  4. Admin Problem
    5.6k
Admin Problem
admin
70 Beiträge 8 Kommentatoren 10.2k Aufrufe 7 Beobachtet
    @nullfreizeit
    iobroker stop
    iobroker fix
    iobroker start
    iobroker diag
    Poste mal die lange Ausgabe von diag.
    N Offline
    N Offline
    nullfreizeit
    #41
    Danke Thomas, hier der output…
    *** ioBroker Diagnosis ***
    Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
    The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
    https://forum.iobroker.net
    Just copy and paste the Summary Page, including the ``` characters at start and end.
    It helps us to help you!
    Press any key to continue
    ======== Start marking the full check here =========
    Skript v.2022-12-13
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Architecture:   armv7l
    Docker:         false
    Virtualization: none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 10 (buster)
    Release:        10
    Codename:       buster
    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     12:40:40 up  2:58,  1 user,  load average: 2.90, 5.12, 7.21
    CPU threads: 4
    *** Time and Time Zones ***
    Sun Dec 25 11:40:40 UTC 2022
    Sun Dec 25 12:40:40 CET 2022
    CET +0100
    Europe/Berlin
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           3.8G        132M        2.0G         16M        1.7G        3.5G
    Swap:           99M        5.0M         94M
    Total:         3.9G        137M        2.1G
             3838 M total memory
              133 M used memory
              702 M active memory
              923 M inactive memory
             1991 M free memory
              245 M buffer memory
             1468 M swap cache
               99 M total swap
                5 M used swap
               94 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4       29G   16G   13G  57% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     1.9G   16K  1.9G   1% /dev/shm
    tmpfs          tmpfs     1.9G   17M  1.9G   1% /run
    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
    Show mounted filesystems (real ones only):
    TARGET        SOURCE         FSTYPE OPTIONS
    /             /dev/mmcblk0p2 ext4   rw,noatime
    |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    7.6G    /var/
    5.9G    /var/lib
    5.8G    /var/lib/motioneye/Camera2
    3.6G    /var/lib/motioneye/Camera2/2021-08-04
    /opt/iobroker/backups:
    953M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.8G    /opt/iobroker/iobroker-data/
    1.3G    /opt/iobroker/iobroker-data/history
    278M    /opt/iobroker/iobroker-data/files
    138M    /opt/iobroker/iobroker-data/backup-objects
    72M     /opt/iobroker/iobroker-data/files/telegram.admin
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    14M     /opt/iobroker/iobroker-data/objects.jsonl
    8.6M    /opt/iobroker/iobroker-data/objects.json.migrated
    8.6M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    7.4M    /opt/iobroker/iobroker-data/files/eventlist/static/js/2.fcddf06e.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.12.1
    /usr/bin/node           v18.12.1
    /usr/bin/npm            8.19.2
    nodejs:
      Installed: 18.12.1-deb-1nodesource1
      Candidate: 18.12.1-deb-1nodesource1
      Version table:
     *** 18.12.1-deb-1nodesource1 100
            100 /var/lib/dpkg/status
         16.19.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u2 500
    Temp directories causing npm8 problem: 650
    *** ioBroker-Installation ***
    ioBroker Status
    node:internal/modules/cjs/loader:998
      throw err;
    Error: Cannot find module 'node-forge'
    Require stack:
    - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
    - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
    - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
        at Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
        at Module._load (node:internal/modules/cjs/loader:841:27)
        at Module.require (node:internal/modules/cjs/loader:1061:19)
        at require (node:internal/modules/cjs/helpers:103:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:7:15)
        at Module._compile (node:internal/modules/cjs/loader:1159:14)
        at Module._extensions..js (node:internal/modules/cjs/loader:1213:10)
        at Module.load (node:internal/modules/cjs/loader:1037:32)
        at Module._load (node:internal/modules/cjs/loader:878:12)
        at Module.require (node:internal/modules/cjs/loader:1061:19) {
      code: 'MODULE_NOT_FOUND',
      requireStack: [
        '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
        '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    Node.js v18.12.1
    Core adapters versions
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.12.1
    js-controller:
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.12.1
    admin:
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: @googleapis/drive@4.0.1 /opt/iobroker/node_modules/@googleapis/drive
    npm ERR! extraneous: @iobroker/ws-server@2.1.0 /opt/iobroker/node_modules/@iobroker/ws-server
    npm ERR! extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@protobufjs/aspromise
    npm ERR! extraneous: @protobufjs/base64@1.1.2 /opt/iobroker/node_modules/@protobufjs/base64
    npm ERR! extraneous: @protobufjs/codegen@2.0.4 /opt/iobroker/node_modules/@protobufjs/codegen
    npm ERR! extraneous: @protobufjs/eventemitter@1.1.0 /opt/iobroker/node_modules/@protobufjs/eventemitter
    npm ERR! extraneous: @protobufjs/fetch@1.1.0 /opt/iobroker/node_modules/@protobufjs/fetch
    npm ERR! extraneous: @protobufjs/float@1.0.2 /opt/iobroker/node_modules/@protobufjs/float
    npm ERR! extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@protobufjs/inquire
    npm ERR! extraneous: @protobufjs/path@1.1.2 /opt/iobroker/node_modules/@protobufjs/path
    npm ERR! extraneous: @protobufjs/pool@1.1.0 /opt/iobroker/node_modules/@protobufjs/pool
    npm ERR! extraneous: @protobufjs/utf8@1.1.0 /opt/iobroker/node_modules/@protobufjs/utf8
    npm ERR! extraneous: @serialport/binding-mock@10.2.2 /opt/iobroker/node_modules/@serialport/binding-mock
    npm ERR! extraneous: @serialport/bindings-cpp@10.8.0 /opt/iobroker/node_modules/@serialport/bindings-cpp
    npm ERR! extraneous: @serialport/bindings-interface@1.2.2 /opt/iobroker/node_modules/@serialport/bindings-interface
    npm ERR! extraneous: @serialport/parser-byte-length@10.5.0 /opt/iobroker/node_modules/@serialport/parser-byte-length
    npm ERR! extraneous: @serialport/parser-cctalk@10.5.0 /opt/iobroker/node_modules/@serialport/parser-cctalk
    npm ERR! extraneous: @serialport/parser-delimiter@10.5.0 /opt/iobroker/node_modules/@serialport/parser-delimiter
    npm ERR! extraneous: @serialport/parser-inter-byte-timeout@10.5.0 /opt/iobroker/node_modules/@serialport/parser-inter-byte-timeout
    npm ERR! extraneous: @serialport/parser-packet-length@10.5.0 /opt/iobroker/node_modules/@serialport/parser-packet-length
    npm ERR! extraneous: @serialport/parser-readline@10.5.0 /opt/iobroker/node_modules/@serialport/parser-readline
    npm ERR! extraneous: @serialport/parser-ready@10.5.0 /opt/iobroker/node_modules/@serialport/parser-ready
    npm ERR! extraneous: @serialport/parser-regex@10.5.0 /opt/iobroker/node_modules/@serialport/parser-regex
    npm ERR! extraneous: @serialport/parser-slip-encoder@10.5.0 /opt/iobroker/node_modules/@serialport/parser-slip-encoder
    npm ERR! extraneous: @serialport/parser-spacepacket@10.5.0 /opt/iobroker/node_modules/@serialport/parser-spacepacket
    npm ERR! extraneous: @serialport/stream@10.5.0 /opt/iobroker/node_modules/@serialport/stream
    npm ERR! extraneous: @swc/helpers@0.3.17 /opt/iobroker/node_modules/@swc/helpers
    npm ERR! extraneous: @tootallnate/once@1.1.2 /opt/iobroker/node_modules/@tootallnate/once
    npm ERR! extraneous: @types/long@4.0.2 /opt/iobroker/node_modules/@types/long
    npm ERR! extraneous: @types/node-schedule@1.3.2 /opt/iobroker/node_modules/@types/node-schedule
    npm ERR! extraneous: @types/suncalc@1.9.0 /opt/iobroker/node_modules/@types/suncalc
    npm ERR! extraneous: acorn-walk@8.2.0 /opt/iobroker/node_modules/acorn-walk
    npm ERR! extraneous: acorn@8.8.1 /opt/iobroker/node_modules/acorn
    npm ERR! extraneous: ansi-regex@2.1.1 /opt/iobroker/node_modules/ansi-regex
    npm ERR! extraneous: any-promise@1.3.0 /opt/iobroker/node_modules/any-promise
    npm ERR! extraneous: aproba@1.2.0 /opt/iobroker/node_modules/aproba
    npm ERR! extraneous: are-we-there-yet@1.1.7 /opt/iobroker/node_modules/are-we-there-yet
    npm ERR! extraneous: array.prototype.findindex@2.2.1 /opt/iobroker/node_modules/array.prototype.findindex
    npm ERR! extraneous: arrify@2.0.1 /opt/iobroker/node_modules/arrify
    npm ERR! extraneous: ast-types@0.13.4 /opt/iobroker/node_modules/ast-types
    npm ERR! extraneous: async@ /opt/iobroker/node_modules/async
    npm ERR! extraneous: available-typed-arrays@1.0.5 /opt/iobroker/node_modules/available-typed-arrays
    npm ERR! extraneous: balanced-match@1.0.2 /opt/iobroker/node_modules/balanced-match
    npm ERR! extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
    npm ERR! extraneous: base64-js@1.5.1 /opt/iobroker/node_modules/base64-js
    npm ERR! extraneous: bignumber.js@9.1.1 /opt/iobroker/node_modules/bignumber.js
    npm ERR! extraneous: bl@1.2.3 /opt/iobroker/node_modules/bl
    npm ERR! extraneous: bluebird@3.7.2 /opt/iobroker/node_modules/bluebird
    npm ERR! extraneous: brace-expansion@2.0.1 /opt/iobroker/node_modules/brace-expansion
    npm ERR! extraneous: brotli@1.3.3 /opt/iobroker/node_modules/brotli
    npm ERR! extraneous: buffer@4.9.2 /opt/iobroker/node_modules/buffer
    npm ERR! extraneous: busboy@1.6.0 /opt/iobroker/node_modules/busboy
    npm ERR! extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
    npm ERR! extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
    npm ERR! extraneous: clone@2.1.2 /opt/iobroker/node_modules/clone
    npm ERR! extraneous: code-point-at@1.1.0 /opt/iobroker/node_modules/code-point-at
    npm ERR! extraneous: compress-json@2.1.2 /opt/iobroker/node_modules/compress-json
    npm ERR! extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible
    npm ERR! extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression
    npm ERR! extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
    npm ERR! extraneous: copy-to@2.0.1 /opt/iobroker/node_modules/copy-to
    npm ERR! extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
    npm ERR! extraneous: crypto-js@4.1.1 /opt/iobroker/node_modules/crypto-js
    npm ERR! extraneous: data-uri-to-buffer@3.0.1 /opt/iobroker/node_modules/data-uri-to-buffer
    npm ERR! extraneous: decompress-response@6.0.0 /opt/iobroker/node_modules/decompress-response
    npm ERR! extraneous: deep-equal@2.1.0 /opt/iobroker/node_modules/deep-equal
    npm ERR! extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
    npm ERR! extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/deep-is
    npm ERR! extraneous: default-user-agent@1.0.0 /opt/iobroker/node_modules/default-user-agent
    npm ERR! extraneous: degenerator@3.0.2 /opt/iobroker/node_modules/degenerator
    npm ERR! extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
    npm ERR! extraneous: detect-libc@1.0.3 /opt/iobroker/node_modules/detect-libc
    npm ERR! extraneous: dfa@1.2.0 /opt/iobroker/node_modules/dfa
    npm ERR! extraneous: dgram@1.0.1 /opt/iobroker/node_modules/dgram
    npm ERR! extraneous: digest-header@1.0.0 /opt/iobroker/node_modules/digest-header
    npm ERR! extraneous: dns-packet@1.3.4 /opt/iobroker/node_modules/dns-packet
    npm ERR! extraneous: dropbox-v2-api@ /opt/iobroker/node_modules/dropbox-v2-api
    npm ERR! extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/end-of-stream
    npm ERR! extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
    npm ERR! extraneous: es-get-iterator@1.1.2 /opt/iobroker/node_modules/es-get-iterator
    npm ERR! extraneous: es-shim-unscopables@1.0.0 /opt/iobroker/node_modules/es-shim-unscopables
    npm ERR! extraneous: es-to-primitive@1.2.1 /opt/iobroker/node_modules/es-to-primitive
    npm ERR! extraneous: escodegen@1.14.3 /opt/iobroker/node_modules/escodegen
    npm ERR! extraneous: esprima@4.0.1 /opt/iobroker/node_modules/esprima
    npm ERR! extraneous: estraverse@4.3.0 /opt/iobroker/node_modules/estraverse
    npm ERR! extraneous: esutils@2.0.3 /opt/iobroker/node_modules/esutils
    npm ERR! extraneous: eventemitter3@3.1.2 /opt/iobroker/node_modules/eventemitter3
    npm ERR! extraneous: events@1.1.1 /opt/iobroker/node_modules/events
    npm ERR! extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
    npm ERR! extraneous: express-fileupload@1.4.0 /opt/iobroker/node_modules/express-fileupload
    npm ERR! extraneous: extend-shallow@2.0.1 /opt/iobroker/node_modules/extend-shallow
    npm ERR! extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/fast-levenshtein
    npm ERR! extraneous: fast-text-encoding@1.0.6 /opt/iobroker/node_modules/fast-text-encoding
    npm ERR! extraneous: fast-xml-parser@3.21.1 /opt/iobroker/node_modules/fast-xml-parser
    npm ERR! extraneous: file-type@3.9.0 /opt/iobroker/node_modules/file-type
    npm ERR! extraneous: file-uri-to-path@2.0.0 /opt/iobroker/node_modules/file-uri-to-path
    npm ERR! extraneous: fontkit@ /opt/iobroker/node_modules/fontkit
    npm ERR! extraneous: for-each@0.3.3 /opt/iobroker/node_modules/for-each
    npm ERR! extraneous: formstream@1.1.1 /opt/iobroker/node_modules/formstream
    npm ERR! extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
    npm ERR! extraneous: fs-extra@11.1.0 /opt/iobroker/node_modules/fs-extra
    npm ERR! extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
    npm ERR! extraneous: function.prototype.name@1.1.5 /opt/iobroker/node_modules/function.prototype.name
    npm ERR! extraneous: functions-have-names@1.2.3 /opt/iobroker/node_modules/functions-have-names
    npm ERR! extraneous: gauge@2.7.4 /opt/iobroker/node_modules/gauge
    npm ERR! extraneous: gaxios@5.0.2 /opt/iobroker/node_modules/gaxios
    npm ERR! extraneous: gcp-metadata@5.1.0 /opt/iobroker/node_modules/gcp-metadata
    npm ERR! extraneous: get-symbol-description@1.0.0 /opt/iobroker/node_modules/get-symbol-description
    npm ERR! extraneous: get-uri@3.0.2 /opt/iobroker/node_modules/get-uri
    npm ERR! extraneous: github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
    npm ERR! extraneous: google-auth-library@8.7.0 /opt/iobroker/node_modules/google-auth-library
    npm ERR! extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
    npm ERR! extraneous: googleapis-common@6.0.4 /opt/iobroker/node_modules/googleapis-common
    npm ERR! extraneous: gopd@1.0.1 /opt/iobroker/node_modules/gopd
    npm ERR! extraneous: gtoken@6.1.2 /opt/iobroker/node_modules/gtoken
    npm ERR! extraneous: has-bigints@1.0.2 /opt/iobroker/node_modules/has-bigints
    npm ERR! extraneous: has-binary2@1.0.3 /opt/iobroker/node_modules/has-binary2
    npm ERR! extraneous: has-tostringtag@1.0.0 /opt/iobroker/node_modules/has-tostringtag
    npm ERR! extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
    npm ERR! extraneous: he@1.2.0 /opt/iobroker/node_modules/he
    npm ERR! extraneous: hot-patcher@1.0.0 /opt/iobroker/node_modules/hot-patcher
    npm ERR! extraneous: http-proxy-agent@4.0.1 /opt/iobroker/node_modules/http-proxy-agent
    npm ERR! extraneous: humanize-ms@1.2.1 /opt/iobroker/node_modules/humanize-ms
    npm ERR! extraneous: ieee754@1.1.13 /opt/iobroker/node_modules/ieee754
    npm ERR! extraneous: ini@1.3.8 /opt/iobroker/node_modules/ini
    npm ERR! extraneous: internal-slot@1.0.4 /opt/iobroker/node_modules/internal-slot
    npm ERR! invalid: iobroker.backitup@ /opt/iobroker/node_modules/iobroker.backitup
    npm ERR! invalid: iobroker.eventlist@ /opt/iobroker/node_modules/iobroker.eventlist
    npm ERR! invalid: iobroker.flot@ /opt/iobroker/node_modules/iobroker.flot
    npm ERR! extraneous: iobroker.history@2.2.4 /opt/iobroker/node_modules/iobroker.history
    npm ERR! invalid: iobroker.js-controller@4.0.23 /opt/iobroker/node_modules/iobroker.js-controller
    npm ERR! invalid: iobroker.onvif@ /opt/iobroker/node_modules/iobroker.onvif
    npm ERR! extraneous: iobroker.simple-api@2.7.2 /opt/iobroker/node_modules/iobroker.simple-api
    npm ERR! extraneous: iobroker.socketio@4.2.0 /opt/iobroker/node_modules/iobroker.socketio
    npm ERR! invalid: iobroker.telegram@ /opt/iobroker/node_modules/iobroker.telegram
    npm ERR! invalid: iobroker.time-switch@ /opt/iobroker/node_modules/iobroker.time-switch
    npm ERR! invalid: iobroker.vis-weather@ /opt/iobroker/node_modules/iobroker.vis-weather
    npm ERR! invalid: iobroker.web@ /opt/iobroker/node_modules/iobroker.web
    npm ERR! extraneous: iobroker.ws.server@1.0.1 /opt/iobroker/node_modules/iobroker.ws.server
    npm ERR! extraneous: iobroker.ws@1.3.0 /opt/iobroker/node_modules/iobroker.ws
    npm ERR! extraneous: ip@1.1.8 /opt/iobroker/node_modules/ip
    npm ERR! extraneous: ipaddr.js@2.0.1 /opt/iobroker/node_modules/ipaddr.js
    npm ERR! extraneous: is-arguments@1.1.1 /opt/iobroker/node_modules/is-arguments
    npm ERR! extraneous: is-bigint@1.0.4 /opt/iobroker/node_modules/is-bigint
    npm ERR! extraneous: is-boolean-object@1.1.2 /opt/iobroker/node_modules/is-boolean-object
    npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
    npm ERR! extraneous: is-callable@1.2.7 /opt/iobroker/node_modules/is-callable
    npm ERR! extraneous: is-date-object@1.0.5 /opt/iobroker/node_modules/is-date-object
    npm ERR! extraneous: is-extendable@0.1.1 /opt/iobroker/node_modules/is-extendable
    npm ERR! extraneous: is-fullwidth-code-point@1.0.0 /opt/iobroker/node_modules/is-fullwidth-code-point
    npm ERR! extraneous: is-map@2.0.2 /opt/iobroker/node_modules/is-map
    npm ERR! extraneous: is-negative-zero@2.0.2 /opt/iobroker/node_modules/is-negative-zero
    npm ERR! extraneous: is-number-object@1.0.7 /opt/iobroker/node_modules/is-number-object
    npm ERR! extraneous: is-regex@1.1.4 /opt/iobroker/node_modules/is-regex
    npm ERR! extraneous: is-set@2.0.2 /opt/iobroker/node_modules/is-set
    npm ERR! extraneous: is-shared-array-buffer@1.0.2 /opt/iobroker/node_modules/is-shared-array-buffer
    npm ERR! extraneous: is-string@1.0.7 /opt/iobroker/node_modules/is-string
    npm ERR! extraneous: is-symbol@1.0.4 /opt/iobroker/node_modules/is-symbol
    npm ERR! extraneous: is-typed-array@1.1.10 /opt/iobroker/node_modules/is-typed-array
    npm ERR! extraneous: is-weakmap@2.0.1 /opt/iobroker/node_modules/is-weakmap
    npm ERR! extraneous: is-weakref@1.0.2 /opt/iobroker/node_modules/is-weakref
    npm ERR! extraneous: is-weakset@2.0.2 /opt/iobroker/node_modules/is-weakset
    npm ERR! extraneous: jmespath@0.15.0 /opt/iobroker/node_modules/jmespath
    npm ERR! extraneous: json-bigint@1.0.0 /opt/iobroker/node_modules/json-bigint
    npm ERR! extraneous: jwa@2.0.0 /opt/iobroker/node_modules/jwa
    npm ERR! extraneous: jws@4.0.0 /opt/iobroker/node_modules/jws
    npm ERR! extraneous: layerr@0.1.2 /opt/iobroker/node_modules/layerr
    npm ERR! extraneous: levn@0.3.0 /opt/iobroker/node_modules/levn
    npm ERR! extraneous: linebreak@1.1.0 /opt/iobroker/node_modules/linebreak
    npm ERR! extraneous: localforage@1.10.0 /opt/iobroker/node_modules/localforage
    npm ERR! extraneous: lodash.get@4.4.2 /opt/iobroker/node_modules/lodash.get
    npm ERR! extraneous: long@4.0.0 /opt/iobroker/node_modules/long
    npm ERR! extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
    npm ERR! extraneous: mdns-discovery@0.2.6 /opt/iobroker/node_modules/mdns-discovery
    npm ERR! extraneous: mimic-response@3.1.0 /opt/iobroker/node_modules/mimic-response
    npm ERR! extraneous: minimatch@5.1.2 /opt/iobroker/node_modules/minimatch
    npm ERR! extraneous: minimist@1.2.7 /opt/iobroker/node_modules/minimist
    npm ERR! extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/mkdirp-classic
    npm ERR! extraneous: mz@2.7.0 /opt/iobroker/node_modules/mz
    npm ERR! extraneous: napi-build-utils@1.0.2 /opt/iobroker/node_modules/napi-build-utils
    npm ERR! extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
    npm ERR! extraneous: netmask@2.0.2 /opt/iobroker/node_modules/netmask
    npm ERR! extraneous: nimble@0.0.2 /opt/iobroker/node_modules/nimble
    npm ERR! extraneous: node-abi@2.30.1 /opt/iobroker/node_modules/node-abi
    npm ERR! extraneous: node-addon-api@5.0.0 /opt/iobroker/node_modules/node-addon-api
    npm ERR! extraneous: node-fetch@2.6.7 /opt/iobroker/node_modules/node-fetch
    npm ERR! extraneous: node-gyp-build@4.5.0 /opt/iobroker/node_modules/node-gyp-build
    npm ERR! extraneous: node-mndp@0.0.3 /opt/iobroker/node_modules/node-mndp
    npm ERR! extraneous: node-ssdp@4.0.1 /opt/iobroker/node_modules/node-ssdp
    npm ERR! extraneous: node-telegram-bot-api@0.59.0 /opt/iobroker/node_modules/node-telegram-bot-api
    npm ERR! extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
    npm ERR! extraneous: noop-logger@0.1.1 /opt/iobroker/node_modules/noop-logger
    npm ERR! extraneous: npmlog@4.1.2 /opt/iobroker/node_modules/npmlog
    npm ERR! extraneous: number-is-nan@1.0.1 /opt/iobroker/node_modules/number-is-nan
    npm ERR! extraneous: object-is@1.1.5 /opt/iobroker/node_modules/object-is
    npm ERR! extraneous: object.assign@4.1.4 /opt/iobroker/node_modules/object.assign
    npm ERR! extraneous: onvif@0.6.7 /opt/iobroker/node_modules/onvif
    npm ERR! extraneous: optionator@0.8.3 /opt/iobroker/node_modules/optionator
    npm ERR! extraneous: os-name@1.0.3 /opt/iobroker/node_modules/os-name
    npm ERR! extraneous: osx-release@1.1.0 /opt/iobroker/node_modules/osx-release
    npm ERR! extraneous: pac-proxy-agent@5.0.0 /opt/iobroker/node_modules/pac-proxy-agent
    npm ERR! extraneous: pac-resolver@5.0.1 /opt/iobroker/node_modules/pac-resolver
    npm ERR! extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
    npm ERR! extraneous: pdfkit@ /opt/iobroker/node_modules/pdfkit
    npm ERR! extraneous: png-js@1.0.0 /opt/iobroker/node_modules/png-js
    npm ERR! extraneous: prebuild-install@5.3.6 /opt/iobroker/node_modules/prebuild-install
    npm ERR! extraneous: prelude-ls@1.1.2 /opt/iobroker/node_modules/prelude-ls
    npm ERR! extraneous: proxy-agent@5.0.0 /opt/iobroker/node_modules/proxy-agent
    npm ERR! extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/proxy-from-env
    npm ERR! extraneous: pump@2.0.1 /opt/iobroker/node_modules/pump
    npm ERR! extraneous: querystring@0.2.0 /opt/iobroker/node_modules/querystring
    npm ERR! extraneous: querystringify@2.2.0 /opt/iobroker/node_modules/querystringify
    npm ERR! extraneous: rc@1.2.8 /opt/iobroker/node_modules/rc
    npm ERR! extraneous: regexp.prototype.flags@1.4.3 /opt/iobroker/node_modules/regexp.prototype.flags
    npm ERR! extraneous: request-promise-core@1.1.4 /opt/iobroker/node_modules/request-promise-core
    npm ERR! extraneous: request-promise@4.2.6 /opt/iobroker/node_modules/request-promise
    npm ERR! extraneous: requires-port@1.0.0 /opt/iobroker/node_modules/requires-port
    npm ERR! extraneous: restructure@2.0.1 /opt/iobroker/node_modules/restructure
    npm ERR! extraneous: safe-regex-test@1.0.0 /opt/iobroker/node_modules/safe-regex-test
    npm ERR! extraneous: serialport@10.5.0 /opt/iobroker/node_modules/serialport
    npm ERR! extraneous: set-blocking@2.0.0 /opt/iobroker/node_modules/set-blocking
    npm ERR! extraneous: sharp@0.25.4 /opt/iobroker/node_modules/sharp
    npm ERR! extraneous: simple-concat@1.0.1 /opt/iobroker/node_modules/simple-concat
    npm ERR! extraneous: simple-get@4.0.1 /opt/iobroker/node_modules/simple-get
    npm ERR! extraneous: smart-buffer@4.2.0 /opt/iobroker/node_modules/smart-buffer
    npm ERR! extraneous: socks-proxy-agent@5.0.1 /opt/iobroker/node_modules/socks-proxy-agent
    npm ERR! extraneous: socks@2.7.1 /opt/iobroker/node_modules/socks
    npm ERR! extraneous: socksv5@0.0.6 /opt/iobroker/node_modules/socksv5
    npm ERR! extraneous: stealthy-require@1.1.1 /opt/iobroker/node_modules/stealthy-require
    npm ERR! extraneous: streamsearch@1.1.0 /opt/iobroker/node_modules/streamsearch
    npm ERR! extraneous: string-width@1.0.2 /opt/iobroker/node_modules/string-width
    npm ERR! extraneous: string.prototype.trimend@1.0.6 /opt/iobroker/node_modules/string.prototype.trimend
    npm ERR! extraneous: string.prototype.trimstart@1.0.6 /opt/iobroker/node_modules/string.prototype.trimstart
    npm ERR! extraneous: strip-ansi@3.0.1 /opt/iobroker/node_modules/strip-ansi
    npm ERR! extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/strip-json-comments
    npm ERR! extraneous: strnum@1.0.5 /opt/iobroker/node_modules/strnum
    npm ERR! extraneous: suncalc@1.9.0 /opt/iobroker/node_modules/suncalc
    npm ERR! extraneous: tar-fs@2.1.1 /opt/iobroker/node_modules/tar-fs
    npm ERR! extraneous: tar-stream@2.2.0 /opt/iobroker/node_modules/tar-stream
    npm ERR! extraneous: thenify-all@1.6.0 /opt/iobroker/node_modules/thenify-all
    npm ERR! extraneous: thenify@3.3.1 /opt/iobroker/node_modules/thenify
    npm ERR! extraneous: tiny-inflate@1.0.3 /opt/iobroker/node_modules/tiny-inflate
    npm ERR! extraneous: tr46@0.0.3 /opt/iobroker/node_modules/tr46
    npm ERR! extraneous: type-check@0.3.2 /opt/iobroker/node_modules/type-check
    npm ERR! extraneous: unbox-primitive@1.0.2 /opt/iobroker/node_modules/unbox-primitive
    npm ERR! extraneous: unescape@1.0.1 /opt/iobroker/node_modules/unescape
    npm ERR! extraneous: unicode-properties@1.4.1 /opt/iobroker/node_modules/unicode-properties
    npm ERR! extraneous: unicode-trie@2.0.0 /opt/iobroker/node_modules/unicode-trie
    npm ERR! extraneous: url-join@4.0.1 /opt/iobroker/node_modules/url-join
    npm ERR! extraneous: url-parse@1.5.10 /opt/iobroker/node_modules/url-parse
    npm ERR! extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
    npm ERR! extraneous: url@0.10.3 /opt/iobroker/node_modules/url
    npm ERR! extraneous: urllib@2.40.0 /opt/iobroker/node_modules/urllib
    npm ERR! extraneous: utility@1.17.0 /opt/iobroker/node_modules/utility
    npm ERR! extraneous: uuid@9.0.0 /opt/iobroker/node_modules/uuid
    npm ERR! extraneous: vm2@3.9.13 /opt/iobroker/node_modules/vm2
    npm ERR! extraneous: webdav@4.11.2 /opt/iobroker/node_modules/webdav
    npm ERR! extraneous: webidl-conversions@3.0.1 /opt/iobroker/node_modules/webidl-conversions
    npm ERR! extraneous: whatwg-url@5.0.0 /opt/iobroker/node_modules/whatwg-url
    npm ERR! extraneous: which-boxed-primitive@1.0.2 /opt/iobroker/node_modules/which-boxed-primitive
    npm ERR! extraneous: which-collection@1.0.1 /opt/iobroker/node_modules/which-collection
    npm ERR! extraneous: which-pm-runs@1.1.0 /opt/iobroker/node_modules/which-pm-runs
    npm ERR! extraneous: which-typed-array@1.1.9 /opt/iobroker/node_modules/which-typed-array
    npm ERR! extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
    npm ERR! extraneous: win-release@1.1.1 /opt/iobroker/node_modules/win-release
    npm ERR! extraneous: word-wrap@1.2.3 /opt/iobroker/node_modules/word-wrap
    npm ERR! extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
    npm ERR!     /home/pi/.npm/_logs/2022-12-25T11_40_46_790Z-debug-0.log
    Adapters from github:   4
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.12.1
    ioBroker-Repositories
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.12.1
    ioBroker-Instances
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.12.1
    Objects and States
    Objects:        0
    States:         0
    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:2 https://deb.nodesource.com/node_16.x buster InRelease
    Hit:3 http://archive.raspberrypi.org/debian buster InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:8081            0.0.0.0:*               LISTEN      0          14968      500/motion
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17637      690/sshd
    tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          16733      371/python
    tcp        0      0 127.0.0.1:7999          0.0.0.0:*               LISTEN      0          14970      500/motion
    tcp        0      0 127.0.0.1:554           0.0.0.0:*               LISTEN      0          14969      500/motion
    tcp        0      0 0.0.0.0:5038            0.0.0.0:*               LISTEN      109        16032      681/asterisk
    tcp6       0      0 :::22                   :::*                    LISTEN      0          17639      690/sshd
    udp        0      0 0.0.0.0:5060            0.0.0.0:*                           109        16046      681/asterisk
    udp        0      0 0.0.0.0:4569            0.0.0.0:*                           109        16047      681/asterisk
    udp        0      0 0.0.0.0:50708           0.0.0.0:*                           108        14912      389/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15785      680/dhcpcd
    udp        0      0 0.0.0.0:42178           0.0.0.0:*                           109        17779      681/asterisk
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14910      389/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          16714      680/dhcpcd
    udp6       0      0 :::51309                :::*                                109        17780      681/asterisk
    udp6       0      0 :::5353                 :::*                                108        14911      389/avahi-daemon: r
    udp6       0      0 :::38784                :::*                                108        14913      389/avahi-daemon: r
    iob diag has finished.
    Press any key for a summary
    Copy text starting here:
                            v.2022-12-13
    Operatingsystem:        Raspbian GNU/Linux 10 (buster)
    Installation:           Native
    Timezone:               Europe/Berlin
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Nodejs-Installation:    /usr/bin/nodejs         v18.12.1
                            /usr/bin/npm            8.19.2
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.12.1
    ioBroker Core:          js-controller
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.12.1
                            admin
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.12.1
    ioBroker Status:
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.12.1
    Pending iob updates:    0
      throw err;
    Require stack:
      requireStack: [
    Node.js v18.12.1
    Objects:                0
    States:                 0
    Size of iob-Database:
    3.5M    /opt/iobroker/iobroker-data/states.jsonl
    3.0M    /opt/iobroker/iobroker-data/states.json.migrated
    3.0M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    ====================== END OF SUMMARY =================
    • N nullfreizeit
      Skript v.2022-12-13
      *** BASE SYSTEM ***
      Docker:         false
      Release:        10
      Codename:       buster
      VERSION_ID="10"
      ID=raspbian
      ID_LIKE=debian
      CPU threads: 4
      CET +0100
      Europe/Berlin
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           99M        5.0M         94M
               3838 M total memory
                133 M used memory
                702 M active memory
               1991 M free memory
                245 M buffer memory
               1468 M swap cache
                 99 M total swap
                  5 M used swap
                 94 M free swap
      *** FILESYSTEM ***
      /var:
      7.6G    /var/
      5.9G    /var/lib
      /usr/bin/npm            8.19.2
      nodejs:
        Version table:
      ioBroker Status
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.12.1
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.12.1
      js-controller:
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.12.1
      admin:
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.12.1
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.12.1
      ioBroker-Instances
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.12.1
      Objects and States
      Objects:        0
      States:         0
      Pending Updates: 0
                              v.2022-12-13
      User-ID:                1000
      X-Server:               false
                              /usr/bin/npm            8.19.2
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.12.1
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.12.1
                              admin
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.12.1
      ioBroker Status:
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.12.1
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.12.1
      Objects:                0
      States:                 0
      #42
      @nullfreizeit
      cd /opt/iobroker
      sudo -H -u iobroker npm install iobroker.js-controller
      N 1 Antwort Letzte Antwort
        @nullfreizeit
        cd /opt/iobroker
        N Offline
        N Offline
        nullfreizeit
        #43
        Hi Thomas, bekomme nun diese Fehlermeldung.
        pi@raspberrypi:~ $ cd /opt/iobroker
        pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
        npm ERR! code ENOTEMPTY
        npm ERR! syscall rename
        npm ERR! path /opt/iobroker/node_modules/async
        npm ERR! dest /opt/iobroker/node_modules/.async-STKQSxEj
        npm ERR! errno -39
        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/async' -> '/opt/iobroker/node_modules/.async-STKQSxEj'
        npm ERR!     /home/iobroker/.npm/_logs/2022-12-25T17_32_10_903Z-debug-0.log
        • N nullfreizeit
          npm ERR! errno -39
          #44
          @nullfreizeit
          Ja, siehe oben im Forum angepinnt.
          • N Offline
            N Offline
            nullfreizeit
            #45
            Hab jetzt alles gem. dem Link hier durch und den fixer drüber laufen lassen.
            Bekomme nun folgende Fehlermeldung. Danke für einen Rat.
            https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
            pi@raspberrypi:~ $ iobroker fix
            library: loaded
            Library version=2022-12-09
                Welcome to the ioBroker installation fixer!
                Script version: 2022-12-22
                You might need to enter your password a couple of times.
                Installing prerequisites (1/4)
            Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
            Reading package lists... Done
            Installed gcc-c++
                Checking ioBroker user and directory permissions (2/4)
            Created /etc/sudoers.d/iobroker
                Database maintenance (3/4)
            Checking for uncompressed JSONL databases... This might take a while!
            Compressing /opt/iobroker/iobroker-data/states.jsonl
            Compressing /opt/iobroker/iobroker-data/objects.jsonl
            Compressed 2 JSONL files. Done
                Checking autostart (4/4)
            Enabling autostart...
            Autostart enabled!
            pi@raspberrypi:~ $ iobroker start
            pi@raspberrypi:~ $ iobroker list instances
              throw err;
            Require stack:
              requireStack: [
            Node.js v18.12.1
            pi@raspberrypi:~ $ npm -v
            8.19.2
            • N nullfreizeit
              library: loaded
              Installed gcc-c++
              Autostart enabled!
                throw err;
              Require stack:
                requireStack: [
              Node.js v18.12.1
              8.19.2
              #46
              @nullfreizeit
              iob stop
              sudo apt install nodejs=16.19.0-deb-1nodesource1
              • N nullfreizeit
                library: loaded
                Installed gcc-c++
                Autostart enabled!
                  throw err;
                Require stack:
                  requireStack: [
                Node.js v18.12.1
                8.19.2
                #47
                @nullfreizeit
                Danach
                cd /opt/iobroker
                iobroker restart
                  @nullfreizeit
                  Danach
                  cd /opt/iobroker
                  iobroker restart
                  N Offline
                  N Offline
                  nullfreizeit
                  #48
                  Danke, bekomme allerdings schon vor dem iobroker restart das hier…
                  0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 0 not upgraded.
                  Need to get 24.2 MB of archives.
                  After this operation, 50.7 MB disk space will be freed.
                  Do you want to continue? [Y/n] y
                  Get:1 https://deb.nodesource.com/node_16.x bullseye/main armhf nodejs armhf 16.19.0-deb-1nodesource1 [24.2 MB]
                  Fetched 24.2 MB in 2s (11.9 MB/s)
                  dpkg: warning: downgrading nodejs from 18.12.1-deb-1nodesource1 to 16.19.0-deb-1nodesource1
                  (Reading database ... 63183 files and directories currently installed.)
                  Preparing to unpack .../nodejs_16.19.0-deb-1nodesource1_armhf.deb ...
                  Unpacking nodejs (16.19.0-deb-1nodesource1) over (18.12.1-deb-1nodesource1) ...
                  Setting up nodejs (16.19.0-deb-1nodesource1) ...
                  Processing triggers for man-db (2.9.4-2) ...
                  npm ERR! errno -39
                  npm ERR!     /home/iobroker/.npm/_logs/2022-12-25T22_53_30_615Z-debug-0.log
                  • N nullfreizeit
                    npm ERR! errno -39
                    #49
                    @nullfreizeit
                    https://forum.iobroker.net/topic/57337/fehler-25-oder-217-bei-adapter-install-update-mit-npm8
                      @nullfreizeit
                      N Offline
                      N Offline
                      nullfreizeit
                      #50
                      Hilft leider nicht
                      pi@raspberrypi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                        throw err;
                      Require stack:
                          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
                          at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                          at Module.require (node:internal/modules/cjs/loader:1067:19)
                          at Module._compile (node:internal/modules/cjs/loader:1165:14)
                          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                          at Module.load (node:internal/modules/cjs/loader:1043:32)
                          at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                          at Module.require (node:internal/modules/cjs/loader:1067:19) {
                        requireStack: [
                      pi@raspberrypi:~ $
                      • N nullfreizeit
                        Hilft leider nicht
                          throw err;
                        Require stack:
                          requireStack: [
                        pi@raspberrypi:~ $
                        #51
                        @nullfreizeit
                        cd /opt/iobroker
                        iobroker restart
                          @nullfreizeit
                          cd /opt/iobroker
                          iobroker restart
                          N Offline
                          N Offline
                          nullfreizeit
                          #52
                          Ja sorry. Läuft gerade wieder durch. Danke schonmal
                          • N Offline
                            N Offline
                            nullfreizeit
                            #53
                            @thomas-braun sagte in Admin Problem:
                            Hi Thomas, war gestern Abend nach dem hier wieder kurzzeitig im Adminpanel drin. Allerdings konnten keine Instanzen gestartet werden. Hab dann noch mal den fixer drüber laufen lassen und dann kam ich noch nicht einmal mehr ins Adminpanel rein. Hab das heute versucht zu wiederholen. Der Fehler kommt dann. Irgendeine Idee? Vielen Dank.
                            npm WARN skipping integrity check for git dependency ssh://git@github.com/walli545/ioBroker.time-switch.git
                            npm WARN skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.eventlist.git
                            npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                            npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                            npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                            npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                            npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                            npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
                            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                            npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                            npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                            added 4 packages, removed 1 package, and changed 859 packages in 22m
                            84 packages are looking for funding
                              run `npm fund` for details
                            pi@raspberrypi:/opt/iobroker $ iobroker restart
                            pi@raspberrypi:/opt/iobroker $ iobroker list instances
                              throw err;
                            Require stack:
                              requireStack: [
                            • N Offline
                              N Offline
                              nullfreizeit
                              #54
                              Wenn ich den Befehl
                              absetze kommen diese Meldungen (gekürzt)...
                              pi@raspberrypi:/opt/iobroker $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpango-1.0.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libjpeg.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfreetype.so.6': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangocairo-1.0.so.0.4400.7': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libjpeg.so.8.2.2': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo-gobject.so.2': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebp.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpdemux.so.2.0.6': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libxml2.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libjpeg.so.8': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgsf-1.so.114.0.46': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebp.so.7.1.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexpat.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpdemux.so.2': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/glib-2.0/include/glibconfig.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangoft2-1.0.so.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips-cpp.so.42.12.1': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgmodule-2.0.so.0.6400.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgdk_pixbuf-2.0.so.0.4000.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgobject-2.0.so.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips-cpp.so.42': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgthread-2.0.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpng.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgsf-1.so.114': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpng16.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangoft2-1.0.so.0.4400.7': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgio-2.0.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpmux.so.3': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips.so.42': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libffi.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgthread-2.0.so.0.6400.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libharfbuzz.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpmux.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgio-2.0.so.0.6400.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebp.so.7': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangocairo-1.0.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpng16.so.16': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfreetype.so.6.17.1': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgthread-2.0.so.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexpat.so.1.6.11': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liblcms2.so.2': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libxml2.so.2': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo-gobject.so.2.11600.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liborc-0.4.so.0.31.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpango-1.0.so.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfribidi.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpdemux.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liborc-0.4.so.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libffi.so.7': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libharfbuzz.so.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/librsvg-2.so.2.47.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfribidi.so.0.4.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpango-1.0.so.0.4400.7': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/xml2Conf.sh': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpixman-1.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexpat.so.1': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgsf-1.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libharfbuzz.so.0.20600.4': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips-cpp.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgif.so.7.0.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexif.so.12.3.3': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgdk_pixbuf-2.0.so.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgio-2.0.so.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libz.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libz.so.1': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfontconfig.so.1.12.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgif.so.7': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgobject-2.0.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpixman-1.so.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgdk_pixbuf-2.0.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgobject-2.0.so.0.6400.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liblcms2.so.2.0.8': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexif.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfontconfig.so.1': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfribidi.so.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/librsvg-2.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfontconfig.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpng16.so.16.37.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libffi.so.7.1.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpixman-1.so.0.38.4': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfreetype.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgmodule-2.0.so.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libglib-2.0.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libtiff.so.5.5.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/librsvg-2.so.2': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangoft2-1.0.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo.so.2.11600.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liblcms2.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libglib-2.0.so.0.6400.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgif.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libtiff.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libtiff.so.5': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo-gobject.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo.so.2': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libxml2.so.2.9.10': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexif.so.12': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libz.so.1.2.11': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liborc-0.4.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpmux.so.3.0.5': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips.so.42.12.1': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgmodule-2.0.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libglib-2.0.so.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangocairo-1.0.so.0': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo.so': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/lcms2_plugin.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/jmorecfg.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/zconf.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/tiff.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/tiffconf.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/fontconfig/fontconfig.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/fontconfig/fcprivate.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/fontconfig/fcfreetype.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlreader.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xpath.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/nanohttp.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/nanoftp.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/globals.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/c14n.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/uri.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlstring.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/debugXML.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xpointer.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlautomata.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/pattern.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlIO.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xinclude.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/HTMLtree.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlsave.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xlink.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/tree.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/dict.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlschemas.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/SAX2.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/parser.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/threads.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlregexp.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/chvalid.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/hash.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/valid.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/list.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/encoding.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlerror.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/schematron.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/SAX.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xpathInternals.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlversion.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/relaxng.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/catalog.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/schemasInternals.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlwriter.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlmemory.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlmodule.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlexports.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlunicode.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/HTMLparser.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/entities.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/parserInternals.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlschemastypes.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/DOCBparser.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gmarshal.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gtypemodule.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gclosure.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gvaluetypes.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gvaluearray.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gvalue.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/glib-enumtypes.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gobjectnotifyqueue.c': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gparam.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gtype.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gbinding.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/genums.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gobject.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/glib-types.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gsourceclosure.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gvaluecollector.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gboxed.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gparamspecs.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gobject-autocleanups.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gsignal.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gtypeplugin.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib-unix.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gmodule.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib-object.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gstring.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/giochannel.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gurifuncs.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gprimes.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gstrfuncs.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gfileutils.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gbytes.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gunicode.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gtestutils.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gshell.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/orc-0.4/orc/orcvariable.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/lcms2.h': Permission denied
                              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/expat_external.h': Permission denied
                              • N nullfreizeit
                                Wenn ich den Befehl
                                #55
                                @nullfreizeit
                                Da hast du mal mit falschen Rechten hantiert. Vermutlich als root.
                                Setz vor das rm -rf in der Befehlskette noch ein sudo.
                                Und dann nie mehr als root herumkaspern.
                                  @nullfreizeit
                                  N Offline
                                  N Offline
                                  nullfreizeit
                                  #56
                                  Danke Thomas. Hat scheinbar geklappt. Allerdings immer noch der Fehler wenn ich "iobroker list instances" eingebe...
                                  pi@raspberrypi:/opt/iobroker $  for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do sudo rm -rf ${i%%/}; done
                                    throw err;
                                  Require stack:
                                    requireStack: [
                                  • N nullfreizeit
                                      throw err;
                                    Require stack:
                                      requireStack: [
                                    #57
                                    @nullfreizeit
                                    cd /opt/iobroker
                                    iobroker restart
                                    Bzw.:
                                    cd /opt/iobroker
                                    npm ls node-forge
                                      @nullfreizeit
                                      cd /opt/iobroker
                                      iobroker restart
                                      Bzw.:
                                      cd /opt/iobroker
                                      npm ls node-forge
                                      N Offline
                                      N Offline
                                      nullfreizeit
                                      #58
                                      npm ls node-forge
                                      dann kommt das hier:
                                      pi@raspberrypi:/opt/iobroker $ npm ls node-forge
                                      iobroker.inst@3.0.0 /opt/iobroker
                                      ├─┬ @iobroker/js-controller-common@4.0.24 extraneous
                                      │ └── node-forge@ deduped invalid: "^1.0.0" from node_modules/@iobroker/js-controller-common
                                      ├─┬ google-p12-pem@4.0.1 extraneous
                                      │ └── node-forge@ deduped invalid: "^1.0.0" from node_modules/@iobroker/js-controller-common, "^1.3.1" from node_modules/google-p12-pem
                                      ├── node-forge@ invalid: "^1.0.0" from node_modules/@iobroker/js-controller-common, "^1.3.1" from node_modules/google-p12-pem extraneous
                                      └─┬ rsa-compat@1.9.4 extraneous
                                        └── node-forge@0.7.6 extraneous
                                      npm ERR! invalid: node-forge@ /opt/iobroker/node_modules/node-forge
                                      npm ERR! extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
                                      npm ERR! extraneous: node-forge@0.7.6 /opt/iobroker/node_modules/rsa-compat/node_modules/node-forge
                                      npm ERR!     /home/iobroker/.npm/_logs/2022-12-26T10_04_48_709Z-debug-0.log
                                      • N nullfreizeit
                                        npm ls node-forge
                                        #59
                                        @nullfreizeit
                                        iob stop
                                        iob fix
                                        iob diag
                                        • N Offline
                                          N Offline
                                          nullfreizeit
                                          #60
                                          Hi Thomas,
                                          hab noch mal
                                          added 4 packages, and changed 859 packages in 16m
                                          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 7777, bind: 0.0.0.0, run as: admin
                                            system.adapter.alarm.0                  : alarm                 : raspberrypi                              - disabled
                                            system.adapter.asterisk.0               : asterisk              : raspberrypi                              -  enabled, port: 5038
                                            system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                            system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                                            system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                                            system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                                            system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                                            system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
                                            system.adapter.eventlist.0              : eventlist             : raspberrypi                              - disabled
                                            system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                                            system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
                                          + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                                            system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                                            system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
                                            system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
                                            system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                                            system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                                            system.adapter.landroid.0               : landroid              : raspberrypi                              - disabled
                                            system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
                                            system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1889, bind: 192.168.188.35
                                            system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
                                            system.adapter.nina.0                   : nina                  : raspberrypi                              -  enabled
                                            system.adapter.onvif.0                  : onvif                 : raspberrypi                              - disabled
                                            system.adapter.openligadb.0             : openligadb            : raspberrypi                              -  enabled
                                            system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
                                            system.adapter.pegelalarm.0             : pegelalarm            : raspberrypi                              -  enabled
                                            system.adapter.rssfeed.0                : rssfeed               : raspberrypi                              -  enabled
                                            system.adapter.sayit.0                  : sayit                 : raspberrypi                              - disabled, port: 0
                                            system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                                            system.adapter.simple-api.0             : simple-api            : raspberrypi                              - disabled, port: 8087, bind: 0.0.0.0, run as: admin
                                            system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                                            system.adapter.sony-bravia.0            : sony-bravia           : raspberrypi                              -  enabled
                                            system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
                                            system.adapter.terminal.0               : terminal              : raspberrypi                              - disabled, port: 8088, bind: 0.0.0.0, run as: admin
                                            system.adapter.time-switch.0            : time-switch           : raspberrypi                              - disabled
                                            system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                                            system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                                            system.adapter.tvspielfilm.0            : tvspielfilm           : raspberrypi                              -  enabled
                                            system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                                            system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                                            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                                            system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                                            system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                                            system.adapter.vis-material.0           : vis-material          : raspberrypi                              -  enabled
                                            system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
                                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                                            system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
                                            system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                                            system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                                            system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                            system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
                                            system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                                            system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
                                          + instance is alive
                                          gemacht. Nun läuft Admin wieder. Backitup ist auch wieder angesprungen. Alle anderen Adapater starten aber nicht. Soll ich nochmal den fix drüber laufen lassen wie du beschrieben hast? Danke
