  4. Skript LOWBAT
Skript LOWBAT
201 Beiträge 44 Kommentatoren 68.6k Aufrufe 14 Beobachtet
    deifel
    #181
    Kleine Ergänzung: Bei der Lösung von dslraser werden die cux-Geräte gefunden und eine Warnung angezeigt...
    Ich lass es jetzt trotzdem so drin
    • D deifel
      #182
      @deifel sagte:
      Es hätte mich auch sehr gewundert, wenn nicht.
      • X Xanon
        ich setzte dieses Skript ein, um mich über leere Batterien informieren zu lassen.
        //Add device rules
        addDeviceCounter("lowbat_ip",      $('channel[state.id=*.LOW_BAT]'),                     true);
        addDeviceCounter("lowbat",         $('channel[state.id=*.LOWBAT]'),                      true);
        addDeviceCounter("sticky_unreach", $('channel[state.id=*.STICKY_UNREACH]'),              true);
        addDeviceCounter("unreach",        $('channel[state.id=*.UNREACH]'),                     true);
        addDeviceCounter("config_pending", $('channel[state.id=*.CONFIG_PENDING]'),              true);
        //addDeviceCounter("open_windows",   $('channel{TYPE=SHUTTER_CONTACT}[state.id=*.STATE]'), true);
        //addDeviceCounter("on_lights",      $('channel{TYPE=DIMMER}[state.id=*.LEVEL]'),          function(state){return state>0;});
        addDeviceCounter("open_shutters",  $('channel{TYPE=BLIND}[state.id=*.LEVEL]'),           function(state){return state>0;});
        //addDeviceCounter("playing_music",  $('channel[state.id=*audio-*.playing]'),              true);
         * Code - do not change anything bellow this line *
        function addDeviceCounter(name, selector, val_to_count) {
            //Total amount of devices found by selector
            var state_total = 'deviceCounter.' + name + '.total';
            createState(state_total, 0);
            //List of devices that match condition
            var state_list = 'deviceCounter.' + name + '.list';
            createState(state_list, "");
            //Number of devices that match condition
            var state_counter = 'deviceCounter.' + name + '.counter';
            createState(state_counter, 0);
            function countDevs(obj) {
                var d_count = 0;
                var d_list  = [];
                selector.each(function (id, i) {
                    var status = getState(id).val;
                    var obj    = getObject(id);
                    if ((typeof val_to_count === 'function' && val_to_count(status)) ||
                        (typeof val_to_count === 'boolean'  && val_to_count == status)) {
                        //Get parent object
                        var parentChannelId = id.slice(id.lastIndexOf("."));
                        var parentDevicelId = id.split(".").slice(0,-2).join(".");
                        var deviceObject = getObject(parentDevicelId);
                        //remember device name
                        d_list.push(deviceObject.common.name);
                    ++d_count;                                                 // Zählt die Anzahl der vorhandenen Geräte unabhängig vom Status
                log(name + "(" + d_count + "): " + d_list);
                setState(state_list,     d_list.join(' '));
                setState(state_counter,  d_list.length);
                setState(state_total,    d_count);
            //Re-evaluate when a device status changes
            selector.on(function(obj) {    // bei Zustandänderung *. LOWBAT in allen Gewerken
                countDevs(obj);
            //Re-evaluate each hour
            schedule("*/1 * * * *", countDevs);
            //Evaluate for the first time
            countDevs();
        Ich habe LOWBAT und LOW_BAT (also IP Komponenten) im Einsatz.
        Nun wollte ich gerne die beiden States zu einer LOWBAT State zusammenfügen.
        Habe es mit
        addDeviceCounter("lowbat",      $('channel[state.id=*.LOW_BAT]'),                     true);
        versucht, aber statt beide States zusammenzuzählen werden mir bei jedem Timer Event (steht zu Testzwecken auf 1 Min.) mal der eine angezeigt / angesagt und mal der andere.
        Gibt es überhaupt eine Möglichkeit beide States in einem LOWBAT anzeigen zu lassen?
        Kann mir einer sagen, was ich falsch mache oder anders machen muß?
        Vielen Dank schon mal für die Hilfe.
        Xanon
        FoggF Offline
        FoggF Offline
        Fogg
        #183
        @Xanon said in Skript LOWBAT:
        Danke, das Skript sieht gut aus und funktionierte auf anhieb!!
        Um Deine Frage zu beantworten, wie wäre es mit:
        addDeviceCounter("lowbat",      $('channel[state.id=*.LOW_BAT]') + $('channel[state.id=*.LOWBAT]'),                     true);
        Habs aber nicht ausprobiert, habe keine IP Komponenten.
          markphilip
          #184
          sorry das ich den alten thread noch mal auspacke. Ich habe allerdings das problem das meine Homematic Ip Komponenten nicht erkannt werden.
          Ich habe das Script folgendermaßen geändert:
          createState('zählenLowbat.möglicheLOWBAT', 0); // wenn benötigt: Anzahl der Geräte mit Batterie
          createState('zählenLowbat.anzahlLOWBAT', 0); // wenn benötigt: Anzahl der vorhandenen LOWBAT
          createState('zählenLowbat.textLOWBAT', " "); // Namen LOWBAT, die an sind als Variable unter Javascript.0 anlegen
          var cacheSelectorLOWBAT = $('channel[state.id=*0.LOWBAT]'); // für Homematic
          var cacheSelectorLOW_BAT = $('channel[state.id=*0.LOW_BAT]'); // für Homematic IP
          function countLowbat(obj) {
          // Setzt die Zähler vor dem Durchlauf aller Elemente *.LOWBAT auf 0
          var moeglicheLOWBAT = 0;
          var textLOWBAT = [];
          if (obj) {
          log('Auslösender Aktor: ' + obj.id + ': ' + obj.newState.val); // Info im Log, welcher Zustand sich geändert hat
          } else {
          log('Ausgelöst bei Timer');
          cacheSelectorLOWBAT.each(function (id, i) { // Schleife für jedes gefundenen Element *0.LOWBAT
          var status = false;
          if(getState(id)) {
          status = getState(id).val; // Zustand *0.LOWBAT abfragen (jedes Element)
          if (status === true) { // wenn Zustand = true, wird das Array erweitert
          textLOWBAT.push(obj.common.name); // Zu Array hinzufügen
          log("Geräte Nr. " + i + ": " + getObject(id).common.name + ": " + status);
          ++moeglicheLOWBAT; // Zählt die Anzahl der vorhandenen Geräte unabhängig vom Status
          // Schleife ist durchlaufen. Im Log wird der aktuelle Status (Anzahl, davon LOWBAT zutreffend) ausgegeben
          log("Text: " + textLOWBAT);
          log("Anzahl Geräte: " + moeglicheLOWBAT + " # davon LOWBAT erkannt: " + textLOWBAT.length);
          // die ermittelten Werte werden als javascript.0. Variable in ioBroker gespeichert (z.B. für die Verarbeitung in VIS)
          setState("zählenLowbat.textLOWBAT", textLOWBAT.join(',<br>')); // Schreibt die Namen der Geräte mit LOWBAT Meldung
          setState("zählenLowbat.anzahlLOWBAT", textLOWBAT.length); // Schreibt die aktuelle Anzahl der LOWBAT-Meldungen
          setState("zählenLowbat.möglicheLOWBAT", moeglicheLOWBAT); // Schreibt die Anzahl der vorhandenen Batterie-Geräte
          cacheSelectorLOWBAT.on(function(obj) { // bei Zustandänderung . LOWBAT in allen Gewerken
          countLowbat(obj);
          schedule("
          /60 * * * *", function () { //oder!! soll entweder ausgelöst werden alle 10 Minuten
          log("===>Will be triggered every 60 minutes!");
          countLowbat();
          muss ich sonst noch was ändern?
          • M markphilip
            if (obj) {
            } else {
            var status = false;
            if(getState(id)) {
            countLowbat(obj);
            schedule("
            countLowbat();
            #185
            @markphilip sagte:
            Du verwendest anschließend nur cacheSelectorLOWBAT. Ändere den mal in
            const cacheSelectorLOWBAT  = $('hm-rpc.*.0.LOW*');
            Javascript-Code bitte immer in Code tags </> posten.
            opossumO 1 Antwort Letzte Antwort
              @markphilip sagte:
              opossumO Offline
              opossumO Offline
              opossum
              schrieb am zuletzt editiert von opossum
              #186
              Hallo, @paul53,
              ich habe das Batteriescript im Einsatz, läuft auch und zeigt mir zuverlässig die LowBats an.
              Jetzt habe ich ein Homematicgerät in RaspberryMatic abgelernt, weil es mit dem Gerät nicht funktioniert hat. Es handelt sich um einen Magnet-Tür-Kontakt.
              Leider wirft mir nun das Script eine Warnung aus:
              getState "hm-rpc.1.OEQ0167836.1.LOWBAT" not found (3)
              Das ist genau das abgelernte Gerät. Wo zieht sich das Script die Daten für die Geräte her? Ich suche schon ziemlich lange. Hier scheint es ein Problem mit der Löschverfolgung zu geben. Wenn Du nähere Angaben benötigst, lass' es mich bitte wissen. Vielen Dank für Deine Hilfe.
              https://www.schlepper-petersdorf.de
              • opossumO opossum
                Hallo, @paul53,
                #187
                @opossum
                Starte die Javascript-Instanz neu, damit deren Puffer aktualisiert wird.
                  @opossum
                  opossumO Offline
                  opossumO Offline
                  opossum
                  #188
                  Hallo, @paul53,
                  manche Dinge sind so einfach, und man vergisst es immer wieder. Das Problem saß mal wieder vorm Bildschirm. Danke Dir.
                  • BluefoxB Bluefox
                    @Homoran:
                    Was muss ich tun??
                    Das Lowbat-Script wäre unbedingt auch etwas für die Homepage! `
                    nimm das:
                    createState('zählenLowbat.möglicheLOWBAT', 0);   // wenn benötigt: Anzahl der vorhandenen LOWBAT
                    createState('zählenLowbat.textLOWBAT', " ");     // Anzahl LOWBAT, die an sind als Variable unter Javascript.0 anlegen
                    var cacheSelectorLOWBAT  = $('channel[state.id=*.LOWBAT]');
                    	var anzahlLOWBAT    = 0;
                    	if (obj) {
                    	} else {
                    	cacheSelectorLOWBAT.each(function (id, i) {                         // Schleife für jedes gefundenen Element *.LOWBAT
                    		var status = getState(id).val;                                  // Zustand *.LOWBAT abfragen (jedes Element)
                    		if (status === true) {                                          // wenn Zustand = true, dann wird die Anzahl der Geräte hochgezählt
                    		++anzahlLOWBAT;                                                 // Zählt die Anzahl der vorhandenen Geräte unabhängig vom Status
                    	log("Anzahl Geräte: " + moeglicheLOWBAT + " # davon LOWBAT erkannt: " +  anzahlLOWBAT);
                    	// die ermittelten Werte werden als javascript.0\. Variable in ioBroker gespeichert (z.B. für die Verarbeitung in VIS)
                    ')); // Schreibt die aktuelle Namen der Geräte mit LOWBAT Meldung
                    	setState("zählenLowbat.anzahlLOWBAT",   textLOWBAT.length);        // Schreibt die aktuelle Anzahl der Geräte im System
                    	setState("zählenLowbat.möglicheLOWBAT", moeglicheLOWBAT);          // Schreibt die aktuelle Anzahl der vorhandene Geräte
                    cacheSelectorLOWBAT.on(function(obj) {    // bei Zustandänderung *. LOWBAT in allen Gewerken
                       countLowbat(obj);
                    schedule("*/60 * * * *", function () {                                  //oder!! soll entweder ausgelöst werden alle 10 Minuten
                       countLowbat();
                    Semmy
                    #189
                    @bluefox sagte in Skript LOWBAT:
                    @Homoran:
                    Was muss ich tun??
                    nimm das:
                    	if (obj) {
                    	} else {
                       countLowbat(obj);
                       countLowbat();
                    Ich bekomme immer diese Fehlermeldung
                    17:59:05.589	error	javascript.0 (574) script.js.Haus.Test_Batterie compile failed: at script.js.Haus.Test_Batterie:38
                    paul53P HomoranH 2 Antworten Letzte Antwort
                    • S Semmy
                      @Homoran:
                      Was muss ich tun??
                      nimm das:
                      	if (obj) {
                      	} else {
                         countLowbat(obj);
                         countLowbat();
                      #190
                      @semmy sagte: Fehlermeldung
                      Füge mal Zeilen 34 und 35 zu einer Zeile zusammen.
                      • S Semmy
                        @Homoran:
                        Was muss ich tun??
                        nimm das:
                        	if (obj) {
                        	} else {
                           countLowbat(obj);
                           countLowbat();
                        #191
                        @semmy du referenzierst tatsächlich einen Post von 2015?
                        bist du Archäologe?
                        Bist du sicher, dass das Skript (wie genau sieht das jetzt bei dir aus??) heute noch passt?
                          Semmy
                          #192
                          @paul53 Fehlermeldung ist weg. Werden mit den Script auch IP-Geräte angezeigt?
                          HomoranH bahnuhrB paul53P 3 Antworten Letzte Antwort
                          • S Semmy
                            #193
                            @semmy sagte in Skript LOWBAT:
                            eher nicht.
                            ich weiß gar nicht, ob es die schon 2015 gab.
                            Außerdem ist die Datenstruktur da anders.
                            Aber @liv-in-sky hat dazu was tolles gebastelt. musst du mal suchen
                            • S Semmy
                              bahnuhrB Online
                              bahnuhrB Online
                              bahnuhr
                              #194
                              @semmy
                              Schau dir den Selektor an, dann kannst du die Frage selber beantworten!
                              bei HM: LOWBAT
                              bei IP: LOW_BAT
                              Also nein, nur HM
                              alternative: Script umschreiben.
                              oder du nimmst mein geändertes Script:
                              DP natürlich anpassen.
                              // Batterie Meldung über leere Batterien
                                  var bat_arr = [];
                                  var logging = false;
                                  var cacheSelectorLOWBAT  = $('channel[state.id=hm-rpc.*0.LOW*]').each(function(id, i) {
                                      if(id.indexOf('CUX') == -1 && id.indexOf('ALARM') == -1) { bat_arr.push(id); }       // Objekte mit "cux" oder "Alarm" im Namen nicht in array schreiben
                              weiter();
                              function weiter() {
                                  textLOWBAT = [];
                                  bat_arr.forEach(Ermittlung);
                                  function Ermittlung(id, i) {
                                      var sname = getObject(id).common.name;
                                      var sdevicename = sname.replace(/.LOWBAT/g, '');   // .lowbat aus Text entfernen
                                      sdevicename = sdevicename.replace(/.LOW_BAT/g, '');   // .lowbat aus Text entfernen
                                      sdevicename = sdevicename.replace(/:0/g, '');     // :0 aus Text entfernen
                                      if (logging) log("a) " + i + " : " + id + " : " + status + " : " + sdevicename);
                                          if (status == true) {
                                                  if (logging) log("c) dazu fügen: " + sdevicename);
                                                  textLOWBAT.push('- ' + sdevicename);                           // Zu Array hinzufügen
                                                  log("Batterie leer: Gerät: " + sdevicename);
                                      if (logging) log ("d) " + textLOWBAT.length);
                                      //textLOWBAT = deleteDuplicates(textLOWBAT);   // es geht nicht -> warum weiß ich nicht !
                                      textLOWBAT.sort();
                                      if (logging) log ("e) " + textLOWBAT.join('<br>').replace(/- /g,'') );
                                      setState('javascript.0.System.Batterie.Batterie_LOWBAT', textLOWBAT.join('<br>').replace(/- /g,'') );    // Schreibt die aktuelle Namen der Geräte mit LOWBAT Meldung
                                      setState('javascript.0.System.Batterie.Batterie_Anzahl', textLOWBAT.length);
                                  // Telegram Meldung
                                      var sText = "Batterie Meldung vom:   " + Datum_holen("tmj") + "\n--------------------------------------------------------" + "\n";
                                      if (textLOWBAT.length === 0) {
                                          sText = sText + "Keine leeren Batterien in Homematic Geräten gefunden.";
                                      } else {
                                          sText = sText + "Bei folgenden Homematic Geräten ist die Batterie leer:\n";
                                          sText = sText + textLOWBAT.join('\n');
                                      sendTo('telegram.0', sText);
                                      //log (sText);
                              on({id: bat_arr, change: "ne"}, function(){        // bei Zustandänderung im "bat_arr*
                                  log("Auslöser: bat_arr");
                                  weiter();
                              schedule("15 0 * * *", function () {        //  nachts Batterie Status überprüfen
                                  log("Auslöser: Schedule");
                                  weiter();
                              Danke.
                              gute Forenbeiträge: https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge
                              • bahnuhrB bahnuhr
                                @semmy
                                bei HM: LOWBAT
                                bei IP: LOW_BAT
                                Also nein, nur HM
                                    var bat_arr = [];
                                weiter();
                                function weiter() {
                                    textLOWBAT = [];
                                        textLOWBAT.sort();
                                    // Telegram Meldung
                                        } else {
                                        //log (sText);
                                    weiter();
                                    weiter();
                                #195
                                @bahnuhr sagte in Skript LOWBAT:
                                bei HM: LOWBAT
                                bei IP: LOW_BAT
                                Bei HM auch bool und bei IP in Volt, oder?
                                • S Semmy
                                  #196
                                  @semmy sagte: Werden mit den Script auch IP-Geräte angezeigt?
                                  Nein, es sei denn, der $Selector (Zeile 5) wird angepasst:
                                  var cacheSelectorLOWBAT  = $('hm-rpc.*.0.LOW*');
                                  @homoran sagte in Skript LOWBAT:
                                  LOW_BAT ist auch boolean.
                                    Semmy
                                    schrieb am zuletzt editiert von Semmy
                                    #197
                                    @paul53 Ich habe das folgende Script schon Jahre am Laufen, es wird mir zwar angezeigt, dass Batterien leer sind, aber das Gerät dazu nicht.
                                     var debug = true;
                                    createState('zählenLowbat.möglicheLOWBAT', 0);   // wenn benötigt: Anzahl der vorhandenen Geräte
                                    var cacheSelectorLOW_BAT  = $('channel[state.id=*.LOW_BAT]');   // für Homematic IP, dort LOWBAT in LOW_BAT umbenannt
                                       if (obj) {
                                          if(debug) log('Auslösender Aktor: ' + obj.id + ': ' + obj.newState.val);  // Info im Log, welcher Zustand sich geändert hat
                                       } else {
                                          if(debug) log('Ausgelöst bei Timer');
                                            var name = getObject(id).common.name;                                   // neu eingefügt
                                            var devicename = name.substring(0, name.indexOf(":0.LOWBAT"));    // neu eingefügt, LOWBAT aus Bezeichnung entfernen
                                            textLOWBAT.push(devicename);                                   // Zu Array hinzufügen; aktualisiert, vormals obj.common.name
                                            ++anzahlLOWBAT;
                                          if(debug) log("Geräte Nr. " + i + ": " + getObject(id).common.name + ": " + status);
                                       cacheSelectorLOW_BAT.each(function (id, i) {                         // Schleife für jedes gefundenen Element *.LOW_BAT, Homematic IP
                                          var status = getState(id).val;                                    // Zustand *.LOW_BAT abfragen (jedes Element)
                                            var devicename = name.substring(0, name.indexOf(":0.LOW_BAT"));   // neu eingefügt, LOW_BAT aus Bezeichnung entfernen
                                            ++anzahlLOWBAT;
                                       if(debug) log("Text: " + textLOWBAT);
                                       setState("zählenLowbat.textLOWBAT",     textLOWBAT.join('<br>')); // Schreibt die aktuelle Namen der Geräte mit LOWBAT Meldung
                                       setState("zählenLowbat.anzahlLOWBAT",   anzahlLOWBAT);        // Schreibt die aktuelle Anzahl der Geräte im System
                                       countLowbat(obj);
                                    cacheSelectorLOW_BAT.on(function(obj) {    // bei Zustandänderung *. LOW_BAT in allen Gewerken
                                       countLowbat(obj);
                                    // Bei Start
                                    countLowbat();
                                    • S Semmy
                                       var debug = true;
                                         if (obj) {
                                         } else {
                                              ++anzahlLOWBAT;
                                              ++anzahlLOWBAT;
                                         countLowbat(obj);
                                         countLowbat(obj);
                                      // Bei Start
                                      countLowbat();
                                      #198
                                      @semmy sagte: das Gerät dazu nicht.
                                      Der DP "zählenLowbat.textLOWBAT" enthält nicht die Gerätenamen? Dann ist die Struktur der Datenpunktnamen wahrscheinlich abweichend.
                                      Man kann auch direkt auf die Gerätenamen zugreifen (Zeilen 25, 26 und 37, 38 ersetzen):
                                              let idDev = id.substring(0, id.lastIndexOf('.'));
                                              idDev = id.substring(0, idDev.lastIndexOf('.'));
                                              let devicename = getObject(idDev).common.name;
                                        Semmy
                                        #199
                                        @paul53 sagte in Skript LOWBAT:
                                        Ok, jetzt funktioniert es wieder wie es soll.
                                        Vielen Dank
                                        Semmy
                                        • S Semmy
                                          Vielen Dank
                                          Semmy
                                          sigi234S Online
                                          sigi234S Online
                                          sigi234
                                          #200
                                          @semmy
                                          Schau dir das mal an:
                                          https://forum.iobroker.net/topic/55426/test-adapter-device-watcher-v2-x-x-github-latest?_=1687204350972
                                          Immer Daten sichern!
