  3. Einsteigerfragen
  4. Installation
  5. ioBroker Installation npm Err!
50 Beiträge 4 Kommentatoren 10.7k Aufrufe 3 Beobachtet
  • X Xerxes55
    pi@raspberrypi:~ $ systemctl status iobroker.service
    ● iobroker.service - ioBroker Server
         Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor pres>
         Active: active (running) since Tue 2022-12-20 22:03:13 CET; 8min ago
           Docs: http://iobroker.net
       Main PID: 7918 (iobroker.js-con)
          Tasks: 11 (limit: 3720)
            CPU: 10.455s
         CGroup: /system.slice/iobroker.service
                 └─7918 iobroker.js-controller
    Dec 20 22:03:13 raspberrypi systemd[1]: Started ioBroker Server.
    Dec 20 22:03:15 raspberrypi sudo[7967]: iobroker : PWD=/ ; USER=root ; COMMAND=>
    Dec 20 22:03:15 raspberrypi sudo[7967]: pam_unix(sudo:session): session opened >
    Dec 20 22:03:15 raspberrypi sudo[7967]: pam_unix(sudo:session): session closed >
    Dec 20 22:03:16 raspberrypi bash[7918]: object system.meta.uuid created: 9c0c44>
    Dec 20 22:03:16 raspberrypi bash[7918]: object system.user.admin created
    lines 1-16/16 (END)...skipping...
            CPU: 10.455s
    lines 1-16/16 (END)
    @xerxes55 sagte in ioBroker Installation npm Err!:
    sudo systemctl stop iobroker
    iobroker fix
    sudo systemctl start iobroker
    X 1 Antwort Letzte Antwort
      iobroker fix
      X Offline
      X Offline
      Xerxes55
      pi@raspberrypi:~ $ sudo systemctl stop iobroker
      pi@raspberrypi:~ $ iobroker fix
      library: loaded
      Library version=2022-12-09
      ioBroker is not installed in /opt/iobroker! Cannot fix anything...
      pi@raspberrypi:~ $ sudo systemctl start iobroker
      pi@raspberrypi:~ $
      • X Xerxes55
        library: loaded
        pi@raspberrypi:~ $
        @xerxes55
        cd /opt/iobroker
        sudo -H -u iobroker npm install iobroker.js-controller
        iobroker restart
        iobroker status
          @xerxes55
          cd /opt/iobroker
          iobroker restart
          iobroker status
          X Offline
          X Offline
          Xerxes55
          Habe die Installation noch mal gestartet und?
          pi@raspberrypi:~ $ curl -sLf https://iobroker.net/install.sh | bash -
          library: loaded
              Welcome to the ioBroker installer!
              Installer version: 2022-12-09
              You might need to enter your password a couple of times.
              Installing prerequisites (1/4)
          Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
          Reading package lists... Done
          Changing npm registry to https://registry.npmjs.org
          Installed gcc-c++
              Creating ioBroker user and directory (2/4)
          Directory /opt/iobroker created
              Installing ioBroker (3/4)
              Finalizing installation (4/4)
          Enabling autostart...
          Autostart enabled!
              ioBroker was installed successfully
              Open http://192.168.178.58:8081 in a browser and start configuring!
          You need to re-login before doing anything else on the console!
          pi@raspberrypi:~ $
          Hurra, jetzt geht es, aber warum?
          • X Xerxes55
            library: loaded
            Installed gcc-c++
            Autostart enabled!
            pi@raspberrypi:~ $
            aber warum?
            Weil jetzt die richtige nodeJS-Version installiert ist.
            • X Xerxes55
              library: loaded
              Installed gcc-c++
              Autostart enabled!
              pi@raspberrypi:~ $
              @xerxes55
              Und was sagt nun
              uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
                aber warum?
                X Offline
                X Offline
                Xerxes55
                Aber warum diese Problem? Ich die Installation strikt nach den Anleitung gemacht. Wer installiert NodeJS. Linux oder ioBroker?
                  @xerxes55
                  Und was sagt nun
                  X Offline
                  X Offline
                  Xerxes55
                  pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
                  armv7l
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v16.19.0
                  v16.19.0
                  8.19.3
                  4.0.23
                  pi
                  pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                  tty
                  /home/pi
                  nodejs:
                    Installed: 16.19.0-deb-1nodesource1
                    Candidate: 16.19.0-deb-1nodesource1
                    Version table:
                   *** 16.19.0-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                       12.22.12~dfsg-1~deb11u1 500
                  pi@raspberrypi:~ $
                  • X Xerxes55
                    Der Paketmanager. Der wird auch eigentlich vom Installationsskript richtig gefüttert. Keine Ahnung was du da gemacht hast.
                    • X Xerxes55
                      armv7l
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v16.19.0
                      v16.19.0
                      8.19.3
                      4.0.23
                      pi
                      tty
                      /home/pi
                      nodejs:
                        Version table:
                      pi@raspberrypi:~ $
                      X Offline
                      X Offline
                      Xerxes55
                      @xerxes55
                      Jetzt ist ales ok? Kann ich damit produktiv arbeiten?
                      • X Xerxes55
                        @xerxes55
                        @xerxes55
                        Sollte passen.
                          X Offline
                          X Offline
                          Xerxes55
                          @thomas-braun said in ioBroker Installation npm Err!:
                          Ich habe schon mehrmals geschrieben: alles gemäß der Anleitung in dem Link am Anfang. Den Beitrag hast du auch selbst geschrieben! Bin kein Linux Fachmann!
                          • X Xerxes55
                            da muss aber beteits eine alte nodejs vor dem Aufruf des Installers drauf gewesen sein,
                            Deswegen wurde iobroker unvollständig installiert.
                            Entweder du, oder wenn noch nichts drauf is installiert iobroker die momentan aktuelle Version.
                            • X Xerxes55
                              Das weiß ich. Und daher weiß ich auch, dass es genau so auch funktioniert.
                                X Offline
                                X Offline
                                Xerxes55
                                Ich habe die SD Karte komplett neu geschrieben, daher weiß ich nicht woher das kommt. Trotzdem vielen, vielen Dank!
                                • C Offline
                                  Chris982
                                  Hey, habe ein ähnliches Problem, wollte das updateaus dem iobroker machen aber irgendwas ist schief gelaufen.
                                  Habe danach schon einiges versucht zu deinstallieren wie die node und iobroker aber jetzt geht gar nix mehr.
                                  wenn ich über den installtions link den iobroker neu installieren will kommt:
                                  OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                  OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                  OK:3 https://repos.influxdata.com/debian bullseye InRelease
                                  OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                                  OK:5 https://packages.grafana.com/enterprise/deb stable InRelease
                                  npm ERR! builtins is not a function
                                  npm ERR! /home/pi/.npm/_logs/2022-12-21T18_56_11_280Z-debug-0.log
                                  Installed gcc-c++
                                  npm ERR! /home/pi/.npm/_logs/2022-12-21T18_56_16_582Z-debug-0.log
                                  Autostart enabled!
                                  Open http://192.168.1.95 10.8.0.1:8081 in a browser and start configuring!
                                  eine idee was ich machen kann? er ist definitv nicht mehr erreichbar
                                  • C Chris982
                                    Installed gcc-c++
                                    Autostart enabled!
                                    @chris982
                                    Setz das in CodeTags.
                                    C 1 Antwort Letzte Antwort
                                      @chris982
                                      Chris982
                                      Installed gcc-c++
                                      Autostart enabled!
                                      meinst du so?
                                      • C Chris982
                                        Installed gcc-c++
                                        Autostart enabled!
                                        meinst du so?
                                        @chris982
                                        Check deine nodejs-Installation. Ich vermute die ist/war mal krumm.
                                          @chris982
                                          Chris982
                                          pi@raspberrypi:~ $ apt policy nodejs
                                          nodejs
                                          nodejs:
                                            Installiert:           16.19.0-deb-1nodesource1
                                            Installationskandidat: 16.19.0-deb-1nodesource1
                                            Versionstabelle:
                                          Welcome to Node.js v16.19.0.
                                          Type ".help" for more information.
                                          ich denke auch weil da 2 nodejs installiert sind. aber wie kann ich die 12.22.12 löschen?
