  4. Hilfe beim Einrichten von Sonoff Zigbee 3.0 USB Dongle Plus
34 Beiträge 5 Kommentatoren 12.3k Aufrufe 5 Beobachtet
  • H Honnkoponko
    Hallo @Thomas-Braun
    Könntest du mir auch mit USB SonOff helfen ich bekomme folgendes Fehler
    2024-11-18 11:51:00.730  - info: host.domiobroker77 "system.adapter.zigbee.0" disabled
    2024-11-18 11:51:00.731  - info: host.domiobroker77 stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2024-11-18 11:51:00.739  - info: zigbee.0 (1725) Got terminate signal TERMINATE_YOURSELF
    2024-11-18 11:51:00.742  - info: zigbee.0 (1725) cleaned everything up...
    2024-11-18 11:51:00.754  - info: zigbee.0 (1725) Zigbee: disabling joining new devices.
    2024-11-18 11:51:00.774  - warn: zigbee.0 (1725) Failed to stop zigbee during startup
    2024-11-18 11:51:00.775  - info: zigbee.0 (1725) terminating
    2024-11-18 11:51:00.776  - debug: zigbee.0 (1725) Plugin sentry destroyed
    2024-11-18 11:51:00.777  - info: zigbee.0 (1725) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-11-18 11:51:00.830  - info: host.domiobroker77 stopInstance system.adapter.zigbee.0 send kill signal
    2024-11-18 11:51:01.245  - info: zigbee.0 (1725) terminating
    2024-11-18 11:51:01.366  - info: host.domiobroker77 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-11-18 11:51:11.212  - info: host.domiobroker77 "system.adapter.zigbee.0" enabled
    2024-11-18 11:51:11.663  - info: host.domiobroker77 instance system.adapter.zigbee.0 in version "1.10.3" started with pid 1835
    2024-11-18 11:51:15.573  - debug: zigbee.0 (1835) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2024-11-18 11:51:15.620  - debug: zigbee.0 (1835) Objects client ready ... initialize now
    2024-11-18 11:51:15.623  - debug: zigbee.0 (1835) Objects create System PubSub Client
    2024-11-18 11:51:15.625  - debug: zigbee.0 (1835) Objects create User PubSub Client
    2024-11-18 11:51:15.697  - debug: zigbee.0 (1835) Objects client initialize lua scripts
    2024-11-18 11:51:15.709  - debug: zigbee.0 (1835) Objects connected to redis: 127.0.0.1:9001
    2024-11-18 11:51:15.753  - debug: zigbee.0 (1835) Redis States: Use Redis connection: 127.0.0.1:9000
    2024-11-18 11:51:15.773  - debug: zigbee.0 (1835) States create System PubSub Client
    2024-11-18 11:51:15.775  - debug: zigbee.0 (1835) States create User PubSub Client
    2024-11-18 11:51:15.847  - debug: zigbee.0 (1835) States connected to redis: 127.0.0.1:9000
    2024-11-18 11:51:15.891  - debug: zigbee.0 (1835) Plugin sentry Initialize Plugin (enabled=true)
    2024-11-18 11:51:16.397  - info: zigbee.0 (1835) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.16.0, js-controller: 6.0.9
    2024-11-18 11:51:16.446  - debug: zigbee.0 (1835) Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"extenedPanID":[139,122,111,94,77,60,43,26]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_5a52e2baefdbed118632e92d62c613ac-if00-port0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
    2024-11-18 11:51:16.535  - info: zigbee.0 (1835) delete old Backup files. keep only last 10
    2024-11-18 11:51:16.537  - info: zigbee.0 (1835) Starting Zigbee  npm ...
    2024-11-18 11:51:16.600  - debug: zigbee.0 (1835) Starting zigbee-herdsman...
    2024-11-18 11:51:17.011  - info: zigbee.0 (1835) Installed Version: iobroker.zigbee@1.10.3
    2024-11-18 11:51:17.405  - debug: zigbee.0 (1835) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2024_11_18-11_51_16.tar.gz success
    2024-11-18 11:51:37.754  - error: zigbee.0 (1835) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    2024-11-18 11:51:37.755  - error: zigbee.0 (1835) Failed to start Zigbee
    2024-11-18 11:51:37.756  - error: zigbee.0 (1835) Error herdsman start
    2024-11-18 11:51:47.761  - info: zigbee.0 (1835) Try to reconnect. 1 attempts left
    2024-11-18 11:51:47.762  - info: zigbee.0 (1835) Starting Zigbee  npm ...
    2024-11-18 11:51:47.769  - debug: zigbee.0 (1835) Starting zigbee-herdsman...
    2024-11-18 11:51:47.779  - info: zigbee.0 (1835) Installed Version: iobroker.zigbee@1.10.3
    2024-11-18 11:51:47.975  - error: zigbee.0 (1835) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
    2024-11-18 11:51:47.978  - error: zigbee.0 (1835) Failed to start Zigbee
    2024-11-18 11:51:47.979  - error: zigbee.0 (1835) Error herdsman start
    Hier ich liste was ich gemacht habe:
    1. Mit
    /dev/serial/by-id/
    Habe ich Device bekommen:
    mwit@domiobroker77:~ $ ls /dev/serial/by-id/
    1. In Adapter Setting habe ich das eingetragen (mit DevID und ExtDevID)
    Adapter started und will nicht grün sein...;(
    Was kann ich dort anpassen?
    Wie kann ich aus Putty nur zigbee Logs zeigen?
    Mit
    mwit@domiobroker77:~ $ iob logs --watch | uniq
    Zeig alle Adapter Logs. Kann ich das irgendwie filtern?
    haselchenH Offline
    haselchenH Offline
    haselchen
    @honnkoponko
    Es reicht ja wenn du das Log vom Adapterstart zeigst.
    Eventuell im Adapter noch den Debug Modus anschalten.
    • H Honnkoponko
      Hallo @Thomas-Braun
      1. Mit
      /dev/serial/by-id/
      Mit
      @honnkoponko sagte in Hilfe beim Einrichten von Sonoff Zigbee 3.0 USB Dongle Plus:
      Deutet auf Trouble mit der Firmware hin. Steck das Ding mal aus und nach ein paar Minuten wieder ein. Betreibst du den Stick an einer USB-Verlängerung?
      Ordentlicher Reboot schadet auch nichts.
      H 1 Antwort Letzte Antwort
        Honnkoponko
        Reboot habe ich gemacht
        Ich probiere noch mit rein und raus
        Ich nutze USB Verlängerung (nicht möglich direkt in USB port einstecken)
        Ist das fixierbar oder einfacher CC2652P Zigbee Dongle kaufen? (habe ich gelesen CC2531 haben Probleme)
        Soll ich andere USB Port versuchen - macht das Sinn?
        • H Honnkoponko
          Ja, aber der Sonoff 3.0 hat ohnehin einen anderen Chipsatz, nicht den CC2531.
          Ich weiß nie, welchen der beiden bei Sonoff gerade verwendet wird. Stell mal testweise den Stack auf EZSP (oder so ähnlich) um.
            Honnkoponko
            schrieb am zuletzt editiert von Honnkoponko
            Habe ich rein raus gemacht und nichts.
            Für EZSP EInstellung:
            zigbee.0
            PID
            Time
            debug
            Message
            zigbee.0
            2052	2024-11-18 12:48:57.567	error	Error herdsman start
            zigbee.0
            2052	2024-11-18 12:48:57.567	error	Failed to start Zigbee
            zigbee.0
            2052	2024-11-18 12:48:57.566	error	Starting zigbee-herdsman problem : "Failure to connect"
            zigbee.0
            2052	2024-11-18 12:48:27.322	info	Installed Version: iobroker.zigbee@1.10.3
            zigbee.0
            2052	2024-11-18 12:48:27.312	debug	Starting zigbee-herdsman...
            zigbee.0
            2052	2024-11-18 12:48:27.304	info	Starting Zigbee npm ...
            zigbee.0
            2052	2024-11-18 12:48:27.303	info	Try to reconnect. 1 attempts left
            zigbee.0
            2052	2024-11-18 12:48:17.297	error	Error herdsman start
            zigbee.0
            2052	2024-11-18 12:48:17.296	error	Failed to start Zigbee
            zigbee.0
            2052	2024-11-18 12:48:17.294	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
            Ich habe ZBDongle-E so ich denke es ist CC2652P CHipset
            Einstellung sollte TI Z-Stack/CCxxxx sein
            Was kann ich noch probieren?
            Andere USB Port oder was?
            DOngle ist in USB 2.0 - soll ich USB 3.0 nutzen?
            Oder USB-Verlängerung ist zu lange - ich habe 5m...Kann das Probleme machen?
            AsgothianA haselchenH 2 Antworten Letzte Antwort
            • H Honnkoponko
              zigbee.0
              PID
              Time
              debug
              Message
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              zigbee.0
              PID
              Time
              debug
              Message
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              Der Sonoff-ZBDongle-e sollte einen EZSP Chipsatz haben. Ansonsten beschwert sich der Adapter über eine inkonsistente Konfiguration. Daher bitte
              • Adapter anhalten
              • sicher gehen das kein Zigbee Prozess mehr läuft - das kann bis zu 20 Sekunden dauern
              • die Datei nvbackup.json im Verzeichnis /opt/iobroker/iobroker-data/zigbee_0 löschen
              • adapter wieder starten
              A.
              • H Honnkoponko
                zigbee.0
                PID
                Time
                debug
                Message
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                haselchenH Offline
                haselchenH Offline
                haselchen
                @honnkoponko
                Nun mal nicht so hippelig.
                Hast Du ein -E oder -P ?
                Welche Firmware ist auf dem Stick?
                Wenn wir das alles geklärt haben , versuch mal die PAN ID auf Ausgangslage zu setzen .
                Alles große D.
                Aber erst wenn das oben geklärt ist.
                • haselchenH haselchen
                  @honnkoponko
                  Alles große D.
                  Honnkoponko
                  @haselchen
                  Ich habe ZBDongle-E mit Firmware 6.10.3.0 - ich kan auf 7.4.4.0 updaten wenn Sinn macht
                  PAN_ID meinst du in Iobroker ExtID oder auf USB Geraät (nicht sicher wie ich das mache)
                  • H Honnkoponko
                    @haselchen
                    haselchenH Offline
                    haselchenH Offline
                    haselchen
                    @honnkoponko
                    Bevor Du ein Update machst .
                    Probier im Adapter aus, in der Zeile Network ID alles D reinzuschreiben.
                    Gib dann mal Feedback mit Log Auszug bitte
                    • AsgothianA Asgothian
                      zigbee.0
                      PID
                      Time
                      debug
                      Message
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      • Adapter anhalten
                      A.
                      Honnkoponko
                      @asgothian said in Hilfe beim Einrichten von Sonoff Zigbee 3.0 USB Dongle Plus:
                      zigbee.0
                      PID
                      Time
                      debug
                      Message
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      • Adapter anhalten
                      A.
                      Genau das hat Problem behoben vielen Dank dafür!!!!
                      SOll ich Firmware Update machen auf Sonoff oder ist 6.10.3.0 ok?
                        @honnkoponko
                        Honnkoponko
                        @haselchen
                        Ich habe auf DDD geändert plus @Asgothian Punkte gemacht und jetzt ist ok.
                        In dem Fall FIrmware Upgrade macht Sinn oder besser altes FW haben?
                        • H Honnkoponko
                          @haselchen
                          haselchenH Offline
                          haselchenH Offline
                          haselchen
                          @honnkoponko
                          Da ist vermutlich @Asgothian der Experte.
                          Ich hab den -P Stick.
                          Musste mal schauen, welche stabil ist und aufgespielt werden kann.
                            @honnkoponko
                            Honnkoponko
                            @Asgothian
                            Macht das Sinn Sonoff zu upgraden? Ich habe jetzt 6.10.3.0
                            Bring das etwas wenn ich auf 7.4.xx Update mache?
                            • H Honnkoponko
                              @Asgothian
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              @Asgothian
                              Mit dem EZSP Chipsatz hab ich wenig Erfahrung. Ich empfehle eigentlich eher bei der alten Firmware zu bleiben es sei denn es gibt Auffälligkeiten damit.
                              A.
