  4. Neuer Adapter für Roborock-Staubsauger
1.1k Beiträge 155 Kommentatoren 512.9k Aufrufe 137 Beobachtet
  • System 9S System 9
    guten morgen.
    ich bekomme fehler, da einige Datenpunkte nicht angelegt werden.
    State "roborock.0.Devices.6vZ1zawxmrZgMTxgOPtwJn.deviceStatus.carpet_clean_mode" has no existing object, this might lead to an error in future versions
    State "roborock.0.Devices.6vZ1zawxmrZgMTxgOPtwJn.deviceStatus.carpet_mode" has no existing object, this might lead to an error in future versions
    was kann ich hier machen ?
    T
    T
    TimoWald
    #872
    Hallo, wieso bekomme ich meinen Adapter nicht mehr auf grün?
    Dieser Feher kommt nach dem starten.
    Was kann ich tun?
    2025-08-20 06:57:36.146 - info: host.iobroker instance system.adapter.roborock.0 in version "0.6.19" (non-npm: copystring/ioBroker.roborock#769dee8a000aa78ecdcb826185abcafc1aada5d5) started with pid 2735931
    2025-08-20 06:57:40.150 - info: roborock.0 (2735931) starting. Version 0.6.19 (non-npm: copystring/ioBroker.roborock#769dee8a000aa78ecdcb826185abcafc1aada5d5) in /opt/iobroker/node_modules/iobroker.roborock, node: v20.18.0, js-controller: 7.0.7
    2025-08-20 06:57:40.171 - info: roborock.0 (2735931) Starting adapter. This might take a few minutes depending on your setup. Please wait.
    2025-08-20 06:57:40.187 - info: roborock.0 (2735931) Loaded existing clientID: ee6783f4-5d0a-4d48-b00e-7cafd23b31d9
    2025-08-20 06:57:40.472 - error: roborock.0 (2735931) Failed to process undefined on robot undefined (unknown device model): TypeError: Cannot read properties of null (reading 'rrHomeId')
    at http_api.getHomeID (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:111:31)
    at processTicksAndRejections (node:internal/process/task_queues:95:5)
    at http_api.updateHomeData (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:123:19)
    at http_api.init (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:33:3)
    at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:55:3)
    2025-08-20 06:57:40.762 - info: roborock.0 (2735931) MQTT initialized
    2025-08-20 06:57:40.763 - error: roborock.0 (2735931) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2025-08-20 06:57:40.764 - error: roborock.0 (2735931) unhandled promise rejection: this.homeData is not initialized. Initialize via getHomeData() first
    2025-08-20 06:57:40.764 - error: roborock.0 (2735931) Error: this.homeData is not initialized. Initialize via getHomeData() first
    at http_api.getDevices (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:179:10)
    at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:62:39)
    2025-08-20 06:57:40.765 - error: roborock.0 (2735931) this.homeData is not initialized. Initialize via getHomeData() first
    2025-08-20 06:57:40.779 - info: roborock.0 (2735931) terminating
    2025-08-20 06:57:40.781 - warn: roborock.0 (2735931) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2025-08-20 06:57:40.843 - info: roborock.0 (2735931) MQTT connection established {"cmd":"connack","retain":false,"qos":0,"dup":false,"length":2,"topic":null,"payload":null,"sessionPresent":false,"returnCode":0}.
    2025-08-20 06:57:41.282 - info: roborock.0 (2735931) terminating
    2025-08-20 06:57:41.437 - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-08-20 06:57:41.437 - error: host.iobroker Caught by controller[1]: Error: this.homeData is not initialized. Initialize via getHomeData() first
    2025-08-20 06:57:41.437 - error: host.iobroker Caught by controller[1]: at http_api.getDevices (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:179:10)
    2025-08-20 06:57:41.438 - error: host.iobroker Caught by controller[1]: at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:62:39)
    2025-08-20 06:57:41.438 - error: host.iobroker instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2025-08-20 06:57:41.438 - info: host.iobroker Restart adapter system.adapter.roborock.0 because enabled
    2025-08-20 06:57:52.160 - info: host.iobroker "system.adapter.roborock.0" disabled
    2025-08-20 06:58:14.994 - error: roborock.0 (2735952) adapter disabled
    2025-08-20 06:58:15.040 - warn: roborock.0 (2735952) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
    2025-08-20 06:58:15.723 - error: host.iobroker instance system.adapter.roborock.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
    2025-08-20 06:58:15.723 - info: host.iobroker Do not restart adapter system.adapter.roborock.0 because disabled or deleted
    • A Anderl 0
      Moin!
      Kann mir bitte jemand mit dem Fehler weiterhelfen? Lief bis gestern alles tadellos, und seit dem bekomm ich diese Fehler ins Log:
      host.raspberrypi
      2025-06-30 09:25:58.061	error	instance system.adapter.roborock.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.raspberrypi
      2025-06-30 09:25:58.061	error	Caught by controller[0]: }
      host.raspberrypi
      2025-06-30 09:25:58.061	error	Caught by controller[0]: code: 'ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH'
      host.raspberrypi
      2025-06-30 09:25:58.061	error	Caught by controller[0]: reason: 'wrong final block length',
      host.raspberrypi
      2025-06-30 09:25:58.061	error	Caught by controller[0]: library: 'Provider routines',
      host.raspberrypi
      2025-06-30 09:25:58.060	error	Caught by controller[0]: at UDP.onMessage (node:dgram:944:8) {
      host.raspberrypi
      2025-06-30 09:25:58.060	error	Caught by controller[0]: at Socket.emit (node:domain:489:12)
      host.raspberrypi
      2025-06-30 09:25:58.060	error	Caught by controller[0]: at Socket.emit (node:events:518:28)
      host.raspberrypi
      2025-06-30 09:25:58.060	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33)
      host.raspberrypi
      2025-06-30 09:25:58.060	error	Caught by controller[0]: at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25)
      host.raspberrypi
      2025-06-30 09:25:58.059	error	Caught by controller[0]: at Decipheriv.final (node:internal/crypto/cipher:193:29)
      host.raspberrypi
      2025-06-30 09:25:58.055	error	Caught by controller[0]: Error: error:1C80006B:Provider routines::wrong final block length
      roborock.0
      2025-06-30 09:25:57.628	error	Exception-Code: ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH: error:1C80006B:Provider routines::wrong final block length
      roborock.0
      2025-06-30 09:25:57.627	error	Error: error:1C80006B:Provider routines::wrong final block length at Decipheriv.final (node:internal/crypto/cipher:193:29) at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33) at Socket.emit (node:events:518:28) at Socket.emit (node:domain:489:12) at UDP.onMessage (node:dgram:944:8)
      roborock.0
      2025-06-30 09:25:57.623	error	uncaught exception: error:1C80006B:Provider routines::wrong final block length
      N
      N
      nu_81
      schrieb am zuletzt editiert von nu_81
      #873
      @anderl-0
      hab nun auf einmal die selben Fehler.
      Hast du das Problem schon gelöst?
      • N nu_81
        @anderl-0
        Thomas BraunT
        Thomas BraunT
        #874
        @nu_81
        Versionsnummern der üblichen Verdächtigen? Alternativ die Ausgabe von
        iob diag
        posten.
        N 1 Antwort Letzte Antwort
          @nu_81
          iob diag
          posten.
          N
          N
          nu_81
          #875
          @thomas-braun said in Fehler Roborock - Adapter:
          @nu_81
          Welche Verdächtigen meinst du? Kann dir leider nicht folgen.
          • N nu_81
            @nu_81
            Thomas BraunT
            Thomas BraunT
            #876
            @nu_81
            Versionen von nodejs, js-controller usw.
            Poste einfach die Ausgabe von
            iob diag
            da steht erstmal alles drin.
              @nu_81
              iob diag
              N
              N
              nu_81
              #877
              Hier der Log.
              Danke schonmal!
              Script v.2025-08-09
              *** BASE SYSTEM ***
               Static hostname: raspberrypi
                     Icon name: computer
                        Kernel: Linux 6.12.34+rpt-rpi-v8
                  Architecture: arm64
              OS is similar to:
              Model           : Raspberry Pi 4 Model B Rev 1.1
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : 64 bit
              Systemuptime and Load:
               18:42:51 up  5:25,  3 users,  load average: 1.54, 0.91, 0.58
              CPU threads: 4
              *** LIFE CYCLE STATUS ***
              Operating System is the current Debian stable version codenamed 'bookworm'!
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              ~ Under-voltage has occurred
              ~ Arm frequency capping has occurred
              ~ Throttling has occurred
              ~ Soft temperature limit has occurred
              *** TIME AND TIMEZONES ***
                             Local time: Sat 2025-08-23 18:42:51 CEST
                         Universal time: Sat 2025-08-23 16:42:51 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              pihome
              HOME=/home/pihome
              GROUPS=pihome adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker uosserver
              iobroker
              HOME=/home/iobroker
              *** DISPLAY-SERVER SETUP ***
              Display-Server:         false
              Unit display-manager.service could not be found.
              Display-Manager:
              Desktop:
              Session:                tty
              *** MEMORY ***
              Mem:            4.0G        3.1G        281M         29M        696M        839M
              Swap:           209M        209M        704K
              Total:          4.2G        3.4G        282M
              Active iob-Instances:   29
                       3796 M total memory
                       2995 M used memory
                       2252 M active memory
                       1046 M inactive memory
                        268 M free memory
                         38 M buffer memory
                        625 M swap cache
                        199 M total swap
                        199 M used swap
                          0 M free swap
              top - 18:42:52 up  5:25,  3 users,  load average: 1.54, 0.91, 0.58
              Tasks: 252 total,   1 running, 251 sleeping,   0 stopped,   0 zombie
              %Cpu(s): 44.4 us, 22.2 sy,  0.0 ni, 33.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :   3796.9 total,    268.2 free,   2996.0 used,    664.5 buff/cache
              MiB Swap:    200.0 total,      0.7 free,    199.3 used.    800.9 avail Mem
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** DMESG CRITICAL ERRORS ***
              No critical errors detected
              *** FILESYSTEM ***
              udev           devtmpfs  1.6G     0  1.6G   0% /dev
              tmpfs          tmpfs     760M  1.2M  759M   1% /run
              /dev/mmcblk0p2 ext4       29G   17G   11G  63% /
              tmpfs          tmpfs     1.9G  9.2M  1.9G   1% /dev/shm
              tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
              /dev/mmcblk0p1 vfat      510M   66M  445M  13% /boot/firmware
              tmpfs          tmpfs     380M   84K  380M   1% /run/user/1002
              tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
              [Sat Aug 23 13:17:08 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:5A:13:07 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=b69ad78b-02 rootfstype=ext4 fsck.repair=yes rootwait
              [Sat Aug 23 13:17:11 2025] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
              [Sat Aug 23 13:17:12 2025] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w.
              Show mounted filesystems:
              TARGET           SOURCE         FSTYPE OPTIONS
              /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
              `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              1.2G    /var/
              486M    /var/log
              380M    /var/log/journal/0350b7d3c8bd4b9ca7427777c909465d
              348M    /var/cache
              Archived and active journals take up 379.5M in the file system.
              /opt/iobroker/backups:
              54M     /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              358M    /opt/iobroker/iobroker-data/
              269M    /opt/iobroker/iobroker-data/files
              68M     /opt/iobroker/iobroker-data/backup-objects
              48M     /opt/iobroker/iobroker-data/files/iot.admin
              47M     /opt/iobroker/iobroker-data/files/iot.admin/static/js
              38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
              24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
              15M     /opt/iobroker/iobroker-data/objects.jsonl
              8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
              8.6M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
              USB-Devices by-id:
              /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
              *** ZigBee Settings ***
              Your zigbee.0 COM-Port is matching 'by-id'. Very good!
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v20.19.4
              /usr/bin/node           v20.19.4
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              /usr/bin/corepack       0.32.0
              nodejs:
                Installed: 20.19.4-1nodesource1
                Candidate: 20.19.4-1nodesource1
                Version table:
               *** 20.19.4-1nodesource1 1001
                      500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                   20.19.3-1nodesource1 1001
                   20.19.2-1nodesource1 1001
                   20.19.1-1nodesource1 1001
                   20.19.0-1nodesource1 1001
                   20.18.3-1nodesource1 1001
                   20.18.2-1nodesource1 1001
                   20.18.1-1nodesource1 1001
                   20.18.0-1nodesource1 1001
                   20.17.0-1nodesource1 1001
                   20.16.0-1nodesource1 1001
                   20.15.1-1nodesource1 1001
                   20.15.0-1nodesource1 1001
                   20.14.0-1nodesource1 1001
                   20.13.1-1nodesource1 1001
                   20.13.0-1nodesource1 1001
                   20.12.2-1nodesource1 1001
                   20.12.1-1nodesource1 1001
                   20.12.0-1nodesource1 1001
                   20.11.1-1nodesource1 1001
                   20.11.0-1nodesource1 1001
                   20.10.0-1nodesource1 1001
                   20.9.0-1nodesource1 1001
                   20.8.1-1nodesource1 1001
                   20.8.0-1nodesource1 1001
                   20.7.0-1nodesource1 1001
                   20.6.1-1nodesource1 1001
                   20.6.0-1nodesource1 1001
                   20.5.1-1nodesource1 1001
                   20.5.0-1nodesource1 1001
                   20.4.0-1nodesource1 1001
                   20.3.1-1nodesource1 1001
                   20.3.0-1nodesource1 1001
                   20.2.0-1nodesource1 1001
                   20.1.0-1nodesource1 1001
                   20.0.0-1nodesource1 1001
                   18.19.0+dfsg-6~deb12u2 500
                      500 http://deb.debian.org/debian bookworm/main arm64 Packages
                   18.19.0+dfsg-6~deb12u1 500
                      500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
              No problems detected
              Errors in npm tree: 0
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 3139)
              Core adapters versions
              admin:          7.6.17
              javascript:     8.9.2
              nodejs modules from github:     1
              +-- iobroker.tapo@0.4.8 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#615315d4bae5c77b153ac5067bdca8ba3ad3996f)
              Adapter State
              + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
              + system.adapter.alarm.0                  : alarm                 : raspberrypi                              -  enabled
                system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
              + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
              + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
              + system.adapter.deyeidc.0                : deyeidc               : raspberrypi                              -  enabled, port: 8899
              + system.adapter.fahrplan.0               : fahrplan              : raspberrypi                              -  enabled
              + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
                system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
                system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
                system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
              + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
              + system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              -  enabled
              + system.adapter.mihome-vacuum.2          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
              + system.adapter.nuki-extended.0          : nuki-extended         : raspberrypi                              -  enabled
              + system.adapter.ph803w.0                 : ph803w                : raspberrypi                              -  enabled
                system.adapter.roborock.0               : roborock              : raspberrypi                              -  enabled
              + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              -  enabled
              + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
              + system.adapter.tapo.0                   : tapo                  : raspberrypi                              -  enabled
              + system.adapter.telegram.1               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
              + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
              + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
              + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : raspberrypi                              -  enabled
              + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Upgrade policy: none
              Installed ioBroker-Adapters
              Used repository: stable
              Adapter    "admin"        : 7.6.17   , installed 7.6.17
              Adapter    "alarm"        : 3.7.0    , installed 3.7.0
              Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
              Adapter    "alias-manager": 2.0.0    , installed 2.0.0
              Adapter    "backitup"     : 3.3.5    , installed 3.3.5
              Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
              Adapter    "denon"        : 1.15.12  , installed 1.15.12
              Adapter    "deyeidc"      : 0.2.0    , installed 0.2.0
              Adapter    "fahrplan"     : 1.4.1    , installed 1.4.1
              Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
              Adapter    "ical"         : 1.16.2   , installed 1.16.1 [Updatable]
              Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
              Adapter    "iot"          : 3.3.0    , installed 3.3.0
              Adapter    "javascript"   : 8.9.2    , installed 8.9.2
              Controller "js-controller": 7.0.7    , installed 7.0.7
              Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
              Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
              Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
              Adapter    "ph803w"       : 1.2.0    , installed 1.2.0
              Adapter    "roborock"     : 0.6.18   , installed 0.6.18
              Adapter    "scenes"       : 3.2.3    , installed 3.2.3
              Adapter    "schoolfree"   : 1.1.10   , installed 1.1.9  [Updatable]
              Adapter    "shelly"       : 10.1.0   , installed 10.1.0
              Adapter    "shuttercontrol": 2.0.3   , installed 2.0.1  [Updatable]
              Adapter    "trashschedule": 3.3.0    , installed 3.3.0
              Adapter    "web"          : 7.0.8    , installed 7.0.8
              Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
              Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
              Objects and States
              Objects:        8590
              States:         6628
              Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
              Hit:2 http://deb.debian.org/debian bookworm InRelease
              Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
              Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
              Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       448519     33748/iobroker.js-c
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       446004     33748/iobroker.js-c
              tcp        0      0 0.0.0.0:6789            0.0.0.0:*               LISTEN      1002       6488       914/slirp4netns
              tcp        0      0 0.0.0.0:8880            0.0.0.0:*               LISTEN      1002       6494       914/slirp4netns
              tcp        0      0 0.0.0.0:8881            0.0.0.0:*               LISTEN      1002       6496       914/slirp4netns
              tcp        0      0 0.0.0.0:8882            0.0.0.0:*               LISTEN      1002       6498       914/slirp4netns
              tcp        0      0 127.0.0.1:11002         0.0.0.0:*               LISTEN      1002       6361       730/discovery
              tcp        0      0 0.0.0.0:8444            0.0.0.0:*               LISTEN      1002       6492       914/slirp4netns
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6107       732/sshd: /usr/sbin
              tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        8720       856/pihole-FTL
              tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      999        8055       856/pihole-FTL
              tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      999        8056       856/pihole-FTL
              tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1002       6490       914/slirp4netns
              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       453005     34618/io.shelly.1
              tcp        0      0 0.0.0.0:11443           0.0.0.0:*               LISTEN      1002       6500       914/slirp4netns
              tcp6       0      0 :::3000                 :::*                    LISTEN      1001       448417     34233/io.fullybrows
              tcp6       0      0 :::51989                :::*                    LISTEN      1001       449536     34424/io.nuki-exten
              tcp6       0      0 :::22                   :::*                    LISTEN      0          6109       732/sshd: /usr/sbin
              tcp6       0      0 :::53                   :::*                    LISTEN      999        8722       856/pihole-FTL
              tcp6       0      0 :::80                   :::*                    LISTEN      999        8057       856/pihole-FTL
              tcp6       0      0 :::443                  :::*                    LISTEN      999        8058       856/pihole-FTL
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       446157     33776/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       452363     34755/io.web.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        484        553/avahi-daemon: r
              udp        0      0 0.0.0.0:5514            0.0.0.0:*                           1002       6504       914/slirp4netns
              udp        0      0 0.0.0.0:3478            0.0.0.0:*                           1002       6502       914/slirp4netns
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       452785     34516/io.shelly.0
              udp        0      0 255.255.255.255:10001   0.0.0.0:*                           1002       555009     730/discovery
              udp        0      0 0.0.0.0:10003           0.0.0.0:*                           1002       6506       914/slirp4netns
              udp        0      0 0.0.0.0:36782           0.0.0.0:*                           1002       552483     914/slirp4netns
              udp        0      0 0.0.0.0:55259           0.0.0.0:*                           1001       451740     34458/io.ph803w.0
              udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        8719       856/pihole-FTL
              udp        0      0 0.0.0.0:123             0.0.0.0:*                           999        9782       856/pihole-FTL
              udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1001       451251     34397/io.mihome-vac
              udp        0      0 0.0.0.0:33046           0.0.0.0:*                           104        486        553/avahi-daemon: r
              udp        0      0 192.168.2.109:33514     0.0.0.0:*                           1002       552649     730/discovery
              udp6       0      0 :::5353                 :::*                                104        485        553/avahi-daemon: r
              udp6       0      0 :::53                   :::*                                999        8721       856/pihole-FTL
              udp6       0      0 :::123                  :::*                                999        9783       856/pihole-FTL
              udp6       0      0 fe80::9e7d:2a5f:b7c:546 :::*                                0          7193       638/NetworkManager
              udp6       0      0 :::33351                :::*                                104        487        553/avahi-daemon: r
                  at Socket.emit (node:events:524:28)
                  at UDP.onMessage (node:dgram:951:8)
              2025-08-23 18:43:58.144  - error: roborock.0 (42090) Exception-Code: ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH: error:1C80006B:Provider routines::wrong final block length
              2025-08-23 18:43:58.191  - info: roborock.0 (42090) terminating
              2025-08-23 18:43:58.193  - warn: roborock.0 (42090) Terminated (UNCAUGHT_EXCEPTION): Without reason
              2025-08-23 18:43:58.851  - info: roborock.0 (42090) terminating
              2025-08-23 18:43:59.247  - error: host.raspberrypi Caught by controller[0]: Error: error:1C80006B:Provider routines::wrong final block length
              2025-08-23 18:43:59.247  - error: host.raspberrypi Caught by controller[0]:     at Decipheriv.final (node:internal/crypto/cipher:193:29)
              2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:     at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25)
              2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:     at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33)
              2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:     at Socket.emit (node:events:524:28)
              2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:     at Socket.emit (node:domain:489:12)
              2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:     at UDP.onMessage (node:dgram:951:8) {
              2025-08-23 18:43:59.248  - error: host.raspberrypi Caught by controller[0]:   library: 'Provider routines',
              2025-08-23 18:43:59.249  - error: host.raspberrypi Caught by controller[0]:   reason: 'wrong final block length',
              2025-08-23 18:43:59.249  - error: host.raspberrypi Caught by controller[0]:   code: 'ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH'
              2025-08-23 18:43:59.249  - error: host.raspberrypi Caught by controller[0]: }
              2025-08-23 18:43:59.249  - error: host.raspberrypi instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
              2025-08-23 18:43:59.249  - info: host.raspberrypi Restart adapter system.adapter.roborock.0 because enabled
              2025-08-23 18:44:02.499  - info: tapo.0 (34846) Get camera Status failed
              2025-08-23 18:44:02.500  - info: tapo.0 (34846) No stok found for: 80211AE049E6EC914F17A219E950F4E9242DB387 this means the device is offline or connection lost. No update or commands possible
              2025-08-23 18:44:06.991  - info: tr-064.0 (34564) forEachConfiguredDevice: in GetSpecificHostEntry 1(Gioia/B8:94:E7:E7:C5:98) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
              2025-08-23 18:44:12.515  - info: tapo.0 (34846) Get camera Status failed
              2025-08-23 18:44:12.516  - info: tapo.0 (34846) No stok found for: 80211AE049E6EC914F17A219E950F4E9242DB387 this means the device is offline or connection lost. No update or commands possible
              • N nu_81
                Hier der Log.
                Danke schonmal!
                Script v.2025-08-09
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                OS is similar to:
                Docker          : false
                Kernel          : aarch64
                Userland        : 64 bit
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pihome
                HOME=/home/pihome
                iobroker
                HOME=/home/iobroker
                Display-Manager:
                Desktop:
                Session:                tty
                *** MEMORY ***
                         3796 M total memory
                         2995 M used memory
                          268 M free memory
                           38 M buffer memory
                          625 M swap cache
                          199 M total swap
                          199 M used swap
                            0 M free swap
                *** FILESYSTEM ***
                /var:
                1.2G    /var/
                486M    /var/log
                348M    /var/cache
                USB-Devices by-id:
                zigbee.X
                Extended Pan ID:
                *** MASKED ***
                Pan ID:
                *** MASKED ***
                Channel:
                *** MASKED ***
                Network Key:
                *** MASKED ***
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                admin:          7.6.17
                javascript:     8.9.2
                Adapter State
                + instance is alive
                Objects and States
                Objects:        8590
                States:         6628
                Pending Updates: 0
                Thomas BraunT
                Thomas BraunT
                #878
                @nu_81 sagte in Neuer Adapter für Roborock-Staubsauger:
                Ich habe den Verdacht, das könnte mit nodejs zusammenhängen.
                Bring die drei Adapter auf Stand und dann ein
                iob nodejs-update
                B N 2 Antworten Letzte Antwort
                  iob nodejs-update
                  B
                  B
                  breaksrmine
                  #879
                  Beim Adapter 0.6.18 kommt beim Roborock QV 35A folgende Fehler.
                  Steuern geht aber ohne Probleme
                  roborock.0
                  2025-08-23 19:17:02.540 warn Unsupported attribute: seq_type of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                  roborock.0
                  2025-08-23 19:17:02.539 warn Unsupported attribute: exit_dock of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                  roborock.0
                  2025-08-23 19:17:02.538 warn Unsupported attribute: cleaning_info of get_status with value [object Object]. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                  roborock.0
                  2025-08-23 19:17:02.458 warn Unsupported attribute: last_clean_t of get_status with value 1755969220. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                  roborock.0
                  2025-08-23 19:17:02.457 warn Unsupported attribute: switch_status of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                  roborock.0
                  2025-08-23 19:17:02.416 warn Unsupported attribute: kct of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                  roborock.0
                  2025-08-23 19:17:02.336 warn Unsupported attribute: common_status of get_status with value 2. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                  roborock.0
                  2025-08-23 19:17:02.335 warn Unsupported attribute: dss of get_status with value 169. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                  roborock.0
                  2025-08-23 19:17:02.335 warn Unsupported attribute: rss of get_status with value 2. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                  roborock.0
                  2025-08-23 19:17:02.334 warn Unsupported attribute: extra_time of get_status with value 1860. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                  roborock.0
                  2025-08-23 19:17:02.333 warn Unsupported attribute: clean_percent of get_status with value 45. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                  roborock.0
                  2025-08-23 19:17:02.172 warn Unsupported attribute: charge_status of get_status with value 1. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                  roborock.0
                  roborock.0
                  2025-08-23 19:17:01.851 warn Unsupported attribute: in_warmup of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                  roborock.0
                  2025-08-23 19:17:01.650 warn Unsupported attribute: water_shortage_status of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                  roborock.0
                  2025-08-23 19:17:01.530 warn Unsupported attribute: mop_forbidden_enable of get_status with value 1. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                  roborock.0
                  2025-08-23 19:17:01.529 warn Unsupported attribute: water_box_carriage_status of get_status with value 1. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                  roborock.0
                  2025-08-23 19:17:01.488 warn Unsupported attribute: water_box_mode of get_status with value 207. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                  roborock.0
                  2025-08-23 19:17:01.287 warn Unsupported attribute: water_box_status of get_status with value 1. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a168
                    iob nodejs-update
                    N
                    N
                    nu_81
                    #880
                    Hallo, habe das Update durchgeführt.
                    Der Fehler bleibt jedoch leider.
                    Script v.2025-08-09
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    OS is similar to:
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : 64 bit
                     11:31:58 up 11:00,  2 users,  load average: 1.93, 0.82, 0.49
                    CPU threads: 4
                    Current issues:
                                   Local time: Mon 2025-08-25 11:31:58 CEST
                               Universal time: Mon 2025-08-25 09:31:58 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pihome
                    HOME=/home/pihome
                    iobroker
                    HOME=/home/iobroker
                    Display-Manager:
                    Desktop:
                    Session:                tty
                    *** MEMORY ***
                    Mem:            4.0G        3.4G         59M         25M        599M        542M
                    Swap:           2.1G        452M        1.7G
                    Total:          6.1G        3.9G        1.8G
                    Active iob-Instances:   24
                             3796 M total memory
                             3280 M used memory
                             2278 M active memory
                             1257 M inactive memory
                               55 M free memory
                               35 M buffer memory
                              535 M swap cache
                             2047 M total swap
                              432 M used swap
                             1615 M free swap
                    top - 11:31:58 up 11:00,  2 users,  load average: 1.93, 0.82, 0.49
                    Tasks: 237 total,   1 running, 236 sleeping,   0 stopped,   0 zombie
                    %Cpu(s): 14.3 us, 14.3 sy,  0.0 ni, 71.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :   3796.9 total,     52.2 free,   3283.9 used,    571.4 buff/cache
                    MiB Swap:   2048.0 total,   1616.0 free,    432.0 used.    513.0 avail Mem
                    *** FILESYSTEM ***
                    /dev/mmcblk0p2 ext4       29G   19G  8.9G  68% /
                    tmpfs          tmpfs     1.9G  6.3M  1.9G   1% /dev/shm
                    [Mon Aug 25 00:31:18 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:5A:13:07 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=b69ad78b-02 rootfstype=ext4 fsck.repair=yes rootwait
                    [Mon Aug 25 00:31:21 2025] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
                    [Mon Aug 25 00:31:23 2025] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w.
                    /var:
                    2.8G    /var/
                    476M    /var/log
                    412M    /var/log/journal/0350b7d3c8bd4b9ca7427777c909465d
                    172M    /var/lib
                    Archived and active journals take up 411.5M in the file system.
                    15M     /opt/iobroker/backups/
                    16M     /opt/iobroker/iobroker-data/objects.jsonl
                    USB-Devices by-id:
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    /usr/bin/nodejs         v22.18.0
                    /usr/bin/node           v22.18.0
                    /usr/bin/npm            10.9.3
                    /usr/bin/npx            10.9.3
                    /usr/bin/corepack       0.33.0
                    nodejs:
                      Installed: 22.18.0-1nodesource1
                      Candidate: 22.18.0-1nodesource1
                      Version table:
                     *** 22.18.0-1nodesource1 1001
                            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                         22.17.1-1nodesource1 1001
                         22.17.0-1nodesource1 1001
                         22.16.0-1nodesource1 1001
                         22.15.1-1nodesource1 1001
                         22.15.0-1nodesource1 1001
                         22.14.0-1nodesource1 1001
                         22.13.1-1nodesource1 1001
                         22.13.0-1nodesource1 1001
                         22.12.0-1nodesource1 1001
                         22.11.0-1nodesource1 1001
                         22.10.0-1nodesource1 1001
                         22.9.0-1nodesource1 1001
                         22.8.0-1nodesource1 1001
                         22.7.0-1nodesource1 1001
                         22.6.0-1nodesource1 1001
                         22.5.1-1nodesource1 1001
                         22.5.0-1nodesource1 1001
                         22.4.1-1nodesource1 1001
                         22.4.0-1nodesource1 1001
                         22.3.0-1nodesource1 1001
                         22.2.0-1nodesource1 1001
                         22.1.0-1nodesource1 1001
                         22.0.0-1nodesource1 1001
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 39639)
                    admin:          7.6.17
                    javascript:     8.9.2
                    Adapter State
                      system.adapter.denon.0                  : denon                 : raspberrypi                              - disabled
                      system.adapter.deyeidc.0                : deyeidc               : raspberrypi                              - disabled, port: 8899
                      system.adapter.mihome-vacuum.2          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
                      system.adapter.scenes.0                 : scenes                : raspberrypi                              - disabled
                      system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
                    + instance is alive
                    Adapter    "ical"         : 1.16.2   , installed 1.16.2
                    Adapter    "schoolfree"   : 1.1.10   , installed 1.1.10
                    Adapter    "shuttercontrol": 2.0.3   , installed 2.0.3
                    Objects and States
                    Objects:        8782
                    States:         6752
                    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                    Pending Updates: 0
                    tcp        0      0 0.0.0.0:6789            0.0.0.0:*               LISTEN      1002       6662       920/slirp4netns
                    tcp        0      0 0.0.0.0:8882            0.0.0.0:*               LISTEN      1002       6672       920/slirp4netns
                    tcp        0      0 0.0.0.0:8881            0.0.0.0:*               LISTEN      1002       6670       920/slirp4netns
                    tcp        0      0 0.0.0.0:8880            0.0.0.0:*               LISTEN      1002       6668       920/slirp4netns
                    tcp        0      0 0.0.0.0:8444            0.0.0.0:*               LISTEN      1002       6666       920/slirp4netns
                    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      999        9512       863/pihole-FTL
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6540       739/sshd: /usr/sbin
                    tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        924        863/pihole-FTL
                    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      999        9513       863/pihole-FTL
                    tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1002       6664       920/slirp4netns
                    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       15151      2682/io.shelly.1
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       930        716/iobroker.js-con
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5702       716/iobroker.js-con
                    tcp        0      0 0.0.0.0:11443           0.0.0.0:*               LISTEN      1002       6674       920/slirp4netns
                    tcp        0      0 127.0.0.1:11002         0.0.0.0:*               LISTEN      1002       5094       737/discovery
                    tcp6       0      0 :::3000                 :::*                    LISTEN      1001       14447      2186/io.fullybrowse
                    tcp6       0      0 :::51989                :::*                    LISTEN      1001       11994      2364/io.nuki-extend
                    tcp6       0      0 :::80                   :::*                    LISTEN      999        9514       863/pihole-FTL
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          6542       739/sshd: /usr/sbin
                    tcp6       0      0 :::53                   :::*                    LISTEN      999        926        863/pihole-FTL
                    tcp6       0      0 :::443                  :::*                    LISTEN      999        9515       863/pihole-FTL
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       15445      2584/io.web.0
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7048       907/io.admin.0
                    udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        923        863/pihole-FTL
                    udp        0      0 0.0.0.0:123             0.0.0.0:*                           999        24743      863/pihole-FTL
                    udp        0      0 0.0.0.0:60493           0.0.0.0:*                           1001       11997      2376/io.ph803w.0
                    udp        0      0 0.0.0.0:58631           0.0.0.0:*                           1002       675873     920/slirp4netns
                    udp        0      0 0.0.0.0:5514            0.0.0.0:*                           1002       6678       920/slirp4netns
                    udp        0      0 0.0.0.0:3478            0.0.0.0:*                           1002       6676       920/slirp4netns
                    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       14856      2439/io.shelly.0
                    udp        0      0 255.255.255.255:10001   0.0.0.0:*                           1002       868410     737/discovery
                    udp        0      0 0.0.0.0:10003           0.0.0.0:*                           1002       6680       920/slirp4netns
                    udp        0      0 192.168.2.109:38760     0.0.0.0:*                           1002       868411     737/discovery
                    udp6       0      0 :::53                   :::*                                999        925        863/pihole-FTL
                    udp6       0      0 :::123                  :::*                                999        23343      863/pihole-FTL
                    udp6       0      0 :::59687                :::*                                1002       675872     920/slirp4netns
                    udp6       0      0 fe80::9e7d:2a5f:b7c:546 :::*                                0          849        644/NetworkManager
                    udp6       0      0 :::54266                :::*                                1002       675860     920/slirp4netns
                        at UDP.onMessage (node:dgram:988:8)
                    2025-08-25 11:33:11.924  - error: roborock.0 (49238) Exception-Code: ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH: error:1C80006B:Provider routines::wrong final block length
                    2025-08-25 11:33:11.957  - info: roborock.0 (49238) terminating
                    2025-08-25 11:33:11.959  - warn: roborock.0 (49238) Terminated (UNCAUGHT_EXCEPTION): Without reason
                    2025-08-25 11:33:12.555  - error: host.raspberrypi Caught by controller[0]: Error: error:1C80006B:Provider routines::wrong final block length
                    2025-08-25 11:33:12.556  - error: host.raspberrypi Caught by controller[0]:     at Decipheriv.final (node:internal/crypto/cipher:184:29)
                    2025-08-25 11:33:12.556  - error: host.raspberrypi Caught by controller[0]:     at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25)
                    2025-08-25 11:33:12.556  - error: host.raspberrypi Caught by controller[0]:     at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33)
                    2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:     at Socket.emit (node:events:518:28)
                    2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:     at Socket.emit (node:domain:489:12)
                    2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:     at UDP.onMessage (node:dgram:988:8) {
                    2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:   library: 'Provider routines',
                    2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:   reason: 'wrong final block length',
                    2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]:   code: 'ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH'
                    2025-08-25 11:33:12.557  - error: host.raspberrypi Caught by controller[0]: }
                    2025-08-25 11:33:12.557  - error: host.raspberrypi instance system.adapter.roborock.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    2025-08-25 11:33:12.558  - info: host.raspberrypi Restart adapter system.adapter.roborock.0 because enabled
                    2025-08-25 11:33:18.253  - info: tapo.0 (2625) Get camera Status failed
                    2025-08-25 11:33:18.254  - info: tapo.0 (2625) No stok found for: 80211AE049E6EC914F17A219E950F4E9242DB387 this means the device is offline or connection lost. No update or commands possible
                    2025-08-25 11:33:28.273  - info: tapo.0 (2625) Get camera Status failed
                    2025-08-25 11:33:28.274  - info: tapo.0 (2625) No stok found for: 80211AE049E6EC914F17A219E950F4E9242DB387 this means the device is offline or connection lost. No update or commands possible
                    N Ro75R 2 Antworten Letzte Antwort
                    • N nu_81
                      Script v.2025-08-09
                      *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                      OS is similar to:
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : 64 bit
                      CPU threads: 4
                      Current issues:
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pihome
                      HOME=/home/pihome
                      iobroker
                      HOME=/home/iobroker
                      Display-Manager:
                      Desktop:
                      Session:                tty
                      *** MEMORY ***
                               3796 M total memory
                               3280 M used memory
                                 55 M free memory
                                 35 M buffer memory
                                535 M swap cache
                               2047 M total swap
                                432 M used swap
                               1615 M free swap
                      *** FILESYSTEM ***
                      /var:
                      2.8G    /var/
                      476M    /var/log
                      172M    /var/lib
                      USB-Devices by-id:
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      /usr/bin/npm            10.9.3
                      /usr/bin/npx            10.9.3
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      admin:          7.6.17
                      javascript:     8.9.2
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        8782
                      States:         6752
                      Pending Updates: 0
                      N
                      N
                      nu_81
                      #881
                      @nu_81 Hallo, hat jemand hierzu noch eine Idee?
                      Danke euch schonmal
                      • N nu_81
                        Script v.2025-08-09
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        OS is similar to:
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : 64 bit
                        CPU threads: 4
                        Current issues:
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pihome
                        HOME=/home/pihome
                        iobroker
                        HOME=/home/iobroker
                        Display-Manager:
                        Desktop:
                        Session:                tty
                        *** MEMORY ***
                                 3796 M total memory
                                 3280 M used memory
                                   55 M free memory
                                   35 M buffer memory
                                  535 M swap cache
                                 2047 M total swap
                                  432 M used swap
                                 1615 M free swap
                        *** FILESYSTEM ***
                        /var:
                        2.8G    /var/
                        476M    /var/log
                        172M    /var/lib
                        USB-Devices by-id:
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        /usr/bin/npm            10.9.3
                        /usr/bin/npx            10.9.3
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        admin:          7.6.17
                        javascript:     8.9.2
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        8782
                        States:         6752
                        Pending Updates: 0
                        Ro75R
                        Ro75R
                        Ro75
                        #882
                        Previously detected issues: ~ Under-voltage has occurred ~ Arm frequency capping has occurred ~ Throttling has occurred ~ Soft temperature limit has occurred
                        Originalnetzteil verwenden - kein Ladegerät! Sorge für gute Kühlung.
                        Ro75.
                        • D3ltoroxpD
                          D3ltoroxpD
                          D3ltoroxp
                          #883
                          ich kann leider vom Adapter keine DP abgreifen, der mit den Status der Station anzeigt. Tank voll, leer usw. Hab den roborock Qrevo Edge S5A + Station.
                          • Ro75R Ro75
                            Ro75.
                            N
                            N
                            nu_81
                            #884
                            @ro75
                            Danke, ich benutze das Originalnetzteil.
                            Das mit der Kühlung hatte ich schon gesehen und kümmere mich nun um ein anderes Gehäuse, bzw. um einen Lüfter.
                            Das Problem mit der Kühlung verursacht aber doch nicht das Problem am Adapter, oder?!
                            • D3ltoroxpD
                              D3ltoroxpD
                              D3ltoroxp
                              #885
                              Ich sehe auch grad, er connected gar nicht mehr mit dem Sauger. Das ist neu, es ging mal.
                              roborock.0
                              2025-09-01 18:08:41.980	info	terminating
                              roborock.0
                              2025-09-01 18:08:41.657	info	MQTT connection established {"cmd":"connack","retain":false,"qos":0,"dup":false,"length":2,"topic":null,"payload":null,"sessionPresent":false,"returnCode":0}.
                              roborock.0
                              2025-09-01 18:08:41.478	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                              roborock.0
                              2025-09-01 18:08:41.477	info	terminating
                              roborock.0
                              2025-09-01 18:08:41.468	error	this.homeData is not initialized. Initialize via updateHomeData() first
                              roborock.0
                              2025-09-01 18:08:41.467	error	Error: this.homeData is not initialized. Initialize via updateHomeData() first at http_api.getDevices (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:192:10) at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:112:39)
                              roborock.0
                              2025-09-01 18:08:41.464	error	unhandled promise rejection: this.homeData is not initialized. Initialize via updateHomeData() first
                              roborock.0
                              2025-09-01 18:08:41.463	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              roborock.0
                              2025-09-01 18:08:41.462	info	MQTT initialized
                              roborock.0
                              2025-09-01 18:08:41.418	error	No homeId found
                              roborock.0
                              2025-09-01 18:08:41.417	error	failed to get getHomeDetail: invalid token
                              • D3ltoroxpD D3ltoroxp
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                roborock.0
                                N
                                N
                                nu_81
                                #886
                                Habe den Adapter komplett entfernt und neu installiert.
                                Der Fehler bleibt leider.
                                Jemand noch eine Idee?
                                host.raspberrypi
                                2025-09-01 20:11:10.015	info	Restart adapter system.adapter.roborock.0 because enabled
                                host.raspberrypi
                                2025-09-01 20:11:10.015	error	instance system.adapter.roborock.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                host.raspberrypi
                                2025-09-01 20:11:10.015	error	Caught by controller[0]: }
                                host.raspberrypi
                                2025-09-01 20:11:10.015	error	Caught by controller[0]: code: 'ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH'
                                host.raspberrypi
                                2025-09-01 20:11:10.015	error	Caught by controller[0]: reason: 'wrong final block length',
                                host.raspberrypi
                                2025-09-01 20:11:10.015	error	Caught by controller[0]: library: 'Provider routines',
                                host.raspberrypi
                                2025-09-01 20:11:10.015	error	Caught by controller[0]: at UDP.onMessage (node:dgram:988:8) {
                                host.raspberrypi
                                2025-09-01 20:11:10.014	error	Caught by controller[0]: at Socket.emit (node:domain:489:12)
                                host.raspberrypi
                                2025-09-01 20:11:10.014	error	Caught by controller[0]: at Socket.emit (node:events:518:28)
                                host.raspberrypi
                                2025-09-01 20:11:10.014	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33)
                                host.raspberrypi
                                2025-09-01 20:11:10.014	error	Caught by controller[0]: at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25)
                                host.raspberrypi
                                2025-09-01 20:11:10.014	error	Caught by controller[0]: at Decipheriv.final (node:internal/crypto/cipher:184:29)
                                host.raspberrypi
                                2025-09-01 20:11:10.014	error	Caught by controller[0]: Error: error:1C80006B:Provider routines::wrong final block length
                                roborock.0
                                2025-09-01 20:11:09.673	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                roborock.0
                                2025-09-01 20:11:09.671	info	terminating
                                roborock.0
                                2025-09-01 20:11:09.641	error	Exception-Code: ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH: error:1C80006B:Provider routines::wrong final block length
                                roborock.0
                                2025-09-01 20:11:09.641	error	Error: error:1C80006B:Provider routines::wrong final block length at Decipheriv.final (node:internal/crypto/cipher:184:29) at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33) at Socket.emit (node:events:518:28) at Socket.emit (node:domain:489:12) at UDP.onMessage (node:dgram:988:8)
                                roborock.0
                                2025-09-01 20:11:09.640	error	uncaught exception: error:1C80006B:Provider routines::wrong final block length
                                roborock.0
                                2025-09-01 20:11:07.212	info	MQTT initialized
                                roborock.0
                                2025-09-01 20:11:05.656	info	Starting adapter. This might take a few minutes depending on your setup. Please wait.
                                roborock.0
                                2025-09-01 20:11:05.626	info	starting. Version 0.6.18 in /opt/iobroker/node_modules/iobroker.roborock, node: v22.18.0, js-controller: 7.0.7
                                • N nu_81
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  N
                                  N
                                  nu_81
                                  #887
                                  @nu_81 said in Neuer Adapter für Roborock-Staubsauger:
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  host.raspberrypi
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  roborock.0
                                  Hab es durch iÍnstallation des dev_ts gelöst.
                                  • N nu_81
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    N
                                    N
                                    nu_81
                                    #888
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    host.raspberrypi
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    Hab es durch Installation des dev_ts gelöst.
                                    • N
                                      N
                                      Nachtfuchs
                                      #889
                                      Hallo Gemeinde,
                                      wir sind seit gestern Besitzer des QRevo Slim und nun soll dieser natürlich auch mit dem ioBroker sprechen. Adapter aus Adapterliste ausgewählt, aber er wirft diese Fehlermeldungen aus - kennt das jemand?
                                      Dank euch
                                      Thomas BraunT B 2 Antworten Letzte Antwort
                                      • N Nachtfuchs
                                        Hallo Gemeinde,
                                        Dank euch
                                        Thomas BraunT
                                        Thomas BraunT
                                        #890
                                        @nachtfuchs
                                        iob stop
                                        iob fix
                                        iob start
                                        Und bring deine nodejs-Installation in Ordnung. Keine aktuelle Version verwendet npm 10.7.0.
                                        • N
                                          N
                                          Nachtfuchs
                                          #891
                                          @Thomas-Braun
                                          Mal wieder unglaublicher support, DANKE!
                                          Und danke für den Hinweis, werde mich mal am Wochenende an Dein nodejs Fixer Skript machen.
