  4. Admin Problem
    5.6k
Admin Problem
admin
70 Beiträge 8 Kommentatoren 10.2k Aufrufe 7 Beobachtet
    @nullfreizeit
    cd /opt/iobroker
    sudo -H -u iobroker npm install iobroker.js-controller
    N Offline
    N Offline
    nullfreizeit
    Hi Thomas, bekomme nun diese Fehlermeldung.
    pi@raspberrypi:~ $ cd /opt/iobroker
    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/async
    npm ERR! dest /opt/iobroker/node_modules/.async-STKQSxEj
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/async' -> '/opt/iobroker/node_modules/.async-STKQSxEj'
    npm ERR!     /home/iobroker/.npm/_logs/2022-12-25T17_32_10_903Z-debug-0.log
    • N nullfreizeit
      npm ERR! errno -39
      @nullfreizeit
      Ja, siehe oben im Forum angepinnt.
      • N Offline
        N Offline
        nullfreizeit
        Hab jetzt alles gem. dem Link hier durch und den fixer drüber laufen lassen.
        Bekomme nun folgende Fehlermeldung. Danke für einen Rat.
        https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
        pi@raspberrypi:~ $ iobroker fix
        library: loaded
        Library version=2022-12-09
            Welcome to the ioBroker installation fixer!
            Script version: 2022-12-22
            You might need to enter your password a couple of times.
            Installing prerequisites (1/4)
        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
        Reading package lists... Done
        Installed gcc-c++
            Checking ioBroker user and directory permissions (2/4)
            Database maintenance (3/4)
        Checking for uncompressed JSONL databases... This might take a while!
        Compressing /opt/iobroker/iobroker-data/states.jsonl
        Compressing /opt/iobroker/iobroker-data/objects.jsonl
        Compressed 2 JSONL files. Done
            Checking autostart (4/4)
        Enabling autostart...
        Autostart enabled!
            Your installation was fixed successfully
            Run iobroker start to start ioBroker again!
        pi@raspberrypi:~ $ iobroker start
        pi@raspberrypi:~ $ iobroker list instances
        node:internal/modules/cjs/loader:998
          throw err;
        Error: Cannot find module 'node-forge'
        Require stack:
        - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
        - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
        - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
        - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
            at Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
            at Module._load (node:internal/modules/cjs/loader:841:27)
            at Module.require (node:internal/modules/cjs/loader:1061:19)
            at require (node:internal/modules/cjs/helpers:103:18)
            at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:7:15)
            at Module._compile (node:internal/modules/cjs/loader:1159:14)
            at Module._extensions..js (node:internal/modules/cjs/loader:1213:10)
            at Module.load (node:internal/modules/cjs/loader:1037:32)
            at Module._load (node:internal/modules/cjs/loader:878:12)
            at Module.require (node:internal/modules/cjs/loader:1061:19) {
          code: 'MODULE_NOT_FOUND',
          requireStack: [
            '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
            '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
            '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
            '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        Node.js v18.12.1
        pi@raspberrypi:~ $ npm -v
        8.19.2
        • N nullfreizeit
          library: loaded
          Installed gcc-c++
          Autostart enabled!
            throw err;
          Require stack:
            requireStack: [
          Node.js v18.12.1
          8.19.2
          @nullfreizeit
          iob stop
          sudo apt install nodejs=16.19.0-deb-1nodesource1
          • N nullfreizeit
            library: loaded
            Installed gcc-c++
            Autostart enabled!
              throw err;
            Require stack:
              requireStack: [
            Node.js v18.12.1
            8.19.2
            @nullfreizeit
            Danach
            cd /opt/iobroker
            iobroker restart
            N 1 Antwort Letzte Antwort
              @nullfreizeit
              Danach
              cd /opt/iobroker
              iobroker restart
              N Offline
              N Offline
              nullfreizeit
              Danke, bekomme allerdings schon vor dem iobroker restart das hier…
              0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 0 not upgraded.
              Need to get 24.2 MB of archives.
              After this operation, 50.7 MB disk space will be freed.
              Do you want to continue? [Y/n] y
              Get:1 https://deb.nodesource.com/node_16.x bullseye/main armhf nodejs armhf 16.19.0-deb-1nodesource1 [24.2 MB]
              Fetched 24.2 MB in 2s (11.9 MB/s)
              dpkg: warning: downgrading nodejs from 18.12.1-deb-1nodesource1 to 16.19.0-deb-1nodesource1
              (Reading database ... 63183 files and directories currently installed.)
              Preparing to unpack .../nodejs_16.19.0-deb-1nodesource1_armhf.deb ...
              Unpacking nodejs (16.19.0-deb-1nodesource1) over (18.12.1-deb-1nodesource1) ...
              Setting up nodejs (16.19.0-deb-1nodesource1) ...
              Processing triggers for man-db (2.9.4-2) ...
              npm ERR! errno -39
              npm ERR!     /home/iobroker/.npm/_logs/2022-12-25T22_53_30_615Z-debug-0.log
              • N nullfreizeit
                npm ERR! errno -39
                @nullfreizeit
                https://forum.iobroker.net/topic/57337/fehler-25-oder-217-bei-adapter-install-update-mit-npm8
                  @nullfreizeit
                  N Offline
                  N Offline
                  nullfreizeit
                  Hilft leider nicht
                  pi@raspberrypi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                    throw err;
                  Require stack:
                      at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
                      at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                      at Module.require (node:internal/modules/cjs/loader:1067:19)
                      at Module._compile (node:internal/modules/cjs/loader:1165:14)
                      at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                      at Module.load (node:internal/modules/cjs/loader:1043:32)
                      at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                      at Module.require (node:internal/modules/cjs/loader:1067:19) {
                    requireStack: [
                  pi@raspberrypi:~ $
                  • N nullfreizeit
                    Hilft leider nicht
                      throw err;
                    Require stack:
                      requireStack: [
                    pi@raspberrypi:~ $
                    @nullfreizeit
                    cd /opt/iobroker
                    iobroker restart
                      @nullfreizeit
                      cd /opt/iobroker
                      iobroker restart
                      N Offline
                      N Offline
                      nullfreizeit
                      Ja sorry. Läuft gerade wieder durch. Danke schonmal
                      • N Offline
                        N Offline
                        nullfreizeit
                        @thomas-braun sagte in Admin Problem:
                        Hi Thomas, war gestern Abend nach dem hier wieder kurzzeitig im Adminpanel drin. Allerdings konnten keine Instanzen gestartet werden. Hab dann noch mal den fixer drüber laufen lassen und dann kam ich noch nicht einmal mehr ins Adminpanel rein. Hab das heute versucht zu wiederholen. Der Fehler kommt dann. Irgendeine Idee? Vielen Dank.
                        npm WARN skipping integrity check for git dependency ssh://git@github.com/walli545/ioBroker.time-switch.git
                        npm WARN skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.eventlist.git
                        npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                        npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                        npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                        npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                        npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
                        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                        npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                        added 4 packages, removed 1 package, and changed 859 packages in 22m
                        84 packages are looking for funding
                          run `npm fund` for details
                        pi@raspberrypi:/opt/iobroker $ iobroker restart
                        pi@raspberrypi:/opt/iobroker $ iobroker list instances
                          throw err;
                        Require stack:
                          requireStack: [
                        • N Offline
                          N Offline
                          nullfreizeit
                          Wenn ich den Befehl
                          absetze kommen diese Meldungen (gekürzt)...
                          pi@raspberrypi:/opt/iobroker $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpango-1.0.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libjpeg.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfreetype.so.6': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangocairo-1.0.so.0.4400.7': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libjpeg.so.8.2.2': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo-gobject.so.2': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebp.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpdemux.so.2.0.6': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libxml2.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libjpeg.so.8': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgsf-1.so.114.0.46': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebp.so.7.1.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexpat.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpdemux.so.2': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/glib-2.0/include/glibconfig.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangoft2-1.0.so.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips-cpp.so.42.12.1': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgmodule-2.0.so.0.6400.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgdk_pixbuf-2.0.so.0.4000.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgobject-2.0.so.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips-cpp.so.42': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgthread-2.0.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpng.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgsf-1.so.114': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpng16.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangoft2-1.0.so.0.4400.7': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgio-2.0.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpmux.so.3': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips.so.42': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libffi.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgthread-2.0.so.0.6400.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libharfbuzz.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpmux.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgio-2.0.so.0.6400.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebp.so.7': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangocairo-1.0.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpng16.so.16': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfreetype.so.6.17.1': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgthread-2.0.so.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexpat.so.1.6.11': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liblcms2.so.2': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libxml2.so.2': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo-gobject.so.2.11600.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liborc-0.4.so.0.31.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpango-1.0.so.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfribidi.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpdemux.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liborc-0.4.so.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libffi.so.7': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libharfbuzz.so.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/librsvg-2.so.2.47.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfribidi.so.0.4.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpango-1.0.so.0.4400.7': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/xml2Conf.sh': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpixman-1.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexpat.so.1': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgsf-1.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libharfbuzz.so.0.20600.4': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips-cpp.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgif.so.7.0.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexif.so.12.3.3': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgdk_pixbuf-2.0.so.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgio-2.0.so.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libz.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libz.so.1': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfontconfig.so.1.12.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgif.so.7': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgobject-2.0.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpixman-1.so.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgdk_pixbuf-2.0.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgobject-2.0.so.0.6400.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liblcms2.so.2.0.8': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexif.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfontconfig.so.1': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfribidi.so.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/librsvg-2.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfontconfig.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpng16.so.16.37.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libffi.so.7.1.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpixman-1.so.0.38.4': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libfreetype.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgmodule-2.0.so.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libglib-2.0.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libtiff.so.5.5.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/librsvg-2.so.2': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangoft2-1.0.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo.so.2.11600.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liblcms2.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libglib-2.0.so.0.6400.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgif.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libtiff.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libtiff.so.5': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo-gobject.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo.so.2': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libxml2.so.2.9.10': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libexif.so.12': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libz.so.1.2.11': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/liborc-0.4.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libwebpmux.so.3.0.5': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libvips.so.42.12.1': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libgmodule-2.0.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libglib-2.0.so.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libpangocairo-1.0.so.0': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/lib/libcairo.so': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/lcms2_plugin.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/jmorecfg.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/zconf.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/tiff.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/tiffconf.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/fontconfig/fontconfig.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/fontconfig/fcprivate.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/fontconfig/fcfreetype.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlreader.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xpath.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/nanohttp.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/nanoftp.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/globals.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/c14n.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/uri.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlstring.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/debugXML.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xpointer.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlautomata.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/pattern.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlIO.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xinclude.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/HTMLtree.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlsave.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xlink.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/tree.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/dict.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlschemas.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/SAX2.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/parser.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/threads.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlregexp.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/chvalid.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/hash.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/valid.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/list.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/encoding.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlerror.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/schematron.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/SAX.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xpathInternals.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlversion.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/relaxng.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/catalog.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/schemasInternals.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlwriter.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlmemory.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlmodule.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlexports.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlunicode.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/HTMLparser.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/entities.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/parserInternals.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/xmlschemastypes.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/libxml2/libxml/DOCBparser.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gmarshal.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gtypemodule.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gclosure.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gvaluetypes.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gvaluearray.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gvalue.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/glib-enumtypes.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gobjectnotifyqueue.c': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gparam.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gtype.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gbinding.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/genums.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gobject.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/glib-types.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gsourceclosure.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gvaluecollector.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gboxed.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gparamspecs.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gobject-autocleanups.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gsignal.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gobject/gtypeplugin.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib-unix.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/gmodule.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib-object.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gstring.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/giochannel.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gurifuncs.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gprimes.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gstrfuncs.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gfileutils.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gbytes.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gunicode.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gtestutils.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/glib-2.0/glib/gshell.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/orc-0.4/orc/orcvariable.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/lcms2.h': Permission denied
                          rm: cannot remove '/opt/iobroker/node_modules/.sharp-I3mcBL1h/vendor/include/expat_external.h': Permission denied
                          • N nullfreizeit
                            Wenn ich den Befehl
                            @nullfreizeit
                            Da hast du mal mit falschen Rechten hantiert. Vermutlich als root.
                            Setz vor das rm -rf in der Befehlskette noch ein sudo.
                            Und dann nie mehr als root herumkaspern.
                              @nullfreizeit
                              N Offline
                              N Offline
                              nullfreizeit
                              Danke Thomas. Hat scheinbar geklappt. Allerdings immer noch der Fehler wenn ich "iobroker list instances" eingebe...
                              pi@raspberrypi:/opt/iobroker $  for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do sudo rm -rf ${i%%/}; done
                                throw err;
                              Require stack:
                                requireStack: [
                              • N nullfreizeit
                                  throw err;
                                Require stack:
                                  requireStack: [
                                @nullfreizeit
                                cd /opt/iobroker
                                iobroker restart
                                Bzw.:
                                cd /opt/iobroker
                                npm ls node-forge
                                  @nullfreizeit
                                  cd /opt/iobroker
                                  iobroker restart
                                  Bzw.:
                                  cd /opt/iobroker
                                  npm ls node-forge
                                  N Offline
                                  N Offline
                                  nullfreizeit
                                  npm ls node-forge
                                  dann kommt das hier:
                                  pi@raspberrypi:/opt/iobroker $ npm ls node-forge
                                  iobroker.inst@3.0.0 /opt/iobroker
                                  ├─┬ @iobroker/js-controller-common@4.0.24 extraneous
                                  │ └── node-forge@ deduped invalid: "^1.0.0" from node_modules/@iobroker/js-controller-common
                                  ├─┬ google-p12-pem@4.0.1 extraneous
                                  │ └── node-forge@ deduped invalid: "^1.0.0" from node_modules/@iobroker/js-controller-common, "^1.3.1" from node_modules/google-p12-pem
                                  ├── node-forge@ invalid: "^1.0.0" from node_modules/@iobroker/js-controller-common, "^1.3.1" from node_modules/google-p12-pem extraneous
                                  └─┬ rsa-compat@1.9.4 extraneous
                                    └── node-forge@0.7.6 extraneous
                                  npm ERR! code ELSPROBLEMS
                                  npm ERR! invalid: node-forge@ /opt/iobroker/node_modules/node-forge
                                  npm ERR! extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
                                  npm ERR! extraneous: node-forge@0.7.6 /opt/iobroker/node_modules/rsa-compat/node_modules/node-forge
                                  npm ERR!     /home/iobroker/.npm/_logs/2022-12-26T10_04_48_709Z-debug-0.log
                                  • N nullfreizeit
                                    npm ls node-forge
                                    @nullfreizeit
                                    iob stop
                                    iob fix
                                    iob diag
                                    • N Offline
                                      N Offline
                                      nullfreizeit
                                      Hi Thomas,
                                      hab noch mal
                                      added 4 packages, and changed 859 packages in 16m
                                      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 7777, bind: 0.0.0.0, run as: admin
                                        system.adapter.alarm.0                  : alarm                 : raspberrypi                              - disabled
                                        system.adapter.asterisk.0               : asterisk              : raspberrypi                              -  enabled, port: 5038
                                        system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                        system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                                        system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                                        system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                                        system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                                        system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
                                        system.adapter.eventlist.0              : eventlist             : raspberrypi                              - disabled
                                        system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                                      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                                        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                                        system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
                                        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
                                        system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                                        system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                                        system.adapter.landroid.0               : landroid              : raspberrypi                              - disabled
                                        system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
                                        system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1889, bind: 192.168.188.35
                                        system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
                                        system.adapter.nina.0                   : nina                  : raspberrypi                              -  enabled
                                        system.adapter.onvif.0                  : onvif                 : raspberrypi                              - disabled
                                        system.adapter.openligadb.0             : openligadb            : raspberrypi                              -  enabled
                                        system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
                                        system.adapter.pegelalarm.0             : pegelalarm            : raspberrypi                              -  enabled
                                        system.adapter.rssfeed.0                : rssfeed               : raspberrypi                              -  enabled
                                        system.adapter.sayit.0                  : sayit                 : raspberrypi                              - disabled, port: 0
                                        system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                                        system.adapter.simple-api.0             : simple-api            : raspberrypi                              - disabled, port: 8087, bind: 0.0.0.0, run as: admin
                                        system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                                        system.adapter.sony-bravia.0            : sony-bravia           : raspberrypi                              -  enabled
                                        system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
                                        system.adapter.terminal.0               : terminal              : raspberrypi                              - disabled, port: 8088, bind: 0.0.0.0, run as: admin
                                        system.adapter.time-switch.0            : time-switch           : raspberrypi                              - disabled
                                        system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                                        system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                                        system.adapter.tvspielfilm.0            : tvspielfilm           : raspberrypi                              -  enabled
                                        system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                                        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                                        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                                        system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                                        system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                                        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                                        system.adapter.vis-material.0           : vis-material          : raspberrypi                              -  enabled
                                        system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
                                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                                        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
                                        system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                                        system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
                                        system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                                        system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
                                      + instance is alive
                                      gemacht. Nun läuft Admin wieder. Backitup ist auch wieder angesprungen. Alle anderen Adapater starten aber nicht. Soll ich nochmal den fix drüber laufen lassen wie du beschrieben hast? Danke
                                      • N nullfreizeit
                                        Hi Thomas,
                                        hab noch mal
                                        + instance is alive
                                        @nullfreizeit
                                        Und
                                        iobroker diag
                                        sagt was?
                                          @nullfreizeit
                                          Und
                                          iobroker diag
                                          sagt was?
                                          N Offline
                                          N Offline
                                          nullfreizeit
                                          Das hier:
        v.2022-12-13
                                          Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
                                          Installation:           Native
                                          Timezone:               Europe/Berlin
                                          User-ID:                1000
                                          X-Server:               false
                                          Pending OS-Updates:     0
                                          Nodejs-Installation:    /usr/bin/nodejs         v16.19.0
        /usr/bin/node           v16.19.0
        /usr/bin/npm            8.19.3
                                          ioBroker Core:          js-controller           4.0.24
        admin                   6.3.5
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Pending iob updates:    0
                                          Objects:                8724
                                          States:                 7313
                                          Size of iob-Database:
                                          20M     /opt/iobroker/iobroker-data/objects.jsonl
                                          8.6M    /opt/iobroker/iobroker-data/objects.json.migrated
                                          8.6M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                          4.2M    /opt/iobroker/iobroker-data/states.jsonl
                                          3.0M    /opt/iobroker/iobroker-data/states.json.migrated
                                          3.0M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                          ====================== END OF SUMMARY ==================
                                          Allerdings hat er vor der "Summary" dies hier als Fehler angezeigt...
                                          *** ioBroker-Installation ***
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Core adapters versions
                                          js-controller:  4.0.24
                                          admin:          6.3.5
                                          npm ERR! invalid: iobroker.admin@6.3.5 /opt/iobroker/node_modules/iobroker.admin
                                          npm ERR! invalid: iobroker.backitup@2.5.9 /opt/iobroker/node_modules/iobroker.backitup
                                          npm ERR! invalid: iobroker.discovery@3.1.0 /opt/iobroker/node_modules/iobroker.discovery
                                          npm ERR! invalid: iobroker.eventlist@0.5.5 /opt/iobroker/node_modules/iobroker.eventlist
                                          npm ERR! invalid: iobroker.onvif@0.4.5 /opt/iobroker/node_modules/iobroker.onvif
                                          npm ERR! invalid: iobroker.time-switch@2.2.2 /opt/iobroker/node_modules/iobroker.time-switch
                                          npm ERR!     /home/pi/.npm/_logs/2022-12-26T10_52_10_883Z-debug-0.log
                                          Adapters from github:   3
