  4. Test Adapter OpenDTU
    2.4k
    4.4k
dtuhoymilesopendtusolar
457 Beiträge 47 Kommentatoren 164.9k Aufrufe 42 Beobachtet
  • FriedhofsblondF Friedhofsblond
    so, fällt Euch nochwas auf (ausser dem Xfce) ;) ?
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: ioserver
           Icon name: computer-desktop
             Chassis: desktop 🖥️
              Kernel: Linux 6.1.0-13-amd64
        Architecture: x86-64
     Hardware Vendor: Intel_R_ Client Systems
      Hardware Model: NUC7CJYH
    Firmware Version: JYGLKCPX.86A.0070.2023.0505.1501
    model name      : Intel(R) Celeron(R) J4005 CPU @ 2.00GHz
    Docker          : false
    Virtualization  : none
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     14:54:52 up 2 min,  2 users,  load average: 0.19, 0.20, 0.08
    CPU threads: 2
    *** Time and Time Zones ***
                   Local time: Fri 2023-10-20 14:54:52 CEST
               Universal time: Fri 2023-10-20 12:54:52 UTC
                     RTC time: Fri 2023-10-20 12:54:52
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    superuser
    /home/superuser
    superuser adm cdrom floppy sudo audio dip video plugdev users netdev iobroker
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       web
    *** MEMORY ***
    Mem:            7.9G        1.2G        6.3G         27M        697M        6.7G
    Swap:           1.0G          0B        1.0G
    Total:          8.9G        1.2G        7.3G
             7556 M total memory
             1171 M used memory
              213 M active memory
             1162 M inactive memory
             5986 M free memory
               34 M buffer memory
              630 M swap cache
              975 M total swap
                0 M used swap
              975 M free swap
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  3.7G     0  3.7G   0% /dev
    tmpfs          tmpfs     756M  1.1M  755M   1% /run
    /dev/sda2      ext4      218G  7.9G  199G   4% /
    tmpfs          tmpfs     3.7G     0  3.7G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    /dev/sda1      vfat      511M  9.8M  502M   2% /boot/efi
    tmpfs          tmpfs     756M   20K  756M   1% /run/user/104
    tmpfs          tmpfs     756M   16K  756M   1% /run/user/1000
    [Fri Oct 20 14:52:44 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Fri Oct 20 14:52:45 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    Show mounted filesystems \(real ones only\):
    TARGET      SOURCE    FSTYPE OPTIONS
    /           /dev/sda2 ext4   rw,relatime,errors=remount-ro
    `-/boot/efi /dev/sda1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
    /var:
    2.4G    /var/
    2.0G    /var/cache
    1.9G    /var/cache/apt/archives
    1.9G    /var/cache/apt
    215M    /var/log
    Archived and active journals take up 198.6M in the file system.
    /opt/iobroker/backups:
    2.4M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    60M     /opt/iobroker/iobroker-data/
    34M     /opt/iobroker/iobroker-data/backup-objects
    15M     /opt/iobroker/iobroker-data/files
    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    sort: fflush failed: 'standard output': Broken pipe
    sort: write error
    8.2M    /opt/iobroker/iobroker-data/objects.jsonl
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    3.2M    /opt/iobroker/iobroker-data/states.jsonl
    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
    1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 http://debian.inf.tu-dresden.de/debian bookworm/main amd64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.10.1
    javascript:     "javascript" not found
    Adapters from github:   1
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioserver                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : ioserver                                 -  enabled
      system.adapter.discovery.0              : discovery             : ioserver                                 - disabled
    + system.adapter.email.0                  : email                 : ioserver                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : ioserver                                 -  enabled, port: 8086
      system.adapter.mercedesme.0             : mercedesme            : ioserver                                 - disabled
      system.adapter.mqtt.1                   : mqtt                  : ioserver                                 - disabled, port: 1883, bind: 0.0.0.0
      system.adapter.oilfox.0                 : oilfox                : ioserver                                 -  enabled
    + system.adapter.opendtu.0                : opendtu               : ioserver                                 -  enabled
    + system.adapter.terminal.0               : terminal              : ioserver                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.viessmannapi.0           : viessmannapi          : ioserver                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.10.1   , installed 6.10.1
    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "mercedesme"   : 0.1.1    , installed 0.1.1
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "oilfox"       : 4.2.0    , installed 4.2.0
    Adapter    "opendtu"      : 1.0.0    , installed 1.0.0
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "viessmannapi" : 2.0.9    , installed 2.2.1
    Objects and States
    Objects:        9445
    States:         7679
    Hit:1 http://debian.inf.tu-dresden.de/debian bookworm InRelease
    Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://debian.inf.tu-dresden.de/debian bookworm-updates InRelease
    Hit:4 https://apt.grafana.com stable InRelease
    Hit:5 https://repos.influxdata.com/debian stable InRelease
    Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:48497           0.0.0.0:*               LISTEN      111        22545      1091/rpc.statd
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19494      953/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       20542      953/iobroker.js-con
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          19488      988/exim4
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14966      1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          19016      567/sshd: /usr/sbin
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          19489      988/exim4
    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       21025      1156/io.terminal.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       20669      1002/io.admin.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        17117      591/influxd
    tcp6       0      0 :::3000                 :::*                    LISTEN      112        19513      952/grafana
    tcp6       0      0 :::111                  :::*                    LISTEN      0          14968      1/init
    tcp6       0      0 :::37127                :::*                    LISTEN      111        22551      1091/rpc.statd
    tcp6       0      0 :::9090                 :::*                    LISTEN      0          16646      1/init
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14967      1/init
    udp        0      0 0.0.0.0:49340           0.0.0.0:*                           111        22542      1091/rpc.statd
    udp        0      0 127.0.0.1:843           0.0.0.0:*                           0          22537      1091/rpc.statd
    udp6       0      0 :::111                  :::*                                0          14969      1/init
    udp6       0      0 :::37763                :::*                                111        22548      1091/rpc.statd
    2023-10-20 14:53:03.484  - info: influxdb.0 (1045) enabled logging of Viessmann-Gas-WW-Tag, Alias=true, 21 points now activated
    2023-10-20 14:53:03.484  - info: influxdb.0 (1045) enabled logging of Viessmann-Strom-Heizung-Tag, Alias=true, 22 points now activated
    2023-10-20 14:53:03.484  - info: influxdb.0 (1045) enabled logging of Viessmann-WW-Temp, Alias=true, 23 points now activated
    2023-10-20 14:53:03.485  - info: influxdb.0 (1045) enabled logging of Viessmann-VL-Temp, Alias=true, 24 points now activated
    2023-10-20 14:53:03.485  - info: influxdb.0 (1045) enabled logging of Zisterne-Füllstand-Perc, Alias=true, 25 points now activated
    2023-10-20 14:53:03.485  - info: influxdb.0 (1045) enabled logging of Zisterne-Füllstand-Liter, Alias=true, 26 points now activated
    2023-10-20 14:53:03.485  - info: influxdb.0 (1045) enabled logging of B200-Letzte-Fahrt-km, Alias=true, 27 points now activated
    2023-10-20 14:53:03.486  - info: influxdb.0 (1045) enabled logging of B200-Durchschnittsverbrauch-L, Alias=true, 28 points now activated
    2023-10-20 14:53:03.486  - info: influxdb.0 (1045) enabled logging of B200-Durchschnittsverbrauch-letzte-Fahrt, Alias=true, 29 points now activated
    2023-10-20 14:53:03.486  - info: influxdb.0 (1045) enabled logging of B200-KM-Stand, Alias=true, 30 points now activated
    2023-10-20 14:53:03.490  - info: influxdb.0 (1045) Connected!
    2023-10-20 14:53:06.011  - info: host.ioserver instance system.adapter.backitup.0 started with pid 1060
    2023-10-20 14:53:07.223  - info: backitup.0 (1060) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.18.2, js-controller: 5.0.12
    2023-10-20 14:53:07.268  - info: backitup.0 (1060) [iobroker] backup will be activated at 23:00 every 1 day(s)
    2023-10-20 14:53:10.013  - info: host.ioserver instance system.adapter.opendtu.0 started with pid 1113
    2023-10-20 14:53:11.095  - info: opendtu.0 (1113) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.opendtu, node: v18.18.2, js-controller: 5.0.12
    2023-10-20 14:53:11.349  - info: opendtu.0 (1113) Connect to OpenDTU over websocket connection.
    2023-10-20 14:53:14.011  - info: host.ioserver instance system.adapter.viessmannapi.0 started with pid 1128
    2023-10-20 14:53:15.223  - info: viessmannapi.0 (1128) starting. Version 2.2.1 in /opt/iobroker/node_modules/iobroker.viessmannapi, node: v18.18.2, js-controller: 5.0.12
    2023-10-20 14:53:18.059  - info: host.ioserver instance scheduled system.adapter.oilfox.0 5 12 * * *
    2023-10-20 14:53:22.014  - info: host.ioserver instance system.adapter.terminal.0 started with pid 1156
    2023-10-20 14:53:23.447  - info: terminal.0 (1156) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.terminal, node: v18.18.2, js-controller: 5.0.12
    2023-10-20 14:53:23.492  - info: terminal.0 (1156) http server listening on port 8088
    2023-10-20 14:53:25.953  - info: opendtu.0 (1113) Connect to OpenDTU over websocket connection.
    2023-10-20 14:53:27.313  - info: viessmannapi.0 (1128) 1 installations found.
    #361
    @friedhofsblond sagte in Test Adapter OpenDTU:
    sort: write error
    Komische Meldung, sollte da nicht auftauchen.
    Und schalt den Desktop AUS!
    FriedhofsblondF 1 Antwort Letzte Antwort
      sort: write error
      FriedhofsblondF Offline
      Friedhofsblond
      #362
      OK ich schau mal nach.
      Ansonsten beobachte ich mal was morgen so passiert.
      Danke erstmal 👍
      • S schoeppi_1
        @knopers1
        Dann noch ein Hinweis, da ich im Dauerbetrieb doch noch was unschönes bemerkt habe.
        Diesen Teil habe ich nach meinem ersten POST noch dazu gefügt:
        Das ist darin begründet, dass die Regelung sich bei großen Sollwertänderungen manchmal aufgeschaukelt hat und es dann einige Minuten gebraucht hat, bis wieder eingeregelt war.
        Dieser Teil bewirkt, das ich nur eine max. Sollwertänderung von 10W plus oder Minus bei jedem Durchlauf zulasse. Damit vermeide ich das Aufschwingen. Er regelt also langsam auf den neuen Wert. Auch dafür gut, wenn es einen kurzen Leistungspick gibt.
        Ich nutze auch einen IR-Lesekopf der mir den 16.7.0 (saldierte Leistung) zurück gibt. Der zeigt auch Minuswerte an. So wie ich dein Anliegen verstehe, ist es egal ob ich in der Nacht einspeise oder auch tagsüber. Daher sollte es prinzipiell funktionieren.
        Ich lade mein Batterie tagsüber. Der dahinter geschaltete WR ist dann vom Netz getrennt. Wenn ich einspeise, ist das Ladegerät vom Netz getrennt. Ich weiß nicht ob man eine Batterie gleichzeitig laden und entladen kann, was Dir vermutlich vorschwebt?
        Ich empfehle generell auch einen Shelly 1PM einzubauen. Schon allein um zu sehen was in der PV passiert.
        vg und viel Erfolg Stephan
        knopers1
        schrieb am zuletzt editiert von knopers1
        #363
        @schoeppi_1
        sehr geil 👍 besten Dank! Ich musste das Script etwas anpassen, da ich dauerhaft die Grundlast einspeisen möchte. Am Tage sollte der Akku trotzdem noch voll werden, da ich noch weitere drei Module an 1300 Watt WR Leisung angeschlossen habe.
        ich habe jetzt dein erstes Script für meinen Zweck abgeändert, und Mal hier zur Begutachtung exportiert. Kannst Du deine 10 Watt Änderung an meinem angepassten Script noch einfügen?
        Komme jetzt mit den zwei Abschnitten nicht ganz klar...
          <variables>
            <variable id="BN!a@q$SEAU4^)xo:SRJ">maxSolarPower</variable>
            <variable id="AcYpB0Ty+wVObL7=Y.a.">measuredPower</variable>
            <variable id="1}Q0686mMw0ZGk)e+r?(">measuredSolarPower</variable>
            <variable id="le#}gR{6G.yhW=x|6pS8">neededPower</variable>
            <variable id="X-B3:`dA%wy5$?]at5W-">NeededPowerPercent</variable>
            <variable id=":U;.Z4:pYNy(TwM9X-dL">storedNeededPower</variable>
            <variable id="}s`y%Qd}~t2t(jU$8(ud">upperLimit</variable>
            <variable id="P^1|W+9iVy?PgNp}9!.S">lowerLimit</variable>
            <variable id="?~:J:;gqC%-pt?=zNsH:">Sunrise</variable>
            <variable id="UJ`JGN{Ezb$K7jJ[4P}j">Sunset</variable>
            <variable id=")2]D^Y|D:QS6S[A}9J=/">SolarLimit</variable>
          </variables>
          <block type="schedule" id="!P+uzJ#%y!_wHsKqo2~M" x="-769" y="-524">
            <field name="SCHEDULE">*/15 * * * * *</field>
            <statement name="STATEMENT">
              <block type="controls_if" id="xaOp|xXgB@BB44iq}cJ.">
                <value name="IF0">
                  <block type="time_compare_ex" id="Y8n@Iqzd:%qZbp|#P_v^">
                    <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true" actual_time="true"></mutation>
                    <field name="USE_ACTUAL_TIME">TRUE</field>
                    <field name="OPTION">between</field>
                    <value name="START_TIME">
                      <shadow type="text" id="]-0N3DkP*7?ghtYzXwX!">
                        <field name="TEXT">10:00</field>
                      </shadow>
                    </value>
                    <value name="END_TIME">
                      <shadow type="text" id="fBJt;J|@?8y+L|`jmRd9">
                        <field name="TEXT">09:00</field>
                      </shadow>
                    </value>
                  </block>
                </value>
                <statement name="DO0">
                  <block type="variables_set" id="~p6WKGjCNU[UXfc{|$8|">
                    <field name="VAR" id="BN!a@q$SEAU4^)xo:SRJ">maxSolarPower</field>
                    <value name="VALUE">
                      <block type="math_number" id="Z(v(#cMkS]/o.,;iyE/|">
                        <field name="NUM">600</field>
                      </block>
                    </value>
                    <next>
                      <block type="variables_set" id="Ih%sQzzK`!Ec=`tscEm-">
                        <field name="VAR" id="AcYpB0Ty+wVObL7=Y.a.">measuredPower</field>
                          <block type="get_value" id="E60zTd:yszZT-@pD[YB#">
                            <field name="OID">hm-rega.0.10421</field>
                          </block>
                        </value>
                        <next>
                          <block type="variables_set" id=":rlAB32E^@yPP9Jh?EMO">
                            <field name="VAR" id="1}Q0686mMw0ZGk)e+r?(">measuredSolarPower</field>
                              <block type="get_value" id="Q8pLDlgI~N(N2-6)X@Qu">
                                <field name="OID">opendtu.0.114182913679.ac.phase_1.power</field>
                              </block>
                            </value>
                            <next>
                              <block type="variables_set" id="t8-xB+K`%rr)x]%:Q5cN">
                                <field name="VAR" id="le#}gR{6G.yhW=x|6pS8">neededPower</field>
                                  <block type="math_arithmetic" id="2FaDMR/kS5K9d!j=`dK3">
                                    <field name="OP">ADD</field>
                                    <value name="A">
                                      <shadow type="math_number" id="2FEk%?jHI2)Hvf4}p|*;">
                                        <field name="NUM">1</field>
                                      </shadow>
                                      <block type="variables_get" id="Z`YZ!4FileGG?5VwaP-/">
                                      </block>
                                    </value>
                                    <value name="B">
                                      <shadow type="math_number" id="+10nRI6/x]hugF{/lmxM">
                                      </shadow>
                                      <block type="variables_get" id="n0BqKn~p@qPw.Jvfrj,s">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <next>
                                  <block type="variables_set" id="$61h{3os=)%X-VEx9M:i">
                                    <field name="VAR" id="X-B3:`dA%wy5$?]at5W-">NeededPowerPercent</field>
                                      <block type="math_round" id="3$tH.4.P)ukPPcI4xw.A">
                                        <field name="OP">ROUND</field>
                                        <value name="NUM">
                                          <shadow type="math_number" id="{D8W1ElJ#97Cg:]vDkM;">
                                            <field name="NUM">3.1</field>
                                          </shadow>
                                          <block type="math_arithmetic" id="ju~9S8j-`0c/OF%2$7-o">
                                            <field name="OP">MULTIPLY</field>
                                            <value name="A">
                                              <shadow type="math_number" id="6:p#t,*^;)z:Wb:@dc|3">
                                                <field name="NUM">100</field>
                                              </shadow>
                                            </value>
                                            <value name="B">
                                              <shadow type="math_number" id=".fYZ,3H9RSS}:wD=%Bvk">
                                              </shadow>
                                              <block type="math_arithmetic" id="Z9S-r-/8^FbCeq,[{ULB">
                                                <field name="OP">DIVIDE</field>
                                                <value name="A">
                                                  <shadow type="math_number" id="jul_lM$(9.yj`:ZH8}%@">
                                                  </shadow>
                                                  <block type="variables_get" id="_mPBX.l-0%hNvWtND[z1">
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  <shadow type="math_number" id="{Q+JfjzDv.)Z1KRbU*uv">
                                                  </shadow>
                                                  <block type="variables_get" id="M!sN^/9!7$b}.ru.lqgC">
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                    <next>
                                      <block type="variables_set" id="g3gA+F5X4*$4x2),%sJV">
                                        <field name="VAR" id=":U;.Z4:pYNy(TwM9X-dL">storedNeededPower</field>
                                          <block type="get_value" id="7wbrC,7l;@ahCGcw2/pL">
                                            <field name="OID">0_userdata.0.PV-Anlage.storedNeededPowerHM600.storedNeededPower</field>
                                          </block>
                                        </value>
                                        <next>
                                          <block type="variables_set" id="2KI]WdQd`0MzEf%mOPaL">
                                            <field name="VAR" id="}s`y%Qd}~t2t(jU$8(ud">upperLimit</field>
                                              <block type="math_round" id="Ha.~N]M`[1eWboby_aYe">
                                                <value name="NUM">
                                                  <shadow type="math_number" id=":C/cpWh)P`-jK9}]IN*4">
                                                  </shadow>
                                                  <block type="math_arithmetic" id="v}v!|Jkv3JHVqQR7poM0">
                                                    <value name="A">
                                                      <shadow type="math_number" id="Nou}`9U#64_9EfeP$7E^">
                                                      </shadow>
                                                      <block type="variables_get" id="{dg*rTfc(I5I1PoYYN;l">
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      <shadow type="math_number" id="D`~([S!SEua]l95F+#-*">
                                                      </shadow>
                                                      <block type="math_arithmetic" id="#Aa[sC!ija_TtL9Go*jl">
                                                        <value name="A">
                                                          <shadow type="math_number" id="GfovLR]X(6=?),|X/9K2">
                                                          </shadow>
                                                          <block type="variables_get" id="?YS@_}6Hup[`ZsLR!Z45">
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          <shadow type="math_number" id="YxGb?xk[MY37)!7O-Cqe">
                                                            <field name="NUM">0.05</field>
                                                          </shadow>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <next>
                                              <block type="variables_set" id="+KJ71_Z(eLN.a(uoEuci">
                                                <field name="VAR" id="P^1|W+9iVy?PgNp}9!.S">lowerLimit</field>
                                                  <block type="math_round" id="=HYNg!vGE)^Z7m{+e$cs">
                                                    <value name="NUM">
                                                      <shadow type="math_number" id="|d.50MyF$Zxnn(B]!gq~">
                                                      </shadow>
                                                      <block type="math_arithmetic" id="?8HAOa[X,LM#h`p]lLc4">
                                                        <value name="A">
                                                          <shadow type="math_number" id="(8p!3BSrd)N0m`PVj}cd">
                                                          </shadow>
                                                          <block type="variables_get" id="?$cU!rsg;wkU}CP.VsR.">
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          <shadow type="math_number" id="@kP8*eoC!D4/Wa?%grKM">
                                                          </shadow>
                                                          <block type="math_arithmetic" id="D$_kryX`Gb5eu$gnYS_q">
                                                            <value name="A">
                                                              <shadow type="math_number" id="MHx^YJ`[IJHske|0K5}M">
                                                              </shadow>
                                                              <block type="variables_get" id="nrL6t1UCC{jy1*U[O|Xq">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              <shadow type="math_number" id="||~-FC.nb3oU=fuLJzw}">
        <field name="NUM">0.1</field>
                                                              </shadow>
                                                            </value>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <next>
                                                  <block type="debug" id="8cGY=ms*^/Fbn#Cde4/e">
                                                    <value name="TEXT">
                                                      <shadow type="text" id="csk68CmH=pR,ptmE?y}5">
                                                      </shadow>
                                                      <block type="text_join" id="QUQf.~7J|ziuD3sLdl)|">
                                                        <value name="ADD0">
                                                          <block type="text" id="lGPf[Ci!QdAF4j#Bn34-">
                                                            <field name="TEXT">Sonnenaufgang; </field>
                                                          </block>
                                                        </value>
                                                        <value name="ADD1">
                                                          <block type="variables_get" id="kwmbl:u%6-!)]lE{Bhdj">
                                                            <field name="VAR" id="?~:J:;gqC%-pt?=zNsH:">Sunrise</field>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <next>
                                                      <block type="debug" id="yaFK]t~sZKg}j1WzH!TL">
                                                        <value name="TEXT">
                                                          <shadow type="text" id="A:^a.TTl)CuCY?K4{Z0;">
                                                          </shadow>
                                                          <block type="text_join" id="g_%Dq-ksE!p;Tib-dWoB">
                                                            <value name="ADD0">
                                                              <block type="text" id="(bZZUaTT0bt~IQ|a~%#R">
        <field name="TEXT">Sonnenuntergang; </field>
                                                              </block>
                                                            </value>
                                                            <value name="ADD1">
                                                              <block type="variables_get" id="weuYcyZ5+:mfnpSK9UiP">
        <field name="VAR" id="UJ`JGN{Ezb$K7jJ[4P}j">Sunset</field>
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <next>
                                                          <block type="debug" id="1|f1K~GhCe(a;/q4o_X]">
                                                            <value name="TEXT">
                                                              <shadow type="text" id="WtDq6*-h|XRBClzt7C[}">
                                                              </shadow>
                                                              <block type="text_join" id="2Zo2{I0w6J%`$2:qEY1l">
        <value name="ADD0">
        <block type="text" id="+YI.VRyx;em.YT$D(|bs">
        <field name="TEXT">Istwert: </field>
        </block>
        </value>
        <value name="ADD1">
        <block type="variables_get" id="z%3ACfZd0~)KLgj0p}%@">
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                            <next>
                                                              <block type="debug" id="r+xN[i`4xS-M`OYDBpb.">
        <value name="TEXT">
        <shadow type="text" id="huRV|RwGh(WJG|l-)Aw`">
        </shadow>
        <block type="text_join" id="(f(78JM#Hy0@?Z0hJe~l">
        <value name="ADD0">
        <block type="text" id="~}`O(MW.TU:J%_oS)#Xu">
        <field name="TEXT">obere Grenze: </field>
        </block>
        </value>
        <value name="ADD1">
        <block type="variables_get" id=",vBoJg7x{3!@v.c5w4q]">
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="debug" id="qBNh2:P3U}F#$|$6FZFn">
        <value name="TEXT">
        <shadow type="text" id="2kPK8(t-SdR9TZvb.%-l">
        </shadow>
        <block type="text_join" id="}cq5v9RJT$55w(=?6BX)">
        <value name="ADD0">
        <block type="text" id="*q^TTVgJ+?:b!z,x/S;V">
        <field name="TEXT">untere Grenze: </field>
        </block>
        </value>
        <value name="ADD1">
        <block type="variables_get" id="Vh$)4$K%:ZHW:~MiMXet">
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="debug" id="k}*+@}8y%^u*6nB1JGm^">
        <value name="TEXT">
        <shadow type="text" id="p_lud?Lq-FYBOI}E.h])">
        </shadow>
        <block type="text_join" id="9O/.cB+R0J#M=YHuIJn?">
        <value name="ADD0">
        <block type="text" id="3Uv-x,Irz%wnP{oXU!s^">
        <field name="TEXT">benötigte Power in Prozent:</field>
        </block>
        </value>
        <value name="ADD1">
        <block type="variables_get" id="T);Yxf;X[xS0z_7}_YkI">
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="controls_if" id="//Rx),f%pyif!qW8O/?G">
        <mutation elseif="1" else="1"></mutation>
        <value name="IF0">
        <block type="logic_operation" id="6|n{EZ*g-L?wwMuw~`pt">
        <field name="OP">AND</field>
        <value name="A">
        <block type="logic_compare" id="@s)ep$AZC}nn4%[Y{zXv">
        <field name="OP">GTE</field>
        <value name="A">
        <block type="variables_get" id="rLGQIwoD@(-[)i.@Gek1">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="i.8)/]r6EY5E@{+61}ch">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <block type="logic_compare" id="M%7gn=%*6!Oo0Iy!N0HE">
        <field name="OP">EQ</field>
        <value name="A">
        <block type="variables_get" id="FPBUa4}8MCdw~u2(u=Z4">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="])#t~DUCT78?qe_~1/X)">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <block type="debug" id="_|aD2Z`JU`?BoQCCcfTz">
        <value name="TEXT">
        <shadow type="text" id="wcNA/`cj2DUcJLr26^bd">
        <field name="TEXT">keine Änderung, Wert ist gleich gespeichertem Wert</field>
        </shadow>
        </value>
        </block>
        </statement>
        <value name="IF1">
        <block type="logic_operation" id="4WJuW,40dOlCCnG8!=A(">
        <field name="OP">OR</field>
        <value name="A">
        <block type="logic_compare" id="0U*fZT58L0uKFJsD)N{;">
        <field name="OP">GT</field>
        <value name="A">
        <block type="variables_get" id="%=U`G7.6z`w:8|:XtgTI">
        </block>
        </value>
        <value name="B">
        <block type="variables_get" id="IE{(_NPVQP{:.^rxbG?4">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <block type="logic_compare" id="7GGwP6lHcmy!ILxZJvYk">
        <field name="OP">LT</field>
        <value name="A">
        <block type="variables_get" id="EN^7brshgWEicI7V4)C!">
        </block>
        </value>
        <value name="B">
        <block type="variables_get" id="7B.88d1a^Hr`R-b6!iMZ">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <statement name="DO1">
        <block type="controls_if" id="P8/_4.KJ/zZ6qh9iBh+o">
        <value name="IF0">
        <block type="logic_compare" id="mk*xKT^,LdqKZpmRr}r4">
        <field name="OP">LTE</field>
        <value name="A">
        <block type="variables_get" id=".d_KP;p/?wytr_{S7(db">
        </block>
        </value>
        <value name="B">
        <block type="variables_get" id="R!EQmKR0*lP1iR`NTG%f">
        </block>
        </value>
        </block>
        </value>
        <block type="variables_set" id="v_^pc%4YAqueF4@xp/Ph">
        <field name="VAR" id=")2]D^Y|D:QS6S[A}9J=/">SolarLimit</field>
        <block type="variables_get" id="rba!2I;EQyijkPfjo!Ze">
        </block>
        </value>
        <next>
        <block type="update" id="E7HJvqAC,*BNAxN~e8sd">
        <block type="variables_get" id="hR1[WimPbd@1ICN+UAdn">
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <statement name="ELSE">
        <block type="variables_set" id="iqqD`P-h34,:2q7p$CH|">
        <block type="math_number" id="dowAhu.+=iz#Wc-F]p:X">
        </block>
        </value>
        <next>
        <block type="update" id="*?5=;cANP)NJ|KuX_[PF">
        <block type="math_number" id="7vXqNl1zb}n*oh6q3:]4">
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <block type="controls_if" id="ngN)`(Ee_|WVjpbeEi,Z">
        <value name="IF0">
        <block type="logic_compare" id="E;jvy,d?,h~{8J-;$c#Z">
        <value name="A">
        <block type="variables_get" id="j.wG0w+y^vE]tm7AZ2SR">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="qmst0kfQa63`(1C?20+t">
        <field name="NUM">4</field>
        </block>
        </value>
        </block>
        </value>
        <block type="variables_set" id="eG:yr(gAO*#W@6$4I,9T">
        <block type="math_number" id="0qq=Pa2L.`pfN{/fr=|V">
        <field name="NUM">5</field>
        </block>
        </value>
        </block>
        </statement>
        <next>
        <block type="control" id="KN@t^0cE0k@-082b*`$}">
        <field name="OID">opendtu.0.114182913679.power_control.limit_nonpersistent_relative</field>
        <block type="variables_get" id="T,9Ms}!g05fFGlV[=97t">
        </block>
        </value>
        <next>
        <block type="update" id="K~#2,NL{?T,t?vi8K@_K">
        <field name="OID">0_userdata.0.PV-Anlage.Solarlimit_HM600.Solarlimit_HM600</field>
        <block type="variables_get" id="obffp}fvI-w|9kbk(:D7">
        </block>
        </value>
        <next>
        <block type="debug" id="4(mO4hae0d8|yCEDlMj~">
        <value name="TEXT">
        <shadow type="text" id="GhK9E*i9z*IoFuBKSaq1">
        </shadow>
        <block type="text_join" id="K$7:Tw;%Pm?f$3/:xV?V">
        <value name="ADD0">
        <block type="text" id="tzX795?CuQ=.SGL`i!ns">
        <field name="TEXT">gesetztes Limit: </field>
        </block>
        </value>
        <value name="ADD1">
        <block type="variables_get" id="`hpd|~6gnaa1#A:#I^ku">
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        <block type="debug" id="k-_yI!1YR}Cw@^zA*2By">
        <value name="TEXT">
        <shadow type="text" id="pOzzR,#7b~P,=jhm/QLz">
        <field name="TEXT">keine Änderung</field>
        </shadow>
        </value>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
                                                              </block>
                                                            </next>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </statement>
                  <block type="debug" id="6hv2w66u%V}c3Ij`Q?pi">
                    <value name="TEXT">
                      <shadow type="text" id="LmPU])Tk80,#%40`K:m4">
                        <field name="TEXT">Zeit ist außerhalb der Reglungszeit.</field>
                      </shadow>
                    </value>
                  </block>
                </statement>
              </block>
            </statement>
          </block>
        </xml>
        das Laden und Entladen parallel macht dem Akku nichts aus... Es geht und wird auch woanders genau so geregelt.
        • K knopers1
          @schoeppi_1
            <variables>
            </variables>
                  <value name="IF0">
                        </shadow>
                      </value>
                        </shadow>
                      </value>
                    </block>
                  </value>
                        </block>
                      </value>
                      <next>
                            </block>
                          </value>
                          <next>
                                </block>
                              </value>
                              <next>
                                      <value name="A">
                                        </shadow>
                                        </block>
                                      </value>
                                      <value name="B">
                                        </shadow>
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                  <next>
                                          <value name="NUM">
                                            </shadow>
                                              <value name="A">
                                                </shadow>
                                              </value>
                                              <value name="B">
                                                </shadow>
                                                  <value name="A">
                                                    </shadow>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    </shadow>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                      <next>
                                            </block>
                                          </value>
                                          <next>
                                                  <value name="NUM">
                                                    </shadow>
                                                      <value name="A">
                                                        </shadow>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        </shadow>
                                                          <value name="A">
                                                            </shadow>
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <next>
                                                      <value name="NUM">
                                                        </shadow>
                                                          <value name="A">
                                                            </shadow>
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            </shadow>
                                                              <value name="A">
        </shadow>
        </block>
                                                              </value>
                                                              <value name="B">
        </shadow>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <next>
                                                      <value name="TEXT">
                                                        </shadow>
                                                          <value name="ADD0">
                                                            </block>
                                                          </value>
                                                          <value name="ADD1">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <next>
                                                          <value name="TEXT">
                                                            </shadow>
                                                              <value name="ADD0">
        </block>
                                                              </value>
                                                              <value name="ADD1">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <next>
                                                              <value name="TEXT">
        </shadow>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        </block>
                                                              </value>
                                                              <next>
        <value name="TEXT">
        </shadow>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        </block>
        </value>
        <next>
        <value name="IF0">
        <value name="A">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="TEXT">
        </shadow>
        </value>
        </block>
        </statement>
        <value name="IF1">
        <value name="A">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        <next>
        </block>
        </value>
        <next>
        </block>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        <value name="TEXT">
        </shadow>
        </value>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                              </next>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </statement>
                      <value name="TEXT">
                        </shadow>
                      </value>
                    </block>
                  </statement>
                </block>
              </statement>
            </block>
          </xml>
          Friedhofsblond
          schrieb am zuletzt editiert von Friedhofsblond
          #364
          @knopers1
          mal so nebenbei.
          Ich frage mich immer wie lange solche Solarakkus halten - angeblich ja: 5.000-10.000 Ladezyklen.
          Wenn gerade jetzt in der Übergangszeit mal Sonne, Wolken usw. sich zügig ablösen ist ja der Akku ständig am be/entladen. - Da ist der bald hin.
          Oder wenn man mal den Herd anschaltet .... lässt sich sicher nicht einfach händeln.
          K CodierknechtC 2 Antworten Letzte Antwort
            @knopers1
            mal so nebenbei.
            knopers1
            #365
            @schoeppi_1
            Alles angepasst aber irend etwas passt nicht...
            bei 250 Watt Netzbezug, setzt das Script mein hm-600WR auf 10%-60 Watt bei 0 Watt Sonnenleistung
              <variables>
                <variable id="BN!a@q$SEAU4^)xo:SRJ">max_WR_Leistung</variable>
                <variable id="AcYpB0Ty+wVObL7=Y.a.">saldierte_Leistung</variable>
                <variable id="1}Q0686mMw0ZGk)e+r?(">IST-Wert_WR</variable>
                <variable id="le#}gR{6G.yhW=x|6pS8">SOLL-Wert_WR</variable>
                <variable id="av^_6@}eU-gIk%dJ,!,}">Stellwert_WR</variable>
              </variables>
              <block type="schedule" id="OO@|Rtoh_rlRKcPbfGAo" x="-2262" y="-1412">
                <field name="SCHEDULE">0,10,20,30,40,50 * * * * *</field>
                  <block type="comment" id="!%pL=9LkG.9?H[$qx2YI">
                    <field name="COMMENT">wenn Nachteinspeisung aktiv</field>
                    <next>
                      <block type="controls_if" id="7T?Z|?Y5.p-:678Tx$Ti">
                        <value name="IF0">
                          </block>
                        </value>
                          <block type="comment" id="un41CmgNYK(Y]/a|36h]">
                            <field name="COMMENT">Variablen beschreiben</field>
                            <next>
                              <block type="variables_set" id="EqaM{MYS7M6`-h;!zF93">
                                <field name="VAR" id="BN!a@q$SEAU4^)xo:SRJ">max_WR_Leistung</field>
                                  <block type="math_number" id="^w]xAxYJ7wN]m6;vk(fV">
                                  </block>
                                </value>
                                <next>
                                  <block type="variables_set" id="wR,+k_F;sMBf]aAYh+~t">
                                    <field name="VAR" id="AcYpB0Ty+wVObL7=Y.a.">saldierte_Leistung</field>
                                      <block type="get_value" id="RX$n4zq((b9U%h@.fnK,">
                                      </block>
                                    </value>
                                    <next>
                                      <block type="variables_set" id="~RRNE/ol!3MoTz;#)`PK">
                                        <field name="VAR" id="1}Q0686mMw0ZGk)e+r?(">IST-Wert_WR</field>
                                          <block type="get_value" id="5CvJRCtL/p)gjkP2,A%K">
                                          </block>
                                        </value>
                                        <next>
                                          <block type="variables_set" id="mZ+[ru,M.bbbDx$!%cbd">
                                            <field name="VAR" id="le#}gR{6G.yhW=x|6pS8">SOLL-Wert_WR</field>
                                              <block type="math_arithmetic" id="rv08p$|]!!eg`$;G4?[t">
                                                <value name="A">
                                                  <shadow type="math_number" id="n}1O70OfJnrAub1M8c[r">
                                                  </shadow>
                                                  <block type="math_arithmetic" id="3y=~@f2Qw!_YiJJ7yyxq">
                                                    <value name="A">
                                                      <shadow type="math_number" id="qLf/8W@9:(9C9tZ0)%zs">
                                                      </shadow>
                                                      <block type="variables_get" id="0N8%)B@Js@QKG(.|9C;/">
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      <shadow type="math_number" id="N@J09x*NDsor:$]CWIb)">
                                                      </shadow>
                                                      <block type="variables_get" id="k8CjoP?zy$q5sYiz|fp`">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  <shadow type="math_number" id="RrKwrA08I}5~xOXJTY=l">
                                                    <field name="NUM">0</field>
                                                  </shadow>
                                                </value>
                                              </block>
                                            </value>
                                            <next>
                                              <block type="comment" id="%`DgcG;amO_v`JekW7X#">
                                                <field name="COMMENT">maximal WR Leistung einstellen</field>
                                                <next>
                                                  <block type="controls_if" id="X.V3jJA5CZkZQUc%Yn{;">
                                                    <mutation elseif="3"></mutation>
                                                    <value name="IF0">
                                                      <block type="logic_compare" id="TKLqCZMY~Wns-BS@K,K2">
                                                        <value name="A">
                                                          <block type="variables_get" id="?B6HLx3_C%j{i`W3_h~4">
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          <block type="variables_get" id="=j*pkdNV[O*7=,LmG^hL">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                      <block type="variables_set" id="T{[2|VMAG8kqI|/hwnX.">
                                                        <field name="VAR" id="av^_6@}eU-gIk%dJ,!,}">Stellwert_WR</field>
                                                          <block type="variables_get" id="YULaab+c`U9LO`fH91iU">
                                                          </block>
                                                        </value>
                                                        <next>
                                                          <block type="comment" id="EK7aa~/95cKP_*9jtj~u">
                                                            <field name="COMMENT">Vermeidung W Änderungen &gt; 10W wegen Schwingen</field>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </statement>
                                                    <value name="IF1">
                                                      <block type="logic_compare" id="gVY;LPML8z$4uv`|Pif0">
                                                        <value name="A">
                                                          <block type="variables_get" id="(@i,:QFP%Ui#$Qc#}9zK">
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          <block type="math_arithmetic" id="qS;D4lv4a]J5@{4bq}}[">
                                                            <value name="A">
                                                              <shadow type="math_number" id="I_UEM;1#-apn7r1ubP.Q">
                                                              </shadow>
                                                              <block type="variables_get" id="E`wS@czP,1f}|UDsLxWy">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              <shadow type="math_number" id="vc]UO5xK#u/;a[$nc{7L">
                                                              </shadow>
                                                              <block type="math_number" id="=1.lbX$$-%3|HK%5O1s6">
        <field name="NUM">10</field>
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                      <block type="variables_set" id="2hh%7nQbUqWU/c/oD;1]">
                                                          <block type="math_arithmetic" id="B0B7N@oj(qhgq.[CfLrm">
                                                            <value name="A">
                                                              </shadow>
                                                              <block type="variables_get" id="~U[j;IW!IuC97gq%wTiT">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              </shadow>
                                                              <block type="math_number" id="npdn`ZMsF.UU%sumAg]f">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <next>
                                                          <block type="comment" id="+52id[cI4NLN3rH@}5+9">
                                                            <field name="COMMENT">Vermeidung W Änderungen &lt; 10W wegen Schwingen</field>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </statement>
                                                    <value name="IF2">
                                                      <block type="logic_compare" id="cp:Gbx*F@Z)|d?I_*NM[">
                                                        <value name="A">
                                                          <block type="variables_get" id="!m{sPTYgujd)08}F(iiw">
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          <block type="math_arithmetic" id="@tgzHg%Ae%v`SEE4*4Vh">
                                                            <value name="A">
                                                              </shadow>
                                                              <block type="variables_get" id="D:an~$hFrNvX$+lLY*).">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              </shadow>
                                                              <block type="math_number" id="c;wHpOxmnU[,woPIEeV^">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <statement name="DO2">
                                                      <block type="variables_set" id="0K$GCJ,wp=x$|NNUk}tJ">
                                                          <block type="math_arithmetic" id="J^O#Rg+68T:Xnfp?_IAb">
                                                            <value name="A">
                                                              </shadow>
                                                              <block type="variables_get" id="E@NrHLM:p${9Orq}X6^w">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              </shadow>
                                                              <block type="math_number" id="~LDPUO1B|3*vKw~E+7Ji">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </statement>
                                                    <value name="IF3">
                                                      <block type="logic_operation" id="P_uomd33Pm,$sKLHaK?8">
                                                        <value name="A">
                                                          <block type="logic_compare" id="%9^pqGFOAdF_Q4+I_kk|">
                                                            <value name="A">
                                                              <block type="variables_get" id="3FJ;ccWjMMWY975Kj@5s">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              <block type="math_number" id="3[DVAMar{wt_rK:[kRtU">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          <block type="logic_compare" id="H(i+-mX%!VeQT-k-dSW~">
                                                            <value name="A">
                                                              <block type="variables_get" id="If*V!EDhw)-mx.R1T4n|">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              <block type="math_number" id="Ba7:PVdMPz2$p~*KFDnQ">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <statement name="DO3">
                                                      <block type="comment" id="f1T,}m=[3vLl{OBvCavV">
                                                        <field name="COMMENT">benötigte Leistung einstellen</field>
                                                        <next>
                                                          <block type="variables_set" id="N2`__2dpmt+NXIcxENW/">
                                                              <block type="variables_get" id=";3S?@Jd,;,GMMI=X8X,0">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </statement>
                                                    <next>
                                                      <block type="comment" id="5V:8{H(Wby#lc(I7TXo3">
                                                        <field name="COMMENT">Vermeidung das SOLL-Wert &lt; 10W wird</field>
                                                        <next>
                                                          <block type="controls_if" id="z~i9;MPg9rNBrD:.ZcHx">
                                                            <value name="IF0">
                                                              <block type="logic_compare" id="#wA@uq;vFm}184]3,XTf">
        <value name="A">
        <block type="variables_get" id="b~F;nG1/8mo.0J8Qo;]3">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="1a.@~,.{Y9?msC|}i!Eh">
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                              <block type="variables_set" id="y-1KyiEpr+hF9[GjI6yR">
        <block type="math_number" id="ZCQw^kFMn*J`ypL@Xt.A">
        </block>
        </value>
                                                              </block>
                                                            </statement>
                                                            <next>
                                                              <block type="control" id="%cOvD+Otu7dc3(7+Pt%?">
        <block type="math_round" id="qp8W?7#X`RyZcY2C7b7k">
        <value name="NUM">
        <shadow type="math_number" id="OJ-sBUj]4[O=:~#bD`+/">
        </shadow>
        <block type="variables_get" id="c;t^q^e_m6@Xsn@8(u`r">
        </block>
        </value>
        </block>
        </value>
                                                              </block>
                                                            </next>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </statement>
                      </block>
                    </next>
                  </block>
                </statement>
              </block>
            </xml>
            K 1 Antwort Letzte Antwort
            • K knopers1
              @schoeppi_1
                <variables>
                </variables>
                      <next>
                          <value name="IF0">
                            </block>
                          </value>
                              <next>
                                    </block>
                                  </value>
                                  <next>
                                        </block>
                                      </value>
                                      <next>
                                            </block>
                                          </value>
                                          <next>
                                                  <value name="A">
                                                    </shadow>
                                                      <value name="A">
                                                        </shadow>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        </shadow>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    </shadow>
                                                  </value>
                                                </block>
                                              </value>
                                              <next>
                                                  <next>
                                                      <value name="IF0">
                                                          <value name="A">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                            </block>
                                                          </value>
                                                          <next>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </statement>
                                                      <value name="IF1">
                                                          <value name="A">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                              <value name="A">
        </shadow>
        </block>
                                                              </value>
                                                              <value name="B">
        </shadow>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                              <value name="A">
        </shadow>
        </block>
                                                              </value>
                                                              <value name="B">
        </shadow>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <next>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </statement>
                                                      <value name="IF2">
                                                          <value name="A">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                              <value name="A">
        </shadow>
        </block>
                                                              </value>
                                                              <value name="B">
        </shadow>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                              <value name="A">
        </shadow>
        </block>
                                                              </value>
                                                              <value name="B">
        </shadow>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </statement>
                                                      <value name="IF3">
                                                          <value name="A">
                                                              <value name="A">
        </block>
                                                              </value>
                                                              <value name="B">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                              <value name="A">
        </block>
                                                              </value>
                                                              <value name="B">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                          <next>
        </block>
                                                              </value>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </statement>
                                                      <next>
                                                          <next>
                                                              <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
        </block>
                                                              </value>
        </block>
        </value>
        </block>
                                                              </statement>
                                                              <next>
        <value name="NUM">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        </block>
                                                              </next>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </statement>
                        </block>
                      </next>
                    </block>
                  </statement>
                </block>
              </xml>
              knopers1
              #366
              @schoeppi_1
              evtl, habe ich falsch die Werte eingetragen....
              Mein Hichi IR Zähler saldiert auch, Ich habe aber drei HM-WR die Leistung abgeben, wovon nur einer geregelt werden soll! Da bei mir parallel drei Hoymiles arbeiten, muss ich bei "saldierte_Leistung" den Wert aller drei Hoymiles auswählen? Oder was genau wird dort eingetragen?
                @knopers1
                mal so nebenbei.
                CodierknechtC Offline
                Codierknecht
                #367
                Damit sind komplette Zyklen gemeint.
                HmIP|ZigBee|Tasmota|Unifi
                Zabbix Certified Specialist
                L 1 Antwort Letzte Antwort
                • CodierknechtC Codierknecht
                  Laser
                  schrieb am zuletzt editiert von Laser
                  #368
                  @codierknecht
                  Da sind schon Vollzyklen gemeint, wie ich das aus den Akkubeschreibungen rauslese. Aber wenn im Sekundentakt geladen und entladen wird (Herdplatte), dann komme ich sehr schnell auf einen Vollzyklus. Ich möchte das ungern testen.
                  • K knopers1
                    @schoeppi_1
                    schoeppi_1
                    #369
                    @knopers1
                    Ich habe dein Script angesehen.
                    Die 10Watt Änderung ist bereits im Script enthalten (Vermeidung großer Sprungantworten bei Sollwertänderungen).
                    Zur 2. Frage Tei1
                    Da du saldiert auf 0W kommen willst, brauchst du den 16.7.0 Wert aus dem IR Kopf. Egal was du sonst noch machst, ist das ja der Wert den du erreichen möchtest. Also möglichst genau 0W.
                    Hier:
                    muss das Kriterium rein, dass das die Nulleinspeisung einschaltet. Da ich nur nachts Nulleinspeisung betreibe, ist es bei mir die Steckdose, die am Ausgang des WR hängt.
                    Da du 24h Nulleinspeisung machen willst, wäre diese Abfrage unnötig. Du könntest z.B. einen neuen Datenpunkt erstellen vom Typ Zahl und auf "1" abfragen. Also wenn "1", dann arbeite das Script ab. Bei "0" mache nichts. Dann brauchst du nichts am Script ändern und könntest in der Objektansicht durch setzen auf "0" das Script anhalten. Oder du verwendest eben ein andere Bedingung. Jedenfalls brauchst du eine Bedingung, die immer erfüllt ist.
                    Zur 2. Frage Teil2
                    muss der saldierte Wert abgefragt werden, auf den geregelt werden soll. Das ist der 16.7.0 aus dem ausgelesenen IR Kopf.
                    Ich bekomme den Wert über MQTT in den ioBroker und habe ihn dann gewandelt in eine Variable.
                    Falls dir das hilft, anbei ein Screen meines Scriptes wie das zumindest bei mir geht:
                    Da ich selbst noch nicht viel Erfahrung bei der Blockly Projektierung habe, geht das vielleicht auch anders besser/kürzer/schneller? 🤷‍♂️
                    Weiterhin viel Erfolg.
                    C 1 Antwort Letzte Antwort
                    • S schoeppi_1
                      @knopers1
                      Zur 2. Frage Tei1
                      Hier:
                      Zur 2. Frage Teil2
                      chris299
                      #370
                      @schoeppi_1 dein setup klingt spannend. Was genau setzt du denn als Hardware ein? (Batterie und Ladegerät, Fotos wären auch toll…)
                      • C chris299
                        schoeppi_1
                        #371
                        @chris299
                        Moin,
                        prinzipiell ist es so:
                        PV auf Garagendach speist ins Hausnetz. Batterie 24V/100A steht im Keller, damit sie im Warmen steht.
                        Da der Weg von der Garage in den Keller sehr lang ist, habe ich mich dazu entschlossen, ein Ladegerät 24V/16A und keinen MPPT einzusetzen. Wissentlich, dass die Verluste größer sind aufgrund der DC/AC Wandlung, aber dafür ohne "Erdarbeiten für dicke Gleichspannungskabel und auch ohne großen Aufwand zu verwirklichen.
                        Aus der Batterie entnehme ich max. 2kW in der Nacht (um die Batterie zu schonen) . Das reicht für den Grundbedarf in den Sommermonaten über Nacht. Da meine PV bei aktuellem Wetter und Sonnenstand die Batterie seit ca. 2 Wochen nicht mehr voll bekommt, macht eine größere Batterie (derzeit) auch keinen Sinn.
                        Sieht also so aus:
                        Laden: WLan Steckdose_Laden ->Ladegerät -> 30A Sicherung -> Batterie
                        Entladen: Batterie -> 30A Sicherung -> Battery Protect (gegen Tiefenentladung) -> HM WR -> WLan Steckdose_Entladen
                        grobe Funktion: (alles im IoBroker verschaltet)
                        Laden:
                        Wenn nicht Entladen wird, schaltet das Ladegerät zu, wenn die PV >550W erzeugt. Wenn die Leistung unter 450W sinkt, wieder aus. Bei schöner Sonne, ist die Batterie dann in ca. 4-5 Stunden geladen. (~400Wx5Std = 2kW)
                        Entladen:
                        Wenn nicht geladen wird und es ist nach 19Uhr, schaltet die Steckdose_Entladen ein und es wird eingespeist. Wie geschrieben jetzt mit Nulleinspeisung, um möglichst effizient die erzeugte Batterieenergie zu verwenden.
                        Ich habe hier absichtlich keine Fabrikate genannt oder Fotos eingestellt, da ich nicht weiß ob das erlaubt ist.
                        • S schoeppi_1
                          @chris299
                          Moin,
                          Sieht also so aus:
                          Laden:
                          Entladen:
                          chris299
                          #372
                          @schoeppi_1 so ein setup hatte ich mir für mein Balkonkraftwerk auch überlegt, aber ich frage mich da folgendes:
                          Lohnt sich das für 1-2kWh Überschuss im Sommer überhaupt?
                          Und mit welchen Preisen für Komponenten muss ich da eigentlich rechnen?
                          Daher auch meine Frage nach den konkreten Geräten. (Warum sollte eine Nennung hier nicht erlaubt sein?)
                          Und kann man das wirklich mit einem normalen Ladegerät machen? Diese prüfen ja immer erstmal die Batterie und legen dann erst los. Wenn man aber die Ladung ständig wegen Wolken oder so unterbricht, dann kann das kaum gut sein für die Batterie....
                            axel
                            #373
                            @chris299 ich habe eine ähnlich große Anlage, 1,5 KWP. Anlage dient ausschließlich der Grundversorgung des Hauses. Einspeisen tue ich derzeit nichts. Das bedeutet unser PV Sturm wird zu 100 % selbst verbraucht. So habe ich die beste Amortisation meiner Investition. Ich werde im nächsten Jahr noch mal das selbe hinzu bauen. ich kann den Grundverbrauch noch nicht messen, der wird aber höher sein. Dann sollte ein wenig Überschuss entstehen. Aber für eine Batterienutzung reicht das meines Erachtens nicht. Dafür sind Batterien viel zu teuer und die Wirtschaftlichkeit ist nicht gegeben. Zu den Produkten: meines Erachtens kannst du nehmen, was du willst. Die Qualität ist meist sehr gleichbleibend. Die Dinger kommen eh oft aus der gleichen Fabrikationslinie und haben nur andere Labels. Das gilt auch für die Micro-Inverter.
                            QNAP 677 VM 16 GB, 4 Kerne, 3,4 GHz
                            29.375 Objekte
                            24.247 Zustände
                            • C chris299
                              schoeppi_1
                              #374
                              @chris299
                              Ich denke diese Frage muss jeder für sich beantworten, da der Anreiz unterschiedlich ist.
                              3 Beispiele...
                              Gewinnrechnung:
                              Invest ca. 1100€ (Batt. WR, Sicherung, Leitungen, Steckdose, Ladegerät,..) -> 180Tage x 30Cent x 2kW = 108€ im Jahr -> Amortisationszeit 10 Jahre wenn die Glaskugel stimmt und nichts kaputt geht. -> unter dem Gesichtspunkt wird es vermutlich nichts bringen
                              Spaß an der Sache:
                              Das gilt primär für mich. :-) Ich wollte einfach wissen, ob ich es hinbekomme und kann. Man fängt klein an (PV) und dann kommen die Ideen. So bin ich zum IoBroker gekommen und verstehe es als Hobby, bei gleichzeitigem sinnvollen Effekt.
                              Einspeisung vermeiden:
                              Es kann Sinn machen, die Einspeisung nicht zu groß werden zulassen.
                              Was ich geschrieben habe, war nur das prinzipielle Konzept. Wenn das Ladegerät aus ist, schalte ich es erst 2-3 Minuten verzögert ein wenn die Leistung über die PV vorhanden ist, um zu vermeiden, dass die Wolke am Himmel größer ist und es keinen Sinn macht einzuschalten.
                              Wenn das Ladegerät ein ist, schaltete es auch nicht gleich wieder ab wenn die Wolke am Himmel erscheint. Ich meine aktuell eine Ausschaltverzögerung von 7 Minuten drin zu haben wenn die untere Schwelle unterschritten wurde. Geht die Leistung zwischenzeitlich wieder hoch, bleibt das Ladegerät natürlich an. An die Werte und Bedingungen habe ich mich empirisch herangetastet.
                              Es ist nichts anderes, wie wenn du an deinem Auto ein Ladegerät anschließt und lädst, nur eben in Abhängigkeit der erzeugten Energie.
                              • S schoeppi_1
                                @chris299
                                3 Beispiele...
                                Gewinnrechnung:
                                Spaß an der Sache:
                                Codierknecht
                                #375
                                @schoeppi_1 sagte in Test Adapter OpenDTU:
                                Ansichtssache.
                                Aktuell geht man von etwa 1 Mio. BKW in DE aus, auch wenn die Zahl der offiziell angemeldeten deutlich geringer ist.
                                Lass es in den kommenden Monaten/Jahren mal 10 Mio. werden.
                                Wenn jedes davon nur 200 W Überschuss einspeist, sind das 2 Gigawatt. Also 2 kleine AKW. Da braucht man dann als Oppositionspolitiker nicht mehr über die Abschaltung der letzten 3 AKW Anfang des Jahres zu jammern.
                                Klar kriegt man dafür in der Regel (wegen unterlassenem Antrag beim Energieversorger) keine Vergütung.
                                Aber besser als z.B. komplette Landschaften für Braunkohle umzupflügen oder AKW ohne Endlager zu betreiben ist es allemal.
                                  Ansichtssache.
                                  schoeppi_1
                                  #376
                                  @codierknecht
                                  Ich habe nicht damit gemeint, dass man nicht vergütete Energie nicht einspeisen sollte, sondern die Energie aus der Batterie nicht unnötig ins Netz zu speisen, die man zuvor aus der PV mühsam geerntet hat. Daher ist die Regelung von Vorteil gegenüber der Konstanteinspeisung.
                                  Wenn es die 600(800)W Grenze nicht gäbe, oder man zumindest einen Elektriker finden würde, der auch kleine Anlagen abnimmt....
                                  Wenn es keinen Huddel mit dem Netzbetreiber geben würde, der sich wundert, dass bei einem BKW die Einspeisung am Jahresende so groß ist, das es mit 600W nicht stimmen kann ....
                                  ja wenn das nicht wäre... stimme ich Dir zu 100% zu :-)
                                  • IdleBitI Offline
                                    IdleBitI Offline
                                    IdleBit
                                    schrieb am zuletzt editiert von IdleBit
                                    #377
                                    Bitte macht einen eigenen Thread für die Sachen auf die nicht den Adapter betreffen.
                                    • IdleBitI IdleBit
                                      chris299
                                      #378
                                      @idlebit sorry, dass ich den Thread "missbraucht" habe. evtl. kann ein Moderator wie @Homoran die Beiträge in einen eigenen Thread verfrachten....
                                      Aber nun habe ich tatsächlich ein Thema zum Adapter:
                                      Wie ich in den letzten Tagen feststellen musste, ist der "Tagesertrag" meines HMS nicht wirklich der Tagesertrag sondern der Ertrag seit letztem Reset. Leider kommen bei dunklerem Herbstwetter wie jetzt solche Resets mehrmals am Tag vor...
                                      Dazu gibt es auch ein Issue hier: https://github.com/tbnobody/OpenDTU/issues/1397
                                      Evtl würde es sinn machen den DP umzubenennen und/oder eine Logik für die wirkliche Tagessumme zu implementieren.
                                      Nun wollte ich das mittels Blockly "umrunden" aber mir fehlt da etwas die Tiefe, wie man das angehen könnte.
                                      Das Problem ist dabei ja, das man die verschiedenen Reset-summen pro Tag summieren muss, man aber nicht weiss, ob an dem betreffenden Tag noch ein Reset kommt oder erst am nächsten Morgen.
                                      Ich schreibe mir die Tagessumme dann auch in einen eigenen DP einmal am Tag weg, damit ich jeweils nur ein einen Wert pro Tag in der History für mein echart Balken-diagramm bekomme.
                                      Kann man so eine temporäre Tagessumme im Script selbst halten oder braucht man dafür noch einen DP?
                                      S C 2 Antworten Letzte Antwort
                                      • C chris299
                                        schoeppi_1
                                        #379
                                        @chris299
                                        also ich kann Dir nur sagen, was ich gemacht habe. Ich verwende die OpenDTU Energiewerte gar nicht aus der genannten Problematik heraus.
                                        Ich habe ja WLAN Steckdosen (z.B. Shelly, Sonoff,... ) zur Schaltung der Nachteinspeisung und fürs Laden verwendet. Das ist ein sicherer Weg die Energie zu messen.
                                        Kurz vor Start der Nachteinspeisung schreibe ich mittels Blockly Trigger "Zeitplan" den Energiewert der Steckdose in einen DP "Zählerstand_Nacht_Entladen". Dann subtrahiere ich den Energiewert der Steckdose vom DP "Zählerstand_Nacht_Entladen" und erhalte die Differenz. Also dass, was ich aus der Batterie wirklich bekomme.
                                        Genau so mache ich es auch umgekehrt, wenn ich die Batterie über den Tag lade.
                                        • S schoeppi_1
                                          @chris299
                                          chris299
                                          #380
                                          @schoeppi_1 danke für den Hinweis, aber ich hätte da gern die Tageswerte der einzelnen Panel. Das bekommt man leider nur aus der OpenDTU...
