  4. Admin Problem
    5.6k
Admin Problem
admin
70 Beiträge 8 Kommentatoren 10.2k Aufrufe 7 Beobachtet
  • N nullfreizeit
    Hilft leider nicht
    pi@raspberrypi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
    pi@raspberrypi:~ $ iobroker start
    pi@raspberrypi:~ $ iobroker list instances
    node:internal/modules/cjs/loader:998
      throw err;
    Error: Cannot find module 'node-forge'
    Require stack:
    - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
    - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
    - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
        at Function.Module._load (node:internal/modules/cjs/loader:841:27)
        at Module.require (node:internal/modules/cjs/loader:1067:19)
        at require (node:internal/modules/cjs/helpers:103:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:7:15)
        at Module._compile (node:internal/modules/cjs/loader:1165:14)
        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
        at Module.load (node:internal/modules/cjs/loader:1043:32)
        at Function.Module._load (node:internal/modules/cjs/loader:878:12)
        at Module.require (node:internal/modules/cjs/loader:1067:19) {
      code: 'MODULE_NOT_FOUND',
      requireStack: [
        '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
        '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    pi@raspberrypi:~ $
    @nullfreizeit
    cd /opt/iobroker
    sudo -H -u iobroker npm install iobroker.js-controller
    iobroker restart
    N 1 Antwort Letzte Antwort
      @nullfreizeit
      cd /opt/iobroker
      iobroker restart
      N Offline
      N Offline
      nullfreizeit
      Ja sorry. Läuft gerade wieder durch. Danke schonmal
      • N Offline
        N Offline
        nullfreizeit
        @thomas-braun sagte in Admin Problem:
        Hi Thomas, war gestern Abend nach dem hier wieder kurzzeitig im Adminpanel drin. Allerdings konnten keine Instanzen gestartet werden. Hab dann noch mal den fixer drüber laufen lassen und dann kam ich noch nicht einmal mehr ins Adminpanel rein. Hab das heute versucht zu wiederholen. Der Fehler kommt dann. Irgendeine Idee? Vielen Dank.
        pi@raspberrypi:~ $ cd /opt/iobroker
        pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
        npm WARN skipping integrity check for git dependency ssh://git@github.com/walli545/ioBroker.time-switch.git
        npm WARN skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.eventlist.git
        npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
        npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
        npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
        npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
        npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        added 4 packages, removed 1 package, and changed 859 packages in 22m
        84 packages are looking for funding
          run `npm fund` for details
        pi@raspberrypi:/opt/iobroker $ iobroker restart
        pi@raspberrypi:/opt/iobroker $ iobroker list instances
          throw err;
        Require stack:
          requireStack: [
        • N Offline
          N Offline
          nullfreizeit
          Wenn ich den Befehl
          absetze kommen diese Meldungen (gekürzt)...
          pi@raspberrypi:/opt/iobroker $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpango-1.0.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libjpeg.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfreetype.so.6': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangocairo-1.0.so.0.4400.7': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libjpeg.so.8.2.2': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo-gobject.so.2': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebp.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpdemux.so.2.0.6': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libxml2.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libjpeg.so.8': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgsf-1.so.114.0.46': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebp.so.7.1.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexpat.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpdemux.so.2': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/glib-2.0/include/glibconfig.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangoft2-1.0.so.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips-cpp.so.42.12.1': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgmodule-2.0.so.0.6400.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgdk_pixbuf-2.0.so.0.4000.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgobject-2.0.so.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips-cpp.so.42': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgthread-2.0.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpng.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgsf-1.so.114': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpng16.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangoft2-1.0.so.0.4400.7': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgio-2.0.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpmux.so.3': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips.so.42': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libffi.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgthread-2.0.so.0.6400.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libharfbuzz.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpmux.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgio-2.0.so.0.6400.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebp.so.7': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangocairo-1.0.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpng16.so.16': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfreetype.so.6.17.1': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgthread-2.0.so.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexpat.so.1.6.11': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liblcms2.so.2': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libxml2.so.2': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo-gobject.so.2.11600.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liborc-0.4.so.0.31.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpango-1.0.so.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfribidi.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpdemux.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liborc-0.4.so.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libffi.so.7': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libharfbuzz.so.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/librsvg-2.so.2.47.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfribidi.so.0.4.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpango-1.0.so.0.4400.7': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/xml2Conf.sh': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpixman-1.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexpat.so.1': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgsf-1.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libharfbuzz.so.0.20600.4': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips-cpp.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgif.so.7.0.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexif.so.12.3.3': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgdk_pixbuf-2.0.so.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgio-2.0.so.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libz.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libz.so.1': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfontconfig.so.1.12.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgif.so.7': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgobject-2.0.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpixman-1.so.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgdk_pixbuf-2.0.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgobject-2.0.so.0.6400.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liblcms2.so.2.0.8': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexif.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfontconfig.so.1': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfribidi.so.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/librsvg-2.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfontconfig.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpng16.so.16.37.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libffi.so.7.1.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpixman-1.so.0.38.4': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfreetype.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgmodule-2.0.so.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libglib-2.0.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libtiff.so.5.5.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/librsvg-2.so.2': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangoft2-1.0.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo.so.2.11600.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liblcms2.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libglib-2.0.so.0.6400.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgif.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libtiff.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libtiff.so.5': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo-gobject.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo.so.2': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libxml2.so.2.9.10': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexif.so.12': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libz.so.1.2.11': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liborc-0.4.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpmux.so.3.0.5': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips.so.42.12.1': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgmodule-2.0.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libglib-2.0.so.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangocairo-1.0.so.0': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo.so': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/lcms2_plugin.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/jmorecfg.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/zconf.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/tiff.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/tiffconf.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/fontconfig/fontconfig.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/fontconfig/fcprivate.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/fontconfig/fcfreetype.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlreader.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xpath.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/nanohttp.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/nanoftp.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/globals.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/c14n.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/uri.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlstring.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/debugXML.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xpointer.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlautomata.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/pattern.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlIO.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xinclude.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/HTMLtree.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlsave.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xlink.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/tree.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/dict.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlschemas.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/SAX2.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/parser.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/threads.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlregexp.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/chvalid.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/hash.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/valid.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/list.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/encoding.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlerror.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/schematron.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/SAX.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xpathInternals.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlversion.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/relaxng.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/catalog.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/schemasInternals.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlwriter.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlmemory.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlmodule.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlexports.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlunicode.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/HTMLparser.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/entities.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/parserInternals.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlschemastypes.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/DOCBparser.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gmarshal.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gtypemodule.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gclosure.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gvaluetypes.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gvaluearray.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gvalue.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/glib-enumtypes.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gobjectnotifyqueue.c': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gparam.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gtype.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gbinding.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/genums.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gobject.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/glib-types.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gsourceclosure.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gvaluecollector.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gboxed.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gparamspecs.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gobject-autocleanups.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gsignal.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gtypeplugin.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib-unix.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gmodule.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib-object.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gstring.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/giochannel.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gurifuncs.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gprimes.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gstrfuncs.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gfileutils.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gbytes.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gunicode.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gtestutils.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gshell.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/orc-0.4/orc/orcvariable.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/lcms2.h': Permission denied
          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/expat_external.h': Permission denied
          • N nullfreizeit
            Wenn ich den Befehl
            @nullfreizeit
            Da hast du mal mit falschen Rechten hantiert. Vermutlich als root.
            Setz vor das rm -rf in der Befehlskette noch ein sudo.
            Und dann nie mehr als root herumkaspern.
              @nullfreizeit
              N Offline
              N Offline
              nullfreizeit
              Danke Thomas. Hat scheinbar geklappt. Allerdings immer noch der Fehler wenn ich "iobroker list instances" eingebe...
              pi@raspberrypi:/opt/iobroker $  for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do sudo rm -rf ${i%%/}; done
                throw err;
              Require stack:
                requireStack: [
              • N nullfreizeit
                  throw err;
                Require stack:
                  requireStack: [
                @nullfreizeit
                cd /opt/iobroker
                iobroker restart
                Bzw.:
                cd /opt/iobroker
                npm ls node-forge
                  @nullfreizeit
                  cd /opt/iobroker
                  iobroker restart
                  Bzw.:
                  cd /opt/iobroker
                  npm ls node-forge
                  N Offline
                  N Offline
                  nullfreizeit
                  npm ls node-forge
                  dann kommt das hier:
                  pi@raspberrypi:/opt/iobroker $ npm ls node-forge
                  iobroker.inst@3.0.0 /opt/iobroker
                  ├─┬ @iobroker/js-controller-common@4.0.24 extraneous
                  │ └── node-forge@ deduped invalid: "^1.0.0" from node_modules/@iobroker/js-controller-common
                  ├─┬ google-p12-pem@4.0.1 extraneous
                  │ └── node-forge@ deduped invalid: "^1.0.0" from node_modules/@iobroker/js-controller-common, "^1.3.1" from node_modules/google-p12-pem
                  ├── node-forge@ invalid: "^1.0.0" from node_modules/@iobroker/js-controller-common, "^1.3.1" from node_modules/google-p12-pem extraneous
                  └─┬ rsa-compat@1.9.4 extraneous
                    └── node-forge@0.7.6 extraneous
                  npm ERR! code ELSPROBLEMS
                  npm ERR! invalid: node-forge@ /opt/iobroker/node_modules/node-forge
                  npm ERR! extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
                  npm ERR! extraneous: node-forge@0.7.6 /opt/iobroker/node_modules/rsa-compat/node_modules/node-forge
                  npm ERR!     /home/iobroker/.npm/_logs/2022-12-26T10_04_48_709Z-debug-0.log
                  • N nullfreizeit
                    npm ls node-forge
                    @nullfreizeit
                    iob stop
                    iob fix
                    iob diag
                    • N Offline
                      N Offline
                      nullfreizeit
                      Hi Thomas,
                      hab noch mal
                      added 4 packages, and changed 859 packages in 16m
                      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 7777, bind: 0.0.0.0, run as: admin
                        system.adapter.alarm.0                  : alarm                 : raspberrypi                              - disabled
                        system.adapter.asterisk.0               : asterisk              : raspberrypi                              -  enabled, port: 5038
                        system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                        system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                        system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                        system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                        system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                        system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
                        system.adapter.eventlist.0              : eventlist             : raspberrypi                              - disabled
                        system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                        system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
                        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
                        system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                        system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                        system.adapter.landroid.0               : landroid              : raspberrypi                              - disabled
                        system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
                        system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1889, bind: 192.168.188.35
                        system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
                        system.adapter.nina.0                   : nina                  : raspberrypi                              -  enabled
                        system.adapter.onvif.0                  : onvif                 : raspberrypi                              - disabled
                        system.adapter.openligadb.0             : openligadb            : raspberrypi                              -  enabled
                        system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
                        system.adapter.pegelalarm.0             : pegelalarm            : raspberrypi                              -  enabled
                        system.adapter.rssfeed.0                : rssfeed               : raspberrypi                              -  enabled
                        system.adapter.sayit.0                  : sayit                 : raspberrypi                              - disabled, port: 0
                        system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                        system.adapter.simple-api.0             : simple-api            : raspberrypi                              - disabled, port: 8087, bind: 0.0.0.0, run as: admin
                        system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                        system.adapter.sony-bravia.0            : sony-bravia           : raspberrypi                              -  enabled
                        system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
                        system.adapter.terminal.0               : terminal              : raspberrypi                              - disabled, port: 8088, bind: 0.0.0.0, run as: admin
                        system.adapter.time-switch.0            : time-switch           : raspberrypi                              - disabled
                        system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                        system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                        system.adapter.tvspielfilm.0            : tvspielfilm           : raspberrypi                              -  enabled
                        system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                        system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                        system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                        system.adapter.vis-material.0           : vis-material          : raspberrypi                              -  enabled
                        system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
                        system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                        system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
                        system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                        system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
                      + instance is alive
                      gemacht. Nun läuft Admin wieder. Backitup ist auch wieder angesprungen. Alle anderen Adapater starten aber nicht. Soll ich nochmal den fix drüber laufen lassen wie du beschrieben hast? Danke
                      • N nullfreizeit
                        Hi Thomas,
                        hab noch mal
                        + instance is alive
                        @nullfreizeit
                        Und
                        iobroker diag
                        sagt was?
                          @nullfreizeit
                          Und
                          iobroker diag
                          sagt was?
                          N Offline
                          N Offline
                          nullfreizeit
                          Das hier:
                                                  v.2022-12-13
                          Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
                          Installation:           Native
                          Timezone:               Europe/Berlin
                          User-ID:                1000
                          X-Server:               false
                          Pending OS-Updates:     0
                          Nodejs-Installation:    /usr/bin/nodejs         v16.19.0
                                                  /usr/bin/node           v16.19.0
                                                  /usr/bin/npm            8.19.3
                          ioBroker Core:          js-controller           4.0.24
                                                  admin                   6.3.5
                          Objects type: jsonl
                          States  type: jsonl
                          Pending iob updates:    0
                          Objects:                8724
                          States:                 7313
                          Size of iob-Database:
                          20M     /opt/iobroker/iobroker-data/objects.jsonl
                          8.6M    /opt/iobroker/iobroker-data/objects.json.migrated
                          8.6M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                          4.2M    /opt/iobroker/iobroker-data/states.jsonl
                          3.0M    /opt/iobroker/iobroker-data/states.json.migrated
                          3.0M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                          ====================== END OF SUMMARY ==================
                          Allerdings hat er vor der "Summary" dies hier als Fehler angezeigt...
                          *** ioBroker-Installation ***
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Core adapters versions
                          js-controller:  4.0.24
                          admin:          6.3.5
                          npm ERR! invalid: iobroker.admin@6.3.5 /opt/iobroker/node_modules/iobroker.admin
                          npm ERR! invalid: iobroker.backitup@2.5.9 /opt/iobroker/node_modules/iobroker.backitup
                          npm ERR! invalid: iobroker.discovery@3.1.0 /opt/iobroker/node_modules/iobroker.discovery
                          npm ERR! invalid: iobroker.eventlist@0.5.5 /opt/iobroker/node_modules/iobroker.eventlist
                          npm ERR! invalid: iobroker.onvif@0.4.5 /opt/iobroker/node_modules/iobroker.onvif
                          npm ERR! invalid: iobroker.time-switch@2.2.2 /opt/iobroker/node_modules/iobroker.time-switch
                          npm ERR!     /home/pi/.npm/_logs/2022-12-26T10_52_10_883Z-debug-0.log
                          Adapters from github:   3
                          • N Offline
                            N Offline
                            nullfreizeit
                            schrieb am zuletzt editiert von nullfreizeit
                            Admin hat den Adapter "javascript" scheinbar von alleine neu installiert... der läuft jetzt wieder. Alles andere inkl. Zigbee bleibt auf rot (Verbunden mit Host / Lebenszeichen).
                            Bekomme beim Aufrufen der Instanzen links unten timeout-Fehlermeldungen
                            host.raspberrypi
                            	2022-12-26 12:20:02.691	error	cannot read and parse "/opt/iobroker/node_modules/iobroker.js-controller/io-package.json"
                            Hab das im Log gefunden
                            2022-12-26 11:51:16.264 - info: host.raspberrypi iobroker npm-install: NPM version: 8.19.3
                            2022-12-26 11:51:16.287 - info: host.raspberrypi iobroker npm-install: Installing iobroker.javascript@6.1.4... (System call)
                            • N nullfreizeit
                              host.raspberrypi
                              @nullfreizeit
                              Installier die genannten sechs Adapter nochmal neu.
                                @nullfreizeit
                                N Offline
                                N Offline
                                nullfreizeit
                                Wie sollte ich deine Meinung nach vorgehen. Über Admin deinstallieren und neu (aber sind dann nicht auch die Daten weg)? Oder über Putty irgendwie?
                                Danke dir vielmals für deine Geduld! Ich bin allen hier so dankbar das ihr euch auch für mich als Laien Zeit nehmt.
                                • N nullfreizeit
                                  #66
                                  @nullfreizeit
                                  Ich würde wohl in die jeweiligen Verzeichnisse wechseln und
                                  sudo -u iobroker npm install
                                  ausführen.
                                  • N Offline
                                    N Offline
                                    nullfreizeit
                                    #67
                                    Ich warte mal etwas ab. Scheinbar versucht er sich selbst zu fixen...
                                    Mihome.vacuum hat er auch neu installiert und es scheint zu laufen. Gleich mal testen.
                                    host.raspberrypi
                                    	2022-12-26 13:02:53.507	info	iobroker npm-install: Installing iobroker.openweathermap@0.3.3... (System call)
                                    host.raspberrypi
                                    	2022-12-26 13:02:53.490	info	iobroker npm-install: NPM version: 8.19.3
                                    host.raspberrypi
                                    	2022-12-26 13:02:48.930	info	iobroker install openweathermap@0.3.3 using installedFrom
                                    • N Offline
                                      N Offline
                                      nullfreizeit
                                      #68
                                      Beim Aufruf der Instanzen im Admin Panel kommt dieser Fehler unten links
                                      Scheinbar muss ich einfach nur warten... Versucht nun den nächsten Adapter zu fixen...
                                      host.raspberrypi
                                      	2022-12-26 13:26:46.151	info	iobroker install shelly@6.0.0 using installedFrom
                                      host.raspberrypi
                                      	2022-12-26 13:26:46.150	warn	startInstance cannot find adapter "shelly@6.0.0". Try to install it... 1 attempt
                                      • N Offline
                                        N Offline
                                        nullfreizeit
                                        #69
                                        Ich möchte mich noch einmal bei allen bedanken. Danke an Thomas und die anderen hier.
                                        Es funktioniert nun alles wieder. Keine Ahnung was los war - never change a running system.
                                        • N nullfreizeit
                                          #70
                                          @nullfreizeit sagte in Admin Problem:
                                          Falsch. Das Gegenteil ist richtig:
                                          Halte dein System immer auf aktuellem Stand.
                                          Dann läuft das auch.
