  4. Admin Problem
    5.6k
Admin Problem
admin
70 Beiträge 8 Kommentatoren 10.2k Aufrufe 7 Beobachtet
    @nullfreizeit
    https://forum.iobroker.net/topic/57337/fehler-25-oder-217-bei-adapter-install-update-mit-npm8
    N Offline
    N Offline
    nullfreizeit
    Hilft leider nicht
    pi@raspberrypi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
    pi@raspberrypi:~ $ iobroker start
    pi@raspberrypi:~ $ iobroker list instances
    node:internal/modules/cjs/loader:998
      throw err;
    Error: Cannot find module 'node-forge'
    Require stack:
    - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
    - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
    - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
        at Function.Module._load (node:internal/modules/cjs/loader:841:27)
        at Module.require (node:internal/modules/cjs/loader:1067:19)
        at require (node:internal/modules/cjs/helpers:103:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:7:15)
        at Module._compile (node:internal/modules/cjs/loader:1165:14)
        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
        at Module.load (node:internal/modules/cjs/loader:1043:32)
        at Function.Module._load (node:internal/modules/cjs/loader:878:12)
        at Module.require (node:internal/modules/cjs/loader:1067:19) {
      code: 'MODULE_NOT_FOUND',
      requireStack: [
        '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
        '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    pi@raspberrypi:~ $
    • N nullfreizeit
      Hilft leider nicht
        throw err;
      Require stack:
        requireStack: [
      pi@raspberrypi:~ $
      @nullfreizeit
      cd /opt/iobroker
      sudo -H -u iobroker npm install iobroker.js-controller
      iobroker restart
      N 1 Antwort Letzte Antwort
        @nullfreizeit
        cd /opt/iobroker
        iobroker restart
        N Offline
        N Offline
        nullfreizeit
        Ja sorry. Läuft gerade wieder durch. Danke schonmal
        • N Offline
          N Offline
          nullfreizeit
          @thomas-braun sagte in Admin Problem:
          Hi Thomas, war gestern Abend nach dem hier wieder kurzzeitig im Adminpanel drin. Allerdings konnten keine Instanzen gestartet werden. Hab dann noch mal den fixer drüber laufen lassen und dann kam ich noch nicht einmal mehr ins Adminpanel rein. Hab das heute versucht zu wiederholen. Der Fehler kommt dann. Irgendeine Idee? Vielen Dank.
          pi@raspberrypi:~ $ cd /opt/iobroker
          pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
          npm WARN skipping integrity check for git dependency ssh://git@github.com/walli545/ioBroker.time-switch.git
          npm WARN skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.eventlist.git
          npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
          npm WARN deprecated har-validator@5.1.5: this library is no longer supported
          npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
          npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
          npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
          npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
          npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
          npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
          npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
          added 4 packages, removed 1 package, and changed 859 packages in 22m
          84 packages are looking for funding
            run `npm fund` for details
          pi@raspberrypi:/opt/iobroker $ iobroker restart
          pi@raspberrypi:/opt/iobroker $ iobroker list instances
            throw err;
          Require stack:
            requireStack: [
          • N Offline
            N Offline
            nullfreizeit
            Wenn ich den Befehl
            absetze kommen diese Meldungen (gekürzt)...
            pi@raspberrypi:/opt/iobroker $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpango-1.0.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libjpeg.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfreetype.so.6': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangocairo-1.0.so.0.4400.7': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libjpeg.so.8.2.2': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo-gobject.so.2': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebp.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpdemux.so.2.0.6': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libxml2.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libjpeg.so.8': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgsf-1.so.114.0.46': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebp.so.7.1.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexpat.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpdemux.so.2': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/glib-2.0/include/glibconfig.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangoft2-1.0.so.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips-cpp.so.42.12.1': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgmodule-2.0.so.0.6400.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgdk_pixbuf-2.0.so.0.4000.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgobject-2.0.so.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips-cpp.so.42': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgthread-2.0.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpng.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgsf-1.so.114': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpng16.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangoft2-1.0.so.0.4400.7': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgio-2.0.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpmux.so.3': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips.so.42': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libffi.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgthread-2.0.so.0.6400.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libharfbuzz.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpmux.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgio-2.0.so.0.6400.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebp.so.7': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangocairo-1.0.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpng16.so.16': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfreetype.so.6.17.1': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgthread-2.0.so.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexpat.so.1.6.11': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liblcms2.so.2': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libxml2.so.2': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo-gobject.so.2.11600.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liborc-0.4.so.0.31.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpango-1.0.so.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfribidi.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpdemux.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liborc-0.4.so.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libffi.so.7': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libharfbuzz.so.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/librsvg-2.so.2.47.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfribidi.so.0.4.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpango-1.0.so.0.4400.7': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/xml2Conf.sh': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpixman-1.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexpat.so.1': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgsf-1.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libharfbuzz.so.0.20600.4': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips-cpp.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgif.so.7.0.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexif.so.12.3.3': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgdk_pixbuf-2.0.so.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgio-2.0.so.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libz.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libz.so.1': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfontconfig.so.1.12.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgif.so.7': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgobject-2.0.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpixman-1.so.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgdk_pixbuf-2.0.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgobject-2.0.so.0.6400.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liblcms2.so.2.0.8': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexif.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfontconfig.so.1': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfribidi.so.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/librsvg-2.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfontconfig.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpng16.so.16.37.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libffi.so.7.1.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpixman-1.so.0.38.4': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfreetype.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgmodule-2.0.so.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libglib-2.0.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libtiff.so.5.5.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/librsvg-2.so.2': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangoft2-1.0.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo.so.2.11600.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liblcms2.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libglib-2.0.so.0.6400.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgif.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libtiff.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libtiff.so.5': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo-gobject.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo.so.2': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libxml2.so.2.9.10': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexif.so.12': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libz.so.1.2.11': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liborc-0.4.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpmux.so.3.0.5': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips.so.42.12.1': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgmodule-2.0.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libglib-2.0.so.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangocairo-1.0.so.0': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo.so': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/lcms2_plugin.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/jmorecfg.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/zconf.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/tiff.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/tiffconf.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/fontconfig/fontconfig.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/fontconfig/fcprivate.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/fontconfig/fcfreetype.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlreader.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xpath.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/nanohttp.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/nanoftp.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/globals.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/c14n.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/uri.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlstring.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/debugXML.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xpointer.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlautomata.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/pattern.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlIO.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xinclude.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/HTMLtree.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlsave.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xlink.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/tree.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/dict.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlschemas.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/SAX2.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/parser.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/threads.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlregexp.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/chvalid.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/hash.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/valid.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/list.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/encoding.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlerror.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/schematron.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/SAX.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xpathInternals.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlversion.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/relaxng.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/catalog.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/schemasInternals.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlwriter.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlmemory.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlmodule.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlexports.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlunicode.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/HTMLparser.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/entities.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/parserInternals.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlschemastypes.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/DOCBparser.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gmarshal.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gtypemodule.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gclosure.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gvaluetypes.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gvaluearray.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gvalue.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/glib-enumtypes.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gobjectnotifyqueue.c': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gparam.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gtype.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gbinding.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/genums.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gobject.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/glib-types.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gsourceclosure.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gvaluecollector.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gboxed.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gparamspecs.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gobject-autocleanups.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gsignal.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gtypeplugin.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib-unix.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gmodule.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib-object.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gstring.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/giochannel.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gurifuncs.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gprimes.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gstrfuncs.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gfileutils.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gbytes.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gunicode.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gtestutils.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gshell.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/orc-0.4/orc/orcvariable.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/lcms2.h': Permission denied
            rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/expat_external.h': Permission denied
            • N nullfreizeit
              Wenn ich den Befehl
              @nullfreizeit
              Da hast du mal mit falschen Rechten hantiert. Vermutlich als root.
              Setz vor das rm -rf in der Befehlskette noch ein sudo.
              Und dann nie mehr als root herumkaspern.
                @nullfreizeit
                N Offline
                N Offline
                nullfreizeit
                Danke Thomas. Hat scheinbar geklappt. Allerdings immer noch der Fehler wenn ich "iobroker list instances" eingebe...
                pi@raspberrypi:/opt/iobroker $  for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do sudo rm -rf ${i%%/}; done
                  throw err;
                Require stack:
                  requireStack: [
                • N nullfreizeit
                    throw err;
                  Require stack:
                    requireStack: [
                  @nullfreizeit
                  cd /opt/iobroker
                  iobroker restart
                  Bzw.:
                  cd /opt/iobroker
                  npm ls node-forge
                    @nullfreizeit
                    cd /opt/iobroker
                    iobroker restart
                    Bzw.:
                    cd /opt/iobroker
                    npm ls node-forge
                    N Offline
                    N Offline
                    nullfreizeit
                    npm ls node-forge
                    dann kommt das hier:
                    pi@raspberrypi:/opt/iobroker $ npm ls node-forge
                    iobroker.inst@3.0.0 /opt/iobroker
                    ├─┬ @iobroker/js-controller-common@4.0.24 extraneous
                    │ └── node-forge@ deduped invalid: "^1.0.0" from node_modules/@iobroker/js-controller-common
                    ├─┬ google-p12-pem@4.0.1 extraneous
                    │ └── node-forge@ deduped invalid: "^1.0.0" from node_modules/@iobroker/js-controller-common, "^1.3.1" from node_modules/google-p12-pem
                    ├── node-forge@ invalid: "^1.0.0" from node_modules/@iobroker/js-controller-common, "^1.3.1" from node_modules/google-p12-pem extraneous
                    └─┬ rsa-compat@1.9.4 extraneous
                      └── node-forge@0.7.6 extraneous
                    npm ERR! code ELSPROBLEMS
                    npm ERR! invalid: node-forge@ /opt/iobroker/node_modules/node-forge
                    npm ERR! extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
                    npm ERR! extraneous: node-forge@0.7.6 /opt/iobroker/node_modules/rsa-compat/node_modules/node-forge
                    npm ERR!     /home/iobroker/.npm/_logs/2022-12-26T10_04_48_709Z-debug-0.log
                    • N nullfreizeit
                      npm ls node-forge
                      @nullfreizeit
                      iob stop
                      iob fix
                      iob diag
                      • N Offline
                        N Offline
                        nullfreizeit
                        Hi Thomas,
                        hab noch mal
                        added 4 packages, and changed 859 packages in 16m
                        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 7777, bind: 0.0.0.0, run as: admin
                          system.adapter.alarm.0                  : alarm                 : raspberrypi                              - disabled
                          system.adapter.asterisk.0               : asterisk              : raspberrypi                              -  enabled, port: 5038
                          system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                          system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                          system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                          system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                          system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                          system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
                          system.adapter.eventlist.0              : eventlist             : raspberrypi                              - disabled
                          system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                          system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                          system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
                          system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                          system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                          system.adapter.landroid.0               : landroid              : raspberrypi                              - disabled
                          system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
                          system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1889, bind: 192.168.188.35
                          system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
                          system.adapter.nina.0                   : nina                  : raspberrypi                              -  enabled
                          system.adapter.onvif.0                  : onvif                 : raspberrypi                              - disabled
                          system.adapter.openligadb.0             : openligadb            : raspberrypi                              -  enabled
                          system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
                          system.adapter.pegelalarm.0             : pegelalarm            : raspberrypi                              -  enabled
                          system.adapter.rssfeed.0                : rssfeed               : raspberrypi                              -  enabled
                          system.adapter.sayit.0                  : sayit                 : raspberrypi                              - disabled, port: 0
                          system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                          system.adapter.simple-api.0             : simple-api            : raspberrypi                              - disabled, port: 8087, bind: 0.0.0.0, run as: admin
                          system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                          system.adapter.sony-bravia.0            : sony-bravia           : raspberrypi                              -  enabled
                          system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
                          system.adapter.terminal.0               : terminal              : raspberrypi                              - disabled, port: 8088, bind: 0.0.0.0, run as: admin
                          system.adapter.time-switch.0            : time-switch           : raspberrypi                              - disabled
                          system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                          system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                          system.adapter.tvspielfilm.0            : tvspielfilm           : raspberrypi                              -  enabled
                          system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                          system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                          system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                          system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                          system.adapter.vis-material.0           : vis-material          : raspberrypi                              -  enabled
                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                          system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
                          system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                          system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
                          system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                          system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
                        + instance is alive
                        gemacht. Nun läuft Admin wieder. Backitup ist auch wieder angesprungen. Alle anderen Adapater starten aber nicht. Soll ich nochmal den fix drüber laufen lassen wie du beschrieben hast? Danke
                        • N nullfreizeit
                          Hi Thomas,
                          hab noch mal
                          + instance is alive
                          @nullfreizeit
                          Und
                          iobroker diag
                          sagt was?
                            @nullfreizeit
                            Und
                            iobroker diag
                            sagt was?
                            N Offline
                            N Offline
                            nullfreizeit
                            Das hier:
                                                    v.2022-12-13
                            Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
                            Installation:           Native
                            Timezone:               Europe/Berlin
                            User-ID:                1000
                            X-Server:               false
                            Pending OS-Updates:     0
                            Nodejs-Installation:    /usr/bin/nodejs         v16.19.0
                                                    /usr/bin/node           v16.19.0
                                                    /usr/bin/npm            8.19.3
                            ioBroker Core:          js-controller           4.0.24
                                                    admin                   6.3.5
                            Objects type: jsonl
                            States  type: jsonl
                            Pending iob updates:    0
                            Objects:                8724
                            States:                 7313
                            Size of iob-Database:
                            20M     /opt/iobroker/iobroker-data/objects.jsonl
                            8.6M    /opt/iobroker/iobroker-data/objects.json.migrated
                            8.6M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                            4.2M    /opt/iobroker/iobroker-data/states.jsonl
                            3.0M    /opt/iobroker/iobroker-data/states.json.migrated
                            3.0M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                            ====================== END OF SUMMARY ==================
                            Allerdings hat er vor der "Summary" dies hier als Fehler angezeigt...
                            *** ioBroker-Installation ***
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Core adapters versions
                            js-controller:  4.0.24
                            admin:          6.3.5
                            npm ERR! invalid: iobroker.admin@6.3.5 /opt/iobroker/node_modules/iobroker.admin
                            npm ERR! invalid: iobroker.backitup@2.5.9 /opt/iobroker/node_modules/iobroker.backitup
                            npm ERR! invalid: iobroker.discovery@3.1.0 /opt/iobroker/node_modules/iobroker.discovery
                            npm ERR! invalid: iobroker.eventlist@0.5.5 /opt/iobroker/node_modules/iobroker.eventlist
                            npm ERR! invalid: iobroker.onvif@0.4.5 /opt/iobroker/node_modules/iobroker.onvif
                            npm ERR! invalid: iobroker.time-switch@2.2.2 /opt/iobroker/node_modules/iobroker.time-switch
                            npm ERR!     /home/pi/.npm/_logs/2022-12-26T10_52_10_883Z-debug-0.log
                            Adapters from github:   3
                            • N Offline
                              N Offline
                              nullfreizeit
                              schrieb am zuletzt editiert von nullfreizeit
                              Admin hat den Adapter "javascript" scheinbar von alleine neu installiert... der läuft jetzt wieder. Alles andere inkl. Zigbee bleibt auf rot (Verbunden mit Host / Lebenszeichen).
                              Bekomme beim Aufrufen der Instanzen links unten timeout-Fehlermeldungen
                              host.raspberrypi
                              	2022-12-26 12:20:02.691	error	cannot read and parse "/opt/iobroker/node_modules/iobroker.js-controller/io-package.json"
                              Hab das im Log gefunden
                              2022-12-26 11:51:16.264 - info: host.raspberrypi iobroker npm-install: NPM version: 8.19.3
                              2022-12-26 11:51:16.287 - info: host.raspberrypi iobroker npm-install: Installing iobroker.javascript@6.1.4... (System call)
                              • N nullfreizeit
                                host.raspberrypi
                                @nullfreizeit
                                Installier die genannten sechs Adapter nochmal neu.
                                  @nullfreizeit
                                  N Offline
                                  N Offline
                                  nullfreizeit
                                  Wie sollte ich deine Meinung nach vorgehen. Über Admin deinstallieren und neu (aber sind dann nicht auch die Daten weg)? Oder über Putty irgendwie?
                                  Danke dir vielmals für deine Geduld! Ich bin allen hier so dankbar das ihr euch auch für mich als Laien Zeit nehmt.
                                  • N nullfreizeit
                                    #66
                                    @nullfreizeit
                                    Ich würde wohl in die jeweiligen Verzeichnisse wechseln und
                                    sudo -u iobroker npm install
                                    ausführen.
                                    • N Offline
                                      N Offline
                                      nullfreizeit
                                      #67
                                      Ich warte mal etwas ab. Scheinbar versucht er sich selbst zu fixen...
                                      Mihome.vacuum hat er auch neu installiert und es scheint zu laufen. Gleich mal testen.
                                      host.raspberrypi
                                      	2022-12-26 13:02:53.507	info	iobroker npm-install: Installing iobroker.openweathermap@0.3.3... (System call)
                                      host.raspberrypi
                                      	2022-12-26 13:02:53.490	info	iobroker npm-install: NPM version: 8.19.3
                                      host.raspberrypi
                                      	2022-12-26 13:02:48.930	info	iobroker install openweathermap@0.3.3 using installedFrom
                                      • N Offline
                                        N Offline
                                        nullfreizeit
                                        #68
                                        Beim Aufruf der Instanzen im Admin Panel kommt dieser Fehler unten links
                                        Scheinbar muss ich einfach nur warten... Versucht nun den nächsten Adapter zu fixen...
                                        host.raspberrypi
                                        	2022-12-26 13:26:46.151	info	iobroker install shelly@6.0.0 using installedFrom
                                        host.raspberrypi
                                        	2022-12-26 13:26:46.150	warn	startInstance cannot find adapter "shelly@6.0.0". Try to install it... 1 attempt
                                        • N Offline
                                          N Offline
                                          nullfreizeit
                                          #69
                                          Ich möchte mich noch einmal bei allen bedanken. Danke an Thomas und die anderen hier.
                                          Es funktioniert nun alles wieder. Keine Ahnung was los war - never change a running system.
