  4. Admin Problem
    5.6k
Admin Problem
admin
70 Beiträge 8 Kommentatoren 10.2k Aufrufe 7 Beobachtet
  • N nullfreizeit
    Danke, bekomme allerdings schon vor dem iobroker restart das hier…
    0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 0 not upgraded.
    Need to get 24.2 MB of archives.
    After this operation, 50.7 MB disk space will be freed.
    Do you want to continue? [Y/n] y
    Get:1 https://deb.nodesource.com/node_16.x bullseye/main armhf nodejs armhf 16.19.0-deb-1nodesource1 [24.2 MB]
    Fetched 24.2 MB in 2s (11.9 MB/s)
    dpkg: warning: downgrading nodejs from 18.12.1-deb-1nodesource1 to 16.19.0-deb-1nodesource1
    (Reading database ... 63183 files and directories currently installed.)
    Preparing to unpack .../nodejs_16.19.0-deb-1nodesource1_armhf.deb ...
    Unpacking nodejs (16.19.0-deb-1nodesource1) over (18.12.1-deb-1nodesource1) ...
    Setting up nodejs (16.19.0-deb-1nodesource1) ...
    Processing triggers for man-db (2.9.4-2) ...
    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/async
    npm ERR! dest /opt/iobroker/node_modules/.async-STKQSxEj
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/async' -> '/opt/iobroker/node_modules/.async-STKQSxEj'
    npm ERR!     /home/iobroker/.npm/_logs/2022-12-25T22_53_30_615Z-debug-0.log
    @nullfreizeit
    https://forum.iobroker.net/topic/57337/fehler-25-oder-217-bei-adapter-install-update-mit-npm8
    N 1 Antwort Letzte Antwort
      @nullfreizeit
      N Offline
      N Offline
      nullfreizeit
      Hilft leider nicht
      pi@raspberrypi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
      pi@raspberrypi:~ $ iobroker start
      pi@raspberrypi:~ $ iobroker list instances
      node:internal/modules/cjs/loader:998
        throw err;
      Error: Cannot find module 'node-forge'
      Require stack:
      - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
      - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
      - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
      - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
          at Function.Module._load (node:internal/modules/cjs/loader:841:27)
          at Module.require (node:internal/modules/cjs/loader:1067:19)
          at require (node:internal/modules/cjs/helpers:103:18)
          at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:7:15)
          at Module._compile (node:internal/modules/cjs/loader:1165:14)
          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
          at Module.load (node:internal/modules/cjs/loader:1043:32)
          at Function.Module._load (node:internal/modules/cjs/loader:878:12)
          at Module.require (node:internal/modules/cjs/loader:1067:19) {
        code: 'MODULE_NOT_FOUND',
        requireStack: [
          '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
          '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
          '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
          '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
      pi@raspberrypi:~ $
      • N nullfreizeit
        Hilft leider nicht
          throw err;
        Require stack:
          requireStack: [
        pi@raspberrypi:~ $
        @nullfreizeit
        cd /opt/iobroker
        iobroker restart
          @nullfreizeit
          cd /opt/iobroker
          iobroker restart
          N Offline
          N Offline
          nullfreizeit
          Ja sorry. Läuft gerade wieder durch. Danke schonmal
          • N Offline
            N Offline
            nullfreizeit
            @thomas-braun sagte in Admin Problem:
            Hi Thomas, war gestern Abend nach dem hier wieder kurzzeitig im Adminpanel drin. Allerdings konnten keine Instanzen gestartet werden. Hab dann noch mal den fixer drüber laufen lassen und dann kam ich noch nicht einmal mehr ins Adminpanel rein. Hab das heute versucht zu wiederholen. Der Fehler kommt dann. Irgendeine Idee? Vielen Dank.
            pi@raspberrypi:~ $ cd /opt/iobroker
            npm WARN skipping integrity check for git dependency ssh://git@github.com/walli545/ioBroker.time-switch.git
            npm WARN skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.eventlist.git
            npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
            npm WARN deprecated har-validator@5.1.5: this library is no longer supported
            npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
            npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
            npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
            npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
            npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
            npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
            added 4 packages, removed 1 package, and changed 859 packages in 22m
            84 packages are looking for funding
              run `npm fund` for details
            pi@raspberrypi:/opt/iobroker $ iobroker restart
            pi@raspberrypi:/opt/iobroker $ iobroker list instances
              throw err;
            Require stack:
              requireStack: [
            • N Offline
              N Offline
              nullfreizeit
              Wenn ich den Befehl
              absetze kommen diese Meldungen (gekürzt)...
              pi@raspberrypi:/opt/iobroker $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpango-1.0.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libjpeg.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfreetype.so.6': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangocairo-1.0.so.0.4400.7': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libjpeg.so.8.2.2': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo-gobject.so.2': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebp.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpdemux.so.2.0.6': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libxml2.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libjpeg.so.8': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgsf-1.so.114.0.46': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebp.so.7.1.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexpat.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpdemux.so.2': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/glib-2.0/include/glibconfig.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangoft2-1.0.so.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips-cpp.so.42.12.1': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgmodule-2.0.so.0.6400.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgdk_pixbuf-2.0.so.0.4000.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgobject-2.0.so.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips-cpp.so.42': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgthread-2.0.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpng.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgsf-1.so.114': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpng16.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangoft2-1.0.so.0.4400.7': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgio-2.0.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpmux.so.3': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips.so.42': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libffi.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgthread-2.0.so.0.6400.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libharfbuzz.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpmux.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgio-2.0.so.0.6400.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebp.so.7': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangocairo-1.0.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpng16.so.16': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfreetype.so.6.17.1': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgthread-2.0.so.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexpat.so.1.6.11': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liblcms2.so.2': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libxml2.so.2': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo-gobject.so.2.11600.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liborc-0.4.so.0.31.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpango-1.0.so.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfribidi.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpdemux.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liborc-0.4.so.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libffi.so.7': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libharfbuzz.so.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/librsvg-2.so.2.47.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfribidi.so.0.4.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpango-1.0.so.0.4400.7': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/xml2Conf.sh': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpixman-1.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexpat.so.1': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgsf-1.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libharfbuzz.so.0.20600.4': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips-cpp.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgif.so.7.0.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexif.so.12.3.3': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgdk_pixbuf-2.0.so.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgio-2.0.so.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libz.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libz.so.1': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfontconfig.so.1.12.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgif.so.7': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgobject-2.0.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpixman-1.so.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgdk_pixbuf-2.0.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgobject-2.0.so.0.6400.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liblcms2.so.2.0.8': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexif.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfontconfig.so.1': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfribidi.so.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/librsvg-2.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfontconfig.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpng16.so.16.37.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libffi.so.7.1.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpixman-1.so.0.38.4': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfreetype.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgmodule-2.0.so.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libglib-2.0.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libtiff.so.5.5.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/librsvg-2.so.2': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangoft2-1.0.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo.so.2.11600.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liblcms2.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libglib-2.0.so.0.6400.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgif.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libtiff.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libtiff.so.5': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo-gobject.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo.so.2': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libxml2.so.2.9.10': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexif.so.12': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libz.so.1.2.11': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liborc-0.4.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpmux.so.3.0.5': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips.so.42.12.1': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgmodule-2.0.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libglib-2.0.so.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangocairo-1.0.so.0': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo.so': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/lcms2_plugin.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/jmorecfg.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/zconf.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/tiff.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/tiffconf.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/fontconfig/fontconfig.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/fontconfig/fcprivate.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/fontconfig/fcfreetype.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlreader.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xpath.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/nanohttp.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/nanoftp.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/globals.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/c14n.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/uri.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlstring.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/debugXML.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xpointer.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlautomata.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/pattern.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlIO.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xinclude.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/HTMLtree.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlsave.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xlink.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/tree.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/dict.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlschemas.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/SAX2.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/parser.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/threads.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlregexp.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/chvalid.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/hash.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/valid.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/list.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/encoding.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlerror.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/schematron.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/SAX.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xpathInternals.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlversion.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/relaxng.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/catalog.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/schemasInternals.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlwriter.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlmemory.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlmodule.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlexports.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlunicode.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/HTMLparser.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/entities.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/parserInternals.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlschemastypes.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/DOCBparser.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gmarshal.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gtypemodule.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gclosure.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gvaluetypes.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gvaluearray.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gvalue.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/glib-enumtypes.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gobjectnotifyqueue.c': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gparam.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gtype.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gbinding.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/genums.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gobject.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/glib-types.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gsourceclosure.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gvaluecollector.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gboxed.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gparamspecs.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gobject-autocleanups.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gsignal.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gtypeplugin.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib-unix.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gmodule.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib-object.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gstring.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/giochannel.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gurifuncs.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gprimes.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gstrfuncs.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gfileutils.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gbytes.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gunicode.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gtestutils.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gshell.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/orc-0.4/orc/orcvariable.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/lcms2.h': Permission denied
              rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/expat_external.h': Permission denied
              • N nullfreizeit
                Wenn ich den Befehl
                @nullfreizeit
                Da hast du mal mit falschen Rechten hantiert. Vermutlich als root.
                Setz vor das rm -rf in der Befehlskette noch ein sudo.
                Und dann nie mehr als root herumkaspern.
                  @nullfreizeit
                  N Offline
                  N Offline
                  nullfreizeit
                  Danke Thomas. Hat scheinbar geklappt. Allerdings immer noch der Fehler wenn ich "iobroker list instances" eingebe...
                  pi@raspberrypi:/opt/iobroker $  for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do sudo rm -rf ${i%%/}; done
                    throw err;
                  Require stack:
                    requireStack: [
                  • N nullfreizeit
                      throw err;
                    Require stack:
                      requireStack: [
                    @nullfreizeit
                    cd /opt/iobroker
                    iobroker restart
                    Bzw.:
                    cd /opt/iobroker
                    npm ls node-forge
                      @nullfreizeit
                      cd /opt/iobroker
                      iobroker restart
                      Bzw.:
                      cd /opt/iobroker
                      npm ls node-forge
                      N Offline
                      N Offline
                      nullfreizeit
                      npm ls node-forge
                      dann kommt das hier:
                      pi@raspberrypi:/opt/iobroker $ npm ls node-forge
                      iobroker.inst@3.0.0 /opt/iobroker
                      ├─┬ @iobroker/js-controller-common@4.0.24 extraneous
                      │ └── node-forge@ deduped invalid: "^1.0.0" from node_modules/@iobroker/js-controller-common
                      ├─┬ google-p12-pem@4.0.1 extraneous
                      │ └── node-forge@ deduped invalid: "^1.0.0" from node_modules/@iobroker/js-controller-common, "^1.3.1" from node_modules/google-p12-pem
                      ├── node-forge@ invalid: "^1.0.0" from node_modules/@iobroker/js-controller-common, "^1.3.1" from node_modules/google-p12-pem extraneous
                      └─┬ rsa-compat@1.9.4 extraneous
                        └── node-forge@0.7.6 extraneous
                      npm ERR! code ELSPROBLEMS
                      npm ERR! invalid: node-forge@ /opt/iobroker/node_modules/node-forge
                      npm ERR! extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
                      npm ERR! extraneous: node-forge@0.7.6 /opt/iobroker/node_modules/rsa-compat/node_modules/node-forge
                      npm ERR!     /home/iobroker/.npm/_logs/2022-12-26T10_04_48_709Z-debug-0.log
                      • N nullfreizeit
                        npm ls node-forge
                        @nullfreizeit
                        iob stop
                        iob fix
                        iob diag
                        • N Offline
                          N Offline
                          nullfreizeit
                          Hi Thomas,
                          hab noch mal
                          added 4 packages, and changed 859 packages in 16m
                          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 7777, bind: 0.0.0.0, run as: admin
                            system.adapter.alarm.0                  : alarm                 : raspberrypi                              - disabled
                            system.adapter.asterisk.0               : asterisk              : raspberrypi                              -  enabled, port: 5038
                            system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                            system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                            system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                            system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                            system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                            system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
                            system.adapter.eventlist.0              : eventlist             : raspberrypi                              - disabled
                            system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                          + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                            system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                            system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
                            system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
                            system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                            system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                            system.adapter.landroid.0               : landroid              : raspberrypi                              - disabled
                            system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
                            system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1889, bind: 192.168.188.35
                            system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
                            system.adapter.nina.0                   : nina                  : raspberrypi                              -  enabled
                            system.adapter.onvif.0                  : onvif                 : raspberrypi                              - disabled
                            system.adapter.openligadb.0             : openligadb            : raspberrypi                              -  enabled
                            system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
                            system.adapter.pegelalarm.0             : pegelalarm            : raspberrypi                              -  enabled
                            system.adapter.rssfeed.0                : rssfeed               : raspberrypi                              -  enabled
                            system.adapter.sayit.0                  : sayit                 : raspberrypi                              - disabled, port: 0
                            system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                            system.adapter.simple-api.0             : simple-api            : raspberrypi                              - disabled, port: 8087, bind: 0.0.0.0, run as: admin
                            system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                            system.adapter.sony-bravia.0            : sony-bravia           : raspberrypi                              -  enabled
                            system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
                            system.adapter.terminal.0               : terminal              : raspberrypi                              - disabled, port: 8088, bind: 0.0.0.0, run as: admin
                            system.adapter.time-switch.0            : time-switch           : raspberrypi                              - disabled
                            system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                            system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                            system.adapter.tvspielfilm.0            : tvspielfilm           : raspberrypi                              -  enabled
                            system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                            system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                            system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                            system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                            system.adapter.vis-material.0           : vis-material          : raspberrypi                              -  enabled
                            system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                            system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
                            system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                            system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
                            system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                            system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
                          + instance is alive
                          gemacht. Nun läuft Admin wieder. Backitup ist auch wieder angesprungen. Alle anderen Adapater starten aber nicht. Soll ich nochmal den fix drüber laufen lassen wie du beschrieben hast? Danke
                          • N nullfreizeit
                            Hi Thomas,
                            hab noch mal
                            + instance is alive
                            @nullfreizeit
                            Und
                            iobroker diag
                            sagt was?
                              @nullfreizeit
                              Und
                              iobroker diag
                              sagt was?
                              N Offline
                              N Offline
                              nullfreizeit
                              Das hier:
                                                      v.2022-12-13
                              Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
                              Installation:           Native
                              Timezone:               Europe/Berlin
                              User-ID:                1000
                              X-Server:               false
                              Pending OS-Updates:     0
                              Nodejs-Installation:    /usr/bin/nodejs         v16.19.0
                                                      /usr/bin/node           v16.19.0
                                                      /usr/bin/npm            8.19.3
                              ioBroker Core:          js-controller           4.0.24
                                                      admin                   6.3.5
                              Objects type: jsonl
                              States  type: jsonl
                              Pending iob updates:    0
                              Objects:                8724
                              States:                 7313
                              Size of iob-Database:
                              20M     /opt/iobroker/iobroker-data/objects.jsonl
                              8.6M    /opt/iobroker/iobroker-data/objects.json.migrated
                              8.6M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                              4.2M    /opt/iobroker/iobroker-data/states.jsonl
                              3.0M    /opt/iobroker/iobroker-data/states.json.migrated
                              3.0M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                              ====================== END OF SUMMARY ==================
                              Allerdings hat er vor der "Summary" dies hier als Fehler angezeigt...
                              *** ioBroker-Installation ***
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Core adapters versions
                              js-controller:  4.0.24
                              admin:          6.3.5
                              npm ERR! invalid: iobroker.admin@6.3.5 /opt/iobroker/node_modules/iobroker.admin
                              npm ERR! invalid: iobroker.backitup@2.5.9 /opt/iobroker/node_modules/iobroker.backitup
                              npm ERR! invalid: iobroker.discovery@3.1.0 /opt/iobroker/node_modules/iobroker.discovery
                              npm ERR! invalid: iobroker.eventlist@0.5.5 /opt/iobroker/node_modules/iobroker.eventlist
                              npm ERR! invalid: iobroker.onvif@0.4.5 /opt/iobroker/node_modules/iobroker.onvif
                              npm ERR! invalid: iobroker.time-switch@2.2.2 /opt/iobroker/node_modules/iobroker.time-switch
                              npm ERR!     /home/pi/.npm/_logs/2022-12-26T10_52_10_883Z-debug-0.log
                              Adapters from github:   3
                              • N Offline
                                N Offline
                                nullfreizeit
                                schrieb am zuletzt editiert von nullfreizeit
                                Admin hat den Adapter "javascript" scheinbar von alleine neu installiert... der läuft jetzt wieder. Alles andere inkl. Zigbee bleibt auf rot (Verbunden mit Host / Lebenszeichen).
                                Bekomme beim Aufrufen der Instanzen links unten timeout-Fehlermeldungen
                                host.raspberrypi
                                	2022-12-26 12:20:02.691	error	cannot read and parse "/opt/iobroker/node_modules/iobroker.js-controller/io-package.json"
                                Hab das im Log gefunden
                                2022-12-26 11:51:16.264 - info: host.raspberrypi iobroker npm-install: NPM version: 8.19.3
                                2022-12-26 11:51:16.287 - info: host.raspberrypi iobroker npm-install: Installing iobroker.javascript@6.1.4... (System call)
                                • N nullfreizeit
                                  host.raspberrypi
                                  @nullfreizeit
                                  Installier die genannten sechs Adapter nochmal neu.
                                    @nullfreizeit
                                    N Offline
                                    N Offline
                                    nullfreizeit
                                    Wie sollte ich deine Meinung nach vorgehen. Über Admin deinstallieren und neu (aber sind dann nicht auch die Daten weg)? Oder über Putty irgendwie?
                                    Danke dir vielmals für deine Geduld! Ich bin allen hier so dankbar das ihr euch auch für mich als Laien Zeit nehmt.
                                    • N nullfreizeit
                                      #66
                                      @nullfreizeit
                                      Ich würde wohl in die jeweiligen Verzeichnisse wechseln und
                                      sudo -u iobroker npm install
                                      ausführen.
                                      • N Offline
                                        N Offline
                                        nullfreizeit
                                        #67
                                        Ich warte mal etwas ab. Scheinbar versucht er sich selbst zu fixen...
                                        Mihome.vacuum hat er auch neu installiert und es scheint zu laufen. Gleich mal testen.
                                        host.raspberrypi
                                        	2022-12-26 13:02:53.507	info	iobroker npm-install: Installing iobroker.openweathermap@0.3.3... (System call)
                                        host.raspberrypi
                                        	2022-12-26 13:02:53.490	info	iobroker npm-install: NPM version: 8.19.3
                                        host.raspberrypi
                                        	2022-12-26 13:02:48.930	info	iobroker install openweathermap@0.3.3 using installedFrom
                                        • N Offline
                                          N Offline
                                          nullfreizeit
                                          #68
                                          Beim Aufruf der Instanzen im Admin Panel kommt dieser Fehler unten links
                                          Scheinbar muss ich einfach nur warten... Versucht nun den nächsten Adapter zu fixen...
                                          host.raspberrypi
                                          	2022-12-26 13:26:46.151	info	iobroker install shelly@6.0.0 using installedFrom
                                          host.raspberrypi
                                          	2022-12-26 13:26:46.150	warn	startInstance cannot find adapter "shelly@6.0.0". Try to install it... 1 attempt
