  4. Admin Problem
    5.6k
Admin Problem
admin
70 Beiträge 8 Kommentatoren 10.2k Aufrufe 7 Beobachtet
  • N nullfreizeit
    Hi Thomas,
    hab noch mal
    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
    npm WARN skipping integrity check for git dependency ssh://git@github.com/walli545/ioBroker.time-switch.git
    npm WARN skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.eventlist.git
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    added 4 packages, and changed 859 packages in 16m
    84 packages are looking for funding
      run `npm fund` for details
    pi@raspberrypi:/opt/iobroker $ iobroker restart
    pi@raspberrypi:/opt/iobroker $ iobroker list instances
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 7777, bind: 0.0.0.0, run as: admin
      system.adapter.alarm.0                  : alarm                 : raspberrypi                              - disabled
      system.adapter.asterisk.0               : asterisk              : raspberrypi                              -  enabled, port: 5038
      system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
      system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
      system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
      system.adapter.eventlist.0              : eventlist             : raspberrypi                              - disabled
      system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
      system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
      system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
      system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      system.adapter.landroid.0               : landroid              : raspberrypi                              - disabled
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
      system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1889, bind: 192.168.188.35
      system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
      system.adapter.nina.0                   : nina                  : raspberrypi                              -  enabled
      system.adapter.onvif.0                  : onvif                 : raspberrypi                              - disabled
      system.adapter.openligadb.0             : openligadb            : raspberrypi                              -  enabled
      system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
      system.adapter.pegelalarm.0             : pegelalarm            : raspberrypi                              -  enabled
      system.adapter.rssfeed.0                : rssfeed               : raspberrypi                              -  enabled
      system.adapter.sayit.0                  : sayit                 : raspberrypi                              - disabled, port: 0
      system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.simple-api.0             : simple-api            : raspberrypi                              - disabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.sony-bravia.0            : sony-bravia           : raspberrypi                              -  enabled
      system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
      system.adapter.terminal.0               : terminal              : raspberrypi                              - disabled, port: 8088, bind: 0.0.0.0, run as: admin
      system.adapter.time-switch.0            : time-switch           : raspberrypi                              - disabled
      system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
      system.adapter.tvspielfilm.0            : tvspielfilm           : raspberrypi                              -  enabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
      system.adapter.vis-material.0           : vis-material          : raspberrypi                              -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
      system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
      system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
      system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
      system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
      system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
    + instance is alive
    gemacht. Nun läuft Admin wieder. Backitup ist auch wieder angesprungen. Alle anderen Adapater starten aber nicht. Soll ich nochmal den fix drüber laufen lassen wie du beschrieben hast? Danke
    #61
    @nullfreizeit
    Und
    iobroker diag
    sagt was?
    N 1 Antwort Letzte Antwort
      @nullfreizeit
      Und
      iobroker diag
      sagt was?
      N Offline
      N Offline
      nullfreizeit
      #62
      Das hier:
                              v.2022-12-13
      Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
      Installation:           Native
      Timezone:               Europe/Berlin
      User-ID:                1000
      X-Server:               false
      Pending OS-Updates:     0
      Nodejs-Installation:    /usr/bin/nodejs         v16.19.0
                              /usr/bin/node           v16.19.0
                              /usr/bin/npm            8.19.3
      ioBroker Core:          js-controller           4.0.24
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      Pending iob updates:    0
      Objects:                8724
      States:                 7313
      Size of iob-Database:
      20M     /opt/iobroker/iobroker-data/objects.jsonl
      8.6M    /opt/iobroker/iobroker-data/objects.json.migrated
      8.6M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
      4.2M    /opt/iobroker/iobroker-data/states.jsonl
      3.0M    /opt/iobroker/iobroker-data/states.json.migrated
      3.0M    /opt/iobroker/iobroker-data/states.json.bak.migrated
      ====================== END OF SUMMARY ==================
      Allerdings hat er vor der "Summary" dies hier als Fehler angezeigt...
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      npm ERR! code ELSPROBLEMS
      npm ERR! invalid: iobroker.admin@6.3.5 /opt/iobroker/node_modules/iobroker.admin
      npm ERR! invalid: iobroker.backitup@2.5.9 /opt/iobroker/node_modules/iobroker.backitup
      npm ERR! invalid: iobroker.discovery@3.1.0 /opt/iobroker/node_modules/iobroker.discovery
      npm ERR! invalid: iobroker.eventlist@0.5.5 /opt/iobroker/node_modules/iobroker.eventlist
      npm ERR! invalid: iobroker.onvif@0.4.5 /opt/iobroker/node_modules/iobroker.onvif
      npm ERR! invalid: iobroker.time-switch@2.2.2 /opt/iobroker/node_modules/iobroker.time-switch
      npm ERR!     /home/pi/.npm/_logs/2022-12-26T10_52_10_883Z-debug-0.log
      Adapters from github:   3
      • N Offline
        N Offline
        nullfreizeit
        schrieb am zuletzt editiert von nullfreizeit
        #63
        Admin hat den Adapter "javascript" scheinbar von alleine neu installiert... der läuft jetzt wieder. Alles andere inkl. Zigbee bleibt auf rot (Verbunden mit Host / Lebenszeichen).
        Bekomme beim Aufrufen der Instanzen links unten timeout-Fehlermeldungen
        host.raspberrypi
        	2022-12-26 12:20:02.691	error	cannot read and parse "/opt/iobroker/node_modules/iobroker.js-controller/io-package.json"
        Hab das im Log gefunden
        2022-12-26 11:51:16.264 - info: host.raspberrypi iobroker npm-install: NPM version: 8.19.3
        2022-12-26 11:51:16.287 - info: host.raspberrypi iobroker npm-install: Installing iobroker.javascript@6.1.4... (System call)
        • N nullfreizeit
          host.raspberrypi
          #64
          @nullfreizeit
          Installier die genannten sechs Adapter nochmal neu.
            @nullfreizeit
            N Offline
            N Offline
            nullfreizeit
            #65
            Wie sollte ich deine Meinung nach vorgehen. Über Admin deinstallieren und neu (aber sind dann nicht auch die Daten weg)? Oder über Putty irgendwie?
            Danke dir vielmals für deine Geduld! Ich bin allen hier so dankbar das ihr euch auch für mich als Laien Zeit nehmt.
            • N nullfreizeit
              #66
              @nullfreizeit
              Ich würde wohl in die jeweiligen Verzeichnisse wechseln und
              sudo -u iobroker npm install
              ausführen.
              • N Offline
                N Offline
                nullfreizeit
                #67
                Ich warte mal etwas ab. Scheinbar versucht er sich selbst zu fixen...
                Mihome.vacuum hat er auch neu installiert und es scheint zu laufen. Gleich mal testen.
                host.raspberrypi
                	2022-12-26 13:02:53.507	info	iobroker npm-install: Installing iobroker.openweathermap@0.3.3... (System call)
                host.raspberrypi
                	2022-12-26 13:02:53.490	info	iobroker npm-install: NPM version: 8.19.3
                host.raspberrypi
                	2022-12-26 13:02:48.930	info	iobroker install openweathermap@0.3.3 using installedFrom
                • N Offline
                  N Offline
                  nullfreizeit
                  #68
                  Beim Aufruf der Instanzen im Admin Panel kommt dieser Fehler unten links
                  Scheinbar muss ich einfach nur warten... Versucht nun den nächsten Adapter zu fixen...
                  host.raspberrypi
                  	2022-12-26 13:26:46.151	info	iobroker install shelly@6.0.0 using installedFrom
                  host.raspberrypi
                  	2022-12-26 13:26:46.150	warn	startInstance cannot find adapter "shelly@6.0.0". Try to install it... 1 attempt
                  • N Offline
                    N Offline
                    nullfreizeit
                    #69
                    Ich möchte mich noch einmal bei allen bedanken. Danke an Thomas und die anderen hier.
                    Es funktioniert nun alles wieder. Keine Ahnung was los war - never change a running system.
                    • N nullfreizeit
                      #70
                      @nullfreizeit sagte in Admin Problem:
                      Falsch. Das Gegenteil ist richtig:
                      Halte dein System immer auf aktuellem Stand.
                      Dann läuft das auch.
