  4. Skript LOWBAT
    5.8k
Skript LOWBAT
201 Beiträge 44 Kommentatoren 67.0k Aufrufe 14 Beobachtet
    deifel
    #161
    Nein, unter meinen 5 CUXD-Geräten gibt es keinen LowBat Datenpunkt.
    Warnmeldungen erscheinen aber genau für die 5 Geräte im Log.
    • D deifel
      #162
      @deifel sagte:
      Welche ?
        deifel
        #163
        10:30:00.016	warn	javascript.0 (28564) at script.js.common.Lowbat:20:10
        10:30:00.016	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
        10:30:00.016	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
        10:30:00.017	warn	javascript.0 (28564) at script.js.common.Lowbat:21:19
        10:30:00.017	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
        10:30:00.017	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
        10:30:00.018	info	javascript.0 (28564) script.js.common.Lowbat: Geräte Nr. 101: undefined: null
        10:30:00.018	warn	javascript.0 (28564) at script.js.common.Lowbat:20:10
        10:30:00.018	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
        10:30:00.018	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
        10:30:00.019	warn	javascript.0 (28564) at script.js.common.Lowbat:21:19
        10:30:00.019	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
        10:30:00.019	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
        10:30:00.020	info	javascript.0 (28564) script.js.common.Lowbat: Geräte Nr. 102: undefined: null
        10:30:00.021	warn	javascript.0 (28564) at script.js.common.Lowbat:20:10
        10:30:00.021	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
        10:30:00.021	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
        10:30:00.022	warn	javascript.0 (28564) at script.js.common.Lowbat:21:19
        10:30:00.022	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
        10:30:00.022	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
        10:30:00.023	info	javascript.0 (28564) script.js.common.Lowbat: Geräte Nr. 103: undefined: null
        10:30:00.023	warn	javascript.0 (28564) at script.js.common.Lowbat:20:10
        10:30:00.023	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
        10:30:00.023	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
        10:30:00.024	warn	javascript.0 (28564) at script.js.common.Lowbat:21:19
        10:30:00.024	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
        10:30:00.024	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
        10:30:00.024	info	javascript.0 (28564) script.js.common.Lowbat: Geräte Nr. 104: undefined: null
        10:30:00.025	warn	javascript.0 (28564) at script.js.common.Lowbat:20:10
        10:30:00.025	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
        10:30:00.025	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
        10:30:00.026	warn	javascript.0 (28564) at script.js.common.Lowbat:21:19
        10:30:00.026	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
        10:30:00.026	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
        10:30:00.026	info	javascript.0 (28564) script.js.common.Lowbat: Geräte Nr. 105: undefined: null
        10:30:00.026	info	javascript.0 (28564) script.js.common.Lowbat: Text:
        10:30:00.026	info	javascript.0 (28564) script.js.common.Lowbat: Anzahl Geräte: 106 # davon LOWBAT erkannt: 0
        • D deifel
          #164
          @deifel Welche IDs gibt das Test-Skript mit den Nummern 101 bis 105 aus ?
            deifel
            #165
            @paul53 said in Skript LOWBAT:
            $('channel[state.id=*0.LOWBAT]').each(function(id, i) { if(i > 82) log(i + ': ' + id); });
            10:35:50.771	info	javascript.0 (28564) script.js.common.TEST: 100: hm-rpc.0.QEQ0087728.0.LOWBAT
            10:35:50.771	info	javascript.0 (28564) script.js.common.TEST: 101: hm-rpc.1.CUX2801001.0.LOWBAT
            10:35:50.771	info	javascript.0 (28564) script.js.common.TEST: 102: hm-rpc.1.CUX4000001.0.LOWBAT
            10:35:50.771	info	javascript.0 (28564) script.js.common.TEST: 103: hm-rpc.1.CUX9000002.0.LOWBAT
            10:35:50.771	info	javascript.0 (28564) script.js.common.TEST: 104: hm-rpc.1.CUX9000003.0.LOWBAT
            10:35:50.771	info	javascript.0 (28564) script.js.common.TEST: 105: hm-rpc.1.CUX9000004.0.LOWBAT
              deifel
              #166
              Hab die Datenpunkte gefunden. Indicator.lowbat heißen die.
              Soll / muss ich die entfernen?
              • D deifel
                #167
                @deifel Erweitere mal den $Selector:
                $('channel[state.id=hm-rpc.0*0.LOWBAT]').each(function(id, i) {
                  deifel
                  #168
                  Damit bekomme ich die CUXD-Geräte nicht mehr angezeigt, nur die "korrekten" Geräte.
                  • D deifel
                    #169
                    @deifel Dann übernehme die Erweiterung in das Lowbat-Skript.
                      deifel
                      #170
                      Ich danke Dir! Wenn ich das so übernehme, dann fehlen mir leider die Geräte aus der HM-IP-Instanz :/
                        deifel
                        #171
                        Kannst Du mir sagen, wie ich die Geräte aus meiner HM-IP-Instanz (rpc.2) noch dazu bekomme?
                        Diese werden nicht gefunden. Die Datenpunkte LOWBAT sind aber vorhanden.
                        Vielen DANK!
                        • D deifel
                          Ich habe das Gerät jetzt manuell unter Objekte bei der Funktion "Batteriebetrieb" rausgenommen. Dort stand es drin.
                          Jetzt läuft das Script durch. Am Schluss erscheinen Warnmeldungen für die CUXD-Geräte, obwohl diese nicht im Gewerk "Batteriebetrieb" sind.
                          Ist diese Warnmeldung korrekt?
                          #172
                          @deifel sagte:
                          Dann erweitere den $Selector anstelle von "hm-rpc.0" um das Gewerk (Schreibweise groß/klein in der enum-ID beachten)
                          $('channel[state.id=*0.LOWBAT](functions=Batteriebetrieb)').each(function(id, i) {
                             log(i + ': ' + id);
                          Werden dann alle "richtigen" IDs geloggt ?
                          • D deifel
                            Vielen DANK!
                            dslraserD Offline
                            dslraserD Offline
                            dslraser
                            #173
                            @deifel sagte in Skript LOWBAT:
                            Bei mir heißen die HM-IP LOW_BAT und nicht LOWBAT.
                              deifel
                              #174
                              Danke - das hab ich versucht. Eigenartigerweise wird damit nichts gefunden :(
                              Ich verzweifle noch.
                              "Batteriebetrieb" ist korrekt geschrieben.
                              Die Datenpunkte unter den IP-Geräten heißen allerdings "LOW_BAT".
                              Mit dem Selektor :
                                 log(i + ': ' + id);
                              bekomme ich kein Ergebnis (0 Geräte).
                              Mit dem Selektor:
                              bekomme ich nur die von der normalen HM-Instanz.
                              und mit dem Selektor:
                              bekomme ich die normalen und die CuxD - aber auch keine HM-IP-Geräte
                                deifel
                                #175
                                $('channel[state.id=hm-rpc.*0.LOW*](functions=Batteriebetrieb)').each(function(id, i) {
                                   if(i > 1) log(i + ': ' + id);
                                Gibt mir alle aus, also inkl. HMIP und auch den CUX-D-Geräten. Wenn ich jetzt noch die CUXD weg bekomme, dann wärs perfekt.
                                • D deifel
                                  #176
                                  @deifel sagte:
                                     if(id.indexOf('CUX') == -1) log(i + ': ' + id);
                                    deifel
                                    #177
                                    Leider nein, damit findet er nichts :(
                                    dslraserD paul53P 2 Antworten Letzte Antwort
                                    • D deifel
                                      dslraserD Offline
                                      dslraserD Offline
                                      dslraser
                                      #178
                                      @deifel
                                      Ich bin unterwegs und am Handy, deshalb bekomme ich das Script nicht kopiert, aber hier ein Screenshot vom Selektor, wie es bei mir funktioniert.
                                      • D deifel
                                        #179
                                        @deifel sagte:
                                        Ohne functions ?
                                        $('channel[state.id=hm-rpc.*0.LOW*]').each(function(id, i) {
                                          deifel
                                          #180
                                          Danke Euch Beiden! Es klappt jetzt mit beiden Varianten. Wobei evtl. das von dslraser sicherer ist, da es nicht nur noch low* abfragt - keine Ahnung, was in Zukunft sonst noch "low" wird ;)
                                          Vielen Dank für die tatkräftige Unterstützung!!!
