c
            tcp        0      0 0.0.0.0:6789            0.0.0.0:*               LISTEN      1002       6488       914/slirp4netns
            tcp        0      0 0.0.0.0:8880            0.0.0.0:*               LISTEN      1002       6494       914/slirp4netns
            tcp        0      0 0.0.0.0:8881            0.0.0.0:*               LISTEN      1002       6496       914/slirp4netns
            tcp        0      0 0.0.0.0:8882            0.0.0.0:*               LISTEN      1002       6498       914/slirp4netns
            tcp        0      0 127.0.0.1:11002         0.0.0.0:*               LISTEN      1002       6361       730/discovery
            tcp        0      0 0.0.0.0:8444            0.0.0.0:*               LISTEN      1002       6492       914/slirp4netns
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6107       732/sshd: /usr/sbin
            tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        8720       856/pihole-FTL
            tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      999        8055       856/pihole-FTL
            tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      999        8056       856/pihole-FTL
            tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1002       6490       914/slirp4netns
            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       453005     34618/io.shelly.1
            tcp        0      0 0.0.0.0:11443           0.0.0.0:*               LISTEN      1002       6500       914/slirp4netns
            tcp6       0      0 :::3000                 :::*                    LISTEN      1001       448417     34233/io.fullybrows
            tcp6       0      0 :::51989                :::*                    LISTEN      1001       449536     34424/io.nuki-exten
            tcp6       0      0 :::22                   :::*                    LISTEN      0          6109       732/sshd: /usr/sbin
            tcp6       0      0 :::53                   :::*                    LISTEN      999        8722       856/pihole-FTL
            tcp6       0      0 :::80                   :::*                    LISTEN      999        8057       856/pihole-FTL
            tcp6       0      0 :::443                  :::*                    LISTEN      999        8058       856/pihole-FTL
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       446157     33776/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       452363     34755/io.web.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        484        553/avahi-daemon: r
            udp        0      0 0.0.0.0:5514            0.0.0.0:*                           1002       6504       914/slirp4netns
            udp        0      0 0.0.0.0:3478            0.0.0.0:*                           1002       6502       914/slirp4netns
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       452785     34516/io.shelly.0
            udp        0      0 255.255.255.255:10001   0.0.0.0:*                           1002       555009     730/discovery
            udp        0      0 0.0.0.0:10003           0.0.0.0:*                           1002       6506       914/slirp4netns
            udp        0      0 0.0.0.0:36782           0.0.0.0:*                           1002       552483     914/slirp4netns
            udp        0      0 0.0.0.0:55259           0.0.0.0:*                           1001       451740     34458/io.ph803w.0
            udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        8719       856/pihole-FTL
            udp        0      0 0.0.0.0:123             0.0.0.0:*                           999        9782       856/pihole-FTL
            udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1001       451251     34397/io.mihome-vac
            udp        0      0 0.0.0.0:33046           0.0.0.0:*                           104        486        553/avahi-daemon: r
            udp        0      0 192.168.2.109:33514     0.0.0.0:*                           1002       552649     730/discovery
            udp6       0      0 :::5353                 :::*                                104        485        553/avahi-daemon: r
            udp6       0      0 :::53                   :::*                                999        8721       856/pihole-FTL
            udp6       0      0 :::123                  :::*                                999        9783       856/pihole-FTL
            udp6       0      0 fe80::9e7d:2a5f:b7c:546 :::*                                0          7193       638/NetworkManager
            udp6       0      0 :::33351                :::*                                104        487        553/avahi-daemon: r
                at Socket.emit (node:events:524:28)
                at UDP.onMessage (node:dgram:951:8)
            2025-08-23 18:43:58.144  - error: roborock.0 (42090) Exception-Code: ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH: error:1C80006B:Provider routines::wrong final block length
            2025-08-23 18:43:58.191  - info: roborock.0 (42090) terminating
            2025-08-23 18:43:58.193  - warn: roborock.0 (42090) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2025-08-23 18:43:58.851  - info: roborock.0 (42090) terminating
            2025-08-23 18:43:59.247  - error: host.raspberrypi Caught by controller[0]: Error: error:1C80006B:Provider routines::wrong final block length
            2025-08-23 18:43:59.247  - error: host.raspberrypi Caught by controller[0]:     at Decipheriv.final (node:internal/crypto/cipher:193:29)
            2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:     at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25)
            2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:     at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33)
            2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:     at Socket.emit (node:events:524:28)
            2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:     at Socket.emit (node:domain:489:12)
            2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:     at UDP.onMessage (node:dgram:951:8) {
            2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:   library: 'Provider routines',
            2025-08-23 18:43:59.249  - error: host.raspberrypi Caught by controller[0]:   reason: 'wrong final block length',
            2025-08-23 18:43:59.249  - error: host.raspberrypi Caught by controller[0]:   code: 'ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH'
            2025-08-23 18:43:59.249  - error: host.raspberrypi Caught by controller[0]: }
            2025-08-23 18:43:59.249  - error: host.raspberrypi instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2025-08-23 18:43:59.249  - info: host.raspberrypi Restart adapter system.adapter.roborock.0 because enabled
            2025-08-23 18:44:02.499  - info: tapo.0 (34846) Get camera Status failed
            2025-08-23 18:44:02.500  - info: tapo.0 (34846) No stok found for: 80211AE049E6EC914F17A219E950F4E9242DB387 this means the device is offline or connection lost. No update or commands possible
            2025-08-23 18:44:06.991  - info: tr-064.0 (34564) forEachConfiguredDevice: in GetSpecificHostEntry 1(Gioia/B8:94:E7:E7:C5:98) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-08-23 18:44:12.515  - info: tapo.0 (34846) Get camera Status failed
            2025-08-23 18:44:12.516  - info: tapo.0 (34846) No stok found for: 80211AE049E6EC914F17A219E950F4E9242DB387 this means the device is offline or connection lost. No update or commands possible
            • N nu_81
              Hier der Log.
              Danke schonmal!
              Script v.2025-08-09
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              OS is similar to:
              Docker          : false
              Kernel          : aarch64
              Userland        : 64 bit
              CPU threads: 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pihome
              HOME=/home/pihome
              iobroker
              HOME=/home/iobroker
              Display-Manager:
              Desktop:
              Session:                tty
              *** MEMORY ***
                       3796 M total memory
                       2995 M used memory
                        268 M free memory
                         38 M buffer memory
                        625 M swap cache
                        199 M total swap
                        199 M used swap
                          0 M free swap
              *** FILESYSTEM ***
              /var:
              1.2G    /var/
              486M    /var/log
              348M    /var/cache
              USB-Devices by-id:
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              admin:          7.6.17
              javascript:     8.9.2
              Adapter State
              + instance is alive
              Objects and States
              Objects:        8590
              States:         6628
              Pending Updates: 0
              Thomas BraunT
              Thomas BraunT
              #878
              @nu_81 sagte in Neuer Adapter für Roborock-Staubsauger:
              Ich habe den Verdacht, das könnte mit nodejs zusammenhängen.
              Bring die drei Adapter auf Stand und dann ein
              iob nodejs-update
              B N 2 Antworten Letzte Antwort
                iob nodejs-update
                B
                B
                breaksrmine
                #879
                Beim Adapter 0.6.18 kommt beim Roborock QV 35A folgende Fehler.
                Steuern geht aber ohne Probleme
                roborock.0
                2025-08-23 19:17:02.540 warn Unsupported attribute: seq_type of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                roborock.0
                2025-08-23 19:17:02.539 warn Unsupported attribute: exit_dock of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                roborock.0
                2025-08-23 19:17:02.538 warn Unsupported attribute: cleaning_info of get_status with value [object Object]. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                roborock.0
                2025-08-23 19:17:02.458 warn Unsupported attribute: last_clean_t of get_status with value 1755969220. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                roborock.0
                2025-08-23 19:17:02.457 warn Unsupported attribute: switch_status of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                roborock.0
                2025-08-23 19:17:02.416 warn Unsupported attribute: kct of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                roborock.0
                2025-08-23 19:17:02.336 warn Unsupported attribute: common_status of get_status with value 2. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                roborock.0
                2025-08-23 19:17:02.335 warn Unsupported attribute: dss of get_status with value 169. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                roborock.0
                2025-08-23 19:17:02.335 warn Unsupported attribute: rss of get_status with value 2. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                roborock.0
                2025-08-23 19:17:02.334 warn Unsupported attribute: extra_time of get_status with value 1860. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                roborock.0
                2025-08-23 19:17:02.333 warn Unsupported attribute: clean_percent of get_status with value 45. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                roborock.0
                2025-08-23 19:17:02.172 warn Unsupported attribute: charge_status of get_status with value 1. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                roborock.0
                roborock.0
                2025-08-23 19:17:01.851 warn Unsupported attribute: in_warmup of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                roborock.0
                2025-08-23 19:17:01.650 warn Unsupported attribute: water_shortage_status of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                roborock.0
                2025-08-23 19:17:01.530 warn Unsupported attribute: mop_forbidden_enable of get_status with value 1. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                roborock.0
                2025-08-23 19:17:01.529 warn Unsupported attribute: water_box_carriage_status of get_status with value 1. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                roborock.0
                2025-08-23 19:17:01.488 warn Unsupported attribute: water_box_mode of get_status with value 207. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                roborock.0
                2025-08-23 19:17:01.287 warn Unsupported attribute: water_box_status of get_status with value 1. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                  iob nodejs-update
                  N
                  N
                  nu_81
                  #880
                  Hallo, habe das Update durchgeführt.
                  Der Fehler bleibt jedoch leider.
                  Script v.2025-08-09
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  OS is similar to:
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : 64 bit
                   11:31:58 up 11:00,  2 users,  load average: 1.93, 0.82, 0.49
                  CPU threads: 4
                  Current issues:
                                 Local time: Mon 2025-08-25 11:31:58 CEST
                             Universal time: Mon 2025-08-25 09:31:58 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pihome
                  HOME=/home/pihome
                  iobroker
                  HOME=/home/iobroker
                  Display-Manager:
                  Desktop:
                  Session:                tty
                  *** MEMORY ***
                  Mem:            4.0G        3.4G         59M         25M        599M        542M
                  Swap:           2.1G        452M        1.7G
                  Total:          6.1G        3.9G        1.8G
                  Active iob-Instances:   24
                           3796 M total memory
                           3280 M used memory
                           2278 M active memory
                           1257 M inactive memory
                             55 M free memory
                             35 M buffer memory
                            535 M swap cache
                           2047 M total swap
                            432 M used swap
                           1615 M free swap
                  top - 11:31:58 up 11:00,  2 users,  load average: 1.93, 0.82, 0.49
                  Tasks: 237 total,   1 running, 236 sleeping,   0 stopped,   0 zombie
                  %Cpu(s): 14.3 us, 14.3 sy,  0.0 ni, 71.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :   3796.9 total,     52.2 free,   3283.9 used,    571.4 buff/cache
                  MiB Swap:   2048.0 total,   1616.0 free,    432.0 used.    513.0 avail Mem
                  *** FILESYSTEM ***
                  /dev/mmcblk0p2 ext4       29G   19G  8.9G  68% /
                  tmpfs          tmpfs     1.9G  6.3M  1.9G   1% /dev/shm
                  [Mon Aug 25 00:31:18 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:5A:13:07 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=b69ad78b-02 rootfstype=ext4 fsck.repair=yes rootwait
                  [Mon Aug 25 00:31:21 2025] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
                  [Mon Aug 25 00:31:23 2025] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w.
                  /var:
                  2.8G    /var/
                  476M    /var/log
                  412M    /var/log/journal/0350b7d3c8bd4b9ca7427777c909465d
                  172M    /var/lib
                  Archived and active journals take up 411.5M in the file system.
                  15M     /opt/iobroker/backups/
                  16M     /opt/iobroker/iobroker-data/objects.jsonl
                  USB-Devices by-id:
                  zigbee.X
                  Extended Pan ID:
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  /usr/bin/nodejs         v22.18.0
                  /usr/bin/node           v22.18.0
                  /usr/bin/npm            10.9.3
                  /usr/bin/npx            10.9.3
                  /usr/bin/corepack       0.33.0
                  nodejs:
                    Installed: 22.18.0-1nodesource1
                    Candidate: 22.18.0-1nodesource1
                    Version table:
                   *** 22.18.0-1nodesource1 1001
                          500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                       22.17.1-1nodesource1 1001
                       22.17.0-1nodesource1 1001
                       22.16.0-1nodesource1 1001
                       22.15.1-1nodesource1 1001
                       22.15.0-1nodesource1 1001
                       22.14.0-1nodesource1 1001
                       22.13.1-1nodesource1 1001
                       22.13.0-1nodesource1 1001
                       22.12.0-1nodesource1 1001
                       22.11.0-1nodesource1 1001
                       22.10.0-1nodesource1 1001
                       22.9.0-1nodesource1 1001
                       22.8.0-1nodesource1 1001
                       22.7.0-1nodesource1 1001
                       22.6.0-1nodesource1 1001
                       22.5.1-1nodesource1 1001
                       22.5.0-1nodesource1 1001
                       22.4.1-1nodesource1 1001
                       22.4.0-1nodesource1 1001
                       22.3.0-1nodesource1 1001
                       22.2.0-1nodesource1 1001
                       22.1.0-1nodesource1 1001
                       22.0.0-1nodesource1 1001
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 39639)
                  admin:          7.6.17
                  javascript:     8.9.2
                  Adapter State
                    system.adapter.denon.0                  : denon                 : raspberrypi                              - disabled
                    system.adapter.deyeidc.0                : deyeidc               : raspberrypi                              - disabled, port: 8899
                    system.adapter.mihome-vacuum.2          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
                    system.adapter.scenes.0                 : scenes                : raspberrypi                              - disabled
                    system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
                  + instance is alive
                  Adapter    "ical"         : 1.16.2   , installed 1.16.2
                  Adapter    "schoolfree"   : 1.1.10   , installed 1.1.10
                  Adapter    "shuttercontrol": 2.0.3   , installed 2.0.3
                  Objects and States
                  Objects:        8782
                  States:         6752
                  Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                  Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                  Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                  Pending Updates: 0
                  tcp        0      0 0.0.0.0:6789            0.0.0.0:*               LISTEN      1002       6662       920/slirp4netns
                  tcp        0      0 0.0.0.0:8882            0.0.0.0:*               LISTEN      1002       6672       920/slirp4netns
                  tcp        0      0 0.0.0.0:8881            0.0.0.0:*               LISTEN      1002       6670       920/slirp4netns
                  tcp        0      0 0.0.0.0:8880            0.0.0.0:*               LISTEN      1002       6668       920/slirp4netns
                  tcp        0      0 0.0.0.0:8444            0.0.0.0:*               LISTEN      1002       6666       920/slirp4netns
                  tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      999        9512       863/pihole-FTL
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6540       739/sshd: /usr/sbin
                  tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        924        863/pihole-FTL
                  tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      999        9513       863/pihole-FTL
                  tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1002       6664       920/slirp4netns
                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       15151      2682/io.shelly.1
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       930        716/iobroker.js-con
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5702       716/iobroker.js-con
                  tcp        0      0 0.0.0.0:11443           0.0.0.0:*               LISTEN      1002       6674       920/slirp4netns
                  tcp        0      0 127.0.0.1:11002         0.0.0.0:*               LISTEN      1002       5094       737/discovery
                  tcp6       0      0 :::3000                 :::*                    LISTEN      1001       14447      2186/io.fullybrowse
                  tcp6       0      0 :::51989                :::*                    LISTEN      1001       11994      2364/io.nuki-extend
                  tcp6       0      0 :::80                   :::*                    LISTEN      999        9514       863/pihole-FTL
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          6542       739/sshd: /usr/sbin
                  tcp6       0      0 :::53                   :::*                    LISTEN      999        926        863/pihole-FTL
                  tcp6       0      0 :::443                  :::*                    LISTEN      999        9515       863/pihole-FTL
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       15445      2584/io.web.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7048       907/io.admin.0
                  udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        923        863/pihole-FTL
                  udp        0      0 0.0.0.0:123             0.0.0.0:*                           999        24743      863/pihole-FTL
                  udp        0      0 0.0.0.0:60493           0.0.0.0:*                           1001       11997      2376/io.ph803w.0
                  udp        0      0 0.0.0.0:58631           0.0.0.0:*                           1002       675873     920/slirp4netns
                  udp        0      0 0.0.0.0:5514            0.0.0.0:*                           1002       6678       920/slirp4netns
                  udp        0      0 0.0.0.0:3478            0.0.0.0:*                           1002       6676       920/slirp4netns
                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       14856      2439/io.shelly.0
                  udp        0      0 255.255.255.255:10001   0.0.0.0:*                           1002       868410     737/discovery
                  udp        0      0 0.0.0.0:10003           0.0.0.0:*                           1002       6680       920/slirp4netns
                  udp        0      0 192.168.2.109:38760     0.0.0.0:*                           1002       868411     737/discovery
                  udp6       0      0 :::53                   :::*                                999        925        863/pihole-FTL
                  udp6       0      0 :::123                  :::*                                999        23343      863/pihole-FTL
                  udp6       0      0 :::59687                :::*                                1002       675872     920/slirp4netns
                  udp6       0      0 fe80::9e7d:2a5f:b7c:546 :::*                                0          849        644/NetworkManager
                  udp6       0      0 :::54266                :::*                                1002       675860     920/slirp4netns
                      at UDP.onMessage (node:dgram:988:8)
                  2025-08-25 11:33:11.924  - error: roborock.0 (49238) Exception-Code: ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH: error:1C80006B:Provider routines::wrong final block length
                  2025-08-25 11:33:11.957  - info: roborock.0 (49238) terminating
                  2025-08-25 11:33:11.959  - warn: roborock.0 (49238) Terminated (UNCAUGHT_EXCEPTION): Without reason
                  2025-08-25 11:33:12.555  - error: host.raspberrypi Caught by controller[0]: Error: error:1C80006B:Provider routines::wrong final block length
                  2025-08-25 11:33:12.556  - error: host.raspberrypi Caught by controller[0]:     at Decipheriv.final (node:internal/crypto/cipher:184:29)
                  2025-08-25 11:33:12.556  - error: host.raspberrypi Caught by controller[0]:     at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25)
                  2025-08-25 11:33:12.556  - error: host.raspberrypi Caught by controller[0]:     at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33)
                  2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:     at Socket.emit (node:events:518:28)
                  2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:     at Socket.emit (node:domain:489:12)
                  2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:     at UDP.onMessage (node:dgram:988:8) {
                  2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:   library: 'Provider routines',
                  2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:   reason: 'wrong final block length',
                  2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:   code: 'ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH'
                  2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]: }
                  2025-08-25 11:33:12.557  - error: host.raspberrypi instance system.adapter.roborock.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  2025-08-25 11:33:12.558  - info: host.raspberrypi Restart adapter system.adapter.roborock.0 because enabled
                  2025-08-25 11:33:18.253  - info: tapo.0 (2625) Get camera Status failed
                  2025-08-25 11:33:18.254  - info: tapo.0 (2625) No stok found for: 80211AE049E6EC914F17A219E950F4E9242DB387 this means the device is offline or connection lost. No update or commands possible
                  2025-08-25 11:33:28.273  - info: tapo.0 (2625) Get camera Status failed
                  2025-08-25 11:33:28.274  - info: tapo.0 (2625) No stok found for: 80211AE049E6EC914F17A219E950F4E9242DB387 this means the device is offline or connection lost. No update or commands possible
                  N Ro75R 2 Antworten Letzte Antwort
                  • N nu_81
                    Script v.2025-08-09
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    OS is similar to:
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : 64 bit
                    CPU threads: 4
                    Current issues:
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pihome
                    HOME=/home/pihome
                    iobroker
                    HOME=/home/iobroker
                    Display-Manager:
                    Desktop:
                    Session:                tty
                    *** MEMORY ***
                             3796 M total memory
                             3280 M used memory
                               55 M free memory
                               35 M buffer memory
                              535 M swap cache
                             2047 M total swap
                              432 M used swap
                             1615 M free swap
                    *** FILESYSTEM ***
                    /var:
                    2.8G    /var/
                    476M    /var/log
                    172M    /var/lib
                    USB-Devices by-id:
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    /usr/bin/npm            10.9.3
                    /usr/bin/npx            10.9.3
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    admin:          7.6.17
                    javascript:     8.9.2
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        8782
                    States:         6752
                    Pending Updates: 0
                    N
                    N
                    nu_81
                    #881
                    @nu_81 Hallo, hat jemand hierzu noch eine Idee?
                    Danke euch schonmal
                    • N nu_81
                      Script v.2025-08-09
                      *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                      OS is similar to:
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : 64 bit
                      CPU threads: 4
                      Current issues:
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pihome
                      HOME=/home/pihome
                      iobroker
                      HOME=/home/iobroker
                      Display-Manager:
                      Desktop:
                      Session:                tty
                      *** MEMORY ***
                               3796 M total memory
                               3280 M used memory
                                 55 M free memory
                                 35 M buffer memory
                                535 M swap cache
                               2047 M total swap
                                432 M used swap
                               1615 M free swap
                      *** FILESYSTEM ***
                      /var:
                      2.8G    /var/
                      476M    /var/log
                      172M    /var/lib
                      USB-Devices by-id:
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      /usr/bin/npm            10.9.3
                      /usr/bin/npx            10.9.3
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      admin:          7.6.17
                      javascript:     8.9.2
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        8782
                      States:         6752
                      Pending Updates: 0
                      Ro75R
                      Ro75R
                      Ro75
                      #882
                      Previously detected issues: ~ Under-voltage has occurred ~ Arm frequency capping has occurred ~ Throttling has occurred ~ Soft temperature limit has occurred
                      Originalnetzteil verwenden - kein Ladegerät! Sorge für gute Kühlung.
                      Ro75.
                      • D3ltoroxpD
                        D3ltoroxpD
                        D3ltoroxp
                        #883
                        ich kann leider vom Adapter keine DP abgreifen, der mit den Status der Station anzeigt. Tank voll, leer usw. Hab den roborock Qrevo Edge S5A + Station.
                        • Ro75R Ro75
                          Ro75.
                          N
                          N
                          nu_81
                          #884
                          @ro75
                          Danke, ich benutze das Originalnetzteil.
                          Das mit der Kühlung hatte ich schon gesehen und kümmere mich nun um ein anderes Gehäuse, bzw. um einen Lüfter.
                          Das Problem mit der Kühlung verursacht aber doch nicht das Problem am Adapter, oder?!
                          • D3ltoroxpD
                            D3ltoroxpD
                            D3ltoroxp
                            #885
                            Ich sehe auch grad, er connected gar nicht mehr mit dem Sauger. Das ist neu, es ging mal.
                            roborock.0
                            2025-09-01 18:08:41.980	info	terminating
                            roborock.0
                            2025-09-01 18:08:41.657	info	MQTT connection established {"cmd":"connack","retain":false,"qos":0,"dup":false,"length":2,"topic":null,"payload":null,"sessionPresent":false,"returnCode":0}.
                            roborock.0
                            2025-09-01 18:08:41.478	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                            roborock.0
                            2025-09-01 18:08:41.477	info	terminating
                            roborock.0
                            2025-09-01 18:08:41.468	error	this.homeData is not initialized. Initialize via updateHomeData() first
                            roborock.0
                            2025-09-01 18:08:41.467	error	Error: this.homeData is not initialized. Initialize via updateHomeData() first at http_api.getDevices (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:192:10) at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:112:39)
                            roborock.0
                            2025-09-01 18:08:41.464	error	unhandled promise rejection: this.homeData is not initialized. Initialize via updateHomeData() first
                            roborock.0
                            2025-09-01 18:08:41.463	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            roborock.0
                            2025-09-01 18:08:41.462	info	MQTT initialized
                            roborock.0
                            2025-09-01 18:08:41.418	error	No homeId found
                            roborock.0
                            2025-09-01 18:08:41.417	error	failed to get getHomeDetail: invalid token
                            • D3ltoroxpD D3ltoroxp
                              roborock.0
                              roborock.0
                              roborock.0
                              roborock.0
                              roborock.0
                              roborock.0
                              roborock.0
                              roborock.0
                              roborock.0
                              roborock.0
                              roborock.0
                              N
                              N
                              nu_81
                              #886
                              Habe den Adapter komplett entfernt und neu installiert.
                              Der Fehler bleibt leider.
                              Jemand noch eine Idee?
                              host.raspberrypi
                              2025-09-01 20:11:10.015	info	Restart adapter system.adapter.roborock.0 because enabled
                              host.raspberrypi
                              2025-09-01 20:11:10.015	error	instance system.adapter.roborock.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                              host.raspberrypi
                              2025-09-01 20:11:10.015	error	Caught by controller[0]: }
                              host.raspberrypi
                              2025-09-01 20:11:10.015	error	Caught by controller[0]: code: 'ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH'
                              host.raspberrypi
                              2025-09-01 20:11:10.015	error	Caught by controller[0]: reason: 'wrong final block length',
                              host.raspberrypi
                              2025-09-01 20:11:10.015	error	Caught by controller[0]: library: 'Provider routines',
                              host.raspberrypi
                              2025-09-01 20:11:10.015	error	Caught by controller[0]: at UDP.onMessage (node:dgram:988:8) {
                              host.raspberrypi
                              2025-09-01 20:11:10.014	error	Caught by controller[0]: at Socket.emit (node:domain:489:12)
                              host.raspberrypi
                              2025-09-01 20:11:10.014	error	Caught by controller[0]: at Socket.emit (node:events:518:28)
                              host.raspberrypi
                              2025-09-01 20:11:10.014	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33)
                              host.raspberrypi
                              2025-09-01 20:11:10.014	error	Caught by controller[0]: at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25)
                              host.raspberrypi
                              2025-09-01 20:11:10.014	error	Caught by controller[0]: at Decipheriv.final (node:internal/crypto/cipher:184:29)
                              host.raspberrypi
                              2025-09-01 20:11:10.014	error	Caught by controller[0]: Error: error:1C80006B:Provider routines::wrong final block length
                              roborock.0
                              2025-09-01 20:11:09.673	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                              roborock.0
                              2025-09-01 20:11:09.671	info	terminating
                              roborock.0
                              2025-09-01 20:11:09.641	error	Exception-Code: ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH: error:1C80006B:Provider routines::wrong final block length
                              roborock.0
                              2025-09-01 20:11:09.641	error	Error: error:1C80006B:Provider routines::wrong final block length at Decipheriv.final (node:internal/crypto/cipher:184:29) at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33) at Socket.emit (node:events:518:28) at Socket.emit (node:domain:489:12) at UDP.onMessage (node:dgram:988:8)
                              roborock.0
                              2025-09-01 20:11:09.640	error	uncaught exception: error:1C80006B:Provider routines::wrong final block length
                              roborock.0
                              2025-09-01 20:11:07.212	info	MQTT initialized
                              roborock.0
                              2025-09-01 20:11:05.656	info	Starting adapter. This might take a few minutes depending on your setup. Please wait.
                              roborock.0
                              2025-09-01 20:11:05.626	info	starting. Version 0.6.18 in /opt/iobroker/node_modules/iobroker.roborock, node: v22.18.0, js-controller: 7.0.7
                              • N nu_81
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                N
                                N
                                nu_81
                                #887
                                @nu_81 said in Neuer Adapter für Roborock-Staubsauger:
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                host.raspberrypi
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                Hab es durch iÍnstallation des dev_ts gelöst.
                                • N nu_81
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  N
                                  N
                                  nu_81
                                  #888
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  Hab es durch Installation des dev_ts gelöst.
                                  • N
                                    N
                                    Nachtfuchs
                                    #889
                                    Hallo Gemeinde,
                                    wir sind seit gestern Besitzer des QRevo Slim und nun soll dieser natürlich auch mit dem ioBroker sprechen. Adapter aus Adapterliste ausgewählt, aber er wirft diese Fehlermeldungen aus - kennt das jemand?
                                    Dank euch
                                    Thomas BraunT B 2 Antworten Letzte Antwort
                                    • N Nachtfuchs
                                      Hallo Gemeinde,
                                      Dank euch
                                      Thomas BraunT
                                      Thomas BraunT
                                      #890
                                      @nachtfuchs
                                      iob stop
                                      iob fix
                                      iob start
                                      Und bring deine nodejs-Installation in Ordnung. Keine aktuelle Version verwendet npm 10.7.0.
                                      • N
                                        N
                                        Nachtfuchs
                                        #891
                                        @Thomas-Braun
                                        Mal wieder unglaublicher support, DANKE!
                                        Und danke für den Hinweis, werde mich mal am Wochenende an Dein nodejs Fixer Skript machen.
                                        • N
                                          N
                                          Nachtfuchs
                                          schrieb am zuletzt editiert von Nachtfuchs
                                          #892
                                          Hallo Gemeinde,
                                          ich tauche tiefer in den Adapter ein und habe eine Frage:
                                          Setting
                                          Wir haben im Anbau ein Badezimmer und Wohn-/Schlafzimmer. Ersteres mit Fliesen, letztere mit Parkett.
                                          Ich habe dem QRevo Slim in der App zwei Programme geschrieben:
                                          1. im Badezimmer wischen, den Rest saugen
                                          2. die gesamte Fläche mit wenig Wasser wischen, also Fliesen und Parkett
                                          Im Badezimmer haben wir den HMIP WRC 6, ein Schalter ist "Staubsauger" - dieser führt dazu, dass
                                          a) das Sonos ausgeht (Pause button = wahr)
                                          b) der Staubsauger angeht mit Programm 1) und
                                          c) nach einer Verzögerung das Licht ausgeht
                                          1. soll nur sehr selektiv ausgeführt werden; diesen würde ich dann über einen anderen Taster auf dem WRC 6 steuern.
                                          Die Idee war nun, in den Datenpunkt "StartProgram" das Programm mit dem Namen "Saug+Wi Anbau" (Programm 1) zu schreiben, damit er genau das tut.
                                          Dieses möchte ich über das angefügte Script erreichen, aber wenn ich auslöse, beginnt er mit der Voll-Reinigung, sprich Wischen überall.
                                          Ziel wäre wie gesagt, mittels des anderen Tasters auch "Wi Anbau" (2) zu steuern.
                                          Wenn ich hingegen das Programm auf der IOBroker Oberfläche setze, so reinigt er richtig.
                                          Ich hatte in einer anderen script-Version auch erst das Programm geschrieben und dann den Datenpunkt "app_start" auf TRUE gesetzt, im Sinne erst Programm mitteilen, dann starten - hat leider auch nicht funktioniert.
                                          Wo habe ich den Denkfehler?
                                          Dank euch
