  3. Einsteigerfragen
  4. Installation
  5. ioBroker Installation npm Err!
Geplant Angeheftet Gesperrt Verschoben Installation
50 Beiträge 4 Kommentatoren 10.7k Aufrufe 3 Beobachtet
    @xerxes55
    uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
    sagt?
    X Offline
    X Offline
    Xerxes55
    pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
    armv7l
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v16.19.0
    v16.19.0
    8.19.3
    node:internal/modules/cjs/loader:998
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
        at Function.Module._load (node:internal/modules/cjs/loader:841:27)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
        at node:internal/main/run_main_module:22:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    pi@raspberrypi:~ $
    • X Xerxes55
      armv7l
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.19.0
      v16.19.0
      8.19.3
        throw err;
        requireStack: []
      pi@raspberrypi:~ $
      @xerxes55
      systemctl status iobroker.service
      X 1 Antwort Letzte Antwort
        @xerxes55
        X Offline
        X Offline
        Xerxes55
        pi@raspberrypi:~ $ systemctl status iobroker.service
        ● iobroker.service - ioBroker Server
             Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor pres>
             Active: active (running) since Tue 2022-12-20 22:03:13 CET; 8min ago
               Docs: http://iobroker.net
           Main PID: 7918 (iobroker.js-con)
              Tasks: 11 (limit: 3720)
                CPU: 10.455s
             CGroup: /system.slice/iobroker.service
                     └─7918 iobroker.js-controller
        Dec 20 22:03:13 raspberrypi systemd[1]: Started ioBroker Server.
        Dec 20 22:03:15 raspberrypi sudo[7967]: iobroker : PWD=/ ; USER=root ; COMMAND=>
        Dec 20 22:03:15 raspberrypi sudo[7967]: pam_unix(sudo:session): session opened >
        Dec 20 22:03:15 raspberrypi sudo[7967]: pam_unix(sudo:session): session closed >
        Dec 20 22:03:16 raspberrypi bash[7918]: object system.meta.uuid created: 9c0c44>
        Dec 20 22:03:16 raspberrypi bash[7918]: object system.user.admin created
        lines 1-16/16 (END)...skipping...
                CPU: 10.455s
        lines 1-16/16 (END)
        • X Xerxes55
                  CPU: 10.455s
                  CPU: 10.455s
          lines 1-16/16 (END)
          @xerxes55 sagte in ioBroker Installation npm Err!:
          sudo systemctl stop iobroker
          iobroker fix
          sudo systemctl start iobroker
            iobroker fix
            X Offline
            X Offline
            Xerxes55
            pi@raspberrypi:~ $ sudo systemctl stop iobroker
            pi@raspberrypi:~ $ iobroker fix
            library: loaded
            Library version=2022-12-09
            ioBroker is not installed in /opt/iobroker! Cannot fix anything...
            pi@raspberrypi:~ $ sudo systemctl start iobroker
            pi@raspberrypi:~ $
            • X Xerxes55
              library: loaded
              pi@raspberrypi:~ $
              @xerxes55
              cd /opt/iobroker
              sudo -H -u iobroker npm install iobroker.js-controller
              iobroker restart
              iobroker status
                @xerxes55
                cd /opt/iobroker
                iobroker restart
                iobroker status
                X Offline
                X Offline
                Xerxes55
                Habe die Installation noch mal gestartet und?
                pi@raspberrypi:~ $ curl -sLf https://iobroker.net/install.sh | bash -
                library: loaded
                    Welcome to the ioBroker installer!
                    Installer version: 2022-12-09
                    You might need to enter your password a couple of times.
                    Installing prerequisites (1/4)
                Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                Reading package lists... Done
                Changing npm registry to https://registry.npmjs.org
                Installed gcc-c++
                    Creating ioBroker user and directory (2/4)
                Created /etc/sudoers.d/iobroker
                Directory /opt/iobroker created
                    Installing ioBroker (3/4)
                    Finalizing installation (4/4)
                Enabling autostart...
                Autostart enabled!
                    ioBroker was installed successfully
                    Open http://192.168.178.58:8081 in a browser and start configuring!
                You need to re-login before doing anything else on the console!
                pi@raspberrypi:~ $
                Hurra, jetzt geht es, aber warum?
                • X Xerxes55
                  library: loaded
                  Installed gcc-c++
                  Autostart enabled!
                  pi@raspberrypi:~ $
                  aber warum?
                  Weil jetzt die richtige nodeJS-Version installiert ist.
                  • X Xerxes55
                    library: loaded
                    Installed gcc-c++
                    Autostart enabled!
                    pi@raspberrypi:~ $
                    @xerxes55
                    Und was sagt nun
                      aber warum?
                      X Offline
                      X Offline
                      Xerxes55
                      Aber warum diese Problem? Ich die Installation strikt nach den Anleitung gemacht. Wer installiert NodeJS. Linux oder ioBroker?
                        @xerxes55
                        Und was sagt nun
                        X Offline
                        X Offline
                        Xerxes55
                        armv7l
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v16.19.0
                        v16.19.0
                        8.19.3
                        4.0.23
                        pi
                        pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                        tty
                        /home/pi
                        nodejs:
                          Installed: 16.19.0-deb-1nodesource1
                          Candidate: 16.19.0-deb-1nodesource1
                          Version table:
                         *** 16.19.0-deb-1nodesource1 500
                                500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                                100 /var/lib/dpkg/status
                             12.22.12~dfsg-1~deb11u1 500
                                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                        pi@raspberrypi:~ $
                        • X Xerxes55
                          Der Paketmanager. Der wird auch eigentlich vom Installationsskript richtig gefüttert. Keine Ahnung was du da gemacht hast.
                          • X Xerxes55
                            armv7l
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v16.19.0
                            v16.19.0
                            8.19.3
                            4.0.23
                            pi
                            tty
                            /home/pi
                            nodejs:
                              Version table:
                            pi@raspberrypi:~ $
                            X Offline
                            X Offline
                            Xerxes55
                            @xerxes55
                            Jetzt ist ales ok? Kann ich damit produktiv arbeiten?
                            • X Xerxes55
                              @xerxes55
                              @xerxes55
                              Sollte passen.
                                X Offline
                                X Offline
                                Xerxes55
                                @thomas-braun said in ioBroker Installation npm Err!:
                                Ich habe schon mehrmals geschrieben: alles gemäß der Anleitung in dem Link am Anfang. Den Beitrag hast du auch selbst geschrieben! Bin kein Linux Fachmann!
                                • X Xerxes55
                                  da muss aber beteits eine alte nodejs vor dem Aufruf des Installers drauf gewesen sein,
                                  Deswegen wurde iobroker unvollständig installiert.
                                  Entweder du, oder wenn noch nichts drauf is installiert iobroker die momentan aktuelle Version.
                                  • X Xerxes55
                                    Das weiß ich. Und daher weiß ich auch, dass es genau so auch funktioniert.
                                      X Offline
                                      X Offline
                                      Xerxes55
                                      Ich habe die SD Karte komplett neu geschrieben, daher weiß ich nicht woher das kommt. Trotzdem vielen, vielen Dank!
                                      • C Offline
                                        Chris982
                                        Hey, habe ein ähnliches Problem, wollte das updateaus dem iobroker machen aber irgendwas ist schief gelaufen.
                                        Habe danach schon einiges versucht zu deinstallieren wie die node und iobroker aber jetzt geht gar nix mehr.
                                        wenn ich über den installtions link den iobroker neu installieren will kommt:
                                        OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                        OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                        OK:3 https://repos.influxdata.com/debian bullseye InRelease
                                        OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                                        OK:5 https://packages.grafana.com/enterprise/deb stable InRelease
                                        npm ERR! builtins is not a function
                                        npm ERR! /home/pi/.npm/_logs/2022-12-21T18_56_11_280Z-debug-0.log
                                        Installed gcc-c++
                                        npm ERR! /home/pi/.npm/_logs/2022-12-21T18_56_16_582Z-debug-0.log
                                        Autostart enabled!
                                        Open http://192.168.1.95 10.8.0.1:8081 in a browser and start configuring!
                                        eine idee was ich machen kann? er ist definitv nicht mehr erreichbar
                                        • C Chris982
                                          Installed gcc-c++
                                          Autostart enabled!
                                          @chris982
                                          Setz das in CodeTags.
                                          C 1 Antwort Letzte Antwort
